- 11-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PTP commands
- 06-SNMP commands
- 07-RMON commands
- 08-NETCONF commands
- 09-SmartMC commands
- 10-EPA commands
- 10-EPA commands (only for H3C devices)
- 11-CWMP commands
- 12-EAA commands
- 13-Process monitoring and maintenance commands
- 14-Sampler commands
- 15-Mirroring commands
- 16-NetAnalysis commands
- 17-sFlow commands
- 18-Information center commands
- 19-Packet capture commands
- 20-VCF fabric commands
- 21-NetStream commands
- 22-IPv6 NetStream commands
- 23-eMDI commands
- 24-Performance management commands
- 25-Cloud connection commands
- 26-SQA commands
- 27-TCP connection trace commands
20-VCF fabric commands | 100.36 KB |
display vcf-fabric underlay autoconfigure
display vcf-fabric underlay template-version
vcf-fabric underlay netconf-username
vcf-fabric underlay netconf-password
VCF fabric commands
display vcf-fabric role
Use display vcf-fabric role to display the role of the device in the VCF fabric.
Use this command to display the default role and the current role of the device in the VCF fabric. To change the current role of the device, use the vcf-fabric role command.
# Display the role of the device in the VCF fabric.
<System> display vcf-fabric role
Default role: leaf
Current role: leaf
Default role |
Default role of the device: |
Current role |
Current role of the device: |
vcf-fabric role
display vcf-fabric topology
Use display vcf-fabric topology to display VCF fabric topology information.
This command displays VCF fabric topology information only when it is executed on the master spine node.
Before you display VCF fabric topology information, make sure VCF fabric topology discovery and automated underlay network deployment are enabled.
# Display VCF fabric topology information.
<Sysname> display vcf-fabric topology
Topology Information
* indicates the master spine role among all spines
SpineIP Interface Link LeafIP Status
*10.11.113.51 Ten-GigabitEthernet1/0/1 Up 10.11.113.52 Deploying
Ten-GigabitEthernet1/0/2 Down -- --
Ten-GigabitEthernet1/0/3 Down -- --
Ten-GigabitEthernet1/0/4 Down -- --
Ten-GigabitEthernet1/0/5 Up 10.11.113.53 Deploying
Ten-GigabitEthernet1/0/6 Down -- --
Ten-GigabitEthernet1/0/7 Down -- --
Ten-GigabitEthernet1/0/8 Down -- --
SpineIP |
IPv4 address of the management Ethernet interface on the spine node. This field displays an asterisk (*) before the IP address if the device is the master spine node. |
Interface through which the spine node connects to a leaf node. If the device is a master spine node, all interfaces on the device are displayed. |
Link |
Physical link state of the interface. |
LeafIP |
IPv4 address of the interface through which a leaf node connects to the spine node. |
Status |
Status of automated underlay network deployment on the leaf node. This field displays two hyphens (--) if automated underlay network deployment is not started. This field displays Deploying if automated underlay network deployment is in progress. |
vcf-fabric topology enable
Use display vcf-fabric underlay autoconfigure to display information about automated underlay network deployment.
Before you execute this command, make sure automated underlay network deployment is enabled.
# Display information about automated underlay network deployment.
<Sysname> display vcf-fabric underlay autoconfigure
success command:
system
clock timezone beijing add 08:00:00
system
lldp global enable
lldp compliance cdp
system
ospf 1
graceful-restart ietf
area 0.0.0.0
system
interface LoopBack0
system
l2vpn enable
system
vxlan tunnel arp-learning disable
system
stp global enable
system
ntp-service enable
ntp-service unicast-peer 172.16.1.136
system
netconf soap https enable
restful https enable
system
info-center loghost 172.16.1.136
system
local-user aaa
password ******
service-type https
system
line vty 0 63
authentication-mode scheme
system
bgp 100
graceful-restart
address-family l2vpn evpn
system
system
neutron
rabbit user openstack
rabbit password ******
rabbit host ip 172.16.1.136
restful user aaa password ******
vpn-target 1:1 export-extcommunity
vsi-mac 789c-2f5f-0200
network-type distributed-vxlan
proxy-arp enable
l2agent enable
l3agent enable
system
snmp-agent
snmp-agent packet max-size 4096
snmp-agent community read public
snmp-agent community write private
snmp-agent sys-info version all
Uplink interface:
Downlink interface:
AP-side interfaces:
Loopback0 IP allocation:
Device_MAC Loopback_IP Management_IP State
a43c-adae-0400 200.1.1.6 172.16.1.193 Up
a43c-9aa7-0100 200.1.1.4 172.16.1.152 Up
Loopback1 IP allocation:
a43c-adae-0400 100.1.1.6 172.16.1.193 Up
a43c-9aa7-0100 100.1.1.4 172.16.1.152 Up
Aggregation configuration:
AggrID: 7
interface: Ten-GigabitEthernet1/0/5
interface: Ten-GigabitEthernet1/0/6
IRF allocation:
Self Bridge Mac: a43c-adae-0400
IRF Status: Yes
Member List: [1, 2]
BGP peer configuration:
Device_MAC: 265b-208d-0300
Device_role:leaf
BGP peer list:
200.1.4.5
Device_MAC: 1ea6-06a4-0500
Device_role:spine
BGP peer list:
200.1.4.4
200.1.4.7
Device_MAC: 1ead-aed1-0600
Device_role:leaf
BGP peer list:
200.1.4.5
Device_role:leaf
BGP peer list:
200.1.4.5
Device_role:spine
BGP peer list:
200.1.4.4
200.1.4.7
Device_role:leaf
BGP peer list:
200.1.4.5
success command |
Commands that have been successfully executed during automated underlay network deployment. |
Uplink interface |
Uplink interfaces of the device. |
Downlink interface |
Downlink interfaces of the device. |
Loopback0 IP allocation |
IP addresses assigned to Loopback 0. |
Loopback1 IP allocation |
IP addresses assigned to Loopback 1. |
Aggregation configuration |
Information about Layer 2 aggregation groups. |
IRF allocation |
IRF configurations, including IRF bridge MAC address of the IRF fabric, IRF status, and the IRF member ID of the device. |
BGP peer configuration |
Information about BGP peers of the device. NOTE: BGP peer information on all spine and leaf nodes is displayed only when this command is executed on the master spine node in a spine-aggregate-leaf VCF fabric. |
Use display vcf-fabric underlay template-version to display the supported version and the current version of the template file for automated VCF fabric deployment.
The version format of a template file for automated VCF fabric deployment is x.y. Only the x part is examined during a version compatibility check. For successful automated deployment, make sure x in the version of the template file to be used is not greater than x in the supported version.
# Display the supported version and the current version of the template file for automated VCF fabric deployment when automated deployment is not started.
<Sysname> display vcf-fabric underlay template-version
Supported template version: 14.0
Current template version: Not available
# Display the supported version and the current version of the template file for automated VCF fabric deployment when automated deployment has finished.
Current template version: 14.0
Supported template version |
Supported version of the template file for automated VCF fabric deployment. |
Current template version |
Current version of the template file for automated VCF fabric deployment. This field displays Not available if automated VCF fabric deployment has not started. This field displays None if automated VCF fabric deployment has finished but the template file does not contain a version number. |
vcf-fabric role
Use vcf-fabric role to specify the role of the device.
Use undo vcf-fabric role to restore the default.
vcf-fabric role { access | aggr | leaf | spine }
The device is a leaf node.
Neutron view
access: Specifies the access node.
aggr: Specifies the aggregate node.
leaf: Specifies the leaf node.
spine: Specifies the spine node.
If you change the role of the device, the new role takes effect after the device restarts.
# Specify the device as a spine node.
[Sysname] vcf-fabric role spine
vcf-fabric spine-role master
Use vcf-fabric spine-role master to specify the device as a master spine node.
Use undo vcf-fabric spine-role master to restore the default.
The device is not a master spine node.
You must execute this command on a spine node.
When multiple spines nodes exist in the VCF fabric, you must specify a device as the master spine node to collect the topology for the entire VCF fabric.
For the new role to take effect, you must restart the automated underlay network deployment. To restart the automated underlay network deployment, execute the undo vcf-fabric underlay autoconfigure command and then the vcf-fabric underlay autoconfigure command.
# Specify the device as a master spine.
[Sysname] vcf-fabric spine-role master
For this configuration to take effect, you must execute the undo vcf-fabric underlay autoconfigure and vcf-fabric underlay autoconfigure commands in sequence.
vcf-fabric role
Use vcf-fabric topology enable to enable VCF fabric topology discovery.
Use undo vcf-fabric topology enable to disable VCF fabric topology discovery.
VCF fabric topology discovery is disabled.
# Enable VCF fabric topology discovery.
[Sysname] vcf-fabric topology enable
Use vcf-fabric underlay autoconfigure to specify the template file for automated underlay network deployment.
Use undo vcf-fabric underlay autoconfigure to cancel automated underlay network deployment.
vcf-fabric underlay autoconfigure template
No template file is specified for automated underlay network deployment.
template: Specifies a template file by its name, a case-insensitive string of 1 to 127 characters. A template file is a file ending with the .template file extension.
After this command is executed, the device uses the specified template file to deploy the underlay network.
If you re-execute this command after automated underlay network deployment is cancelled, the spine node will assign different IP addresses to loopback interfaces on leaf nodes. Thus, the leaf nodes will go offline and come online again.
# Specify template file vxlan_leaf.template for automated underlay network deployment.
[Sysname] vcf-fabric underlay autoconfigure vxlan_leaf.template
Use vcf-fabric underlay netconf-username to set the NETCONF username.
Use undo vcf-fabric underlay netconf-username to restore the default.
vcf-fabric underlay netconf-username username
The device uses the NETCONF username defined in the template file for automated VCF fabric deployment.
username: Specifies the username used by the spine device to collect the global topology through NETCONF, a case-sensitive string of 1 to 63 characters.
This command is available on spine nodes.
During automated underlay network deployment, a spine node establishes NETCONF sessions with other devices in the underlay network to collect the global topology. If a user changes the username or password on a device in the undelay network, the NETCONF session between the device and the spine node is disconnected. Thun, the spine node fails to sense the topology change. To resolve the issue, use this command to change the NETCONF username on the spine node.
Make sure all devices in the underlay network use the same username and password for NETCONF session establishment.
# Set the NETCONF username to aaa.
[Sysname] vcf-fabric underlay netconf-username aaa
Use vcf-fabric underlay netconf-password to set the NETCONF password.
Use undo vcf-fabric netconf-underlay password to restore the default.
vcf-fabric underlay netconf-password { cipher | simple } string
undo vcf-fabric underlay netconf-password
The device uses the NETCONF password defined in the template file for automated VCF fabric deployment.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive. Its plaintext form is a string of 1 to 63 characters. Its encrypted form is a string of 1 to 127 characters.
During automated underlay network deployment, a spine node establishes NETCONF sessions with other devices in the underlay network to collect the global topology. If a user changes the username or password on a device in the undelay network, the NETCONF session between the device and the spine node is disconnected. Thun, the spine node fails to sense the topology change. To resolve the issue, use this command to change the NETCONF password on the spine node.
# Set the NETCONF password to aaa in plaintext form.
[Sysname] vcf-fabric underlay netconf-password simple aaa
vcf-fabric underlay pause
Use vcf-fabric underlay pause to pause automated underlay network deployment.
Use undo vcf-fabric underlay pause to continue automated underlay network deployment.
Automated underlay network deployment is not paused.
You can use this command to pause automated underlay network deployment if the device is in the process of automated underlay network deployment.
# Pause automated underlay network deployment.
[Sysname] vcf-fabric underlay pause
