H3C S12500CR Switch Series Hardware Reference-6W101
HomeSupportSwitchesS12500R SeriesProduct LiteratureHardware Information & SpecificationsH3C S12500CR Switch Series Hardware Reference-6W101
01-Hardware Reference
01-Hardware Reference 18.10 MB
1 Chassis· 1-1
Chassis views· 1-1
Chassis components· 1-2
Technical specifications· 1-5
Weights and dimensions· 1-5
System power consumption· 1-6
Heat dissipation· 1-6
Environmental specifications· 1-6
2 Modules· 2-1
Naming conventions· 2-1
SEU naming conventions· 2-1
Interface module naming conventions· 2-2
Fabric module naming conventions· 2-2
Module compatibility matrixes· 2-3
Restriction and guidelines· 2-4
SEUs· 2-4
Environment management modules· 2-4
Interface modules· 2-5
Fabric modules· 2-5
Type K SEUs· 2-6
LSXM1SUPKR1· 2-6
LSXM1SUPKAR1· 2-9
Type S SEUs· 2-11
LSXM1SUPRS2· 2-11
LSXM3SUPRS2-G1· 2-14
Type K environment management modules· 2-16
LSXM1CMUR1· 2-17
Type S environment management modules· 2-19
LSXM1CMURS2/LSXM3CMURS2-G3· 2-19
Interface module adapters· 2-21
Type K 400G interface modules· 2-22
LSXM1CDMS36KCR1· 2-22
LSXM1CDQ36KBR1· 2-23
LSXM1CDQ24KB1· 2-24
LSXM1CDQ24KBR1· 2-26
LSXM1CDQ18KCR1· 2-27
Type K 200G interface modules· 2-29
LSXM1CCQ48KBR1· 2-29
Type K 100G interface modules· 2-30
LSXM1CGQ72KCR1· 2-30
LSXM1CGQ48KB1· 2-32
LSXM2CGQ48KBR1· 2-33
LSXM1CGMS48KBR1· 2-35
LSXM1CGQ48KBR1· 2-36
LSXM1CGQFX16KBR1· 2-38
Type K 24KBR flexible line processing platform modules· 2-39
LSXM1MOD24KBR1· 2-39
Type S 400G interface modules· 2-40
LSXM3CDHQ36RSG2· 2-40
LSXM3CDQ16SF2· 2-41
LSXM3CDQ8SF2· 2-43
Type S 200G interface modules· 2-44
LSXM3CCQ36SG2· 2-44
Type S 100G interface modules· 2-45
LSXM3CGQ48SG2/LSXM4CGQ48SG2· 2-45
LSXM4CGQ36SF2/LSXM4CGQ36SF2-G3· 2-47
LSXM3CGQ36SF2· 2-48
LSXM3CGQ18SF2/LSXM3CGQ18SF2-G3· 2-49
Type S 40G interface modules· 2-51
LSXM3QGS36SF2/LSXM3QGS36SF2-G3· 2-51
Type S 25G interface modules· 2-52
LSXM3YGS48SF2/LSXM3YGS48SF2-G3· 2-52
Type S 10G interface modules· 2-54
LSXM3TGS48SF2/LSXM3TGS48SF2-G3· 2-54
LSXM3TGT48CQSF2· 2-55
Interface modules available for the LSXM1MOD24KBR1 flexible line processing platform module· 2-57
LSXM1CGQ18C1· 2-57
LSXM1CGQ8C1· 2-59
LSXM1TGS24C1· 2-60
Type K fabric modules· 2-61
LSXM1SFK16ER1· 2-61
LSXM1SFK16GR1· 2-62
LSXM1SFK08ER1· 2-63
LSXM1SFK08FR1· 2-65
LSXM1SFK08GR1· 2-66
Type S fabric modules· 2-67
LSXM3SFS16F2/LSXM3SFS16F2-G3· 2-67
LSXM3SFS16G2/LSXM3SFS16G2-G3· 2-68
LSXM3SFS16H2/LSXM3SFS16H2-G3· 2-69
LSXM3SFS08F2/LSXM3SFS08F2-G3· 2-70
LSXM3SFS08G2/LSXM3SFS08G2-G3· 2-71
LSXM3SFS08H2/LSXM3SFS08H2-G3· 2-73
LSXM3SFS08K2· 2-74
Fabric module filler panels· 2-75
Slide rails· 2-76
LSXM1BSR· 2-76
3 Power trays and power supplies· 3-1
Power supplies· 3-1
PSR2000B-54D·· 3-1
PSR3000B-54AHD·· 3-2
4 Fan trays· 4-1
Fan tray compatibility information· 4-1
FAN-80-9-A/FAN-80-9-A-G3· 4-1
FAN-80-5-A/FAN-80-5-A-G3· 4-4
FAN-80B-5-B-G3 (high performance) 4-7
5 Cables· 5-1
DC power cord· 5-2
AC power cord· 5-2
Console cable· 5-2
Connecting a DB9-to-RJ45 console cable· 5-3
Connecting a USB-to-RJ45 console cable· 5-4
Ethernet twisted pair cable· 5-6
Introduction· 5-6
Application scenarios· 5-6
Maximum transmission distance· 5-6
RJ-45 connector 5-6
Cable pinouts· 5-6
Cable type· 5-7
Pin assignments· 5-8
Making an Ethernet twisted pair cable· 5-9
Optical fiber 5-10
Introduction· 5-10
Precautions· 5-11
SFP+/SFP28 copper cable· 5-11
SFP+ AOC/SFP28 AOC cable· 5-12
QSFP+ copper cable· 5-12
QSFP28 copper cable· 5-13
QSFP+ AOC/QSFP28 AOC cable· 5-13
QSFP+ to SFP+/QSFP28 to SFP28 copper cable· 5-14
QSFP112 AOC cable· 5-14
QSFP112 to 2QSFP112 AOC cable· 5-14
QSFP-DD copper cable· 5-15
1 Chassis
H3C S12500CR Ethernet Switch Series is a new generation of rack switches designed for data center core networks. It optimizes the CLOS switching fabric architecture and features powerful forwarding performance and various traffic scheduling features.
Unless otherwise stated, supervisor engine units (SEUs), interface modules, fabric modules, and environment management modules are collectively referred to as "modules" in this document.
Chassis views
The chassis views in this section are for illustration only.
H3C S12500CR switch series includes the S12516CR and S12508CR switch models.
Figure1-1 S12516CR
Figure1-2 S12508CR
Chassis components
The switch has the following sections: interface module section, power supply section, fan tray section, fabric module section, SEU section, and environment management module section. The following figures use the S12516CR switch for illustration.
Figure1-3 Front and rear views of the S12516CR switch
Table1-1 Section descriptions for the S12516CR switch
Section
Location identification
Power supply section
N/A
Power supplies are required.
·     On an S12516CR switch installed with Type K modules, install a minimum of four power trays and four power supplies. On an S12516CR switch installed with Type S modules, install a minimum of two power trays and two power supplies.
·     On an S12508CR switch installed with Type K modules, install a minimum of two power trays and two power supplies. On an S12508CR switch installed with Type S modules, install a minimum of one power tray and two power supplies.
The switch supports N+N (dual power inputs) or N+1 (single power input) power supply redundancy. Determine the number of power supplies based on the power supply mode and system power consumption.
You can install a power supply in any of the empty power supply slots.
Environment management module section
N/A
Environment management modules are required.
The switch has two environment management module slots. You must install two environment management modules on the switch.
SEU section
The ejector lever pillow blocks on the SEU slots are pink marked. The SEU ejector levers are also pink marked to suggest the corresponding installation location.
SEUs are required.
·     The switch has two SEU slots. You can install one SEU, or two SEUs for redundancy on the switch.
·     To install only one SEU on the switch, you can install it in either of the SEU slots.
Interface module section
The ejector lever pillow blocks on interface module slots are purple marked. The interface module edges and ejector levers are also purple marked to suggest the corresponding installation location.
Interface modules are required.
·     S12516CR—16 interface module slots.
·     S12508CR—8 interface module slots.
Prepare appropriate type and number of interface modules for the switch as required. You can install an interface module in any of the empty interface module slots.
Fan tray section
N/A
Fan trays are required.
The switch has five fan tray slots.
To ensure adequate heat dissipation when you install Type K modules, make sure the five fan tray slots are all installed with fan trays.
When you install Type S modules that include the LSXM3CDHQ36RSG2 or LSXM3CDHQ36SG2 interface module, make sure the five fan tray slots are all installed with fan trays. If the modules do not include the LSXM3CDHQ36RSG2 or LSXM3CDHQ36SG2 interface module, make sure a minimum of three fan tray slots are installed with fan trays.
Fabric module section
The fabric module slots are behind fan trays.
Fabric modules are required.
·     The switch has nine fabric module slots. Prepare appropriate type and number of fabric modules for the switch as required.
·     Fan trays cover fabric module slots. To remove a fabric module, first remove the fan tray that covers the fabric module.
Table1-2 describes the slot arrangement for removable components.
Table1-2 Slot arrangement for removable components
Switch model
SEU
Interface module
Fabric module
Power supply
Power tray
Fan tray
S12516CR
Slots 0 and 1
Slots 2 and 3
Slots 4 to 19
Slots 20 to 28
Slots 20 and 21 are covered by FAN 1.
Slots 22 and 23 are covered by FAN 2.
Slots 24 and 25 are covered by FAN 3.
Slots 26 and 27 are covered by FAN 4.
Slot 28 is covered by FAN 5.
PWR 1 to PWR 6
PEM 1 to PEM 6
Each power tray has six power supply slots PWR 1 to PWR 6.
FAN 1 to FAN 5
S12508CR
Slots 0 to 1
Slots 2 to 3
Slots 4 to 11
Slots 12 to 20
Slots 12 and 13 are covered by FAN 1.
Slots 14 and 15 are covered by FAN 2.
Slots 16 and 17 are covered by FAN 3.
Slots 18 and 19 are covered by FAN 4.
Slot 20 is covered by FAN 5.
PWR 1 to PWR 6
PEM 1 to PEM 4
FAN 1 to FAN 5
The switch uses modular design. Its weight includes the chassis (including mounting brackets and filler panels) and its removable components (including modules, power supplies, fan trays, interface modules, and other removable components).
Table1-3 Chassis weights and dimensions
Switch model
Weight
Height
Width
Depth
S12516CR
111.6 kg (246.03 lb)
1331 mm (52.40 in)/30 RUs
442 mm (17.40 in)
920 mm (36.22 in)
S12508CR
82.4 kg (181.66 lb)
842 mm (33.15 in)/19 RUs
442 mm (17.40 in)
920 mm (36.22 in)
·     Rack Unit (RU) is a measurement unit used to indicate the height of a rack. 1 RU is equal to 44.45 mm (1.75 in).
·     The dimensions are the dimensions of the chassis, excluding the dimensions of mounting brackets, cable management brackets, modules, power supplies, and other accessories.
·     For the weights and dimensions of modules, power supplies, fan trays, interface modules, and other removable components, see the descriptions for the components.
The system power consumption of the switch depends on the type and number of modules and the fan tray power consumption.
·     The minimum system power consumption is the total static power consumption of all modules plus the minimum fan tray power consumption.
·     The maximum system power consumption is the total dynamic power consumption of all modules plus the maximum fan tray power consumption.
For example, for an S12516CR switch that has two LSXM1SUPKR1 SEUs, two LSXM1CMUR1 environment management modules, two LSXM1CGQ48KBR1 interface modules, six LSXM1SFK16GR1 fabric modules, and five FAN-80-9-A fan trays, the minimum system power consumption of the switch is 2 × 50 + 2 × 22 + 2 × 395 + 6 × 471 + 5 × 54 = 4030 W. The maximum system power consumption of the switch is 2 × 60 + 2 × 26 + 2 × 765 + 6 × 822 + 5 × 1105 = 12159 W.
Heat dissipation
The heat generated by the switch is closely related to its power consumption. It is typically assumed that 90% of the power consumption is converted to heat, and the power supply's conversion efficiency is 90%. Heat dissipation/hour of the switch is 0.9 × (total power consumption of the modules plus power consumption of the fan trays)/0.9 × 3.4121.
For the power consumption of the modules and fan trays, see "Modules" and "Fan trays."
The unit of heat is typically measured in BTU/h, and 1 watt is equal to 3.4121 BTU/h.
Table1-4 Environmental specifications
Item
Operating
Storage
Temperature
0°C to 40°C (32°F to 104°F)
–40°C to +70°C (–40°F to +158°F)
Relative humidity
5% to 95%, noncondensing
2 Modules
The switch supports varieties of modules that are different in power consumptions. For a module, its power consumption varies by its state.
·     The minimum power consumption of a module refers to the power consumed by the module when it is running with all its ports down and its fiber ports not installed with transceiver modules.
·     The typical power consumption of a module refers to the power consumed by the module when it is running with 50% of its ports connected and at 50% load.
·     The maximum power consumption of a module refers to the power consumed by the module when it is running with all its ports connected and at full load.
·     For the transceiver modules or cables available for the modules, see H3C S12500CR Switch Router Series Type-K Modules and Transceivers Compatibility Matrix and H3C S12500CR Switch Router Series Type-S Modules and Transceivers Compatibility Matrix.
·     Module dimensions are expressed in Height (H) × Width (W) × Depth (D) format:
¡     Height—Height of the front panel of the module.
¡     Width—Width of the front panel of the module.
¡     Depth—Depth from the front panel of the module to the connector (including the connector, but excluding the ejector levers and captive screws).
Naming conventions
Figure2-1 SEU naming conventions
Table2-1 SEU naming conventions
No.
1
Product line. LS represents the switch product line.
2
Product series, which is fixed at X.
3
Distinguisher.
4
Module type.
5
SEU type.
6
Extended attribute.
Figure2-2 Interface module naming conventions
Table2-2 Interface module naming conventions
No.
1
2
3
Distinguisher.
4
Main interface type.
5
Feature supported by the interface module. For example, MS indicates MACsec, and FX indicates FlexE.
6
Number of main interfaces.
7
Interface module type.
8
Extended attribute.
Figure2-3 Fabric module naming conventions
Table2-3 Fabric module naming conventions
No.
1
2
3
Distinguisher.
4
Module type. SF represents the fabric module.
5
Fabric module type. Values include:
·     K—Type K fabric module.
·     S—Type S fabric module.
6
Compatible switch model:
·     16 represents that the fabric module is compatible with the S12516CR switch.
·     08 represents that the fabric module is compatible with the S12508CR switch.
7
Fabric module class. Values include:
·     ER.
·     GR.
8
Extended attribute.
The switch supports Type K and Type S modules. To avoid module damage or operation anomalies, do not install both types of modules on the same switch.
·     Type K SEUs (for example, LSXM1SUPKR1) can be used together only with Type K interface modules (for example, LSXM1CGQ48KBR1), LSXM1CMUR1 environment management module, and Type K fabric modules (for example, LSXM1SFK08GR1).
·     Type S SEUs (for example, LSXM3SUPRS2-G1) can be used together only with Type S interface modules (for example, LSXM3TGS48SF2), Type S environment management module (for example, LSXM3CMURS2-G3), and Type S fabric modules (for example, LSXM3SFS08F2).
When you use Type S SG interface modules, strictly follow the guidelines below:
·     For the LSXM3CGQ48SG2 or LSXM3CCQ36SG2 interface module, follow these guidelines:
¡     On an S12508CR switch, the interface module can be used together with all Type S fabric modules and cannot be used together with the FAN-80-5-A fan tray.
¡     On an S12516CR switch, the interface module can be used together only with Type S Class H fabric modules and cannot be used together with the FAN-80-9-A fan tray.
·     The LSXM4CGQ48SG2 interface module can be used together only with Type S Class K fabric modules and cannot be used together with the FAN-80-5-A or FAN-80-9-A fan tray.
·     The LSXM3CDHQ36RSG2 interface module can be used together only with Type S Class K fabric modules and high-performance fan trays.
Table2-4 Type K module compatibility matrix
Switch model
SEU
Fabric module
Interface module
S12516CR
LSXM1SUPKR1
LSXM1SUPKAR1
LSXM1CMUR1
·     LSXM1SFK16ER1
·     LSXM1SFK16GR1
Type K interface modules (for example, LSXM1CGQ48KBR1).
For more information about Type K interface modules, see the related sections in this chapter.
S12508CR
·     LSXM1SFK08ER1
·     LSXM1SFK08FR1
·     LSXM1SFK08GR1
Table2-5 Type S module compatibility matrix
Switch model
SEU
Fabric module
Interface module
S12516CR
LSXM1SUPRS2
LSXM3SUPRS2-G1
LSXM1CMURS2
LSXM3CMURS2-G3
·     LSXM3SFS16F2
·     LSXM3SFS16G2
·     LSXM3SFS16H2
·     LSXM3SFS16F2-G3
·     LSXM3SFS16G2-G3
·     LSXM3SFS16H2-G3
Type S interface modules (for example, LSXM3TGS48SF2).
For more information about Type S interface modules, see the related sections in this chapter.
S12508CR
·     LSXM3SFS08G2
·     LSXM3SFS08F2
·     LSXM3SFS08H2
·     LSXM3SFS08G2-G3
·     LSXM3SFS08F2-G3
·     LSXM3SFS08H2-G3
·     LSXM3SFS08K2
To verify compatibility of modules with the software release you are using, see the release notes.
For the transceiver modules and cables available for the modules, see H3C S12500CR Switch Router Series Type-K Modules and Transceivers Compatibility Matrix and H3C S12500CR Switch Router Series Type-S Modules and Transceivers Compatibility Matrix.
SEUs
SEUs are the core component of the system control plane. You can install one SEU, or two SEUs for redundancy on the switch. Do not install SEUs of different models on the same switch.
You can access and configure the switch through the serial console port or the mini USB console port. Only one port is active at a time.
To connect a USB device to the module, make sure the USB device is in good condition.
Set the same speed and duplex mode for a management Ethernet port and its peer port.
If multiple management ports are connected to one remote switch, you must assign their peer ports to different VLANs on the remote switch. Then, you can transfer startup software images to the switch through TFTP or FTP.
The environment management module is the system monitoring module of the switch. It can collect system running information and interact with the management system of the equipment room in real time to deliver highly reliable switch monitoring and management.
Table2-6 Module functionalities
Functionalities
Smart monitoring and management
·     The module exchanges data with the management system of the equipment room in real time, improving energy management resiliency in the data center.
¡     The module monitors the switch temperature in real time, and adjusts the fan speed intelligently to avoid overtemperature.
¡     The module reports the power requirements of the switch in real time to the management system of the equipment room which will then adjust power supply accordingly to avoid power distribution system overload or underload or energy waste.
·     The module monitors the power consumption and power usage of the switch in real time and automatically powers on or off interface modules accordingly.
·     The module provides asset management and fault diagnosis.
High availability
The module is used in 1+1 redundancy with the other one. When the active module fails, the standby module takes over the services immediately.
Maintainability
The module reserves a COM port and two 10/100/1000BASE-T management ports (ETH) for future service expansion.
The module comes with the system software installed. By default, the module starts up with the installed system software after it is installed on the switch.
The IPE file contains the software version for module upgrade. However, when you use the IPE file to upgrade the SEU, the module will not be upgraded. To upgrade the module, execute the boot-loader update command and then reboot the module by using the reboot command.
The module is used in active/standby mode with the other one. To upgrade the two modules, follow these guidelines:
·     Before the upgrade, make sure the two modules are operating correctly, one in active mode and the other in standby mode.
·     As a best practice, first upgrade the standby module and then the active module.
·     The software versions of two modules might be different during the module upgrade process. Make sure the software versions of two modules are the same after the upgrade for high service availability.
Interface modules
The LSXM1MOD24KBR1 flexible line processing platform module supports various interface modules. For more information, see "Interface modules available for the LSXM1MOD24KBR1 flexible line processing platform module."
For the compatible transceiver modules or cables for the interface modules, see H3C S12500CR Switch Router Series Type-K Modules and Transceivers Compatibility Matrix, H3C S12500CR Switch Router Series Type-S Modules and Transceivers Compatibility Matrix, and H3C S12500R Switch Router Series Port Splitting and Compatibility With Transceivers and Cables.
Fabric modules
Before you install a fabric module, remove the protection box from it.
The fabric module slots are covered by fan trays. You must install the fabric modules before installing the fan trays. To remove a fabric module, first remove the fan tray that covers it.
Before you install a fabric module, press the buttons on the ejector levers to release them. After the fabric module is fully seated into slot, close the ejector levers. Before you remove a fabric module, press the buttons on the ejector levers to release them, open the ejector levers, and then pull the fabric module out of the slot.
Some fabric modules have air baffles. Before you install such a fabric module, make sure the air baffle is closed. After you remove a fabric module, close the air baffle.
Do not install fabric modules of different models on the same switch.
The fan tray in slot FAN5 covers only one fabric module. Only one of the two fabric module status LEDs on the fan tray works. For the fabric module status LED description on a fan tray, see "Fan trays."
To obtain the fabric module models on an operating switch, execute the display device command.
Type K SEUs
LSXM1SUPKR1
View
Figure2-4 LSXM1SUPKR1 view
Table2-7 Technical specifications
Item
Specification
Net weight
6.60 kg (14.55 lb)
Dimensions (H × W × D)
43.7 × 446.4 × 519.8 mm (1.72 × 17.57 × 20.46 in)
Power consumption
·     Minimum: 50 W
·     Typical: 50 W
·     Maximum: 60 W
Processor
Intel processor (quad-core) @ 2.2 GHz
DDR
32GB DDR4 (two DIMM slots)
Flash
4 GB
NVRAM
512 KB
SSD
240 GB (SATA)
Connector type
·     RJ-45
·     LC
·     USB (Type A)
·     Mini USB (Type AB)
Ports
·     1 × RJ-45 console port
·     1 × mini USB console port
·     2 × 10/100/1000BASE-T management and upgrade ports
·     2 × GE SFP management and upgrade ports
·     1 × USB port (USB 3.0, host port)
·     2 × 1PPS/TOD time synchronization ports
·     2 × SMB clock input ports
·     2 × SMB clock output ports
Transmission baud rate
·     Console port: ≤ 115200 bps. The default value is 9600 bps.
·     10/100/1000BASE-T port: 10/100/1000 Mbps
·     SFP port: 1000 Mbps
Transmission medium and max transmission distance of the console port
Common asynchronous serial interface cable, with a maximum transmission distance of 15 m (49.21 ft)
Transmission medium and max transmission distance of the 10/100/1000BASE-T port
Category-5 twisted pair cable, with a transmission distance of 100 m (328.08 ft)
Ports and LEDs
Figure2-5 Front panel
(1) 1PPS/TOD time synchronization port
(2) SMB clock output port
(3) SMB clock input port
(4) USB port
(5) Console port (CONSOLE)
(6) GE SFP management and upgrade port
(7) 10/100/1000BASE-T management and upgrade port LED (LINK)
(8) 10/100/1000BASE-T management and upgrade port
(9) Active/standby status LED
(10) 10/100/1000BASE-T management and upgrade port LED (ACT)
(11) GE SFP management and upgrade port LED
(12) Mini USB console port
(13) Slot status LED
Table2-8 LED description (1)
LED mark
LED
Status
Slots 2 to 28
Slot status LED
Off
The module in the corresponding slot has failed or no module is available in the corresponding slot.
Flashing green (0.5 Hz)
The module in the corresponding slot is operating correctly.
Flashing green (4 Hz)
The module in the corresponding slot is loading software.
If the module remains in this state, the software version running on the switch is incompatible with the module.
Steady red
An alarm has occurred on the module in the corresponding slot.
LINK/ACT
Off
No link is present on the port.
Flashing green
The port is sending or receiving data.
Steady green
A link is present on the port.
ACT
Off
The SEU is in standby state.
Steady green
The SEU is in active state.
Table2-9 LED description (2)
LINK
ACT
Off
Off
Steady green
Off
A 1000 Mbps link is present on the port.
Steady orange
Off
A 10/100 Mbps link is present on the port.
Steady green
Flashing yellow
The port is receiving or sending data at 1000 Mbps.
Steady orange
Flashing yellow
The port is receiving or sending data at 10/100 Mbps.
LSXM1SUPKAR1
View
Figure2-6 LSXM1SUPKAR1 view
Table2-10 Technical specifications
Item
Specification
Net weight
6.60 kg (14.55 lb)
Power consumption
·     Minimum: 60 W
·     Typical: 65 W
·     Maximum: 70 W
Processor
DDR
Flash
4GB
NVRAM
512 KB
Connector type
·     RJ-45
·     LC
·     USB (Type A)
Ports
Ports and LEDs
Figure2-7 Front panel
(4) USB port
Table2-11 LED description (1)
LED mark
LED
Status
Slots 2 to 28
Slot status LED
Off
Steady red
LINK/ACT
Off
Flashing green
Steady green
ACT
Off
Steady green
Table2-12 LED description (2)
LINK
ACT
Off
Off
Steady green
Off
Steady orange
Off
Steady green
Flashing yellow
Steady orange
Flashing yellow
Type S SEUs
LSXM1SUPRS2
View
Figure2-8 LSXM1SUPRS2 view
Table2-13 Technical specifications
Item
Specification
Net weight
6.60 kg (14.55 lb)
Power consumption
·     Minimum: 50 W
·     Typical: 50 W
·     Maximum: 60 W
Processor
Quad-core, 2.2 GHz
SDRAM
32 GB
Flash
4 GB
NVRAM
512 KB
SSD
240 GB
Connector type
·     RJ-45
·     LC
·     USB (Type A)
Ports
Ports and LEDs
Figure2-9 Front panel
(4) USB port
Table2-14 LED description (1)
LED mark
LED
Status
Slots 2 to 28
Slot status LED
Off
Steady red
LINK/ACT
Off
Flashing green
Steady green
ACT
Off
Steady green
Table2-15 LED description (2)
LINK
ACT
Off
Off
Steady green
Off
Steady orange
Off
Steady green
Flashing yellow
Steady orange
Flashing yellow
LSXM3SUPRS2-G1
View
Figure2-10 LSXM3SUPRS2-G1 view
Table2-16 Technical specifications
Item
Specification
Net weight
6.0 kg (13.23 lb)
Power consumption
·     Minimum: 45 W
·     Typical: 54 W
·     Maximum: 58 W
Processor
8-core
SDRAM
16GB DDR4
SSD
128 GB
NVRAM
1 MB
Connector type
·     RJ-45
·     LC
·     USB (Type A)
Ports
·     1 × USB port (USB 2.0, host port)
Ports and LEDs
Figure2-11 Front panel
(1) Slot status LED
(2) USB port
(3) Console port (CONSOLE)
(4) SFP management Ethernet port 1
(5) SFP management Ethernet port 2
(6) 10/100/1000BASE-T management Ethernet port 1 LED (ACT)
(7) 10/100/1000BASE-T management Ethernet port 1 LED (LINK)
(8) 10/100/1000BASE-T management Ethernet port 2 LED (ACT)
(9) 10/100/1000BASE-T management Ethernet port 2 LED (LINK)
(10) Reset button (RESET)
(11) Active/standby status LED (ACTIVE)
(12) 10/100/1000BASE-T management Ethernet port 2
(13) 10/100/1000BASE-T management Ethernet port 1
(14) SFP management Ethernet port 2 LED
(15) SFP management Ethernet port 1 LED
Table2-17 LED description
LED
Status
10/100/1000BASE-T management Ethernet port LED
ACT: Off
LINK: Off
ACT: Off
LINK: Steady green
ACT: Off
LINK: Steady orange
ACT: Flashing yellow
LINK: Steady green
LINK: Steady orange
SFP management Ethernet port LED
Flashing
The port is receiving or sending data.
On
Off
Slot status LED
Flashing green (once every two seconds)
Flashing green (four times per second)
The module in the slot is loading software.
Steady green
The module in the corresponding slot is starting up.
Steady red
A high severity alarm has occurred on the module in the corresponding slot or the module in the corresponding slot has failed.
Flashing red (once every four seconds)
The temperature of the module in the corresponding slot has exceeded the upper warning temperature threshold or dropped below the lower temperature threshold.
Off
No module is available in the corresponding slot or the module in the corresponding slot has failed.
Steady on
Off
The following are the possible causes:
·     The SEU is in standby state.
·     The SEU has failed. To identify the failure, see the module status LED description.
The environment management module is the system monitoring module of the switch. It can collect system running information and interact with the management system of the equipment room in real time to deliver highly reliable device monitoring and management.
Table2-18 Module functionalities
Functionalities
High availability
Maintainability
LSXM1CMUR1
View
Figure2-12 LSXM1CMUR1
Table2-19 Technical specifications
Item
Specification
Net weight
2.50 kg (5.51 lb)
32.0 × 192.0 × 396.9 mm (1.26 × 7.56 × 15.63 in)
Power consumption
·     Minimum: 22 W
·     Typical: 22 W
·     Maximum: 26 W
Processor
DDR
8GB DDR4 (two DIMM slots)
Flash
8 GB
LEDs
·     2 × management port LEDs
·     1 × fan tray status LED
·     1 × power supply status LED
·     1 × module status LED
·     1 × active/standby status LED
For the LED description, see "Table2-20"
Operating temperature
Operating relative humidity
Ports
·     1 × COM port (reserved for future use)
·     2 × 10/100/1000BASE-T management ports (reserved for future use)
Hot swapping
Supported
Ports and LEDs
Figure2-13 Front panel
(1) COM port
(2) 10/100/1000BASE-T management port (ETH)
(3) 10/100/1000BASE-T management port (ETH)
(4) Active/standby status LED
(5) Module status LED
(6) Power supply status LED
(7) Fan tray status LED
(8) 10/100/1000BASE-T management port LED
(9) 10/100/1000BASE-T management port LED
Table2-20 LED description
LED mark
LED
Color
Status
N/A
Green
Steady on
Off
Flashing
FAN
Fan tray status LED
Green
Steady on
All fan trays are present and operating correctly.
Red
Steady on
A fan tray is not present or has failed.
PWR
Green
Steady on
All present power supplies are operating correctly.
Red
Steady on
A power supply has failed.
RUN/ALM
Module status LED
Green
Steady on
The module is starting up.
Flashing
The module is operating correctly.
Red
Steady on
The module has failed.
ACTIVE
Green
Steady on
The module is in active state.
Off
The module is in standby state.
View
The LSXM1CMURS2 and LSXM3CMURS2-G3 are similar in views except for their marks.
Figure2-14 LSXM1CMURS2/LSXM3CMURS2-G3 view (LSXM3CMURS2-G3 as an example)
Table2-21 Technical specifications
Item
LSXM1CMURS2
LSXM3CMURS2-G3
Net weight
2.50 kg (5.51 lb)
2.30 kg (5.07 lb)
Power consumption
·     Minimum: 22 W
·     Typical: 22 W
·     Maximum: 26 W
·     Minimum: 15 W
·     Typical: 16 W
·     Maximum: 18 W
Processor
Quad-core
Quad-core
SDRAM
8 GB
4 GB
Flash
8 GB
8 GB
LEDs
For the LED description, see "Table2-22"
Ports
Hot swapping
Supported
Ports and LEDs
Figure2-15 Front panel (LSXM3CMURS2-G3 as an example)
(1) COM port
Table2-22 LED description
LED mark
LED
Color
Status
N/A
Green
Steady on
Off
Flashing
FAN
Fan tray status LED
Green
Steady on
Red
Steady on
PWR
Green
Steady on
Red
Steady on
RUN/ALM
Module status LED
Green
Steady on
Flashing
Red
Steady on
ACTIVE
Green
Steady on
Off
Follow these restrictions and guidelines when you install interface module adapters:
·     An interface module adapter is required for an interface module with dimensions of 50.0 × 432.6 × 519.8 mm (1.97 × 17.03 × 20.46 in), except for the LSXM1CGQ72KCR1.
·     Two interface module adapters are required for each LSXM1CGQ72KCR1 interface module.
For how to install an interface module adapter, see H3C S12500CR LSXM1IMAA Interface Module Adapter User Manual.
LSXM1CDMS36KCR1
View
Figure2-16 LSXM1CDMS36KCR1 view
Table2-23 Technical specifications
Item
Specification
Net weight
11.80 kg (26.01 lb)
50.0 × 446.4 × 519.8 mm (1.97 × 17.57 × 20.46 in)
Power consumption
·     Minimum: 485 W
·     Typical: 785 W
·     Maximum: 1710 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
36
Port type
400GBASE-R-QSFP-DD fiber port (supports MACsec)
Services
Provides data access and switching with 36 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-17 Front panel
(1) 400G QSFP-DD port
(2) 400G QSFP-DD port LED
Table2-24 LED description
LED
Status
QSFP-DD fiber port LED
Flashing
The QSFP-DD port is sending or receiving data.
On
A link is present on the QSFP-DD port.
Off
No link is present on the QSFP-DD port.
LSXM1CDQ36KBR1
View
Figure2-18 LSXM1CDQ36KBR1 view
Table2-25 Technical specifications
Item
Specification
Net weight
13.10 kg (28.88 lb)
Power consumption
·     Minimum: 740 W
·     Typical: 1130 W
·     Maximum: 1868 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
36
Port type
Services
Hot swapping
Supported
Ports and LEDs
Figure2-19 Front panel
Table2-26 LED description
LED
Status
Flashing
On
Off
LSXM1CDQ24KB1
View
Figure2-20 LSXM1CDQ24KB1 view
Table2-27 Technical specifications
Item
Specification
Net weight
10.00 kg (22.05 lb)
Power consumption
·     Minimum: 469 W
·     Typical: 696 W
·     Maximum: 1020 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
24
Port type
Services
Provides data access and switching with 24 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-21 Front panel
Table2-28 LED description
LED
Status
Flashing
On
Off
LSXM1CDQ24KBR1
View
Figure2-22 LSXM1CDQ24KBR1 view
Table2-29 Technical specifications
Item
Specification
Net weight
10.00 kg (22.05 lb)
Power consumption
·     Minimum: 469 W
·     Typical: 696 W
·     Maximum: 1020 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
24
Port type
Services
Hot swapping
Supported
Ports and LEDs
Figure2-23 Front panel
Table2-30 LED description
LED
Status
Flashing
On
Off
LSXM1CDQ18KCR1
View
Figure2-24 LSXM1CDQ18KCR1 view
Table2-31 Technical specifications
Item
Specification
Net weight
8.80 kg (19.40 lb)
Power consumption
·     Minimum: 195 W
·     Typical: 380 W
·     Maximum: 850 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
18
Port type
Services
Provides data access and switching with 18 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-25 Front panel
Table2-32 LED description
LED
Status
Flashing
On
Off
LSXM1CCQ48KBR1
View
Figure2-26 LSXM1CCQ48KBR1 view
Table2-33 Technical specifications
Item
Specification
Net weight
10.50 kg (23.15 lb)
Power consumption
·     Minimum: 412 W
·     Typical: 564 W
·     Maximum: 1142 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
48
Port type
200GBASE-R-QSFP56 fiber port
Services
Provides data access and switching with 48 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-27 Front panel
(1) 200G QSFP56 port
(2) 200G QSFP56 port LED
Table2-34 LED description
LED
Status
QSFP56 fiber port LED
Flashing
The QSFP56 port is sending or receiving data.
On
A link is present on the QSFP56 port.
Off
No link is present on the QSFP56 port.
LSXM1CGQ72KCR1
View
Figure2-28 LSXM1CGQ72KCR1 view
Table2-35 Technical specifications
Item
Specification
Net weight
14.70 kg (32.41 lb)
100.8 × 432.6 × 519.8mm (3.97 × 17.03 × 20.46 in)
Power consumption
·     Minimum: 530 W
·     Typical: 635 W
·     Maximum: 980 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
72
Port type
·     72 × 100GBASE-R-QSFP28 fiber ports
·     36 × 200GBASE-R-QSFP56 fiber ports
·     18 × 200GBASE-R-QSFP56 fiber ports + 36 × 100GBASE-R-QSFP28 fiber ports
A 200GBASE-R-QSFP56 fiber port acts as a 100GBASE-R-QSFP28 fiber port when it operates at 100 Gbps.
Services
Provides data access and switching with 72 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-29 Front panel
(1) 200G QSFP56 port LED
(2) 100G QSFP56 ports
(3) 100G QSFP28 ports
(4) 200G QSFP28 port LED
Table2-36 LED description
LED
Status
QSFP28 fiber port LED
Flashing
The QSFP56 or QSFP28 port is sending or receiving data.
On
A link is present on the QSFP56 or QSFP28 port.
Off
No link is present on the QSFP56 or QSFP28 port.
LSXM1CGQ48KB1
View
Figure2-30 LSXM1CGQ48KB1 view
Table2-37 Technical specifications
Item
Specification
Net weight
9.30 kg (20.50 lb)
Power consumption
·     Minimum: 395 W
·     Typical: 447 W
·     Maximum: 765 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
48
Port type
Services
Hot swapping
Supported
Ports and LEDs
Figure2-31 Front panel
(1) 100G QSFP28 fiber port
(2) 100G QSFP28 fiber port LED
Table2-38 LED description
LED
Status
QSFP28 port LED
Flashing
The QSFP28 port is sending or receiving data.
On
A link is present on the QSFP28 port.
Off
No link is present on the QSFP28 port.
LSXM2CGQ48KBR1
View
Figure2-32 LSXM2CGQ48KBR1 view
Table2-39 Technical specifications
Item
Specification
Net weight
9.30 kg (20.50 lb)
Power consumption
·     Minimum: 395 W
·     Typical: 447 W
·     Maximum: 765 W
Processor
SDRAM
32GB DDR4 SDRAM
Port quantity
48
Port type
Services
Hot swapping
Supported
Ports and LEDs
Figure2-33 Front panel
Table2-40 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
LSXM1CGMS48KBR1
View
Figure2-34 LSXM1CGMS48KBR1 view
Table2-41 Technical specifications
Item
Specification
Net weight
9.70 kg (21.38 lb)
Power consumption
·     Minimum: 525 W
·     Typical: 675 W
·     Maximum: 1040 W
Processor
x86 (quad-core) @ 2.2 GHz
SDRAM
16GB DDR4 SDRAM
Port quantity
48
Port type
100GBASE-R-QSFP28 fiber port (supports MACsec)
Services
Hot swapping
Supported
Ports and LEDs
Figure2-35 Front panel
(1) 100G QSFP28 fiber port LED
Table2-42 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
LSXM1CGQ48KBR1
View
Figure2-36 LSXM1CGQ48KBR1 view
Table2-43 Technical specifications
Item
Specification
Net weight
9.30 kg (20.50 lb)
Power consumption
·     Minimum: 395 W
·     Typical: 447 W
·     Maximum: 765 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
48
Port type
Services
Hot swapping
Supported
Ports and LEDs
Figure2-37 Front panel
Table2-44 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
LSXM1CGQFX16KBR1
View
Figure2-38 LSXM1CGQFX16KBR1 view
Table2-45 Technical specifications
Item
Specification
Net weight
10.60 kg (23.37 lb)
Power consumption
·     Minimum: 330 W
·     Typical: 385 W
·     Maximum: 485 W
Processor
SDRAM
16GB DDR4 SDRAM
Port quantity
16
Port type
100GBASE-R-QSFP28 fiber port (supports FlexE)
Services
Provides data access and switching with 16 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-39 Front panel
Table2-46 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
LSXM1MOD24KBR1
View
Figure2-40 LSXM1MOD24KBR1 view
(1) Interface module slot 1 (installed with a subcard filler panel)
(2) Interface module slot 2 (installed with a subcard filler panel)
Table2-47 Technical specifications
Item
Specification
Net weight
7.40 kg (16.31 lb)
Power consumption
·     Minimum: 135 W
·     Typical: 350 W
·     Maximum: 577 W
Processor
SDRAM
16GB DDR4 SDRAM
Slots
You can install two interface modules on the module. For the compatible interface modules, see "Interface modules available for the LSXM1MOD24KBR1 flexible line processing platform module"
Hot swapping
Supported
LSXM3CDHQ36RSG2
View
Figure2-41 LSXM3CDHQ36RSG2 view
Table2-48 Technical specifications
Item
Specification
Net weight
11.80 kg (26.01 lb)
Power consumption
·     Minimum: 745 W
·     Typical: 1108 W
·     Maximum: 1568 W
Port quantity
36
Port type
400GBASE-R-QSFP112 fiber port
Services
Provides data access and forwarding with thirty-six 400GE fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-42 Front panel
(1) 400GBASE-R-QSFP112 fiber port
(2) 400GBASE-R-QSFP112 fiber port LED
Table2-49 LED description
LED
Status
Flashing
The QSFP112 port is sending or receiving data.
On
A link is present on the QSFP112 port.
Off
No link is present on the QSFP112 port.
LSXM3CDQ16SF2
View
Figure2-43 LSXM3CDQ16SF2 view
Table2-50 Technical specifications
Item
Specification
Net weight
8.85 kg (19.51 lb)
Power consumption
·     Minimum: 260 W
·     Typical: 365 W
·     Maximum: 679 W
Port quantity
16
Port type
Services
Provides data access and forwarding with sixteen 400GE fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-44 Front panel
(1) 400G QSFP-DD fiber port
(2) 400G QSFP-DD fiber port LED
Table2-51 LED description
LED
Status
Flashing
On
Off
LSXM3CDQ8SF2
View
Figure2-45 LSXM3CDQ8SF2 view
Item
Specification
Net weight
8.50 kg (18.74 lb)
Power consumption
·     Minimum: 258 W
·     Typical: 320 W
·     Maximum: 542 W
Port quantity
8
Port type
Services
Provides data access and forwarding with eight 400GE fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-46 Front panel
Table2-52 LED description
LED
Status
Flashing
On
Off
LSXM3CCQ36SG2
View
Figure2-47 LSXM3CCQ36SG2 view
Table2-53 Technical specifications
Item
Specification
Net weight
9.05 kg (19.95 lb)
Power consumption
·     Minimum: 366 W
·     Typical: 502 W
·     Maximum: 789 W
Port quantity
36
Port type
Services
Provides data access and forwarding with 36 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-48 Front panel
(1) 200GBASE-R-QSFP56 fiber port
(2) 200GBASE-R-QSFP56 fiber port LED
Table2-54 LED description
LED
Status
Flashing
On
Off
View
Figure2-49 LSXM3CGQ48SG2/LSXM4CGQ48SG2 view (LSXM3CGQ48SG2 as an example)
Table2-55 Technical specifications
Item
Specification
Net weight
9.30 kg (20.50 lb)
Power consumption
·     Minimum: 410 W
·     Typical: 539 W
·     Maximum: 842 W
Port quantity
48
Port type
Services
Provides data access and forwarding with 48 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-50 Front panel
(1) 100GBASE-R-QSFP28 fiber port LED
(2) 100GBASE-R-QSFP28 fiber port
Table2-56 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
View
Figure2-51 LSXM4CGQ36SF2/LSXM4CGQ36SF2-G3 view (LSXM4CGQ36SF2-G3 as an example)
Table2-57 Technical specifications
Item
LSXM4CGQ36SF2
LSXM4CGQ36SF2-G3
Net weight
8.95 kg (19.73 lb)
9.00 kg (19.84 lb)
Power consumption
·     Minimum: 344 W
·     Typical: 412 W
·     Maximum: 644 W
·     Minimum: 346 W
·     Typical: 414 W
·     Maximum: 648 W
Port quantity
36
36
Port type
Services
Hot swapping
Supported
Ports and LEDs
Figure2-52 Front panel
(2) 100GBASE-R-QSFP28 fiber port LED
Table2-58 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
LSXM3CGQ36SF2
View
Figure2-53 LSXM3CGQ36SF2 view
Table2-59 Technical specifications
Item
Specification
Net weight
8.60 kg (18.96 lb)
Power consumption
·     Minimum: 252 W
·     Typical: 328 W
·     Maximum: 587 W
Port quantity
36
Port type
Services
Hot swapping
Supported
Ports and LEDs
Figure2-54 Front panel
Table2-60 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
View
Figure2-55 LSXM3CGQ18SF2/LSXM3CGQ18SF2-G3 view (LSXM3CGQ18SF2 as an example)
Table2-61 Technical specifications
Item
LSXM3CGQ18SF2
LSXM3CGQ18SF2-G3
Net weight
7.40 kg (16.31 lb)
7.40 kg (16.31 lb)
Power consumption
·     Minimum: 144 W
·     Typical: 194 W
·     Maximum: 311 W
·     Minimum: 150 W
·     Typical: 200 W
·     Maximum: 322 W
Port quantity
18
18
Port type
Services
Provides data access and forwarding with 18 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-56 Front panel
Table2-62 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
View
Figure2-57 LSXM3QGS36SF2/LSXM3QGS36SF2-G3 view (LSXM3QGS36SF2 as an example)
Table2-63 Technical specifications
Item
LSXM3QGS36SF2
LSXM3QGS36SF2-G3
Net weight
7.70 kg (16.98 lb)
7.65 kg (16.87 lb)
Power consumption
·     Minimum: 140 W
·     Typical: 188 W
·     Maximum: 356 W
·     Minimum: 146 W
·     Typical: 194 W
·     Maximum: 367 W
Port quantity
36
36
Port type
40GBASE-R-QSFP+ fiber port
Services
Hot swapping
Supported
Ports and LEDs
Figure2-58 Front panel
(1) 40G QSFP+ fiber port
(2) 40G QSFP+ fiber port LED
Table2-64 LED description
LED
Status
QSFP + port LED
Flashing
The QSFP+ port is sending or receiving data.
On
A link is present on the QSFP+ port.
Off
No link is present on the QSFP+ port.
View
Figure2-59 LSXM3YGS48SF2LSXM3YGS48SF2-G3 view (LSXM3YGS48SF2 as an example)
Table2-65 Technical specifications
Item
LSXM3YGS48SF2
LSXM3YGS48SF2-G3
Net weight
7.20 kg (15.87 lb)
7.15 kg (15.76 lb)
Power consumption
·     Minimum: 101 W
·     Typical: 118 W
·     Maximum: 234 W
·     Minimum: 107 W
·     Typical: 124 W
·     Maximum: 245 W
Port quantity
48
48
Port type
25GBASE-R-SFP28 fiber port
Services
Hot swapping
Supported
Ports and LEDs
Figure2-60 Front panel
(1) 25G SFP28 fiber port
(2) 25G SFP28 fiber port LED
Table2-66 LED description
LED
Status
SFP28 port LED
Flashing
The SFP28 port is sending or receiving data.
On
A link is present on the SFP28 port.
Off
No link is present on the SFP28 port.
View
Figure2-61 LSXM3TGS48SF2/LSXM3TGS48SF2-G3 view (LSXM3TGS48SF2 as an example)
Table2-67 Technical specifications
Item
LSXM3TGS48SF2
LSXM3TGS48SF2-G3
Net weight
7.20 kg (15.87 lb)
7.05 kg (15.54 lb)
Power consumption
·     Minimum: 95 W
·     Typical: 101 W
·     Maximum: 175 W
·     Minimum: 101 W
·     Typical: 107 W
·     Maximum: 186 W
Port quantity
48
48
Port type
10GBASE-R-SFP+ fiber port
Services
Hot swapping
Supported
Ports and LEDs
Figure2-62 Front panel
(1) 10G SFP+ fiber port
(2) 10G SFP+ fiber port LED
Table2-68 LED description
LED
Status
SFP + port LED
Flashing
The SFP+ port is sending or receiving data.
On
A link is present on the SFP+ port.
Off
No link is present on the SFP+ port.
LSXM3TGT48CQSF2
View
Figure2-63 LSXM3TGT48CQSF2 view
Table2-69 Technical specifications
Item
Specification
Net weight
7.35 kg (16.20 lb)
Power consumption
·     Minimum: 154 W
·     Typical: 190 W
·     Maximum: 266 W
Port quantity
50
Port type
·     2 × 100GBASE-R-QSFP28 fiber ports
·     48 × 10G/5G/2.5G/1G/100BASE-T-RJ45 copper ports
Services
Provides data access and forwarding with 48 copper Ethernet ports and 2 fiber Ethernet ports
Hot swapping
Supported
LEDs
Figure2-64 Front panel
(1) 10G/5G/2.5G/1G/100BASE-T-RJ45 copper port LED
(3) 100GBASE-R-QSFP28 fiber port
(4) 10G/5G/2.5G/1G/100BASE-T-RJ45 copper port
Table2-70 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
RJ-45 Ethernet port LED
Flashing
The RJ-45 Ethernet port is sending or receiving data.
On
A link is present on the RJ-45 Ethernet port.
Off
No link is present on the RJ-45 Ethernet port.
Table2-71 Interface modules available for the LSXM1MOD24KBR1
Interface module model
Port quantity and type
LSXM1CGQ18C1
18-port 100GBASE Ethernet optical interface module
18 × QSFP28 ports
LSXM1CGQ8C1
8 × QSFP28 ports
LSXM1TGS24C1
24-port 10GBASE Ethernet optical interface module
24 × SFP+ ports
LSXM1CGQ18C1
View
Figure2-65 LSXM1CGQ18C1 view
Table2-72 Technical specifications
Item
Specification
Net weight
1.78 kg (3.92 lb)
44.0 × 191.0 × 271.0 mm (1.73 × 7.52 × 10.67 in)
Power consumption
·     Minimum: 90 W
·     Typical: 101 W
·     Maximum: 169 W
Port quantity
18
Port type
Services
Hot swapping
Supported
Ports and LEDs
Figure2-66 Front panel
Table2-73 LED description
LED
Status
QSFP + port LED
Flashing
On
Off
LSXM1CGQ8C1
View
Figure2-67 LSXM1CGQ8C1 view
Table2-74 Technical specifications
Item
Specification
Net weight
1.50 kg (3.31 lb)
Power consumption
·     Minimum: 38 W
·     Typical: 49 W
·     Maximum: 79 W
Port quantity
8
Port type
Services
Provides data access and switching with eight Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-68 Front panel
Table2-75 LED description
LED
Status
QSFP28 port LED
Flashing
On
Off
LSXM1TGS24C1
View
Figure2-69 LSXM1TGS24C1 view
Table2-76 Technical specifications
Item
Specification
Net weight
1.53 kg (3.37 lb)
Power consumption
·     Minimum: 33 W
·     Typical: 35 W
·     Maximum: 63 W
Port quantity
10
Port type
Services
Provides data access and switching with 10 Ethernet fiber ports
Hot swapping
Supported
Ports and LEDs
Figure2-70 Front panel
Table2-77 LED description
LED
Status
SFP+ port LED
Flashing
On
Off
LSXM1SFK16ER1
View
Figure2-71 LSXM1SFK16ER1 view
Table2-78 Technical specifications
Item
Specification
Net weight
10.00 kg (22.05 lb)
39.8 × 853.0 × 278.4 mm (1.57 × 33.58 × 10.96 in)
Power consumption
·     Minimum: 159 W
·     Typical: 226 W
·     Maximum: 293 W
Processor
SDRAM
8GB DDR4 SDRAM
Hot swapping
Supported
Buttons and LEDs
Figure2-72 Front panel
(1) RUN/ALM LED
Table2-79 LED description
LED
Status
RUN/ALM
Green
The fabric module is operating correctly.
Red
The fabric module has failed or is loading software.
Off
The fabric module is not powered on or has not started loading software.
LSXM1SFK16GR1
View
Figure2-73 LSXM1SFK16GR1 view
Table2-80 Technical specifications
Item
Specification
Net weight
11.30 kg (24.91 lb)
Power consumption
·     Minimum: 471 W
·     Typical: 647 W
·     Maximum: 822 W
Processor
SDRAM
8GB DDR4 SDRAM
Hot swapping
Supported
Buttons and LEDs
Figure2-74 Front panel
(1) RUN/ALM LED
Table2-81 LED description
LED
Status
RUN/ALM
Green
Red
Off
LSXM1SFK08ER1
View
Figure2-75 LSXM1SFK08ER1 view
Table2-82 Technical specifications
Item
Specification
Net weight
4.80 kg (10.58 lb)
39.8 × 453.0 × 278.4 mm (1.57 × 17.83 × 10.96 in)
Power consumption
·     Minimum: 90 W
·     Typical: 146 W
·     Maximum: 157 W
Processor
SDRAM
8GB DDR4 SDRAM
Hot swapping
Supported
Buttons and LEDs
Figure2-76 Front panel
(1) RUN/ALM LED
Table2-83 LED description
LED
Status
RUN/ALM
Green
Red
Off
LSXM1SFK08FR1
View
Figure2-77 LSXM1SFK08FR1 view
Table2-84 Technical specifications
Item
Specification
Net weight
5.70 kg (12.57 lb)
Power consumption
·     Minimum: 160 W
·     Typical: 218 W
·     Maximum: 284 W
Processor
SDRAM
8GB DDR3 SDRAM
Hot swapping
Supported
Buttons and LEDs
Figure2-78 Front panel
(1) RUN/ALM LED
Table2-85 LED description
LED
Status
RUN/ALM
Green
Red
Off
LSXM1SFK08GR1
View
Figure2-79 LSXM1SFK08GR1 view
Table2-86 Technical specifications
Item
Specification
Net weight
5.90 kg (13.01 lb)
Power consumption
·     Minimum: 207 W
·     Typical: 277 W
·     Maximum: 366 W
Processor
SDRAM
8GB DDR4 SDRAM
Hot swapping
Supported
Buttons and LEDs
Figure2-80 Front panel
(1) RUN/ALM LED
Table2-87 LED description
LED
Status
RUN/ALM
Green
Red
Off
View
Figure2-81 LSXM3SFS16F2/LSXM3SFS16F2-G3 view (LSXM3SFS16F2 as an example)
Table2-88 Technical specifications
Item
LSXM3SFS16F2
LSXM3SFS16F2-G3
Net weight
9.40 kg (20.72 lb)
9.25 kg (20.39 lb)
Power consumption
·     Minimum: 123 W
·     Typical: 172 W
·     Maximum: 257 W
·     Minimum: 120 W
·     Typical: 163 W
·     Maximum: 247 W
SDRAM
4 GB
Hot swapping
Supported
Compatible switch models
S12516CR
Buttons and LEDs
Figure2-82 Front panel
(1) RUN/ALM LED
Table2-89 LED description
LED
Status
RUN/ALM
Green
Red
Off
View
Figure2-83 LSXM3SFS16G2/LSXM3SFS16G2-G3 view (LSXM3SFS16G2 as an example)
Table2-90 Technical specifications
Item
LSXM3SFS16G2
LSXM3SFS16G2-G3
Net weight
10.20 kg (22.49 lb)
10.20 kg (22.49 lb)
Power consumption
·     Minimum: 241 W
·     Typical: 317 W
·     Maximum: 500 W
·     Minimum: 238 W
·     Typical: 308 W
·     Maximum: 490 W
SDRAM
4 GB
Hot swapping
Supported
S12516CR
Buttons and LEDs
Figure2-84 Front panel
(1) RUN/ALM LED
Table2-91 LED description
LED
Status
RUN/ALM
Green
Red
Off
View
Figure2-85 LSXM3SFS16H2/LSXM3SFS16H2-G3 view (LSXM3SFS16H2 as an example)
Table2-92 Technical specifications
Item
LSXM3SFS16H2
LSXM3SFS16H2-G3
Net weight
9.95 kg (21.94 lb)
10.25 kg (22.60 lb)
Power consumption
·     Minimum: 360 W
·     Typical: 547 W
·     Maximum: 729 W
·     Minimum: 353 W
·     Typical: 534 W
·     Maximum: 712 W
SDRAM
4 GB
Hot swapping
Supported
S12516CR
Buttons and LEDs
Figure2-86 Front panel
(1) RUN/ALM LED
Table2-93 LED description
LED
Status
RUN/ALM
Green
Red
Off
View
Figure2-87 LSXM3SFS08F2/LSXM3SFS08F2-G3 view
Table2-94 Technical specifications
Item
LSXM3SFS08F2
LSXM3SFS08F2-G3
Net weight
4.50 kg (9.92 lb)
4.40 kg (9.70 lb)
Power consumption
·     Minimum: 68 W
·     Typical: 86 W
·     Maximum: 124 W
·     Minimum: 65 W
·     Typical: 77 W
·     Maximum: 114 W
SDRAM
4 GB
Hot swapping
Supported
S12508CR
Buttons and LEDs
Figure2-88 Front panel
(1) RUN/ALM LED
Table2-95 LED description
LED
Status
RUN/ALM
Green
Red
Off
View
Figure2-89 LSXM3SFS08G2/LSXM3SFS08G2-G3 view (LSXM3SFS08G2-G3 as an example)
Table2-96 Technical specifications
Item
LSXM3SFS08G2
LSXM3SFS08G2-G3
Net weight
5.10 kg (11.24 lb)
5.00 kg (11.02 lb)
Power consumption
·     Minimum: 137 W
·     Typical: 176 W
·     Maximum: 259 W
·     Minimum: 134 W
·     Typical: 167 W
·     Maximum: 249 W
SDRAM
4 GB
Hot swapping
Supported
S12508CR
Buttons and LEDs
Figure2-90 Front panel
(1) RUN/ALM LED
Table2-97 LED description
LED
Status
RUN/ALM
Green
Red
Off
View
Figure2-91 LSXM3SFS08H2/LSXM3SFS08H2-G3 view (LSXM3SFS08H2 as an example)
Table2-98 Technical specifications
Item
LSXM3SFS08H2
LSXM3SFS08H2-G3
Net weight
5.15 kg (11.35 lb)
5.20 kg (11.46 lb)
Power consumption
·     Minimum: 177 W
·     Typical: 245 W
·     Maximum: 363 W
·     Minimum: 170 W
·     Typical: 232 W
·     Maximum: 346 W
SDRAM
4 GB
Hot swapping
Supported
S12508CR
Buttons and LEDs
Figure2-92 Front panel
(1) RUN/ALM LED
Table2-99 LED description
LED
Status
RUN/ALM
Green
Red
Off
LSXM3SFS08K2
View
Figure2-93 LSXM3SFS08K2 view
Table2-100 Technical specifications
Item
Specification
Net weight
6.45 kg (14.22 lb)
Power consumption
·     Minimum: 422 W
·     Typical: 486 W
·     Maximum: 733 W
SDRAM
4 GB
Hot swapping
Supported
S12508CR
Buttons and LEDs
Figure2-94 Front panel
(1) RUN/ALM LED
Table2-101 LED description
LED
Status
RUN/ALM
Green
Red
Off
The switch comes with fabric module slots empty. To ensure adequate dissipation, purchase and install fabric module filler panels in empty fabric module slots.
Table2-102 Fabric module filler panels
Quantity per chassis
S12516CR fabric module filler panel
0 to 6
S12508CR fabric module filler panel
Table2-103 Weights and dimensions of fabric module filler panels
Net weight
Height
Width
Depth
2.8 kg (6.17 lb)
39.8 mm (1.57 in)
853.0 mm (33.58 in)
289.0 mm (11.38 in)
1.6 kg (3.53 lb)
39.8 mm (1.57 in)
453.0 mm (17.83 in)
289.0 mm (11.38 in)
Slide rails
LSXM1BSR
View
Figure2-95 LSXM1BSR view
(1) Slide rail installation hole
(2) Sign
(3) Chassis rail
(4) Front plate installation hole
(5) Locating tab
No slide rails are provided with the switch. Purchase slide rails yourself as needed. Table2-104 shows the weights of chassis when they are fully configured and slide rail technical specifications.
Table2-104 LSXM1BSR technical specification
Switch model
Max chassis weight (fully configured)
Applicable slide rails
Slide rail model
Adjustment range
Occupied rack space
S12516CR
620 kg (1366.84 lb)
LSXM1BSR
630 to 900 mm (24.80 to 35.43 in)
1 RU
S12508CR
400 kg (881.83 lb)
The switch supports N+N (dual power inputs) or N+1 (single power input) power supply redundancy. Determine the number of power supplies based on the power supply mode and system power consumption. Make sure the maximum total output power of the installed power supplies is greater than the system power consumption. As a best practice, reserve a 20% power surplus. Table3-1 shows the power trays and power supplies available for the switch
Table3-1 Power trays and power supplies available for the switch
Switch model
Available power trays
Available power supplies
S12516CR
S12508CR
CR-PEM-DC2000
PSR2000B-54D
CR-PEM-AC3000
PSR3000B-54AHD
CR-PEM-HVDC3000
Table3-2 Weights and dimensions of power trays
Power tray model
Net weight
Height
Width
Depth
CR-PEM-DC2000
7.3 kg (16.09 lb)
46.7 mm (1.84 in)
437.5 mm (17.22 in)
750 mm (29.53 in)
CR-PEM-AC3000
6.7 kg (14.77 lb)
46.7 mm (1.84 in)
437.5 mm (17.22 in)
750 mm (29.53 in)
CR-PEM-HVDC3000
6.7 kg (14.77 lb)
46.7 mm (1.84 in)
437.5 mm (17.22 in)
750 mm (29.53 in)
IMPORTANT
IMPORTANT:
Do not install power supplies of different models on the same switch.
When the temperature of a power supply exceeds the upper limit or drops below the lower limit, the power supply shuts down automatically. When the temperature restores into the normal range, the power supply starts up automatically.
Power supplies
PSR2000B-54D
Table3-3 Technical specifications
Item
Specification
Net weight
2.00 kg (4.41 lb)
41 × 68 × 440 mm (1.61 × 2.68 × 17.32 in)
Rated input voltage
–48 to –60 VDC
Input voltage range
–39 to –72 VDC
Input current
60 A (max)
Rated output voltage
54 VDC
Max output current
37 A
Max output power
2000 W
Compatible power trays
CR-PEM-DC2000
Temperature
·     Operating: –10°C to +50°C (14°F to 122°F)
·     Storage: –40°C to +70°C (–40°F to +158°F)
LEDs
Figure3-1 Front panel
(1) IN OK LED
(2) OUT OK LED
Table3-4 LED description
LED
Mark
Color
Status
Input status LED
IN OK
Off
No power input.
Green
Normal power input.
Red
An input undervoltage or overvoltage condition has occurred, or the power supply does not have power input.
Output status LED
OUT OK
Off
No power output.
Green
Normal power output.
Red
The power supply has entered output overvoltage, output overcurrent, or overtemperature protection state.
PSR3000B-54AHD
Table3-5 Technical specifications
Item
Specification
Net weight
2.00 kg (4.41 lb)
Rated input voltage
·     100 to 130 VAC @ 60 Hz
·     200 to 240 VAC @ 50 Hz
·     240 VDC
·     336 VDC
Input voltage range
·     90 to 150 VAC @ 47 to 63 Hz
·     176 to 290 VAC @ 47 to 63 Hz
·     180 to 290 VDC
·     260 to 400 VDC
Input current
16 A (rated)
54 VDC
Max output current
55.6 A
Max output power
·     100 to 130 VAC @ 60 Hz: 1500 W
·     200 to 240 VAC @ 50 Hz: 3000 W
·     240 VDC: 3000 W
·     336 VDC: 3000 W
·     AC power input: CR-PEM-AC3000 and CR-PEM-HVDC3000
·     240 VDC power input: CR-PEM-AC3000 and CR-PEM-HVDC3000
·     336 VDC power input: CR-PEM-HVDC3000
Temperature
LEDs
Figure3-2 Front panel
(1) IN OK LED
(2) OUT OK LED
Table3-6 LED description
LED
Mark
Color
Status
Input status LED
IN OK
Off
No power input.
Green
Normal power input.
Red
Output status LED
OUT OK
Off
No power output.
Green
Red
4 Fan trays
View
Figure4-1 FAN-80-9-A/FAN-80-9-A-G3 view (FAN-80-9-A as an example)
Table4-1 Technical specifications
Item
FAN-80-9-A
FAN-80-9-A-G3
Net weight
8.50 kg (18.74 lb)
8.50 kg (18.74 lb)
1100 × 80.4 × 183.2 mm (43.31 × 3.17 × 7.21 in)
Power consumption
·     Minimum: 54 W
·     Typical: 202 W
·     Maximum: 1105 W
·     Minimum: 54 W
·     Typical: 202 W
·     Maximum: 1105 W
Max fan speed
14500 R.P.M
14500 R.P.M
Max air flow rate
900 CFM (25.49 m3/min)
5% RH to 95% RH, noncondensing
Storage temperature
Storage relative humidity
S12516CR
LEDs
Figure4-2 Front panel
(1) Fan tray status LED (FAN)
(2) Fabric module status LED 1 (SWITCHING FABRIC)
(3) Fabric module status LED 2 (SWITCHING FABRIC)
Table4-2 Fan tray status LED description
LED status
Steady green
The fan tray is operating correctly.
Steady red
The fan tray has failed.
Off
The fan tray is not powered on.
Table4-3 Description for fabric module status LEDs on the fan tray
RUN/ALM LED status
The fabric module is loading software or is operating incorrectly.
Steady red
The fabric module has failed.
Off
The fabric module has not started or is not powered on.
·     The fabric module status LEDs on the fan tray correspond to the fabric modules the fan tray covers from left to right.
·     The fan tray in slot FAN5 covers only one fabric module. Only one of the two fabric module status LEDs on the fan tray works.
View
Figure4-3 FAN-80-5-A/FAN-80-5-A-G3 view (FAN-80-5-A as an example)
Table4-4 Technical specifications
Item
FAN-80-5-A
FAN-80-5-A-G3
Net weight
5.40 kg (11.90 lb)
5.40 kg (11.90 lb)
601.3 × 80.4 × 183.2 mm (23.67 × 3.17 × 7.21 in)
Power consumption
·     Minimum: 27 W
·     Typical: 110 W
·     Maximum: 590 W
·     Minimum: 27 W
·     Typical: 110 W
·     Maximum: 590 W
Max fan speed
14500 R.P.M
14500 R.P.M
Max air flow rate
500 CFM (14.16 m3/min)
Storage temperature
S12508CR
LEDs
Figure4-4 Front panel
Table4-5 Fan tray status LED description
LED status
Steady green
Steady red
Off
Table4-6 Description for fabric module status LEDs on the fan tray
RUN/ALM LED status
Steady red
Off
View
Figure4-5 FAN-80B-5-B-G3 (high performance) view
Table4-7 Technical specifications
Item
Specification
Net weight
5.75 kg (12.68 lb)
Power consumption
·     Minimum: 66 W
·     Typical: 183 W
·     Maximum: 916 W
Max fan speed
14500 R.P.M
Max air flow rate
660 CFM (18.69 m3/min)
Storage temperature
S12508CR
LEDs
Figure4-6 Front panel
(2) Fabric module status LEDs (SWITCHING FABRIC)
Table4-8 Fan tray status LED description
LED status
Steady green
Steady red
Off
Table4-9 Description for fabric module status LEDs on the fan tray
RUN/ALM LED status
Steady red
Off
5 Cables
The switch supports varies interface modules that provide different types of ports. The used cable varies by port type. For more information, see Table5-1.
Table5-1 Cables
Cable
Port type
Function
DC power cord
DC power receptacle
Connects a power tray to the external DC power supply system
AC power cord
AC power receptacle
Connects a power tray to the external AC power supply system
Console cable
·     RJ-45 port at one end and DB-9 port at the other end
·     RJ-45 port at one end and USB port at the other end
Connects the console port of the switch to the configuration terminal
RJ-45 Ethernet ports
Connects RJ-45 Ethernet ports to transmit data
Optical fiber
SFP/SFP+/SFP28/QSFP+/QSFP28 ports
Connects the fiber ports to transmit data
SFP+/SFP28 ports
Connects SFP+/SFP28 ports to transmit data
SFP+/SFP28 ports
QSFP+ copper cable
QSFP+ ports
Connects QSFP+ ports to transmit data
QSFP28 copper cable
QSFP28 ports
Connects QSFP28 ports to transmit data
QSFP+/QSFP28 ports
Connects QSFP+/QSFP28 ports to transmit data
QSFP+ port at one end and SFP+ port at the other end
Connects QSFP+ port at one end and SFP+ port at the other end
QSFP28 port at one end and SFP28 port at the other end
Connects QSFP28 port at one end and SFP28 port at the other end
QSFP112 AOC cable
QSFP112 ports
Connects QSFP112 ports to transmit data
One 400G QSFP112 module at one end and two 200G QSFP112 modules at the other end
Connects 400G QSFP112 port at one end and 200G QSFP112 ports at the other end
QSFP-DD ports
Connects QSFP-DD ports to transmit data
DC power cord
DC power cords are used for connecting the DC power supplies of the switch to the external DC power supply system. Table5-52 shows the DC power cords supported by the switch.
Table5-2 DC power cords supported by the switch
Compatible power supply/power tray
Cable length
Cable type
CR-PEM-DC2000
5 m (16.40 ft)
DC power cord
Connects the power tray to the external DC power supply system
25 m (82.02 ft)
35 m (114.83 ft)
CR-PEM-HVDC3000
1 m (3.28 ft)
3 m (9.84 ft)
15 m (49.21 ft)
AC power cord
AC power cords are used for connecting the AC power supplies of the switch to the external AC power supply system.
To select an AC power cord for an AC power supply, consider the following items:
·     Power capacity of the power supply.
·     Current-carrying capacity of the power cord.
·     Region-and country-specific plug type.
AC power supplies of the switch require 16A AC power cords. For power plugs required by different countries or regions, see H3C Power Cords & Cables User Guide.
Console cable
As shown in Table5-3, two types of console cables can be used for connecting the switch to a configuration terminal.
Table5-3 Connection methods and console cables
Connection method
Console cable type
Configuration terminal-side connector
Switch-side connector
Using the serial console port for connection
DB-9 female connector
RJ-45
USB port
RJ-45
The switch is not provided with a serial console cable.
The signal pinout for the RJ-45 connector of a serial console cable varies by vendor. To avoid abnormal configuration terminal display, use a serial console cable provided by H3C. For more information, see Table5-4. To prepare a serial console cable yourself, make sure the signal pinout for the RJ-45 connector is the same as that shown in Table5-5.
Table5-4 Console cable views
Console cable type
Console cable view
Product code for the recommended H3C console cable
04042967
0404A1EE
IMPORTANT
IMPORTANT:
Follow these guidelines when you connect a DB9-to-RJ45 console cable:
·     Identify the mark on the console port and make sure you are connecting to the correct port.
·     The serial ports on PCs do not support hot swapping. To connect a PC to an operating switch, first connect the PC end. To disconnect a PC from an operating switch, first disconnect the switch end.
A DB9-to-RJ45 console cable is an 8-core shielded cable, with a crimped RJ-45 connector at one end for connecting to the console port of the switch, and a crimped DB-9 female connector at the other end for connecting to the 9-pin serial port on a configuration terminal.
Figure5-1 DB9-to-RJ45 console cable
Table5-5 DB9-to-RJ45 console cable signal pinout
RJ-45
Signal
DB-9
Signal
1
RTS
8
CTS
2
DTR
6
DSR
3
TXD
2
RXD
4
SG
5
SG
5
SG
5
SG
6
RXD
3
TXD
7
DSR
4
DTR
8
CTS
7
RTS
To connect the switch to a configuration terminal (for example, a PC) by using a DB9-to-RJ45 console cable:
1.     Plug the DB-9 female connector of the DB9-to-RJ45 console cable to the serial port on the PC.
2.     Connect the RJ-45 connector to the console port on the switch.
Connecting a USB-to-RJ45 console cable
IMPORTANT
IMPORTANT:
·     To use a USB-to-RJ45 console cable to connect the switch to a configuration terminal, first download and install the USB-to-RJ45 console driver on the configuration terminal and then connect the USB-to-RJ45 console cable to the configuration terminal.
·     If you have connected a USB-to-RJ45 console cable to the configuration terminal before driver installation, you must reconnect the USB-to-RJ45 console cable to the configuration terminal.
For information about the signal pinout for the RJ-45 connector of a USB-to-RJ45 console cable, see Table5-5.
The following describes driver installation on the Windows system. To install the driver on other operating systems, see the installation guide in the driver compression package named by the corresponding operating system.
To connect the switch to a configuration terminal by using a USB-to-RJ45 console cable:
1.     Click the following link, or copy it to the address bar on your browser and download the USB-to-RJ45 console driver.
http://www.h3c.com/en/home/USB_to_RJ45_Console/
2.     View the TXT file Read me in the Windows folder to identify whether the Windows system of the configuration terminal supports the driver.
3.     If the Windows system supports the driver, install PL23XX-M_LogoDriver_Setup_v200_20190815.exe.
4.     Click Next on the welcome page of the driver installation wizard.
Figure5-2 Driver installation wizard
5.     Click Finish after the driver installation is completed.
Figure5-3 Driver installation finished
6.     Connect the standard USB connector of the cable to the USB port of the configuration terminal.
7.     Connect the RJ-45 connector of the cable to the serial console port of the switch.
Ethernet twisted pair cable
Introduction
An Ethernet twisted pair cable contains four pairs of insulated copper wires twisted together. Every wire uses a different color, and has a diameter of about 1 mm (0.04 in).
Application scenarios
An Ethernet twisted pair cable typically transmits analog signals and is advantageous in transmitting data over shorter distances. It is the commonly used transmission media of the Ethernet.
Maximum transmission distance
The maximum transmission distance of the Ethernet twisted pair cable is 100 m (328.08 ft). To extend the transmission distance, you can connect two twisted pair cable segments with a repeater. At most four repeaters can be added, which means five segments can be joined together to provide a transmission distance of 500 m (1640.42 ft).
RJ-45 connector
An Ethernet twisted pair cable connects network devices through the RJ-45 connectors at the two ends. Figure5-4 shows the pinouts of an RJ-45 connector.
Figure5-4 RJ-45 connector pinout diagram
Cable pinouts
EIA/TIA cabling specifications define two standards, 568A and 568B, for cable pinouts.
·     Standard 568A—pin 1: white/green stripe, pin 2: green solid, pin 3: white/orange stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: orange solid, pin 7: white/brown stripe, pin 8: brown solid.
·     Standard 568B—pin 1: white/orange stripe, pin 2: orange solid, pin 3: white/green stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: green solid, pin 7: white/brown stripe, pin 8: brown solid.
Cable type
Based on performance
Ethernet twisted pair cables can be classified into category 3, category 4, category 5, category 5e, category 6, and category 7 cables based on performance. In LANs, category 5, category 5e, and category 6 are commonly used.
Table5-6 Description for commonly used Ethernet twisted pair cables
Category 5
Suitable for data transmission at a maximum speed of 100 Mbps, with a bandwidth of 100 MHz.
Category 5e
Suitable for data transmission at a maximum speed of 1000 Mbps, with a bandwidth of 100 MHz.
Category 6
Suitable for data transmission at a maximum speed of 1 Gbps, with a bandwidth of 250 MHz.
Category 6a
Suitable for data transmission at a maximum speed of 10 Gbps, with a bandwidth of 500 MHz.
Category 7
Suitable for data transmission at a maximum speed of 10 Gbps, with a bandwidth of 600 MHz.
Based on pinouts
Ethernet twisted pair cables can be classified into straight-through and crossover cables based on their pinouts.
·     Straight-through—The pinouts at both ends are T568B compliant, as shown in Figure5-5.
·     Crossover—The pinouts are T568B compliant at one end and T568A compliant at the other end, as shown in Figure5-6.
Figure5-5 Straight-through cable
Figure5-6 Crossover cable
Pin assignments
Select an Ethernet twisted pair cable according to the RJ-45 Ethernet port type on your device. An RJ-45 Ethernet port can be MDI (for routers and PCs) or MDIX (for the switch). Table5-7 and Table5-8 show their pinouts.
Table5-7 RJ-45 MDI port pinouts
Pin
10Base-T/100Base-TX
1000Base-T
Signal
Function
Signal
Function
1
Tx+
Sends data
BIDA+
Bi-directional data cable A+
2
Tx-
Sends data
BIDA-
Bi-directional data cable A-
3
Rx+
Receives data
BIDB+
Bi-directional data cable B+
4
Reserved
N/A
BIDC+
Bi-directional data cable C+
5
Reserved
N/A
BIDC-
Bi-directional data cable C-
6
Rx-
Receives data
BIDB-
Bi-directional data cable B-
7
Reserved
N/A
BIDD+
Bi-directional data cable D+
8
Reserved
N/A
BIDD-
Bi-directional data cable D-
Table5-8 RJ-45 MDIX port pinouts
Pin
10Base-T/100Base-TX
1000Base-T
Signal
Function
Signal
Function
1
Rx+
Receives data
BIDB+
2
Rx-
Receives data
BIDB-
3
Tx+
Sends data
BIDA+
4
Reserved
N/A
BIDD+
5
Reserved
N/A
BIDD-
6
Tx-
Sends data
BIDA-
7
Reserved
N/A
BIDC+
8
Reserved
N/A
BIDC-
To ensure normal communication, the pins for sending data on one port must correspond to the pins for receiving data on the peer port. When both ports on the two devices are MDI or MDIX, use a crossover Ethernet cable. When one port is MDI and the other is MDIX, use a straight-through Ethernet cable. To summarize, straight-through and crossover cables connect the following devices:
·     Straight-through cables connect devices of different types—For example, switch to PC and switch to router.
·     Crossover cables connect devices of the same type—For example, switch to switch, router to router, and PC to PC.
If an RJ-45 Ethernet port is enabled with MDI/MDIX autosensing, it can automatically negotiate pin roles.
The RJ-45 Ethernet ports on the switch support MDI/MDIX autosensing. By default, MDI/MDIX autosensing is enabled on a port.
Making an Ethernet twisted pair cable
1.     Cut the cable to a required length with the crimping tool.
2.     Strip off an appropriate length of the cable sheath. The length is typically that of the RJ-45 connector.
3.     Untwist the pairs so that they can lie flat, and arrange the colored wires based on the wiring specifications.
4.     Cut the top of the wires even with one another and insert the wires into the RJ-45 connector. Make sure the wires extend to the front of the RJ-45 connector and make good contact with the metal contacts in the RJ-45 connector and in the correct order.
5.     Crimp the RJ-45 connector with the crimping tool until you hear a click.
6.     Repeat the above steps with the other end of the cable.
7.     Use a cable tester to verify the connectivity of the cable.
Optical fiber
CAUTION
CAUTION:
Use the same types of transceiver modules, pigtail cords, patch cords, and fiber cables. If you use single-mode optical fibers, the transceiver modules, pigtail cords, patch cords, and fiber cables must be single-mode.
Introduction
Optical fiber
Optical fibers are widely used in fiber-optic communications, which are advantageous for long-distance communications.
Optical fibers can be classified into the following types:
·     Single-mode fiber (SMF)—It has a core size of 10 µm or smaller, and has a lower modal dispersion. It carries only a single ray of light and is mostly used for communication over longer distances.
·     Multimode fiber (MMF)—It has a core size of 50 µm, 62.5 µm, or higher, and has a higher modal dispersion than the single-mode optical fiber. It is mostly used for communication over shorter distances.
Table5-9 Allowed maximum tensile force and crush load
Period of force
Tensile load (N)
Crush load (N/mm)
Short period
150
500
Long term
80
100
Optical fiber cable
An optical fiber cable is a cable containing one or more optical fibers. The optical fiber elements are typically individually coated with plastic layers and contained in a protective tube. Optical fiber cables can be classified into single-mode optical fiber cables and multimode optical fiber cables.
Patch cord
A fiber that has connectors at both ends is called a patch cord. A patch cord connects one optical device to another for signal routing. Patch cords can be classified into single-mode patch cords and multi-mode patch cords.
·     Single-mode patch cord—The jacket is yellow. It permits transmission over longer distances.
·     Multimode patch cord—The jacket is orange. It permits transmission over shorter distances.
Patch cords can be classified into SC, LC, and FC based on interface type. The length of a patch cord can be 0.5 m (1.64 ft), 1 m (3.28 ft), 2 m (6.56 ft), 3 m (9.84 ft), 5 m (16.40 ft), and 10 m (32.81 ft).
Pigtail cord
A pigtail cord is an optical fiber that has an optical connector on one end and a length of exposed fiber on the other. The end of the pigtail is fusion spliced to a fiber, connecting the fiber cable and transceiver.
Pigtail cords can be classified into single-mode (yellow) pigtail cords and multimode (orange) pigtail cords, and can also be classified into SC, LC, FC, and so on based on interface type.
Fiber connector
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient. There are multiple types of fiber connectors. Figure5-7 and Figure5-8 show an MPO connector and an LC connector, respectively.
Figure5-7 MPO connector
Figure5-8 LC connector
Precautions
·     Make sure the fiber connector and fiber type match the transceiver module type.
·     The fiber ports on the switch are provided with dust plugs. To prevent particles from entering the ports, insert the dust plugs into the fiber ports that you are not to use.
·     Fiber connectors must be protected under safe and reliable outer packing, and be fitted with dust caps. Fiber connectors must be installed with dust caps when they are not in use. Take care not to scratch their end face. Replace the dust cap if it is loose or polluted.
·     Before you connect an optical fiber, use dust free paper and absolute alcohol to clean the end face of the fiber connector. You can brush the end faces only in one direction.
·     Never bend or curve a fiber during connection. After a fiber is installed well, the bend radius must be not less than 40 mm or 1.57 in (the minimum dynamic bend radius is 20 D, and the minimum static bend radius is 10 D. D indicates the outer diameter of dust caps).
·     If the fiber has to pass through a metallic board hole, the hole must have a sleek and fully filleted surface (the filleting radius must be not less than 2 mm or 0.08 in). When the fiber passes through a metallic board hole or bend along the acute side of mechanical parts, it must wear jackets or cushions.
·     Do not use excessive force when you insert or remove a fiber connector. Never pull, press, or extrude the fiber fiercely. For the allowed maximum tensile load and crush load, see Table5-9.
SFP+/SFP28 copper cable
You can use SFP+ copper cables to connect the SFP+ ports. The SFP+ copper cables available for the switch are 10G SFP+ Cu cables, as shown in Figure5-9.
You can use SFP28 copper cables to connect the SFP28 ports. The SFP28 copper cables are similar to SFP+ copper cables in appearance.
Figure5-9 SFP+ copper cable
(1) Connector
(2) Pull latch
SFP+ AOC/SFP28 AOC cable
You can use SFP+ AOC cables to connect the SFP+ ports.
You can use SFP28 AOC cables to connect the SFP28 ports. The SFP28 AOC cables are similar to SFP+ AOC cables in appearance.
Figure5-10 SFP+ AOC cable
(1) Connector
(2) Pull latch
QSFP+ copper cable
You can use QSFP+ copper cables to connect the QSFP+ ports.
Figure5-11 QSFP+ copper cable
(1) Connector
(2) Pull latch
QSFP28 copper cable
You can use QSFP28 copper cables to connect the QSFP28 ports.
Figure5-12 QSFP28 copper cable
(1) Connector
(2) Pull latch
QSFP+ AOC/QSFP28 AOC cable
You can use QSFP+ AOC cables to connect the QSFP+ ports.
You can use QSFP28 AOC cables to connect the QSFP28 ports. The QSFP28 AOC cables are similar to QSFP+ AOC cables in appearance.
Figure5-13 QSFP+ AOC cable
(1) Connector
(2) Pull latch
QSFP+ to SFP+/QSFP28 to SFP28 copper cable
A QSFP+ to SFP+ copper cable is a cable with one QSFP+ module at one end and four SFP+ modules at the other end.
A QSFP28 to SFP28 copper cable is a cable with one QSFP28 module at one end and four SFP28 modules at the other end. The QSFP28 to SFP28 copper cables are similar to QSFP+ to SFP+ copper cables in appearance.
Figure5-14 QSFP+ to SFP+ copper cable
(1) QSFP+ connector
(2) QSFP+ pull latch
(3) SFP+ connector
(4) SFP+ pull latch
QSFP112 AOC cable
You can use QSFP112 AOC cables to connect the QSFP112 ports.
Figure5-15 QSFP112 AOC cable
QSFP112 to 2QSFP112 AOC cable
A QSFP112 to 2QSFP112 AOC cable has a 400G QSFP112 module at one end and two 200G QSFP112 modules at the other end.
Figure5-16 QSFP112 to 2QSFP112 AOC cable
QSFP-DD copper cable
You can use QSFP-DD copper cables to connect the QSFP-DD ports.
Figure5-17 QSFP-DD copper cable
