H3C G3&G5 Servers HDM User Guide-2.XX&3.XX-6W107
HomeSupportConfigure & DeployUser ManualsH3C G3&G5 Servers HDM User Guide-2.XX&3.XX-6W107
02-Appendix B Sensor Name and Description
02-Appendix B Sensor Name and Description 32.03 KB
Table 1 Sensor name and description
Sensor type
Sensor name
Sensor description
Temperature
Inlet_Temp
Air inlet temperature
Outlet_Temp
Air outlet temperature
CPUN_Temp
CPU core temperature
CPUN_DTS
Remaining temperature before CPU throttling.
The value is typically negative. The smaller the value, the larger the remaining temperature.
Px_DIMM_Chy-z
Max. temperature of DIMM channels for CPU N
Front_HD_Max
Max. temperature of front SAS/SATA drives
Front_NVMe_Max
Max. temperature of front NVMe drives
Rear_HD_Max
Max. temperature of rear SAS/SATA drives
Rear_NVMe_Max
Max. temperature of rear NVMe drives
Rear_BP_Zone
Max. temperature of the rear drive backplane
Mid_HD_Max
Max. temperature of middle SAS/SATA drives
Mid_NVMe_Max
Max. temperature of middle NVMe drives
PCH
PCH temperature
PSUN
Power supply temperature
CPUN_VR
CPU VR temperature
Expander_Card
Expander card temperature
PCIN
PCI/PCIe module temperature
PCIN_Zone
Temperature of PCI/ PCIe slots on the riser card
Voltage
CPUN_Vcore
CPU N core voltage
CPUN_DDR_VPP1
VPP1 voltage of DIMMs for CPU N
CPUN_DDR_VPP2
VPP2 voltage of DIMMs for CPU N
CPUN_DDR_VDDQ1
VDDQ1 voltage of DIMMs for CPU N
CPUN_DDR_VDDQ2
VDDQ2 voltage of DIMMs for CPU N
PSUN_VIN
Power supply N input voltage
PSUN_VOUT
Power supply N output voltage
SYS_12V
System 12V voltage (system HSC output voltage)
SYS_5V
System 5V voltage
SYS_3V3
System 3.3V voltage
SYS_3V_BAT
Voltage of the RTC battery on the system board
HDD_BPN_12V
12V voltage for the front drive backplane
M_HDD_BPN_12V
12V voltage for the middle drive backplane
R_HDD_BPN_12V
12V voltage for the rear drive backplane
Current
PSUN_IIN
Power supply N input current
PSUN_IOUT
Power supply N output current
Power
Total_Power
Total chassis power
FAN_Power
Total fan power
CPU_Power
Total CPU power
MEM_Power
Total memory power
DISK_Power
Total drive power
PSUN_PIN
Power supply N input power
PSUN_POUT
Power supply N output power
Rotation speed
FANx_Speed
or FANx_F_Speed
or FANx_R_Speed
Rotation speed of fan module x in RPM
or rotation speed of the front fan in fan module x in RPM
or rotation speed of the rear fan in fan module x in RPM
Status
CPUN_Status
CPU status
CPUx_CHy_Dz
DIMM status
PCH_Status
PCH status
The embedded storage controllers and SAS controllers are included.
Watchdog2
System watchdog overflow and action
Sys_Restart
System startup/startup reason
Boards
Exceptional host power outage
BIOS_Boot_Up
BIOS startup completed
Sys_FW_Progress
System firmware (BIOS) and POST status
ACPI_State
ACPI power status
Power_Button
Power button on the lower panel
PSUN_Status
System power supply N status (N: 0 to n)
PSU_Mismatch
Model inconsistency between power supplies
PSU_Redundant
System power redundancy status
FANN_Status
or FANN_F_Status
or FANN_R_Status
Fan module N status
Status of front/rear fan in fan module N
FAN_Redundant
Fan redundancy status
Front: Disk_FN_Status
Rear: Disk_RN_Status
Middle: Disk_MN_Status
Drive status (N: 0 to n)
LAN_Leash_Lost
Link status of network adapter ports
PCIe_Status
Overall PCIe alarm status
LAN_N_Link
Link status of network adapter port N (N: 0 to n)
BMC_Boot_Up
BMC startup
UID_Button
Long press on the UID button on the panel for BMC reset
SEL_Status
SEL status
HDD_BPN_Status
Status of front drive backplane N (N: 0 to n, depending on product marks)
M_HDD_BPN_Status
Status of middle drive backplane N (N: 0 to n, depending on product marks)
R_HDD_BPN_Status
Status of rear drive backplane N (N: 0 to n, depending on product marks)
MB_Status
System board status
AreaIntrusion
Chassis status
