12-Telemetry Command Reference
HomeSupportSwitchesS6530X SeriesReference GuidesCommand ReferencesH3C S6530X Switch Series Command References-R8108Pxx-6W10012-Telemetry Command Reference
03-Flow group commands
03-Flow group commands 77.47 KB
Flow group commands
display telemetry flow-group
Use display telemetry flow-group to display the configuration and application status of flow groups.
display telemetry flow-group [ group-id | name group-name ] [ slot slot-number ]
group-id: Specifies a flow group by its ID. The value range for this argument is 1 to 7.
name group-name: Specifies a flow group by its name, a case-sensitive string of 1 to 63 characters.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the configuration and application status on the master device.
If you do not specify the group-id or name group-name option, this command displays the configuration and application status of all flow groups.
# Display the configuration of flow group 1 and its application status in slot 3.
<Sysname> display telemetry flow-group 1 slot 3
Flow group 1 (Failed)
  ACL       : 2001
  Template  :
    destination-ip
    destination-port
    source-ip
    source-port
    vxlan
      inner-destination-ip
      inner-source-ip
  Mode      : MOD
  Aging time: 100 minutes
  Rate limit: -
  Max entry : 200
Flow group 2 named aaa (Successful)
ID, name, and application status of the flow group. Values for the application status include:
·     Successful—The flow group is applied successfully.
·     Failed—The flow group fails to be applied for some reasons other than incomplete flow group configuration.
·     Inactive—The flow group has not been administratively applied.
·     Incomplete—The flow group fails to be applied because its configuration is incomplete.
Rate limit
Maximum rate of packets to the CPU in pps. A hyphen (-) indicates that no rate limit is configured.
Max entry
Maximum number of flow entries generated. A hyphen (-) indicates that no entry limit is configured.
display telemetry flow-group flow-table
Use display telemetry flow-group flow-table to display the flow entries generated by flow groups.
display telemetry flow-group flow-table [ [ group-id | name group-name ] | mod ] [ destination-ip { dst-ipv4 | dst-ipv6 } | destination-port dst-port | protocol protocol | source-ip { src-ipv4 | src-ipv6 } | source-port src-port | vxlan [ inner-destination-ip { dst-ipv4 | dst-ipv6 } | inner-destination-port dst-port | inner-protocol protocol | inner-source-ip { src-ipv4 | src-ipv6 } | inner-source-port src-port | vxlan-id vxlan-id ] * ] * { slot slot-number }
mod: Specifies flow groups in MOD mode and flow groups in simple MOD mode.
destination-ip { dst-ipv4 | dst-ipv6 }: Specifies the destination IPv4 or IPv6 address.
destination-port dst-port: Specifies the destination port number.
protocol protocol: Specifies the network layer protocol.
source-ip { src-ipv4 | src-ipv6 }: Specifies the source IPv4 or IPv6 address.
source-port src-port: Specifies the source port number.
vxlan: Specifies the VXLAN protocol.
·     inner-destination-ip { dst-ipv4 | dst-ipv6 }: Specifies the inner destination IPv4 or IPv6 address of VXLAN packets.
·     inner-destination-port dst-port: Specifies the inner destination port number of VXLAN packets.
·     inner-protocol protocol: Specifies the inner network layer protocol.
·     inner-source-ip { src-ipv4 | src-ipv6 }: Specifies the inner source IPv4 or IPv6 address.
·     inner-source-port src-port: Specifies the inner source port number.
·     vxlan-id vxlan-id: Specifies the VXLAN ID.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the flow entries on all member devices.
If you do not specify flow groups, this command displays the flow entries generated by each flow group.
# Display the flow entries generated by flow group 1 for slot 3.
<Sysname> display telemetry flow-group flow-table 1 slot 3
Slot: 3
Flow group 1 (name: abc)
Mode: MOD
Src IP          Dst IP          Pro SPort DPort Aging    Packets
In Src IP       In Dst IP       InP InSP  InDP  VXLAN ID Bytes
Drop Reason
192.168.1.86    192.168.10.2    6   20    30    12m10s   10
-               -               -   -     -     -        12400
unknown-vlan
Mode
Flow group mode:
MOD—MOD mode or simple MOD mode.
In Src IP
Inner source IP address of VXLAN packets.
In Dst IP
Inner destination IP address of VXLAN packets.
InP
Inner network layer protocol.
InSP
Inner source port number.
InDP
Inner destination port number.
VXLAN ID
VXLAN ID.
Drop Reason
Packet drop reason:
·     acl-deny—Packets match the deny statement of an ACL.
·     car-exceeded—Packet rate exceeded CAR.
·     higig-header-error—HiGig header error.
·     invalid-tpid—Invalid TPID.
·     ip-multicast-error—IP multicast packet error.
·     ipv4-dip-miss—The destination IPv4 address of a packet does not match a route or matches the default route.
·     ipv4-l3-header-error—IPv4 header error.
·     ipv6-dip-miss—The destination IPv6 address of a packet does not match a route or matches the default route.
·     parity-error—Parity error.
·     tunnel-header-error—Tunnel packet header error.
·     unknown-vlan—Unknown VLAN.
if-match acl
Use if-match acl to specify an ACL for a flow group.
Use undo if-match acl to remove an ACL from a flow group.
if-match acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name }
undo if-match acl
No ACL is specified for a flow group.
Flow group view
ipv6: Specifies the IPv6 ACL type.
mac: Specifies the Layer 2 ACL type.
user-defined: Specifies the user-defined ACL type.
acl-number: Specifies the ACL number. The following are available value ranges:
·     2000 to 2999 for basic ACLs.
·     3000 to 3999 for advanced ACLs.
·     4000 to 4999 for Layer 2 ACLs.
·     5000 to 5999 for user-defined ACLs.
name acl-name: Specifies the ACL name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter.
When specifying an ACL, follow these restrictions and guidelines:
·     If the specified ACL does not exist or does not have any rules, no traffic will match the ACL.
·     In the specified ACL, a rule with the vpn-instance keyword specified takes effect only on VPN packets, and a rule without the vpn-instance keyword specified takes effect on both packets in the public network and VPN packets.
When specifying an ACL by its number, follow these rules:
·     To specify an IPv4 ACL, specify only its number.
·     To specify an IPv6 ACL, Layer 2 ACL, or user-defined ACL, you must specify both its type and number.
When specifying an ACL by its name, follow these rules:
·     To specify an IPv4 ACL, specify only its name.
·     To specify an IPv6 ACL, Layer 2 ACL, or user-defined ACL, you must specify both its type and name.
A flow group takes effect only on the traffic that matches the specified ACL.
Only one ACL can be specified for a flow group.
# Specify ACL 3000 in flow group 1.
[Sysname] telemetry flow-group 1
[Sysname-telemetry-flow-group-1] if-match acl 3000
acl (ACL and QoS Command Reference)
telemetry apply flow-group
Use telemetry apply flow-group to apply a flow group.
Use undo telemetry apply flow-group to remove the application of a flow group.
telemetry apply flow-group { group-id | name group-name }
undo telemetry apply flow-group { group-id | name group-name }
No flow group is applied.
Only one flow group can be applied.
# Apply flow group 1.
[Sysname] telemetry apply flow-group 1
Use telemetry flow-group to create a flow group and enter its view, or enter the view of an existing flow group.
Use undo telemetry flow-group to delete a flow group.
telemetry flow-group group-id [ name group-name ] [ mode simple-mod ]
undo telemetry flow-group { group-id | name group-name }
No flow groups exist.
group-id: Specifies a flow group ID. The value range for this argument is 1 to 7.
name group-name: Specifies a flow group name, a case-sensitive string of 1 to 63 characters. The name must be globally unique and cannot start with system-defined-.
mode: Specifies a flow group mode. The default is MOD mode.
·     simple-mod: Specifies the simple MOD mode.
The flow entries generated by a flow group can be used by other features. A flow group can be in one of the following modes:
·     MOD mode—Used by MOD. This mode occupies hardware resources but has a lower burden on the CPU.
·     Simple MOD mode—Used by MOD. This mode has a higher burden on the CPU but saves hardware resources.
You cannot name or rename an existing flow group and cannot modify the mode of an existing flow group.
To delete an applied flow group, first remove the application and then delete the flow group.
# Create flow group 1 in MOD mode and enter its view.
# Create flow group 3 in simple MOD mode and enter its view.
[Sysname] telemetry flow-group 3 mode simple-mod
[Sysname-telemetry-flow-group-3]
telemetry flow-group aging-time
Use telemetry flow-group aging-time to set the aging time for flow entries.
Use undo telemetry flow-group aging-time to restore the default.
telemetry flow-group aging-time aging-time
The aging time for flow entries is 15 minutes.
aging-time: Specifies the aging time for flow entries in minutes. The value range for this argument is 1 to 16.
# Set the aging time for flow entries to 20 minutes.
[Sysname] telemetry flow-group aging-time 20
telemetry flow-group max-entry
Use telemetry flow-group max-entry to set the maximum number of flow entries generated.
Use undo telemetry flow-group max-entry to restore the default.
telemetry flow-group max-entry max-entries
The maximum number of flow entries generated is 5000.
max-entries: Specifies the maximum number of flow entries generated. The value range for this argument is 1 to 8192.
When the maximum number of flow entries is reached, the device does not generate new flow entries until old flow entries are aged out.
# Set the maximum number of flow entries generated to 100.
[Sysname] telemetry flow-group max-entry 100
template
Use template to configure a flow entry generation rule.
Use undo template to delete a flow entry generation rule.
template { destination-ip | destination-port | protocol | source-ip | source-port | vxlan { inner-destination-ip | inner-destination-port | inner-protocol | inner-source-ip | inner-source-port | vxlan-id } * } *
undo template
No flow entry generation rule is configured.
destination-ip: Generates flow entries based on the destination IP address.
destination-port: Generates flow entries based on the destination port number.
protocol: Generates flow entries based on the Layer 3 protocol type.
source-ip: Generates flow entries based on the source IP address.
source-port: Generates flow entries based on the source port number.
vxlan: Generates flow entries for VXLAN packets.
·     inner-destination-ip: Generates flow entries based on the inner destination IP address.
·     inner-destination-port: Generates flow entries based on the inner destination port number.
·     inner-protocol: Generates flow entries based on the inner Layer 3 protocol type.
·     inner-source-ip: Generates flow entries based on the inner source IP address.
·     inner-source-port: Generates flow entries based on the inner source port number.
·     vxlan-id: Generates flow entries based on the VXLAN ID.
This command enables the device to identify traffic and generate flow entries based on the specified header fields.
# Configure flow group 1 to generated flow entries based on the source IP address, destination IP address, source port number, and destination port number.
[Sysname-telemetry-flow-group-1] template destination-ip destination-port source-ip source-port
