07-MPLS Command Reference
HomeSupportRouters5G IPRAN Access RoutersReference GuidesCommand ReferencesH3C RA5300[5300-X][5300-AC] Routers Command Reference-R7752-6W10007-MPLS Command Reference
03-LDP commands
03-LDP commands 571.35 KB
LDP commands· 1
LDP common commands· 1
accept target-hello· 1
backoff 2
display mpls ldp discovery· 2
display mpls ldp error-packet 7
display mpls ldp fec· 9
display mpls ldp interface· 14
display mpls ldp lsp· 15
display mpls ldp lsp fault-analysis· 17
display mpls ldp parameter 18
display mpls ldp peer 21
display mpls ldp summary· 25
display mpls ldp troubleshooting· 26
dscp· 28
error-packet size· 29
graceful-restart 30
graceful-restart timer 30
label-distribution· 31
log enable· 32
log record-size· 33
loop-detect 33
lsr-id· 34
maxhops· 35
md5-authentication all 36
md5-authentication peer-lsr-id· 37
md5-authentication prefix-list 38
mpls ldp· 39
mpls ldp local-lsr-id· 40
mpls ldp timer 41
non-stop-routing· 43
propagate mapping· 44
pv-limit 45
reset mpls ldp· 45
reset mpls ldp error-packet 46
snmp-agent trap enable ldp· 47
snmp-agent trap enable ldp-private· 47
vpn-instance· 48
IPv4 LDP commands· 49
accept-label 49
advertise-label peer 50
advertise-label prefix-list 52
display mpls ldp igp sync· 53
igp sync delay· 54
igp sync delay on-restart 55
import bgp· 56
lsp-trigger 57
mpls ldp enable· 59
mpls ldp igp sync disable· 59
mpls ldp sync (IS-IS view) 60
mpls ldp sync (OSPF view/OSPF area view) 61
mpls ldp transport-address· 62
session protection· 63
targeted-peer 64
IPv6 LDP commands· 65
ipv6 accept-label 65
ipv6 advertise-label peer 67
ipv6 advertise-label prefix-list 69
ipv6 import bgp· 70
ipv6 lsp-trigger 71
mpls ldp ipv6 enable· 73
mpls ldp transport-address· 74
targeted-peer 75
LDP commands
LDP common commands
accept target-hello
Use accept target-hello to enable the device to automatically establish targeted LDP sessions on receiving LDP Targeted Hellos.
Use undo accept target-hello to disable the targeted session automatic setup feature.
accept target-hello { all | prefix-list prefix-list-name }
The device does not automatically establish targeted LDP sessions on receiving Targeted Hellos.
LDP view
all: Automatically establishes targeted LDP sessions on receiving all Targeted Hellos.
prefix-list prefix-list-name: Automatically establishes targeted LDP sessions on receiving Targeted Hellos from peers permitted by an IPv4 prefix list. The prefix-list-name argument represents the IPv4 prefix list name, a case-sensitive string of 1 to 63 characters.
In some networks, the destination device must be able to establish an targeted LDP session automatically when it receives Targeted Hellos from the source device. For example, on a remote LFA FRR network, the source node computes PQ nodes. LDP needs to automatically establish targeted sessions between the source node and the PQ nodes. To achieve this purpose, you must execute this command on the PQ nodes. Then, the PQ nodes can automatically establish the targeted LDP sessions on receiving Targeted Hellos from the source node. For more information about remote LFA FRR, see IS-IS configuration in Layer 3—IP Routing Configuration Guide.
# Configure the device to automatically establish targeted LDP sessions when it receives Targeted Hellos from peers 1.1.1.9 and 2.2.2.9.
[Sysname] ip prefix-list accept-fec-list index 1 permit 1.1.1.9 32
[Sysname] ip prefix-list accept-fec-list index 2 permit 2.2.2.9 32
[Sysname] mpls ldp
[Sysname-ldp] accept target-hello prefix-list accept-fec-list
ip prefix-list (Layer 3—IP Routing Command Reference)
backoff
Use backoff to set the LDP backoff initial delay time and maximum delay time.
Use undo backoff to restore the default.
backoff initial initial-time maximum maximum-time
undo backoff
The LDP backoff initial delay time is 15 seconds, and the maximum delay time is 120 seconds.
LDP view
LDP-VPN instance view
initial initial-time: Specifies the LDP backoff initial delay time in the range of 15 to 50331 seconds.
maximum maximum-time: Specifies the LDP backoff maximum delay time in the range of 120 to 50331 seconds.
LDP peers continually negotiate with each other until a session is set up. If LDP peers use incompatible negotiation parameters (for example, different label advertisement modes), a large amount of negotiation traffic will enter the network. To suppress LDP session negotiation traffic, use this command to control the interval between negotiation attempts.
After LDP fails to establish a session to a peer LSR for the first time, LDP does not start another attempt until the initial delay timer expires. If the session setup fails again, LDP waits for two times the previous delay before the next attempt. This process continues until the maximum delay time is reached. After that, the maximum delay time always takes effect.
If you configure the initial delay time to be larger than the maximum delay time, the configuration does not take effect. LDP uses the maximum delay time as the initial delay time.
# Configure LDP backoff for the public network, and set the initial delay time to 100 seconds and the maximum delay time to 300 seconds.
[Sysname] mpls ldp
[Sysname-ldp] backoff initial 100 maximum 300
Use display mpls ldp discovery to display LDP discovery information.
display mpls ldp discovery [ all [ ipv6 ] | [ vpn-instance vpn-instance-name ] [ [ interface interface-type interface-number | peer peer-lsr-id ] [ ipv6 ] | targeted-peer { ipv4-address | ipv6-address } ] ] [ verbose ] [ slot slot-number ]
all: Displays LDP discovery information for the public network and all VPN instances.
vpn-instance vpn-instance-name: Displays LDP discovery information for the specified MPLS L3VPN instance. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays LDP discovery information for the public network.
interface interface-type interface-number: Displays information about basic discovery that uses the specified interface to send Link Hellos. The interface-type interface-number argument represents the interface type and number.
peer peer-lsr-id: Displays information about both basic and extended discovery mechanisms that have discovered the specified LDP peer. The peer-lsr-id argument represents the LSR ID of the LDP peer.
ipv6: Displays LDP IPv6 basic and extended discovery information. If you do not specify this keyword, the command displays LDP IPv4 basic and extended discovery information.
The following compatibility matrix shows the support of hardware platforms for this keyword:
Hardware platform
MPU model
Parameter compatibility
RA5300, RA5300-X, RA5300-AC
RSU-400, RSU-400S
Yes
RSU-400-G
No
targeted-peer: Displays information about extended discovery that has sent Targeted Hellos to the specified LDP peer.
ipv4-address: Specifies the IPv4 address of the LDP peer.
ipv6-address: Specifies the IPv6 address of the LDP peer.
verbose: Displays detailed LDP discovery information. If you do not specify this keyword, the command displays brief LDP discovery information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays LDP discovery information on the active MPU.
If you do not specify the all or vpn-instance keyword, this command displays LDP discovery information on the public network.
If you do not specify the interface, peer, ipv6, or targeted-peer keyword, this command displays all LDP IPv4 basic and extended discovery information.
# Display brief LDP IPv4 discovery information for the public network.
<Sysname> display mpls ldp discovery
VPN instance: public instance
     Type: L - Link Hello, T - Targeted Hello
Discovery Source              Hello Sent/Rcvd       Peer LDP ID
(L) XGE2/0/1                  83/80                 100.100.100.18:0
                                                    200.100.100.18:0
(T) 100.100.100.18            23/20                 100.100.100.18:0
VPN instance
Network where LDP is running. For the public network, this field displays public instance. For a VPN instance, this field displays the VPN instance name.
Type of LDP discovery:
·     L—Basic discovery, which sends Link Hellos to discover peers.
·     T—Extended discovery, which sends Targeted Hellos to discover peers.
Discovery Source
Discovery source.
·     If the LDP discovery type is L, this field displays the interface that discovers the peer.
·     If the LDP discovery type is T, this field displays the IPv4 address of the peer.
Hello Sent/Rcvd
Number of hellos sent to the peer/number of hellos received from the peer.
Peer LDP ID
LDP identifier of the LDP peer.
# Display brief LDP IPv6 discovery information for the public network.
<Sysname> display mpls ldp discovery ipv6
Interface: Ten-GigabitEthernet2/0/1
  Hello Sent/Rcvd: 12/12
    Peer LDP ID: 100.100.100.18:0
    Peer LDP ID: 200.200.200.28:0
Targeted Hellos: 2001:0000:130F::09C0:876A:130B ->
                 2005:130F::09C0:876A:130B
  Hello Sent/Rcvd: 93/80
    Peer LDP ID: 100.100.100.180:0
Interface that discovers the LDP peer by using basic discovery.
Hello Sent/Rcvd
Peer LDP ID
Targeted Hellos
Extended LDP discovery information. The address before -> is the local IP address. The address after -> is the peer IP address.
# Display detailed LDP IPv4 discovery information for the public network.
<Sysname> display mpls ldp discovery verbose
Link Hellos:
  Interface Ten-GigabitEthernet2/0/1
    Local LDP ID     : 100.100.100.17:0
    Hello Interval   : 5000 ms            Hello Sent/Rcvd  : 83/160
    Transport Address: 100.100.100.17
    Peer LDP ID      : 100.100.100.18:0
      Source Address : 202.118.224.18     Transport Address: 100.100.100.18
      Hello Hold Time: 15 sec (Local: 15 sec, Peer: 15 sec)
    Peer LDP ID      : 100.100.100.20:0
      Source Address : 202.118.224.20     Transport Address: 100.100.100.20
Targeted Hellos:
  100.100.100.17 -> 100.100.100.18 (Active, Passive)
    Hello Interval   : 15000 ms           Hello Sent/Rcvd  : 23/20
    Session Setup    : Config/Tunnel
      Source Address : 100.100.100.18     Transport Address: 100.100.100.18
      Hello Hold Time: 45 sec (Local: 45 sec, Peer: 45 sec)
  100.100.100.17 -> 100.100.100.20 (Active, Passive)
    Hello Interval   : 15000 ms           Hello Sent/Rcvd  : 23/22
      Source Address : 100.100.100.20     Transport Address: 100.100.100.20
# Display detailed LDP IPv6 discovery information for the public network.
<Sysname> display mpls ldp discovery ipv6 verbose
Link Hellos:
    Transport Address: 2001::2
      Source Address : FE80:130F:20C0:29FF:FEED:9E60:876A:130B
      Transport Address: 2001::1
Targeted Hellos:
        2005:130F::09C0:876A:130B(Active, Passive)
    Transport Address: 2001:0000:130F::09C0:876A:130B
      Source Address : 2005:130F::09C0:876A:130B
      Destination Address : 2001:0000:130F::09C0:876A:130B
      Transport Address   : 2005:130F::09C0:876A:130B
VPN instance
Name of the VPN instance of LDP. If LDP runs on the public network, this field displays public instance.
Link Hellos
Information about basic discovery that sends Link Hellos on interfaces.
In a non-point-to-point network, an interface might discover multiple peers.
Interface using basic discovery.
Local LDP ID
LDP identifier of the local LSR.
Hello Interval
Hello interval in milliseconds.
Hello Sent/Rcvd
Number of Hellos sent or received on the interface.
Transport Address
Local transport address.
Peer LDP ID
Source Address
Source IP address of received Hello messages.
Destination Address
Destination IP address of received Hello messages.
Transport Address
Transport address in the received Hello messages—the transport address of the LDP peer.
Hello Hold Time
Hello hold time in seconds.
Local—Local hello hold time.
Peer—Peer hello hold time.
The negotiated hello hold time is the smaller value of the local and peer hold time values.
Targeted Hellos
Information about extended LDP discovery that sends Targeted Hellos to peers.
Session Setup
Targeted LDP session setup mode. Possible values include:
·     Config—The session was triggered by user configuration.
·     Tunnel—The session was triggered by MPLS LDP configuration on the tunnel interface.
·     L2VPN—The session was triggered automatically by MPLS L2VPN.
·     Session-Protect—The session was triggered by the session protection feature.
·     OSPF RLFA—The session was triggered by OSPF Remote LFA.
·     IS-IS RLFA—The session was triggered by IS-IS Remote LFA.
·     Auto Accept—The session was triggered automatically on receiving a Targeted Hello.
·     The address before -> (100.100.100.17 in this example) is the local IP address.
·     The address after -> (100.100.100.18 in this example) is the peer IP address.
·     (Active) indicates that the local LSR is the Targeted Hello sender.
·     (Passive) indicates that the local LSR is the Targeted Hello receiver.
·     (Active, Passive) indicates that the local LSR is both the Targeted Hello sender and receiver.
Use display mpls ldp error-packet to display information about erroneous packets received by LDP.
display mpls ldp error-packet { tcp [ vpn-instance vpn-instance-name ] [ peer peer-id ] | udp [ interface interface-type interface-number ] } [ reverse ]
tcp: Specifies erroneous TCP packets received by LDP.
vpn-instance vpn-instance-name: Specifies an LDP instance binding an MPLS L3VPN instance. The vpn-instance-name argument specifies the VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information about erroneous TCP packets received in the public LDP instance.
peer peer-lsr-id: Specifies an LDP peer by its LSR ID. If you do not specify this option, the command displays information about erroneous TCP packets received from all LDP peers.
udp: Specifies erroneous UDP packets received by LDP.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays information about erroneous UDP packets received from all interfaces.
reverse: Displays erroneous packet information in descending order based on time, from newest to oldest. If you do not specify this keyword, the command displays erroneous packet information in ascending order based on time, from oldest to newest.
Receiving an erroneous packet can result in the failure to establish or the disconnection of an LDP session. This command displays the content, error reasons, and other information of the erroneous packets received by LDP. You can use the information displayed by this command to locate and troubleshoot LDP session faults.
# Display errorneous TCP packets received by LDP.
<Sysname> display mpls ldp error-packet tcp
Total 1 records
Peer LDP ID    : 2.2.2.9
VPN instance   : public
Receive time   : 2018-04-31 07:12:41
Error reason   : Bad LDP Identifier
Packet length  : 18 bytes
Message type   : -
Packet content :
 00 01 00 0E 02 02 02 09 00 00 02 01 00 04 80 00
 A0 D8
Peer LDP ID
LDP identifier of the peer.
VPN instance
VPN instance name.
Receive time
Time when the erroneous packet was received, in the format of YYYY-MM-DD HH:MM:SS.
Error Reason
Reason for the error. Possible values include:
·     Bad LDP identifier.
·     Bad protocol version.
·     Bad PDU length.
·     Unknown message type.
·     Bad message length.
·     Unknown TLV.
·     Bad TLV length.
·     Malformed TLV value.
·     Unknown FEC.
·     Missing message parameters.
·     Unsupported address family.
Packet length
Length of the error packet, in bytes.
Message type
Message type. Possible values include:
·     Label Request Message.
·     Label Mapping Message.
·     Label Release Message.
·     Label Withdraw Message.
·     Label Abort Request Message.
·     Initialization Message.
·     Keepalive Message.
·     Notification Message.
·     Address Message.
·     Address Withdraw Message.
If the message type is unknown, this field displays a hyphen (-).
Packet content
Content of the error packet.
Use display mpls ldp fec to display LDP FEC-label mappings.
display mpls ldp fec [ all [ ipv6 ] [ summary ] | [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6-address prefix-length | [ ipv6 ] [ summary ] ] ] [ slot slot-number ]
all: Displays FEC-label mappings for the public network or all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. This command displays FEC-label mappings for the specified VPN instance. If you do not specify a VPN instance, this command displays FEC-label mappings for the public network.
ipv4-address mask-length: Specifies an IPv4 FEC by an IPv4 address and a mask length in the range of 0 to 32.
ipv6-address prefix-length: Specifies an IPv6 FEC by an IPv6 address and a prefix length in the range of 0 to 128.
ipv6: Displays IPv6 FEC-label mappings.
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
summary: Displays summary information about all FEC-label mappings learned by LDP.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays FEC-label mappings on the active MPU.
If you do not specify the all or vpn-instance keyword, this command displays FEC-label mappings for the public network.
If you specify only the summary keyword, this command displays summary information about all IPv4 FEC-label mappings.
If you specify only the ipv6 keyword, this command displays detailed information about all IPv6 FEC-label mappings.
If you specify the summary and ipv6 keywords, this command displays summary information about all IPv6 FEC-label mappings.
If you do not specify any of the ipv4-address mask-length, ipv6-address prefix-length, ipv6, and summary parameters, this command displays detailed information about all IPv4 FEC-label mappings.
# Display detailed information about all IPv4 FEC-label mappings learned by LDP for the public network.
<Sysname> display mpls ldp fec
 FEC: 100.100.100.18/32
   Flags: 0x02
   In Label: 1531
   Label Advertisement Policy:
     FEC Prefix-list: Fec-prefix-list
     Peer Prefix-list: Peer-prefix-list
   Upstream Info:
     Peer: 100.100.100.18:0        State: Established (stale)
     Peer: 100.100.100.20:0        State: Established (stale)
   Downstream Info:
       Out Label: 3                State: Established (stale)
       Next Hops: 202.118.224.18          XGE2/0/1
       Out Label: 1025             State: Established (stale)
       Label Stack Index: 16777218
   RIB Info:
     Protocol        : OSPF        BGP AS Num   : 0
     Label Proto ID  : 1           NextHopCount : 2
     VN ID           : 0x423000004
     Tunnel ID       : -           BkTunnel ID  : 0x1200001
     Tunnel ID       : -           BkTunnel ID  : -
 FEC: 200.100.100.18/32 (No route)
   Flags: 0x0
   In Label: 1532
   Upstream Info:
     Peer: 200.200.200.28:0        State: Established
   Downstream Info:
     Peer: 120.100.100.18:0
       Out Label: 3                State: Idle
# Display detailed information about all IPv6 FEC-label mappings learned by LDP for the public network.
<Sysname> display mpls ldp fec ipv6
 FEC: 2005:130F::09C0/128
   Flags: 0x02
   In Label: 1026
     FEC Prefix-list: Fec-ipv6-prefix-list
     Peer Prefix-list: Peer-ipv6-prefix-list
   Upstream Info:
   Downstream Info:
       Next Hops:
       FE80:130F:20C0:29FF:FEED:9E60:876A:130B          XGE2/0/1
   RIB Info:
     Label Proto ID  : 1           NextHopCount : 1
     VN ID           : 0x423000004
Table 5 Command output
VPN instance
FEC
Forwarding equivalence class identified by an IP prefix.
Flags
FEC flag. It represents different things by setting different bits to 1. If multiple bits are set to 1, the flag represents all the things that correspond to those bits. This field displays the sum of the flag values. For example, if the FEC flag has values 0x00000001 and 0x00000020, this field displays 0x00000021.
Possible value of the FEC flag:
·     0x0—Initial value.
·     0x00000001—Egress LSP.
·     0x00000002—Ingress LSP.
·     0x00000004—Waiting to add an outgoing label to RIB.
·     0x00000008—Waiting to refresh LSPs in LSM.
·     0x00000010—Ready to advertise labels.
·     0x00000020—FEC-label mappings have been refreshed during a GR process.
·     0x00000040—Delayed refreshing LSPs in LSM.
·     0x00000080—Non-egress LSP waiting for the recovery during a GR process.
·     0x00000100—The LDP session uses this address as the transmission address.
·     0x10000000—PQ address registered by OSPF Remote LFA.
·     0x20000000—PQ address registered by IS-IS Remote LFA.
·     0x40000000—LSP waiting to be refreshed by OSPF.
·     0x80000000—LSP waiting to be refreshed by IS-IS.
In Label
Incoming label assigned by the local LSR to the FEC.
Label advertisement policy.
FEC Prefix-list
IP prefix list for filtering FEC prefixes.
Peer Prefix-list
IP prefix list for filtering LDP peers.
Upstream Info
Upstream peer to which the local LSR advertised the FEC-label mapping and current state of the LSP.
Peer
LDP ID of an upstream peer.
Current state of the LSP established with the upstream peer:
·     Established—Active state.
·     Idle—Initial state.
·     Release Awaited—Waiting for a Release message.
·     Resource Awaited—Waiting for a label for the FEC.
The state might be marked as follows:
·     stale—The FEC-label mapping is under a GR process.
·     backup—The LSP is a backup LSP.
·     unavailable—The LSP cannot participate in traffic forwarding.
Downstream Info
Downstream peer from which the local LSR received the FEC-label mapping, and current state of the LSP.
Peer
LDP ID of a downstream peer.
Out Label
Outgoing label assigned by the downstream LSR for the FEC.
Current state of the LSP established with the downstream peer:
·     Idle—Inactive state.
Next Hops
Next hops and outgoing interfaces.
Label Stack Index
Label stack index for the ingress LDP LSP selected for the current LDP LSP after route recursion.
RIB Info
Routing information for the FEC.
Protocol
Routing protocol used to establish LDP LSPs:
·     BGP
·     Direct
·     IS-IS
·     OSPF
·     Static
BGP AS Num
BGP AS number. If the routing protocol is not BGP, this field displays 0.
Label Proto ID
Type of the label allocation protocol:
·     0—No label allocation protocol.
·     1—LDP.
·     2—BGP.
·     3—Static LSP.
NextHop Count
Number of ECMP routes.
VN ID
Virtual next hop ID.
Tunnel ID
ID of the tunnel ID for the FEC on an LDP over MPLS TE network. If no tunnel exists, this field display a hyphen (-).
BkTunnel ID
ID of the backup tunnel for the FEC on an LDP over MPLS TE network. If no backup tunnel exists, this field display a hyphen (-).
# Display summary information about all IPv4 FEC-label mappings learned by LDP for the public network.
<Sysname> display mpls ldp fec summary
FECs         : 3
Implicit Null: 1
Explicit Null: 0
Non-Null     : 2
No Label     : 0
No Route     : 0
Sent         : 3
Received     : 3
# Display summary information about all IPv6 FEC-label mappings learned by LDP for the public network.
<Sysname> display mpls ldp fec ipv6 summary
FECs         : 4
Implicit Null: 0
Explicit Null: 0
Non-Null     : 4
No Label     : 0
No Route     : 0
Sent         : 3
Received     : 3
Table 6 Command output
VPN instance
FECs
Number of FECs that LDP has discovered from the routing protocol or FEC-label mappings advertised by peers.
Implicit Null
Number of FECs that are bound to the implicit null label.
Explicit Null
Number of FECs that are bound to the explicit null label.
Non-Null
Number of FECs that are bound to non-null labels.
No Label
Number of FECs without a label.
No Route
Number of FECs without matching routes.
The reason why an FEC has no matching route might be one of the following:
·     No matching route exists in the routing table.
·     The matching route exists in the routing table, but it is not redistributed into LDP.
·     (For IPv6) The mpls ldp ipv6 enable or targeted-peer ipv6-address command is not configured on the device. In this case, an FEC is considered to have no route even though the matching IPv6 route exists in the routing table and has been redistributed into LDP.
Sent
Number of label mappings sent and being sent.
Received
Number of label mappings accepted.
Use display mpls ldp interface to display LDP interface information.
display mpls ldp interface [ all | [ vpn-instance vpn-instance-name ] [ interface-type interface-number ] ] [ ipv6 ]
all: Displays LDP interface information for the public network and all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. This command displays LDP interface information for the specified VPN instance. If you do not specify a VPN instance, this command displays LDP interface information for the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about all LDP interfaces except VA interfaces. For information about VA interfaces, see PPPoE in Layer 2—WAN Access Configuration Guide.
ipv6: Displays information about interfaces enabled with IPv6 LDP. If you do not specify this keyword, the command displays information about interfaces enabled with IPv4 LDP.
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
If you do not specify the all or vpn-instance keyword, this command displays LDP interface information for the public network.
# Display information about all interfaces enabled with IPv4 LDP for the public network.
<Sysname> display mpls ldp interface
Interface                 MPLS         LDP             Auto-config
XGE2/0/1                  Enabled      Configured      -
XGE2/0/5                  Enabled      Configured      -
# Display information about all interfaces enabled with IPv6 LDP for the public network.
<Sysname> display mpls ldp interface ipv6
XGE2/0/1                  Enabled      Not Configured  -
XGE2/0/2                  Enabled      Not Configured  -
Table 7 Command output
VPN instance
Interface enabled with LDP.
MPLS
Whether the interface is enabled with MPLS.
LDP
Whether the interface is configured with the mpls ldp enable command or the mpls ldp ipv6 enable command.
Auto-config
LDP automatic configuration information:
·     If LDP autoconfiguration is enabled, this field displays IGP process information, such as OSPF process ID and OSPF area ID.
·     If LDP autoconfiguration is disabled, this field displays a hyphen (-).
mpls ldp
mpls ldp enable
Use display mpls ldp lsp to display information about LSPs generated by LDP.
display mpls ldp lsp [ all [ ipv6 ] | [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6-address prefix-length | ipv6 ] ]
all: Displays LDP LSP information for the public network and all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. This command displays LDP LSP information for the specified VPN instance. If you do not specify a VPN instance, this command displays LDP LSP information for the public network.
ipv6: Displays information about LDP LSPs for IPv6 FECs.
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
If you do not specify the all or vpn-instance keyword, this command displays LDP LSP information for the public network.
If you do not specify an IPv4 address, an IPv6 address, or the the ipv6 keyword, this command displays information about LDP LSPs for all IPv4 FECs.
# Display LDP LSP information for IPv4 FECs on the public network.
<Sysname> display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A – unavailable
FECs: 4            Ingress: 1          Transit: 1      Egress: 3
FEC                In/Out Label        Nexthop         OutInterface/LSINDEX
1.1.1.1/32         -/3                 10.1.1.1        XGE2/0/1
                   1151/3              10.1.1.1        XGE2/0/1
                   -/1025(B)           30.1.1.1        XGE2/0/2
                   1151/1025(B)        30.1.1.1        XGE2/0/2
2.2.2.2/32         3/-
                   -/1151(L)
3.3.3.3/32         -/3                 10.1.1.1        XGE2/0/1
                   1152/3              10.1.1.1        XGE2/0/1
                   -/1025(B)                           LSINDEX16777218
                   1152/1025(B)                        LSINDEX16777218
10.1.1.0/24        1149/-
                   -/1149(L)
192.168.1.0/24     1150/-
                   -/1150(L)
# Display LDP LSP information for IPv6 FECs on the public network.
<Sysname> display mpls ldp lsp ipv6
FECs: 2            Ingress: 1          Transit: 1      Egress: 1
FEC: 2080::29FF:FEED:9E60:876A:130B/128
In/Out Label: -/3                                OutInterface : XGE2/0/1
Nexthop     : FE80:12F:C0::130B
In/Out Label: 1151/3                             OutInterface : XGE2/0/1
In/Out Label: -/1026(L)                          OutInterface : -
Nexthop     : -
FEC: 2001::1/128
In/Out Label: 3/-                               OutInterface : -
Nexthop     : -
Table 8 Command output
VPN instance
Status Flags
LSP status:
·     *—Stale, indicating that the LSP is under a GR process.
·     L—Liberal, indicating that the LSP is not activated because the peer that advertised the label is not the next hop of the route.
·     B—Backup, indicating a backup LSP.
·     N/A—Unavailable, indicating that the LSP is not the optimal LSP for traffic forwarding.
FECs
Total number of FECs.
Ingress
Number of LSPs that take the local device as the ingress node.
Transit
Number of LSPs that take the local device as a transit node.
Egress
Number of LSPs that take the local device as the egress node.
FEC
In/Out Label
Incoming/outgoing label.
Nexthop
Next hop address for the FEC.
Outgoing interface for the FEC or the label stack index of the LDP LSP.
LSINDEXnumber specifies the ingress LDP LSP selected for the current LDP LSP after route recursion. The ingress LDP LSP is the one that matches the LSINDEX entry with a label stack index of number.
display mpls forwarding nhlfe
display mpls lsp
Use display mpls ldp lsp fault-analysis to display fault analysis for LDP LSP setup.
display mpls ldp lsp fault-analysis [ vpn-instance vpn-instance-name ] ipv4-address mask-length
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. This command displays fault analysis for LDP LSP setup in the specified VPN instance. If you do not specify a VPN instance, this command displays fault analysis for LDP LSP setup on the public network.
# Display fault analysis for LDP LSP setup on the public network.
<Sysname> display mpls ldp lsp fault-analysis 1.1.1.1 24
Ingress:
  LSP State               : Up         Route Check             : Passed
  Policy Check            : Passed     Downstream Session Check: Passed
  Downstream Mapping Check: Passed     Resource Check          : Passed
Transit:
Egress:
  LSP State               : Down       Route Check             : Passed
  Policy Check            : Failed     Resource Check          : Passed
Table 9 Command output
LSP State
LSP setup state:
·     Up—The LSP has been established.
·     Down—The LSP has not been established.
Route Check
Check whether routing information exists in the LDP process:
·     Passed—The check passed.
·     Failed—The check failed.
Policy Check
Check whether the LSP is permitted by LDP policies:
Check whether the downstream session exists:
Check whether the downstream advertises label mappings to the current node.
Resource Check
Check whether the label is available.
Use display mpls ldp parameter to display LDP running parameters.
display mpls ldp parameter [ all | vpn-instance vpn-instance-name ]
all: Displays LDP running parameters for the public network and all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. This command displays LDP running parameters for the specified VPN instance. If you do not specify a VPN instance, this command displays LDP running parameters for the public network.
If you do not specify the all or vpn-instance keyword, this command displays LDP running parameters for the public network.
This command displays the following LDP running parameters:
·     Global parameters, which are applicable to all LDP networks.
·     Instance parameters, which are applicable to a specific LDP network.
# Display LDP running parameters for the public network.
<Sysname> display mpls ldp parameter
 Global Parameters:
   Protocol Version    : V1         IGP Sync Delay on Restart : 90 sec
   Nonstop Routing     : Off        Nonstop Routing State     : Not Ready
   Graceful Restart    : Off        Forwarding State Hold Time: 360 sec
   Reconnect Time      : 120 sec    DSCP Value                : 48
   mLDP P2MP           : On         mLDP Recursive-FEC        : Off
 Instance Parameters:
   Instance ID         : 0
   LSR ID              : 0.0.0.0
   Loop Detection      : Off        Entropy Label                  : On
   Hop Count Limit     : 32         Path Vector Limit              : 32
   Label Retention Mode: Liberal    Label Distribution Control Mode: Ordered
   IGP Sync Delay      : 0 sec
Table 10 Command output
VPN instance
Global Parameters
LDP running parameters for all LDP-enabled networks.
Protocol Version
LDP protocol version.
Maximum delay time (in seconds) that LDP must wait before it notifies IGP of an LDP session-up event when there is an LDP restart.
Nonstop Routing
Whether the nonstop routing feature is enabled:
·     On—Enabled.
·     Off—Disabled.
LDP NSR state:
·     Ready—NSR is enabled, and LDP session and LSP information has been synchronized to the standby process. If an active/standby switchover occurs, the LDP session stays in Operational state, and the forwarding is not interrupted.
·     Not Ready—NSR is not enabled, or NSR is enabled but LDP session and LSP information synchronization to the standby process is not completed. If an active/standby switchover occurs, the LDP session might not be able to stay in Operational state, and the forwarding might be interrupted.
Graceful Restart
Whether the GR feature is enabled:
·     On—Enabled.
·     Off—Disabled.
MPLS Forwarding State Holding time in seconds.
Reconnect Time
Reconnect time in seconds.
DSCP Value
DSCP value for outgoing LDP packets.
mLDP P2MP
Enabling status of mLDP P2MP:
·     On—Enabled.
·     Off—Disabled.
mLDP Recursive-FEC
Enabling status of mLDP recursive FEC:
·     On—Enabled.
·     Off—Disabled.
Instance Parameters
LDP running parameters for a VPN instance or public network.
Instance ID
VPN instance ID. For the public network, this field displays 0.
LSR ID
LSR ID of the local device.
Loop Detection
Whether loop detection is enabled:
·     On—Enabled.
·     Off—Disabled.
Entropy Label
Whether the entropy label capability is enabled:
·     On—Enabled.
·     Off—Disabled.
Hop Count Limit
Hop count limit specified for loop detection.
Path Vector Limit
Path Vector length limit specified for loop detection.
The device supports only the Liberal mode.
Label distribution control mode: Ordered or Independent.
IGP Sync Delay
Delay time (in seconds) that LDP must wait before it notifies IGP of an LDP session-up event.
Use display mpls ldp peer to display LDP peer and session information.
display mpls ldp peer [ all | [ vpn-instance vpn-instance-name ] [ peer-lsr-id ] ] [ verbose ] [ slot slot-number ]
all: Displays LDP peer and session information for the public network and all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. This command displays LDP peer and session information for the specified VPN instance. If you do not specify a VPN instance, this command displays LDP peer and session information for the public network.
peer peer-lsr-id: Specifies an LDP peer by its LSR ID. If you do not specify this option, the command displays all LDP peers and related session information.
verbose: Displays detailed LDP peer and session information. If you do not specify this keyword, the command displays brief LDP peer and session information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays LDP peer and session information on the active MPU.
If you do not specify the all or vpn-instance keyword, this command displays LDP peer and session information for the public network.
# Display brief information about all LDP peers and LDP sessions for the public network.
<Sysname> display mpls ldp peer
Total number of peers: 1
Peer LDP ID             State         Role     GR   Auth      KA Sent/Rcvd
2.2.2.9:0               Operational   Passive  Off  Keychain  39/39
Table 11 Command output
VPN instance
Peer LDP ID
State of the LDP session between the local LSR and the peer:
·     Non Existent—No TCP connection is established.
·     Initialized—A TCP connection has been established.
·     OpenRecv—LDP has received an acceptable initialization message.
·     OpenSent—LDP has sent an initialization message.
·     Operational—An LDP session has been established.
Role
Role of the local LSR in the session: Active or Passive.
In a session, the LSR with a higher IP address takes the Active role. The Active LSR initiates a TCP connection to the passive LSR.
GR
Whether GR is enabled on the peer:
·     On—Enabled.
·     Off—Disabled.
Auth
Authentication method enabled for the LDP session on the local device:
·     MD5.
·     Keychain. This option is not support in the current software version.
KA Sent/Rcvd
Number of keepalive messages sent/received.
# Display detailed information about all LDP peers and LDP sessions for the public network.
<Sysname> display mpls ldp peer verbose
 TCP Connection   : 100.100.100.20:47515 -> 100.100.100.17:646
 Session State    : Operational        Session Role     : Passive
 Session Up Time  : 0000:00:03 (DD:HH:MM)
 Max PDU Length   : 4096 bytes (Local: 4096 bytes, Peer: 4096 bytes)
 Keepalive Time     : 45 sec (Local: 45 sec, Peer: 45 sec)
 Keepalive Interval : 15 sec
 Msgs Sent/Rcvd   : 288/426
 KA Sent/Rcvd     : 13/13
 Label Adv Mode   : DU                 Graceful Restart : On
 Reconnect Time   : 120 sec            Recovery Time    : 360 sec
 Loop Detection   : On                 Path Vector Limit: 32
 mLDP P2MP        : On
 Discovery Sources:
   Targeted Hello 100.100.100.17 -> 100.100.100.20 (Active, Passive)
     Hello Hold Time: 45 sec           Hello Interval   : 15000 ms
   Targeted Hello 2005:130F::09C0:876A:130B ->
                  2001:0000:130F:0000:0000:09C0:876A:130B (Active, Passive)
     Hello Hold Time: 15 sec           Hello Interval   : 5000 ms
   Ten-GigabitEthernet2/0/1 (v6)
 Label Acceptance Policy :
   accept-label peer peer-prefix-list peer1 prefix-list fec2
   ipv6 accept-label peer peer-prefix-list peer3 prefix-list fec4
 Label Advertisement Policy :
   advertise-label peer peer-prefix-list peer1 prefix-list fec2
   ipv6 advertise-label peer peer-prefix-list peer3 prefix-list fec4
 Session Protection      : On
   State            : Ready            Duration         : 120 sec
 Addresses received from peer:
   202.118.224.20   100.100.100.20   11.22.33.44      1.2.3.10
   1.2.3.4
Table 12 Command output
VPN instance
Peer LDP ID
Local LDP ID
TCP connection
TCP connection information for the session. It includes the IP addresses and port numbers used by both ends of the TCP connection, and whether authentication is enabled for the TCP connection. If MD5 authentication is enabled, this field displays MD5 On. If authentication is not enabled, this field does not display authentication information.
Session State
State of the LDP session:
Session Role
Role the local LSR in the session: Active or Passive.
Session Up time
Duration of the session in Operational state.
Max PDU Length
Maximum PDU length negotiated, in bytes.
Local—Maximum PDU length (in bytes) on the local LSR.
Peer—Maximum PDU length (in bytes) on the peer.
Keepalive Time
Keepalive time negotiated, in seconds.
Local—Locally configured Keepalive holding time in seconds.
Peer—Keepalive holding time (in seconds) configured on the peer.
Keepalive Interval
Keepalive interval in seconds.
Msgs Sent/Rcvd
Total number of LDP messages sent and received.
KA Sent/Rcvd
Total number of Keepalive messages sent and received.
Label Adv Mode
Label advertisement mode negotiated. The device only supports the DU mode.
Graceful Restart
·     On—Enabled.
·     Off—Disabled.
Reconnect Time
Reconnect time negotiated, in seconds.
Recovery Time
Recovery time (in seconds) carried in packets sent by the peer.
Loop Detection
Whether loop detection is enabled on the peer:
·     On—Enabled.
·     Off—Disabled.
Path Vector Limit
Maximum Path Vector length configured on the peer.
mLDP P2MP
Whether mLDP P2MP is enabled:
·     On—Enabled.
·     Off—Disabled.
Discovery Sources
Discovery source of the LDP peer.
Targeted Hello
LDP peer discovered by the extended discovery mechanism.
·     The address after -> (100.100.100.20 in this example) is the peer IP address.
·     (Active) indicates that the local LSR is the active end. It actively sends Targeted Hellos to its peer.
·     (Passive) indicates that the local LSR is the passive end. It passively responds to the Targeted Hellos from its peer.
·     (Active, Passive) indicates that the local LSR acts as both the active end and the passive end.
Interface running LDP basic discovery. The device discovers the LDP peer by sending Link Hellos out of the interface.
(v6) indicates that the LDP peer is discovered by sending IPv6 Link Hellos.
Hello Hold Time
Hello hold time negotiated, in seconds.
Hello Interval
Current Hello interval, in milliseconds.
Label acceptance policy used to filter label mappings received from the peer.
Label advertisement policy used to filter label mappings received from the peer.
Session Protection
Whether session protection is enabled:
·     On—Enabled.
·     Off—Disabled.
Session protection state:
·     Incomplete—Session protection is not ready.
·     Ready—Session protection is ready.
·     Protecting—The session is under protection.
Duration
Local session protection duration, in seconds.
Infinite indicates that session protection takes effect permanently.
Holdup time remaining
Remaining time of the session hold timer, in seconds.
This field is displayed only when the session protection state is Protecting. A value of Infinite indicates that session protection takes effect permanently.
IP addresses received from the peer.
Use display mpls ldp summary to display LDP summary information.
display mpls ldp summary [ all | vpn-instance vpn-instance-name ] [ slot slot-number ]
all: Displays LDP summary information for the public network and all VPN instances.
vpn-instance vpn-instance-name: Displays LDP summary information for the specified VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays LDP summary information on the active MPU.
If you do not specify any parameters, this command displays LDP summary information for the public network.
# Display LDP summary information for the public network.
<Sysname> display mpls ldp summary
VPN Instance Name    : Public
  Instance ID        : 0
  Instance State     : Active
  Interfaces         : 1 (1 active)
  Targeted Peers     : 0
  Targeted Peers(v6) : 0
  Adjacencies        : 1
  Adjacencies(v6)    : 1
  Peers              : 1
    Operational : 1 (0 GR)
    OpenSent    : 0
    OpenRecv    : 0
    Initialized : 0
    Non-Existent: 0
Table 13 Command output
Instance ID
VPN instance identifier. A value of 0 represents the public network.
Instance State
LDP status in the VPN instance: Active or Inactive.
Interfaces
Number of interfaces enabled with LDP.
active: Number of interfaces running LDP.
Targeted Peers
Number of LDP IPv4 peers discovered by the LDP extended discovery mechanism, including the manually specified peers and the automatically established peers.
Targeted Peers(v6)
Number of LDP IPv6 peers discovered by the LDP extended discovery mechanism, including the manually specified peers and the automatically established peers.
Adjacencies
Number of IPv4 Hello adjacencies.
Adjacencies(v6)
Number of IPv6 Hello adjacencies.
Peers
Total number of peers.
Operational
Number of peers in Operational state.
GR: Number of GR-capable peers.
OpenSent
Number of peers in OpenSent state.
OpenRecv
Number of peers in OpenRecv state.
Initialized
Number of peers in Initialized state.
Non-Existent
Number of peers in Non-Existent state.
Use display mpls ldp troubleshooting to display information about LDP session interruptions.
This command displays the reasons for LDP session interruptions, helping you locate and resolve LDP session interruption issues.
# Display information about LDP session interruptions.
<Sysname> display mpls ldp troubleshooting
Total records: 1
Date and time: 2019-05-23 14:33:26
Event description:
Session (22.2.2.2:0, public instance) is down (received a fatal notification message: Keepalive timer expired). (LocalTransportAddr=11.1.1.1, PeerTransportAddr=22.2.2.2, SessionRole=Passive, SessionUpTime=0000:00:35, KeepaliveHoldTime=45s, KeepaliveSentCount=143, KeepaliveRcvdCount=148, GracefulRestart=Off, SocketID=35, WaitSendMsgCount=0, CPUUsage=19%, MemoryState=Normal, PingResult: packets sent 9, received 0, lost 9)
Table 14 Command output
Total n records
Total number of LDP session interruption events.
Date and time
Date and time when an LDP session interruption occurred, in the format of YYYY-MM-DD HH:MM:SS.
Event Description
Description of the session interruption: Session (peer-lsr-id, vpn-instance-name) is down (reason). (session-information).
·     peer-lsr-id—LSR ID of the LDP peer. If the peer LSR ID was not obtained, this field displays 0.0.0.0:0.
·     vpn-instance-name—Name of the VPN instance. If the session belongs to the public network, this field displays public instance.
·     reason—Reason for the session interruption (see Table 15).
·     session-information—Information about the LDP session (see Table 16).
Table 15 Reasons for the session interruption
Reason
interface not operational
The interface was not available.
MPLS disabled on interface
MPLS was disabled on the interface.
LDP disabled on interface
LDP was disabled on the interface.
LDP auto-configure disabled on interface
LDP autoconfiguration was disabled on the interface.
VPN instance changed on interface
VPN instance of the interface was changed.
LDP instance deleted
LDP instance was deleted.
targeted peer deleted
The targeted peer was deleted manually.
L2VPN disabled targeted peer
L2VPN disabled the targeted peer.
TE tunnel disabled targeted peer
TE tunnel disabled the targeted peer.
session protection disabled targeted peer
Session protection disabled the targeted peer.
OSPF Remote LFA disabled targeted peer
OSPF Remote LFA disabled the targeted peer.
IS-IS Remote LFA disabled targeted peer
IS-IS Remote LFA disabled the targeted peer.
process deactivated
The LDP process was downgraded.
failed to receive the initialization message
LDP failed to receive the initialization message.
graceful restart reconnect timer expired
The GR reconnect timer expired.
failed to recover adjacency by NSR
NSR failed to recover the adjacency.
failed to upgrade session by NSR
NSR failed to upgrade the session.
closed the GR session
The GR session was closed.
keepalive hold timer expired
The keepalive hold timer expired.
hello hold timer expired
The hello hold timer expired.
session reset
The session was reset.
TCP connection down
The TCP connection went down.
LDP received a fatal message.
internal error
An internal error occurred.
memory in critical state
The memory reached the critical state.
transport address changed on interface
The transport address on the interface was changed.
MD5 password changed
The MD5 password for the session was changed.
Table 16 LDP session information
LocalTransportAddr
PeerTransportAddr
Peer transport address.
SessionRole
Role of the local LSR in the session, which can be Active or Passive.
SessionUpTime
Duration of the session in Operational state, in the format of DD:HH:MM.
KeepaliveHoldTime
Keepalive holdtime negotiated, in seconds.
KeepaliveSentCount
Number of keepalive messages sent locally.
KeepaliveRcvdCount
Number of keepalive messages received locally.
GracefulRestart
·     On—Enabled.
·     Off—Disabled.
SocketID
Socket ID of the session.
WaitSendMsgCount
Number of TCP messages to be sent.
CPUusage
CPU usage rate when the session went down.
MemoryState
Memory state when the session went down. Memory states include normal, minor, severe, and critical.
PingResult
Result for the peer transport address ping operation performed after Maintain Probe (MTP) was enabled. The information include:
·     packets sent—Number of sent ICMP echo requests.
·     received—Number of received ICMP responses.
·     lost—Number of ICMP echo requests not responded to.
For more information about MTP, see the basic IP routing configuration in Layer 3—IP Routing Configuration Guide.
dscp
Use dscp to set a DSCP value for outgoing LDP packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for outgoing LDP packets is 48.
LDP view
dscp-value: Specifies the DSCP value for outgoing LDP packets, in the range of 0 to 63.
To control the transmission preference of outgoing LDP packets, set a DSCP value for outgoing LDP packets.
# Set the DSCP value for outgoing LDP packets to 56.
[Sysname] mpls ldp
[Sysname-ldp] dscp 56
error-packet size
Use error-packet size to configure the maximum number of erroneous packets that LDP can record.
Use undo error-packet dot1p to restore the default.
error-packet size { tcp tcp-size | udp udp-size }
undo error-packet size { tcp | udp }
LDP can record a maximum of 100 erroneous TCP packets and 100 erroneous UDP packets.
LDP view
tcp tcp-size: Specifies the maximum number of erroneous TCP packets that LDP can record. The value range for the tcp-size argument is 0 to 4096.
udp udp-size: Specifies the maximum number of erroneous UDP packets that LDP can record. The value range for the udp-size argument is 0 to 4096.
After the number of erroneous packets recorded by LDP reaches the maximum, if a new erroneous packet is received, LDP will delete the earliest erroneous packet and record the new one.
# Set the maximum number of erroneous TCP packets that LDP can record to 128.
[Sysname] mpls ldp
[Sysname-ldp] error-packet size tcp 128
graceful-restart
Use graceful-restart to enable Graceful Restart (GR) for LDP.
Use undo graceful-restart to disable LDP GR.
graceful-restart
LDP GR is disabled.
LDP view
LDP GR enables an LSR to retain MPLS forwarding entries during an LDP restart, ensuring continuous MPLS forwarding.
The configuration of this command takes effect only on new LDP sessions. To apply the configuration to existing LDP sessions, you must reset the LDP sessions by using the reset mpls ldp command.
# Enable GR for LDP.
[Sysname] mpls ldp
[Sysname-ldp] graceful-restart
reset mpls ldp
Use graceful-restart timer to set the MPLS Forwarding State Holding timer and the Reconnect timer for GR.
Use undo graceful-restart timer to restore the default.
graceful-restart timer { forwarding-hold hold-time | reconnect reconnect-time }
undo graceful-restart timer { forwarding-hold | reconnect }
The MPLS Forwarding State Holding timer is 180 seconds and the Reconnect timer is 120 seconds.
LDP view
forwarding-hold hold-time: Specifies the MPLS Forwarding State Holding time in the range of 60 to 6000 seconds. This time specifies how long the local LSR retains its MPLS forwarding entries after the control plane of the local LSR restarts.
reconnect reconnect-time: Specifies the Reconnect time in the range of 60 to 300 seconds. This time specifies the period the local LSR expects the peer to wait for LDP session re-establishment after the peer detects an LDP session failure. The local LSR sends the Reconnect time to the peer.
The MPLS Forwarding State Holding time must be greater than the Reconnect time.
# Set the MPLS Forwarding State Holding time to 200 seconds, and the Reconnect time to 100 seconds.
[Sysname] mpls ldp
[Sysname-ldp] graceful-restart timer forwarding-hold 200
[Sysname-ldp] graceful-restart timer reconnect 100
graceful-restart
label-distribution
Use label-distribution to configure the label distribution control mode.
Use undo label-distribution to restore the default.
label-distribution { independent | ordered }
The label distribution control mode is ordered.
LDP view
independent: Specifies Independent label distribution mode. In this mode, an LSR can distribute label mappings to the upstream LSR at any time.
ordered: Specifies Ordered label distribution mode. In this mode, an LSR distributes a label mapping for an FEC to the upstream LSR only when one of the following events occurs:
·     The LSR receives a label mapping for that FEC from the downstream LSR.
·     The LSR is the egress node of that FEC.
In Ordered mode, an LSR can determine that the downstream LSR has established an LSP when the LSR receives an FEC-label mapping from the downstream LSR.
The Independent mode enables faster LSP convergence because each LSR independently advertises labels without waiting for labels from downstream LSRs.
# Set the Independent LDP label distribution mode for the public network.
[Sysname] mpls ldp
[Sysname-ldp] label-distribution independent
log enable
Use log enable to enable LDP logging.
Use undo log enable to disable LDP logging.
log enable
undo log enable
LDP logging is enabled.
LDP view
After LDP logging is enabled, the device generates log messages for LDP running state changes, and records the log messages in a local file.
# Enable LDP logging.
[Sysname] mpls ldp
[Sysname-ldp] log enable
log record-size
Use log record-size to set the maximum number of LDP log messages that can be recorded.
Use undo log record-size to restore the default.
log record-size record-size
The device can record a maximum of 4096 LDP log messages.
LDP view
record-size: Sets the maximum number of LDP log messages that can be recorded, in the range of 0 to 200000. If you set the maximum number of 0, the device does not record LDP log messages.
Use this command to control the number of LDP log messages saved locally. A proper number of LDP log messages can facilitate maintenance and reduce system resources consumption.
# Set the maximum number of LDP log messages that can be recorded to 1000.
[Sysname] mpls ldp
[Sysname-ldp] log record-size 1000
loop-detect
Use loop-detect to enable loop detection.
Use undo loop-detect to disable loop detection.
loop-detect
undo loop-detect
Loop detection is disabled.
LDP view
The device does not support LDP loop detection. This command only enables the LDP loop detection negotiation capability of the device when the device establish an LDP session with a neighbor.
Execute this command on the device if its neighbor device supports LDP loop detection and requires both devices of the LDP session to advertise the same loop detection settings.
# Enable LDP loop detection for the public network.
[Sysname] mpls ldp
[Sysname-ldp] loop-detect
lsr-id
Use lsr-id to configure an LDP LSR ID.
Use undo lsr-id to restore the default.
lsr-id lsr-id
undo lsr-id
No LDP LSR ID is configured. LDP uses the MPLS LSR ID configured by the mpls lsr-id command for both the public network and VPN instances.
LDP view
lsr-id: Specifies an LDP LSR ID, in dotted decimal notation.
If you configure an LDP LSR ID by using the lsr-id command in LDP view or LDP-VPN instance view, LDP uses the LDP LSR ID. If no LDP LSR ID is configured, LDP uses the LSR ID configured by the mpls lsr-id command.
LDP uses the same LSR ID for all sessions in the same VPN instance. Changing the LDP LSR ID for the VPN instance resets all LDP sessions in the VPN instance.
As a best practice, use the default LDP LSR ID configured by the mpls lsr-id command for the public network. If the lsr-id command is required to configure an LDP LSR ID for the public network, specify the IP address of a local loopback interface as the LDP LSR ID. Changing the LDP LSR ID for the public network resets all LDP sessions in the public network.
# Configure the LDP LSR ID as 2.2.2.2 for the public network.
[Sysname] mpls ldp
[Sysname-ldp] lsr-id 2.2.2.2
# Change the LDP LSR ID to 3.3.3.3 for the public network.
[Sysname-ldp] lsr-id 3.3.3.3
All associated LDP sessions will be reset. Continue? [Y/N]:Y
mpls lsr-id
maxhops
Use maxhops to set the maximum hop count for loop detection.
Use undo maxhops to restore the default.
maxhops hop-number
undo maxhops
The maximum hop count for loop detection is 32.
LDP view
hop-number: Specifies the maximum hop count for loop detection, in the range of 1 to 32.
LDP adds a hop count in a label request or label mapping message. The hop count increments by 1 on each LSR. When the hop count reaches the maximum hop count configured by this command, LDP considers that a loop occurs and terminates LSP establishment.
Set a proper maximum hop count according to the number of LSRs in your network. For example, set a smaller maximum hop count in small networks to allow for fast loop detection. Set a higher maximum hop count in large networks to ensure that LSPs can be successfully established.
# Set the maximum hop count to 25 for loop detection on the public network.
[Sysname] mpls ldp
[Sysname-ldp] maxhops 25
loop-detect
pv-limit
Use md5-authentication all to enable MD5 authentication for all LDP sessions.
Use undo md5-authentication all to disable MD5 authentication for all LDP sessions.
md5-authentication all { cipher | plain } string
LDP MD5 authentication is disabled for all LDP sessions.
LDP view
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters.
To improve security for LDP sessions, you can configure MD5 authentication for the underlying TCP connections to check the integrity of LDP messages.
For two peers to establish an LDP session successfully, make sure the LDP MD5 authentication configuration on the peers are consistent.
MD5 authentication key settings take effect only on new LDP sessions. To apply the new settings to existing LDP sessions, you must reset the LDP sessions by using the reset mpls ldp command.
The effective LDP authentication method is selected in this order: the method configured for the LDP session with the specified peer, the method for the LDP sessions filtered by an IPv4 prefix list, and the method for all LDP sessions.
# Enable MD5 authentication for all LDP sessions, and set a key of pass in plaintext form.
[Sysname] mpls ldp
[Sysname-ldp] md5-authentication all plain pass
The configuration doesn't take effect on previously established sessions.
reset mpls ldp
Use md5-authentication peer-lsr-id to enable MD5 authentication for the LDP session with the specified peer.
Use undo md5-authentication peer-lsr-id to disable MD5 authentication for the LDP session with the specified peer.
md5-authentication peer-lsr-id { cipher | plain } string
MD5 authentication is disabled for the LDP session with a specific peer..
LDP view
peer-lsr-id: Specifies the LSR ID of a peer.
# Enable MD5 authentication for the LDP session with peer 3.3.3.3, and set a key of pass in plaintext form.
[Sysname] mpls ldp
[Sysname-ldp] md5-authentication 3.3.3.3 plain pass
keychain-authentication peer
reset mpls ldp
Use md5-authentication prefix-list to enable MD5 authentication for the LDP sessions permitted by an IPv4 prefix list.
Use undo md5-authentication prefix-list to disable MD5 authentication for the LDP sessions permitted by an IPv4 prefix list.
md5-authentication prefix-list prefix-list-name { cipher | plain } string
undo md5-authentication prefix-list prefix-list-name
MD5 authentication is disabled for the LDP sessions permitted by an IPv4 prefix list.
LDP view
prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters.
# Enable MD5 authentication for the LDP sessions permitted by IPv4 prefix list aaa, and set a key of pass in plaintext form.
[Sysname] mpls ldp
[Sysname-ldp] md5-authentication prefix-list aaa plain pass
reset mpls ldp
mpls ldp
Use mpls ldp to enable LDP globally for an LSR and enter LDP view.
Use undo mpls ldp to disable LDP globally for an LSR and delete all LDP-VPN instances.
mpls ldp
undo mpls ldp
LDP is globally disabled.
You must enable LDP globally for an LSR to run LDP.
The NSR and GR commands, the session protection command, and the targeted-peer command are available only in LDP view. All other commands available in LDP view are also available in LDP-VPN instance view.
Commands executed in LDP view take effect only on the public network. Commands executed in LDP-VPN instance view take effect only on the specified VPN instance. The NSR and GR commands are global commands and take effect on all VPN instances and the public network.
# Enable LDP globally and enter LDP view.
[Sysname] mpls ldp
[Sysname-ldp]
mpls ldp enable
vpn-instance
mpls ldp local-lsr-id
Use mpls ldp local-lsr-id to specify an interface so as to use its primary IPv4 address as the LSR ID of the LDP session.
Use undo mpls ldp local-lsr-id to restore the default.
In interface view:
mpls ldp local-lsr-id { interface interface-type interface-number | self-interface }
In LDP peer view:
mpls ldp local-lsr-id interface interface-type interface-number
The LSR ID of the LDP instance is used as the LSR ID of the LDP session.
Interface view
LDP peer view
interface interface-type interface-number: Specifies an interface by its type and number. The primary IPv4 address of the specified interface will be used as the LSR ID of the LDP session.
self-interface: Uses the primary IPv4 address of the current interface as the LSR ID of the LDP session.
In scenarios where LDP tunnels are used to carry L2VPN and L3VPN services, all LDP sessions use the LSR ID of the LDP VPN instance by default. To implement service isolation in a VPN, you can use this command to specify different LSR IDs for different LDP sessions.
When the device establishes Link Hello adjacencies with an LSR directly connected by multiple links, you must specify the same LSR ID on all the interfaces of the links. Otherwise, the device uses the LSR ID of the link that establishes the first Link Hello adjacency to establish the LDP session. The other links with different LSR IDs cannot establish LDP LSPs by using this LDP session.
When the device establishes with both Link Hello and Targeted Hello adjacencies with an LSR, you must specify the same LSR ID for the LDP sessions of the Link Hello and Targeted Hello adjacencies. Otherwise, only the LDP session that first establishes an adjacency can be successfully established.
After you modify the LSR ID of an LDP session, all associated LDP sessions will be deleted and then re-established.
# Configure Ten-GigabitEthernet 2/0/0 to use its primary IPv4 address as the LSR ID of the LDP session.
[Sysname] interface ten-gigabitethernet 2/0/0
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp local-lsr-id self-interface
# Use the primary IPv4 address of interface Loopback 2 as the LSR ID to establish an LDP session with LDP peer 3.3.3.3.
[Sysname] mpls ldp
[Sysname-ldp] targeted-peer 3.3.3.3
[Sysname-ldp-peer-3.3.3.3] mpls ldp local-lsr-id interface loopback 2
# Use the primary IPv4 address of interface Loopback 1 as the LSR ID to establish an LDP session with LDP peer 2001::1.
[Sysname] mpls ldp
[Sysname-ldp] targeted-peer 2001::1
[Sysname-ldp-peer-2001::1] mpls ldp local-lsr-id interface loopback 1
lsr-id
targeted-peer
mpls ldp timer
Use mpls ldp timer to set the Hello hold time, Hello interval, Keepalive hold time, and Keepalive interval.
Use undo mpls ldp timer to restore the default.
mpls ldp timer { hello-hold timeout | hello-interval interval | keepalive-hold timeout | keepalive-interval interval }
undo mpls ldp timer { hello-hold | hello-interval | keepalive-hold | keepalive-interval }
·     The Link Hello hold time is 15 seconds.
·     The Link Hello interval is 5 seconds.
·     The Targeted Hello hold time is 45 seconds.
·     The Targeted Hello interval is 15 seconds.
·     The Keepalive hold time is 45 seconds.
·     The Keepalive interval is 15 seconds.
Interface view
LDP peer view
hello-hold timeout: Specifies the Hello hold time in the range of 1 to 65535 seconds. LDP keeps the hello adjacency during the Hello hold time. The negotiated Hello hold time takes the smaller value of the local Hello hold time and the peer Hello hold time. If LDP receives no Hello message from the peer before the Hello hold timer expires, LDP deletes the Hello adjacency with the peer. If you set the Hello hold time to 65535, LDP permanently keeps the Hello adjacency.
hello-interval interval: Specifies the Hello interval in the range of 1 to 65535 seconds. LDP sends Hello messages at this interval.
keepalive-hold timeout: Specifies the Keepalive hold time in the range of 15 to 65535 seconds. LDP keeps the LDP session to the peer during the Keepalive hold time. The negotiated Keepalive hold time takes the smaller value of the local Keepalive hold time and the peer Keepalive hold time. If LDP receives no LDP message from the peer before the Keepalive hold timer expires, LDP deletes the LDP session to the peer.
keepalive-interval interval: Specifies the Keepalive interval in the range of 1 to 65535 seconds. LDP sends Keepalive messages to the peer at this interval.
In interface view, this command sets a Link Hello hold time and a Link Hello interval.
In LDP peer view, this command sets a Targeted Hello hold time and a Targeted Hello interval.
LDP automatically sends Targeted Hellos to the specified peer after LDP session protection, LDP over MPLS TE, MPLS L2VPN LDP PW, or VPLS LDP PW is configured. To modify the Targeted Hello/Keepalive hold time and interval, you must use the targeted-peer command to create the LDP peer, and then perform the modification in the LDP peer view.
If the local Hello hold time and local Keepalive hold time are different from those of a peer LSR, the negotiation is as follows:
·     During LDP peer discovery, an LSR compares the local Hello hold time with the peer LSR's Hello hold time carried in Hellos. Then, the LSR uses the smaller one as the negotiated Hello hold time.
¡     If the negotiated Hello hold time is larger than three times the local Hello interval, the LSR sends Hello messages at the local Hello interval.
¡     If it is not larger than three times the local Hello interval, the LSR sends Hello messages at an interval 1/3 of the negotiated Hello hold time.
·     During LDP session negotiation, an LSR compares the local Keepalive hold time with the Keepalive hold time of the peer LSR by exchanging Initialization messages. Then, the LSR uses the smaller one as the negotiated Keepalive hold time.
¡     If the negotiated Keepalive hold time is larger than three times the local Keepalive interval, the LSR sends Keepalive messages at the local Keepalive interval.
¡     If it is not larger than three times the local Keepalive interval, the LSR sends Keepalive messages at an interval 1/3 of the negotiated Keepalive hold time.
If the Hello hold time and the Keepalive hold time values are too large, LDP cannot quickly detect link failures. If the values are too small, LDP might mistakenly consider a normal link failed. As a best practice, use the default values.
Make sure all links between two LSRs have the same Keepalive hold time as the one configured in LDP peer view in either of the following situations:
·     Multiple Link Hello adjacencies exist when the two LSRs are directly connected through multiple links.
·     Both a Link Hello adjacency and a Targeted Hello adjacency exist between the two LSRs.
Keepalive hold time and keepalive interval settings take effect only on new LDP sessions. To apply the settings to existing LDP sessions, you must reset the LDP sessions by using the reset mpls ldp command.
# Set the Targeted Hello hold time to 1000 seconds, Targeted Hello interval to 50 seconds, Keepalive hold time to 1000 seconds, and Keepalive interval to 50 seconds for peer 3.3.3.3.
[Sysname] mpls ldp
[Sysname-ldp-peer-3.3.3.3] mpls ldp timer hello-hold 1000
[Sysname-ldp-peer-3.3.3.3] mpls ldp timer hello-interval 50
[Sysname-ldp-peer-3.3.3.3] mpls ldp timer keepalive-hold 1000
[Sysname-ldp-peer-3.3.3.3] mpls ldp timer keepalive-interval 50
# On Ten-GigabitEthernet 2/0/0, set the Link Hello hold time to 100 seconds, Link Hello interval to 20 seconds, Keepalive hold time to 50 seconds, and Keepalive interval to 10 seconds.
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp timer hello-hold 100
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp timer hello-interval 20
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp timer keepalive-hold 50
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp timer keepalive-interval 10
non-stop-routing
Use non-stop-routing to enable LDP NSR.
Use undo non-stop-routing to disable LDP NSR.
non-stop-routing
LDP NSR is disabled.
LDP view
# Enable LDP NSR.
[Sysname] mpls ldp
[Sysname-ldp] non-stop-routing
propagate mapping
Use propagate mapping to configure a transit LSP generation policy.
Use undo propagate mapping to restore the default.
propagate mapping { all | none | prefix-list prefix-list-name }
LDP only uses redistributed IPv4 host routes with a 32-bit mask to generate transit LSPs.
LDP view
all: All redistributed routes can generate transit LSPs.
none: None of the redistributed routes can generate transit LSPs.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters. LDP uses only the redistributed routes permitted by the IPv4 prefix list to generate transit LSPs.
LDP assigns labels to the routes that have been redistributed into LDP to generate LSPs. A transit LSP generation policy specifies the routes that LDP uses to generate transit LSPs.
As a best practice, use the default transit LSP generation policy. A modified transit LSP generation policy might result in more LSPs than the default policy. To change the policy, make sure the system resources and bandwidth resources are sufficient.
When LDP generates transit LSPs, it generates ingress LSPs simultaneously.
If you execute both the lsp-trigger and propagate mapping commands, establishment of transit LSPs is controlled by the propagate mapping command.
# Configure the device to establish transit LSPs only based on the LDP-redistributed routes 10.10.1.0/24 and 10.20.1.0/24.
[Sysname] ip prefix-list transit-fec-list index 1 permit 10.10.1.0 24
[Sysname] ip prefix-list transit-fec-list index 2 permit 10.20.1.0 24
[Sysname] mpls ldp
[Sysname-ldp] propagate mapping prefix-list transit-fec-list
ip prefix-list (Layer 3—IP Routing Command Reference)
lsp-trigger
pv-limit
Use pv-limit to set the path vector limit.
Use undo pv-limit to restore the default.
pv-limit pv-number
undo pv-limit
The path vector limit is 32.
LDP view
pv-number: Specifies the path vector limit in the range of 1 to 32.
LDP adds LSR ID information in a label request or label mapping message. Each LSR checks whether its LSR ID is contained in the message.
·     If it is not, the LSR adds its own LSR ID into the message.
·     If it is, the LSR considers that a loop occurs and terminates LSP establishment.
In addition, when the number of LSR IDs in the message reaches the path vector limit, LDP also considers that a loop occurs and terminates LSP establishment.
# Set the path vector limit to 3 for LDP loop detection on the public network.
[Sysname] mpls ldp
[Sysname-ldp] pv-limit 3
loop-detect
maxhops
reset mpls ldp
Use reset mpls ldp to reset LDP sessions.
reset mpls ldp [ vpn-instance vpn-instance-name ] [ peer peer-id ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. This command resets the LDP sessions in the specified VPN instance. If you do not specify a VPN instance, this command resets the LDP sessions in the public network.
peer peer-id: Specifies a peer by its LSR ID. If you do not specify a peer, this command resets all LDP sessions in the specified VPN instance or the public network.
Resetting an LDP session deletes and re-establishes the session and all LSPs based on the session.
Changes to LDP session parameters take effect only on new LDP sessions. To apply the changes to an existing LDP session on a network, you must reset all LDP sessions on that network by executing this command without the peer keyword. If you specify the peer keyword, this command resets the LDP session to the specified peer without applying the parameter changes to the session.
# Reset all LDP sessions in the public network.
<Sysname> reset mpls ldp
# Reset all LDP sessions in VPN instance vpn1.
<Sysname> reset mpls ldp vpn-instance vpn1
reset mpls ldp error-packet
Use reset mpls ldp error-packet to clear the erroneous packet information recorded by LDP.
reset mpls ldp error-packet [ tcp | udp ]
tcp: Clears erroneous TCP packet information recorded by LDP.
udp: Clears erroneous UDP packet information recorded by LDP.
If no parameters are specified, this command clears all erroneous TCP and UDP packet information recorded by LDP.
# Clear erroneous TCP packet information recorded by LDP.
<Sysname> reset mpls ldp error-packet tcp
snmp-agent trap enable ldp
Use snmp-agent trap enable ldp to enable SNMP notifications for LDP.
Use undo snmp-agent trap enable ldp to disable SNMP notifications for LDP.
SNMP notifications for LDP are enabled.
This command enables generating SNMP notifications for LDP upon LDP session changes, as defined in RFC 3815. For LDP event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for LDP.
[Sysname] snmp-agent trap enable ldp
snmp-agent trap enable ldp-private
Use snmp-agent trap enable ldp-private to enable private SNMP notifications for LDP.
Use undo snmp-agent trap enable ldp-private to disable private SNMP notifications for LDP.
Private SNMP notifications for LDP are disabled.
This command can enable generating SNMP notifications for LDP configuration consistency checks on multiple links between LDP peers. These notifications are not defined in an RFC and are private LDP notifications supported by the device. For SNMP to output the private LDP notifications correctly, you must also configure parameters for sending SNMP notifications. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable private SNMP notifications for LDP.
[Sysname] snmp-agent trap enable ldp-private
vpn-instance
Use vpn-instance to enable LDP for a VPN instance and enter LDP-VPN instance view, or enter the view of an existing LDP-VPN instance.
Use undo vpn-instance to delete the LDP-VPN instance.
undo vpn-instance vpn-instance-name
LDP is disabled for a VPN instance.
LDP view
vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN instance must have been created by the ip vpn-instance command in system view.
Enabling LDP for VPN instances is used for the Carrier's Carrier network that uses LDP between the Level 1 carrier and Level 2 carrier PEs. In such a network, you must enable LDP for each VPN instance on each Level 1 carrier PE.
The GR, NSR, and LDP-IGP synchronization commands, the dscp command, the session protection command, and the targeted-peer command are available only in LDP view. All other commands available in LDP view are available in LDP-VPN instance view.
Commands executed in LDP view take effect only on the public network. Commands executed in LDP-VPN instance view take effect only on the specified VPN instance. The dscp command, NSR commands, and GR commands are global commands and take effect on all VPN instances and the public network.
# Enable LDP for VPN instance vpn1 and enter LDP-VPN instance view.
[Sysname] mpls ldp
[Sysname-ldp] vpn-instance vpn1
[Sysname-ldp-vpn-instance-vpn1]
ip vpn-instance
mpls ldp
IPv4 LDP commands
accept-label
Use accept-label to configure a label acceptance policy.
Use undo accept-label to delete a label acceptance policy.
accept-label peer { peer-lsr-id | all | peer-prefix-list peer-prefix-list-name } { host | none | prefix-list prefix-list-name }
undo accept-label peer { peer-lsr-id | all | peer-prefix-list peer-prefix-list-name }
No label acceptance policy is configured. LDP accepts all IPv4 FEC-label mappings from all peers.
LDP view
all: Specifies all LDP peers.
peer-prefix-list peer-prefix-list-name: Specifies an IPv4 prefix list to filter LDP peers. The peer-prefix-list-name argument represents the IPv4 prefix list name, a case-sensitive string of 1 to 63 characters.
host: Accepts only the label mappings for host routes with a 32-bit mask.
none: Does not accept label mappings for IPv4 prefixes.
prefix-list prefix-list-name: Specifies an IPv4 prefix list to filter received label mappings. The prefix-list-name argument represents the IPv4 prefix list name, a case-sensitive string of 1 to 63 characters.
Application scenarios
Use this feature to control the number of label mappings received from peers to save device resources. This feature enables LDP to filter the label mappings from specific peers and accept only the label mappings permitted by the filters.
Operating mechanism
After a label acceptance policy is configured, for the label mappings from the specified peers, the LSR accepts only the label mappings whose FEC IPv4 prefixes are host routes or permitted by an IP prefix list. For label mappings not permitted the filter, the LSR does not accept or save them.
If you configure a none label acceptance policy, the LSR does not accept any IPv4 FEC-label mappings from the peers specified in the policy.
Recommended configuration
Using a label advertisement policy on an LSR or using a label acceptance policy on its upstream LSR can achieve the same purpose. As a best practice, use the label advertisement policy to reduce network load.
To accept the previously denied label mappings from a peer, use the undo accept-label command or change the IPv4 prefix list for the peer. Then, execute the reset mpls ldp command to reset the LDP session to that peer to apply the new settings.
The all keyword is exclusive with the peer-lsr-id and peer-prefix-list arguments:
·     After the accept-label peer all command is executed, you cannot execute the accept-label peer { peer-lsr-id | peer-prefix-list peer-prefix-list-name } command.
·     After the accept-label peer { peer-lsr-id | peer-prefix-list peer-prefix-list-name } command is executed, if you execute the accept-label peer all command, the previous command configuration will be deleted.
You can use the accept-label peer peer-lsr-id command, the accept-label peer peer-prefix-list peer-prefix-list-name command, or both commands multiple times to specify multiple peers. If the same peer has been specified by both commands, the command executed first applies.
# Configure a label acceptance policy to accept only the FEC-label mappings containing IPv4 prefixes 10.1.1.0/24 and 10.2.1.0/24 from LDP peer 1.1.1.9.
[Sysname] ip prefix-list prefix-from-RTA index 1 permit 10.1.1.0 24
[Sysname] ip prefix-list prefix-from-RTA index 2 permit 10.2.1.0 24
[Sysname] mpls ldp
[Sysname-ldp] accept-label peer 1.1.1.9 prefix-list prefix-from-RTA
Use advertise-label peer to configure a label advertisement policy for the specified LDP peers.
Use undo advertise-label peer to delete the label advertisement policy configured for the specified LDP peers.
advertise-label peer { peer-lsr-id | all | peer-prefix-list peer-prefix-list-name } { host | none | prefix-list prefix-list-name }
undo advertise-label peer { peer-lsr-id | all | peer-prefix-list peer-prefix-list-name }
No label advertisement policy is configured. The device advertises IPv4 FEC-label mappings permitted by the LSP generation policy to all peers.
LDP view
host: Advertises only the label mappings for host routes with a 32-bit mask.
none: Does not advertise label mappings for IPv4 prefixes.
prefix-list prefix-list-name: Specifies an IPv4 prefix list to filter the label mappings to be advertised. The prefix-list-name argument represents the IPv4 prefix list name, a case-sensitive string of 1 to 63 characters.
Operating mechanism
Use a label advertisement policy to filter label mappings advertised to peers.
After a label advertisement policy is configured, the LSR advertises only the label mappings whose FEC IPv4 prefixes are host routes or permitted by an IP prefix list to the specified LDP peers. For label mappings not permitted the filter, the LSR does not advertise them.
If you configure a none label advertisement policy, the LSR does not advertise any IPv4 FEC-label mappings to the peers specified in the policy.
After label advertisement policies are configured with prefix-list-name specified, the LSR uses the following rules to determine whether to advertise a label mapping to the specified peers:
·     If the IPv4 prefix in a label mapping does not match a permit rule in an IPv4 prefix list or matches a deny rule, the LSR does not advertise this label mapping to an LDP peer.
·     If the IPv4 prefix in a label mapping is permitted by an IPv4 prefix list, the LSR advertises this label mapping to the LDP peers specified in the corresponding label advertisement policy.
·     If the IPv4 prefix in a label mapping is permitted by the IPv4 prefix lists of multiple label advertisement policies, the policy configured first applies.
·     After the advertise-label peer all command is executed, you cannot execute the advertise-label peer { peer-lsr-id | peer-prefix-list peer-prefix-list-name } command.
·     After the advertise-label peer { peer-lsr-id | peer-prefix-list peer-prefix-list-name } command is executed, if you execute the advertise-label peer all command, the previous command configuration will be deleted.
You can use the advertise-label peer peer-lsr-id command, the advertise-label peer peer-prefix-list peer-prefix-list-name command, or both commands multiple times to specify multiple peers. If the same peer has been specified by both commands, the command executed first applies.
# Configure two label advertisement policies. One policy advertises only the label mapping for subnet 10.1.1.0/24 to peer 3.3.3.9. The other policy advertises only the label mapping for subnet 10.2.1.0/24 to peer 4.4.4.9.
[Sysname] ip prefix-list prefix-to-C permit 10.1.1.0 24
[Sysname] ip prefix-list prefix-to-D permit 10.2.1.0 24
[Sysname] ip prefix-list peer-C permit 3.3.3.9 32
[Sysname] ip prefix-list peer-D permit 4.4.4.9 32
[Sysname] mpls ldp
[Sysname-ldp] advertise-label peer 3.3.3.9 prefix-list prefix-to-C
[Sysname-ldp] advertise-label peer 4.4.4.9 prefix-list prefix-to-D
advertise-label prefix-list
Use advertise-label prefix-list to configure a label advertisement policy.
Use undo advertise-label prefix-list to delete a label advertisement policy.
advertise-label prefix-list prefix-list-name [ peer peer-prefix-list-name ]
undo advertise-label prefix-list prefix-list-name
LDP view
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters. This prefix list filters advertised label mappings.
peer peer-prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters. This prefix list filters LDP peers. If you do not specify this option, the device advertises label mappings to all peers.
Configure multiple label advertisement policies by executing this command multiple times.
If a label mapping is permitted by an advertisement policy, LDP advertises the mapping by following these rules:
·     If the policy has no peer IPv4 prefix list (peer peer-prefix-list-name not specified), LDP advertises the label mapping to all peers.
·     If the policy has a peer IPv4 prefix list, LDP advertises the label mapping to the peers permitted by the peer IPv4 prefix list.
If a label mapping is permitted by multiple advertisement policies, LDP advertises the label mapping according to the first configured policy.
[Sysname] mpls ldp
[Sysname-ldp] advertise-label prefix-list prefix-to-C peer peer-C
[Sysname-ldp] advertise-label prefix-list prefix-to-D peer peer-D
display mpls ldp fec
lsp-trigger
display mpls ldp igp sync
Use display mpls ldp igp sync to display LDP-IGP synchronization information.
display mpls ldp igp sync [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays LDP-IGP synchronization information for all interfaces.
# Display LDP-IGP synchronization information for all interfaces.
<Sysname> display mpls ldp igp sync
Ten-GigabitEthernet2/0/1:
  IGP protocols: OSPF
  Sync status: Ready
  Peers:
    10.1.1.2:0
Ten-GigabitEthernet2/0/2:
  IGP protocols: OSPF, IS-IS
  Sync status: Delayed (24 sec remaining)
  Peers:
    20.1.1.2:0
Ten-GigabitEthernet2/0/3:
  LDP-IGP synchronization is disabled on the interface
Table 17 Command output
IGP protocols
IGP protocols that require LDP-IGP synchronization: OSPF and IS-IS.
Sync status
LDP-IGP synchronization state:
·     Ready—LDP is converged and is available for IGP.
·     Delayed—LDP is waiting to notify IGP of the convergence. remaining indicates the remaining time for the delay, in seconds.
·     Not ready—LDP is not converged and is not available for IGP.
·     LDP not enabled—LDP is not enabled on the interface.
Peers
LDP peer that completes LDP convergence on the interface.
igp sync delay
Use igp sync delay to set the delay for LDP to notify IGP of the LDP convergence completion.
Use undo igp sync delay to restore the default.
igp sync delay time
undo igp sync delay
LDP immediately notifies IGP of the LDP convergence completion.
LDP view
time: Specifies the notification delay in the range of 5 to 300 seconds.
LDP convergence on a link is completed when the following conditions exist:
·     The local device establishes an LDP session to a minimum of one peer, and the LDP session is already in Operational state.
·     The local device has distributed the label mappings to a minimum of one peer.
If LDP notifies IGP immediately after convergence, MPLS traffic forwarding might be interrupted in one of the following scenarios:
·     LDP peers use the Ordered label distribution control mode. When LDP notifies IGP of the LDP convergence, the device has not received a label mapping from downstream.
·     A large number of label mappings are distributed from downstream. When LDP notifies IGP of the LDP convergence completion, label advertisement is not completed.
In these scenarios, you must use the igp sync delay command to configure the notification delay. When LDP convergence on a link is completed, LDP waits a delay time before notifying IGP of the LDP convergence completion to reduce traffic interruption.
# Set a 30-second delay for LDP to notify IGP of the LDP convergence.
[Sysname] mpls ldp
[Sysname-ldp] igp sync delay 30
igp sync delay on-restart
mpls ldp igp sync disable
mpls ldp sync (IS-IS view)
mpls ldp sync (OSPF view/OSPF area view)
Use igp sync delay on-restart to set the maximum delay for LDP to notify IGP of the LDP-IGP synchronization status after an LDP restart or an active/standby switchover occurs.
Use undo igp sync delay on-restart to restore the default.
igp sync delay on-restart time
The maximum notification delay is 90 seconds.
LDP view
time: Specifies the maximum notification delay in the range of 60 to 600 seconds.
When an LDP restart or an active/standby switchover occurs, LDP takes time to converge. LDP notifies IGP of the LDP-IGP synchronization status as follows:
·     If a notification delay is not configured, LDP immediately notifies IGP of the current synchronization states during convergence, and then updates the states after LDP convergence. This could impact IGP processing.
·     If a notification delay is configured, LDP notifies IGP of the synchronization states in bulk when one of the following events occurs:
¡     LDP recovers to the state before the restart or switchover.
¡     The maximum delay timer expires.
# Set a 300-second maximum delay for LDP to notify IGP of the LDP-IGP synchronization status after an LDP restart or active/standby switchover occurs.
[Sysname] mpls ldp
[Sysname-ldp] igp sync delay on-restart 300
igp sync delay
import bgp
Use import bgp to enable LDP to redistribute BGP IPv4 unicast routes.
Use undo import bgp to disable LDP from redistributing BGP IPv4 unicast routes.
import bgp [ as-number ]
undo import bgp
LDP does not redistribute BGP IPv4 unicast routes.
LDP view
as-number: Redistributes BGP IPv4 unicast routes in the specified AS. An AS number is in the range of 1 to 4294967295. If you do not specify an AS number, this command enables LDP to redistribute all BGP IPv4 unicast routes.
IMPORTANT
IMPORTANT:
Use this command only if necessary. Execution of this command will increase the number of routes redistributed to LDP. A large number of redistributed routes will use a large amount of labels and memory.
By default, LDP automatically redistributes IPv4 IGP routes, including the BGP IPv4 unicast routes that have been redistributed into IGP. Then, LDP assigns labels to the IGP routes and labeled BGP routes if these routes are permitted by an LSP generation policy. LDP does not automatically redistribute BGP IPv4 unicast routes if the routes are not redistributed into the IGP.
For example, on a carrier's carrier network where IGP is not configured between a PE of a Level 1 carrier and a CE of a Level 2 carrier, LDP cannot redistribute BGP IPv4 unicast routes to assign labels to them. For this network to operate correctly, you can enable LDP to redistribute BGP IPv4 unicast routes. If the routes are permitted by an LSP generation policy, LDP assigns labels to them to establish LSPs. For more information about carrier's carrier, see MPLS L3VPN in MPLS Configuration Guide.
# Enable LDP to redistribute BGP IPv4 unicast routes in AS 100 on the public network.
[Sysname] mpls ldp
[Sysname-ldp] import bgp 100
lsp-trigger
lsp-trigger
Use lsp-trigger to configure an LSP generation policy for IPv4 FECs.
Use undo lsp-trigger to restore the default.
lsp-trigger { all | mapping | prefix-list prefix-list-name }
undo lsp-trigger
LDP only uses redistributed IPv4 host routes with a 32-bit mask to generate LSPs.
LDP view
all: Enables LDP to use all redistributed routes to generate LSPs. On loopback interfaces, only routes with a 32-bit mask can trigger LDP to establish LSPs.
mapping: Enables LDP to use redistributed routes that match the FECs of label mappings received from downstream LSRs to generate LSPs.
prefix-list prefix-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters. LDP uses only the redistributed routes permitted by the IPv4 prefix list to generate LSPs.
LDP assigns labels to the routes that have been redistributed into LDP to generate LSPs. An LSP generation policy specifies the routes that LDP uses to generate LSPs.
As a best practice, use the default LSP generation policy. A modified LSP generation policy can result in more LSPs than the default policy. To change the policy, make sure the system resources and bandwidth resources are sufficient.
The default LSP generation policy depends on the label distribution control mode.
·     In Ordered mode, LDP can use only the following routes to generate LSPs:
¡     Loopback interface address routes with a 32-bit mask.
¡     The routes with a 32-bit mask that match the FECs of label mappings received from downstream LSRs.
·     In Independent mode, LDP can use all routes with a 32-bit mask to generate LSPs.
If you specify the mapping keyword, the LSP generation policy also depends on the label distribution control mode.
·     In Ordered mode, LDP can use the following routes to generate LSPs:
¡     Routes that match the FECs of label mappings received from downstream LSRs.
·     In Independent mode, LDP can use the following routes to generate LSPs:
¡     All routes with a 32-bit mask.
If you specify the all or prefix-list keyword, the LSP generation policy is independent of the label distribution control mode.
·     If you specify the all keyword, LDP uses all redistributed routes to generate LSPs.
·     If you specify the prefix-list keyword, LDP uses routes permitted by the IPv4 prefix list to generate LSPs.
# Configure an LSP generation policy that enables LDP to use only redistributed routes 10.10.1.0/24 and 10.20.1.0/24 to establish LSPs for the public network.
[Sysname] ip prefix-list egress-fec-list index 1 permit 10.10.1.0 24
[Sysname] ip prefix-list egress-fec-list index 2 permit 10.20.1.0 24
[Sysname] mpls ldp
[Sysname-ldp] lsp-trigger prefix-list egress-fec-list
import bgp
ip prefix-list (Layer 3—IP Services Command Reference)
mpls ldp enable
Use mpls ldp enable to enable IPv4 LDP on an interface.
Use undo mpls ldp enable to disable IPv4 LDP on an interface.
mpls ldp enable
IPv4 LDP is disabled on an interface.
Interface view
An up interface enabled with IPv4 LDP and MPLS sends IPv4 Link Hellos for neighbor discovery.
On an LDP over MPLS TE network, an up MPLS TE tunnel interface enabled with LDP sends Targeted Hellos to the tunnel destination. The interface establishes a session to the tunnel peer to set up an LDP LSP over the MPLS TE tunnel.
Before you enable IPv4 LDP on an interface, use the mpls ldp command in system view to enable LDP globally. If the interface is bound to a VPN instance, you must also use the vpn-instance command to enable LDP for the VPN instance.
Disabling LDP on an interface terminates all LDP sessions on the interface, and removes all LSPs established through the sessions.
An interface can be enabled with both IPv4 LDP and IPv6 LDP.
# Enable IPv4 LDP on Ten-GigabitEthernet 2/0/0.
[Sysname] mpls ldp
[Sysname-ldp] quit
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp enable
display mpls ldp interface
mpls enable
mpls ldp
mpls ldp ipv6 enable
Use mpls ldp igp sync disable to disable LDP-IGP synchronization on an interface.
Use undo mpls ldp igp sync disable to enable LDP-IGP synchronization on an interface.
LDP-IGP synchronization is enabled on an interface.
Interface view
After you enable LDP-IGP synchronization for an OSPF area or an IS-IS process, LDP-IGP synchronization is enabled on the OSPF or IS-IS process interfaces by default. To disable LDP-IGP synchronization on an interface, execute the mpls ldp igp sync disable command on that interface.
# Disable LDP-IGP synchronization on Ten-GigabitEthernet 2/0/0.
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp igp sync disable
Use mpls ldp sync to enable LDP-ISIS synchronization.
Use undo mpls ldp sync to disable LDP-ISIS synchronization.
mpls ldp sync [ level-1 | level-2 ]
undo mpls ldp sync [ level-1 | level-2 ]
LDP-ISIS synchronization is disabled.
IS-IS view
level-1: Specifies Level-1 of the IS-IS process.
level-2: Specifies Level-2 of the IS-IS process.
LDP establishes LSPs based on the IGP optimal route. If LDP is not synchronized with IGP, MPLS traffic forwarding might be interrupted. The LDP-IGP synchronization feature is used to solve the synchronization problem.
After LDP-IGP synchronization is enabled, IGP advertises the actual cost of a link only when LDP convergence on the link is completed. Before LDP is converged, IGP advertises the maximum cost of the link. As a result, the link is visible on the IGP topology, but IGP does not select the link as the optimal route when other links are available. In this way, the device can avoid discarding MPLS packets due to lack of LDP LSP on the optimal route.
LDP-IGP synchronization is not supported for an IS-IS process that belongs to a VPN instance.
If you do not specify any keywords, this command enables LDP-ISIS synchronization for both Level-1 and Level-2.
If you execute this command multiple times, the most recent configuration takes effect. For example, if you execute the mpls ldp sync level-1 command after you execute the mpls ldp sync command, LDP-ISIS synchronization is enabled for Level-1 but disabled for Level-2.
# Enable LDP-ISIS synchronization for Level-2 of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] mpls ldp sync level-2
igp sync delay
Use mpls ldp sync to enable LDP-OSPF synchronization.
Use undo mpls ldp sync to disable LDP-OSPF synchronization.
mpls ldp sync
undo mpls ldp sync
LDP-OSPF synchronization is disabled.
OSPF view
OSPF area view
LDP-IGP synchronization is not supported for an OSPF process and its OSPF areas if the OSPF process belongs to a VPN instance.
To enable LDP-OSPF synchronization for an OSPF area, use this command in OSPF area view. To enable LDP-OSPF synchronization for all areas of an OSPF process, use this command in OSPF view.
# Enable LDP-OSPF synchronization for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] mpls ldp sync
igp sync delay
mpls ldp transport-address
Use mpls ldp transport-address to specify the LDP IPv4 transport address.
Use undo mpls ldp transport-address to remove the configuration.
In interface view:
mpls ldp transport-address { ipv4-address | interface }
undo mpls ldp transport-address { ipv4-address | interface }
In LDP peer view:
mpls ldp transport-address ipv4-address
In interface view, if the interface belongs to the public network, the LDP IPv4 transport address is the local LSR ID. If the interface belongs to a VPN, the LDP IPv4 transport address is the primary IP address of the interface.
In LDP peer view, the LDP IPv4 transport address is the local LSR ID.
Interface view
LDP peer view
ipv4-address: Specifies the LDP IPv4 transport address.
interface: Uses the IPv4 address of the current interface as the LDP IPv4 transport address.
Before two LSRs establish an IPv4 LDP session, they must establish a TCP connection by using the LDP IPv4 transport address.
As a best practice, use the default LDP IPv4 transport address.
If two LSRs have multiple links in between and you want to establish an IPv4 LDP session on each link, make sure all the links use the same IPv4 transport address.
# Specify the LDP transport address carried in Targeted Hellos sent to peer 3.3.3.3 as 2.2.2.2.
[Sysname] mpls ldp
[Sysname-ldp-peer-3.3.3.3] mpls ldp transport-address 2.2.2.2
# On Ten-GigabitEthernet 2/0/0, specify the LDP transport address carried in Link Hellos as the IP address of the interface.
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp transport-address interface
display mpls ldp discovery
targeted-peer
session protection
Use session protection to enable session protection.
Use undo session protection to disable session protection.
session protection [ duration time ] [ peer peer-prefix-list-name ]
Session protection is disabled.
LDP view
duration time: Specifies the session protection duration time in the range of 30 to 2147483 seconds. If you do not specify the duration, session protection always takes effect.
peer peer-prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters. Sessions to the peers whose LSR IDs are permitted by the specified IP prefix list are protected. If you do not specify this option, all sessions established by the Basic Discovery mechanism are protected.
If two LDP peers have both a direct link and an indirect link in between, you can configure this feature to protect their LDP session when the direct link fails.
LDP establishes both a Link Hello adjacency over the direct link and a Targeted Hello adjacency over the indirect link with the peer. When the direct link fails, LDP deletes the Link Hello adjacency but still maintains the Targeted Hello adjacency. In this way, the LDP session between the two peers is kept available, and the FEC-label mappings based on this session are not deleted. When the direct link recovers, the LDP peers do not need to re-establish the LDP session or re-learn the FEC-label mappings.
When you enable the session protection feature, you can specify the session protection duration. If the Link Hello adjacency does not recover within the duration, LDP deletes the Targeted Hello adjacency and the LDP session. If you do not specify the session protection duration, the two peers always maintain the LDP session over the Targeted Hello adjacency.
# Enable protection for the session to peer 3.3.3.3, and set the session protection duration to 120 seconds.
[Sysname] ip prefix-list protected-peer-list index 1 permit 3.3.3.3 32
[Sysname] mpls ldp
[Sysname-ldp] session protection duration 120 peer protected-peer-list
display mpls ldp peer
targeted-peer
Use targeted-peer to create a targeted IPv4 LDP peer and enter its view, or enter the view of an existing targeted IPv4 LDP peer. The device can send unsolicited IPv4 Targeted Hellos to the peer and can respond to IPv4 Targeted Hellos received from the peer.
Use undo targeted-peer to cancel the configuration.
targeted-peer ipv4-address [ peer-name ]
undo targeted-peer ipv4-address
No targeted LDP peers exist. The device does not send IPv4 Targeted Hellos to any peers, or respond to IPv4 Targeted Hellos received from any peers.
LDP view
ipv4-address: Specifies the peer IPv4 address.
peer-name: Specifies a name for the peer. If you do not specify a name, this command uses the specified peer IPv4 address (ipv4-address) as the name of the peer. You cannot specify the same name for different peer IPv4 addresses.
If you do not specify the LDP transport address, LDP sends the local LSR ID to the peer specified by this command in IPv4 Targeted Hellos.
To ensure a successful IPv4 Targeted Hello adjacency, make sure the following requirements are met:
·     The peer IPv4 address configured on the local LSR is the same as the IPv4 transport address configured in LDP peer view on the peer.
·     A route exists between the local IPv4 transport address and the peer IPv4 address.
LDP automatically sends Targeted Hellos to the specified peer after LDP session protection, LDP over MPLS TE, MPLS L2VPN LDP PW, or VPLS LDP PW is configured. To modify the Targeted Hello/Keepalive hold time and interval, you must use this command to create the LDP peer, and then perform the modification in the LDP peer view.
# Configure the device to send IPv4 Targeted Hellos to peer 3.3.3.3, and enter LDP peer view.
[Sysname] mpls ldp
IPv6 LDP commands
ipv6 accept-label
Use ipv6 accept-label to configure a label acceptance policy.
Use undo ipv6 accept-label to delete a label acceptance policy.
ipv6 accept-label peer { peer-lsr-id | all | peer-prefix-list peer-prefix-list-name } { host | none | prefix-list prefix-list-name }
undo ipv6 accept-label peer { peer-lsr-id | all | peer-prefix-list peer-prefix-list-name }
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware platform
MPU model
Comamnd compatibility
RA5300, RA5300-X, RA5300-AC
RSU-400, RSU-400S
Yes
RSU-400-G
No
No label acceptance policy is configured. LDP accepts all IPv6 FEC-label mappings from all peers.
LDP view
peer-lsr-id: Specifies an LDP peer by its LSR ID.
host: Accepts only the label mappings for host routes with a 128-bit mask.
none: Does not accept label mappings for IPv6 prefixes.
prefix-list prefix-list-name: Specifies an IPv6 prefix list to filter received label mappings. The prefix-list-name argument represents the IPv6 prefix list name, a case-sensitive string of 1 to 63 characters.
Operating mechanism
After a label acceptance policy is configured, for the label mappings from the specified peers, the LSR accepts only the label mappings whose FEC IPv6 prefixes are host routes or permitted by an IPv6 prefix list. For label mappings not permitted the filter, the LSR does not accept or save them.
If you configure a none label acceptance policy, the LSR does not accept any IPv6 FEC-label mappings from the peers specified in the policy.
To accept the previously denied label mappings from a peer, use the undo ipv6 accept-label command or change the IPv6 prefix list for the peer. Then, execute the reset mpls ldp command to reset the LDP session to that peer to apply the new settings.
·     After the ipv6 accept-label peer all command is executed, you cannot execute the ipv6 accept-label peer { peer-lsr-id | peer-prefix-list peer-prefix-list-name } command.
·     After the ipv6 accept-label peer { peer-lsr-id | peer-prefix-list peer-prefix-list-name } command is executed, if you execute the ipv6 accept-label peer all command, the previous command configuration will be deleted.
You can use the ipv6 accept-label peer peer-lsr-id command, the ipv6 accept-label peer peer-prefix-list peer-prefix-list-name command, or both commands multiple times to specify multiple peers. If the same peer has been specified by both commands, the command executed first applies.
# Configure a label acceptance policy to accept only the FEC-label mappings containing IPv6 prefix 2001:D00::/32 and a prefix length greater than or equal to 32 bits from LDP peer 1.1.1.9.
[Sysname] ipv6 prefix-list prefix-from-RTA permit 2001:D00:: 32 less-equal 128
[Sysname] mpls ldp
[Sysname-ldp] ipv6 accept-label peer 1.1.1.9 prefix-list prefix-from-RTA
display mpls ldp peer verbose
ipv6 prefix-list (Layer 3—IP Routing Command Reference)
ipv6 advertise-label peer
Use ipv6 advertise-label peer to configure a label advertisement policy for the specified LDP peers.
Use undo ipv6 advertise-label peer to delete the label advertisement policy configured for the specified LDP peers.
ipv6 advertise-label peer { peer-lsr-id | all | peer-prefix-list peer-prefix-list-name } { host | none | prefix-list prefix-list-name }
undo ipv6 advertise-label peer { peer-lsr-id | all | peer-prefix-list peer-prefix-list-name }
Hardware platform
MPU model
Command compatibility
RSU-400, RSU-400S
Yes
RSU-400-G
No
No label advertisement policy is configured. The device advertises IPv6 FEC-label mappings permitted by the LSP generation policy to all peers.
LDP view
none: Does not advertise label mappings for IPv6 prefixes.
prefix-list prefix-list-name: Specifies an IPv6 prefix list to filter the label mappings to be advertised. The prefix-list-name argument represents the IPv6 prefix list name, a case-sensitive string of 1 to 63 characters.
Operating mechanism
If you configure a none label advertisement policy, the LSR does not advertise any IPv6 FEC-label mappings to the peers specified in the policy.
·     If the IPv6 prefix in a label mapping does not match a permit rule in an IPv6 prefix list or matches a deny rule, the LSR does not advertise this label mapping to an LDP peer.
·     If the IPv6 prefix in a label mapping is permitted by an IPv6 prefix list, the LSR advertises this label mapping to the LDP peers specified in the corresponding label advertisement policy.
·     If the IPv6 prefix in a label mapping is permitted by the IPv6 prefix lists of multiple label advertisement policies, the policy configured first applies.
·     After the ipv6 advertise-label peer all command is executed, you cannot execute the ipv6 advertise-label peer { peer-lsr-id | peer-prefix-list peer-prefix-list-name } command.
·     After the ipv6 advertise-label peer { peer-lsr-id | peer-prefix-list peer-prefix-list-name } command is executed, if you execute the ipv6 advertise-label peer all command, the previous command configuration will be deleted.
You can use the ipv6 advertise-label peer peer-lsr-id command, the ipv6 advertise-label peer peer-prefix-list peer-prefix-list-name command, or both commands multiple times to specify multiple peers. If the same peer has been specified by both commands, the command executed first applies.
# Configure two label advertisement policies. One policy advertises only the label mapping for subnet 2001::1/64 to peer 3.3.3.9. The other policy advertises only the label mapping for subnet 3001::1/64 to peer 4.4.4.9.
[Sysname] ipv6 prefix-list prefix-to-C permit 2001::1 64
[Sysname] ipv6 prefix-list prefix-to-D permit 3001::1 64
[Sysname] mpls ldp
[Sysname-ldp] ipv6 advertise-label peer 3.3.3.9 prefix-list prefix-to-C
[Sysname-ldp] ipv6 advertise-label peer 4.4.4.9 prefix-list prefix-to-D
ipv6 advertise-label prefix-list
Use ipv6 advertise-label prefix-list to configure a label advertisement policy.
Use undo ipv6 advertise-label prefix-list to delete a label advertisement policy.
ipv6 advertise-label prefix-list prefix-list-name [ peer peer-prefix-list-name ]
undo ipv6 advertise-label prefix-list prefix-list-name
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
LDP view
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. This prefix list filters advertised label mappings.
[Sysname] mpls ldp
[Sysname-ldp] ipv6 advertise-label prefix-list prefix-to-C peer peer-C
[Sysname-ldp] ipv6 advertise-label prefix-list prefix-to-D peer peer-D
ipv6 lsp-trigger
ipv6 import bgp
Use ipv6 import bgp to enable LDP to redistribute BGP IPv6 unicast routes.
Use undo ipv6 import bgp to disable LDP from redistributing BGP IPv6 unicast routes.
ipv6 import bgp [ as-number ]
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
LDP does not redistribute BGP IPv6 unicast routes.
LDP view
as-number: Redistributes BGP IPv6 unicast routes in the specified AS. An AS number is in the range of 1 to 4294967295. If you do not specify an AS number, this command enables LDP to redistribute all BGP IPv6 unicast routes.
IMPORTANT
IMPORTANT:
Use this command only if necessary. Execution of this command will increase the number of routes redistributed to LDP. A large number of redistributed routes use a large amount of labels and memory.
By default, LDP automatically redistributes IPv6 IGP routes, including the BGP IPv6 unicast routes that have been redistributed into IGP. Then, LDP assigns labels to the IGP routes and labeled BGP routes if these routes are permitted by an LSP generation policy. LDP does not automatically redistribute BGP IPv6 unicast routes if the routes are not redistributed into the IGP.
For example, on a carrier's carrier network where IGP is not configured between a PE of a Level 1 carrier and a CE of a Level 2 carrier, LDP cannot redistribute BGP IPv6 unicast routes to assign labels to them. For this network to operate correctly, enable LDP to redistribute BGP IPv6 unicast routes. If the routes are permitted by an LSP generation policy, LDP assigns labels to them to establish LSPs. For more information about carrier's carrier, see MPLS L3VPN in MPLS Configuration Guide.
# Enable LDP to redistribute BGP IPv6 unicast routes in AS 100 on the public network.
[Sysname] mpls ldp
[Sysname-ldp] ipv6 import bgp 100
ipv6 lsp-trigger
ipv6 lsp-trigger
Use ipv6 lsp-trigger to configure an LSP generation policy for IPv6 FECs.
Use undo ipv6 lsp-trigger to restore the default.
ipv6 lsp-trigger { all | mapping | prefix-list prefix-list-name }
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
LDP only uses redistributed IPv6 host routes with a 128-bit prefix to generate LSPs.
LDP view
prefix-list prefix-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. LDP uses only the redistributed routes permitted by the IPv6 prefix list to generate LSPs.
¡     Loopback interface address routes with a 128-bit prefix.
¡     The routes with a 128-bit prefix that match the FECs of label mappings received from downstream LSRs.
·     In Independent mode, LDP can use all routes with a 128-bit prefix to generate LSPs.
¡     All routes with a 128-bit prefix.
·     If you specify the prefix-list keyword, LDP uses routes permitted by the IPv6 prefix list to generate LSPs.
# Configure an LSP generation policy that enables LDP to use only redistributed routes 2001::1/64 to establish LSPs for the public network.
[Sysname] ipv6 prefix-list egress-fec-list permit 2001::1 64
[Sysname] mpls ldp
[Sysname-ldp] ipv6 lsp-trigger prefix-list egress-fec-list
ipv6 import bgp
ipv6 prefix-list (Layer 3—IP Services Command Reference)
Use mpls ldp ipv6 enable to enable IPv6 LDP on an interface.
Use undo mpls ldp ipv6 enable to disable IPv6 LDP on an interface.
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
IPv6 LDP is disabled on an interface.
Interface view
An up interface enabled with IPv6 LDP and MPLS sends IPv6 Link Hellos for neighbor discovery.
Before you enable IPv6 LDP on an interface, use the mpls ldp command in system view to enable LDP globally. If the interface is bound to a VPN instance, you must also use the vpn-instance command to enable LDP for the VPN instance.
If an interface is enabled with only IPv6 LDP, LDP can send IPv6 Hellos only after you specify the LDP transport address by using the mpls ldp transport-address command.
# Enable IPv6 LDP on Ten-GigabitEthernet 2/0/0.
[Sysname] mpls ldp
[Sysname-ldp] quit
[Sysname-Ten-GigabitEthernet2/0/0] mpls ldp ipv6 enable
mpls enable
mpls ldp
mpls ldp enable
Use mpls ldp transport-address to specify the LDP IPv6 transport address.
In interface view:
mpls ldp transport-address ipv6-address
undo mpls ldp transport-address ipv6-address
In LDP peer view:
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
No LDP IPv6 transport address is configured.
Interface view
LDP peer view
ipv6-address: Specifies the LDP IPv6 transport address.
Before two LSRs establish an IPv6 LDP session, they must establish a TCP connection by using the LDP IPv6 transport address.
If two LSRs have multiple links in between and you want to establish an IPv6 LDP session on each link, make sure all the links use the same IPv6 transport address.
# Specify the LDP transport address as 2002::1 for the TCP connection established with peer 2001::1.
[Sysname] mpls ldp
[Sysname-ldp-peer-2001::1] mpls ldp transport-address 2002::1
targeted-peer
targeted-peer
Use targeted-peer to create a targeted IPv6 LDP peer and enter its view, or enter the view of an existing targeted IPv6 LDP peer. The device can send unsolicited IPv6 Targeted Hellos to the peer and can respond to IPv6 Targeted Hellos received from the peer.
targeted-peer ipv6-address [ peer-name ]
undo targeted-peer ipv6-address
Hardware platform
MPU model
RSU-400, RSU-400S
Yes
RSU-400-G
No
No targeted LDP peers exist. The device does not send IPv6 Targeted Hellos to any peers, or respond to IPv6 Targeted Hellos received from any peers.
LDP view
ipv6-address: Specifies the peer IPv6 address.
peer-name: Specifies a name for the peer. If you do not specify a name, this command uses the specified peer IPv6 address (ipv6-address) as the name of the peer. You cannot specify the same name for different peer IPv6 addresses.
After a targeted IPv6 LDP peer is created, LDP does not send IPv6 Targeted Hellos to the peer until you specify the LDP IPv6 transport address in LDP peer view.
To ensure a successful IPv6 Targeted Hello adjacency, make sure the following requirements are met:
·     The peer IPv6 address configured on the local LSR is the same as the IPv6 transport address configured in LDP peer view on the peer.
·     A route exists between the local IPv6 transport address and the peer IPv6 address.
# Configure the device to send IPv6 Targeted Hellos to peer 2001::1, and enter LDP peer view.
[Sysname] mpls ldp
