- 12-Network Management and Monitoring Configuration Guide
- 01-GOLD configuration
- 02-iFIT configuration
- 03-NETCONF configuration
- 04-NQA configuration
- 05-NTP configuration
- 06-Packet capture configuration
- 07-PTP configuration
- 08-SNMP configuration
- 09-TCP connection trace configuration
- 10-Information center configuration
- 11-Network synchronization configuration
- 12-System maintenance and debugging configuration
- 13-Process monitoring and maintenance configuration
- 14-Mirroring configuration
| 00-Preface | 110.58 KB |
Preface
This configuration guide describes features that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
