| 07-BFD commands | 473.71 KB |
bfd authentication-mode (BFD template view)
bfd authentication-mode (interface view/static BFD session view)
bfd destination-port evpn-vpls-srv6
bfd destination-port evpn-vpws-srv6
bfd detect-interface first-fail-timer
bfd detect-interface source-ip
bfd detect-interface special-processing
bfd detect-multiplier (BFD template view)
bfd detect-multiplier (interface view/static BFD session view)
bfd min-receive-interval (BFD template view)
bfd min-receive-interval (interface view/static BFD session view)
bfd min-transmit-interval (BFD template view)
bfd min-transmit-interval (interface view/static BFD session view)
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-echo-receive-interval
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bfd session-negotiation delay-upon-down
bfd session-negotiation delay-upon-reboot
sbfd destination ipv4 remote-discriminator
sbfd destination ipv6 remote-discriminator
BFD commands
Basic BFD commands
associate-static-session
Use associate-static-session to associate a static BFD session with another static BFD session.
Use undo associate-static-session to restore the default.
associate-static-session session-name [ re-negotiate seconds ]
A static BFD session is not associated with any other static BFD sessions.
Static BFD session view
session-name: Specify a static BFD session by its name, a case-sensitive string of 1 to 64 characters. The specified static BFD session cannot be the current static BFD session.
re-negotiate seconds: Specifies the maximum amount of time that the associated static BFD session can perform negotiation. The value range for the seconds argument is 10 to 600 seconds. The default is 60 seconds. This option takes effect only on bidirectional associations.
The device supports the following association types for two static BFD sessions (static BFD session a and static BFD session b are used for illustration):
· Unidirectional association—Session a is associated with session b in the view of session a, or session b is associated with session a in the view of session b.
· Bidirectional association—Session a is associated with session b in the view of session a, and session b is associated with session a in the view of session b.
A unidirectional association works as follows (the association configured in the view of static BFD session a is taken as an example):
1. When session a changes to the Down state, session b also changes to the Down state. Before session a comes up, session b is not allowed to perform negotiation.
2. When session a changes to the Up state, static BFD session b starts to perform negotiation. The state of session a is not affected even if session b cannot come up through negotiation.
A bidirectional association works as follows:
2. When session a changes to the Up state, session b starts to perform negotiation.
¡ If session b comes up through negotiation in the specified time, both static BFD sessions are placed in Up state.
¡ If session b fail to come up through negotiation in the specified time, both static BFD sessions are placed in Down state.
3. The same rules apply to the state changes of session a if session b first changes to the Down state.
To change an associated static BFD session, first execute the undo associate-static-session command and then associate a new static BFD session by using the associate-static-session command.
# Associate static BFD session aaa with static BFD session bbb.
[Sysname] bfd static aaa
[Sysname-bfd-static-session-aaa] associate-static-session bbb
Use bfd authentication-mode to configure the BFD authentication mode for BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
BFD control packets are not authenticated.
BFD template view
hmac-md5: Specifies the HMAC MD5 algorithm.
hmac-mmd5: Specifies the HMAC Meticulous MD5 algorithm.
hmac-msha1: Specifies the HMAC Meticulous SHA1 algorithm.
hmac-sha1: Specifies the HMAC SHA1 algorithm.
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Application scenarios
In the scenario where BFD is used to detect link connectivity and a BFD session parameter template is specified, you can execute this command to enhance BFD session security.
The two ends can successfully negotiate a BFD session only when they have consistent authentication settings.
BFD version 0 does not support this command. The configuration does not take effect.
# For BFD template named bfd1, configure simple authentication for BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1] bfd authentication-mode simple 1 plain 123456
bfd template
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Single-hop BFD control packets are not authenticated.
Interface view
Use this command to enhance BFD session security.
A static BFD session supports this command only when it is in IPv4 or IPv6 control packet mode used for single-hop detection.
# Configure GigabitEthernet 1/0/6 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname] interface gigabitethernet 1/0/6
[Sysname-GigabitEthernet1/0/6] bfd authentication-mode simple 1 plain 123456
bfd dampening
Use bfd dampening to configure BFD session flapping suppression.
Use undo bfd dampening to disable BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
undo bfd dampening
BFD sessions are not suppressed.
maximum-interval: Specifies the maximum time a BFD session is suppressed, in the range of 1 to 3600 seconds. The default is 20 seconds.
initial-interval: Specifies the amount of time a BFD session is suppressed for the first time. The value range for the initial-interval argument is 1 to 3600 seconds. The default is 6 seconds.
secondary-interval: Specifies the amount of time a BFD session is suppressed for the second time. The value range for the secondary-interval argument is 1 to 3600 seconds. The default is 10 seconds.
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability.
This command allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
· A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
· After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
· After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
· After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡ If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡ If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
# Enable BFD session flapping suppression, and set the maximum-interval, initial-interval, and secondary-interval to 12 seconds, 4 seconds, and 8 seconds, respectively.
[Sysname] bfd dampening maximum 12 initial 4 secondary 8
Use bfd destination-port to configure the destination port number for a static BFD session used to detect SRv6 PWs.
Use undo bfd destination-port to restore the default.
bfd destination-port port-number
The destination port number is not configured for a static BFD session used to detect SRv6 PWs. The port number configured by using the bfd destination-port evpn-vpls-srv6 or bfd destination-port evpn-vpws-srv6 command in system view applies.
port-number: Specifies the destination port number for BFD control packets, which takes 4784.
An H3C device and a device from another vendor can establish an SRv6 PW. When you use BFD to detect such an SRv6 PW, the two ends of the BFD session might be configured with different port numbers. Port number inconsistency will cause BFD session negotiation to fail. To resolve the issue, use this command to edit the destination port number for the static BFD session used for SRv6 PW detection on the H3C device.
This command configured in static BFD session view takes effect only for that session. For the configuration to take effect globally, configure the bfd destination-port evpn-vpls-srv6 or bfd destination-port evpn-vpws-srv6 command in system view.
Only the following static BFD sessions support this command:
· Static BFD sessions used to detect SRv6 PWs on EVPN VPLS over SRv6 networks.
· Static BFD sessions used to detect SRv6 PWs on EVPN VPWS over SRv6 networks.
# Create static BFD session abc to detect the SRv6 PW in VSI aaa. The IPv6 address of the remote PE is 20::1 for the SRv6 PW. Configure the destination port number as 4784 for the static BFD session.
[Sysname] bfd static abc evpn-vpls-srv6 vsi aaa remote-peer 20::1
[Sysname-bfd-static-session-abc] bfd destination-port 4784
# Create static BFD session abc to detect the SRv6 PW associated with the cross-connect. The interface associated with the cross-connect is GigabitEthernet1/0/6, and the IPv6 address of the remote PE is 20::1. Configure the destination port number as 4784 for the static BFD session.
[Sysname] bfd static abc evpn-vpws-srv6 interface gigabitethernet 1/0/6 remote-peer 20::1
bfd static evpn-vpls-srv6 (Segment Routing Command Reference)
bfd static evpn-vpws-srv6 (Segment Routing Command Reference)
Use bfd destination-port evpn-vpls-srv6 to configure the destination port number for all static BFD sessions used to detect SRv6 PWs on EVPN VPLS over SRv6 networks.
Use undo bfd destination-port evpn-vpls-srv6 to restore the default.
bfd destination-port evpn-vpls-srv6 port-number
The destination port number is 3784 for static BFD sessions used to detect SRv6 PWs on EVPN VPLS over SRv6 networks.
An H3C device and a device from another vendor can establish an SRv6 PW on an EVPN VPLS over SRv6 network. When you use BFD to detect such an SRv6 PW, the two ends of the BFD session might be configured with different port numbers. Port number inconsistency will cause BFD session negotiation to fail. To resolve the issue, use this command to edit the destination port number for the static BFD session used for SRv6 PW detection on the H3C device.
You can configure the destination port number for BFD control packets in system view or static BFD session view.
· The bfd destination-port evpn-vpls-srv6 command configured in system view takes effect for all static BFD sessions used to detect SRv6 PWs on EVPN VPLS over SRv6 networks.
· The bfd destination-port command configured in static BFD session view takes effect only for that session.
# Configure the destination port number as 4784 for all static BFD sessions used to detect SRv6 PWs on EVPN VPLS over SRv6 networks.
[Sysname] bfd destination-port evpn-vpls-srv6 4784
Use bfd destination-port evpn-vpws-srv6 to configure the destination port number for all static BFD sessions used to detect SRv6 PWs on EVPN VPWS over SRv6 networks.
Use undo bfd destination-port evpn-vpws-srv6 to restore the default.
bfd destination-port evpn-vpws-srv6 port-number
The destination port number is 3784 for static BFD sessions used to detect SRv6 PWs on EVPN VPWS over SRv6 networks.
port-number: Specifies the destination port number for BFD control packets, which takes 4784. The default value and value range for this argument vary by BFD session type.
An H3C device and a device from another vendor can establish an SRv6 PW on an EVPN VPWS over SRv6 network. When you use BFD to detect such an SRv6 PW, the two ends of the BFD session might be configured with different port numbers. Port number inconsistency will cause BFD session negotiation to fail. To resolve the issue, use this command to edit the destination port number for the static BFD session used for SRv6 PW detection on the H3C device.
· The bfd destination-port evpn-vpws-srv6 command configured in system view takes effect for all static BFD sessions used to detect SRv6 PWs on EVPN VPWS over SRv6 networks.
# Configure the destination port number as 4784 for all static BFD sessions used to detect SRv6 PWs on EVPN VPWS over SRv6 networks.
[Sysname] bfd destination-port evpn-vpws-srv6 4784
Use bfd detect-interface first-fail-timer to configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
Use undo bfd detect-interface first-fail-timer to restore the default.
bfd detect-interface first-fail-timer seconds
The first BFD session establishment failure is not reported to the data link layer.
Interface view
seconds: Specifies the timeout time that reports the first BFD session establishment failure to the data link layer. The value range for this argument is 1 to 10000 seconds.
If the BFD session fails to be established when the timer expires, BFD reports the failure to the data link layer and sets the data link layer state of the interface to DOWN(BFD). This behavior rapidly identifies the interfaces for which BFD sessions fail to be established. In this case, the BFD session state is displayed as Down in the display bfd session command output. The line protocol state of the interface is displayed as DOWN(BFD) in the display interface command output.
If you execute the bfd detect-interface source-ip command on the local end, the BFD session for detecting the local interface state fails to be established when the following conditions exist:
· The bfd detect-interface source-ip command is not executed on the remote end.
· The local and remote ends have mismatching BFD authentication settings.
# Configure the timer that delays reporting the first BFD session establishment failure as 10 seconds for GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] bfd detect-interface first-fail-timer 10
Use bfd detect-interface source-ip to associate the interface state with BFD.
Use undo bfd detect-interface to remove the association between the interface state and BFD.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
The interface state is not associated with BFD.
Interface view
ip-address: Specifies the source IP address for BFD control packets.
discriminator: Specifies BFD session discriminators. If you do not specify discriminators, the device obtains BFD session discriminators through autonegotiation.
local local-value: Specifies the local discriminator. The value range for the local-value argument is 1 to 32768.
remote remote-value: Specifies the remote discriminator in the range of 1 to 4294967295.
template template-name: Specifies a template by its name, a case-sensitive string of 1 to 63 characters. If you specify a nonexistent template or do not specify a template, the BFD session uses the BFD parameters configured in interface view. If you first specify a nonexistent template and then create the template, the BFD session uses the parameters configured in the template.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence. The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
· Layer 3 Ethernet interfaces.
· Member ports in a Layer 3 aggregation group.
· Layer 3 Ethernet subinterfaces.
· Layer 3 aggregate interfaces.
· Layer 3 aggregate subinterfaces.
This command must be configured on both ends of the link for a BFD session to be established.
For BFD detection to take effect, do not configure this command on both a Layer 3 Ethernet interface and its subinterface.
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd detect-interface source-ip 20.1.1.1 discriminator local 513 remote 514 on the local device, you must configure bfd detect-interface source-ip 20.1.1.1 discriminator local 514 remote 513 on the peer device.
The local discriminators of BFD sessions for interfaces on the same device must be different.
The echo function does not take effect on BFD sessions associated with interface states.
# Associate GigabitEthernet 1/0/6 with BFD to detect the interface state, and specify the source IP address for BFD control packets as 20.1.1.1.
[Sysname-GigabitEthernet1/0/6] bfd detect-interface source-ip 20.1.1.1
Use bfd detect-interface special-processing to enable special processing for BFD sessions.
Use undo bfd detect-interface special-processing to disable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
undo bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
All types of special processing for BFD sessions are disabled.
Interface view
admin-down: Notifies a session down event to the data link layer upon receipt of a BFD packet with the State field as AdminDown. This keyword helps rapidly discover interfaces on which BFD sessions are manually shut down. If you do not specify this keyword, the device sets the BFD session state to Down, but does not notify the session down event to the data link layer.
authentication-change: Immediately sets the session to down state upon a local authentication information change. This keyword helps rapidly discover interfaces with authentication information changes. If you do not specify this keyword, the device sets the session to down state if authentication information inconsistency still persists after a period of time.
session-up: Ignores authentication information inconsistency when the local session is up. If a large number of BFD sessions exist, examining authentication information consistency affects device performance. If you do not specify this keyword, the device examines authentication information in incoming BFD packets when the local session state is up. If the authentication information does not match on the two ends, the BFD session is declared down.
If you do not specify any parameters, this command enables or disables all types of special processing.
When the authentication mode for BFD packets is M-MD5, M-SHA1, HMAC-MMD5, or HMAC-MSHA1, configuring the bfd detect-interface special-processing session-up command on only the local or remote end will cause BFD session flapping. To avoid this issue, perform one of the following tasks:
· Change the authentication mode for BFD packets.
· Configure the bfd detect-interface special-processing session-up command on both of the local and remote ends.
# Enable all types of special processing for BFD sessions on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] bfd detect-interface special-processing admin-down authentication-change session-up
Use bfd detect-multiplier to set the detection time multiplier for control packet mode.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The detection time multiplier is 3 for control packet mode.
BFD template view
value: Specifies a detection time multiplier in the range of 3 to 50.
In the scenario where BFD is used to detect link connectivity and a BFD session parameter template is specified, you can use the BFD session parameter template to adjust the BFD detection time multiplier, minimum interval for receiving echo packets, minimum interval for receiving BFD control packets, and minimum interval for sending BFD control packets. For example, in a scenario where BFD is used to detect LSP connectivity, you can specify a BFD session parameter template to adjust the session parameters. If no BFD session parameter template is specified, the BFD session will use the multihop BFD session parameters configured in system view. You can adjust the BFD detection time multiplier in the specified BFD session parameter template based on the actual network conditions to adjust the BFD detection time.
Operating mechanism
The detection time multiplier determines the maximum number of concurrent BFD packets that can be discarded.
Table 1 Actual detection interval calculation method
Mode |
Actual detection interval of the sender |
Single-hop control packet mode BFD session in asynchronous mode |
Detection time multiplier of the receiver × MAX (minimum receiving interval supported by the sender, minimum sending interval supported by the receiver) |
Single-hop control packet mode BFD session in demand mode |
Detection time multiplier of the sender × MAX (minimum sending interval supported by the sender, minimum receiving interval supported by the receiver) |
Multihop control packet mode BFD session in asynchronous mode |
Multihop control packet mode BFD session in demand mode |
The timers for BFD sessions in different directions are negotiated separately, and they can have different values.
When a BFD session is valid, both the control packet sending interval and detection time can be dynamically negotiated and edited without affecting the session state.
# For BFD template named bfd1, set the detection time multiplier for control packet mode to 6.
[Sysname-bfd-template-bfd1] bfd detect-multiplier 6
bfd template
Use bfd detect-multiplier to set the single-hop detection time multiplier for control packet mode and echo packet mode.
The single-hop detection time multiplier is 3 for control packet mode and echo packet mode.
Interface view
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 2 Actual detection interval calculation method
Mode |
Echo packet mode |
Detection time multiplier of the sender × actual packet sending interval of the sender |
Control packet mode BFD session in asynchronous mode |
Control packet mode BFD session in demand mode |
· Static BFD sessions in IPv4 control packet mode used for single-hop detection.
· Static BFD sessions in IPv4 echo packet mode used for single-hop detection.
· Static BFD sessions in IPv6 control packet mode used for single-hop detection.
· Static BFD sessions in IPv6 echo packet mode used for single-hop detection.
# Set the single-hop detection time multiplier for control packet mode and echo packet mode to 6 on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] bfd detect-multiplier 6
bfd static
bfd echo enable
Use bfd echo enable to enable the echo function.
Use undo bfd echo enable to disable the echo function.
undo bfd echo [ receive | send ] enable
The echo function is disabled.
Interface view
receive: Specifies the echo packet receiving capability.
send: Specifies the echo packet sending capability.
If you enable the echo function for a BFD session in which control packets are sent and the session comes up, BFD performs the following operations:
· Periodically sends echo packets to detect link connectivity.
· Decreases the control packet receiving rate at the same time.
To enable only the echo packet receiving capability, use the bfd echo receive enable command.
To enable only the echo packet sending capability, use the bfd echo send enable command.
If you do not specify the receive or send keyword, the command enables both the echo packet receiving and sending capabilities.
The echo function does not take effect on BFD sessions in control packet mode that use IPv6 link-local addresses.
# Enable the echo function on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] bfd echo enable
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
ip-address: Specifies the source IP address of BFD echo packets. The source IP address must be a valid unicast IPv4 address in dotted decimal notation.
As a best practice, configure this command on the source end of an echo-packet-mode BFD session. In addition, make sure the source IP address is not in the same network segment as any interfaces on the device. This can avoid link congestion caused by a large number of ICMP redirect packets sent from the peer.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
As a best practice, configure this command on the source end of an echo-packet-mode BFD session. In addition, make sure the source IPv6 address is not in the same network segment as any interfaces on the device. This can avoid link congestion caused by a large number of ICMPv6 redirect packets sent from the peer.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd init-fail-timer
Use bfd init-fail-timer to set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
Use undo bfd init-fail-timer to restore the default.
bfd init-fail-timer seconds
BFD does not notify upper-layer protocols of session establishment failures.
seconds: Specifies the delay time in the range of 5 to 600 seconds. After the delay time, BFD notifies the upper-layer protocol of session establishment failures.
CAUTION: For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches. |
This command takes effect only for control packet mode.
In some cases, for an upper-layer protocol to act correctly, BFD must notify the upper-layer protocol of session establishment failures. For example, with this command configured, the link aggregation module can promptly set the state of a member port from Selected to Unselected in the case of a link failure.
# Set the delay timer to 10 seconds for BFD to notify upper-layer protocols of session establishment failures.
[Sysname] bfd init-fail-timer 10
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
The minimum interval for receiving BFD echo packets is 1000 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value takes 0 or is in the range of 3 to 1000.
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
The local end stops sending echo packets after autonegotiation with the remote end if the following conditions are met:
· The echo mode is enabled on the local end.
· The minimum interval for receiving BFD echo packets is set to 0 milliseconds on the remote end.
# Set the minimum interval for receiving BFD echo packets to 500 milliseconds on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] bfd min-echo-receive-interval 500
bfd static
Use bfd min-receive-interval to set the minimum interval for receiving BFD control packets.
Use undo bfd min-receive-interval to restore the default.
The minimum interval for receiving BFD control packets is 10 milliseconds.
BFD template view
interval: Specifies the minimum interval for receiving BFD control packets, in milliseconds. The value range is 3 to 1000.
Use this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the following values:
· Minimum interval for transmitting BFD control packets on the peer end.
· Minimum interval for receiving BFD control packets on the local end.
# For BFD template named bfd1, set the minimum interval for receiving BFD control packets to 500 milliseconds.
[Sysname-bfd-template-bfd1] bfd min-receive-interval 500
bfd template
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
The minimum interval for receiving single-hop BFD control packets is 10 milliseconds.
Interface view
interval: Specifies the minimum interval for receiving single-hop BFD control packets, in milliseconds. The value range is 3 to 1000.
# Set the minimum interval for receiving single-hop BFD control packets to 500 milliseconds on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] bfd min-receive-interval 500
bfd static
Use bfd min-transmit-interval to set the minimum interval for transmitting BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
The minimum interval for transmitting BFD control packets is 10 milliseconds.
BFD template view
interval: Specifies the minimum interval for transmitting BFD control packets, in milliseconds. The value range is 3 to 1000.
Use this command to prevent the BFD packet sending rate from exceeding the device capability.
The actual BFD control packet transmitting interval on the local end is the greater value between the following values:
· Minimum interval for transmitting BFD control packets on the local end.
· Minimum interval for receiving BFD control packets on the peer end.
# For BFD template named bfd1, set the minimum interval for transmitting BFD control packets to 500 milliseconds.
[Sysname-bfd-template-bfd1] bfd min-transmit-interval 500
bfd template
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
The minimum interval for transmitting single-hop BFD control packets is 10 milliseconds.
Interface view
interval: Specifies the minimum interval for transmitting single-hop BFD control packets, in milliseconds. The value range is 3 to 1000.
# Set the minimum interval for transmitting single-hop BFD control packets to 500 milliseconds on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] bfd min-transmit-interval 500
bfd static
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
No authentication is performed.
A static BFD session supports this command only when it is in IPv4 or IPv6 control packet mode used for multihop detection.
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and key to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
bfd static
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
IANA assigned port number 4784 to BFD for multihop BFD detection in control packet mode. By default, H3C devices use 4784 as the destination port number for multihop BFD control packets, while devices from other vendors might use 3784. To avoid BFD session establishment failures, make sure the devices on both ends of the BFD session use the same destination port number for multihop BFD control packets.
This command applies to only new multihop BFD sessions in control packet mode.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier for control packet mode and echo packet mode.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier is 3 for control packet mode and echo packet mode.
value: Specifies the multihop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 3 Actual detection interval calculation method
Mode |
Echo packet mode |
· Static BFD sessions in IPv4 control packet mode used for multihop detection.
· Static BFD sessions in IPv4 echo packet mode used for multihop detection.
· Static BFD sessions in IPv6 control packet mode used for multihop detection.
· Static BFD sessions in IPv6 echo packet mode used for multihop detection.
# Set the multihop detection time multiplier to 6.
[Sysname] bfd multi-hop detect-multiplier 6
bfd static
Use bfd multi-hop min-echo-receive-interval to set the minimum interval for receiving multihop BFD echo packets.
Use undo bfd multi-hop min-echo-receive-interval to restore the default.
bfd multi-hop min-echo-receive-interval interval
The minimum interval for receiving multihop BFD echo packets is 1000 milliseconds.
interval: Specifies the minimum interval for receiving multihop BFD echo packets, in milliseconds. The value for this argument takes 0 or is in the range of 3 to 1000.
The interval for receiving multihop BFD echo packets is also the interval for sending multihop BFD echo packets. By executing this command, you can control both the receiving interval and sending interval for multihop BFD echo packets.
A static BFD session supports this command only when it is in IPv4 or IPv6 echo packet mode used for multihop detection.
# Set the minimum interval for receiving multihop BFD echo packets to 500 milliseconds.
[Sysname] bfd multi-hop min-echo-receive-interval 500
bfd static
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
The minimum interval for receiving multihop BFD control packets is 10 milliseconds.
interval: Specifies the minimum interval for receiving multihop BFD control packets, in milliseconds. The value range is 3 to 1000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving capability (minimum control packet receiving interval) of the local end. If the receiving capability is exceeded, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 500
bfd static
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
The minimum interval for transmitting multihop BFD control packets is 10 milliseconds.
interval: Specifies the minimum interval for transmitting multihop BFD control packets, in milliseconds. The value range is 3 to 1000.
# Set the minimum interval for transmitting multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 500
bfd static
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
active: Specifies the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Specifies the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
A minimum of one end must operate in active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
Use bfd session-negotiation delay-upon-down to enable session negotiation delay for down BFD sessions and set a delay timer.
Use undo bfd session-negotiation delay-upon-down to restore the default.
bfd session-negotiation delay-upon-down interval
Session negotiation delay is disabled for down BFD sessions.
interval: Specifies a delay timer in the range of 1 to 1200 seconds.
If an upper-layer protocol uses BFD to detect the active path, an active/standby path switchover is triggered after the active path goes down. If the BFD session comes up before the active path recovers, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur.
The session negotiation delay function starts a delay timer for each BFD session from up to down state and each newly created session. Before the timer expires, the device does not perform session negotiation on each BFD session. The delay timer allows the active path to recover completely before the BFD session comes up again.
# Enable session negotiation delay for down BFD sessions and set the delay timer to 6 seconds.
[Sysname] bfd session-negotiation delay-upon-down 6
display bfd session
Use bfd session-negotiation delay-upon-reboot to enable BFD session negotiation delay upon a device reboot and set a delay timer.
Use undo bfd session-negotiation delay-upon-reboot to restore the default.
bfd session-negotiation delay-upon-reboot interval
BFD session negotiation delay upon a device reboot is disabled.
If an upper-layer protocol uses BFD to detect the active path, an active/standby path switchover is triggered upon a device reboot. If the BFD session comes up after a device reboot, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur if the active path of the upper-layer protocol has not recovered completely.
The session negotiation delay function starts a delay timer when the device reboots successfully. Before this timer expires, the device does not perform session negotiation on BFD sessions in down state or newly created sessions. The delay timer allows the active path to recover completely before the BFD session comes up again.
If both the bfd session-negotiation delay-upon-reboot and bfd session-negotiation delay-upon-down commands are executed, the device uses the longer delay time configured in the two commands after a reboot.
# Enable BFD session negotiation delay upon a device reboot and set the delay timer to 6 seconds.
[Sysname] bfd session-negotiation delay-upon-reboot 6
display bfd session
bfd static
Use bfd static to create a static BFD session and enter its view, or enter the view of an existing static BFD session.
Use undo bfd static to delete a static BFD session and all its settings.
Static BFD session for single-hop detection with IPv4 control packets:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ] ]
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number [ discriminator local local-value remote remote-value] ]
Static BFD session for multihop detection with IPv4 control packets:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ] ]
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] [ discriminator local local-value remote remote-value ] [ track-interface interface-type interface-number ] ]
Static BFD session for single-hop detection with IPv4 echo packets:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
Static BFD session for multihop detection with IPv4 echo packets:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] destination-ip ipv4-address [ source-ip ipv4-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
Static BFD session for single-hop detection with IPv6 control packets:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ] ]
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number [ discriminator local local-value remote remote-value ] ]
Static BFD session for multihop detection with IPv6 control packets:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator { auto | local local-value remote remote-value } ] [ track-interface interface-type interface-number ] ]
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ discriminator local local-value remote remote-value ] [ track-interface interface-type interface-number ] ]
Static BFD session for single-hop detection with IPv6 echo packets:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
Static BFD session for multihop detection with IPv6 echo packets:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] destination-ipv6 ipv6-address [ source-ipv6 ipv6-address ] one-arm-echo [ discriminator { auto | local local-value } ] ]
Static BFD session for single-hop detection with IPv4 control packets (the peer address is fixed at 224.0.0.184):
bfd static session-name [ peer-ip default-ip interface interface-type interface-number source-ip ip-address discriminator local discr-value remote discr-value ]
undo bfd static session-name
No static BFD sessions exist.
session-name: Specifies a static BFD session name, a case-sensitive string of 1 to 64 characters.
peer-ip ipv4-address: Specifies the peer IPv4 address in dotted decimal notation. It must be a valid unicast IPv4 address. For a static BFD session in control packet mode, the peer IPv4 address and the source IPv4 address determine the path to be detected. For a static BFD session in echo packet mode, the peer IPv4 address and the destination IPv4 address determine the path to be detected.
peer-ipv6 ipv6-address: Specifies the peer IPv6 address. For a static BFD session in control packet mode, the peer IPv6 address and the source IPv6 address determine the path to be detected. For a static BFD session in echo packet mode, the peer IPv6 address and the destination IPv6 address determine the path to be detected.
default-ip: Specifies the peer IPv4 address as 224.0.0.184.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the static BFD session belongs to the public network.
interface interface-type interface-number: Specifies an interface by its type and number. BFD uses the specified interface as the outgoing interface for outgoing packets.
destination-ip ipv4-address: Specifies the destination IPv4 address for echo packets, in dotted decimal notation. It must be a valid unicast IPv4 address of the local end.
destination-ipv6 ipv6-address: Specifies the destination IPv6 address for echo packets. It must be the IPv6 address of the local end.
source-ip ipv4-address: Specifies the source IPv4 address for BFD packets, in dotted decimal notation. It must be a valid unicast IPv4 address.
peer-ipv6 ipv6-address: Specifies the source IPv6 address for BFD packets.
one-arm-echo: Specifies the static BFD session mode as echo packet mode.
local local-value: Specifies the local discriminator in the range of 1 to 32768.
auto: Enables the device to automatically assign local discriminator values to static BFD sessions.
track-interface interface-type interface-number: Specifies an interface monitored by the static BFD session. When the monitored interface fails, the static BFD session changes to the down state. If you do not specify an interface, the static BFD session does not monitor any interfaces. A static BFD session can monitor the following interfaces:
· Layer 3 Ethernet interfaces and their subinterfaces.
· Layer 3 aggregate interfaces and their subinterfaces and member ports.
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see Track in High Availability Configuration Guide.
Mechanism of selecting the source and destination IP addresses for BFD packets
For a static BFD session in control packet mode, the source IP address of BFD packets is the IP address specified for the source-ip/source-ipv6 keyword, and the destination IP address is the IP address specified for the peer-ip/peer-ipv6 keyword. Without the source-ip/source-ipv6 keyword specified, the device selects the source IP address for sending BFD packets in the following order:
1. The device looks up its its local routing table to search for a route to the IP address or IPv6 address specified with the peer-ip/peer-ipv6 keyword. It selects the output interface IP address of that route as the source IP address for BFD packets.
2. If you edit the IP address of the output interface after the static BFD session is configured, whether the device updates the source IP address for BFD packets depends on the phase of the session:
¡ If the BFD session is in negotiation phase, the device updates the source IP address for BFD packets.
¡ If the BFD session is in detection phase, the device does not update the source IP address for BFD packets.
3. If the network-slice command is executed in static BFD session view, the device selects the network slicing address. If the network slicing address is invalid, the device cannot send BFD packets.
For a static BFD session in echo packet mode, the source IP address of BFD packets is the IP address specified for the source-ip/source-ipv6 keyword, and the destination IP address is the IP address specified for the destination-ip/destination-ipv6 keyword. Without the source-ip/source-ipv6 or bfd echo-source-ip/bfd echo-source-ipv6 keyword specified, the device uses the IPv4 or IPv6 address specified for the destination-ip/destination-ipv6 keyword as the source IPv4 or IPv6 address of echo packets.
Recommended configuration for data link layer connectivity detection
To detect data link layer connectivity, execute the following command:
· bfd static session-name peer-ip default-ip interface interface-type interface-number source-ip ip-address discriminator local discr-value remote discr-value
Specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address. An interface can use only one static BFD session to detect data link layer connectivity.
Recommended configuration for a VPN VPWS dual-homed network
In a VPN VPWS dual-homed network, when the AC of a DF fails, the BDF cannot quickly detect the failure to take over. To solve this problem, you can configure a static BFD session on the DF to monitor the AC state and execute the evpn track bfd command on the BDF. The takeover process occurs as follows:
1. When the AC of the DF fails, the DF sets the static BFD session to the down state and notifies the BDF.
2. The BDF quickly takes over as the DF, which minimizes packet loss.
For more information about EVPN VPWS networking and DF election, see EVPN VPWS configuration in EVPN Configuration Guide.
Recommended configuration for selecting a card to maintain BFD sessions
After a BFD session comes up, the device automatically selects a card to periodically send BFD packets and maintain BFD session state. To preferentially select a card for maintaining BFD sessions, specify the select-board option when you configure this command. For the configuration to take effect, make sure the specified card is installed.
If a static BFD session in control packet mode is created on the peer device, you must use this command to create a static BFD session on the local device. The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd static abc peer-ip 20.1.1.1 vpn-instance vpn1 source-ip 20.1.1.2 discriminator local 513 remote 514 on the local device, you must configure bfd static bcd peer-ip 20.1.1.2 vpn-instance vpn1 source-ip 20.1.1.1 discriminator local 514 remote 513 on the peer device.
When creating a static BFD session, you must specify a peer IP address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
The bfd static session-name command without any parameters specified can only be used to enter the view of an existing static BFD session.
If you do not specify the local discriminator or remote discriminator when creating a static BFD session, you must perform either of the following tasks for the BFD session to take effect:
· Use the discriminator command to specify the local discriminator and remote discriminator for the static BFD session.
· Execute the undo bfd static command and then execute the bfd static command to re-create the static BFD session with the local and remote discriminators specified.
You need to create a static BFD session on only the local device if you use the echo packet mode for detection. As a best practice, specify the source IP address for echo packets when creating a static BFD session. Make sure the specified source IP address does not belong to the subnet where a local interface resides. Without a source IP address specified, the device uses the IP address specified in the bfd echo-source-ip or bfd echo-source-ipv6 command as the source IP address of echo packets.
To use a static BFD session in control packet mode for single-hop detection, you must perform the following configuration:
· Specify the IP address of the peer interface for the peer-ip/peer-ipv6 keyword.
· Specify the IP address of the local interface for the source-ip/source-ipv6 keyword.
If you specify an interface, make sure the following requirements are met for the static BFD session to be successfully established:
· The IP address of the peer interface where the static BFD session resides is used as the peer IP address.
· The IP address of the local interface where the static BFD session resides is used as the source IP address.
To modify a static BFD session, delete the static BFD session and then configure a new static BFD session.
Different static BFD sessions cannot have the same local discriminator.
# Create a static BFD session and enter its view. The static BFD session detects the path between 1.1.1.1 and 1.1.1.2 and uses GigabitEthernet 1/0/6 to send BFD packets with source IP address 1.1.1.1 and destination IP address is 1.1.1.2. The local discriminator is 1537, and the remote discriminator is 2048.
[Sysname] bfd static abc peer-ip 1.1.1.2 interface gigabitethernet 1/0/6 source-ip 1.1.1.1 discriminator local 1537 remote 2048
# Create a static BFD session in echo mode and enter its view. The static BFD session detects the path between 1.1.1.1 and 1.1.1.2 and uses GigabitEthernet 1/0/6 to send BFD packets with source IP address 9.9.9.9 and destination IP address is 1.1.1.2.
[Sysname] bfd static abc peer-ip 1.1.1.1 interface gigabitethernet 1/0/6 destination-ip 1.1.1.2 source-ip 9.9.9.9 one-arm-echo discriminator auto
bfd echo-source-ip
discriminator
evpn track bfd (EVPN Command Reference)
network slice (Segment Routing Command Reference)
track bfd (High Availability Command Reference)
bfd template
Use bfd template to create a BFD template and enter its view, or enter the view of an existing BFD template.
Use undo bfd template to delete the BFD template.
bfd template template-name
undo bfd template template-name
No BFD templates exist.
template-name: Specifies the template name, a case-sensitive string of 1 to 63 characters.
# Create BFD template bfd1 and enter BFD template view.
discriminator
Use discriminator to specify the local and remote discriminators for a static BFD session.
Use undo discriminator to remove the local and remote discriminator for the static BFD session.
discriminator { local local-value | remote remote-value }
undo discriminator { local local-value | remote remote-value }
No local and remote discriminators are specified for a static BFD session..
Use this command only if you do not specify the local or remote discriminator when creating a static BFD session.
To modify the local or remote discriminator of a static BFD session, execute the undo discriminator and then the discriminator command to specify a new local or remote discriminator.
# Create local discriminator 1537 and remote discriminator 2048 for static BFD session abc.
[Sysname-bfd-static-session-abc] discriminator local 1537
[Sysname-bfd-static-session-abc] discriminator remote 2048
bfd static
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator local local-value | static name session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw | srv6-policy ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
discriminator local local-value: Specifies a BFD session by its local discriminator in the range of 1 to 4294967295.
static name session-name: Specifies a static BFD session by its name, a case-sensitive string of 1 to 64 characters.
dynamic: Specifies dynamic BFD sessions.
static: Specifies static BFD sessions.
control: Specifies BFD sessions in control packet mode.
echo: Specifies BFD sessions in echo mode.
ip: Specifies BFD sessions used to detect IPv4 links.
ipv6: Specifies BFD sessions used to detect IPv6 links.
lsp: Specifies BFD sessions used to detect MPLS LSPs.
te: Specifies BFD sessions used to detect MPLS TE tunnels.
pw: Specifies BFD sessions used to detect PWs.
srv6-policy: Specifies BFD sessions used to detect SRv6 policies.
state: Displays BFD sessions by session state.
down: Specifies BFD sessions in Down state.
admin-down: Specifies BFD sessions in AdminDown state.
init: Specifies BFD sessions in Init state.
up: Specifies BFD sessions in Up state.
discriminator remote remote-value: Specifies a BFD session by its remote discriminator in the range of 1 to 4294967295.
peer-ip ipv4-address: Specifies a BFD session by the peer IPv4 address in dotted decimal notation.
peer-ipv6 ipv6-address: Specifies a BFD session by the peer IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays the BFD sessions of the public network.
verbose: Displays detailed BFD session information.
If you do not specify the dynamic or static keyword, this command displays all dynamic and static BFD sessions.
# Display brief information about all BFD sessions.
<Sysname> display bfd session
Total sessions: 10 Up sessions: 10 Init mode: Active
513/513 1.1.1.1 1.1.1.2 Up 2297ms GE1/0/6
IPv6 session working in control packet mode:
Local discr: 513 Remote discr: 513
Source IP: FE80::20C:29FF:FED4:7171
Destination IP: FE80::20C:29FF:FE72:AC4D
Session state: Up Interface: GE1/0/7
Hold time: 2142ms
MPLS LSP session working in control packet mode:
32773/32770 1.1.1.9 3.3.3.9 Up 0ms N/A
IPv6 SR session working in echo mode:
Local discr: 2049
Session state: Up Interface: Tun1
Hold time: 2142ms
IPv6 SR policy session working in echo mode:
Local discr: 33793
Source IP: 1::1
Destination IP: 4::4
Session state: Up Interface: GE1/0/6
Hold time: 2357ms
IPv4 static session working in control packet mode:
1600/1600 1.1.1.1 1.1.1.2 Up 2290ms GE1/0/6
IPv6 static session working in control packet mode:
Local discr: 1700 Remote discr: 1700
Hold time: 2142ms
MPLS TE session working in control packet mode:
2050/2050 1.1.1.1 127.0.0.1 Up 2458ms N/A
MPLS TE session working in echo mode:
LD SourceAddr DestAddr State Holdtime Interface
2051 1.1.1.1 3.3.3.3 Up 4851ms Tun2
MPLS PW session working in control packet mode:
20481/20481 2.2.2.2 127.0.0.1 Up 2489ms N/A
Total sessions |
Total number of BFD sessions. |
Up sessions |
Total number of active BFD sessions. |
Init mode |
BFD operating mode: Active or passive. |
XX session working in yy mode |
BFD session type and operating mode: · IPv4 session working in control packet mode. · IPv4 session working in echo mode. · IPv6 session working in control packet mode. · IPv6 session working in echo mode. · MPLS LSP session working in control packet mode—BFD session in control packet mode used to detect failures in an LSP. · MPLS LSP session working in echo mode—BFD session in echo mode used to detect failures in an LSP. · IPv6 SR session working in echo mode—BFD session in echo mode used to detect failures in an SRv6 tunnel. · IPv4 static session working in control packet mode. · IPv6 static session working in control packet mode. · MPLS TE session working in control packet mode. · MPLS TE session working in echo mode. · MPLS PW session working in control packet mode. · IPv6 SR policy session working in echo mode—BFD session in echo mode used to detect SRv6 policies. |
LD/RD |
Local discriminator/Remote discriminator of the session. |
SourceAddr |
Source IPv4 address of the session. |
DestAddr |
Destination IPv4 address of the session. |
State |
Session state: Down, Init, AdmDown, or Up. |
Holdtime |
Length of time before session detection timer expires. For a BFD session in Down state, this field displays 0ms. |
Name of the interface of the session. |
Local discr |
Local discriminator of the session. |
Remote discr |
Source IP |
Source IPv6 address of the session. This field displays N/A if you do not configure the source IP address. |
Destination IP |
Destination IPv6 address of the session. |
Session state |
Session state: Down, AdmDown, Init, or Up. |
Hold time |
# Display detailed information about all BFD sessions.
<Sysname> display bfd session verbose
Total sessions: 9 Up sessions: 9 Init mode: Active
Source IP: 1.1.1.1 Destination IP: 1.1.1.2
Destination port: 3784 Session state: Up
Interface: GigabitEthernet1/0/6
Min Tx interval: 500ms Actual Tx interval: 500ms
Min Rx interval: 500ms Detection time: 2500ms
Rx count: 42 Tx count: 43
Connection type: Direct Up duration: 00:00:20
Hold time: 2078ms Auth mode: None
Detection mode: Async Slot: 1
Protocol: OSPF
Version: 1
Diag info: No Diagnostic
Hardware mode: Disable
Interface: GigabitEthernet1/0/7
Rx count: 38 Tx count: 38
Connection type: Direct Up duration: 00:00:15
Hold time: 2211ms Auth mode: None
Protocol: OSPFv3
Version: 1
Local discr: 32774 Remote discr: 32770
Source IP: 1.1.1.9 Destination IP: 3.3.3.9
Destination port: 4784 Session state: Up
Interface: N/A
Min Tx interval: 1000ms Actual Tx interval: 3000ms
Min Rx interval: 1000ms Detection time: 150000ms
Rx count: 1 Tx count: 13
Connection type: Indirect Up duration: 00:00:36
Hold time: 149536ms Auth mode: None
Protocol: MPLS_LSPV
Version: 1
Local discr: 2049
Destination port: 3785 Session state: Up
Interface: Tunnel1
Hold time: 2049ms Actual Tx interval: 500ms
Rx count: 7065 Tx count: 7065
Connection type: Indirect Up duration: 00:50:08
Protocol: SRv6
Version: 1
Session name: abc
Local discr: 310 Remote discr: 308
Source IP: 12.1.1.1 Destination IP: 12.1.1.2
Min Tx interval: 1000ms Actual Tx interval: 1000ms
Min Rx interval: 1000ms Detection time: 5000ms
Rx count: 59 Tx count: 1003
Connection type: Direct Up duration: 00:19:26
Hold time: 4426ms Auth mode: None
Protocol: STATIC_IPv4
Version: 1
Session name: bbbb
Protocol: STATIC_IPv6
Version: 1
MPLS TE Session working in control packet mode:
Local discr: 2050 Remote discr: 2050
Source IP: 1.1.1.1 Destination IP: 127.0.0.1
Interface: N/A
Rx count: 72 Tx count: 73
Connection type: Indirect Up duration: 00:00:30
Hold time: 2458ms Auth mode: None
Protocol: MPLS_LSPV
Version: 1
Local discr: 2051
Source IP: 1.1.1.1 Destination IP: 3.3.3.3
Interface: Tunnel2
Hold time: 4851ms Actual Tx interval: 1000ms
Rx count: 9083 Tx count: 9637
Connection type: Indirect Up duration: 02:20:42
Protocol: MPLS_LSPV
Version: 1
Diag info: No Diagnostics
Local discr: 20481 Remote discr: 20481
Source IP: 2.2.2.2 Destination IP: 127.0.0.1
Interface: N/A
Hold time: 2489ms Auth mode: None
Protocol: MPLS_LSPV
Version: 1
Table 5 Command output
Total sessions |
Up sessions |
Init mode |
BFD session type and operating mode: · IPv4 session working in control packet mode. · IPv4 session working in echo mode. · IPv6 session working in control packet mode. · IPv6 session working in echo mode. · MPLS LSP session working in control packet mode—BFD session in control packet mode used to detect failures in an LSP. · MPLS LSP session working in echo mode—BFD session in echo mode used to detect failures in an LSP. · IPv6 SR session working in echo mode—BFD session in echo mode used to detect failures in an SRv6 tunnel. · IPv4 static session working in control packet mode. · IPv6 static session working in control packet mode. · MPLS TE session working in control packet mode. · MPLS TE session working in echo mode. · MPLS PW session working in control packet mode. |
Local discr |
Remote discr |
Source IP |
Source IP address of the session. This field displays N/A if you do not configure the source IP address. |
Destination IP |
Destination IP address of the session. |
Destination port |
Destination port number in BFD packets defined in Comware: · The destination port number in single-hop BFD control packets is 3784. · The destination port number in single-hop or multihop BFD echo packets is 3785. · The destination port number in multihop BFD control packets is 4784. · The destination port number in BFD control packets for association between link aggregation and BFD is 6784. The device uses the destination port number in incoming packets that are not defined in Comware as the destination port number in outgoing BFD packets. |
Session state |
Min Tx interval |
Minimum transmit interval. |
Min Rx interval |
Minimum receive interval. |
Actual Tx interval |
Actual transmit interval. If BFD session negotiation delay is configured, this field displays a hyphen (-) before the delay timer expires. |
Detection time |
Actual session detection timer. |
Rx count |
Number of packets received. |
Tx count |
Number of packets sent. |
Hold time |
Length of time before session detection timer expires. For a BFD session in down state, this field displays 0ms. |
Auth mode |
Session authentication mode. |
Connection type |
Connection type of the interface: Direct or Indirect. |
Up duration |
Time period for which the session has been up. |
Detection mode |
Detection mode: · Async—Asynchronous mode. · Async/Echo—Asynchronous mode with echo detection enabled. |
Slot |
Slot number of the device. |
Remaining delay time |
Remaining time of the delay timer, in seconds. If BFD session negotiation delay is not configured or the delay timer has expired, this field is not displayed. |
Protocol |
Protocol associated with BFD: · OSPF. · ISIS_BR_L1—IS-IS with the network type as broadcast and the router type as Level 1. · ISIS_BR_L2—IS-IS with the network type as broadcast and the router type as Level 2. · ISIS_P2P—IS-IS with the network type as P2P. · ISIS6_BR_L1—IPv6 IS-IS with the network type as broadcast and the router type as Level 1. · ISIS6_BR_L2—IPv6 IS-IS with the network type as broadcast and the router type as Level 2. · ISIS6_P2P—IPv6 IS-IS with the network type as P2P. · BGP. · MPLS_RSVP. · STATIC4—IPv4 static routing. · TRACK—Track. · IPFRR—FIB IP FRR. · MAD. · MPLS_LSPV. · OSPFv3. · BGP4+. · PIM. · PIM6—IPv6 PIM. · STATIC6—IPv6 static routing. · Interface—Interface state. · TUNNEL. · LAGG—Link aggregation. · SRv6. · STATIC_IPv4—IPv4 static BFD session. · STATIC_IPv6—IPv6 static BFD session. |
Diag info |
Diagnostic information about the session: · No Diagnostic. · Control Detection Time Expired—A control-mode BFD session goes down because local detection times out. · Echo Function Failed—An echo-mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted. · Neighbor Signaled Session Down—The remote end notifies the local end of BFD session down. · Administratively Down—The local system prevents a BFD session from being established. · Dampening Down (Remaining time: XXs)—A BFD session is suppressed within the specified interval. Remaining time is the remaining suppression time in seconds. |
Hardware mode |
Mode in which BFD packets are processed in hardware: · Enabled. · Disable—BFD packets are processed in software. |
Encapsulation mode |
Mode in which BFD packets for SRv6 TE policy detection are encapsulated. · Encaps—Normal encapsulation. · Insert—Insert encapsulation. |
Tracked interface |
Interface monitored by the static BFD session. |
bfd static
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd
Use snmp-agent trap enable bfd to enable SNMP notifications for BFD.
Use undo snmp-agent trap enable bfd to disable SNMP notifications for BFD.
All SNMP notifications are enabled for BFD.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for BFD.
[Sysname] undo snmp-agent trap enable bfd
SBFD commands
Use bfd detect-multiplier to set the SBFD detection time multiplier in BFD template view.
The SBFD detection time multiplier is 3.
Interface view
BFD template view
The detection time multiplier determines the maximum number of SBFD control packets that an initiator can discard continuously.
The detection time is the detection time multiplier of the initiator multiplied by the minimum SBFD packet sending interval of the initiator.
# In BFD template abc, set the detection time multiplier to 6.
[Sysname] bfd template abc
[Sysname-bfd-template-abc] bfd detect-multiplier 6
Use bfd min-echo-receive-interval to set the minimum interval for receiving SBFD echo packets.
The minimum interval for receiving SBFD echo packets is 1000 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for receiving SBFD echo packets, in milliseconds. The value takes 0 or is in the range of 3 to 1000. The value 0 indicates that the device does not receive SBFD echo packets.
This command sets the SBFD echo packet receiving interval, which is the actual SBFD echo packet sending interval.
# Set the minimum interval for receiving SBFD echo packets to 500 milliseconds on GigabitEthernet 1/0/6.
[Sysname] interface gigabitethernet 1/0/6
Use bfd min-transmit-interval to set the minimum interval for transmitting SBFD control packets in BFD template view.
The minimum interval for transmitting SBFD control packets is 10 milliseconds.
BFD template view
interval: Specifies the minimum interval for transmitting SBFD control packets, in milliseconds. The value range is 3 to 1000.
Use this command to prevent the SBFD control packet sending rate from exceeding the device capability.
The actual SBFD control packet transmitting interval is the set minimum interval.
# In BFD template abc, set the minimum interval for transmitting SBFD control packets to 500 milliseconds.
[Sysname-bfd-template-abc] bfd min-transmit-interval 500
Use bfd multi-hop detect-multiplier to set the SBFD detection time multiplier in system view.
# Set the detection time multiplier to 6.
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting SBFD control packets in system view.
# Set the minimum interval for transmitting SBFD control packets to 500 milliseconds.
Use bfd session-negotiation delay-upon-down to enable session negotiation delay for down SBFD sessions and set a delay timer.
Session negotiation delay is disabled for down SBFD sessions.
If an upper-layer protocol uses SBFD to detect the active path, an active/standby path switchover is triggered after the active path goes down. If the SBFD session comes up before the active path recovers, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur.
The session negotiation delay function starts a delay timer for each SBFD session from up to down state and each newly created session. Before the timer expires, the device does not perform session negotiation on each SBFD session. The delay timer allows the active path to recover completely before the SBFD session comes up again.
# Enable session negotiation delay for down SBFD sessions and set the delay timer to 6 seconds.
display bfd session
Use bfd session-negotiation delay-upon-reboot to enable SBFD session negotiation delay upon a device reboot and set a delay timer.
SBFD session negotiation delay upon a device reboot is disabled.
If an upper-layer protocol uses SBFD to detect the active path, an active/standby path switchover is triggered upon a device reboot. If the SBFD session comes up after a device reboot, the traffic on the standby path will be switched over to the active path. In this case, traffic loss will occur if the active path of the upper-layer protocol has not recovered completely.
The session negotiation delay function starts a delay timer when the device reboots successfully. Before this timer expires, the device does not perform session negotiation on SBFD sessions in down state or newly created sessions. The delay timer allows the active path to recover completely before the SBFD session comes up again.
# Enable SBFD session negotiation delay upon a device reboot and set the delay timer to 6 seconds.
display bfd session
bfd template
[Sysname] bfd template bfd1
display sbfd session
Use display sbfd session to display SBFD session information.
display sbfd session { initiator [ discriminator value | [ ipv6 [ peer-ipv6 ipv6-address ] | srv6-policy ] [ verbose ] | verbose ] | reflector [ discriminator value | verbose ] }
initiator: Displays SBFD session information for the initiator.
reflector: Displays SBFD session information for the reflector.
discriminator value: Specifies an SBFD session by its local discriminator in the range of 1 to 4294967295.
ipv6: Specifies SBFD sessions used to detect IPv6 links.
peer-ipv6 ipv6-address: Specifies an SBFD session by the peer IPv6 address.
srv6-policy: Displays SBFD sessions used to detect SRv6 TE policies.
verbose: Displays detailed information about all SBFD sessions. If you do not specify this keyword, this command displays brief SBFD session information.
If you do not specify the discriminator or verbose keyword, this command displays brief information about all SBFD sessions.
# Display brief information about all SBFD sessions for the initiator.
<Sysname> display sbfd session initiator
Total sessions: 2 Up sessions: 2
SBFD session (MPLS LSP):
Local discr: 32770 Remote discr: 1000001
Session state: Up Hold time: 2184ms
SBFD session (SRv6 PLY):
Local discr: 33794 Remote discr: 1000001
Source IP: 15::15
Destination IP: 3::3
Session state: Up Hold time: 4201ms
Table 6 Command output
Total sessions |
Total number of SBFD sessions. |
Up sessions |
Number of active SBFD sessions. |
SBFD session (xxx) |
Path type detected by the SBFD session: · MPLS LSP. · SRv6 PLY—SRv6 TE policy. · IPv6—IPv6 link. |
Local discr |
Remote discr |
Source IP |
Source IP address of the session. |
Destination IP |
Session state |
Session state: Down or Up. |
Hold time |
Length of time before the session detection timer expires, in milliseconds. For an SBFD session in Down state, this field displays 0ms. |
# Display detailed information about the SBFD session with local discriminator 32770 for the initiator.
<Sysname> display sbfd session initiator discriminator 32770
Local discr: 32770 Remote discr: 1000002
Session state: Up Hold time: 4130ms
Detection time: 5000ms Up duration: 00:01:18
Rx count: 1 Tx count: 78
Slot: 1
Protocol: MPLS_LSPV
Template name: temmpls
Table 7 Command output
Local discr |
Remote discr |
Source IP |
Destination IP |
Session state |
Hold time |
Color |
Color attribute value of the SRv6 TE policy. |
NID |
Forwarding entry index of the SID list of the SRv6 TE policy. |
Min Tx interval |
Minimum SBFD packet transmission interval in milliseconds. |
Actual SBFD packet transmission interval in milliseconds. If SBFD session negotiation delay is configured, this field displays a hyphen (-) before the delay timer expires. |
Detection time |
Actual session detection timer in milliseconds. |
Up duration |
Rx count |
Tx count |
Slot |
Remaining time of the delay timer, in seconds. If SBFD session negotiation delay is not configured or the delay timer has expired, this field is not displayed. |
Diag info |
Diagnostic information about the session: · No Diagnostic. · Control Detection Time Expired—The SBFD session goes down because local detection times out. · Neighbor Signaled Session Down—The remote end notifies the local end of SBFD session down. |
Template name |
Template associated with the session. If no template is associated, this field is not displayed. |
Hardware mode |
Mode in which SBFD packets are processed in hardware: · Enabled. · Disable—SBFD packets are processed in software. |
Mode in which SBFD packets for SRv6 TE policy detection are encapsulated. · Encaps—Normal encapsulation. · Insert—Insert encapsulation. |
# Display detailed information about all SBFD sessions for the initiator.
<Sysname> display sbfd session initiator verbose
Detection time: 5000ms Up duration: 00:01:19
Rx count: 1 Tx count: 79
Slot: 1
Protocol: MPLS_LSPV
Template name: abc
Source IP: 15::15
Color: 10 NID: 2149580802
Detection time: 5000ms Up duration: 00:22:43
Rx count: 232 Tx count: 242
Slot: 1
Protocol: SRv6PLY
Table 8 Command output
Total sessions |
Up sessions |
Local discr |
Remote discr |
Source IP |
Destination IP |
Session state |
Hold time |
Color |
NID |
Min Tx interval |
Minimum SBFD packet transmission interval. |
Actual SBFD packet transmission interval. If SBFD session negotiation delay is configured, this field displays a hyphen (-) before the delay timer expires. |
Detection time |
Up duration |
Rx count |
Tx count |
Slot |
Protocol |
Protocol associated with SBFD: · MPLS_LSPV—LSP. · SRv6PLY—SRv6 TE policy. |
Diag info |
Template name |
Hardware mode |
# Display brief information about all SBFD sessions for the reflector.
<Sysname> display sbfd session reflector
Local discriminator 1000001 on slot 1
Configured mode: Explicit Value
Total sessions: 1
Local discr: 1000001 Remote discr: 32770
Source IP: 3.2.1.2 Destination IP: 1.1.1.1
Hold time: 29296ms VRF name: -
Local discriminator 1234567 on slot 1
Total sessions: 1
Local discr: 1234567 Remote discr: 33793
Source IP: 2::22
Destination IP: 100::1
Hold time: 29678ms VRF name: -
Table 9 Command output
Configured mode |
Discriminator type: · IP Address—IPv4 address. · Explicit Value—Integer. |
Total sessions |
Local discr |
Remote discr |
Source IP |
Destination IP |
Hold time |
VRF name |
VPN instance bound to the interface where the packets of the SBFD session are received. If no VPN instance is bound to the interface, this field displays a hyphen (-). |
# Display detailed information about the SBFD session with local discriminator 1000001 for the reflector.
<Sysname> display sbfd session reflector discriminator 1000001
Configured mode: IP Address
Total sessions: 1
Min Tx interval: 1000ms Min Rx interval: 10ms
Detect multi: 5 Up duration: 00:16:51
Rx count: 967 Tx count: 967
Max Rx period: 3008ms Max Tx period: 1000us
Hold time: 29374ms
VRF name: -
# Display detailed information about the SBFD session with local discriminator 1234567 for the reflector.
<Sysname> display sbfd session reflector discriminator 1234567
Total sessions: 1
Source IP: 2::22
Min Tx interval: 500ms Min Rx interval: 10ms
Detect multi: 5 Up duration: 05:35:20
Rx count: 46371 Tx count: 46371
Max Rx period: 611ms Max Tx period: 2000us
Hold time: 29622ms
VRF name: -
Table 10 Command output
Configured mode |
Total sessions |
Local discr |
Remote discr |
Source IP |
Destination IP |
Min Tx interval |
Minimum transmission interval of incoming SBFD packets. |
Min Rx interval |
Minimum SBFD packet receiving interval. |
Detect multi |
Session detection time multiplier carried in incoming SBFD packets. |
Up duration |
Rx count |
Tx count |
Max Rx period |
Maximum SBFD packet receiving interval in milliseconds. |
Max Tx period |
Maximum response packet transmission interval, in microseconds. |
Hold time |
VRF name |
Hardware mode |
sbfd local-discriminator
sbfd destination ipv4 remote-discriminator
Use sbfd destination ipv4 remote-discriminator to associate the destination IPv4 address of the detected path with the remote discriminator of the SBFD session for the initiator.
Use undo sbfd destination ipv4 to cancel the association between the destination IPv4 address of the detected path and the remote discriminator of the SBFD session for the initiator.
sbfd destination ipv4 destination-ipv4-address remote-discriminator { ipv4-address | integer-value }
undo sbfd destination ipv4 destination-ipv4-address
The destination IPv4 address of the detected path is not associated with the remote discriminator of the SBFD session for the initiator.
destination-ipv4-address: Specifies a valid unicast IPv4 address as the destination IPv4 address of the detected path.
ipv4-address: Specifies a valid unicast IPv4 address as the remote discriminator.
integer-value: Specifies an integer as the remote discriminator. The value range for this argument is 1 to 4294967295.
This command allows you to use the specified remote discriminator for an SBFD session to detect an LSP, MPLS TE tunnel, or SR-MPLS TE policy.
The initiator selects a remote discriminator for an SBFD session as follows:
1. Selects the remote discriminator of the SBFD session used for path connectivity detection. For example, the remote discriminator of the SBFD session specified in the mpls sbfd command.
2. Selects the remote discriminator specified in this command.
3. Selects the destination IPv4 address of the detected path. For example, when you use SBFD to detect an SR-MPLS TE policy, the endpoint address is used as the remote discriminator of the SBFD session.
You can execute this command repeatedly to configure multiple associations between destination IPv4 addresses and remote discriminators for the initiator.
When configuring or canceling an association, the SBFD session might flap if it is in up state.
# Associate destination IPv4 address 22.22.2.2/32 of the detected LSP with remote discriminator 1.1.1.1 of the SBFD session for the initiator.
[Sysname] mpls bfd enable
[Sysname] mpls sbfd 22.22.2.2 32
[Sysname] sbfd destination ipv4 22.22.2.2 remote-discriminator 1.1.1.1
mpls bfd (MPLS Command Reference)
sbfd (Segment Routing Command Reference)
sr-policy sbfd enable (Segment Routing Command Reference)
sbfd destination ipv6 remote-discriminator
Use sbfd destination ipv6 remote-discriminator to associate the destination IPv6 address of the detected path with the remote discriminator of the SBFD session for the initiator.
Use undo sbfd destination ipv6 to cancel the association between the destination IPv6 address of the detected path and the remote discriminator of the SBFD session for the initiator.
sbfd destination ipv6 destination-ipv6-address remote-discriminator { ipv4-address | integer-value }
undo sbfd destination ipv6 destination-ipv6-address
The destination IPv6 address of the detected path is not associated with the remote discriminator of the SBFD session for the initiator.
destination-ipv6-address: Specifies a valid global unicast IPv6 address as the destination IPv6 address of the detected path.
This command allows you to use the specified remote discriminator for an SBFD session to detect an SRv6 TE policy.
4. Selects the remote discriminator of the SBFD session used for SRv6 TE policy connectivity detection.
5. Selects the remote discriminator specified in this command.
If you do not specify the remote discriminator for SBFD to detect an SRv6 TE policy, the SBFD session cannot be established.
When the peer CE is dual-homed to two PEs in public network IP over SRv6 BE, IP L3VPN over SRv6 BE, or EVPN L3VPN over SRv6 BE, the local PE generates a primary path and a backup path after you enable FRR on it. To quickly detect failures and forward traffic through the backup path when the primary path fails, you can configure SBFD to detect the SRv6 locator route advertised through BGP by the peer PE. For this function to take effect, perform the following tasks:
· Execute the sbfd destination ipv6 remote-discriminator command on the local PE to specify the remote discriminator for an SBFD session to detect the SRv6 locator.
· Execute the sbfd local-discriminator command on the peer PE of the primary path to specify the local discriminator for the reflector.
· Make sure the remote discriminator on the local PE is consistent with the local discriminator on the peer PE.
You can execute this command repeatedly to configure multiple associations between destination IPv6 addresses and remote discriminators for the initiator.
# Enable SBFD for all SRv6 TE policies, and associate destination IPv6 address 10::1 of the SRv6 TE policy with remote discriminator 1.1.1.1 of the SBFD session for the initiator.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] srv6-policy sbfd
[Sysname-srv6-te] quit
[Sysname-segment-routing-ipv6] quit
[Sysname] sbfd destination ipv6 10::1 remote-discriminator 1.1.1.1
locator-sbfd enable (Segment Routing Command Reference)
srv6-policy sbfd (Segment Routing Command Reference)
Use sbfd local-discriminator to set the local discriminator for the reflector.
Use undo sbfd local-discriminator to remove the local discriminator setting for the reflector.
sbfd local-discriminator { ipv4-address | integer-value }
undo sbfd local-discriminator { ipv4-address | integer-value }
No local discriminator is set for the reflector.
ipv4-address: Specifies a valid unicast IPv4 address as the local discriminator.
integer-value: Specifies an integer as the local discriminator. The value range for this argument is 200000 to 260000.
In a BFD session, both ends periodically send BFD packets to detect bidirectional forwarding path failures. SBFD is a unidirectional failure detection mechanism that provides shorter detection time than BFD. SBFD is used in scenarios where only one end of a link requires failure detection, such as MPLS TE tunnel establishment through static SRLSP.
An SBFD session involves the following roles:
· Initiator—Periodically sends SBFD control packets to detect connectivity to remote entities. An initiator initiates SBFD sessions and maintains SBFD session state.
· Reflector—Listens for incoming SBFD control packets on local entities and replies with response SBFD control packets.
The remote discriminator in SBFD control packets sent by the initiator must be specified in the sbfd local-discriminator command. Otherwise, the reflector does not reply with response SBFD control packets.
You can execute this command multiple times to configure multiple local discriminators.
As a best practice to avoid affecting packet processing performance, configure no more than 1000 SBFD reflectors.
A node can act as the initiator of one session and the reflector of another session at the same time.
# Specify 1.1.1.1 as the local discriminator for the reflector.
[Sysname] sbfd local-discriminator 1.1.1.1
# Specify 1000001 as the local discriminator for the reflector.
[Sysname] sbfd local-discriminator 1000001
sbfd source-ipv6
Use sbfd source-ipv6 to specify the source IPv6 address used by the initiator to send SBFD control packets.
Use undo sbfd source-ipv6 to restore the default.
sbfd source-ipv6 ipv6-address
No source IPv6 address is specified for SBFD control packets.
ipv6-address: Specifies a unicast IPv6 address.
To use SBFD to detect the connectivity of forwarding paths in an SRv6 TE policy or SRv6 BE, you must execute this command on the initiator. In addition, a route to the specified IPv6 address must exist on the reflector.
# Specify 80::2 as the source IPv6 address for SBFD control packets.
[Sysname] sbfd source-ipv6 80::2
