H3C UniServer R4950 G6 Server User Guide-6W104
HomeSupportServersH3C UniServer R4950 G6Install & UpgradeInstallation GuidesH3C UniServer R4950 G6 Server User Guide-6W104
02-Appendix
02-Appendix 8.18 MB
Appendix A  Server specifications· 1
Server models and chassis view· 1
Technical specifications· 2
Components· 3
Front panel 5
Front panel view of the server 5
LEDs and buttons· 7
Ports· 9
Rear panel 10
Rear panel view· 10
LEDs· 12
Ports· 13
System board· 14
System board components· 14
System maintenance switch· 16
DIMM slots· 17
Appendix B  Component specifications· 18
About component model names· 18
DIMMs· 18
DRAM DIMM rank classification label 18
HDDs and SSDs· 19
Drive numbering· 19
Drive LEDs· 20
Drive configurations· 21
Drive backplanes· 22
Front 8SFF SAS/SATA drive backplane· 22
Front 8SFF UniBay drive backplane· 22
Front 8LFF SAS/SATA drive backplane· 23
Front 12LFF SAS/SATA drive backplane· 24
Front 8SAS/SATA+4UniBay drive backplane· 24
Front 4SAS/SATA+8UniBay drive backplane· 25
Front 12LFF UniBay drive backplane· 25
Front 8LFF UniBay drive backplane· 26
Front 17SAS/SATA+8UniBay drive backplane· 27
Mid 4LFF SAS/SATA drive backplane· 27
Rear 2LFF SAS/SATA drive backplane· 28
Rear 4LFF SAS/SATA drive backplane· 28
Rear 2SFF SAS/SATA drive backplane· 29
Rear 2SFF UniBay drive backplane· 29
Rear 4SFF SAS/SATA drive backplane· 30
Rear 4SFF UniBay drive backplane· 30
Riser cards· 31
Riser card guidelines· 31
RC-3FHFL-2U-G6· 31
RC-3FHFL-2U-G6-1· 33
RC-3FHHL-2U-G6· 34
RC-2FHFL-2U-LC-G6· 36
PCA-R4900-4GPU-G6· 37
Riser 4 assembly module (accommodating two FHFL PCIe modules) 38
Riser 4 assembly module (accommodating two HHHL PCIe modules) 39
Riser 3 assembly module (accommodating two HHHL PCIe modules) 39
Fan modules· 40
LCD smart management module· 40
M.2 expander module· 41
M.2 storage controller 42
Server management module· 42
Serial & DSD module· 43
B/D/F information· 44
Appendix C  Managed removal of OCP network adapters· 45
Before you begin· 45
Performing a hot removal 45
Appendix D  Environment requirements· 47
About environment requirements· 47
General environment requirements· 47
Operating temperature requirements· 47
Operating temperature requirements without liquid-cooled module· 47
Operating temperature requirements with liquid-cooled module· 49
Appendix E  Product recycling· 50
Appendix F  Glossary· 51
Appendix G  Acronyms· 52
The information in this document might differ from your product if it contains custom configuration options or features.
Figures in this document are for illustration only.
H3C UniServer R4950 G6 servers are 2U dual-processor servers independently developed by H3C based on the new-generation processor Genoa of AMD EPYC. The servers are suitable for cloud computing, distributed storage, and video storage services of enterprise basics and telecommunication applications. The servers have the characteristics of high computing performance, large storage capacity, low power consumption, strong scalability, high reliability, and ease of management and deployment.
Figure 1 Chassis view
The servers come in the models listed in Table 1. These models support different drive configurations. For more information about drive configuration and compatible storage controller configuration, see H3C UniServer R4950 G6 Server Drive Configurations and Cabling Solutions.
Table 1 R4950 G6 server models
Model
Maximum drive configuration
LFF
12LFF drives at the front + drives (2LFF+4SFF or 4LFF+2SFF) at the rear, with mid-4LFF drives
SFF
25SFF drives at the front + drives (2LFF+4SFF or 4LFF+2SFF) at the rear
Item
Specifications
Dimensions (H × W × D)
·     Without a security bezel: 87.5 × 445.4 × 780 mm (3.44 × 17.54 × 30.71 in)
·     With a security bezel: 87.5 × 445.4 × 808 mm (3.44 × 17.54 × 31.81 in)
Max. weight
34 kg (74.96 lb)
Power consumption
The power consumption varies by configuration.
Processors
2 × AMD EPYC Genoa or Bergamo processors
·     Up to 400 W power consumption per processor
·     Up to 384 MB cache per processor
·     Integrated memory controller, supports 12 memory channels
·     Integrated PCIe controller, supports PCIe5.0 and 64 PCIe Lanes per processor
·     Four-channel XGMI bus interconnection, up to 32 Gb/s per channel
·     Up to 4.1 GHz base frequency
Memory
Up to 24 DIMMs
Supports DDR5 DIMMs, up to 4800 MT/s, RDIMM, and a maximum of 12 TB capacity if two processors are installed
Storage controllers
·     Embedded SATA/embedded NVMe storage controller
·     Standard storage controller (installed in a PCIe slot on a riser card)
Integrated graphics
The graphics chip (model AST2600) is integrated in the BMC management chip to provide a maximum resolution of 1920 × 1200@60Hz (32bpp), where:
·     1920 × 1200: 1920 horizontal pixels and 1200 vertical pixels.
·     60Hz: Screen refresh rate, 60 times per second.
·     32bpp: Color depts. The higher the value, the more colors that can be displayed.
The integrated graphics support a maximum resolution of 1920 × 1200 pixels only after you install a graphics driver that matches the operating system version. If the installed graphics driver does not match the operating system version, the integrated graphics support only the default resolution of the operating system.
If you attach monitors to both the front and rear VGA connectors, only the monitor connected to the front VGA connector is available.
Network connectors
·     1 × embedded 1 Gbps HDM dedicated management port
·     Up to three OCP 3.0 network adapter connectors (two OCP 3.0 network adapter slots + one optional OCP 3.0 network adapter) (OCP 3.0 network adapters support NCSI)
I/O connectors
·     5 × USB connectors
¡     3 × USB 3.0 connectors (one on the right chassis ear, and two on the rear panel)
¡     2 × USB 3.0 connectors (one on the system board, and one available on the left chassis ear only when the multifunctional rack mount kit is used)
·     32 SATA direct-out connectors (displayed as 4 × MCIO connectors)(reuse PCIe5.0)
·     12 × built-in MCIO connectors (PCIe5.0 x8)
·     1 × RJ-45 HDM dedicated network port (at the server rear)
·     2 × VGA connectors (one on the front panel, and one available on the left chassis ear only when the multifunctional rack mount kit is used)
·     1 × serial port (available only when the serial & DSD module is used)
·     1 × HDM dedicated management port (available on the left chassis ear only when the multifunctional rack mount kit is used)
Expansion slots
10 × PCIe5.0 standard slots + 2 × OCP 3.0 network adapter slots
Power supplies
2 × hot-swappable power supplies, 1 + 1 redundancy
Components
Figure 2 R4950 G6 server components
Item
(1) Chassis access panel
N/A
(2) Processor heatsink
Cools the processor.
(3) OCP network adapter
Network adapter installed onto the OCP network adapter connector on the system board.
(4) Processor
Integrates memory and PCIe controllers to provide data processing capabilities for the server.
(5) Storage controller
Provides RAID capability to SAS/SATA drives, including RAID configuration and RAID scale-up. It supports online upgrade of the controller firmware and remote configuration.
(6) Standard PCIe network adapter
Installed in a standard PCIe slot to provide network ports.
(7) Riser card
Provides PCIe slots.
(8) Memory
Stores computing data and data exchanged with external storage temporarily.
The server supports DDR5 DIMMs.
(9) Processor socket cover
Installed over an empty processor socket to protect pins in the socket.
(10) Server management module
Provides I/O connectors and HDM out-of-band management features.
(11) System board
One of the most important parts of a server, on which multiple components are installed, such as processor, memory, and fan. It is integrated with basic server components, including the BIOS chip and PCIe connectors.
(12) Rear drive backplane
Provides power and data channels for drives at the server rear.
(13) Rear drive cage
Installed at the server rear to accommodate drives.
(14) Riser card blank
Installed on an empty PCIe riser connector to ensure good ventilation.
(15) Power supply
Supplies power to the server. The power supplies support hot swapping and 1+1 redundancy.
(16) Chassis
N/A
(17) Chassis ears
Attach the server to the rack. The right ear is integrated with the front I/O component, and the left ear is integrated with VGA connector, HDM dedicated management connector (Type-C), and USB 3.0 connector.
(18) Front drive backplane
Provides power and data channels for drives at the server front.
(19) Drive
Provides data storage space. Drives support hot swapping. Both SSDs and HDDs are supported and the supported drive interface types include SAS, SATA, M.2, and PCIe.
(20) Supercapacitor holder
Secures a supercapacitor in the chassis.
(21) Supercapacitor
Supplies power to the flash card on the power fail safeguard module, which enables the storage controller to back up data to the flash card for protection when power outage occurs.
(22) SATA M.2 SSD expander module
Provides M.2 SSD slots.
(23) SATA M.2 SSD
Provides data storage space for the server.
(24) Serial & DSD module
Provides one serial port and two SD card slots.
(25) SATA M.2 RAID controller
Supports M.2 SSDs installed at the rear and RAID array creation. The SSDs can be used for operating system installation.
(26) Encryption module
Provides encryption services for the server to enhance data security.
(27) Fan cage
Accommodates fan modules.
(28) Fan
Helps server ventilation. Fans support hot swapping and N+1 redundancy.
(29) System battery
Supplies power to the system clock to ensure system time correctness.
(30) Chassis open-alarm module
Detects if the access panel is removed. The detection result can be displayed from the HDM Web interface.
(31) Air baffle
Provides ventilation aisles for processor heatsinks and memory modules and provides support for the supercapacitor.
(32) Processor liquid-cooled module
Cools processors.
Front panel
Figure 3 8LFF front panel
Table 2 8LFF front panel description
Item
1
USB 3.0 connector
2
Drive or LCD smart management module (optional)
3
Serial label pull tab
4
5
USB 3.0 connector
6
VGA connector
Figure 4 12LFF front panel
Table 3 12LFF front panel description
Item
1
12LFF drives (optional)
2
USB 3.0 connector
3
4
5
6
USB 3.0 connector
7
VGA connector
Figure 5 8SFF front panel
Table 4 8SFF front panel description
Item
1
Bay 1: 8SFF drives (optional)*
2
Bay 2: 8SFF drives (optional)*
3
Bay 3: 8SFF drives (optional)*
4
USB 3.0 connector
5
6
7
8
USB 3.0 connector
9
VGA connector
*: Drive types supported by the server vary by drive backplane configuration. For more information, see "Drive backplanes."
Figure 6 25SFF front panel
Table 5 25SFF front panel description
Item
1
25SFF drives (optional)
2
USB 3.0 connector
3
4
5
6
USB 3.0 connector
7
VGA connector
LEDs and buttons
Front panel LEDs and buttons
Figure 7 Front panel LEDs and buttons
Table 6 LEDs and buttons on the front panel
Button/LED
Status
Power on/standby button and system power LED
·     Steady green—The system has started.
·     Flashing green (1 Hz)—The system is starting.
·     Steady amber—The system is in standby state.
·     Off—No power is present. Possible reasons:
¡     No power source is connected.
¡     No power supplies are present.
¡     The installed power supplies are faulty.
¡     The system power cords are not connected correctly.
OCP 3.0 network adapter Ethernet port LED
·     Steady green—A link is present on a port of an OCP 3.0 network adapter.
·     Flashing green—A port on an OCP 3.0 network adapter is receiving or sending data.
·     Off—All ports on the OCP 3.0 network adapter are not in use.
The server supports two OCP3.0 network adapters and supports expansion of one more OCP3.0 network adapter.
Health LED
·     Steady green—The system is operating correctly or a minor alarm is present.
·     Flashing green (4 Hz)—HDM is initializing.
·     Flashing amber (1 Hz)—A major alarm is present.
·     Flashing red (1 Hz)—A critical alarm is present.
If a system alarm is present, log in to HDM to obtain more information about the system running status.
UID button LED
·     Steady blue—UID LED is activated. The UID LED can be activated by using the following methods:
¡     Press the UID button LED.
¡     Activate the UID LED from HDM.
·     Flashing blue:
¡     1 Hz—The firmware is being upgraded or HDM is performing out-of-band firmware update. Do not power off the server.
¡     4 Hz—HDM is restarting. To restart HDM, press the UID button LED for eight seconds.
·     Off—UID LED is not activated.
Intelligent security bezel LEDs and buttons
The LEDs of the intelligent security panel support linkage with server health status, reflecting the running status and health information of servers. This can accelerate on-site inspections and fault location. The LED effects of the intelligent security panel also support custom settings. The default LED effects are as shown in Table 7.
Figure 8 Intelligent security bezel LEDs and buttons
Figure 9 LEDs and buttons on the intelligent security bezel
Phase
LED state
Standby
Standby
Steady white
Startup
POST phase
White LEDs gradually light up from the middle to both sides, reflecting the percentage progress of the POST process
POST finished
white LEDs flow from the middle to both sides three times with a flowing effect
Running
Normal
Breathing white (0.2Hz brightness transition), where the number of lit LEDs indicates the load level.
As the overall load power consumption increases, the LEDs gradually light up from the middle and spread to both sides. The proportion of lit LEDs for different loads is as follows:
·     No load (below 10%)
·     Light load (10% to 50%)
·     Medium load (50% to 80%)
·     Heavy load (above 80%)
Predictive alarming (only drive predictive alarming is supported)
Breathing white (1 Hz brightness transition)
Major alarm present
Critical alarm present (only power error is supported)
Flashing red (1 Hz)
Remote control
System is being remotedly managed or HDM is updating firmware through out-of-band (Do not power off the server)
All flashing white (1 Hz)
HDM restarting
Some flashing white (1 Hz)
Ports
Table 7 Ports on the front panel
Port
VGA connector
DB-15
Connects a display terminal, such as a monitor or KVM device.
USB connector
USB 3.0
Connects the following devices:
·     USB flash drive.
·     USB keyboard or mouse.
·     USB optical drive for operating system installation.
Type-C
Connects a Type-C to USB adapter cable, which connects to a USB Wi-Fi adapter or USB drive.
Rear panel
Rear panel view
Figure 10 Rear panel components
Table 8 Rear panel description
Item
1
PCIe riser bay 1: PCIe slots 1 through 3
2
PCIe riser bay 2: PCIe slots 4 through 6
3
PCIe riser bay 3: PCIe slots 7 and 8
4
PCIe riser bay 4: PCIe slots 9 and 10
5
Power supply 2
6
Power supply 1
7
OCP 3.0 network adapter/Serial & DSD module (optional)
8
VGA connector
9
Two USB 3.0 connectors
10
HDM dedicated network port (1Gbps, RJ-45, default IP address 192.168.1.2/24)
11
OCP 3.0 network adapter (optional)
For more information about serial & DSD modules, see "Serial & DSD module."
When the server is installed with the liquid-cooled module, slot 6 on the rear panel will be used to install the inlet and outlet ports. The quick connectors will be differentiated into male connectors and hose connectors, as shown in Figure 11 and Figure 12, respectively.
Figure 11 Rear panel components (Processor liquid-cooled module with male connector)
Figure 12 Rear panel components (Processor liquid-cooled module with hose connector)
Figure 13 Description of rear panel components (Processor liquid-cooled module)
Item
1
PCIe riser connector 1: PCIe slot 1 to slot 3
2
PCIe riser connector 2: PCIe slot 4 and slot 5
3
PCIe riser connector 3: PCIe slot 7 and slot 8
4
PCIe riser connector 4: PCIe slot 9 and slot 10
5
Power supply 2
6
Power supply 1
7
OCP 3.0 network adapter or serial & DSD module (optional)
8
Outlet of the liquid-cooled module (red)
9
Inlet of the liquid-cooled module (blue)
10
VGA connector
11
12
HDM dedicated network port (1Gb/s, RJ-45, default IP address 192.168.1.2/24)
13
LEDs
Figure 14 Rear panel LEDs
(1) UID LED
(2) Link LED of the Ethernet port
(3) Activity LED of the Ethernet port
(4) Power supply LED for power supply 1
(5) Power supply LED for power supply 2
Table 9 LEDs on the rear panel
LED
Status
UID LED
¡     Enable UID LED from HDM.
·     Flashing blue:
¡     4 Hz—HDM is restarting. To restart HDM, press the UID button LED for 8 seconds.
·     Steady green—A link is present on the port.
·     Off—No link is present on the port.
·     Flashing green (1 Hz)—The port is receiving or sending data.
·     Off—The port is not receiving or sending data.
Power supply LED
·     Steady green—The power supply is operating correctly or the server is in standby state.
·     Flashing green (0.33 Hz)—The power supply is in standby state and does not output power.
·     Flashing green (2 Hz)—The power supply is updating its firmware.
·     Steady amber—Either of the following conditions exists:
¡     The power supply is faulty.
¡     The power supply does not have power input, but another power supply has correct power input.
·     Flashing amber (1 Hz)—An alarm has occurred on the power supply.
·     Off—No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown.
Ports
Table 10 Ports on the rear panel
Port
VGA connector
DB-15
BIOS port
DB-9
The BIOS serial port is used for the following purposes:
·     Log in to the server when the remote network connection to the server has failed.
·     Establish a GSM modem or encryption lock connection.
The port is on the serial & DSD module. For more information, see "Serial & DSD module."
USB connector
USB 3.0
·     USB flash drive.
RJ-45
Establishes a network connection to manage HDM from its Web interface.
Power receptacle
Standard single-phase
Connects the power supply to the power source.
System board
Figure 15 System board components
Table 11 System board components
No.
Mark
1
OCP 3.0 network adapter connector 2/DSD module connector
OCP2&DSD&UART CARD
2
Server management module connector
BMC CON
3
TPM/TCM connector
TPM
4
PCIe riser connector 1 (for processor 1)
RISER1 PCIe x16
5
Fan connector for OCP 3.0 network adapter 1
OCP1 FAN
6
System battery
N/A
7
AUX connector for OCP 3.0 network adapter 1
OCP1 AUX
8
MCIO connector C1-P1A (for processor 1)
C1-P1A
9
MCIO connector C1-P1C (for processor 1)
C1-P1C
10
Drive backplane AUX connector 7
AUX 7
11
Drive backplane AUX connector 9
AUX 9
12
M.2 SSD AUX connector
M.2 AUX(FRONT)
13
Front I/O connector
RIGHT EAR
14
Drive backplane AUX connector 4
AUX 4
15
Power connector for OCP 3.0 network adapter 1
OCP1 PWR
16
LCD smart management module connector
DIAG LCD
17
MCIO connector C1-P0A (for processor 1)
C1-P0A
18
MCIO connector C1-P0C (for processor 1)
C1-P0C
19
MCIO connector C1-P2A (for processor 1)
C1-P2A
20
MCIO connector C1-P2C (for processor 1)
C1-P2C
21
Drive backplane power connector 3
PWR3
22
Drive backplane power connector 2
PWR2
23
Temperature sensor connector
TEMP SENSE
24
Drive backplane AUX connector 3
AUX3
25
Drive backplane AUX connector 1
AUX1
26
Drive backplane AUX connector 2
AUX2
27
MCIO connector C2-P0A (for processor 2)
C2-P0A
28
MCIO connector C2-P0C (for processor 2)
C2-P0C
29
MCIO connector C2-P2A (for processor 2)
C2-P2A
30
MCIO connector C2-P2C (for processor 2)
C2-P2C
31
Drive backplane power connector 1
PWR1
32
Front VGA and USB 3.0 connector
LEFT EAR
33
Chassis-open alarm module connector
INTRUDER
34
MCIO connector C2-P3A (for processor 2)
C2-P3A
35
Drive backplane power connector 5
PWR5
36
MCIO connector C2-P3C (for processor 2)
C2-P3C
37
Drive backplane power connector 8
PWR8
38
Drive backplane power connector 7
PWR7
39
Drive backplane AUX connector 5
AUX5
40
Liquid Leakage Detection module connector
LEAKDET
41
OCP 3.0 network adapter slot 2 (PCIe expansion connector)
OCP2 x8
42
PCIe riser connector 2 (for processor 2)
RISER2 PCIe x16
43
Drive backplane power connector 6
PWR6
44
OCP3 AUX connector 8
AUX8(OCP/NCSI)
45
Drive backplane AUX connector 6
AUX6
46
Drive backplane power connector 4
PWR4
47
LP SlimSAS connector C1-P4A (for processor 1)
C1-P4A
48
Embedded USB3.0 connector
INTER USB3.0
X
N/A
Figure 16 shows the system maintenance switch. Table 12 describes how to use the maintenance switch.
Figure 16 System maintenance switch
Table 12 System maintenance switch description
Item
Remarks
1
·     Off (default)—HDM login requires the username and password of a valid HDM user account.
·     On—HDM login requires the default username and password.
For security purposes, turn off the switch after you complete tasks with the default username and password as a best practice.
5
·     Off (default)—Normal server startup.
·     On—Restores the default BIOS settings.
To restore the default BIOS settings:
1.     Power off the server, and turn on the switch.
2.     Power on the switch and wait for a minimum of 10 seconds.
3.     Power off the server and then turn off the switch.
4.     Start the server and verify that the POST screen prompts The CMOS defaults were loaded.
CAUTION CAUTION:
The server cannot start up when the switch is turned on. To avoid service data loss, stop running services and power off the server before turning on the switch.
6
·     On—Clears all passwords from the BIOS at server startup.
If this switch is on, the server will clear all the passwords at each startup. Make sure you turn off the switch before the next server startup if you do not need to clear all the passwords.
2, 3, 4, 7, and 8
Reserved for future use.
N/A
DIMM slots
The system board provides eight DIMM channels per processor, and 24 channels in total, as shown in Figure 17. Each channel contains two DIMM slots.
Figure 17 System board DIMM slot layout
For components compatible with the server and detailed component information, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand or applicable region. For example, the DDR5-4800-32G-1Rx4 memory model represents memory module labels including UN-DDR5-4800-32G-1Rx4-R, UN-DDR5-4800-32G-1Rx4-F, and UN-DDR5-4800-32G-1Rx4-S, which have different prefixes and suffixes.
DIMMs
The server provides eight DIMM channels per processor and each channel has two DIMM slots. If the server has one processor, the total number of DIMM slots is 16. If the server has two processors, the total number of DIMM slots is 32. For the physical layout of DIMM slots, see "DIMM slots."
A DIMM rank is a set of memory chips that the system accesses while writing or reading from the memory. On a multi-rank DIMM, only one rank is accessible at a time.
To determine the rank classification of a DIMM, use the label attached to the DIMM, as shown in Figure 18.
Figure 18 DDR DIMM rank classification label
Table 13 DIMM rank classification label description
Callout
Remarks
1
Capacity
Options include:
·     32GB.
·     64 GB.
2
Number of ranks
Options include:
·     1R—One rank (Single-Rank).
·     2R—Two ranks (Dual-Rank). A 2R DIMM is equivalent to two 1R DIMMs.
·     4R—Four ranks (Quad-Rank). A 4R DIMM is equivalent to two 2R DIMMs
·     8R—Eight ranks (8-Rank). An 8R DIMM is equivalent to two 4R DIMMs.
3
Data width
Options include:
·     ×4—4 bits.
·     ×8—8 bits.
4
DIMM generation
DDR5
5
Data rate
4800B—4800 MT/s.
6
DIMM type
R—RDIMM.
HDDs and SSDs
Drive numbering
The server provides different drive numbering schemes for different drive configurations at the server front and rear, as shown in Figure 19 through Figure 25.
Figure 19 Drive numbering for front 25SFF drive configuration
Figure 20 Drive numbering for front 12LFF drive configuration
Figure 21 Drive numbering for front 8LFF drive configuration
Figure 22 Drive numbering for rear 2LFF+4SFF drive configuration
Figure 23 Drive numbering for rear 4LFF+2SFF drive configuration
Figure 24 Drive numbering for rear 2SFF+2SFF+4SFF drive configuration
Figure 25 Drive numbering for mid-4LFF drive configuration
Drive LEDs
The server supports SAS/SATA drives and NVMe drives.
For more information about OSs that support hot insertion and managed hot removal of NVMe drives, use the component compatibility lookup tool at http://www.h3c.com/en/home/qr/default.htm?id=66.
Figure 26 shows the location of the LEDs on a drive to indicate the drive status.
Figure 26 Drive LEDs
(1) Fault/UID LED
(2) Present/Active LED
To identify the status of a SAS or SATA drive, use Table 14. To identify the status of an NVMe drive, use Table 15.
Table 14 SAS/SATA drive LED description
Fault/UID LED status
Present/Active LED status
Flashing amber (0.5 Hz)
Steady green/Flashing green (4.0 Hz)
A drive failure is predicted. As a best practice, replace the drive before it fails.
Steady amber
The drive is faulty. Replace the drive immediately.
Steady blue
The drive is operating correctly and is selected by the RAID controller.
Off
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive.
Off
Steady green
The drive is present but no data is being read or written to the drive.
Off
Off
The drive is not securely installed.
Table 15 NVMe drive LED description
Flashing amber (4 Hz)
Off
The drive is in hot insertion process.
Steady amber
Steady blue
The drive is operating correctly and selected by the RAID controller.
Off
Off
Steady green
Off
Off
The server supports multiple drive configurations. For more information about drive configurations and their required storage controller and riser cards, see H3C UniServer R4950 G6 Server Drive Configurations and Cabling Solutions.
Drive backplanes
The server supports the following types of drive backplanes:
·     SAS/SATA drive backplanes—Support only SAS/SATA drives.
·     UniBay drive backplanes—Support both SAS/SATA and NVMe drives. You must connect both SAS/SATA and NVMe data cables. The number of supported drives varies by drive cabling.
·     X SAS/SATA+Y UniBay drive backplanes—Support SAS/SATA drives in all slots and support NVMe drives in certain slots.
¡     X: Number of slots supporting only SAS/SATA drives.
¡     Y: Number of slots supporting both SAS/SATA and NVMe drives.
For UniBay drive backplanes and X SAS/SATA+Y UniBay drive backplanes:
·     The two drive types are supported only when both SAS/SATA and NVMe data cables are connected.
·     The number of supported SAS/SATA drives and the number of supported NVMe drives vary by cable connection.
The PCA-BP-8SFF-2U-G6 8SFF SAS/SATA drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA drives.
Figure 27 8SFF SAS/SATA drive backplane
(1) x8 SlimSAS connector (SAS PORT1)
(2) AUX connector (AUX)
(3) Power connector (PWR)
The PCA-BP-8UniBay-2U-G6 8SFF UniBay drive backplane can be installed at the server front to support eight 2.5-inch SAS/SATA/NVMe drives.
Figure 28 8SFF UniBay drive backplane
(1) x8 SlimSAS connector (SAS PORT)
(2) AUX ( AUX)
(3) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe B3/B4)
(4) Power connector (POWER)
(5) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe B1/B2)
(6) MCIO connector A3/A4 (PCIe5.0 x8)(NVMe A3/A4)
(7) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe A1/A2)
PCIe5.0 x8 description:
·     PCIe5.0: Fifth-generation signal speed.
·     x8: Bus bandwidth.
The PCA-BP-8LFF-2U-G6 8LFF SAS/SATA drive backplane can be installed at the server front to support eight 3.5-inch SAS/SATA drives.
Figure 29 8LFF SAS/SATA drive backplane
(1) x8 Mini-SAS-HD connector (SAS PORT)
(2) Power connector (PWR)
(3) AUX connector (AUX)
The PCA-BP-12LFF-2U-G6 12LFF SAS/SATA drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA drives.
Figure 30 12LFF SAS/SATA drive backplane
(1) x4 SlimSAS connector (SAS PORT 2), managing the last four SAS/SATA drives on the backplane
(2) Power connector 2 (PWR 2)
(4) Power connector 1 (PWR 1)
(5) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane
The PCA-BP-12LFF-4NVMe-2U-G6 12LFF drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives, including eight SAS/SATA drives and four SAS/SATA/NVMe drives.
Figure 31 8SAS/SATA+4UniBay drive backplane
(1) MCIO connector A3 (PCIe5.0 x4)(NVMe-A3), supporting NVMe drive 9
(2) x4 SlimSAS connector (SAS PORT 2), managing the last four SAS/SATA drives on the backplane
(3) Power connector 2 (PWR 2)
(4) AUX connector 1(AUX 1)
(5) Power connector 1 (PWR 1)
(6) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane
(7) MCIO connector A4 (PCIe5.0 x4)(NVMe-A4), supporting NVMe drive 8
(8) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe-A1/A2), supporting NVMe drives 10 and 11
For more information about drive numbering, see "Drive numbering."
The PCA-BP-12LFF-EXP-2U-G6 12LFF drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives, including four SAS/SATA drives and eight SAS/SATA/NVMe drives. The drive backplane integrates an Expander chip to manage 12 SAS/SATA drives through an x8 SlimSAS connector. The drive backplane also provides three downlink interfaces to connect to other drive backplanes and support more drives.
Figure 32 4SAS/SATA+8UniBay drive backplane
(1) x8 SlimSAS uplink interface (SAS PORT), managing all drives on the backplane
(2) x4 SlimSAS downlink interface 3 (SAS EXP3)
(3) Power connector 2 (PWR2)
(4) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe-B1/B2), supporting NVMe drives 6 and 7
(5) Power connector 1 (PWR1)
(6) x8 SlimSAS downlink interface 2 (SAS EXP2)
(7) x4 SlimSAS downlink interface 1 (SAS EXP1)
(8) AUX connector (AUX)
(9) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe B3/B4), supporting NVMe drives 4 and 5
(10) MCIO connector A3/A4 (PCIe5.0 x8)(NVMe A3/A4), supporting NVMe drives 8 and 9
(11) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe A1/A2), supporting NVMe drives 10 and 11
The PCA-BP-12LFF-UniBay-2U-G6 12LFF UniBay drive backplane can be installed at the server front to support twelve 3.5-inch SAS/SATA/NVMe drives.
Figure 33 12LFF UniBay drive backplane
(3) MCIO connector B1/B2 (PCIe5.0 x8)(NVMe-B1/B2)
(4) Power connector 2 (PWR 2)
(5) AUX connector 1 (AUX 1)
(6) MCIO connector C1 (PCIe5.0 x4)(NVMe-C1)
(7) Power connector 1 (PWR 1)
(8) x8 SlimSAS connector (SAS PORT 1), managing the first eight SAS/SATA drives on the backplane
(9) MCIO connector C3/C4 (PCIe5.0 x8)(NVMe-C3/C4)
(10) MCIO connector C2 (PCIe5.0 x4)( NVMe-C2)
(11) MCIO connector B3/B4 (PCIe5.0 x8)(NVMe-B3/B4)
(12) MCIO connector A4 (PCIe5.0 x4)(NVMe-A4)
(13) MCIO connector A1/A2 (PCIe5.0 x8)(NVMe-A1/A2)
The 8LFF UniBay drive backplane (model: UN-PCA-BP-8LFF-UniBay-2U-G6) is installed at the server front and supports up to 8 3.5-inch SAS/SATA/NVMe drives.
Figure 34 8LFF UniBay drive backplane
(1) SlimSAS connector B3/B4 (PCIe5.0 x8), supporting NVMe drives (NVMe-B3/B4)
(2) SlimSAS connector B1/B2 (PCIe5.0 x8), supporting NVMe drives (NVMe-B1/B2)
(3) x8 Mini-SAS-HD connector (SAS-PORT 1)
(4) SlimSAS connector A3/A4 (PCIe5.0 x8), supporting NVMe drives (NVMe-A3/A4)
(5) SlimSAS connector A1/A2 (PCIe5.0 x8), supporting NVMe drives (NVMe-A1/A2)
(6) Power connector (PWR)
The PCA-BP-25SFF-2U-G6 25SFF drive backplane can be installed at the server front to support twenty-five 2.5-inch SAS/SATA/NVMe drives, including 17 SAS/SATA drives and 8 SAS/SATA/NVMe drives. The drive backplane can use an x8 SlimSAS connector to manage 25 SAS/SATA drives. The drive backplane also integrates an Expander chip and three downlink interfaces to connect to other drive backplanes and support more drives.
Figure 35 17SAS/SATA+8UniBay drive backplane
(1) x4 SlimSAS downlink interface 3 (SAS EXP 3)
(2) x8 SlimSAS uplink interface (SAS PORT), managing all drives on the backplane
(3) x8 SlimSAS downlink interface 2 (SAS EXP 2)
(4) x4 SlimSAS downlink interface 1 (SAS EXP 1)
(6) Power connector 2 (PWR 2)
(7) MCIO connector 4 (PCIe5.0 x8)(NVMe 4), supporting NVMe drives 17 and 18
(9) MCIO connector 3 (PCIe5.0 x8)(NVMe 3), supporting NVMe drives 19 and 20
(10) MCIO connector 2 (PCIe5.0 x8)(NVMe 2), supporting NVMe drives 21 and 22
(11) Power connector 3 (PWR 3)
(12) MCIO connector 1 (PCIe5.0 x8)(NVMe 1), supporting NVMe drives 23 and 24
The 4LFF SAS/SATA hard drive backplane (model: PCA-BP-4LFF-2U-M-G6) is installed in the middle-mounted 4LFF drive cage in the chassis, supporting a maximum of four 3.5-inch SAS/SATA drives.
Figure 36 Mid 4LFF SAS/SATA drive backplane
(1) AUX connector (AUX1)
(2) Power connector (PWR1)
(3) x4 Mini-SAS-HD connector (SAS PORT1)
The PCA-BP-2LFF-2U-G6 2LFF SAS/SATA drive backplane is installed at the server rear to support two 3.5-inch SAS/SATA drives.
Figure 37 2LFF SAS/SATA drive backplane
(1) x4 Mini-SAS-HD connector (SAS PORT1)
(2) AUX connector (AUX1)
(3) Power connector (PWR1)
The PCA-BP-4LFF-2U-G6 4LFF SAS/SATA drive backplane is installed at the server rear to support four 3.5-inch SAS/SATA drives.
Figure 38 4LFF SAS/SATA drive backplane
The PCA-BP-2SFF-2U-G6 2SFF SAS/SATA drive backplane is installed at the server rear to support two 2.5-inch SAS/SATA drives.
Figure 39 2SFF SAS/SATA drive backplane
(1) Power connector (PWR)
(2) x4 Mini-SAS-HD connector (SAS PORT)
The PCA-BP-2SFF-2UniBay-2U-G6 2SFF UniBay drive backplane is installed at the server rear to support two 2.5-inch SAS/SATA/NVMe drives.
Figure 40 2SFF UniBay drive backplane
(3) SlimSAS connector (PCIe4.0 x8)(NVME)
(4) AUX connector (AUX)
PCIe4.0 x8 description:
·     PCIe4.0: Fifth-generation signal speed.
The PCA-BP-4SFF-2U-G6 4SFF SAS/SATA drive backplane is installed at the server rear to support four 2.5-inch SAS/SATA drives.
Figure 41 4SFF SAS/SATA drive backplane
(1) x4 Mini-SAS-HD connector (SAS PORT)
The PCA-BP-4SFF-4UniBay-2U-G6 4SFF UniBay drive backplane is installed at the server rear to support four 2.5-inch SAS/SATA/NVMe drives.
Figure 42 4SFF UniBay drive backplane
(1) AUX connector (AUX)
(3) MCIO connector B1/B2 (PCIe5.0 x8) (NVME-B1/B2)
(4) MCIO connector B3/B4 (PCIe5.0 x8) (NVME-B3/B4)
(5) x4 Mini-SAS-HD connector (SAS PORT)
Riser cards
To expand the server with PCIe modules, install riser cards on the PCIe riser connectors.
Each PCIe slot in a riser card can supply a maximum of 75 W of power to the PCIe module. You must connect a separate power cord to the PCIe module if it requires more than 75 W of power.
If a processor is faulty or absent, the PCIe slots connected to it are unavailable.
The slot number of a PCIe slot varies by the PCIe riser connector that holds the riser card. For example, slot 1/4 represents PCIe slot 1 if the riser card is installed on connector 1 and represents PCIe slot 4 if the riser card is installed on connector 2. For information about PCIe riser connector locations, see "Rear panel view."
RC-3FHFL-2U-G6
Figure 43 RC-3FHFL-2U-G6 (1)
(1) PCIe5.0 x16 slot 2/5
(2) PCIe5.0 x16 slot 3/6
(3) GPU module power connector
(4) PCIe5.0 x16 slot 1/4*
Figure 44 RC-3FHFL-2U-G6 (2)
(5) MCIO connector 2-C
(6) MCIO connector 2-A
(7) MCIO connector 1-A
(8) MCIO connector 1-C
slot 1/4: When the riser card is installed in PCIe riser card slot 1, this slot corresponds to PCIe slot 1. When the riser card is installed in PCIe riser card slot 2, this slot corresponds to PCIe slot 2. This rule applies to all the other PCIe riser card slots. For information about PCIe slots, see "Rear panel view."
RC-3FHFL-2U-G6-1
Figure 45 RC-3FHFL-2U-G6-1 (1)
Figure 46 RC-3FHFL-2U-G6-1 (2)
(3)     GPU power connector
(5)     MCIO connector 3-C
(6)     MCIO connector 3-A
RC-3FHHL-2U-G6
Figure 47 RC-3FHHL-2U-G6 (1)
Figure 48 RC-3FHHL-2U-G6 (2)
(1) PCIe5.0 x8 slot 2/5
(2) PCIe5.0 x8 slot 3/6
(3) PCIe5.0 x16 slot 1/4*
(4) MCIO connector 1-A
(5) MCIO connector 1-C
RC-2FHFL-2U-LC-G6
Figure 49 RC-2FHFL-2U-LC-G6 (1)
Figure 50 RC-2FHFL-2U-LC-G6 (2)
(1) PCIe5.0 x16 slot 5
(2) PCIe5.0 x16 slot 4
(4) MCIO connector 2-C
(5) MCIO connector 2-A
(6) MCIO connector 1-A
(7) MCIO connector 1-C
PCA-R4900-4GPU-G6
Figure 51 PCA-R4900-4GPU-G6 (1)
(1) PCIe5.0 x16  slot 14
(2) PCIe5.0 x16 slot 13
(3) PCIe5.0 x16 slot 12
(4) PCIe5.0 x16 slot 11
(5) GPU module power connector
(6) GPU module power connector
Figure 52 PCA-R4900-4GPU-G6 (2)
(7) GPU module power connector
(8) GPU module power connector
Figure 53 PCA-R4900-4GPU-G6 (3)
(9) PCIe5.0 x16 slot 6
(10) PCIe5.0 x16 slot 3
This riser 4 assembly module consists of a riser 4 ×16 P2 expander module (0231AKAX), a riser 4 ×16 P3 expander module (0231AKAW) and 2 × FHFL structure modules (0231AKAV), as shown in Figure 54.
Figure 54 Riser 4 assembly module (accommodating two FHFL PCIe modules)
1
PCIe interface cable S2 from slot 9 (connected to connector C2-P2C on the system board)
2
PCIe interface cable S1 from slot 10 (connected to connector C2-P3A on the system board)
3
PCIe5.0 x16 in slot 10
4
PCIe5.0 x16 in slot 9
5
PCIe interface cable S2 from slot 10 (connected to connector C2-P3C on the system board)
6
Power connector S3 from slot 10 (connected to connector PWR5 on the system board)
7
Power connector S3 from slot 9 (connected to connector PWR8 on the system board)
8
PCIe interface cable S1 from slot 9 (connected to connector C2-P2A on the system board)
This riser 4 assembly module consists of two riser 4 ×8 P2 expander modules (0231AKB1) and 2 × HHHL structure modules (0231AKAU), as shown in Figure 55.
Figure 55 Riser 4 assembly module (accommodating two HHHL PCIe modules)
1
PCIe interface cable S1 from slot 10 (connected to connector C2-P2C on the system board)
2
Power connector S2 from slot 10 (connected to connector PWR5 on the system board)
3
PCIe5.0 x8 in slot 10
4
PCIe5.0 x8 in slot 9
5
Power connector S2 from slot 9 (connected to connector PWR8 on the system board)
6
This riser 3 assembly module consists of two riser 3 ×8 P3 expander modules (0231AKB2) and 2 × HHHL structure modules (0231AKBA), as shown in Figure 56.
Figure 56 Riser 3 assembly module (accommodating two HHHL PCIe modules)
1
PCIe interface cable S1 from slot 8 (connected to connector C2-P3C on the system board)
2
Power connector S2 from slot 8 (connected to connector PWR7 on the system board)
3
PCIe5.0 x8 in slot 8
4
PCIe5.0 x8 in slot 7
5
Power connector S2 from slot 7 (connected to connector PWR6 on the system board)
6
PCIe interface cable S1 from slot 7 (connected to connector C2-P3A on the system board)
Fan modules
The server supports four hot swappable fan modules. The server supports N+1 fan module redundancy. Figure 57 shows the layout of the fan modules in the chassis.
The server can automatically adjust the fan speed based on the actual system temperature. The speed policy is designed to optimize system cooling while minimizing noise levels, achieving an optimal balance between the two.
Figure 57 Fan module layout
An LCD smart management module displays basic server information, operating status, and fault information, and provides diagnostics and troubleshooting capabilities. You can locate and troubleshoot component failures by using the LCD module in conjunction with the event logs generated in HDM. For more information about the LCD smart management module, see its the user guide.
Figure 58 LCD smart management module
LCD_001
Table 16 LCD smart management module description
No.
Item
1
Mini-USB connector
Used for upgrading the firmware of the LCD module.
2
LCD module cable
Connects the LCD module to the system board of the server. For information about the LCD smart management module connector on the system board, see "System board."
3
LCD module shell
Protects and secures the LCD screen.
4
LCD screen
Displays basic server information, operating status, and fault information.
When you install the LCD smart management module, connect the related cables as required. For information about selecting cables, cable coding, and cabling method, see "Connecting the LCD smart management module cable."
M.2 expander module
Figure 59 Front M.2 SSD expander module (front view)
114-M.2转接卡正面
(1) Data cable connector
(2) M.2 SSD drive slot 1
Figure 60 Front M.2 SSD expander module (rear view)
115-M.2转接卡反面
(1) M.2 SSD drive slot 2
Figure 61 M.2 storage controller
(1) SATA  M.2 SSD card slot 1
(2) SATA  M.2 SSD card slot 2
The server management module is installed on the system board to provide I/O connectors and HDM out-of-band features for the server.
Figure 62 Server management module
(1) VGA connector
(2) Two USB 3.0 connectors
(3) HDM dedicated network interface
(4) UID LED
(5) HDM serial port
(6) iFIST module
(7) NCSI connector
Serial & DSD module
The serial & DSD module is installed in the slot on the server rear panel. The module provides two SD slots and forms RAID 1 by default.
Figure 63 Serial & DSD module
44-040-DSD模块_画板 1
Table 17 Component description
Item
1
SD card slot 1
2
SD card slot 2
3
Serial port
B/D/F information
You can obtain B/D/F information by using one of the following methods:
·     BIOS log—Search the dumpiio keyword in the BIOS log.
·     UEFI shell—Execute the pci command. For information about how to execute the command, execute the help pci command.
·     Operating system—The obtaining method varies by OS.
¡     For Linux, execute the lspci command.
If Linux does not support the lspci command by default, obtain and install the pci-utils package from the yum repository.
¡     For Windows, install the pciutils package, and then execute the lspci command.
¡     For VMware, execute the lspci command.
Before you begin
Before you perform a managed removal of an OCP network adapter, perform the following tasks:
·     Use the OS compatibility query tool at http://www.h3c.com/en/home/qr/default.htm?id=66 to obtain operating systems that support managed removal of OCP network adapters.
·     Make sure the BIOS version is 6.30.17 or higher, the HDM2 version is 1.21 or higher, and the CPLD version is V007 or higher.
This section uses an OCP network adapter in slot 16 as an example.
To perform a hot removal:
1.     Access the operating system.
2.     Execute the dmidecode -t 9 command to search for the bus address of the OCP network adapter. As shown in Figure 64, the bus address of the OCP network adapter in slot 16 is 0000:31:00.0.
Figure 64 Searching for the bus address of an OCP network adapter by slot number
3.     Power off the OCP network adapter by executing the echo 0 > /sys/bus/pci/slots/slot number/power command, where slot number represents the number of the slot where the OCP network adapter resides.
Figure 65 Executing the echo 0 > /sys/bus/pci/slots/slot number/power command
4.     Identify whether the OCP network adapter has been disconnected:
¡     Observe the OCP network adapter LED. If the LED is off, the OCP network adapter has been disconnected.
¡     Execute the lspci –vvv –s 0000:31:00.0 command. If no output is displayed, the OCP network adapter has been disconnected.
Figure 66 Identifying OCP network adapter status
5.     Re-insert the OCP network adapter.
6.     Power on the OCP network adapter by executing the echo 1 > /sys/bus/pci/slots/slot number/power command, where slot number represents the number of the slot where the OCP network adapter resides.
7.     Identify whether the OCP network adapter has been connected:
¡     Observe the OCP network adapter LED. If the LED is on, the OCP network adapter has been connected.
¡     Execute the lspci –vvv –s 0000:31:00.0 command. If an output is displayed, the OCP network adapter has been connected.
Figure 67 Identifying OCP network adapter status
8.     Identify whether any exception exists. If any exception occurred, contact H3C Support.
The operating temperature requirements for the server vary depending on the server model and hardware configuration. When the general and component-based requirements conflict, use the component-based requirement.
Be aware that the actual maximum operating temperature of the server might be lower than what is stated because of poor site cooling performance. In a real data center, the server cooling performance might decrease because of adverse external factors, including poor cabinet cooling performance, high power density inside the cabinet, or insufficient spacing between devices.
Item
Specifications
Minimum: 5°C (41°F)
Maximum: 40°C (104°F)
CAUTION CAUTION:
The maximum temperature varies by hardware option presence. For more information, see "Operating temperature requirements."
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
8% to 90%, noncondensing
Storage humidity
5% to 95%, noncondensing
Operating altitude
–60 m to +3000 m (–196.85 ft to +9842.52 ft)
The allowed maximum temperature decreases by 0.33°C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft)
Storage altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
The cooling capability of the server depends on the power density of devices within the cabinet, the cooling capability of the cabinet, and the spacing between the server and other devices. When the server is stacked with other devices, the ventilation of the top vent holes of the server might be affected, which can potentially decrease the maximum operating temperature of the server.
If the other devices are positioned above or below the server inside the cabinet, the maximum operating temperature might be reduced depending on the cooling conditions of the server, power density inside the cabinet, and cabinet cooling capability.
When a single FAN-8038-2U-G6 fan module fails or a single rotor in the FAN-8056-2U-G6 fan module fails, the following might occur:
·     The maximum server operating temperature decreases by 5°C (41°F).
·     The GPU performance might decrease.
·     The performance of processors with a TDP of more than 165 W might decrease.
Table 18 shows the operating temperature requirements for the server without the liquid-cooled module.
Table 18 Operating temperature requirements without liquid-cooled module
Drive configuration
Maximum temperature
Remarks
30°C (86°F)
35°C (95°F)
40°C (104°F)
8SFF (without TOSHIBA SAS HDD SFF)
Smart network adapters and GPUs are not supported when mid drives are installed.
·     Smart network adapters and GPUs are not supported when mid drives are installed.
·     Processors of more than 360W are not supported when the 4GPU module is installed.
The following are not supported:
·     GPUs
·     U.2 NVMe SSDs.
·     Rear drives.
·     Processors of more than 195W.
·     Delta DPS-1600AB-13 R 1600W Platinum AC power supply.
Fan speed unrestricted.
·     8LFF
·     16SFF
·     A40 GPUs.
·     Smart network adapters and GPUs when mid drives are installed.
·     Processors of more than 280W when the 4GPU module is installed.
·     8SFF (with TOSHIBA SAS HDD SFF)
·     12LFF
·     25SFF
·     24 SFF
·     A40/A16 GPUs are not supported.
·     A100-80G/A40/A16 GPUs.
·     Processors of more than 300W when rear drives (including mechanical drives, U.2, NVMe SSDs, and E1.S and excluding SATA/SAS SSDs) are installed.
·     Processors of more than 270W when the 4GPU module is installed.
·     Processors of more than 250W when the rear A2 GPU is installed.
·     536CBF2 smart network adapter when processors of 400W are installed.
With the 8SFF drive configuration that uses TOSHIBA SAS HDD SFF, the 8056 fan module is limited to 90% of its maximum speed.
Table 19 shows the operating temperature requirements for the server with the liquid-cooled module.
Table 19 Operating temperature requirements with liquid-cooled module
Drive configuration
Maximum temperature
Remarks
30°C (86°F)
35°C (95°F)
40°C (104°F)
50°C (122°F)
All configurations are supported.
·     GPUs.
·     U.2 NVMe SSDs.
·     Mid drives and rear drives.
·     GPUs.
·     U.2 NVMe SSDs.
·     Memory with capacity greater than 32G.
·     BF2/DPU smart network adapters.
·     8LFF
·     8SFF (without TOSHIBA SAS HDD SFF)
·     16SFF
·     GPUs.
·     U.2 NVMe SSDs.
Not supported.
·     12LFF
·     25SFF
·     24SFF
A100-80G/A40/ A800/ L40 GPUs are not supported.
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     E-mail: service@h3c.com
·     Website: http://www.h3c.com
Appendix F  Glossary
Item
B
BIOS
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality.
C
CPLD
Complex programmable logic device is an integrated circuit used to build reconfigurable digital circuits.
E
Ethernet adapter
An Ethernet adapter, also called a network interface card (NIC), connects the server to the network.
F
UniSystem
UniSystem provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools.
G
GPU module
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance.
H
HDM
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server.
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
K
KVM
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server.
R
RAID
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance.
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
U
U
A unit of measure defined as 44.45 mm (1.75 in) in IEC 60297-1. It is used as a measurement of the overall height of racks, as well as equipment mounted in the racks.
Appendix G  Acronyms
Acronym
Full name
B
BIOS
Basic Input/Output System
C
CMA
Cable Management Arm
CPLD
Complex Programmable Logic Device
D
DCPMM
Data Center Persistent Memory Module
DDR
Double Data Rate
DIMM
Dual In-Line Memory Module
DRAM
Dynamic Random Access Memory
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDD
Hard Disk Drive
HDM
I
IDC
Internet Data Center
iFIST
integrated Fast Intelligent Scalable Toolkit
K
KVM
Keyboard, Video, Mouse
L
LRDIMM
Load Reduced Dual Inline Memory Module
N
NCSI
Network Controller Sideband Interface
NVMe
Non-Volatile Memory Express
P
PCIe
Peripheral Component Interconnect Express
POST
Power-On Self-Test
R
RAID
Redundant Arrays of Independent Disks
RDIMM
Registered Dual Inline Memory Module
S
SAS
Serial Attached Small Computer System Interface
SATA
Serial ATA
SD
Secure Digital
SDS
Secure Diagnosis System
SFF
Small Form Factor
SSD
Solid State Drive
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
U
UID
Unit Identification
UPS
Uninterruptible Power Supply
USB
Universal Serial Bus
