06-AP Management Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Wi-Fi 7 Access Points Cloud Mode Configuration Guides(R2610P06)-6W10006-AP Management Configuration Guide
01-AP management configuration
01-AP management configuration 84.00 KB
Managing APs
About AP management
Managing a large number of APs is both time consuming and costly. The fit AP+AC network architecture enables an AC to implement centralized AP management and maintenance.
Configuring the default input power level
Configure the default input power level for an AP in case the AP cannot obtain its input power level at startup from an upstream switch.
An AP's support for MIMO modes and USB interfaces varies by input power level, as shown in Table 1.
Table 1 AP's support for MIMO modes and USB interfaces
Input power level
Supported MIMO modes
Whether USB interfaces can be enabled
High
1×1, 2×2, 3×3, and 4×4.
Yes.
Middle
Yes when the MIMO mode is 1×1 or 2×2.
Low
1×1.
No.
When you configure the default input power level for an AP, make sure the setting matches its power mode. An excessively low input power level prevents the AP from operating correctly. An excessively high input power level causes overload of the AP in case of power shortage.
When the device uses a power adapter for power supply, automatic learning of power levels from an upstream switch is not supported. You can manually set the power level to high by using the wlan power-level default high command.
When the device uses a fiber port for power supply, automatic learning of power levels from an upstream switch is not supported. The device power level is high. You can manually set the power level to by using the wlan power-level default command.
2.     Configure the default input power level.
power-level default { high | low | middle }
By default, the default input power level is middle
Enabling or disabling the USB interface
After you enable the USB interface for the AP, the USB interface becomes active only when the input power level of the AP is middle or high.
If the input power level is middle, the MIMO mode can only be 1×1 or 2×2 with the USB interface enabled. With the USB interface disabled, the MIMO mode can reach 4×4.
For information about MIMO modes, see Radio Resources Configuration Guide.
USB disks only support the FAT32 format.
2.     Enable or disable the USB interface.
usb { enable | disable }
By default, the USB interface is disabled on the AP.
Due to differences in compatibility and drivers of USB devices from different vendors, there is no guarantee that USB devices from all vendors can operate correctly on the AP. If a USB device cannot operate correctly, verify that the USB interface on the AP is enabled, and then try using USB devices from other vendors.
Specifying a region code
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring an AP.
To prevent regulation violation caused by region code modification, lock the region code.
2.     Enter global configuration view.
wlan global-configuration
3.     Specify a region code.
By default, the region code is CN for APs specific to China and JP for APs specific to Japan. For the other APs, no region is configured by default. Configure the region code as required.
4.     (Optional.) Lock the region code.
region-code-lock enable
By default, the region code is not locked.
5.     Return to system view.
6.     Enter service template view.
wlan service-template service-template-name
7.     (Optional.) Include or exclude region codes in beacon frames and probe responses and specify the installation environment type.
region-code-ie { disable | enable { any | indoor | outdoor } }
By default, beacon frames and probe responses contain region codes and the installation environment type is any.
Enabling GPS information reporting
This feature enables an AP installed with GPS antennas to output GPS information at intervals and send the GPS information to the information center. For more information about the destination and output rules in the information center, see System Management Configuration Guide.
2.     Enable GPS information reporting.
wlan gps-report enable
By default, GPS information reporting is disabled.
Setting the LED lighting mode
You can configure the LEDs on an AP to flash in the following modes:
·     quiet—Turns off LEDs.
·     awakeFlashes LEDs four times every second.
·     always-on—Turns on LEDs.
·     normal—How LEDs flash in this mode varies by AP model. This mode can identify the running status of an AP.
2.     Set the LED flash mode.
wlan led-mode { always-on | awake | normal | quiet }
By default, the LED lighting mode is normal.
Changing the operating mode for APs
After you change the operating mode for APs, the APs will use the factory default configuration or the configuration saved in the most recent change to the same operating mode.
2.     Change the operating mode for APs.
ap-mode { anchor-ac | cloud | fit }
Enabling or disabling PoE for PIs
2.     Enable or disable PoE for PIs.
poe port port-number1 [ to port-number2 ] { disable | enable }
By default, PoE is disabled on PIs.
Configuring the AP tag
An AP tag is a collection of AP parameter attributes. Based on the business characteristics of each application scenario, the device provides predefined AP tags for you to reference according to the actual network application scenarios. After you specify a tag, the AP can inherit the AP parameters defined in the AP tag without the need for manual configuration.
Currently, the following predefined AP tags are available:
·     meeting—Meeting room tag. This tag sets the bandwidth of 5GHz radios to 80 MHz.
·     high-density—High-density tag.
·     unstable—Unstable AP tag. When an AP with an unstable tag goes offline, it will not trigger automatic power adjustment for neighboring APs. This tag is assigned to APs automatically and does not support manual configuration.
2.     Configure the AP tag.
wlan ap-tag tag
By default, no AP tag is configured.
Display and maintenance commands for AP management
Display AP tags.
display wlan ap-tag { all | tag }
