| 02-WLAN IP snooping commands | 70.03 KB |
client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
client ipv4-snooping dhcp-learning timeout
client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
client ipv6-snooping snmp-nd-report enable
client ip-snooping acl
Use client ip-snooping acl to enable ACL-based learning of endpoint IP addresses.
Use undo client ip-snooping acl to restore the default.
client ip-snooping acl acl-number
ACL-based learning of endpoint IP addresses is disabled.
Service template view
acl-number: Specifies a basic ACL by its number. The value range for this argument is 2000 to 2999.
CAUTION: After you configure a deny rule in the ACL to reject learning specific endpoint IP addresses, you must configure a permit rule following the deny rule. The permit rule must allow learning all endpoint IP addresses. Otherwise, the device cannot learn any endpoint IP addresses. |
After connecting to a wireless network, a wireless endpoint will carry vendor information and an IP address obtained from that wireless network. If the endpoint accesses another vendor's network or another network later, the device on the new network might learn an incorrect IP address from the endpoint. To resolve this issue, enable ACL-based learning of endpoint IP addresses. This feature enables the device to learn IP addresses of new endpoints based on rules of the specified ACL.
When a wireless endpoint connects to a wireless network, the device performs the following task:
1. Matches IP address of that wireless endpoint against the specified ACL.
2. Determines whether to learn the endpoint IP address based on the match result as follows:
¡ If the endpoint IP address matches a permit rule in the ACL, the device will learn the endpoint IP address.
¡ If the endpoint IP address matches a deny rule or cannot match any rule in the ACL, the device will not learn the endpoint IP address.
This feature takes effect only if snooping ARP or ND packets is enabled.
If you execute this command multiple times, only the most recent configuration takes effect.
# Enable ACL-based learning of endpoint IP addresses.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] client ip-snooping acl 2000
Use client ipv4-snooping arp-learning enable to enable snooping ARP packets.
Use undo client ipv4-snooping arp-learning enable to disable snooping ARP packets.
Snooping ARP packets is enabled.
# Disable snooping ARP packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping arp-learning enable
Use client ipv4-snooping dhcp-learning enable to enable snooping DHCPv4 packets.
Use undo client ipv4-snooping dhcp-learning enable to disable snooping DHCPv4 packets.
Snooping DHCPv4 packets is enabled.
# Disable snooping DHCPv4 packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping dhcp-learning enable
Use client ipv4-snooping dhcp-learning timeout to set the timeout for IPv4 address learning through DHCP.
Use undo client ipv4-snooping dhcp-learning timeout to restore the default.
client ipv4-snooping dhcp-learning timeout time
The timeout is 0 and the system does not log off clients that fail to obtain an IPv4 address through DHCP.
time: Specifies the timeout in the range of 1 to 600 seconds.
With the timeout set, the system logs off clients that fail to obtain an IPv4 address through DHCP within the specified period.
Make sure the service template is enabled before you execute this command.
This configuration takes effect only on clients coming online afterwards from the AC.
# Set the timeout to 180 seconds for IPv4 address learning through DHCP.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] client ipv4-snooping dhcp-learning timeout 180
Use client ipv6-snooping dhcpv6-learning enable to enable snooping DHCPv6 packets.
Use undo client ipv6-snooping dhcpv6-learning enable to disable snooping DHCPv6 packets.
Snooping DHCPv6 packets is enabled.
WLAN IP snooping enables a device to learn client IPv6 addresses through snooping DHCPv6 packets and generate snooping entries that record client IPv6 addresses and MAC addresses. The entries will be used for accounting of 802.1X and MAC authentication users.
# Disable snooping DHCPv6 packets.
[Sysname-wlan-st-service1] client ipv6-snooping dhcpv6-learning enable
Use client ipv6-snooping nd-learning enable to enable snooping ND packets.
Use undo client ipv6-snooping nd-learning enable to disable snooping ND packets.
Snooping ND packets is enabled.
# Disable snooping ND packets.
[Sysname-wlan-st-service1] undo client ipv6-snooping nd-learning enable
Use client ipv6-snooping snmp-nd-report enable to enable SNMP to obtain client IPv6 addresses learned from ND packets.
Use undo client ipv6-snooping snmp-nd-report enable to disable SNMP from obtaining client IPv6 addresses learned from ND packets.
SNMP obtains client IPv6 addresses learned from both DHCPv6 and ND packets.
Make sure the service template is disabled when you execute this command.
# Disable SNMP from obtaining client IPv6 addresses learned from ND packets.
[Sysname-wlan-st-service1] undo client ipv6-snooping snmp-nd-report enable
