04-DPI Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath F1000[F5000] Firewalls Series Command Reference(V7)-6W90204-DPI Command Reference
08-Proxy policy commands
08-Proxy policy commands 248.87 KB
action
Use action to set the action for traffic matching a proxy policy rule.
Use undo action to restore the default.
action { no-proxy | ssl-decrypt | tcp-proxy }
undo action
The no-proxy action is used.
Proxy policy rule view
context-admin
no-proxy: Specifies the no-proxy action.
ssl-decrypt: Specifies the SSL decryption action.
tcp-proxy: Specifies the TCP proxy action.
The device supports the following actions for traffic matching a proxy policy rule:
·     No-proxy—The device directly transmits the traffic without TCP or SSL proxy.
·     SSL-decryption—The device acts as an SSL proxy to decrypt the SSL traffic and performs deep packet inspection and Layer 7 load balancing on the decrypted traffic. SSL decryption is implemented based on TCP proxy.
·     TCP-proxy—The device acts as a TCP proxy and provides TCP-layer isolation between the TCP client and TCP server to effectively intercept malicious connections and attacks.
If you execute this command for a proxy policy rule multiple times, the most recent configuration takes effect.
# Specify the ssl-decrypt action for proxy policy rule rule1.
[Sysname] app-proxy-policy
[Sysname-app-proxy-policy] rule 1 name rule1
[Sysname-app-proxy-policy-0-rule1] action ssl-decrypt
display app-proxy-policy
rule
app-proxy internal-server-certificate delete
Use app-proxy internal-server-certificate delete to delete an internal server certificate.
app-proxy internal-server-certificate delete md5 md5-value
context-admin
md5 md5-value: Specifies the MD5 value of an internal server certificate.
When an internal server certificate expires or an internal server does not need to be protected, you can execute this command to delete the imported internal server certificate.
You can execute the display app-proxy imported internal-server-certificate command to view the MD5 values of the internal server certificates.
# Delete the internal server certificate with the MD5 value c4f5f2c41ca1de4258d893c9887bf287.
[Sysname] app-proxy internal-server-certificate delete md5 c4f5f2c41ca1de4258d893c9887bf287
app-proxy internal-server-certificate import
Use app-proxy internal-server-certificate import to import an internal server certificate.
app-proxy internal-server-certificate import { p12 | pem } filename filename
context-admin
p12: Specifies the PKCS#12 certificate file format.
pem: Specifies the PEM certificate file format.
filename filename: Specifies the certificate file name, a case-insensitive string of 1 to 63 characters.
The internal server certificates are required in the scenario of protecting internal servers. With an internal server certificate imported, the device will decrypt the certificate and generate a CER file and a key file. The CER file is used to identify the server and the key file is used to encrypt and decrypt the packets in the subsequent SSL proxy process. The device will calculate the MD5 value of the CER file and use the MD5 value as the unique identifier of the file.
The SSL proxy process is as follows:
1.     The device receives an internal server certificate and calculates the MD5 value of the certificate.
2.     The device compares the calculated MD5 value with the MD5 value of the imported internal server certificate:
¡     If they are the same, the certificate is trusted and the device will use the certificate to establish an SSL connection with the client.
¡     If they are different, the certificate is untrusted.
You can import multiple internal server certificates. If two certificates have the same MD5 value, the new certificate will overwrite the old certificate.
# Import a PKCS#12 certificate file as an internal server certificate.
[Sysname] app-proxy internal-server-certificate import p12 filename server.p12
Password:
app-proxy ssl whitelist activate
Use app-proxy ssl whitelist activate to activate SSL proxy whitelist settings.
context-admin
The following SSL proxy whitelist settings must be manually activated by using this command:
·     Adding or removing hostnames to or from the user-defined SSL hostname whitelist.
·     Enabling or disabling hostnames on the predefined SSL hostname whitelist.
This command is supported only on the default context. For more information about contexts, see context configuration in Virtual Technologies Configuration Guide.
# Add example.com to the user-defined SSL hostname whitelist and activate the setting.
[Sysname] app-proxy ssl whitelist user-defined-hostname example.com
To activate the setting, execute app-proxy ssl whitelist activate.
[Sysname] app-proxy ssl whitelist activate
app-proxy ssl whitelist predefined-hostname enable
Use app-proxy ssl whitelist predefined-hostname enable to enable hostnames on the predefined SSL hostname whitelist.
Use undo app-proxy ssl whitelist predefined-hostname enable to disable hostnames on the predefined SSL hostname whitelist.
app-proxy ssl whitelist predefined-hostname { chrome-hsts [ hostname ] | hostname } enable
undo app-proxy ssl whitelist predefined-hostname { chrome-hsts [ hostname ] | hostname } enable
The entire predefined SSL hostname whitelist is enabled.
context-admin
chrome-hsts [ hostname ]: Specifies a hostname on the Chrome HSTS list. The hostname argument represents the hostname, a case-insensitive string of 1 to 63 characters. If the hostname contains spaces, enclose it in double quotation marks. For example, "user for test". If you do not specify a hostname, this command applies to all hostnames on the Chrome HSTS list.
host-name: Specifies a hostname that is not on the Chrome HSTS list. The hostname is a case-insensitive string of 1 to 63 characters. If the hostname contains spaces, enclose it in double quotation marks. For example, "user for test".
The Chrome HSTS list is a predefined list of server hostnames that are accessible to Web browsers only through HTTPS.
Follow these guidelines to enable or disable hostnames on the Chrome HSTS list:
·     When the entire Chrome HSTS list is enabled, you can disable individual hostnames on the list.
·     When the entire Chrome HSTS list is disabled, all hostnames on the list are disabled and cannot be enabled individually.
# Disable the entire Chrome HSTS list.
[Sysname] undo app-proxy ssl whitelist predefined-hostname chrome-hsts enable
# Disable hostname 12306.cn on the predefined SSL hostname whitelist.
[Sysname] undo app-proxy ssl whitelist predefined-hostname 12306.cn enable
display app-proxy ssl whitelist
Use app-proxy ssl whitelist user-defined-hostname host-name to add a hostname to the user-defined SSL hostname whitelist.
Use undo app-proxy ssl whitelist user-defined-hostname to remove hostnames from the user-defined SSL hostname whitelist.
undo app-proxy ssl whitelist user-defined-hostname { host-name | all }
context-admin
host-name: Specifies a hostname, a case-insensitive string of 1 to 63 characters. If the hostname contains spaces, enclose it in double quotation marks. For example, "user for test".
all: Specifies all hostnames on the user-defined SSL hostname whitelist.
If the DNS Name or Common Name value in a server certificate contains a hostname on the SSL hostname whitelist, the device does not proxy the SSL connections destined for the server.
This command must be manually activated by using the app-proxy ssl whitelist activate command.
# Add example.com to the user-defined SSL hostname whitelist and active the configuration.
app-proxy ssl-decrypt-certificate delete
Use app-proxy ssl-decrypt-certificate delete to delete an SSL decryption certificate.
app-proxy ssl-decrypt-certificate delete filename filename
context-admin
filename: Specifies an SSL decryption certificate by its file name, a case-insensitive string of 1 to 63 characters.
The device, acting as an SSL proxy, requires the correct SSL decryption certificate to issue proxy server certificates to send to clients for server authentication. If the required SSL decryption certificate is not available, the device cannot set up a connection with the client and the SSL traffic will be transmitted directly without SSL decryption.
After an SSL decryption certificate is imported, its file extension will be changed to .cer, which must be appended to the file name when you delete the certificate.
# Delete SSL decryption certificate aaa.cer.
[Sysname] app-proxy ssl-decrypt-certificate delete filename aaa.cer
display app-proxy ssl-decrypt-certificate
app-proxy ssl-decrypt-certificate import
Use app-proxy ssl-decrypt-certificate import to import a CA certificate as a trusted or untrusted SSL decryption certificate.
app-proxy ssl-decrypt-certificate import { trusted | untrusted } { pem | p12 } filename filename
context-admin
trusted: Imports the CA certificate as a trusted SSL decryption certificate.
untrusted: Imports the CA certificate as an untrusted SSL decryption certificate.
The device supports a maximum of one trusted SSL decryption certificate and one untrusted SSL decryption certificate. When importing an SSL decryption certificate, you must mark the certificate as Trusted or Untrusted. If you import multiple trusted or multiple untrusted SSL decryption certificates to the device, the most recent configuration takes effect.
To use the same CA certificate as both the trusted and untrusted SSL decryption certificate, first import the certificate with the Trusted or Untrusted tag, and then add the other tag to the certificate by using the app-proxy ssl-decrypt-certificate modify command.
After an SSL decryption certificate is imported, its file extension will be changed to .cer.
After receiving the certificate of the real server, the device verifies the legitimacy of the server certificate on behalf of the SSL client.
·     If the server certificate is legitimate, the device uses the trusted SSL decryption certificate to issue a new certificate to the client. A server certificate issued by the trusted SSL decryption certificate is trusted by the client.
·     If the server certificate is illegitimate, the device uses the untrusted SSL decryption certificate to issue a new certificate to the client. A security alarm will be generated on the client and users must clear the alarm to continue the access.
The trusted SSL decryption certificate must be installed on the client browser. Otherwise, the client cannot trust the proxy server certificate signed by the trusted SSL decryption certificate and might display a warning or directly terminate proxied SSL connections without a warning.
A Firefox browser does not use the SSL decryption certificate in the Windows certificate store by default. To use the SSL decryption certificate on the Firefox browser, you can take the following methods:
·     Import the SSL decryption certificate into the Firefox browser.
·     Configure the Firefox browser to use the SSL decryption certificate in the Windows certificate store through the following steps:
a.     Enter about:config in the address bar.
b.     In the Search box, enter security.enterprise_roots.enabled.
c.     Locate this entry, and double-click or right-click its value to change false to true.
# Import a PKCS#12 certificate file as a trusted SSL decryption certificate.
[Sysname] app-proxy ssl-decrypt-certificate import trusted p12 filename aaa.p12
Password:
display app-proxy ssl-decrypt-certificate certificate
Use app-proxy ssl-decrypt-certificate modify to add the Trusted or Untrusted tag to an SSL decryption certificate.
Use undo app-proxy ssl-decrypt-certificate modify to remove the Trusted or Untrusted tag from an SSL decryption certificate.
app-proxy ssl-decrypt-certificate modify { trusted | untrusted } filename filename
undo app-proxy ssl-decrypt-certificate modify { trusted | untrusted }
context-admin
trusted: Specifies the Trusted tag.
untrusted: Specifies the Untrusted tag.
filename: Specifies the SSL decryption certificate by its file name, a case-insensitive string of 1 to 63 characters.
To use the same CA certificate as both the trusted and untrusted SSL decryption certificate, first import the certificate with the Trusted or Untrusted tag, and then use this command add the other tag to the certificate.
When you add the Trusted or Untrusted tag to an SSL decryption certificate, the system asks whether you want to overwrite the SSL decryption certificate with the same tag if such a certificate already exists.
Removing the Trusted or Untrusted tag from an SSL decryption certificate does not remove the certificate file from the system. You can use the app-proxy ssl-decrypt-certificate modify command to add the Trusted or Untrusted tag to the certificate again.
After an SSL decryption certificate is imported, its file extension will be changed to .cer. Append the .cer file extension when you specify the file containing the certificate whose credibility you want to change.
# Add the Trusted tag to the CA certificate in certificate file aaa.
[Sysname] app-proxy ssl-decrypt-certificate modify trusted filename aaa.cer
[Sysname] A trusted CA certificate already exists. Overwrite the existing trusted CA certificate with the specified certificate? [Y/N]:
app-proxy-policy
Use app-proxy-policy to enter proxy policy view.
Use undo app-proxy-policy to remove all proxy policy configurations.
app-proxy-policy
context-admin
The device supports only one IPv4 proxy policy.
# Enter proxy policy view.
default action
Use default-action to specify the default action for the proxy policy.
Use undo default-action to restore the default.
default action { no-proxy | ssl-decrypt | tcp-proxy }
undo default action
The proxy policy uses the no-proxy action.
Proxy policy view
context-admin
The default action applies to packets that do not match any rules in the proxy policy.
# Set the default action to ssl-decrypt for the proxy policy.
[Sysname-app-proxy-policy] default action ssl-decrypt
default ssl-decrypt protect-mode
Use default ssl-decrypt protect-mode to specify an SSL decryption protection mode for the proxy policy.
Use undo default ssl-decrypt protect-mode to restore the default.
default ssl-decrypt protect-mode { client | server }
The SSL decryption protection mode of the proxy policy is client.
Proxy policy view
context-admin
client: Specifies client protection.
server: Specifies server protection.
The SSL decryption supports the following protection services:
·     Internal client protection—The device is deployed at the exit of the network where the internal clients are. When the internal clients access an external server, the device acts as a proxy server to decrypt the packets and perform deep packet inspection on the decrypted packets. It protects the internal clients from being attacked by external malicious websites. In this scenario, the device requires imported SSL decryption certificates to establish SSL connections with the clients.
·     Internal server protection—The device is deployed at the entrance of the network where the internal servers are. When the external clients access an internal server, the device acts as a proxy server to decrypt the packets and perform deep packet inspection on the decrypted packets. It protects the internal servers from being attacked by external malicious traffic. In this scenario, the device requires imported internal server certificates to establish SSL connections with the clients.
For more information about DPI, see "DPI overview."
By default, the SSL proxy protects the internal clients. You can select a protection service of the SSL decryption as required and import the corresponding certificates to the device for SSL connection establishment with the clients.
This command takes effect only when the SSL decryption action is used as the default action for the proxy policy.
# Specify server as the SSL decryption protection mode for the proxy policy.
[Sysname-app-proxy-policy] default ssl-decrypt protect-mode server
destination-ip object-group
Use destination-ip object-group to configure an object group as a destination address filtering criterion in a proxy policy rule.
Use undo destination-ip object-group to remove destination address filtering criteria from a proxy policy rule.
destination-ip object-group object-group-name
undo destination-ip object-group [ object-group-name ]
A proxy policy rule does not contain any destination address filtering criterion.
context-admin
object-group-name: Specifies an IP address object group by its name, a case-insensitive string of 1 to 63 characters. The object group must already exist and its name cannot be any.
You can repeat this command to set multiple destination address filtering criteria in a proxy policy rule. A packet passes the destination address filtering if it matches any of the configured destination address filtering criteria.
If you execute the undo destination-ip object-group command without specifying an object group, all destination address filtering criteria in the proxy policy rule will be deleted.
For more information about object groups, see object group configuration in Security Configuration Guide.
# In proxy policy rule rule1, set IP address object groups client1 and client2 as destination address filtering criteria.
[Sysname-app-proxy-policy-0-rule1] destination-ip object-group client1
[Sysname-app-proxy-policy-0-rule1] destination-ip object-group client2
object-group (Security Command Reference)
destination-zone
Use destination-zone to configure a destination security zone filtering criterion in a proxy policy rule.
Use undo destination-zone to remove destination security zone filtering criteria from a proxy policy rule.
destination-zone destination-zone-name
undo destination-zone [ destination-zone-name ]
A proxy policy rule does not contain any destination security zone filtering criterion.
context-admin
destination-zone-name: Specifies a destination security zone by its name, a case-insensitive string of 1 to 31 characters. The destination security zone name cannot be any.
You can repeat this command to set multiple destination security zone filtering criteria in a proxy policy rule. A packet passes the destination security zone filtering if it matches any of the configured destination security zone filtering criteria.
You can specify a nonexistent security zone for a destination security zone filtering criterion. However, the destination security zone filtering criterion does not take effect until the security zone is configured.
If you execute the undo destination-zone command without specifying a security zone, all destination security zone filtering criteria in the proxy policy rule will be deleted.
For more information about security zones, see security zone configuration in Security Configuration Guide.
# In proxy policy rule rule1, set security zones trust and server as destination security zone filtering criteria.
[Sysname-app-proxy-policy-0-rule1] destination-zone trust
[Sysname-app-proxy-policy-0-rule1] destination-zone server
security-zone (Security Configuration Guide)
disable
Use disable to disable a proxy policy rule.
Use undo disable to enable a proxy policy rule.
disable
undo disable
A proxy policy rule is enabled.
context-admin
The device compares a packet against only the enabled proxy policy rules. The match process stops once a matching rule is found.
# Disable proxy policy rule rule1.
[Sysname-app-proxy-policy-0-rule1] disable
Rule
Use display app-proxy imported internal-server-certificate to display information about imported internal server certificates.
context-admin
context-operator
The information about the imported internal server certificates includes MD5 values, data, and signature algorithms.
# Display information about imported internal server certificates.
<Sysname> display app-proxy imported internal-server-certificate
Certificate Md5: c4f5f2c41ca1de4258d893c9887bf287
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            aa:31:f8:3d:06:b0:9b:   Signature Algorithm: sha1WithRSAEncryption
        Issuer: C=CN, ST=bj, L=cp, O=dpi, OU=sec, CN=trustca
        Validity
            Not Before: Sep  7 12:00:43 2017 GMT
            Not After : Aug 28 12:00:43 2057 GMT
        Subject: C=CN, ST=bj, L=cp, O=dpi, OU=sec, CN=trustca
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (2048 bit)
                Modulus:
                    00:ec:d7:73:af:03:07:07:86:e6:31:4d:e5:32:09:
                    20:7f:93:19:20:b2:25:c4:cc:32:8e:e4:29:fd:e0:
                    30:48:4c:8d:0a:83:66:28:af:6a:e0:69:81:08:58:
                    ca:cf:e4:3d:5a:e8:69:92:67:71:e3:c0:66:87:8e:
                    16:cc:6a:89:1d:d4:22:5f:93:14:47:bd:39:60:44:
                    3c:ee:0a:d1:8d:d4:16:84:65:e9:b7:b1:0f:6d:af:
                    6e:ef:21:b5:5a:02:4f:63:46:6e:8b:73:b5:95:70:
                    8a:ed:5d:23:8b:d8:0e:45:2d:8b:52:ab:34:6d:3b:
                    d5:85:ae:1c:d4:26:6e:fb:2c:1e:18:db:55:22:96:
                    d8:1f:1a:33:e9:ff:1f:8c:be:28:9d:de:77:d8:9b:
                    a7:27:0f:7e:e2:52:3e:bd:02:ee:c3:06:93:d0:16:
                    b0:c7:96:bb:c8:b1:96:8d:ee:ca:6e:76:63:1e:b1:
                    b6:fb:31:bf:d0:13:66:ad:f6:97:cf:0b:37:f7:6c:
                    f8:46:b6:76:f1:70:6f:24:6c:92:a6:dd:c2:3b:cf:
                    3c:35:c7:74:60:dd:db:a3:bf:70:b4:55:05:4b:d7:
                    cd:dd:c1:1b:59:0d:41:e7:95:5a:79:44:9d:b0:8b:
                    a7:f2:f4:67:0e:0c:4a:b6:35:97:1e:e6:99:88:fc:
                    c8:e9
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Subject Alternative Name:
                IP Address:1.1.1.1, DNS:trustca, email:[email protected]
            X509v3 Basic Constraints: critical
                CA:TRUE
            X509v3 Key Usage: critical
                Certificate Sign, CRL Sign
            X509v3 Subject Key Identifier:
                D4:35:A8:66:63:03:04:2B:CA:4E:91:06:11:F5:72:1C:26:E0:BE:33
            Netscape Cert Type:
                SSL CA
            Netscape Comment:
                example comment extension
         b9:d2:eb:98:bd:f9:8d:7e:03:a8:0e:b4:29:cf:3a:a1:fd:f4:
         2a:fa:56:1c:cf:40:a4:9e:7f:5a:15:6b:88:8a:dd:86:d2:03:
         c3:38:49:7a:11:09:78:81:8c:8f:0a:3b:fb:d6:60:59:c4:0b:
         12:0e:38:b0:92:f3:2e:b5:96:ab:d3:a4:2d:cb:ef:fd:a0:97:
         d0:63:43:8e:91:1f:f1:fc:39:c8:cf:e5:ee:4b:e7:8c:8b:f8:
         3b:ff:5e:dc:00:df:5b:2f:98:53:f2:c7:da:fa:b8:2e:92:dd:
         33:6a:80:df:0e:22:62:62:5d:2f:6c:eb:4c:80:c4:56:c9:00:
         01:a6:82:60:e4:32:69:f7:7b:8f:6c:93:e5:c3:64:65:fe:aa:
         e1:0b:10:92:bd:ea:2f:2f:e5:b6:fd:b5:5b:df:34:c8:5d:5a:
         91:9a:0d:89:10:76:b8:ed:28:ef:6a:c4:7b:48:d7:88:57:7c:
         cf:4e:c8:38:84:ad:54:6d:3f:40:a0:38:d7:36:61:23:7a:82:
         62:34:41:3d:cc:b2:ee:4a:23:f1:7d:12:e2:23:26:10:df:c8:
         a1:6f:00:00:b7:c2:1f:ce:1b:63:60:e0:63:33:e0:59:31:78:
         bc:27:99:b6:27:40:95:da:1b:37:07:75:2f:99:97:56:33:f5:
         4f:ad:14:31
Figure 1 Command output
Certificate Md5
Certificate
Information about the certificate.
Version
Version number of the certificate.
Serial Number
Serial number of the certificate.
Signature Algorithm
Signature algorithm used in the certificate.
Issuer
Issuer of the certificate.
Validity
Validity of the certificate.
Subject
Identity of the entity to which the certificate belongs.
Public key information of the certificate subject.
Modulus
Modulus length of the key.
Exponent
Key exponent.
X509v3 extensions
X.509v3 extensions in the certificate.
Alternative name of the certificate subject.
IP Address
IP address of the certificate subject.
DNS
DNS name of the certificate subject.
email
Email address of the certificate subject.
Indicates whether the certificate belongs to a CA.
X509v3 Key Usage
Identifies the cryptographic operations which may be performed using the public key contained in the certificate.
Key identifier of the certificate subject.
Netscape Cert Type
Netscape certificate type, an extension defined by Netscape to limit what the certificate can be used for.
Netscape Comment
Netscape comment that can be displayed in certain browsers.
app-proxy server-certificate import
app-proxy server-certificate delete
display app-proxy server-certificate
Use display app-proxy server-certificate to display the SSL server certificates received by the device as the SSL proxy client.
display app-proxy server-certificate [ slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays certificate information on all member devices.
When implementing the SSL proxy function, the device acts as the SSL proxy client to complete the SSL handshake and establish an SSL connection with the SSL server. This command displays information about the SSL server certificates received by the device as the SSL proxy client.
# Display the SSL server certificates received by the device as the SSL proxy client on slot 1.
<Sysname> display app-proxy server-certificate slot 1
Slot1:
Total server certificates: --
Certificate info: /cn=h3c-https-self-signed-certificate-13a73249669cc70a
     Proxy count: 198
     Most recent proxy time: 2017/10/25 10:7:7
     First proxy at: 2017/10/23 15:52:59
Figure 2 Command output
Total number of server certificates received by the device as the SSL proxy client.
Certificate info
Information about the certificate. This field displays the value in the DNS Name field (in the format of example.com) of the certificate. If the server certificate does not contain the DNS Name field, the value in the Common Name field (in the format of /cn=example.com) is displayed.
Proxy count
Number of times connections to the server had been proxied.
Most recent time the device proxied a connection to the server.
First proxy at
First time the device proxied a connection to the server.
reset app-proxy server-certificate
display app-proxy ssl whitelist hostname
Use display app-proxy ssl whitelist hostname to display the SSL hostname whitelist.
display app-proxy ssl whitelist hostname { predefined | user-defined }
context-admin
context-operator
user-defined: Displays the user-defined SSL hostname whitelist.
predefined: Displays the predefined SSL hostname whitelist.
# Display the user-defined SSL hostname whitelist.
<Sysname> display app-proxy ssl whitelist hostname user-defined
Hostname
example1.com
example2.com
# Display the predefined SSL hostname whitelist.
<Sysname> display app-proxy ssl whitelist hostname predefined
Chrome HSTS-defined hostnames:
  status      Hostname
  enabled     2mdn.net
  enabled     accounts.firefox.com
  enabled     aclu.org
  enabled     activiti.alfresco.com
  enabled     adamkostecki.de
  enabled     addvocate.com
  enabled     adsfund.org
  enabled     aie.de
  enabled     airbnb.com
  enabled     aladdinschools.appspot.com
  enabled     alexsexton.com
  enabled     alpha.irccloud.com
  enabled     android.com
  enabled     ansdell.net
  enabled     anycoin.me
  enabled     apadvantage.com
  enabled     api.intercom.io
  enabled     api.lookout.com
  enabled     api.mega.co.nz
  enabled     api.recurly.com
  enabled     api.simple.com
---- More ----
Figure 3 Command output
List of Chrome HSTS-defined hostnames accessible only through HTTPS.
Status
State of the hostname on the SSL hostname whitelist, Enabled or Disabled.
display app-proxy ssl whitelist { ipv4 | ipv6 }
Use display app-proxy ssl whitelist { ipv4 | ipv6 } to display the SSL IP address whitelist.
display app-proxy ssl whitelist { ipv4 | ipv6 } { all [ slot slot-number ] | ip-address }
context-admin
context-operator
ipv4: Specifies the SSL IPv4 address whitelist.
ipv6: Specifies the SSL IPv6 address whitelist.
all: Specifies all IP addresses on the SSL IP address whitelist.
ip-address: Specifies the IP address of an SSL IP address whitelist entry to be displayed.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the SSL IP address whitelist information on all member devices.
# Display the SSL IPv4 address whitelist on slot 1.
<Sysname> display app-proxy ssl whitelist ipv4 all slot 1
Slot 1:
IPv4 address              Port
10.1.1.1                443
10.10.1.1               443
Figure 4 Command output
IPv4 address
IPv4 address in an SSL IP address whitelist entry.
IPv6 address
IPv6 address in an SSL IP address whitelist entry.
Port
Port number of the SSL IP address whitelist entry. Connections destined for a server with the IP address and port number matching an IP address whitelist entry will not be proxied.
Use display app-proxy ssl-decrypt-certificate to display SSL decryption certificate information.
context-admin
context-operator
# Display SSL decryption certificate information.
<Sysname> display app-proxy ssl-decrypt-certificate
Trusted:
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
        Validity
                Modulus:
                    c8:e9
        X509v3 extensions:
                CA:TRUE
            Netscape Cert Type:
                SSL CA
            Netscape Comment:
         4f:ad:14:31
Figure 5 Command output
Trusted
Credibility of the SSL decryption certificate, Trusted or Untrusted.
Version
Serial Number
Signature Algorithm
Issuer
Validity
Subject
Modulus
Exponent
Key exponent.
X509v3 extensions
IP Address
DNS
email
X509v3 Key Usage
Netscape Cert Type
Netscape Comment
Use display app-proxy-policy to display proxy policy information.
display app-proxy-policy [ rule rule-name ]
context-admin
context-operator
rule rule-name: Specifies a proxy policy rule by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a proxy policy rule, this command displays information about all proxy policy rules.
# Display proxy policy information and all rules in the policy.
<Sysname> display app-proxy-policy
Default action: ssl-decrypt (Protect mode: server)
Rule with ID 0 and name rule0:
  Action: ssl-decrypt
  Status: Enabled
  Match criteria:
   Source security zones: trust
   Destination security zones: trust
   Source IP address object groups: srcobj
   Destination IP address object groups: destobj
   Service object groups: serviceobj
   Users: user1
   User groups: usergroup1
  Rule with ID 2 and name rule2:
  Action: ssl-decrypt
  Status: Enabled
  Match criteria:
  source-zone: trust
  destination-zone: Untrust
  Protection mode: Client
Figure 6 Command output
Default action
Default action of the policy:
·     no-proxy.
·     ssl-decrypt.
·     tcp-proxy.
(Protect mode: XXX)
SSL decryption protection mode of the proxy policy:
·     client—Protects internal clients from attacks.
·     server—Protects internal servers from attacks.
This field is available only when the SSL decryption action is used as the default action for the proxy policy.
Rule with ID rule-id and name rule-name
ID and name of a proxy policy rule.
Action
Action for traffic matching the proxy policy rule:
·     no-proxy.
·     ssl-decrypt.
·     tcp-proxy.
Protect mode
SSL decryption protection mode of the proxy policy rule:
·     server—Protects internal clients from attacks.
Source security zones to which the proxy policy rule applies.
Destination security zones to which the proxy policy rule applies.
Source IP address object groups to which the proxy policy rule applies.
Destination IP address object groups to which the proxy policy rule applies.
Service object groups to which the proxy policy rule applies.
Users
Users to whom the proxy policy rule applies.
User groups
User groups to which the proxy policy rule applies.
Use reset app-proxy server-certificate to clear information about the SSL server certificates received by the device as the SSL proxy client.
context-admin
# Clear information about the SSL server certificates received by the device as the SSL proxy client.
<Sysname> reset app-proxy server-certificate
reset app-proxy ssl whitelist ip
Use reset app-proxy ssl whitelist ip to clear the SSL IP address whitelist.
context-admin
# Clear the SSL IP address whitelist.
<Sysname> reset app-proxy ssl whitelist ip
rule
Use rule to create a proxy policy rule and enter its view, or enter the view of an existing proxy policy rule.
Use undo rule to remove a proxy policy rule.
rule { rule-id | [ rule-id ] name rule-name }
undo rule { rule-id | name rule-name }
Proxy policy view
context-admin
rule-id: Specifies a rule ID, which must be an integer in the range of 1 to 65535. If you do not specify a rule ID when creating a rule, the system automatically assigns a rule ID that is larger than that the largest rule ID already used. If rule ID 65535 is already used, the system assigns the smallest unused ID to the rule.
name rule-name: Specifies a rule name, a case-insensitive string of 1 to 63 characters. The rule name is required when you create a rule and it cannot be set to default.
# Create rule 1 named rule1.
[Sysname-app-proxy-policy-1-rule1]
rule move
Use rule move to move a proxy policy rule to a new position.
rule move rule-id before insert-rule-id
Proxy policy view
context-admin
rule-id: Specifies the target rule to be moved by its ID in the range of 1 to 65535. The specified rule must already exist.
insert-rule-id: Specifies the reference rule ID in the range of 1 to 65535. This target rule is moved to the position before the reference rule. To move the rule to the end of all rules, set the reference rule ID to 65535. The specified reference rule must already exist.
# Move rule 5 to the position before rule 2.
[Sysname-app-proxy-policy] rule move 5 before 2
rule
service
Use destination-zone to configure a service filtering criterion in a proxy policy rule.
Use undo destination-zone to remove service filtering criteria from a proxy policy rule.
service object-group { object-group-name }
undo service object-group [ object-group-name ]
A proxy policy rule does not contain any service filtering criterion.
context-admin
object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 63 characters. The object group must already exist and its name cannot be any.
You can repeat this command to set multiple service filtering criteria in a proxy policy rule. A packet passes the service filtering if it matches any of the service filtering criteria.
For successful service filtering criterion configuration, make sure the specified service object group does not contain Layer 5 or higher layer protocols.
If you execute the undo service object-group command without specifying an object group zone, all service filtering criteria in the proxy policy rule will be deleted.
# In proxy rule rule1, specify object groups ftp as a service filtering criterion.
[Sysname-app-proxy-policy-0-rule1] service object-group ftp
source-ip object-group
Use source-ip object-group to configure an object group as a source address filtering criterion in a proxy policy rule.
Use undo source-ip object-group to remove source address filtering criteria from a proxy policy rule.
source-ip object-group object-group-name
undo source-ip object-group [ object-group-name ]
A proxy policy rule does not contain any source address filtering criterion.
context-admin
You can repeat this command to set multiple source address filtering criteria in a proxy policy rule. A packet passes the source address filtering if it matches any of the configured destination address filtering criteria.
If you execute the undo source-ip object-group command without specifying an object group, all source address filtering criteria in the proxy policy rule will be deleted.
# In proxy policy rule rule1, specify IP address object groups server1 and server2 as source address filtering criteria.
[Sysname-app-proxy-policy-0-rule1] source-ip object-group server1
[Sysname-app-proxy-policy-0-rule1] source-ip object-group server2
source-zone
Use source-zone to configure a source security zone filtering criterion in a proxy policy rule.
Use undo source-zone to remove source security zone filtering criteria from a proxy policy rule.
source-zone source-zone-name
undo source-zone [ source-zone-name ]
A proxy policy rule does not contain any source security zone filtering criterion.
context-admin
source-zone-name: Specifies a source security zone by its name, a case-insensitive string of 1 to 31 characters. The source security zone name cannot be any.
You can repeat this command to set multiple source security zone filtering criteria in a proxy policy rule. A packet passes the source security zone filtering if it matches any of the configured source security zone filtering criteria.
You can specify a nonexistent security zone for a source security zone filtering criterion. However, the source security zone filtering criterion does not take effect until the security zone is configured.
If you execute the undo source-zone command without specifying a security zone, all source security zone filtering criteria in the proxy policy rule will be deleted.
# In proxy policy rule rule1, specify security zones trust and server as source security zone filtering criteria.
[Sysname-app-proxy-policy-0-rule1] source-zone trust
[Sysname-app-proxy-policy-0-rule1] source-zone server
security-zone (Security Command Reference)
Use ssl-decrypt protect-mode to specify an SSL decryption protection mode for a proxy policy rule.
Use ssl-decrypt protect-mode to restore the default.
undo ssl-decrypt protect-mode
The SSL decryption protection mode of a proxy policy rule is client.
context-admin
# Specify server as the SSL decryption protection mode for proxy policy rule rule1.
[Sysname-app-proxy-policy-0-rule1] ssl-decrypt protect-mode server
user
Use user to configure a user filtering criterion in a proxy policy rule.
Use undo user to remove user filtering criteria from a proxy policy rule.
user user-name [ domain domain-name ]
undo user [ username [ domain domain-name ] ]
A proxy policy rule does not contain any user filtering criterion.
context-admin
username: Specify a username, a case-sensitive string of 1 to 55 characters. The username cannot be a, al, or all, and cannot contain special characters listed in Table 1.
Table 1 Special characters
Character name
Symbol
Backslash
Vertical bar
Forward slash
Colon
Asterisk
Question mark
Left angle bracket
Right angle bracket
At sign
domain domain-name: Specifies the name of the identity domain to which the user belongs. The identity domain name is a case-insensitive string of 1 to 255 characters which cannot contain special characters listed in Table 1.
You can repeat this command to set multiple user filtering criteria in a proxy policy rule. A packet passes the user filtering if it matches any of the user filtering criteria.
If the specified user does not exist for the following reasons, the configuration succeeds but does not take effect:
·     The user does not exist.
·     The domain does not exist.
·     The user does not exist in the domain.
For successful user filtering criterion configuration, the user must exist and belong to the domain, if specified.
Follow these guidelines when you execute the undo user command:
·     To remove all user filtering criteria in a proxy policy rule, do not specify any parameters.
·     To remove a user in a domain as a user filtering criterion, specify the username parameter with the domain domain-name option.
·     To remove a user that does not belong to any identity domains, specify the username parameter without the domain domain-name option.
# In proxy rule rule1, specify users usera and userb in domain test as user filtering criteria.
[Sysname-app-proxy-policy-0-rule1] user usera domain test
[Sysname-app-proxy-policy-0-rule1] user userb domain test
user-identity enable (Security Command Reference)
user-identity static-user (Security Command Reference)
user-group
Use user-group to configure a user group filtering criterion in a proxy policy rule.
Use undo user-group to remove user group filtering criteria from a proxy policy rule.
user-group user-group-name [ domain domain-name ]
undo user-group [ user-group-name [ domain domain-name ] ]
A proxy policy rule does not contain any user group filtering criterion.
context-admin
user-group-name: Specify a user group by its name, a case-insensitive string of 1 to 200 characters.
domain domain-name: Specifies the name of the identity domain to which the user group belongs. The identity domain name is a case-insensitive string of 1 to 255 characters which cannot contain special characters listed in Table 2.
Table 2 Special characters
Character name
Symbol
Backslash
Vertical bar
Forward slash
Colon
Asterisk
Question mark
Left angle bracket
Right angle bracket
At sign
You can repeat this command to set multiple user group filtering criteria in a proxy policy rule. A packet passes the user group filtering if it matches any of the user group filtering criteria.
The command succeeds but does not take effect if the specified user group does not exist for the following reasons:
Follow these guidelines when you execute the undo user-group command:
·     To remove all user group filtering criteria in a proxy policy rule, do not specify any parameters.
·     To remove a user group in a domain as a user group filtering criterion, specify the user-group-name parameter with the domain domain-name option.
·     To remove a user group that does not belong to any identity domains, specify the user-group-name parameter without the domain domain-name option.
For more information about user groups, see user identification configuration in Security Configuration Guide.
# In proxy rule rule1, specify user groups groupa and groupb in domain test as user group filtering criteria.
[Sysname-app-proxy-policy-0-rule1] user-group groupa domain test
[Sysname-app-proxy-policy-0-rule1] user-group groupb domain test
user-group (Security Command Reference)
