- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-License management commands
- 05-Device management commands
- 06-FTP and TFTP commands
- 07-File system management commands
- 08-RAID management commands (security devices)
- 09-Configuration file management commands
- 10-Software upgrade commands
- 11-ISSU commands
- 12-Automatic configuration commands
- 13-Tcl commands
- 14-Python commands
| 08-RAID management commands (security devices) | 65.11 KB |
add raid
Use add raid to add a file system to level-1 RAID.
add raid raid-name file-system
raid-name: Specifies the name of level-1 RAID. The value can only be md0.
file-system: Specifies a file system by its name.
This command is supported only on the default context.
You can use this command to add a file system only to level-1 RAID.
Before you add a file system to level-1 RAID, make sure the file system has been mounted to the device.
Adding a file system to level-1 RAID deletes all data from the file system.
To ensure that a file system can be added to level-1 RAID successfully, make sure the file system meets the following requirements:
· The disk size of the file system is equal to or larger than the size of the existing disks in the RAID.
· The file system is not used by other processes.
# Add file system hda0 to level-1 RAID.
<Sysname> add raid md0 hda0:
Add file system hda0 to RAID md0? [Y/N]:y
·······Added the file system successfully.
create raid
create raid
Use create raid to create a RAID.
create raid level raid-level { file-system }&<2-n>
level raid-level: Specifies a level for the RAID. The level can only be 0 or 1.
file-system&<2-n>: Specifies a minimum of two file systems by their names. The maximum number of file systems supported in a RAID equals the number of hard disk partitions.
You can create only one RAID on the device. The RAID name is fixed at md0. The level can be level 0 or 1.
· To change the RAID level, you must first use the remove raid command to remove the original RAID.
· If a RAID has been created on the device, you must remove that RAID before you can create a new RAID.
RAID is not supported on an IRF fabric in the current software version.
# Create level-1 RAID.
<Sysname> create raid level 1 hda0: hdb0:
Create RAID md0? [Y/N]:y
················Created RAID successfully.
display raid status
Use display raid status to display RAID status information.
display raid status
# Display status information about level-1 RAID.
<Sysname> display raid status
Name Level State Sync Remaining(GB) File systems
md0 1 active 66.6% 447 hda0[0] hdb0[1]
# Display status information about level-0 RAID.
md0 0 active None 447 hda0[0] hdb1[1]
# Display status information about level-1 RAID. The RAID has a hot backup disk.
md0 1 active Done 447 hda0[0] hdb0[1]
hdc0[2](S)
Name |
RAID name. |
Level |
RAID level. |
State |
RAID running state: · active—The RAID is running correctly. · inactive—The RAID is not running correctly. Data cannot be read from or written to the RAID correctly. |
Sync |
File system synchronization state in the RAID: · A percentage—Synchronizing. · Done—The synchronization has completed. · None—The RAID has only one file system. |
Remaining (GB) |
Available amount of storage space in the RAID. |
File systems |
File systems in the RAID. The number enclosed into a pair of brackets ([n]) represents the order that a file system joins the RAID. The file systems are separated by spaces. The following file system states are available: · Normal—The file system name is displayed in the format of name[n]. · Faulty—The file system name is displayed in the format of name[n](F). · Spare—The file system name is displayed in the format of name[n](S). You can use the add raid command to add a file system to level-1 RAID as a hot backup file system. |
remove raid
Use remove raid to remove a RAID or remove a file system from level-1 RAID 1.
remove raid raid-name [ file-system&<1-n> ]
raid-name: Specifies a RAID by its name. The value can only be md0.
file-system: Specifies a file system by its name or a list of file systems by their names. The maximum number of file systems you specify cannot exceed the number of file systems in the level-1 RAID. If you do not specify a file system, this command removes the entire RAID.
You can use this command to remove a file system only from level-1 RAID.
Before you remove a disk in level-1 RAID, execute this command to remove the file system of that disk from the RAID. This operation avoids data loss caused by disk removal.
Before you remove a file system from level-1 RAID, use the display raid status command to verify that the Sync field displays Done for the file system. This operation ensures successful file system removal. If you remove the entire RAID, you do not need to verify the synchronization state.
# Remove file system hda0 from level-1 RAID.
<Sysname> remove raid md0 hda0:
Remove file system hda0 from RAID md0? [Y/N]:y
······Removed the file system successfully.
# Remove level-0 RAID or level-1 RAID.
Remove RAID md0? [Y/N]:y
······ Removed the RAID successfully.
create raid
display raid status
