H3C G6 Servers Eagle Stream Platform BIOS User Guide-6.00.XX & 6.10.XX-6W109
HomeSupportConfigure & DeployUser ManualsH3C G6 Servers Eagle Stream Platform BIOS User Guide-6.00.XX & 6.10.XX-6W109
01-Text
01-Text 11.64 MB
About the BIOS·· 1
Introduction· 1
Applicable products· 1
Using this document 2
Common BIOS tasks· 3
Entering the BIOS setup utility· 3
Setting the BIOS language· 6
Setting the BIOS setup mode· 6
Displaying processor information· 7
Displaying memory information· 8
Displaying onboard drive information· 9
Configuring PCIe ports· 10
Configuring PXE for NICs· 12
Configuring TXT· 13
Setting HDM network information· 14
Configuring BIOS passwords· 16
About this task· 16
Restrictions and guidelines· 17
Setting a BIOS password· 18
Deleting a BIOS password· 18
Setting the system date and time· 20
Setting the BIOS boot mode· 21
Setting the server boot order 22
Enabling or disabling iFIST· 24
Logging in to iFIST· 24
Configuring serial port redirection· 25
Configuring RAID·· 26
Restoring BIOS default settings· 26
BIOS menus· 28
Main menu· 28
Advanced menu· 29
Socket Configuration submenu· 31
Platform Configuration submenu· 61
Dynamic Device Configuration submenu· 72
Trusted Computing submenu· 88
ACPI Settings submenu· 89
Serial Port Console Redirection submenu· 89
PCI Subsystem Settings submenu· 95
USB Configuration submenu· 96
CSM Configuration submenu· 97
NVMe Configuration submenu· 99
Network Configuration submenu· 99
Miscellaneous Configuration submenu· 102
GPU Configuration submenu· 103
Driver Health submenu· 105
Server menu· 105
Security menu· 116
Boot menu· 119
Exit menu· 122
Industry standards· 124
BIOS options and corresponding Redfish out-of-band attributes· 125
FAQ·· 133
PCIe 10-bit tag support prompt box appears when no settings are edited for the R5500 G6 Intel server 133
Acronyms and abbreviations· 134
About the BIOS
Introduction
The Basic Input and Output System (BIOS) is a non-volatile firmware stored in the system ROM of a server. It is used to perform hardware initialization during server booting and provide runtime services for the operating systems. As shown in Figure 1, the BIOS interacts between the server hardware and the operating system (OS).
Figure 1 Layered architecture of a server system
Applicable products
This document is applicable to the following products:
·     H3C UniServer E3300 G6
·     H3C UniServer R4500 G6
·     H3C UniServer R4300 G6
·     H3C UniServer R4700 G6
·     H3C UniServer R4700LE G6
·     H3C UniServer R4900 G6
·     H3C UniServer R4900LE G6 Ultra
·     H3C UniServer R4900 G6 Ultra
·     H3C UniServer R5300 G6
·     H3C UniServer R5500 G6
·     H3C UniServer R6900 G6
·     H3C UniServer R6700 G6
·     H3C UniServer B5700 G6
Intel Emerald Rapids CPUs support only the BIOS-6.10.XX and later versions.
Using this document
The information in this document is subject to change over time. You can access the H3C website to obtain the most recent version of the BIOS.
The information in this document might differ from your product if it contains custom configuration options or features.
The figures used in this document are for illustration only and might differ from your product.
Options on the BIOS screen vary by product or version and some options might be hidden and only used for internal debugging. To avoid impact on system operation, do not display or edit the hidden options without professional guidance.
Common BIOS tasks
This section provides procedures for the following common BIOS tasks:
·     Entering the BIOS setup utility
·     Setting the BIOS language
·     Setting the BIOS setup mode
·     Displaying processor information
·     Displaying memory information
·     Displaying onboard drive information
·     Configuring PCIe ports
·     Configuring PXE for NICs
·     Configuring TXT
·     Setting HDM network information
·     Configuring BIOS passwords
·     Setting the system date and time
·     Setting the BIOS boot mode
·     Setting the server boot order
·     Enabling or disabling iFIST
·     Logging in to iFIST
·     Configuring serial port redirection
·     Configuring RAID
·     Restoring BIOS default settings
1.     Connect a keyboard, a mouse, and a monitor to the server or enable the remote console from the HDM Web interface.
For information about enabling the remote console, see H3C Servers HDM User Guide.
2.     Start or restart the server.
CAUTION
CAUTION:
·     During the BIOS startup, the system performs checksum verification on the BIOS firmware to ensure the firmware integrity and security. If the verification fails, the startup process is terminated and the system prompts the verification failure.
·     If uncorrectable errors occur during the memory test phase during the startup, the startup fails and the startup page prompts the errors. In this case, view HDM logs and replace the faulty DIMMs.
3.     Press Del or Esc when the BIOS startup screen opens, as shown in Figure 2.
Figure 2 BIOS setup screen
Table 1 BIOS shortcut keys
Key
Esc/Del
Enter the BIOS setup screen.
F7
Enter the Boot menu.
F10
Enter the iFIST GUI. For more information, see H3C Servers iFIST User Guide.
F12
Enter PXE boot.
4.     Enter the BIOS password if required during boot-up.
By default, no BIOS passwords are set. For information about BIOS password setup, see "Configuring BIOS passwords."
If you enter an incorrect password for three consecutive times, the server will restart automatically.
If you forget the password, use the system maintenance switch in the server to clear BIOS password settings. You can also log in to the HDM2 system and negative to the O&M Diagnosis > Secure erasure page to erase the server BIOS data. For more information about security erasure, see H3C Servers HDM2 User Guide. For more information about the system maintenance switch, see the user guide for the server.
IMPORTANT
IMPORTANT:
If you use the system maintenance switch to clear BIOS passwords, restore the switch to the default position after you set new password settings. If you fail to do so, the new settings will be cleared.
5.     If you have set a BIOS administrator password and a user password, select the role before entering BIOS setup.
6.     On the BIOS setup utility screen that opens, follow the instructions in the dialog box that opens to configure BIOS settings, as shown in Figure 3.
Table 2 shows detailed information about the operation keys.
Figure 3 BIOS setup utility screen
Table 2 Operation keys
Key
Select a screen or item.
Select menu or option by navigating up or down.
Enter
Select an item to edit its value or access a submenu.
Change the field value of the selected item.
ESC
Exit the BIOS setup utility or return to the previous screen.
F1
Display the general help window.
F2
Load previous values in the BIOS.
F3
Load default values in the BIOS.
F4
Save the current configuration and exit the BIOS.
F5
To find relevant options for a specific keyword, enter the keyword and press Enter to search for related results.
Scan the QR code to access the BIOS user guide on the official website.
<K>
Scroll up the help information in the top-right corner of the interface.
<M>
Scroll down the help information in the top-right corner of the interface.
Discard changes and exit.
Save changes and exit.
1.     Enter the BIOS setup utility. Select Main, as shown in Figure 4.
2.     Select a BIOS language mode from the System Language field. The setting takes effect immediately.
Figure 4 Setting the BIOS language
1.     Enter the BIOS setup utility. Select Main, as shown in Figure 5.
2.     Select a BIOS setup mode (Text or Graphic) from the Setup Mode field, and then press Enter.
Figure 5 Setting the BIOS setup mode
3.     Press F4 and then select Ok to save the configuration. The server will restart automatically.
1.     Enter the BIOS setup utility. For more information, see "Entering the BIOS setup utility."
2.     Select Advanced > Socket Configuration > Processor Configuration.
The Processor Configuration submenu that opens displays detailed information about processors, as shown in Figure 6.
For more information about the Processor Configuration submenu, see "Processor Configuration submenu."
Figure 6 Processor Configuration submenu screen
2.     Select Advanced > Socket Configuration > Memory Configuration, and press Enter.
3.     Select Memory Topology to enter Memory Topology submenu.
The Memory Topology submenu that opens displays memory capacity and frequency information, as shown in Figure 7.
For more information about the Memory Configuration submenu, see "Memory Configuration submenu."
Figure 7 Memory Configuration submenu
Both the PCH SATA Configuration and PCH sSATA Configuration submenus display onboard drive information. The following uses the PCH SATA Configuration submenu for example. For more information about the submenus, see "PCH-IO Configuration submenu."
2.     Select Advanced > Socket Configuration > Platform Configuration > PCH-IO Configuration > SATA And RST Configuration, and press Enter.
The SATA And RST Configuration submenu that opens displays drive information, as shown in Figure 8.
Figure 8 SATA And RST Configuration submenu
Perform this task to enable or disable PCIe ports (slots). With a PCIe port disabled, the operating system cannot identify the PCIe device connected to the port. To disable a PCIe device, you can perform this task to disable the corresponding port to avoid frequent PCIe device swapping.
1.     Enter the BIOS Setup utility. For more information, see"Entering the BIOS setup utility."
2.     Select Advanced > Socket Configuration> IIO Configuration.
Figure 9 IIO Configuration submenu screen
3.     In the IIO Configuration submenu, select a processor configuration item.
4.     Select a port, and then press Enter.
For more information about the connected device for a port, access the HDM Web interface.
Figure 10 Slot 3 – Port 1A configuration submenu screen
5.     Select Enabled, Disabled, or Auto from the PCI-E Port field, and then press Enter.
6.     Save the configuration and exit the BIOS utility. The configuration takes effect after the server reboots.
This feature configures the NIC preboot execute environment (PXE) feature to boot the server through the network.
Most server NICs have been installed with the PXE feature. When PXE is enabled, the server can download a startup image from a remote device through the network for OS startup or installation.
If the UEFI mode is used, configure an image file that supports the UEFI mode in PXE server configuration.
2.     Select Advance > Network Configuration > PCIE Network Configuration, and configure the PXE feature for all ports or a single port,, as shown in Figure 11.
3.     In the PCIE NIC Configuration submenu, configure the PXE feature for all ports or a single port, as shown in Figure 11.
¡     To configure PEX for all ports, set PCIE NIC PXE.
¡     To configure PEX for a single port, set NIC Port PXE for the specific port.
Figure 11 PCIE Network Configuration submenu screen
Configuring TXT
Trusted Execution Technology (TXT) is a security feature supported by Intel processors for comprehensive data security in virtual computing. Intel TXT is available when TPM 2.0 or TPM 1.2 is used.
Enable the following features:
·     All Intel processor cores.
·     Hyper-Threading [ALL].
·     Intel® VT for Directed I/O (VT-d).
·     TPM (physical TPMs are enabled by default).
1.     Enter the BIOS Setup utility. For more information, see "Entering the BIOS setup utility".
2.     Select Advanced > Socket Configuration > Processor Configuration, and then press Enter.
Figure 12 Enable Intel(R) TXT item
3.     Select Enabled or Disabled from the Enable Intel(R) TXT field, and then press Enter.
4.     Save the configuration and exit the BIOS utility. The configuration takes effect after the server reboots.
Perform this task to configure IP address settings of HDM network ports and the method for obtaining the network information.
The submenus are the same for both HDM dedicated and shared network ports. The following uses the HDM shared network port for example.
Do not disconnect the AC power immediately after you modify and save HDM IPv4 and IPv6 address settings. Otherwise, the IP address setting might fail.
To avoid network storms, make sure the IP address of the HDM shared network port is on a network segment different than the HDM dedicated network port.
To avoid device disconnection, make sure HDM network configurations are correct.
2.     Select Server > HDM Network Configuration, and press Enter.
As shown in Figure 13, in the HDM Network Configuration submenu, both IPv4 configuration and IPv6 configuration are supported. Take IPv4 network configuration as an example.
3.     Select IPv4 Network Configuration.
4.     Select Refresh, press Enter, and then select Yes to refresh HDM network configuration.
Figure 13 HDM Network Configuration submenu
5.     Select Configuration Address source for the HDM shared network port, and press Enter.
6.     From the Configuration Address source field, select the method for obtaining HDM network information. Options are:
¡     UnspecifiedRetains current configuration.
¡     StaticUses manually specified configuration.
¡     DynamicHdmDhcpUses network information obtained through DHCP.
Figure 14 HDM Network Configuration submenu
7.     Press Enter. If you select Static as the method for obtaining HDM network information, edit the following items and press Enter every time you finish editing:
¡     Station IP address—Enter a static IP address. This item is required.
¡     Subnet mask—Enter a subnet mask for the static IP address. This item is required.
¡     Router IP address—Enter a gateway IP address.
8.     Click Save and press Enter. In the dialog box that opens, click Yes to save the configuration.
9.     Click Refresh. In the dialog box that opens, click Yes to refresh the page and then you can view the saved configuration.
BIOS passwords include a boot password as well as an administrator password and a user password for BIOS Setup. By default, no passwords are set.
·     A boot password is required each time the server starts up.
·     An administrator password or a user password is required each time you enter the BIOS Setup screen.
If only the administrator password is set, you can enter this password to obtain administrator privileges. The system prompts for the password when you use shortcut keys to enter the BIOS setup utility, iFIST, boot menu, or PXE boot interface.
If only the user password is set, you can enter this password to obtain user privileges. Table 3 shows the menu items that are accessible in the BIOS with the user privileges.
Table 3 BIOS menu items accessible with the user password
Level-1 menu
Submenu items
Security
User Password
Exit
Save Changes and Exit
Discard Changes and Exit
Save Changes and Reset
Discard Changes and Reset
Save Changes
Discard Changes
When you change a BIOS password, make sure the new password is different from the most recent three passwords.
The BIOS passwords must meet the following requirements:
·     A case-sensitive string of 8 to 20 characters. Valid characters are letters, digits, spaces, and special characters in Table 4.
·     Contain a minimum of two character types from uppercase letters, lowercase letters, and digits.
·     Contain a minimum of one space or special character.
Table 4 Special characters
Character name
Symbol
Character name
Symbol
Back quote
Tilde
Exclamation point
At sign
Pound sign
Dollar sign
Percent sign
Caret
Ampersand sign
Asterisk
Left parenthesis
Right parenthesis
Underscore
_
Plus sign
Minus sign
Equal sign
Left bracket
Right bracket
Back slash
Left brace
Right brace
Vertical bar
Semi-colon
Apostrophe
Colon
Quotation marks
Comma
Dot
Forward slash
Left angle bracket
Right angle bracket
Question mark
The procedure is the same for setting the administrator password and the user password. This section uses the administrator password as an example.
To set the administrator password:
2.     Select Security > Administrator Password -Not Installed, and press Enter, as shown in Figure 15.
Figure 15 Setting the administrator password
3.     In the Enter Password dialog box that opens, enter an administrator password, confirm the password, select Ok, and then press Enter.
The procedure is the same for deleting the administrator password and the user password. This section uses the administrator password as an example.
To delete the administrator password:
2.     Select Security > Administrator Password -Installed, and press Enter, as shown in Figure 16.
3.     In the Enter Password dialog box that opens, enter the current administrator password, leave the new password fields empty, select Ok, and then press Enter, as shown in Figure 16.
Figure 16 Deleting the administrator password
4.     In the WARNING dialog box that opens, select Ok, and press Enter, as shown in Figure 17.
Figure 17 Confirming the deletion
2.     Select the Main menu.
3.     Set the system date, as shown in Figure 18:
a.     Select System Date.
The system date is in the format of mm/dd/yyyy.
b.     Press → or ← to switch between the month, day, and year fields and then use the following methods to modify the value:
-     Press + or to increase the value by 1.
-     Press or to decrease the value by 1.
c.     To save the configuration, press or ← to select the Set button, and then press Enter.
Figure 18 Setting the system date
4.     Set the system time, as shown in Figure 19:
a.     Select System Time.
The system time uses the 24-hour time system and is in the format of hh:mm:ss.
b.     Press or to switch between the hour, minute, and second fields and then use the following methods to modify the value:
c.     To save the configuration, press or to select the Set button, and then press Enter.
Figure 19 Setting the system time
The server supports two BIOS boot modes: legacy mode and UEFI mode.
By default, the boot mode is UEFI. For operating systems that support only the legacy mode, change the boot mode to legacy.
An operating system can run only in the BIOS boot mode under which the system was installed. For example, operating systems installed in legacy mode cannot start up in UEFI mode, and operating systems installed in UEFI mode cannot start up in legacy mode.
1.     Enter the BIOS setup screen. For more information, see "Entering the BIOS setup utility."
2.     As shown in Figure 20, select Boot > Boot mode select, and press Enter.
3.     From the Boot mode select field, select LEGACY or UEFI, and press Enter.
Figure 20 Setting the BIOS boot mode
Perform this task to change the server boot order.
The default boot order is hard disk > network > CD/DVD > other device as shown in the Fixed Boot Order Priorities list in Figure 21.
If the server has more than one boot devices of the same type, the Fixed Boot Order Priorities list displays only the first boot device. To change the first boot device, enter the corresponding priorities submenu of the boot device, and then set the first boot option. For example, to change the first boot option for hard disks, enter the UEFI Hard Disk Drive BBS Priorities submenu as shown in Figure 114, and then set the first boot option.
2.     As shown in Figure 21, select the Boot menu.
Figure 21 Boot menu
Table 5 Server boot options
Item
Example
Hard Disk
Disk (including virtual drives), SD cards, and USB-HDD.
Network
Network.
CD/DVD
CD-ROM and DVD-ROM (including virtual ones), USB-CD, and USB-DVD.
Other Device
The options include but are not limited to:
·     Boot option for entering the Shell command line interface. This option is available only when EFI Shell Boot is set to Enabled.
·     Other unidentified boot devices.
Disabled
The boot option is disabled.
3.     As shown in Figure 21, select the option to be modified from the Fixed Boot Order Priorities area, and press Enter.
4.     In the dialog box that opens, select a new boot device type, and press Enter.
5.     Save the configuration and exit the menu. The configuration takes effect after the server reboots.
This feature enables or disables iFIST. The integrated Fast Intelligent Scalable Toolkit (iFIST) is a standalone intelligent deployment tool embedded in the server. Users do not need to install it. For more information about the iFIST, see H3C Servers iFIST User Guide.
If iFIST is enabled, after the server is initialized, you can enter the iFIST system from the BIOS. If iFIST is disabled, the iFIST Boot shortcut will not be displayed on the BIOS set utility, and you cannot start iFIST by pressing F10.
2.     Select Boot > iFIST Boot, select Enabled or Disabled, and then press Enter, as shown in Figure 22.
Figure 22 iFIST boot option
3.     Press F4 and then select Ok to save the configuration and exit the BIOS utility.
Logging in to iFIST
Press F10 on the BIOS boot screen to access the iFIST GUI. iFIST login screen opens after iFIST starts up.
If the boot screen does not display the iFIST shortcut, make sure iFIST is enabled. For more information, see "Enabling or disabling iFIST."
Figure 23 BIOS boot screen
Serial port redirection redirects console information to the specified serial port. You can perform this task to enable or disable this feature.
2.     Select Advanced > Serial Port Console Redirection, and then press Enter.
Figure 24 Serial Port Console Redirection subscreen
3.     Select Enabled or Disabled from the Console Redirection field, and then press Enter.
4.     If you enabled this feature, select Console Redirection Settings, press Enter, and configure redirection parameters as needed.
5.     Press F4 and then select Ok to save the configuration and exit the BIOS utility.
Configuring RAID
In modern data centers, servers play a crucial role in data storage. As servers evolve, they support an increasing number of hard drives. Building RAID for hard drives maximizes their advantages, making them easy to manage, providing fault tolerance, and enhancing reliability.
For more information about configuring RAID, see "H3C Servers Storage Controller User Guide.''
To replace the system board after the embedded RAID settings are configured, change the embedded PCH controller to RAID mode when no drives are connected.
You can perform this task to restore BIOS to its default settings if unknown modifications to the BIOS cause system problems.
2.     Press F3 in the BIOS, or select Exit > Restore Defaults and press Enter as shown in Figure 25.
3.     Press F4 and Enter to save the settings. The configuration will take effect after the server reboots.
Figure 25 Restoring the default from the Exit submenu screen
BIOS menus
Main menu
As shown in Figure 26, the Main menu contains information about the BIOS, memory, system language, and system time and date. For more information about the menu items, see Table 6.
Figure 26 Main menu screen
Table 6 Items on the Main menu screen
Item
BIOS Information
Project Name
Displays the project name.
N/A
Product Name
Displays the product name.
N/A
BIOS Version
Displays the BIOS version.
N/A
Build Date and Time
Displays the compiling date and time of the BIOS build.
N/A
System Uuid
Displays the universally unique identifier (UUID) of the system.
N/A
Access Level
Displays the privileges of the current login role.
N/A
Platform Information
Processor
Displays the CPU ID and stepping.
N/A
PCH
Displays the platform controller hub (PCH) model.
N/A
RC Revision
Displays the RC version.
N/A
Memory Information
Total Memory
Displays the total memory capacity of DRAM in GB.
N/A
Usable Memory
Displays the usable DRAM memory capacity, in GB.
When a specific memory mode, such as memory mirroring, is set, the total memory capacity is different from the actual usable memory capacity. This item displays the actual usable memory capacity.
N/A
Current Memory Frequency
Displays the current memory frequency.
For information about setting the memory frequency, see "Memory Configuration submenu."
N/A
System Language
Displays the language used in the system.
The BIOS supports English and simplified Chinese.
To switch between the languages, press Enter.
English
Setup Mode
Set the BIOS setup mode.
Options:
·     Text.
·     Graphic.
Graphic
System Date
Displays the system date. You can change the system date as needed.
The system date is in the format of mm/dd/yyyy. Click Date to make changes. Adjust the values using the arrows. Click Set to modify the date, or click Cancel to undo the modifications.
·     Press + or to increase the value by 1.
·     Press - or to decrease the value by 1.
·     Press or to select other items to modify the value.
N/A
System Time
Displays the system time. You can change the system time as needed.
The system time is in the format of hh:mm:ss in 24-hour format. Click Time to make changes, adjust values using arrows, and click Set to apply modifies or Cancel to undo them.
N/A
Advanced menu
As shown in Figure 27, the Advanced menu contains advanced system features and functionalities, which are described in Table 7.
Figure 27 Advanced menu screen
Table 7 Items on the Advanced menu screen
Item
Submenu for configuring the socket.
Submenu for configuring the platform.
Submenu for configuring dynamic device settings.
Trusted Computing
Submenu for configuring trusted computing.
ACPI Settings
Submenu for configuring advanced configuration and power interface (ACPI) settings.
Submenu for configuring serial port console redirection.
Submenu for configuring the PCI subsystem.
USB Configuration
Submenu for configuring USB.
CSM Configuration
Submenu for configuring the compatibility support module (CSM).
NVMe Configuration
Submenu for configuring NVMe.
Submenu for configuring network stacks.
Other configuration.
GPU Configuration
Submenu for configuring GPU settings.
Driver Health
Submenu for viewing the health state of drivers or controllers.
This submenu is available only in UEFI boot mode.
Figure 28 shows the Socket Configuration menu screen, on which you can configure processors, command reference code, uncore, memory, IIO, and advanced power management settings as described in Table 8.
Figure 28 Socket Configuration submenu screen
Table 8 Items on the Socket Configuration submenu screen
Item
Submenu for configuring processors, as shown in Figure 29.
The submenu items are described in Table 9.
Common RefCode Configuration
Submenu for configuring the common reference code, as shown in Figure 32.
The submenu items are described in Table 13.
Uncore Configuration
Submenu for configuring Uncore parameters, as shown in Figure 33.
The submenu items are described in Table 14.
Submenu for configuring memory parameters, as shown in Figure 36.
The submenu items are described in Table 17.
IIO Configuration
Submenu for configuring Integrated I/O module (IIO) parameters, as shown in Figure 39.
The submenu items are described in Table 20.
Advanced Power Management Configuration
Submenu for configuring advanced power management parameters, as shown in Figure 45.
The submenu items are described in Table 26.
Figure 29 shows the Processor Configuration submenu screen, on which you can configure features such as hyper-threading and hardware prefetcher for processors.
Figure 29 Processor Configuration submenu screen
Table 9 Items on the Processor Configuration submenu screen
Item
Socket Information
Socket configuration menu
N/A
Per-Socket Configuration
Access the submenu for per-socket configuration, as shown in Figure 30.
The submenu items are described in Table 11.
N/A
Processor BSP Revision
Displays the processor revision.
N/A
Enable LP [Global]
Configure the Intel Hyper-Threading feature.
Options:
·     ALL LPs (default)Each physical processor is equivalent to two logical processor. A higher processor count can improve the overall performance of the application.
·     Single LPEnable only a single logical processor. Each physical processor is equivalent to only one logical processor.
ALL LPs
Hardware Prefetcher
Select Enabled or Disabled to enable or disable hardware prefetcher.
If hardware prefetcher is enabled, the processor prefetches instructions or data from memory to L2 cache before processing the instructions or data. This feature helps improve system performance by reducing memory access time and eliminating potential bottlenecks.
Enabled
L2 RFO Prefetch Disable
Select Enabled or Disabled to enable or disable L2 read for ownership (RFO) prefetch.
RFO is the process of reading cache rows from memory into the cache before they are written to memory.
Disabled
Adjacent Cache Prefetch
Select Enabled or Disabled to enable or disable adjacent cache prefetcher.
Adjacent cache prefetcher is also referred to as mid-level cache (MLC) prefetcher. This feature provides system optimization for applications that require high-frequency SAM. You can disable this feature when a large amount of RAM is needed.
Enabled
DCU Streamer Prefetcher
Select Enabled or Disabled to enable or disable data cache unit (DCU) stream prefetcher.
If the DCU stream prefetcher is enabled, the processor improves data processing and system performance by prefetching the stream and sending it to the L1 cache.
Enabled
DCU IP Prefetcher
Select Enabled or Disabled to enable or disable DCU IP prefetcher.
If the DCU IP prefetcher is enabled, the processor prefetches data to the L1 cache based on previously loaded instructions to improve system performance.
Enabled
LLC Prefetch
Select Enabled or Disabled to enable or disable the L3 or last level cache (LLC) prefetcher.
Disabled
Homeless Prefetch
Enable or disable the Homeless Prefetch, which allows prefetching missed demands into the intermediate cache when there are not enough resources to track L1 cache demands.
Options:
·     EnabledEnable Homeless prefetch.
·     DisabledDisable Homeless prefetch.
·     Auto—Automatic, configured according to hardware.
Auto
Extended APIC
Select Enabled or Disabled to enable or disable the extended APIC mode. If the total number of processor cores exceeds 256, enable this mode as a best practice for the operating system to better support the processor multi-core feature.
Enabled
Enable Intel(R) TXT
Select Enabled or Disabled to enable or disable the support for the Intel trusted execution technology (TXT).
Intel TXT provides comprehensive data security protection in a virtualized computing environment.
To avoid potential security problems, set the debug mode to Disabled before enabling Intel TXT.
Before enabling this feature, make sure you have finished the prerequisites described in "Configuring TXT."
Disabled
VMX
This item is configurable only when Enable Intel(R) TXT is set to Disabled.
Select Enabled or Disabled to enable or disable Intel virtual machine extensions (VMX).
VMX improves server hardware resource usage by allowing the virtualization layer or OS that supports VMX to use Intel hardware virtualization capabilities.
For virtualization layers or OSs that do not support VMX, this feature does not take effect even if it is enabled.
Enabled
Enable SMX
This item is unconfigurable when Enable Intel(R) TXT is set to Enabled.
Select Enabled or Disabled to enable or disable the safer mode extensions (SMX).
Disabled
AES-NI
Select Enabled or Disabled to enable or disable the support for Intel Advanced Encryption Standard New Instructions (AES-NI).
AES-NI can promote the encryption and decryption speed for applications.
Enabled
Memory Encryption (TME)
Select Enabled or Disabled to enable or disable memory Encryption.
This feature requires setting the memory mode to 2LM, and the security feature will be activated based on the initialization results.
Disabled
Total Memory Encryption (TME) Bypass
Select whether to enable Total Memory Encryption (TME).
Options:
·     Enabled.
·     Disabled.
·     Auto.
Auto
Total Memory Encryption Multi-Tenant (TME-MT)
Select Enabled or Disabled to enable or disable Total Memory Encryption Multi-Tenant
(TME-MT).
Disabled
Memory integrity
Select Enabled or Disabled to enable or disable memory integrity.
This feature can protect data in the memory.
Disabled
Key stock amount
Displays the maximum supported length of the TME-MT Key.
N/A
TME-MT key ID bits
Displays the number of bits for the TME-MT key ID.
N/A
Trust Domain Extension (TDX)
Select Enabled or Disabled to enable or disable Trust Domain Extensions (TDX).
Disabled
TDX Secure Arbitration Mode Loader (SEAM Loader)
Select Enabled or Disabled to enable or disable TDX Secure Arbitration Mode Loader (SEAM Loader).
Disabled
PRM Size
Set the Platform Runtime Mechanisms (PRM) size.
N/A
SGX Factory Reset
Select Enabled or Disabled to enable or disable SW Guard Extensions (SGX) factory reset.
Disabled
Select Enabled or Disabled to enable or disable SW Guard Extensions (SGX).
Disabled
SGX PRM Size
Set the SGX Platform Runtime Mechanisms (PRM) size. When the SGX function is disabled, this option is grayed out. When the SGX function is enabled:
·     If SGX PRM Size is set to a specific value and the value is invalid, the SGX PRM Size value is changed to Auto.
·     When SGX PRM Size is set to Auto, the effective SGX PRM size is the minimum value supported by the current processor.
No valid PRMRR size
Table 10 Items on the Socket Configuration submenu screen
Item
Processor Socket
Displays the slot number for CPU.
Processor ID
Displays the ID for CPU.
Processor Frequency
Displays the base frequency for CPU.
Processor Max Frequency
Displays the maximum rated frequency for CPU.
Processor Min Frequency
Displays the minimum rated frequency for CPU.
Processor TDP
Displays the Thermal Design Power (TDP) for CPU.
Microcode Revision
Displays the microcode version information for CPU.
L1 Cache RAM (Per Core)
Displays the capacity of Level 1 cache
L2 Cache RAM (Per Core)
Displays the capacity of Level 2 cache
L3 Cache RAM (Per Package)
Displays the capacity of Level 3 cache
Processor X Version
Displays CPU X version information. If the CPU is not connected, not present is displayed.
Per-Socket Configuration submenu
Figure 30 shows the Per-Socket Configuration submenu screen. The submenu items are described in Table 11. For more information about processor configurations supported by a specific server, see the user guide for the server.
Figure 30 Per-Socket Configuration submenu screen
Table 11 Items on the Per-Socket Configuration submenu screen
Item
CPU Socket N Configuration
Submenu for configuring processor N, as shown in Figure 31. N represents the processor number. The screen displays only present processors.
The submenu items are described in Table 12.
CPU Socket Configuration submenu
Figure 31 shows the CPU Socket Configuration submenu screen. The submenu items are described in Table 12.
This section uses CPU socket 1 as an example.
Figure 31 CPU Socket 1 Configuration submenu screen
Table 12 Items on the CPU Socket Configuration submenu screen
Item
Available Core Bitmap / Number
Displays the available core bitmap and core quantity.
N/A
Active Core Bitmap / Number
Displays the active core bitmap and core quantity.
Available core quantity = Active core quantity + Disabled core quantity
N/A
Core Disable Number
Select the number of the cores to be disabled. The configuration takes effect after the server starts.
To enable all cores of the processor, set the value to 0.
You can set the Core Disable Number to a number equal to or less than the available core quantity.
For example, if 18 cores are available and 4 cores are disabled, only 14 cores are active.
Generally, the more cores you enable, the better the computing performance. Please be cautious when you disable cores.
0
Common RefCode Configuration submenu
Figure 32 shows the Common RefCode Configuration submenu screen, on which you can configure memory mapped I/O (MMIO) above 4 GB and non-uniform memory access (NUMA) settings as described in Table 13.
Figure 32 Common RefCode Configuration submenu screen
Table 13 Items on the Common RefCode Configuration submenu screen
Item
Numa
Select Enabled or Disabled to enable or disable non-uniform memory access (NUMA).
Under NUMA, a processor can access its own local memory faster than non-local memory.
Enabled
Virtual Numa
Select Enabled or Disabled to enable or disable Virtual NUMA, which divides physical NUMA nodes into evenly distributed virtual nodes in the ACPI table, can improve the performance of more than 64 logical processors on Windows.
Disabled
Uncore Configuration submenu
Figure 33 shows the Uncore Configuration submenu screen, on which you can configure Uncore settings as described in Table 14.
Figure 33 Uncore Configuration submenu screen
Table 14 Items on the Uncore Configuration submenu screen
Item
Uncore General Configuration
Submenu for configuring the Uncore General Settings.
Uncore General Configuration submenu
Figure 34 shows the Uncore General Configuration submenu screen, on which you can configure Uncore settings as described in Table 15.
Figure 34 Uncore General Configuration submenu screen
Table 15 Items on the Uncore General Configuration submenu screen
Item
Uncore Status
Displays the Uncore status.
N/A
KTI Prefetch
Select whether to enable KTI prefetch. KTI prefetch enables memory read operations on DDR bus to be carried out earlier.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
SNC
Select whether to enable sub NUMA clustering (SNC). SNC can shorten the delay between the LLC and the memory.
Options:
·     Auto.
·     Disabled.
·     Enable SNC2 (2-clusters)Enable SNC, support 2 clusters and 2-way IMC.
·     Enable SNC4 (4-clusters)Enable SNC, support 4 clusters and 1-way IMC.
Disabled
MMIO High Base
Set the MMIOH starting address.
Options:
·     56T
·     40T
·     32T
·     24 T
·     16T
·     4T
·     2T
·     1T
·     512G
·     3584T
32T
MMIO High Granularity Size
Set the allocation unit size of MMIOH for each stack.
Options:
·     1G
·     4G
·     16G
·     64G
·     256G
·     1024G
·     4096G (For R5300 G6 and R5500 G6 server, the default is 4096G.)
256G
Limit CPU PA to 46 bits
Select whether to enable the restriction of setting the processor physical address to 46 bits:
·     Enabled.
·     Disabled.
With this feature enabled, the maximum value of MMIO High Granularity Size changes to 1024G.
Disabled
Uncore Status submenu
Figure 35 shows the Uncore Status submenu screen, on which you can view the Uncore status as described in Table 16.
Figure 35 Uncore Status submenu screen
Table 16 Items on the Uncore Status submenu screen
Item
Number of CPU
Displays the number of CPUs.
Current UPI Link Speed
Displays the link speed of the current UPI.
Current UPI Link Frequency
Displays the link frequency of the current UPI.
Global MMIO Low Base / Limit
Displays the low base/limit of the global MMIO.
Global MMIO High Base / Limit
Displays the high base/limit of the global MMIO.
Pci-e Configuration Base / Size
Displays the base/size of the UPI PCIe configuration.
Figure 36 shows the Memory Configuration submenu screen, on which you can configure memory settings such as the memory speed and memory RAS features as described in Table 17.
Figure 36 Memory Configuration submenu screen
Table 17 Items on the Memory Configuration submenu screen
Item
DDR PPR Type
Set the Post Package Repair type.
Options:
·     Soft PPR (default)—Temporary repair.
·     Hard PPR.—Permanent repair.
·     PPR DisabledDisable PPR.
Soft PPR
Memory Frequency
Select the maximum memory frequency, in MT/s.
Options:
·     Auto
·     3200
·     3600
·     4000
·     4400
·     4800
·     5200
·     5600
Auto
DDR 2x Refresh Enable
Select whether to enable two times of memory refresh.
Options:
·     Auto
·     Enabled
·     Disabled
Auto
Memory Topology
Access the submenu that displays memory information, as shown in Figure 37.
The submenu items are described in Table 18.
N/A
Memory RAS Configuration
Access the submenu for configuring memory reliability, availability, and serviceability (RAS) settings, as shown in Figure 38.
The submenu items are described in Table 19.
N/A
Figure 37 shows the Memory Topology submenu screen. The submenu items are described in Table 18.
Figure 37 Memory Topology submenu screen
Table 18 Items on the Memory Topology submenu screen
Item
DIMM Status: Enabled CPU1_CH1_D0: 4400MT/s Micron DRx8 32GB RDIMM
Display the DIMM status, location, and other information. For example, DIMM Status: Enabled CPU1_CH1_D0: 4400MT/s Micron DRx8 32GB RDIMM, where:
·     DIMM Status: EnabledDIMM status, which is enabled.
·     CPU1_CH1_D0—DIMM location, which is DIMM slot 0 of channel 1 for CPU1.
·     4400MT/s—DIMM frequency.
·     Micron—DIMM vendor.
·     DRx8—DR stands for the number of ranks. x8 indicates the bit width of a DIMM chip.
·     32GBCapacity of the DIMM.
·     RDIMMType of the DIMM.
Memory RAS Configuration submenu
Figure 38 shows the Memory RAS Configuration submenu screen. The submenu items are described in Table 19.
Figure 38 Memory RAS Configuration submenu screen
Table 19 Items on the Memory RAS Configuration submenu screen
Item
Mirror Mode
This item is unconfigurable when UEFI ARM Mirror or ADDDC Sparing is set to Enabled.
Specify a mirror mode.
Options:
·     Disabled—Disables mirror mode.
·     Full Mirror ModeSets all 1LM memory to operate in mirror mode, which reduces the available memory capacity by half.
·     Partial Mirror Mode—Enables partial mirror mode. In this mode, you can set the memory size of the mirror.
·     Due to hardware limitations, a segment of address space must be equally divided among the socket, IMC, Channel and rank. Therefore, when all the DIMMs are present, the memory capacity displayed in the POST screen and BIOS Setup utility is greater than half of the total memory capacity in the full mirror mode.
·     Enabling any type of mirror mode will disable XPT prefetch.
Disabled
Partial Mirror X Size(GB)
This item is available only when the Mirror Mode is set to Partial Mirror Mode.
Set the size of the partial mirror.
N/A
ADDDC Sparing
This item is unconfigurable when Mirror Mode is set to Partial Mirror Mode or Full Mirror Mode.
Select Enabled or Disabled to enable or disable adaptive double device data correction (ADDDC) sparing.
ADDDC sparing can correct data errors on two memory chips and is available only for x4 memory.
After modification, you must perform a cold reboot for the new ADDDC Sparing setting to take effect.
For the change to take effect, perform cold reboot.
Disabled
Patrol Scrub
This item enables or disables patrol scrubbing.
·     Disabled—Disables patrol scrubbing.
·     Enable at End of POST—Enables patrol scrubbing after POST.
Patrol scrubbing allows a processor to automatically search for and correct correctable memory errors at regular intervals.
Enable at End of
POST
Patrol Scrub Interval
Set the patrol scrub interval in hours. This item is available only when Patrol Scrub is set to Enabled.
An interval of 0 indicates auto patrol scrubbing.
24
DDR5 ECS
Select Enabled or Disabled to enable or disable DDR5 Error Checking and Scrubbing (ECS) settings.
Select Enable ECS with Result Collection to enable DDR5 ECS settings and collect ECS results.
Enabled
Figure 39 shows the IIO Configuration submenu screens, on which you can configure the peripheral component interconnect express (PCIe) slots, including their link speed and maximum payload size, as described in Table 20.
Figure 39 IIO Configuration submenu screen
Table 20 Items on the IIO Configuration submenu screen
Item
SocketN Configuration
This item is available only when the processor is present.
Display the IIO configuration of processor N.
N/A
Displays the configuration menu for Intel® VT.
N/A
Intel VMD technology
Displays the configuration menu for Intel VMD technology. This menu is available only in UEFI mode.
N/A
IIO-PCIE Express Global Options
PCIe Hot Plug
Select whether to enable or disable PCIe hot plug.
Options:
·     Enabled—Enables global PCIe hot plug.
·     Disabled—Disables global PCIe hot plug.
Enabled
PCI-E ASPM Support (Global)
Select whether to enable PCIe ASPM globally.
Options:
·     Disabled—Disables PCIe ASPM globally.
·     Per-Port—Controls PCIe ASPM per port.
Disabled
PCIe 10-bit Tag Support (Global)
Select whether to enable PCIe 10-bit tag support. The 10-bit tag enables the Requester to increase the number of its unprocessed Non-Posted Requests (NPRs) from 256 to 768, avoiding tag availability as a bottleneck. Options:
·     AutoUses the default device settings.
·     DisabledDisables PCIe 10-bit tag support.
Auto
PCIe Max Read Request Size
Set the PCIe maximum read request size.
Options:
·     Auto
·     128B
·     256B
·     512B
·     1024B
·     2048B
·     4096B
4096B
Socket X Configuration submenu
The Socket X Configuration submenu displays link parameters and status for PCIe ports, and provides options for managing each PCIe port, such as port enabling, link speed selection, and hot swapping enabling.
The Socket Configuration submenu screen varies by server model and PCIe riser card model. The following uses Socket 1 Configuration for example.
Figure 40 shows the Socket 1 Configuration submenu screen. The submenu items are described in Table 21.
Figure 40 Socket 1 Configuration submenu screen
Table 21 Items on the Socket 1 Configuration submenu screen
Item
Port DMI
Displays the configuration menu for Port DMI.
DMI is the interface between the CPU and the PCH.
N/A
Slot 16 - Port 1A
Displays the configuration menu for Port 1A.
Slot 16 indicates the slot ID of the device connected to the PCIe slot.
N/A
The following takes Slot 16 – Port 1A for example.
Figure 41 shows the Port Configuration submenu screen. The submenu items are described in Table 22.
Figure 41 Port Configuration submenu screen
Table 22 Items on the Port Configuration submenu screen
Item
PCI-E Port
This item is available only for non-DMI PCIe ports.
Select whether to enable the PCIe port.
Options:
·     Auto.
·     Enabled.
·     Disabled.
Auto
Link Speed
Select a link speed for the PCIe port.
Options:
·     Auto.
·     Gen 1 (2.5 GT/s).
·     Gen 2 (5.0 GT/s).
·     Gen 3 (8.0 GT/s).
·     Gen 4 (16.0 GT/s)
·     Gen 5 (32.0 GT/s)
Auto
Override Max Link Width
Select a maximum link width to be covered.
Options:
·     Auto.
·     x1.
·     x2.
·     x4.
·     x8.
·     x16.
Auto
PCI-E Port Link Status
Displays the PCIe port link status.
N/A
PCI-E Port Link Max
Displays the maximum bandwidth of the PCIe port link.
N/A
PCI-E Port Link Speed
Displays the PCIe port link speed.
N/A
PCI-E Port Max Payload Size
Set the maximum payload size of the PCI-E port.
Options:
·     Auto.
·     128B.
·     256B.
·     512B.
Auto
PCI-E ASPM Support
Enable PCIe Active-State Power Management (ASPM) support. ASPM can save power in the PCIe subsystem by degrading the power state of PCIe links when devices are not in use. ASPM controls the power state at both ends of the link. Options:
·     AutoUse the hardware default setting.
·     DisabledDisable the ASPM function for all PCIe root ports.
Auto
Enable PCIe 10-bit tag support. The 10-bit tag allows a requester to increase its number of unprocessed Non-Posted Requests (NPR) from 256 to 768, thus avoiding tag availability as a bottleneck. Options:
·     DisabledDisable PCIe 10-bit tag support for the device.
·     Force EnableForcibly enable PCIe 10-bit tag support for the device.
Auto
Intel® VT for Directed I/O (VT-d) submenu
Figure 42 shows the Intel® VT for Directed I/O (VT-d) submenu screen. The submenu items are described in Table 23.
Figure 42 Intel® VT for Directed I/O (VT-d) submenu screen
Table 23 Items on the Intel VT for Directed I/O (VT-d) submenu screen
Item
Select Enabled or Disabled to enable or disable Intel virtualization technology for directed I/O (VT-d).
With this feature enabled, management programs and OSs that support this feature can provide directed I/O with hardware support offered by the Intel virtualization technology. You can enable this feature even if such management programs and OSs are not used.
Intel VT-d enhances system security and reliability, and improves the performance of I/O devices in a virtualized environment.
Enabled
Interrupt Remapping
Select whether to enable interrupt remapping.
Options:
·     Auto.
·     Enabled.
·     DisabledDisable interrupt remapping for Intel VT-d. You must first set the Extended APIC field to Disabled.
Auto
X2APIC Opt-Out
Select Enabled or Disabled to enable or disable X2APIC opt out for VT-d.
Disabled
Intel VMD technology subscreen
Figure 43 shows the Intel VMD technology subscreen. The number of menu options for configuring the VMD feature on this subscreen corresponds to the number of processors. The submenu items are described in Table 24.
Figure 43 Intel VMD technology subscreen
Table 24 Items on the Intel VMD technology submenu
Item
VMD Auto Configuration
Select whether to manually configure Intel VMD based on user requirements and device model and manage NVMe ports.
Options:
·     AutoAutomatically enables Intel VMD for all x4 NVMe ports. The default for UniStor X10000 G6 is Auto.
·     DisabledManually configures VMD. This option is the default.
Intel VMD for Volume Management Device on Socket X
Intel® VMD Volume Management Device configuration menu for processor X. This option is displayed when the processor is in place. This option is displayed when VMD Auto Configuration is set to Disabled.
For each processor, the parameters that can be configured for each port on the Intel VMD for Volume Management Device on Socket subscreen are identical. This section uses Socket 1 as an example. Figure 44 shows the VMD configuration items. The submenu items are described in Table 25.
Figure 44 Intel VMD for Volume Management Device on Socket 1
Table 25 Items on the Intel VMD for Volume Management Device on Socket subscreen
Item
VMD Config for PCH/IOU n
Indicates that the subsequent options are used to configure the VMD feature for PCH port or IOU port n.
N/A
Enable/Disable VMD
Enable or disable the VMD feature for the PCH or IOU port. This function is not supported in Legacy mode and is supported only in UEFI mode. Options:
·     DisabledDisable the VMD feature for the PCH or IOU port.
·     EnabledDisable the VMD feature for the PCH or IOU port. If you select Enabled, the following configuration items are displayed.
Disabled
VMD port nA/B/C/D – Slot x
Enable or disable the VMD feature for a port. The slot number is dynamically displayed according to the actual riser card and NVMe backplane. When a device is connected to the port, the corresponding device slot number is displayed. Options:
·     Disabled.
·     Enabled.
Disabled
Hot Plug Capable
Enable or disable the hot swapping feature. Options include:
·     Disabled.
·     Enabled.
Disabled
CfgBar Size
Set the VMD BAR size, in bits. The minimum value is 20 and the maximum value is 27. By default, the value is 25.
N/A
CfgBar attribute
Set the VMD BAR attribute. Options:
·     32-bit non-prefetchable.
·     64-bit non-prefetchable.
·     64-bit prefetchable.
64-bit prefetchable
MemBar1 size
Set the memory BAR1 size, in bits. The minimum value is 20 and the default value is 25.
N/A
MemBar1 attribute
Set the memory BAR1 attribute. Options:
MemBar2 size
Set the memory BAR2 size, in bits. The minimum value is 20 and the default value is 20.
N/A
MemBar2 attribute
Set the memory BAR2 attribute. Options:
VMD for Direct Assign
Enable or disable VMD resource direct assignment. When enabled, VMD domains are directly assigned to VMs, completely bypassing the virtualization manager to reduce storage latency and increase bandwidth. Options:
·     Disabled.
·     Enabled.
Disabled
Advanced Power Management Configuration submenu
Figure 45 shows the Advanced Power Management Configuration submenu screen, on which you can configure advanced power management parameters, including P state control and C state control for processors and power management policy.
Figure 45 Advanced Power Management Configuration submenu screen
Table 26 Items on the Advanced Power Management Configuration submenu screen
Item
Workload Profile Configuration
Select the workload profile configuration. This item supports out-of-band modification through Redfish or in-band modification by using an SCE tool. For more information about the workload profile configuration, see H3C Servers Eagle Stream Platform Scenario-Based BIOS Configuration Guide.
N/A
Static Turbo
Configure the static turbo feature. Options:
·     Disabled—Disable static turbo.
·     Manual—Enable static turbo and allow the user to select a fixed frequency.
·     Auto—Enable static turbo and fix the frequency at the maximum turbo frequency across all cores.
For this feature to take effect, you must enable the HA mode if a Windows Server of CentOS 7 operating system is used.
Disabled
CPU Frequency Select
Set the CPU frequency. This item is displayed only when Static Turbo is set to Manual or Auto. The available range is also displayed (from the base frequency to the maximum turbo frequency across all cores).
·     When Static Turbo is set to Manual, the CPU frequency can be set to a value between the base frequency and the maximum turbo frequency across all cores. The default value is 40, with the unit being 100 MHz. If the input value is less than the base frequency, it is automatically set to the base frequency. When the input value exceeds the supported maximum turbo frequency across all cores, it is set to the maximum turbo frequency.
·     When Static Turbo is set to Auto, this option is grayed out and set to the maximum turbo frequency across all cores for the current CPU model.
N/A
CPU P State Control
Submenu for configuring CPU P-state control options, as shown in Figure 46.
On the submenu, you can select whether to enable Enhanced Intel SpeedStep Technology (EIST) and turbo mode as described in Table 27.
N/A
Hardware PM State Control
Submenu for configuring hardware P-state control options, as shown in Figure 47.
The submenu items are described in Table 28.
N/A
CPU C State Control
Submenu for configuring CPU C-state control options, as shown in Figure 48.
On the submenu, you can control the power consumption of CPUs in idle state as described in Table 29.
N/A
Package C State Control
Submenu for configuring package C state control options, as shown in Figure 49.
On the submenu, you can set the C2 to C3 state transition timer as described in Table 30.
N/A
CPU Thermal Management
Submenu for configuring CPU thermal management options, as shown in Figure 50.
The submenu items are described in Table 31.
N/A
CPU-Advanced PM Tuning
Submenu for configuring CPU advanced power management tuning, as shown in Figure 51.
The submenu items are described in Table 32.
N/A
Memory Power & Thermal Configuration
Submenu for configuring memory power and thermal, as shown in Figure 53.
The submenu items are described in Table 34.
N/A
CPU P State Control submenu
Figure 46 shows the CPU P State Control submenu screen. The submenu items are described in Table 27.
Figure 46 CPU P State Control submenu screen
Table 27 Items on the CPU P State Control submenu screen
Item
Intel SST-PP
Availability of this item depends on the processor model.
This item is available only when Dynamic SST-PP is set to Disabled.
Configure static SST-PP.
Options:
·     Auto.
·     Level 0.
·     Level 3.
·     Level 4.
Auto
Dynamic SST-PP
Dynamic Speed Select Technology-Performance Profile (SST-PP) allows for the reconfiguration of the processor using dynamic SST-PP. Whether this option is displayed depends on whether the CPU model supports this feature. Options.
·     EnabledEnable dynamic SST-PP.
·     DisabledDisable dynamic SST-PP and use static SST-PP.
Disabled
Active SST-BF
Enable or disable Speed Select Technology - Base Frequency (SST-BF). The SST-BF feature is used to increase the base frequency of high-priority cores and reduce the base frequency of other cores for low-priority workloads, thereby improving overall performance on a macro level. The display of this option depends on whether the CPU model supports this feature. Options:
·     EnabledEnable SST-BF.
·     DisabledDisable SST-BF.
Disabled
Configure SST-BF
Select whether to enable the BIOS to configure SST-BF settings.
Options:
·     EnabledEnables the BIOS to configure SST-BF high priority cores.
·     Disabled.
Enabled
SpeedStep (Pstates)
Enhanced Intel SpeedStep Technology (EIST), after enabling this feature, when the system is in idle state, it will automatically adjust the Performance States (P-state), reduce CPU voltage and frequency to decrease power consumption and heat generation.
Options:
·     Enabled: Enable EIST.
·     Disabled: Disable EIST.
Enabled
Config TDP Lock
Select Enabled or Disabled to enable or disable Thermal Design Power (TDP) lock for the processor.
Enabled
EIST PSD Function
Set the method for EIST to automatically adjust processor voltage and core frequency to reduce power consumption and help heat dissipation.
Options:
·     HW_ALL—Specifies all the hardware.
·     SW_ALL—Specifies all the software.
HW_ALL
Boot performance mode
Set the boot performance state for BIOS before the OS takes over.
Options:
·     Max Performance.
·     Max Efficient.
·     Set by Intel Node Manager.
Max Performance
Energy Efficient Turbo
Select Enabled or Disabled to enable or disable energy efficient Turbo mode.
Enabled
Turbo Mode
Select Enabled or Disabled to enable or disable the Turbo mode.
Enabled
CPU Flex Ratio Override
Select Enabled or Disabled to enable or disable setting processor flex ratio.
Disabled
CPU Core Flex Ratio
This item is configurable only when CPU Flex Ratio Override is set to Enabled.
Set the processor core ratio multiplier, in the range of 0 to 100, to limit the maximum operating frequency of a processor. For example, if the multiplier is 32, the maximum operating frequency is 3200 MHz.
If Turbo is disabled, the maximum operating frequency of a processor will not exceed the limit.
23
Hardware PM State Control submenu
Figure 47 shows the Hardware PM State Control submenu screen. The submenu items are described in Table 28.
Figure 47 Hardware PM State Control submenu screen
Table 28 Items on the Hardware PM State Control submenu screen
Item
Hardware P-States
Set the mode for selecting the hardware P-states.
Options:
·     DisabledDisables the hardware P-state feature.
·     Native ModeAllows direct register access from the OS for CPU configuration. Both the legacy ACPI table (_pct\pss\ppc) and new ACPI specification (_CPC V2) are supported.
·     Out of Band ModeAllows only out-of-band management by using BMC. In this mode, you cannot access the hardware P-state register from the OS.
·     Native Mode with No Legacy SupportThis mode is the same as the native mode except for support of the new ACPI specification (_CPC V2).
Native Mode
EPP Enable
This item is unconfigurable when Hardware P-States is set to Disabled.
Select Enabled or Disabled to enable or disable ENERGY_PERFORMANCE_PREFERENCE (EPP).
If this feature is disabled, the system uses ENEGY_PERF_BIAS (EPB).
Enabled
CPU C State Control submenu
Figure 48 shows the CPU C State Control submenu screen. The submenu items are described in Table 29.
Figure 48 CPU C State Control submenu screen
Table 29 Items on the CPU C State Control submenu screen
Item
Enable Monitor MWAIT
Select Enabled or Disabled to enable or disable Monitor/Mwait instructions.
Select Auto to set the Monitor/Mwait instructions Automatically.
Enabling Monitor/Mwait instructions optimizes processor instruction execution.
To disable CPU C state, you must also disable Monitor MWAIT for some operating systems.
If Enhanced vMotion Compatibility (EVC) errors occur during VM adding to a cluster or VM service migration, enable this feature.
Enabled
CPU C1 auto demotion
Select whether to enable processors to automatically demote to C1.
Options:
·     EnabledEnables processors to automatically demote to C1.
·     DisabledDisables processors from automatically demoting to C1.
·     Auto—Automatically set based on the processor type. If an EMR processor is used, this feature is disabled. If an SPR processor is used, this feature is enabled.
Auto
CPU C1 auto undemotion
Select whether to enable processors to automatically undemote from C1.
Options:
·     EnabledEnables processors to automatically undemote from C1.
·     Disabled—Disables processors from automatically undemoting from C1.
·     AutoAutomatically set based on the processor type. If an EMR processor is used, this feature is disabled. if an SPR processor is used, this feature is enabled.
Auto
CPU C6 report
Select whether to enable the BIOS to report the C6 state to the operating system.
Options:
·     Enabled—Enables the BIOS to report the C6 state to the operating system.
·     Disabled—Disables the BIOS from reporting the C6 state to the operating system.
·     Auto—Enables the BIOS to report the C6 state to the operating system by default.
Disabled
Enhanced Halt State (C1E)
Select Enabled or Disabled to enable or disable the C1E feature.
C1E feature enables a processor to operate at the minimum performance state in idle time to reduce power consumption.
The C1E configuration takes effect after the server restarts.
Disabled
Package C State Control submenu
Figure 49 shows the Package C State Control submenu screen. The submenu items are described in Table 30.
Figure 49 Package C State Control submenu screen
Table 30 Items on the Package C State Control submenu screen
Item
Package C State
Select the package C state limit.
Options:
·     C0/C1 state.
·     C2 state.
·     C6 (non Retention)state.
·     C6 (Retention) state.
·     No Limit.
·     Auto.
C0/C1 state
CPU Thermal Management submenu
Figure 50 shows the CPU Thermal Management submenu screen. The submenu items are described in Table 31.
Figure 50 CPU Thermal Management submenu screen
Table 31 Items on the CPU Thermal Management submenu screen
Item
Thermal Monitor
Select Enabled or Disabled to enable or disable processor temperature monitoring.
Enabled
CPU Advanced PM Tuning submenu
Figure 51 shows the CPU Advanced PM Tuning submenu screen. The submenu items are described in Table 32.
Figure 51 CPU Advanced PM Tuning submenu screen
Table 32 Items on the CPU Advanced PM Tuning submenu screen
Item
Uncore Freq Scaling
Select whether to enable uncore frequency scaling.
Options include:
·     DisabledDisables uncore frequency scaling. When this feature is disabled, you can set the uncore frequency.
·     EnabledEnables uncore frequency scaling. This feature allocates power resources across cores and uncores to maximize the server performance without wasting power.
Enabled
Current Uncore Ratio Range
Displays the current uncore ratio range when uncore freq scaling is set to Disabled.
N/A
Uncore Freq
Set the uncore frequency in a range of 0 to 127. The default value is 127. This option is displayed when uncore freq scaling is set to Disabled.
The valid range for uncore frequency is the current uncore ratio range. If the value you set is smaller than the minimum value or is greater than the maximum value of the range, the minimum value or the maximum value of the range takes effect instead.
N/A
Uncore Freq RAPL
Select whether to enable the uncore frequency run-time average power limit (RAPL).
Options include:
·     Disabled.
·     Enabled.
Enabled
Energy Perf BIAS
Energy and performance bias configuration submenu, on which you can configure the energy and performance policy for the system, as shown in Figure 52.
The submenu items are described in Table 33.
N/A
Optimized Power Mode
Set the power optimization option.
Options:
·     Disabled: Disable power optimization options.
·     Enabled: Enable power optimization options.
Disabled
CPU Advanced PM Tuning > Energy Perf BIAS submenu
Figure 52 shows the Energy Perf BIAS submenu screen. The submenu items are described in Table 33.
Figure 52 Energy Perf BIAS submenu screen
Table 33 Items on the Energy Perf BIAS submenu screen
Item
Power Performance Tuning
This item is inaccessible when Hardware P-States is set to Out of Band Mode.
Select the method to control energy and performance bias tuning.
Options:
·     OS Controls EPBThis option is not available when Hardware P-States is set to Out of Band Mode or Native Mode with No Legacy Support.
·     BIOS Controls EPB.
·     PECI Controls EPBThis option is the default when Hardware P-States is set to Out of Band Mode.
BIOS Controls EPB
ENERGY_PERF_BIAS_CFG Mode
This item is available only when Energy Performance Tuning is set to BIOS Controls EPB.
Select an energy and performance bias option. The setting for this option overrides the energy and performance bias configured by the operating system.
Options:
·     PerformanceProvides maximum system performance (maximum cooling) at the expense of energy efficiency.
·     Balanced PerformanceProvides optimum performance with good energy efficiency.
·     Balanced PowerProvides optimum power efficiency with good performance.
·     PowerProvides maximum power efficiency (maximum power saving) at the expense of system performance.
Performance
Workload Configuration
Select the workload option.
Options:
·     BalancedBalances the performance.
·     I/O sensitive—Keeps I/O sensitive.
Balanced
Memory Power & Thermal Configuration submenu
Figure 53 shows the Memory Power & Thermal Configuration submenu screen. The submenu items are described in Table 34.
Figure 53 Memory Power & Thermal Configuration submenu screen
Table 34 Items on the Memory Power & Thermal Configuration submenu screen
Item
Memory Thermal
Configure memory thermal settings.
N/A
Memory Power Saving Advanced Options
Set the advanced memory power saving settings.
N/A
Figure 54 shows the Memory Thermal submenu screen. The submenu items are described in Table 35.
Figure 54 Memory Thermal submenu screen
Table 35 Items on the Memory Thermal submenu screen
Item
Throttling Mode
Set the throttling mode.
Options:
·     Disabled—Disables the throttling mode.
·     CLTTEnables CLTT to allow thermal throttling based on the memory TSOD temperature.
·     CLTT with PECIEnables CLTT with PECI for thermal throttling.
CLTT
Figure 55 shows the Memory Power Savings Advanced Options submenu screen. The submenu items are described in Table 36.
Figure 55 Memory Power Savings Advanced Options submenu screen
Table 36 Items on the Memory Power Savings Advanced Options submenu screen
Item
CKE Throttling
Set the Clock Enable (CKE) throttling mode. If CKE is disabled, the internal DDR clock is disabled and DDR power consumption decreases.
Options:
·     AutoEnables the CPU to set the CKE throttling mode automatically.
·     Manual—Sets the throttling mode manually.
Auto
Platform Configuration submenu
As shown in Figure 56, the Platform Configuration menu contains the submenus described in Table 37.
Figure 56 Platform Configuration menu screen
Table 37 Items on the Platform Configuration menu screen
Item
Submenu for configuring the platform controller hub (PCH).
Miscellaneous Configuration
Submenu for configuring miscellaneous settings, including video display device and debug mode settings.
Server ME Configuration
Submenu for configuring the server management engine (ME).
Runtime Error Logging
Submenu for configuring runtime error logging.
Figure 57 shows the PCH-IO Configuration submenu screen, on which you can configure PCH settings as described in Table 38.
Figure 57 PCH-IO Configuration submenu screen
Table 38 Items on the PCH-IO Configuration submenu screen
Item
Submenu for configuring PCH SATA settings, as shown in Figure 58, and Figure 59.
The submenu menu items are described in Table 39.
Chipest USB Configuration
Submenu for configuring USB, as shown in Figure 60.
The submenu menu items are described in Table 41.
If multiple SATA interfaces are used simultaneously, you must configure their SATA controllers separately.
Figure 58 shows the SATA And RST Configuration submenu screen. The submenu items are described in Table 39.
Figure 58 SATA And RST Configuration submenu screen
Table 39 Items on the SATA And RST Configuration submenu screen
Item
Controller X SATA And RST Configuration
Submenu for configuring Controller X SATA.
N/A
Software Feature Mark Configuration for Controller X Configure SATA As
SATA Controller X software feature mask configuration.
N/A
Controller X SATA And RST Configuration submenu
Figure 59 shows the Controller X SATA And RST Configuration submenu screen. The submenu items are described in Table 40.
Figure 59 Controller X SATA And RST submenu screen
Table 40 Items on the Controller X SATA And RST Configuration submenu screen
Item
SATA Controller X
Select Enabled or Disabled to enable or disable the SATA controller.
SATA controller. After enabling, you can configure SATA mode and SATA Test mode.
Options:
·     Enabled.
·     Disabled.
Enabled
SATA1 Mode Selection
Set SATA mode.
Options:
·     AHCI: Advanced Host Controller Interface for Serial ATA, simulates the hard drive as a SATA hard drive, requires the installation of SATA hard drive drivers, and supports hot-swapping.
·     RAID: Redundant Array of Independent Disks, combines multiple independent physical hard disks into a single logical hard disk in different ways. This option is required when configuring software RAID.
AHCI
SATA Port x
Displays the name of the connected SATA port x, dynamically obtained based on the hard disk connection status. If not connected, Not Installed is displayed.
The number of SATA ports varies by server model. The value range is 0 to 7.
Disabled
SATA Port x
Select Enabled or Disabled to enable or disable SATA port.
The configuration for each port is the same.
Options:
·     Enabled.
·     Disabled.
Enabled
Software Preserve
Displays the software preserve status.
N/A
Chipset USB Configuration submenu
Figure 60 shows the Chipset USB Configuration submenu screen. The submenu items are described in Table 41.
The number of USB ports and installation locations for USB ports are different for each server model. The Chipset USB Configuration submenu screen varies by server model.
Figure 60 Chipset USB Configuration submenu screen
Table 41 Items on the Chipset USB Configuration submenu screen
Parameter
USB Port Disable Override
Enable or disable independent control of individual USB connectors on the system board. If the USB port is disabled, a USB device inserted into this port cannot be detected by the BIOS or the operating system.
Options:
·     Enabled—You can control USB connectors on a per-connector basis.
·     Disabled—You cannot control USB connectors on a per-connector basis.
Enabled
Miscellaneous Configuration submenu
Figure 61 shows the Miscellaneous Configuration submenu screen, on which you can configure features described in Table 42.
Figure 61 Miscellaneous Configuration submenu screen
Table 42 Items on the Miscellaneous Configuration submenu screen
Item
Active Video
Select a monitor to display videos.
Options:
·     Auto—Enables the server to automatically select a monitor to display videos.
·     Onboard Device—Uses the monitor connected to the onboard VGA connector to display videos.
·     PCIe Device—Uses the monitor connected to the GPU module in the PCIe slot to display videos.
In legacy boot mode, the server cannot display the BIOS menus on the monitor connected to the GPU module or VGA connector if the Onboard Device or PCIe Device option is selected, respectively.
Onboard Device
Server ME Configuration submenu
Figure 62 shows the Server ME Configuration submenu screen, on which you can view server management engine information described in Table 43.
Figure 62 Server ME Configuration submenu screen
Table 43 Items on the Server ME Configuration submenu screen
Item
Oper. Firmware Version
Displays the active firmware version.
N/A
Backup Firmware Version
Displays the backup firmware version.
N/A
Recovery Firmware Version
Displays the recovery firmware version.
N/A
ME Firmware Status #1
Displays ME firmware status #1.
N/A
ME Firmware Status #2
Displays ME firmware status #2.
N/A
Current State
Displays the current ME state.
N/A
Error Code
Displays the error code.
N/A
Recovery Cause
Displays the reason for recovery.
N/A
Intel ME Target Image Boot
Displays the current boot state of the Intel Management Engine (ME) firmware.
N/A
Altitude
Set the altitude at which the server is located, a hexadecimal value in meters. The default is 8000 meters (or 26246.72 ft).
8000
Enable MCTP Proxy
Select Enabled or Disabled to enable or disable MCTP proxy.
Disabled
Server ME Firmware features list
Displays the ME firmware feature list.
Runtime Error Logging submenu
Figure 63 shows the Runtime Error Logging submenu screen, on which you can configure the runtime error logging as described in Table 44.
Figure 63 Runtime Error Logging submenu screen
Table 44 Items on the Runtime Error Logging submenu screen
Item
System Errors
This item controls system error logging, which enables the server to correct system errors automatically and report uncorrectable errors to HDM and the operating system.
Select Enabled or Disabled to enable or disable system error logging.
Enabled
S/W Error Injection Support
Enable or disable S/W error injection support. This item is available only when System Errors is set to Enabled. Options:
·     EnabledEnable S/W error injection support to inject errors through software to check the system performance.
·     DisabledDisable S/W error injection support.
Disabled
System Memory Poison
Select Enabled or Disabled to enable or disable system memory poison.
To report event logs to HDM when uncorrectable memory errors are injected, you must set both System Memory Poison and Viral Status to Disabled.
Enabled
System Cloaking
System cloaking enables the operating system and software to block corrected errors and uncorrected no action required (UCNA) errors.
Select Enabled or Disabled to enable or disable system cloaking.
Enabled
eMCA Settings
Access the submenu for configuring the Enhanced Machine Check Architecture (eMCA), as shown in Figure 64.
The submenu items are described in Table 45.
N/A
Whea Settings
Access the submenu for configuring the Windows Hardware Error Architecture (WHEA), as shown in Figure 65.
The submenu items are described in Table 46.
N/A
Memory Error Enabling
Access the submenu for configuring memory error reporting, as shown in Figure 66.
The submenu items are described in Table 47.
N/A
IIO Error Enabling
Access the submenu for configuring Integrated I/O module (IIO) error reporting, as shown in Figure 67.
The submenu items are described in Table 48.
N/A
eMCA Settings submenu
Figure 64 shows the eMCA Settings submenu screen. The submenu items are described in Table 45.
Figure 64 eMCA Settings submenu screen
Table 45 Items on the eMCA Settings submenu screen
Item
EMCA Logging Support
Select Enabled or Disabled to enable or disable eMCA logging.
eMCA logging provides MAC error reports for the server.
Enabled
LMCE Support
Select Enabled or Disabled to enable or disable local machine check exceptions (LMCE) support.
This feature enables the system to report uncorrectable errors of the Software Recoverable Action Required (SRAR) type only to affected logical processors.
Enabled
EMCA CMCI-SMI Morphing
This item is available only when EMCA Logging Support is set to Enabled.
When EMCA CMCI-SMI morphing is enabled:
·     An SMI is triggered each time a correctable error occurs.
·     If the number of correctable errors on the MCBank exceeds the upper limit, an SMI is triggered but a Corrected Machine Check Interrupt (CMCI) is not.
Options:
·     EMCA gen 2 CSMI—Enables EMCA CMCI-SMI morphing in EMCA gen 2 CSMI mode.
·     Disabled—Disables EMCA CMCI-SMI morphing.
Disabled
EMCA CMCI-SMI Threshold
Set the CMCI-SMI threshold for eMCA reported correctable errors.
2000
Whea Settings submenu
Figure 65 shows the Whea Settings submenu screen. The submenu items are described in Table 46.
Figure 65 Whea Settings submenu screen
Table 46 Items on the Whea Settings submenu screen
Item
WHEA Support
Select Enabled or Disabled to enable or disable WHEA.
WHEA provides hardware error reports for the server.
Enabled
Whea Log Memory Error
Select Enabled or Disabled to enable or disable WHEA memory error logging.
Enabled
Whea Log Processor Error
Select Enabled or Disabled to enable or disable WHEA processor error logging.
Enabled
Whea Log PCI Error
Select Enabled or Disabled to enable or disable WHEA PCI error logging.
Enabled
Memory Error Enabling submenu
Figure 66 shows the Memory Error Enabling submenu screen. The submenu items are described in Table 47.
Figure 66 Memory Error Enabling submenu screen
Table 47 Items on the Memory Error Enabling submenu screen
Item
Memory Corrected Error
Select Enabled or Disabled to enable or disable correctable memory error reporting.
Enabled
IIO Error Enabling submenu
Figure 67 shows the IIO Error Enabling submenu screen. The submenu items are described in Table 48.
Figure 67 IIO Error Enabling submenu screen
Table 48 Items on the IIO Error Enabling submenu screen
Item
Os Native AER Support
Select Enabled or Disabled to enable or disable the AER feature on the OS.
Disabled
IIO MCA Support
Select Enabled or Disabled to enable or disable IIO MCA support.
Disabled
IIO eDPC Support
This item is configurable only when the processors support the Advanced RAS feature.
Set the IIO eDPC support.
Options:
·     DisabledDisables IIO eDPC support.
·     On Fatal ErrorEnables IIO eDPC support when a fatal error occurs.
·     On Fatal and Non-Fatal ErrorsEnables IIO eDPC support when a fatal or non-fatal error occurs.
Disabled
PCIe Poison TLP Egress Blocking
Enable or disable PCIe Poison TLP egress blocking. This item is available when IIO eDPC Support is not set to Disabled. Options:
·     Disabled.
·     Enabled.
Enabled
Dynamic Device Configuration submenu
Figure 68 shows the Dynamic Device Configuration submenu screen. The submenu items are described in Table 49. On the Dynamic Device Configuration submenu screen, you can configure network adapters, storage controllers, and VROC settings.
Figure 68 Dynamic Device Configuration submenu screen
Table 49 Items on the Dynamic Device Configuration submenu screen
Item
Intel(R) VROC SATA Controller
Submenu for configuring Intel(R) VROC SATA controller.
This submenu is available only when the SATA mode is set to RAID in the PCH settings.
Intel(R) VROC sSATA Controller
Submenu for configuring Intel(R) VROC sSATA controller.
This submenu is available only when the sSATA mode is set to RAID in the PCH settings.
Intel(R) VROC tSATA Controller
Submenu for configuring Intel(R) VROC tSATA controller.
This submenu is available only when the tSATA mode is set to RAID in the PCH settings.
Intel(R) Virtual RAID on CPU
Submenu for configuring Intel(R) Virtual RAID on CPU (Intel VROC).
This submenu is available only when VMD is enabled.
Slot x: Port n - Mellanox Network Adapter-B08:59:9F:2E:7A:7C(example)
Submenu for displaying network adapter information.
Intel(R) VROC SATA/sSATA/tSATA Controller submenu
The submenu screens of Intel(R) VROC sSATA controller, Intel(R) VROC SATA controller, and Intel(R) VROC tSATA controller are the same. The following uses the submenu screen of Intel(R) VROC SATA controller for example.
Figure 69 shows the Intel(R) VROC SATA Controller submenu screen. The submenu items are described in Table 50.
Figure 69 Intel(R) VROC SATA Controller submenu screen
Table 50 Items on the Intel(R) VROC SATA controller submenu screen
Item
Create RAID Volume
Open the submenu for creating a RAID volume.
This option is available only when more than two SATA, sSATA, or tSATA drives are connected to the port managed by the SATA, sSATA, or tSATA controller.
RAID Volumes
Displays the list of the created RAID volumes.
Volume0,RAID0(Stripe),424.77GB,Normal
Displays summary information about managed RAID volumes, including their volume name, RAID level, capacity, and state, for example, Volume0, RAID0 (Stripe), 424.77GB, Normal.
Non-RAID Physical Disks
Displays the list of the physical drives that have not been used to build RAID volumes.
Port 0,INTEL SSDSC2BB480G7 SN:PHDV702001YJ480BGN,447.14GB
Displays the information about non-RAID physical drives, including port number, physical drive name, serial number, and size.
Create RAID Volume submenu
Figure 70 shows the Create RAID Volume submenu screen. The submenu items are described in Table 51.
Figure 70 Create RAID Volume submenu screen
Table 51 Items on the Create RAID Volume submenu screen
Item
Create RAID volume
Name
Enter the name of the RAID volume.
Make sure the name does not contain backslashes (\) or spaces.
To avoid operation errors, make sure the name does not contain tildes (-), exclamation points (!), at signs (@), pound signs (#), forward slashes (/), or parentheses (()) as a best practice.
N/A
RAID Level
Select a RAID level.
Options:
·     RAID0(Stripe).
·     RAID1(Mirror).
·     RAID5(Parity)This option is available only when a minimum of three drives are present.
·     RAID10(RAID0+1)This option is available only when a minimum of four drives are present.
RAID0(Stripe)
Select Disks
All available drives, for example:
Select drives over which you want to create the RAID volume.
The selected drive is represented by the symbol X.
No drives are selected.
Stripe Size
Set the stripe size of the RAID volume.
N/A
Capacity(GB)
Displays the total capacity of the RAID volume, in GB.
N/A
Create Volume
Create a RAID volume.
To view information about the configured RAID volumes, select All Intel VMD Controllers.
N/A
RAID VOLUME INFO submenu
Figure 71 shows the RAID VOLUME INFO submenu screen. The submenu items are described in Table 52.
Figure 71 RAID VOLUME INFO submenu screen
Table 52 Items on the RAID VOLUME INFO submenu screen
Item
Volume Actions
Delete
CAUTION CAUTION:
All data in the member drives of the volume are permanently deleted when the volume is deleted. As a best practice to avoid data loss, back up the data before you delete a volume.
To delete the RAID volume, select this item, and press Enter.
Name
Displays the name of the RAID volume.
RAID Level
Displays the RAID level.
Strip Size
Displays the stripe size of the RAID volume.
Size
Displays the capacity of the RAID volume.
Status
Displays the state of the RAID volume.
Bootable
Displays whether the RAID volume is bootable.
Block Size
Displays the block size of the RAID volume, in bytes.
RAID Member Disks
Member drives of the RAID, for example, Port 0, SAMSUNG MZ7LM240HMHQ-00005 SN:S2WNXR_J802073,223.57GB
To manage a member drive or view its detailed information, select that drive and the RAID member drive management submenu opens.
PHYSICAL DISK INFO submenu
Figure 72 shows the PHYSICAL DISK INFO submenu screen. The submenu items are described in Table 53.
Figure 72 PHYSICAL DISK INFO submenu screen (1)
Table 53 Items on the PHYSICAL DISK INFO submenu screen
Item
Disk Actions
Reset to non-RAID
CAUTION CAUTION:
This action deletes all data on the drive. As a best practice to avoid data loss, back up the data before you perform this action.
To remove the drive from the RAID array, select this item, and then select Yes to confirm the deletion, as shown in Figure 73.
Locate LED
Turn on or turn off the locate LED.
Port
Displays the port number of the drive.
Controller
Displays the drive controller information, which is SATA in this example.
Model Number
Displays the model number of the drive.
Serial Number
Displays the serial number of the drive.
Size
Displays the capacity of the drive.
Status
Displays whether the drive is a RAID member.
Block Size
Displays the block size of the drive, in bytes.
Non-RAID Physical Disk submenu
Figure 73 shows the Non-RAID Physical Disk submenu screen for a non-RAID physical drive. On the screen, you can view information about the drive and set the drive as a spare or journaling drive, as described in Table 54.
Figure 73 Non-RAID Physical Disk submenu screen
Table 54 Items on the Non-RAID Physical Disk submenu screen
Item
Disk Actions
Mark as Spare
CAUTION CAUTION:
Setting a drive as a spare drive deletes all data on that drive. As a best practice to avoid data loss, back up the data before you perform this action.
To specify the drive as a spare drive, select this item, and then select Yes to confirm the action.
A spare drive cannot be used to build a RAID volume.
Mark as Journaling Drive
CAUTION CAUTION:
Setting a drive as a journaling drive deletes all data on that drive. As a best practice to avoid data loss, back up the data before you perform this action.
To specify the drive as a journaling drive, select this item, and then select Yes to confirm the action.
A journaling drive cannot be used to build a RAID volume.
Locate LED
Port
Controller
Displays drive controller information, which is SATA in this example.
Model Number
Serial Number
Size
Status
Block Size
Intel(R) Virtual RAID on CPU submenu
Intel® Virtual RAID on CPU (Intel VROC) is a RAID solution specifically designed for NVMe-based SSDs. Figure 74 displays the Intel(R) Virtual RAID on CPU submenu. The menu items are described in Table 55.
The Intel® Virtual RAID on CPU submenu screen displays NVMe drive information only when VMD is enabled. If the VMD is disabled, NVMe drive information is displayed on NVMe Configuration screen. For more information, see "NVMe Configuration submenu."
Figure 74 Intel(R) virtual RAID on CPU submenu screen
Table 55 Items on the Intel(R) Virtual RAID on CPU submenu screen
Item
Volume0, RAID0(Stripe),796.44GB,Normal
Displays information about the created RAID volumes.
Volume0: RAID name.
RAID0: RAID level.
796.44GB(Size): This size of the RAID.
Normal: The status of the RAID.
Figure 75 shows the Create RAID Volume submenu screen.
The menu items are described in Table 56.
Figure 75 Create RAID Volume submenu screen (1)
Table 56 Items on the Create RAID Volume submenu screen
Item
Create RAID Volume
Name
Specify the name of the RAID.
Volume0: The name of the RAID to be created.
N/A
RAID Level
Specify the RAID level.
Options:
·     RAID0(Stripe).
·     RAID1(Mirror).
·     RAID5(Parity).
·     RAID10(RAID0+1).
RAID0
Enable RAID spanned over VMD Controllers
Enable RAID spanned over VMD controllers.
When this item is selected, you can choose the drives controlled by VMD0 and VMD1 controllers to create a RAID.
N/A
Select Disks
N/A
INTEL SSDPE7KX020T7 SN:PHLF7330003S2P0LGN 1863.02GB Port 1:0,Slot 105,CPU0,VMD0,BDF 08:00.0
Strip Size
N/A
Capacity(GB)
Specify the capacity of the RAID volume, in GB.
N/A
Create Volume
Select to create a RAID volume.
Then, the confirm submenu screen opens as shown in Figure 76.
N/A
Figure 76 Create Volume Confirm submenu screen
Created RAID volume information submenu
Figure 77 shows the Created RAID Volume information submenu screen.
The menu items are described in Table 57.
Figure 77 Created RAID volume information submenu screen (1)
Table 57 Items on the Created RAID Volume submenu screen
Item
Delete
Select Delete and press Enter to delete a created RAID volume.
Name
RAID Level
Displays the level of the RAID.
Strip Size
Displays the size of the RAID strip.
Size
Displays the size of the RAID, in GB or TB.
Status
Displays the status of the RAID.
Bootable
Indicates whether the volume can be used for system boot.
Block Size
Displays the size of a block, in bytes.
RAID Member Disks
Displays the member disks of the RAID volume.
Delete submenu
Figure 78 shows the Delete submenu screen.
The menu items are described in Table 58.
Figure 78 Delete submenu screen
Table 58 Items on the Delete submenu screen
Item
Delete the RAID volume. After deletion, all data on this volume will be lost.
Yes
Select Yes and press Enter to delete this volume.
No
Select No and press Enter to cancel the deletion of this volume.
RAID Member Disks submenu
Figure 79 shows the RAID Member Disks submenu screen. The screen is similar for all RAID member disks.
The menu items are described in Table 59.
Figure 79 RAID Member Disks submenu screen (1)
Table 59 Items on the RAID Member Disks submenu screen
Item
Disk Actions
Reset to non-RAID
CAUTION CAUTION:
To remove the drive from the RAID array, select this item, and then select Yes to confirm the deletion, as shown in Figure 80.
Locate LED
Controller
Displays controller information, which is Volume Management Device Controller in this example.
Model Number
Serial Number
Size
Status
Block Size
Root Port Number
Displays the root port number of the drive.
Root Port Offset
Displays the root port offset of the drive.
Slot Number
Displays the slot number of the drive.
Socket Number
Displays the slot number of the processor for the drive.
VMD Controller Number
Displays controller information.
PCI Bus:Device.Function
Displays the Bus:Dev.Func of the drive.
VMD Bus:Device.Function
Displays the Bus:Dev.Func of VMD controller of the drive.
Reset to non-RAID submenu
Figure 80 shows the Reset to non-RAID screen. The submenu items are described in Table 60.
Figure 80 Reset to non-RAID submenu screen
Table 60 Items on the Reset to non-RAID submenu screen
Item
Reset the RAID volume. After resetting, all data on this volume will be deleted.
Yes
Select Yes and press Enter to reset this volume.
No
Figure 81 shows the Non-RAID Physical Disk submenu screen for a non-RAID physical drive. The submenu items are described in Table 61.
Figure 81 Non-RAID Physical Disk submenu screen
Table 61 Items on the Non-RAID Physical Disk submenu screen
Item
Disk Actions
Mark as Spare
CAUTION CAUTION:
To specify the drive as a spare drive, select this item, and then select Yes to confirm the action, as shown in Figure 82.
Locate LED
Controller
Model Number
Serial Number
Size
Status
Block Size
Displays the block size of the drive.
Root Port Number
Root Port Offset
Slot Number
Socket Number
Displays the Bus:Dev.Func of the VMD controller of the drive.
Mark as Spare submenu
Figure 82 shows the Mark as Spare submenu screen. The submenu items are described in Table 62.
Figure 82 Mark as Spare submenu screen
Table 62 Items on the Mark as Spare submenu screen
Item
Disk Actions
Yes
CAUTION CAUTION:
To specify the drive as a spare drive, select Yes to confirm the action, as shown in Figure 82.
No
Select No and press Enter to cancel this action.
Trusted Computing submenu
The server might contain a trusted platform module (TPM) or a trusted cryptography module (TCM).
Figure 83 shows the Trusted Computing submenu screen. The submenu items are described in Table 63.
Figure 83 Trusted Computing submenu screen
Table 63 Items on the Trusted Computing submenu screen
Items
Security Device Support
Select Enabled or Disabled to enable or disable security device support.
Enabled
ACPI Settings submenu
The ACPI Settings submenu contains the ACPI options for you to configure OS-directed configuration and power management of the server as shown in Figure 84. The submenu items are described in Table 64.
Figure 84  ACPI Settings submenu screen
Table 64 Items on the ACPI Settings submenu screen
Item
Enable ACPI Auto Configuration
Select Enabled or Disabled to enable or disable ACPI auto configuration.
ACPI auto configuration allows the operating system to control and allocate power to the server hardware.
Disabled
Enable Hibernation
This item is configurable only when Enable ACPI Auto Configuration is set to Disabled. The configuration does not take effect on some OSs.
Select Enabled or Disabled to enable or disable system hibernation.
Enabled
Serial Port Console Redirection submenu
Figure 85 shows the Serial Port Console Redirection submenu screen, on which you can configure console redirection settings as described in Table 65.
Figure 85  Serial Port Console Redirection submenu screen
Table 65 Items on the Serial Port Console Redirection submenu screen
Item
COM0
Console Redirection
Select Enabled or Disabled to enable or disable console redirection on CMO0.
If the feature is enabled, the data on a specific physical console or a virtual console will be redirected to the specified system console.
Enabled
Console Redirection Settings
This item is available only when Console Redirection is set to Enabled on CMO0.
Configure console redirection settings.
N/A
Legacy Console Redirection
Legacy Console Redirection Settings
N/A
Serial Port for Out-of-Band Management/Windows Emergency Management Services (EMS)
Console Redirection EMS
Select Enabled or Disabled to enable or disable console redirection for Windows emergency management services (EMS).
Disabled
This item is available only when Console Redirection EMS is set to Enabled for Windows EMS.
N/A
Console Redirection Settings submenu (COM0)
Figure 86 shows a Console Redirection Settings submenu screen for serial port COM0. The submenu items are described in Table 66.
Figure 86  Console Redirection Settings submenu screen (COM0)
Table 66 Items on the Console Redirection Settings submenu screen (COM0)
Item
Terminal Type
Select the type of the terminal used for console redirection.
Options:
·     VT100—Uses a supported VT100 video terminal with the ASCII character set.
·     VT100Plus—Uses a supported VT100-plus video terminal and its character set. VT100+ supports colors and function keys.
·     VT-UTF8Uses a video terminal with the UTF-8 character set.
·     ANSIUses the ANSI character set, which is an extended ASCII character set.
VT100Plus
Bits Per Second
Set the baud rate of the serial port in bits per second.
Options:
·     9600.
·     19200.
·     38400.
·     57600.
·     115200.
This baud rate setting must match the setting on the remote terminal.
As a best practice, set a low speed on a long or noisy serial line.
115200
Data Bits
Set the number of bits used to represent one character of data.
Options:
·     7.
·     8.
8
Parity
Set the parity bit to be sent with the data bits for transmission error detection.
Options:
·     NoneDisables the transmission error detection feature.
·     Even—Sets the parity bit so that the number of ones in the data set is an even number.
·     Odd—Sets the parity bit so that the number of ones in the data set is an odd number.
·     Mark—Always sets the parity bit to 1. A parity bit value of 0 indicates that an error has occurred.
·     Space—Always sets the parity bit to 0. A non-zero parity bit indicates that an error has occurred.
None
Stop Bits
Set the number of stop bits used to indicate the end of a serial data packet.
Options:
·     1.
·     2.
Two stop bits might be required for communications with a low-speed device.
1
Flow Control
Select a flow control method to prevent data loss from buffer overflow.
Options:
·     NoneNo flow control is used.
·     Hardware RTS/CTSFlow control that uses the ready to send/clear to send (RTS/CTS) signal. When you select this option, make sure it is supported on the serial port.
If you enable hardware RTS/CTS on a serial port that does not support hardware flow control (such as a port that uses a USB-to-serial cable), or on a serial port with no cable connected, the following issues might occur:
·     Failure to load the option ROM of embedded and external PCIe modules.
·     Screen blackout.
·     Cursor flickering.
None
VT-UTF8 Combo Key Support
Select Enabled or Disabled to enable or disable VT-UTF8 combination key support for ANSI/VT100 terminals.
Enabled
Putty KeyPad
Select a mode to change the action of the function keys and keypad in PuTTY.
Options:
·     VT100.
·     LINUX.
·     XTERMR6.
·     SCO.
·     ESCN.
·     VT400.
VT100
Console Redirection Settings (Legacy) submenu
Figure 87 shows the Console Redirection Settings submenu screen. The submenu items are described in Table 67.
Figure 87 Console Redirection Settings (Legacy) submenu screen
Table 67 Items on the Console Redirection Settings (Legacy)  submenu screen
Item
Redirection COM Port
Select the CMO port for the OS and Option ROM redirection in Legacy mode.
The only option is CMO0.
N/A
Resolution
Set the redirection solution.
Options:
·     80x24.
·     80x25.
80x24
Redirect After POST
Select whether to enable or disable redirection after POST.
Options:
·     Always Enable—Always enables redirection after POST.
·     BootLoader—Disables redirection after the OS is booted in Legacy mode.
Always Enable
Console Redirection Settings (EMS port) submenu
Figure 88 shows a Console Redirection Settings (EMS port) submenu screen. The submenu items are described in Table 68.
Figure 88 Console Redirection Settings (EMS port) submenu screen
Table 68 Items on the Console Redirection Settings (EMS port) submenu screen
Item
Out-of-Band Mgmt Port
Indicate the EMS port.
This port allows Microsoft Windows EMS to remotely access the Window OS to collect fault information.
N/A
Terminal Type EMS
Options:
·     VT100+—Uses a supported VT100-plus video terminal and its character set. VT100+ supports colors and function keys.
VT100+
Bits Per Second EMS
Set the data transfer rate of the serial port in bits per second.
Options:
·     9600.
·     19200.
·     57600.
·     115200.
This data transfer rate setting must match the setting on the remote terminal.
115200
Flow Control EMS
Options:
·     Software Xon/Xoff—Flow control that uses the XON (transmit ON) and XOFF (transmit OFF) control characters. When the data transfer rate exceeds 1200 bits per second, the receiver sends an XOFF to have the sender stop transmission. The sender will resume the transmission only when it receives an XON from the receiver.
None
Data Bits EMS
N/A
Parity EMS
Options:
None
Stop Bits EMS
N/A
PCI Subsystem Settings submenu
Figure 89 shows the PCI Subsystem Settings submenu screen, on which you can configure PCI subsystem settings as described Table 69.
Figure 89 PCI Subsystem Settings submenu screen
Table 69 Items on the PCI Subsystem Settings submenu screen
Item
PCI Bus Driver Version
Displays the PCI bus driver version.
N/A
PCI Devices Common Settings
Above 4G Decoding
Select Enabled or Disabled to enable or disable decoding of 64-bit PCIe modules in a 4 GB or greater address space.
As a best practice, enable this option if the PCIe module has a 4 GB or higher-capacity VRAM. For example, disabling this option can cause an M60 or K80 GPU to get stuck in the EarlyPOST 100% phase, preventing you from accessing the BIOS setup menu or the OS.
Enabled
Re-Size BAR Support
Select Enabled or Disabled to enable or disable support for Re-Size BAR Note.
This feature is available only on H3C UniServer R5300 G6 and H3C UniServer R5500 G6 servers.
Disabled
SR-IOV Support
Select Enabled or Disabled to enable or disable support for PCIe single-root I/O virtualization (SR-IOV). SR-IOV virtualizes one physical PCIe module into multiple virtual PCIe modules, each of which can be bound to a virtual machine, thus allowing multiple accesses to the physical PCIe module.
With SR-IOV support enabled, the BIOS allocates I/O resources if a PCIe module supports SR-IOV. With SR-IOV support disabled, the OS allocates I/O resources if a PCIe module supports SR-IOV.
Enabled
Figure 90 shows the USB Configuration submenu screen, on which you can view connected USB devices and configure USB settings as described in Table 70.
Figure 90  USB Configuration submenu screen
Table 70 Items on the USB Configuration submenu screen
Item
USB Module Version
Displays the USB module version.
N/A
USB Controllers
Displays the detected USB controllers.
The system supports eXtensible Host Controller (XHCI) controllers that support USB 3.0.
N/A
USB Devices
Displays the numbers of connected USB devices, including drives, keyboards, mouses, and hubs.
The server has one embedded USB hub in addition to the connected USB hubs.
N/A
Legacy USB Support
Select whether to enable support for legacy USB devices.
Options:
·     Enabled—Legacy USB support is always enabled.
·     Disabled—USB devices are available only for UEFI applications.
·     Auto—The system automatically disables legacy USB support if no USB devices are connected.
Enabled
XHCI Hand-off
Select Enabled or Disabled to enable or disable the XHCI hand-off feature. This feature provides a solution for the operating system that does not support XHCI.
Enabled
USB Mass Storage Driver Support
Select Enabled or Disabled to enable or disable the support for USB mass storage drivers.
This field displays USB information depending on USB storage devices installed.
Enabled
CSM Configuration submenu
The configuration support module (CSM) provides UEFI compatibility with OSs that do not support UEFI boot mode.
Figure 91 shows the CSM Configuration submenu screen, on which you can configure CMS settings as described in Table 71.
Figure 91 CSM Configuration submenu screen
Table 71 Items on the CSM Configuration submenu screen
Item
CSM Support
Select Enabled or Disabled to enable or disable support for UEFI-incapable operating systems.
You must enable CSM support in legacy boot mode.
Enabled
CSM16 Module Version
Displays the version of the CSM 16 module.
N/A
Option ROM Execution
Displays ROM execution settings.
N/A
Option ROM Policy
Select the option ROM policy.
Options:
·     Auto—Enables the UEFI boot mode for UEFI option ROMs and legacy boot mode for legacy option ROMs.
·     Custom—Customizes a policy matching with the BIOS boot mode. As a best practice, uses the auto mode to prevent some option ROMs from failing to execute due to incorrect settings.
Auto
Network
Select the option ROM load method for network adapters.
This option is available when the option ROM policy is in custom mode.
Options:
·     UEFI—Loads the option ROM for network adapters in UEFI boot mode.
·     Legacy—Loads the option ROM for network adapters in legacy boot mode.
·     In UEFI boot mode: UEFI.
·     In legacy boot mode: Legacy.
Storage
Select the option ROM load method for storage devices.
Options:
·     UEFI—Loads the option ROM for storage devices in UEFI boot mode.
·     Legacy—Loads the option ROM for storage devices in legacy boot mode.
Video
Select the option ROM load method for video devices.
Options:
·     UEFI—Loads the option ROM for video cards in UEFI boot mode.
·     Legacy—Loads the option ROM for video cards in legacy boot mode.
Other PCI devices
Select the option ROM load method for other PCI devices such as input devices.
Options:
·     UEFI—Loads the option ROM for other PCI devices in UEFI boot mode.
·     Legacy—Loads the option ROM for other PCI devices in legacy boot mode.
Figure 92 shows the NVMe Configuration submenu screen, on which all installed NVMe devices without option ROM are displayed. You can select an NVMe device to view its information as shown in Table 72.
Figure 92 NVMe Configuration submenu screen
Table 72 Items on the NVMe Configuration submenu screen
Item
Slot 37: INTEL SSDPE2KX040T8
Open the submenu for the selected NVMe device.
The logical slot number of NVMe devices varies by server model. For more information, see the HDM screen.
The NVMe Device Information submenu screen shows the device settings as described in Table 73.
Table 73 Items on the NVMe Device Information submenu screen
Item
Seg:Bus:Dev:Func
Displays the Seg:Bus:Dev:Func of the NVMe device.
Model Number
Displays the model number of the NVMe device.
Total Size
Displays the total size of the NVMe device.
Vendor ID
Displays the vendor ID of the NVMe device.
Device ID
Displays the device ID of the NVMe device.
Namespace
Displays the namespace of the NVMe device.
Network Configuration submenu
Figure 93 shows the Network Configuration submenu screen, on which all Ethernet adapters are displayed. The submenu items are described in Table 74.
Preboot Execute Environment (PXE) enables a server to load the operating system through the network interface. This feature allows the system to start up independently from local storage devices (such as drives) and locally installed operating systems.
Figure 93 Network Configuration submenu screen
Table 74 Items on the Network Configuration submenu screen
Item
IPv4 PXE Support
Select Enabled or Disabled to enable or disable loading the OS over an IPv4 network.
If Disabled is selected, the IPv4 PXE boot option will not be created.
Enabled
IPv6 PXE Support
This item is not available in Legacy mode.
Select Enabled or Disabled to enable or disable loading the OS over an IPv6 network.
If Disabled is selected, the IPv6 PXE boot option will not be created.
Disabled
PXE Boot Wait Time
Set the wait time to press ESC key to abort the PXE boot.
Value range: 0 to 5, in seconds.
0
Media Detect Count
Set the maximum number of media presence detections.
Value range: 1 to 50.
1
PXE Retry Count
Set the maximum number of PXE retries.
Value range: 0 to 50.
A value of 0 indicates that the number of PXE retries is not limited.
1
Onboard NIC Configuration
Submenu for configuring the onboard network adapter.
Only the BIOS for the B5700 G6 supports this item.
PCIE Network Configuration
Submenu for configuring network settings for the PCIe network adapter, as shown in Figure 95.
The submenu items are described in Table 76.
N/A
Onboard NIC Configuration subscreen
Figure 94 shows the Onboard NIC Configuration subscreen. The submenu items are described in Table 75.
Figure 94 Onboard NIC Configuration subscreen
Table 75 Items on the Onboard NIC Configuration submenu
Item
Onboard Portn PXE
Enable or disable PXE boot for an onboard port. Options:
·     Enabled.
·     Disabled.
Enabled
PCIE Network Configuration submenu
Figure 95 shows the PCIE Network Configuration submenu screen, on which you can configure features described in Table 76.
Figure 95 PCIE Network Configuration submenu screen
Table 76 Items on the PCIE Network Configuration submenu screen
Item
PCIE Network PXE
Select Enabled or Disabled to enable or disable PCIe NIC PXE. This feature is supported both in the Legacy mode and the UEFI mode.
The BIOS for the B5700 G6 does not support this item.
Enabled
NIC: Slot x
Displays the relations between the NIC ID and the slot ID. The following lists the PXE settings of each port on the NIC.
Enable or disable the PXE feature for the network adapter in Slot x. Options:
·     Enabled.
·     Disabled.
Enabled
NIC Slot x Portn
Select Enabled or Disabled to enable or disable PXE on a specific NIC port. If this NIC port does not exist, this setting does not take effect.
Enabled
Figure 96 shows the Miscellaneous Configuration submenu screen, on which you can configure features described in Table 77.
Figure 96 Miscellaneous Configuration submenu screen
Table 77 Items on the Miscellaneous Configuration submenu screen
Item
Debug Mode
Select Enabled or Disabled to enable or disable the server to output BIOS console log messages.
Disabled
Summary Debug Mode
Select Enabled or Disabled to enable or disable summary debug mode.
Disabled
Init CE report
Select Enabled or Disabled to enable or disable the report of correctable errors at the initialization stage.
Disabled
NVRAM Checksum Support
Select Enabled or Disabled to enable or disable NVRAM checksum. If Enabled is selected, each NVRAM data will be checked.
Disabled
Oprm Load Default Policy
Restore Oprom default value policy.
Options:
·     All Oprom PagesRestore Oprom options with default values.
·     None Oprom PagesDo not restore any Oprom options.
All Oprom Pages
Firmware Integrity Check Support
Select Enabled or Disabled to enable or disable firmware integrity check.
If Enabled is selected, the server will take 10 more seconds to complete POST.
Enabled
GPU Configuration submenu
Figure 97 shows the GPU Configuration submenu screen, on which you can view information about present GPUs. For parameter description, see Table 78.
Figure 97 GPU Configuration submenu
Table 78 Items on the GPU Configuration submenu screen
Item
Slot 7: GPU-A10-24G
GPU information and GPU slot.
When no GPU is present, the screen displays No GPU Device Found.
GPU information submenu
The items on the GPU information submenu are the same for different GPUs. This section uses Slot 7: GPU-A10-24G as an example. The item description is displayed in Table 79.
Figure 98 GPU information submenu
Table 79 Items on the GPU submenu screen
Item
Slot Number
GPU slot number.
BDF
GPU bus number:device number:function number.
VendorID
ID of the vendor for the GPU.
DeviceID
Device ID of the GPU.
SubVendorID
ID of the sub-vendor for the GPU.
SubDeviceID
Sub-device ID of the GPU.
Max Speed
Maximum speed of the GPU.
Link Speed
Actual speed of the GPU.
Max Width
Maximum bandwidth of the GPU.
Link Width
Actual bandwidth of the GPU.
FwVersion
Firmware version of the GPU.
Product Name
Product name of the GPU.
Vendor Name
Vendor name of the GPU.
Serial Number
Serial number of the GPU.
Part Number
Part number assigned by the vendor.
The BIOS obtains some GPU information from HDM. If the information obtaining fails, the screen displays "More information is collecting, please wait...."
Driver Health submenu
Figure 99 shows the Driver Health submenu screen, on which you can view the health state of a driver or controller. The submenu items are described in Table 80.
Figure 99 Driver Health submenu screen
Table 80 Items on the Driver Health submenu screen
Item
This submenu displays the state of the actual installed drivers or controllers on the server.
Displays the health state of a driver or a controller.
Options:
·     Healthy—Normal.
·     Failed—Abnormal.
If the state is Failed, press Enter and follow the instructions to repair the driver or controller. The repair method varies by driver or controller.
Server menu
Figure 100 shows the Server menu. From the menu, you can access the firmware information menu, and configure server management features such as the FRB-2 timer, OS watchdog timer, firmware information, HDM network configuration, and HDM user settings.
The menu items are described in Table 81.
Figure 100 Server menu
Table 81 Items on the Server menu screen
Item
IPMI Interface Type
Set the type of interface for communication between the host and the BMC. Options:
·     Kcs InterfaceCommunication through an interface styled after a keyboard controller, which is commonly used for communication over the system bus. When a Windows system is used in Legacy mode, switch the IPMI channel to the Kcs Interface type as a best practice. Otherwise, an Unknown Device alarm will appear in the Device Manager, and IPMI commands cannot be sent in the Windows system.
·     BT InterfaceCommunication through a block transfer style interface, which is typically used for supporting high-speed data transmission.
BT Interface
FRB-2 Configuration
The following are First Run Boot-2 (FRB-2) setting options:
FRB-2 Timer
Select Enabled or Disabled to enable or disable the FRB-2 timer.
Enabled
FRB-2 Timer timeout
This item is available only when FRB-2 Timer is set to Enabled.
Set the timeout for the FRB-2 timer in the range of 1 to 30 minutes.
15 minutes
FRB-2 Timer Policy
Select the action to take when the FRB-2 timer expires.
Options:
·     Do NothingNo action is taken.
·     Reset—Reboots the system.
·     Power Down—Removes the main power from the system.
·     Power CyclePower cycles the system.
Power Cycle
Server Manager Configuration
The following are server management setting options:
Restore On AC Power Loss
Select the state to which the system is restored when the system AC power is restored.
Options:
·     Always Power On—The system always returns to the power-on state.
·     Always Remain Off—The system always returns to the power-off state.
·     Restore Last Power State—The system returns to the power state when AC power was lost.
The default state also depends on HDM settings.
Serial Number
Set the serial number for the server. It is 2-20 characters in length. The format must meet the HDM requirements.
N/A
Asset Tag
Set the asses tag for the server. It is 0-48 characters in length. The format must meet the HDM requirements.
N/A
HDM Configuration
The following are Hardware Device Management (HDM) software setting options:
Load HDM Factory Reset
To restore the factory default settings for HDM, select this item, and then press Enter. It takes one minute to restore the factory default HDM settings. After the restoration finishes, the server restarts automatically.
CAUTION CAUTION:
Do not configure HDM-related items before the server restarts.
N/A
View FRU information
Access the submenu for viewing FRU information, as shown in Figure 101.
The submenu items are described in Table 82.
N/A
HDM Network Configuration
Access the network configuration submenu for HDM access, as shown in Figure 102.
The submenu items are described in Table 83.
N/A
HDM User Settings
Access the submenu for managing HDM user accounts, as shown in Figure 106.
The submenu items are described in Table 87.
N/A
Firmware Information
Displays firmware information submenu.
N/A
View FRU information submenu
Figure 101 shows the View FRU information menu screen, on which you can view FRU information. The menu items are described in Table 82.
Figure 101 View FRU information menu screen
Table 82 Items on the View FRU information menu screen
Item
System Manufacturer
Displays the manufacturer of the system.
System Product Name
Displays the name of the system product.
System Version
Displays the version of the system.
System Serial Number
Displays the serial number of the system.
Board Manufacturer
Displays the manufacturer of the system board.
Board Product Name
Displays the product name of the system board.
Board Part Name
Displays the version of the system board.
Board Serial Number
Displays the serial number of the system board.
Chassis Manufacturer
Displays the manufacturer of the chassis.
Chassis Product Number
Displays the product name of the chassis.
Chassis Serial Number
Displays the serial number of the system product.
System Uuid
Displays the UUID of the system.
HDM Network Configuration submenu
Figure 102 shows the HDM Network Configuration submenu screen, on which you can view HDM network configuration information. The submenu items are described in Table 83.
Figure 102 HDM Network Configuration submenu screen
Table 83 Items on the HDM Network Configuration submenu screen
Item
Sharelink Configuration
Access the submenu for configuring the HDM sharelink.
The BIOS for the B5700 G6 server does not support this item.
IPv4 Network Configuration
Access the submenu for configuring the IPv4 network.
IPv6 Network Configuration
Access the submenu for configuring the IPv6 network.
Sharelink Configuration submenu
Figure 103 shows the Sharelink Configuration submenu screen, on which you can view Sharelink configuration information. The submenu items are described in Table 84.
Figure 103 Sharelink Configuration submenu screen
Table 84 Items on the Sharelink Configuration submenu screen
Item
BIOS Share Link Control
Select whether to enable the modification permission for NCSI shared ports.
Options:
·     DisabledDisables the modification permission for NCSI Network Setting in the BIOS.
·     EnabledEnables the modification permission for NCSI Network Setting in the BIOS.
·     UnspecifiedIf this option is selected, the NCSI network Setting option is grayed.
Unspecified
Select HDM NCSI network port.
This item is available when an NCSI-capable network adapter is installed on the server.
You can select any network port of the present NCSI-capable network adapter.
Sharelink Network
Select whether to enable the HDM shared network port. Options:
·     EnabledEnables the HDM shared network port.
·     DisabledDisables the HDM shared network port.
·     AutoIn this mode. the HDM shared network port is automatically enabled and cannot be disabled.
Enabled
IPv4 Network Configuration submenu
The HDM shared network port and the HDM dedicated network port have the same parameters. The IP addresses of these ports cannot be in the same segment. The following takes the HDM dedicated network port for example.
Figure 104 shows the IPv4 Network Configuration submenu screen, on which you can view IPv4 network configuration information. The menu items are described in Table 85.
Figure 104 IPv4 Network Configuration submenu screen
Table 85 Items on the IPv4 Network Configuration submenu screen
Item
Refresh
Refresh the HDM network configuration information.
Press Enter to refresh configuration before making any changes.
N/A
Save
After finishing IPv4 Network Configuration, save the configuration to make it effective.
Options:
·     YesSave the configuration. Click Refresh. In the dialog box that opens, click Yes to refresh the page and then you can view the saved configuration.
·     NoDo not save the configuration.
N/A
HDM Net Mode
Displays the HDM network mode dynamically.
Options:
·     Normal Mode—In this mode, the HDM can be accessed through the HDM shared network port or the HDM dedicated network port.
·     Active/standby Mode—In this mode, the HDM dedicated port is used as the first choice to access the HDM.
N/A
Dedicated VLAN Setting
Select Enabled or Disabled to enable or disable VLAN on the HDM dedicated network port.
Disabled
Dedicated VLAN id
This item is available only when Dedicated VLAN Setting is set to Enabled.
Configures the VLAN ID, in the range of 2 to 4094.
2
Dedicated VLAN priority
Specify the priority of a dedicated VLAN, in the range of 0 to 7. The larger the number, the higher the priority.
When traffic congestion occurs, frames with the highest priority will be sent first.
0
Shared VLAN Settings
Select Enabled or Disabled to enable or disable VLAN on the HDM shared network port.
Disabled
Shared VLAN id
This item is available only when Shared VLAN Setting is set to Enabled.
2
Shared VLAN priority
Specify the priority of a shared VLAN, in the range of 0 to 7. The larger the number, the higher the priority.
0
HDM Dedicated/Shared Network Port
Configuration Address source
Configure the HDM network status parameters.
Options:
·     Unspecified—Retains the current configuration.
·     StaticUses manually specified configuration.
·     DynamicHdmDhcpUses network information obtained through DHCP.
Unspecified
Current Configuration Address source
Displays the current address source.
N/A
Station IP Address
This item is available only when Configuration Address source is set to Static.
The configured HDM static IPv4 address takes effect only after both the Station IP Address and Subnet Mask are configured.
Specify the station IP address for the port.
192.168.1.2
Subnet Mask
This item must be specified before you set the HDM static IPv4 address.
Specify the subnet mask.
255.255.0.0
Station MAC Address
Displays the MAC address of the port.
N/A
Router IP Address
Specify the gateway IP address.
N/A
Router MAC Address
Displays the gateway MAC address.
N/A
IPv6 Network Configuration submenu
Figure 105 shows the IPv6 Network Configuration submenu screen, on which you can view IPv4 network configuration information. The menu items are described in Table 86.
Figure 105 IPv6 Network Configuration submenu screen
Table 86 Items on the IPv6 Network Configuration submenu screen
Item
Refresh
Refresh HDM network configuration information.
N/A
Save
After finishing IPv6 Network Configuration, save the configuration to make it effective.
Options:
·     YesSaves the configuration. Click Refresh. In the dialog box that opens, click Yes to refresh the page and then you can view the saved configuration.
·     NoDoes not save the configuration.
N/A
HDM Net Mode
Options:
·     Bonding Mode—In this mode, the HDM shared network port and the HDM dedicated network port are used as one logical network port.
N/A
Options:
Unspecified
N/A
Station IP Address
The configured HDM static IPv6 address takes effect only after both the Station IPv6 Address and Prefix Length are configured.
Specify the IPv6 address for the port.
N/A
Prefix Length
This item must be specified before you set the HDM static IPv6 address.
Specify the prefix length, in the range of 0 to 127. 0 indicates that no prefix length is specified.
0
IPv6 Router IP Address
The IPv6 gateway IPv6 address and the port IPv6 address must be in the same segment.
Specify the IPv6 gateway IP address.
N/A
IPv6 address status
Displays the status of the IPv6 address.
Options:
·     Actived.
·     Disabled.
·     Pending.
·     Failed.
·     Deprecated.
·     Invalid.
·     Reserved.
N/A
IPv6 DHCP Algorithm
Displays the IPv6 DHCP algorithm.
N/A
HDM User Settings submenu
Figure 106 shows the HDM User Settings menu screen, on which you can configure HDM users. The menu items are described in Table 87.
Figure 106 HDM User Settings submenu screen
Table 87 Items on the HDM User Settings submenu screen
Item
User ID
Displays the current HDM user ID.
User information is configurable only when the user ID is 2 (Admin).
N/A
User Name
Press Enter to modify the HDM username.
A username is a case-sensitive string of 1 to 16 characters and supports only letters, digits, and underscores (_).
The name of the login user cannot be modified.
N/A
User Password
Set the HDM user password.
The password must follow these HDM password complexity check rules:
·     When password complexity check is enabled:
¡     The password must be a case-sensitive string of 8 to 20 characters and can contain only letters, digits, spaces, and special characters: `-!@#$%^&*()_+-=[]\{}|;':",./<>?
¡     It must contain at least two kinds of characters: uppercase letters, lowercase letters or numbers.
¡     It must contain at least one space or special character.
¡     It cannot be the same as the username or the reverse order of the username.
·     When password complexity check is disabled, the password must be a case-sensitive string of 2 to 20 characters and can contain only letters, digits, spaces, and the following special characters: `-!@#$%^&*()_+-=[]\{}|;':",./<>?
By default, password complexity check is enabled.
For more information about how to enable or disable password complexity check, see HDM online help.
N/A
Add User
Add HDM users. Enter the username, press Enter, and then set the password.
Delete User
Delete HDM users.
Change User Settings
Change HDM user settings.
Load HDM User Configuration
Restore the default HDM user configuration. If the default HDM user is online, this feature is not available.
N/A
Firmware Information submenu
Figure 107 shows the Firmware Information submenu screen, on which you can view firmware information. The menu items are described in Table 88.
Figure 107 Firmware Information submenu screen
Table 88 Items on the Firmware Information submenu screen
Item
BIOS Information
BIOS Vendor
Displays the BIOS vendor.
Core Version
Displays the BIOS core version.
Compliancy
Displays the BIOS compliance standard.
Project Name
Displays the project name.
BIOS Version
Displays the BIOS version.
Build Date and Time
Displays the BIOS build date and time.
HDM Information
HDM Self Test Status
Displays the HDM self test status.
HDM Device ID
Displays the HDM device ID.
HDM Device Revision
Displays the HDM device revision.
HDM Firmware Revision
Displays the HDM firmware revision.
IPMI Version
Display the IPMI version.
Security menu
Figure 108 shows the Security menu, on which you can configure security features such as setting the BIOS administrator and user passwords.
The menu items are described in Table 89.
Figure 108 Security menu screen
Table 89 Items on the Security menu screen
Item
Password Description
Displays the password description.
Administrator Password
Set the administrator password. For more information about restrictions for setting the administrator password, see "Restrictions and guidelines."
User Password
Set the user password. For more information about restrictions for setting the user password, see "Restrictions and guidelines."
Power On Password
Set the power-on password. For more information about restrictions for setting the power-on password, see "Restrictions and guidelines."
HDD Security Configuration
Displays hard disk drives that support security configuration, for example, P2:TS256GMTS800.
To configure security settings for a hard disk drive, select the disk drive and press Enter.
Secure Boot Menu
This item is available only in UEFI boot mode.
Access the submenu for configuring secure boot, as shown in Figure 109.
The submenu items are described in Table 90.
Figure 109 shows the Secure Boot submenu screen. The submenu items are described in Table 90.
Secure boot is available only in UEFI mode. With this feature enabled, key authentication is required when you load any operating system or hardware driver program. This prevents intrusion of malware. The servers come with a secure boot key and you can import keys as needed. Secure boot does not require any hardware.
Figure 109 Secure Boot submenu screen
Table 90 Items on the Secure Boot menu screen
Item
System Mode
Displays the system mode.
N/A
Secure Boot
Select Enabled or Disabled to enable or display secure boot.
With this feature enabled, key authentication is required to load any operating system or hardware driver.
Options:
·     Disabled—Disables the Secure Boot.
·     Enabled—Enables the Secure Boot, and a mode change requires a reboot. To enable Secure Boot, you must meet the following conditions:
¡     Secure Boot Mode is set to Custom mode.
¡     Platform Key (PK) has been registered.
¡     CSM Support is disabled.
Disabled
Secure Boot Mode
Select a secure boot mode.
Options:
·     StandardUses the preset secure boot key and certificate. In standard boot mode, you can select whether to install the factory default secure boot key.
·     CustomIn custom boot mode, you can configure the secure boot policy without needing full authentication.
Custom
Restore Factory Keys
Restore the factory default secure boot keys.
N/A
Reset To Setup Mode
Reset the system mode to setup mode.
N/A
Key Management
Access the submenu for key management, as shown in Figure 110.
The submenu items are described in Table 91.
N/A
Figure 110 shows the Key Management submenu. The submenu items are described in Table 91.
Figure 110 Key Management submenu screen
Table 91 Items on the Key Management submenu screen
Item
Vendor Keys
Displays whether the vendor keys have been modified.
Options:
·     ValidThe vendor keys have not been modified and are valid.
·     ModifiedThe vendor keys have been modified or deleted.
N/A
Factory Key Provision
Select Enabled or Disabled to enable or disable provisioning the factory default keys when the system is in setup mode.
Disabled
Access the submenu for restoring factory default keys.
This operation forces the system to enter user mode and installs factory default secure boot keys.
N/A
Reset To Setup Mode
Access the submenu for resetting the system mode to setup mode.
N/A
Export Secure Boot Variables
Access the submenu for exporting all secure boot variables.
N/A
Enroll Efi Image
Access the submenu for enrolling the EFI image.
This operation enables secure boot for the image and enrolls a SHA256 hash of the PE image in the Authorized Signature Database (DB).
N/A
Platform Key(PK)
Access the submenu for managing the platform key.
Option is Update.
N/A
Key Exchange Keys
Access the submenu for managing key exchange keys.
Options:
·     Update.
·     Append.
N/A
Authorized Signatures
Access the submenu for configuring authorized signatures.
Options:
·     Update.
·     Append.
N/A
Forbidden Signatures
Access the submenu for managing forbidden signatures.
Options:
·     Update.
·     Append.
N/A
Authorized TimeStamps
Access the submenu for managing authorized timestamps.
Options:
·     Update.
·     Append.
N/A
OsRecovery Signatures
Access the submenu for configuring operating system recovery signatures.
Options:
·     Update.
·     Append.
N/A
Boot menu
Figure 111 shows the Boot menu, on which you can configure boot settings such as the boot type and boot sequence.
The menu items are described in Table 92.
Figure 111 Boot menu screen
Table 92 Items on the Boot menu screen
Item
Quiet Boot
Select On or Off to enable or disable quiet boot mode.
Options:
·     DisabledEnables the boot screen to display POST information during boot process.
·     Enabled—Enables the boot screen to display the product logo instead of POST information during boot process.
Enabled
iFIST Boot
Select Enabled or Disabled to enable or disable iFIST boot.
If iFIST boot is disabled, the iFist item is not displayed on the BIOS startup screen as shown in Figure 2, and pressing F10 cannot boot iFIST.
Enabled
USB Boot
Select Enabled or Disabled to enable or disable USB boot.
Enabled
EFI Shell Boot
Select Enabled or Disabled to enable or disable shell boot.
Disabled
Boot mode select
Set the Boot mode selection options.
Options:
·     LEGACY—Legacy boot mode.
·     UEFI—UEFI boot mode.
UEFI
Fixed Boot Order Priorities
The following options are for configuring the boot priority:
Boot Option #1-#4
Set the first to fourth boot options, select Disabled to disable boot items.
Options:
·     Hard Disk: Boot from the hard disk.
·     Network: Boot from the network.
·     CD/DVD: Boot from CD/DVD.
·     Other Device: Boot from other methods.
N/A
Add New Boot Option
Add Boot item submenu.
N/A
Delete Boot Option
Delete Boot item submenu.
N/A
UEFI Hard Disk Drive BBS Priorities
Access the submenu for configuring the boot priorities of hard disk drive, USB-HDD, SD card, and virtual hard disk drive, as shown in Figure 114.
The submenu items are described in Table 94.
N/A
Access the submenu for configuring the boot priorities of hard disk drive, USB-HDD, SD card, and virtual hard disk drive.
N/A
UEFI CDROM/DVD Drive BBS Priorities
When one or more CD- or DVD-ROM drives are connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives.
N/A
N/A
UEFI Network Drive BBS Priorities
Access the submenu for configuring the boot priorities of available network drives.
N/A
N/A
UEFI Other Drive BBS Priorities
Set the boot device priority sequence from the available UEFI other drives.
The options include but are not limited to:
·     Embedded UEFI shell. This option is available only when EFI Shell Boot is set to Enabled.
·     Other unidentified boot devices.
N/A
Add New Boot Option submenu
Figure 112 shows the Add New Boot Option submenu screen, on which you can view menu information. The menu items are described in Table 93.
Figure 112 ADD New Boot Option submenu screen
Table 93 Items on the Add New Boot Option submenu screen
Item
Add Boot Option
Add boot item with a name of 3 to 20 characters.
Path for Boot Option
Select the storage location for the new boot item.
Boot Option file Path
Enter the file path.
Create
Click to complete the creation.
Delete Boot Option submenu
Figure 113 shows the Delete Boot Option submenu screen, on which you can select the boot item you want to delete.
Figure 113 Delete Boot Option submenu screen
Boot the UEFI Hard Disk Drive BBS Priorities submenu
Access the submenu for configuring the boot priorities of UEFI Hard Disk Drive BBS, as shown in Figure 114. The submenu items are described in Table 94.
Figure 114 UEFI Hard Disk Drive BBS Priorities submenu screen
Table 94 Items on the UEFI Hard Disk Drive BBS Priorities submenu screen
Item
Boot Option #X
Select a hard disk as the X boot option. To disable this boot option, select Disabled.
Exit menu
Figure 115 shows the Exit menu, on which you can modify BIOS parameter settings and exit the BIOS.
The menu items are described in Table 95.
Figure 115 Exit menu screen
Table 95 Items on the Exit menu screen
Item
Save Options
Save Changes and Exit
Exit with changes saved.
Discard Changes and Exit
Exit without saving changes.
Save Changes and Reset
Restart the server with changes saved. (Recommended)
Discard Changes and Reset
Restart the server without saving changes.
Save Changes
Save changes without exiting the BIOS.
Discard Changes
Discard changes without exiting the BIOS.
Default Options
Restore Defaults
Restore the factory-default settings.
The following information is not restored:
·     System date and time on the Main screen.
·     Items except for FRB-2 Timer on the Server screen.
·     Password-related items on Security screen.
Boot Override
Select a boot device option and press Enter to boot from that device. This field displays all available boot options.
This setting is a one-time setting that takes effect only at the next boot. Subsequent boots will use the boot order configured on the Boot menu screen.
RedHat Boot Manager(INTEL SSDSC2KB480G7)
Load the operating system from the hard disk.
Industry standards
The BIOS follows the industry standards shown in Table 96.
Table 96 Industry standards
Industry standards
Full name
Version
URL
UEFI
Unified Extensible Firmware Interface (UEFI) Specification
2.9
https://uefi.org/
ACPI
Advanced Configuration and Power Interface (ACPI) Specification
6.5
https://uefi.org/
SMBIOS
System Management BIOS (SMBIOS) Specification
3.6
https://www.dmtf.org/
Redfish
Redfish Specification
1.11
PCI
PCI Local Bus Specification
3.0
https://pcisig.com/specifications/
PCI Firmware
PCI Firmware Specification
3.2
PCIE
PCI Express® Base Specification
5.0
DDR
DDR5 SDRAM Specification
DDR5
https://www.jedec.org/
BIOS options and corresponding Redfish out-of-band attributes
The correspondence between BIOS Setup options and Redfish out-of-band attributes is shown in Table 97. For a detailed introduction to specific Redfish attributes, see "BIOS menus."
Table 97 Correspondence between BIOS Setup options and Redfish out-of-band attributes
BIOS option
MenuPath: Advanced > Socket Configuration > Common RefCode Configuration
NUMA
NUMA
Virtual NUMA
VirtualNuma
MenuPath: Advanced > Socket Configuration > Uncore Configuration > Uncore General Configuration
SNC
SNC
MMIO High Base
MMIOHighBase
MMIO High Granularity Size
MMIOHighGranularitySize
Limit CPU PA to 46 bits
LimitCPUPato46bits
MenuPath: Advanced > Socket Configuration > IIO Configuration
PCIe Hot Plug
PCIeHotPlug
PCI-E ASPM Support (Global)
PCIeAspmSupportGlobal
PCIe 10-bit Tag Support (Global)
PCIe10bitTagSupportGlobal
PCIe Max Read Request Size
PCIeMaxReadRequestSize
MenuPath: Advanced > Socket Configuration > IIO Configuration > Socket 1/2/3/4 Configuration > Port X
(The display of the Port Configuration menu list may vary depending on the server configuration. Use Socket 1 Configuration /Port 1A as an example)
PCI-E Port
Cpu1PciePort1ASlot16En
Link Speed
Cpu1PciePort1AlinkSpeed
Override Max Link Width
Cpu1PciePort1AoverrideMaxLinkWidth
PCI-E Port Max Payload Size
Cpu1PciePort1AMaxPayload
PCI-E ASPM Support
Cpu1PciePort1AASPM
Cpu1PciePort1A10bitTag
MenuPath: Advanced > Socket Configuration > IIO Configuration > Intel VT for Directed I/O (VT-d)
VTdSupport
Interrupt Remapping
InterruptRemapping
X2APIC Opt-Out
X2APICOptOut
MenuPath: Advanced > Socket Configuration > IIO Configuration > Intel VMD technology > Intel VMD for Volume Management Device on Socket 1/2
(Use Intel VMD for Volume Management Device on Socket 1 as an example)
Enable/Disable VMD
Cpu1VMDPchPortsEn
PCH Root Port 0
Cpu1VMDPchRootPort0En
PCH Root Port 1
Cpu1VMDPchRootPort1En
Hot Plug Capable
Cpu1VMDPchHpe
CfgBar size
Cpu1VMDPchCfgBarSize
CfgBar attribute
Cpu1VMDPchCfgBarAttr
MemBar1 size
Cpu1VMDPchMemBar1Size
MemBar1 attribute
Cpu1VMDPchMemBar1Attr
MemBar2 size
Cpu1VMDPchMemBar2Size
MemBar2 attribute
Cpu1VMDPchMemBar2Attr
VMD for Direct Assign
Cpu1VMDPchVMDforDirectAssign
Enable/Disable VMD
Cpu1VMDIou[1-7]En
VMD port [1-7]A - Slot X
Cpu1VMDIou[1-7]PortASlotX
VMD port [1-7]B
Cpu1VMDIou[1-7]PortB
VMD port [1-7]C
Cpu1VMDIou[1-7]PortC
VMD port [1-7]D
Cpu1VMDIou[1-7]PortD
VMD port [1-7]E
Cpu1VMDIou[1-7]PortE
VMD port [1-7]F
Cpu1VMDIou[1-7]PortF
VMD port [1-7]G
Cpu1VMDIou[1-7]PortG
VMD port [1-7]H
Cpu1VMDIou[1-7]PortH
Hot Plug Capable
Cpu1VMDIou[1-7]Hpe
CfgBar size
Cpu1VMDIou[1-7]CfgBarSize
CfgBar attribute
Cpu1VMDIou[1-7]CfgBarAttr
MemBar1 size
Cpu1VMDIou[1-7]MemBar1Size
MemBar1 attribute
Cpu1VMDIou[1-7]MemBar1Attr
MemBar2 size
Cpu1VMDIou[1-7]MemBar2Size
MemBar2 attribute
Cpu1VMDIou[1-7]MemBar2Attr
Cpu1VMDIou[1-7]VMDforDirectAssign
MenuPath: Advanced > Socket Configuration > Memory Configuration
DDR PPR Type
PPRType
Memory Frequency
MemoryFrequency
DDR 2x Refresh Enable
2xRefreshEnable
MenuPath: Advanced > Socket Configuration > Advanced Power Management Configuration > Memory Power & Thermal Configuration > Memory Thermal
Throttling Mode
ThrottlingMode
MenuPath: Advanced > Socket Configuration > Memory Configuration > Memory RAS Configuration
Mirror Mode
MirrorMode
ADDDC Sparing
ADDDCSparing
Patrol Scrub
PatrolScrub
Patrol Scrub Interval
PatrolScrubInterval
DDR5 ECS
DDR5ECS
MenuPath: Advanced > Socket Configuration > Processor Configuration
Enable LP [Global]
HyperThreading
Hardware Prefetcher
HardwarePrefetcher
L2 RFO Prefetch Disable
L2RFOPrefetchDisable
Adjacent Cache Prefetch
AdjacentCachePrefetch
DCU Streamer Prefetcher
DCUStreamerPrefetcher
DCU IP Prefetcher
DCUIPPrefetcher
LLC Prefetch
LLCPrefetch
Homeless Prefetch
HomelessPrefetch
Extended APIC
ExtendedAPIC
Enable Intel(R) TXT
EnableTXT
VMX
VMX
Enable SMX
EnableSMX
AES-NI
AES-NI
Memory Encryption (TME)
TME
Trust Domain Extension (TDX)
TrustDomainExtension
TDX Secure Arbitration Mode Loader (SEAM Loader)
TDXSecureArbitrationModeLoader
SGX Factory Reset
SGXFactoryReset
SW Guard Extensions (SGX)
SWGuardExtensions
SGX PRM Size
SGXPRMSize
Workload Profile Configuration
WorkloadProfileConfiguration
Static Turbo
StaticTurbo
CPU Frequency Select
CPUFrequencySelect
MenuPath: Advanced > Socket Configuration > Advanced Power Management Configuration > Hardware PM State Control
Hardware P-States
HardwarePStates
EPP Enable
EPPEnable
MenuPath: Advanced > Socket Configuration > Advanced Power Management Configuration > CPU P State Control
Intel SST-PP
IntelSstPP
Dynamic SST-PP
DynamicSstPP
Activate SST-BF
ActiveSstBF
Configure SST-BF
ConfigureSstBF
SpeedStep (Pstates)
EIST
EIST PSD Function
EISTPSDFunction
Boot performance mode
BootPerformanceMode
Energy Efficient Turbo
EnergyEfficientTurbo
Turbo Mode
TurboMode
CPU Flex Ratio Override
CPUFlexRatioOverride
CPU Core Flex Ratio
CPUCoreFlexRatio
MenuPath: Advanced > Socket Configuration > Advanced Power Management Configuration > CPU C State Control
Enable Monitor MWAIT
EnableMonitorMWait
CPU C1 auto demotion
CPUC1AutoDemotion
CPU C1 auto undemotion
CPUC1AutoUndemotion
CPU C6 report
CPUC6Report
Enhanced Halt State (C1E)
C1E
MenuPath: Advanced > Socket Configuration > Advanced Power Management Configuration > Package C State Control
Package C State
PackageCState
MenuPath: Advanced > Socket Configuration > Advanced Power Management Configuration > CPU Thermal Management
Thermal Monitor
ThermalMonitor
MenuPath: Advanced > Socket Configuration > Advanced Power Management Configuration > CPU - Advanced PM Tuning
Uncore Freq Scaling
UncoreFreqScaling
Uncore Freq RAPL
UncoreFreqRAPL
Optimized Power Mode
OptimizedPowerMode
MenuPath: Advanced > Socket Configuration > Advanced Power Management Configuration > CPU - Advanced PM Tuning > Energy Perf BIAS
Power Performance Tuning
PowerPerformanceTuning
ENERGY_PERF_BIAS_CFG mode
AltEngPerfBIAS
Workload Configuration
WorkloadConfiguration
MenuPath: Advanced > Platform Configuration > Miscellaneous Configuration
Active Video
ActiveVideo
MenuPath: Advanced > Platform Configuration > PCH-IO Configuration > Chipset USB Configuration
USB Port Disable Override
USBPortDisableOverride
Rear Bottom USB Port 3.0 Capability
RearBottomUSBPort3.0Capability
Rear Top USB Port 3.0 Capability
RearTopUSBPort3.0Capability
Front Right USB Port 3.0 Capability
FrontRightUSBPort3.0Capability
Internal Bottom USB Port 2.0 Capability
InternalBottomUSBPort2.0Capability
Front Left Top USB Port 2.0 Capability
FrontLeftTopUSBPort2.0Capability
Front Right USB Port 2.0 Capability
FrontRightUSBPort2.0Capability
Rear Bottom USB Port 2.0 Capability
RearBottomUSBPort2.0Capability
Rear Top USB Port 2.0 Capability
RearTopUSBPort2.0Capability
MenuPath: Advanced > Platform Configuration > PCH-IO Configuration > SATA And RST Configuration > Controller 1/2/3 SATA And RST
(Use SATA Controller 1 as an example)
SATA Controller 1
SATAController1
SATA1 Mode Selection
SATA1ModeSelection
SATA Port 0/1/2/3/4/5/6/7
Sata1P[0-7]En
MenuPath: Advanced > Platform Configuration > Runtime Error Logging
System Errors
SystemErrors
S/W Error Injection Support
SWErrorInjectionSupport
System Memory Poison
SystemMemoryPoison
System Cloaking
SystemCloaking
MenuPath: Advanced > Platform Configuration > Runtime Error Logging > eMCA Settings
EMCA Logging Support
EmcaLoggingSupport
LMCE Support
LmceSupport
EMCA CMCI-SMI Morphing
EmcaCmciSmiMorphing
EMCA CMCI-SMI Threshold
EmcaCmciSmiThreshold
MenuPath: Advanced > Platform Configuration > Runtime Error Logging > Memory Error Enabling
Memory Corrected Error
MemoryCorrectedError
MenuPath: Advanced > Platform Configuration > Runtime Error Logging > IIO Error Enabling
Os Native AER Support
OsNativeAERSupport
IIO MCA Support
IIOMCASupport
IIO eDPC Support
IIOeDPCSupport
MenuPath: Advanced > Platform Configuration > Server ME Configuration
Altitude
Altitude
Enable MCTP Proxy
MCTProxyEnable
MenuPath: Advanced > Trusted Computing
SecurityDeviceSupport
MenuPath: Advanced > ACPI Settings
EnableACPIAutoConfiguration
Enable Hibernation
EnableHibernation
MenuPath: Advanced > Serial Port Console Redirection
Console Redirection
ConsoleRedirection
ConsoleRedirectionEMS
MenuPath: Advanced > Serial Port Console Redirection > Console Redirection Settings
OutOfBandMgmtPort
Terminal Type EMS
TerminalTypeEMS
Bits per second EMS
BitsPerSecondEMS
Flow Control EMS
FlowControlEMS
MenuPath: Advanced > Serial Port Console Redirection > Legacy Console Redirection Settings
RedirectionCOMPort
Resolution
LegacyOSRedirectionResolution
Redirect After POST
RedirectAfterPOST
MenuPath: Advanced > Serial Port Console Redirection > COM0
Terminal Type
TerminalType
Bits per second
BitsPerSecond
Data Bits
DataBits
Parity
Parity
Stop Bits
StopBits
Flow Control
FlowControl
VTUTF8ComboKeySupport
Putty KeyPad
PuttyKeyPad
MenuPath: Advanced > PCI Subsystem Settings
Above 4G Decoding
Above4GDecoding
SR-IOV Support
SRIOVSupport
MenuPath: Advanced > USB Configuration
Legacy USB Support
LegacyUSBSupport
XHCI Hand-off
XhciHandOff
USBMassStorageDriverSupport
MenuPath: Advanced > CSM Configuration
CSM Support
CSMSupport
Option ROM Policy
OptionRomPolicy
Network
Network
Storage
Storage
Video
Video
Other PCI devices
OtherPCIdevices
MenuPath: Advanced > Network Configuration >Onboard NIC Configuration
Onboard Port1 PXE
OnboardNicPort1PXE
Onboard Port2 PXE
OnboardNicPort2PXE
MenuPath: Advanced > Network Configuration > PCIE Network Configuration
(NIC: Slot x is displayed dynamically, indicating the correspondence between NIC numbers and slot numbers)
PCIE Network PXE
PCIeNetWorkPXE
NIC : Slot 2
PcieNetworkSlot2
NIC Slot2 Port1
PcieSlot2Port1
NIC Slot2 Port2
PcieSlot2Port2
NIC : Slot 16
PcieNetworkSlot16
NIC Slot16 Port1
PcieSlot16Port1
NIC Slot16 Port2
PcieSlot16Port2
NIC Slot16 Port3
PcieSlot16Port3
NIC Slot16 Port4
PcieSlot16Port4
IPv4 PXE Support
IPv4PXESupport
IPv6 PXE Support
IPv6PXESupport
PXE Boot Wait Time
PXEBootWaitTime
Media Detect Count
MediaDetectCount
PXE Retry Count
PXERetryCount
MenuPath: Advanced > Miscellaneous Configuration
Debug Mode
DebugMode
Summary Debug Mode
SummaryDebugMode
Init CE report
InitCEReport
NvramChecksumSupport
Oprom Load Default Policy
OpromLoadDefaultPolicy
DMI Vendor Change
DmiVendorChange
FirmwareIntegrityCheck
MenuPath: Security > Secure Boot Menu
Secure Boot
SecureBoot
Secure Boot Mode
SecureBootMode
MenuPath: Security > Secure Boot Menu > Key Management
FactoryKeyProvision
MenuPath: Boot
Quiet Boot
QuietBoot
iFIST Boot
iFISTBoot
USB Boot
USBBoot
EFI Shell Boot
EFIShellBoot
Boot Mode Select
BootMode
Boot Option #1
BootOrder1
Boot Option #2
BootOrder2
Boot Option #3
BootOrder3
Boot Option #4
BootOrder4
MenuPath: Server
IPMI Interface Type
IPMIInterfaceType
FRB-2 Timer
FRB2Timer
FRB-2 Timer timeout
FRB2TimerTimeout
FRB-2 Timer Policy
FRB2TimerPolicy
MenuPath: Advanced > Socket Configuration > Processor Configuration > Per-Socket Configuration > CPU Socket 1/2/3/4 Configuration
Core Disable Number
Cpu[1-4]CoreDisableNumber
MenuPath: Main
Setup Mode
SetupMode
System Language
SystemLanguage
FAQ
PCIe 10-bit tag support prompt box appears when no settings are edited for the R5500 G6 Intel server
Symptom
When the R5500 G6 Intel server is connected to a switch, a prompt box for PCIe 10-bit Tag Support [Force Enable]->Auto will appear if the following conditions are met:
·     No settings are modified.
·     Press F3 to save the configuration and restart the server.
Analysis
During the startup process, the server will initialize and configure PCIe settings, dynamically changing the PCIe 10-bit tag support setting to Force Enable for the corresponding slot with the switch. Even if you can set the 10-bit tag setting to Auto after pressing F3 to save the configuration and restart the server. However, during the next startup, the corresponding option will still be dynamically changed to Force Enable.
This option an auto configuration item used for ensuring the stability between the server and the switch. Therefore, no action is required when the PCIe 10-bit Tag Support [Force Enable]->Auto prompt box appears.
Acronyms and abbreviations
Term
Definition
A
ACPI
ADR
Asynchronous Dram Refresh
AHCI
Advanced Host Controller Interface
B
BIOS
Basic Input Output System
C
CFG
Configure
CSM
Compatibility Support Module
D
DCU
Drive Control Unit
DMA
Direct Memory Access
DMI
Direct Media Interface
DRAM
Dynamic Random Access Memory
DCPMM
Intel® OptaneTM DC PMEM module
E
ECC
Error Checking and Correcting
EFI
EIST
Enhanced Intel SpeedStep Technology
EMS
EMCA
Enhanced Machine Check Architecture
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDM
I
IDE
Integrated Drive Electronics
IIO
Integrated I/O Module
IMC
Integrated Memory Controller
IRQ
Interrupt Request
iSCSI
Internet Small Computer System Interface
L
LLC
Last Level Cache
LLDP
Link Layer Discovery Protocol
LUN
Logical Unit Number
M
MAC
Media Access Control
MCTP
Management Component Transport Protocol
ME
Management Engine
MMIO
Memory mapping I/O
MRC
Memory Reference Code
N
NIC
Network Interface Controller
NMI
Non-Maskable Interrupt
NUMA
Non Uniform Memory Access
O
OS
Operating System
P
PCH
Platform Controller Hub
PCI
Peripheral Component Interface
PCIe
Peripheral Component Interconnect Express
PCU
Power Controller Unit
PECI
Platform Environment Control Interface
PMem
Persistent memory
PK
Platform Key
POR
Plan Of Record
POST
Power On Self Test
PXE
R
RAID
Redundant Arrays of Independent Disks
RAPL
Running Average Power Limit
RAS
Reliability, Availability, Serviceability
RFO
Read For Ownership
ROM
Read-Only Memory
RTS/CTS
Request To Send/Clear To Send
S
SAS
Serial Attached SCSI
SATA
Serial Advanced Technology Attachment
SCSI
SEL
System Event Log
SMI
System Management Interrupt
SR-IOV
Single-Root I/O Virtualization
SMBIOS
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
TXT
Trusted Execution Technologies
U
UEFI
UID
Unit Identification
UPI
Ultra Path Interconnect
V
VT-d
Intel Virtualization Technology For Directed I/O
VMD
VGA
Video Graphics Array
X
XHCI
eXtensible Host Controller Interface
