12-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9X71)-6W70112-Layer 3—IP Routing Command Reference
13-Guard route commands
13-Guard route commands 47.32 KB
ip route-guard
Use ip route-guard to configure an IPv4 guard route.
Use undo ip route-guard to delete an IPv4 guard route.
ip route-guard ip-address { mask-length | mask }
undo ip route-guard ip-address { mask-length | mask }
No IPv4 guard route is configured.
context-admin
ip-address: Specifies the destination IP address in dotted decimal format.
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a mask in dotted decimal format.
A guard route directs traffic to the guard device for filtering and cleaning. You can manually configure a guard route on the guard device, or use a script to automatically configure a guard route upon receipt of a notification.
Guard routes have the following characteristics:
·     Guard routes use Null 0 as the outgoing interface.
·     Guard routes are inactive routes and will not be installed into the FIB.
·     You must configure a routing protocol, such as BGP or OSPF, to redistribute and advertise guard routes for directing traffic to the guard device.
# Configure a guard route destined to 11.11.11.11/32.
[Sysname] ip route-guard 11.11.11.11 255.255.255.255
display ip routing-table protocol
ipv6 route-guard
Use ipv6 route-guard to configure an IPv6 guard route.
Use undo ipv6 route-guard to delete an IPv6 guard route.
ipv6 route-guard ipv6-address prefix-length
undo ipv6 route-guard ipv6-address prefix-length
No IPv6 guard route is configured.
context-admin
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128.
·     You must configure a routing protocol, such as BGP or OSPFv3, to redistribute and advertise guard routes for directing traffic to the guard device.
# Configure a guard route destined to 1:1:2::/64.
[Sysname] ipv6 route-guard 1:1:2:: 64
display ipv6 routing-table protocol
