- 11-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-IP forwarding basics configuration
- 06-Fast forwarding configuration
- 07-Multi-CPU packet distribution configuration
- 08-Adjacency table configuration
- 09-IP performance optimization configuration
- 10-IPv6 basics configuration
- 11-DHCPv6 configuration
- 12-IPv6 fast forwarding configuration
00-Preface | 110.45 KB |
Preface
This configuration guide describes features and tasks that help you get started with the device, It includes the following feature modules: ARP, IP addressing, DHCP, DNS, IP forwarding basics, fast forwarding, multi-CPU packet distribution, adjacency table, IP performance optimization, basic IPv6 settings, DHCPv6 and IPv6 fast forwarding.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
