| 01-Installation Guide | 2.88 MB |
Installation restrictions and guidelines
Mounting the device on a workbench
Mounting the device on a vertical wall
Connecting the grounding cable
1 Introduction
About the product
H3C Aolynk UR series enterprise routers are designed for SMBs, government agencies, and corporate institutions that require high-speed wired and wireless access in medium and small networks. This series integrates functions such as routing, switching, AC, firewall, and PoE, significantly simplifying network deployment.
Table1-1 H3C Aolynk UR series routers
Product |
UR105G-P |
· Provides three fixed Gigabit LAN ports, one fixed Gigabit WAN port, and one variable Gigabit WAN/LAN port. · Four ports support 802.3af/at-compliant PoE power supply, with a maximum output power of 30 W per port and a PoE load power of 58 W. |
UR210G-P |
· Provides six fixed Gigabit LAN ports, one fixed Gigabit WAN port, and three variable Gigabit WAN/LAN ports. · Eight ports support 802.3af/at-compliant PoE power supply, with a maximum output power of 30 W per port and a PoE load output of 75 W. |
Product view
UR105G-P
Figure1-1 Front view
(1) Power receptacle |
(2) LAN ports and LEDs (10/100/1000BASE-T copper port) |
(3) LAN/WAN port and LED (10/100/1000BASE-T copper ports) |
(4) WAN port and LED (10/100/1000BASE-T copper port) |
(5) PoE-MAX LED (PoE-MAX) |
(6) Reset button (RESET) |
(7) System status LED (SYS) |
Figure1-2 Rear view
(1) Grounding screw |
UR210G-P
Figure1-3 Front view
(3) LAN/WAN ports and LEDs (10/100/1000BASE-T copper ports) |
(4) WAN/LAN port and LED (10/100/1000BASE-T copper port) |
(5) WAN port and LED (10/100/1000BASE-T copper port) |
(6) PoE-MAX LED (MAX) |
(7) Reset button (RESET) |
(8) System status LED (SYS) |
Figure1-4 Rear view
LEDs
LED |
Status |
Steady green |
The device is operating correctly. |
Steady yellow |
An alarm or error is present in the system. |
Slowly flashing yellow |
The device will restore the default Web login password. |
Fast flashing yellow |
The device will restore the factory defaults and then reboot. |
Off |
The power modules are shut down or faulty, or a hardware error is present. |
10/100/1000Base copper port LED |
Steady green |
A link is present on the port, and the port is operating at 10/100/1000 Mbps. |
Flashing green |
The port is sending or receiving data at 10/100/1000 Mbps. |
Off |
No link is present on the port. |
PoE-MAX LED |
Steady green |
The power supplied by the PoE router is within its protection power range, which is 60 W to 75 W on a UR210G-P router and 47 W to 58 W on a UR105G-P router. |
Off |
The power supplied by the PoE router has not reached the minimum value of the protection power range. |
Ports
Port |
· To reboot the device, press and hold the button less than 5 seconds. · For the device to restore the default Web login password, press and hold the button for 5 to 10 seconds until the system status LED (SYS) slowly flashes yellow. · For the device to restore the factory defaults and then reboot, press and hold the reset button for 10 to 15 seconds until the system status LED (SYS) fast flashes yellow. · If you press and hold the button over 15 seconds, the system status LED (SYS) returns to steady green and the device will not perform any recovery action. |
Power receptacle |
Connect to a power supply. |
LAN port |
Connect to an Ethernet port on a computer or downstream switch. |
WAN port |
Connect to a network interface provided by the broadband service provider for Internet access. |
LAN/WAN port WAN/LAN port |
Can be used as either a LAN port or a WAN port. |
Grounding screw |
Connect the grounding cable. |
Technical specifications
Project |
UR105G-P |
UR210G-P |
Dimensions (H × W × D) |
27 × 190 × 125 mm (1.06 × 7.48 × 4.92 in) |
Power consumption |
< 63.18 W |
< 80 W |
Power adapter rated input voltage |
100 VAC to 240 VAC @ 50 or 60 Hz |
Device power input |
54 V ± 5% / 1.17 A |
54 V ± 5% / 1.48 A |
Max output power per port |
30 W |
30 W |
PoE power output |
58 W |
75 W |
Weight |
0.45 kg (0.99 lb) |
0.5 kg (1.10 lb) |
LAN port |
4 × Gigabit copper ports (one port supports WAN switching) |
8 × Gigabit copper ports (two ports support WAN switching) |
WAN port |
1 × Gigabit copper port (LAN switching not supported) |
2 × Gigabit copper ports (LAN switching not supported) |
Operating temperature |
0ºC to 40ºC (32°F to 104°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Heat dissipation method |
Passive cooling |
Passive cooling |
2 Installing the device
Use the table below to determine the mounting methods. This section uses a UR105G-P router as an example.
Device model |
Workbench mounting |
Wall mounting |
UR105G-P |
Supported |
Supported |
UR210G-P |
Supported |
Not supported |
To ensure correct operation and long service life of the device, follow these restrictions and guidelines:
· Use the device indoors only and place it in a dry and well-ventilated location.
· To protect the signal ports on the device from damages caused by overvoltage and overcurrent from lightning strikes, route the interface cables for the device indoors. Do not route the interface cables outdoors.
· To prevent potential damage from a fall, do not place the device on an unstable support platform, such as an unstable table.
· Reserve a minimum clearance of 10 cm (3.94 in) around the device for heat dissipation.
· Ensure the cleanliness of the operating environment of the device. Excessive dust can lead to electrostatic absorption, which not only affects the lifespan of the device but can also cause communication failures.
· Set up the grounding facility for the device separately and away from that of power distribution equipment and lightning protection systems.
· Position the device far away from high-power radio transmitters, radar transmitters, and high-frequency, high-current equipment.
· Use only the power cord supplied with the device. Do not use any non-matching products. The power voltage must be in the input voltage range of the dedicated power cord.
CAUTION: Make sure the workbench is stable and reliably grounded. Do not place heavy objects on the device. |
Place the device horizontally on a workbench.
1. Drill two holes with a minimum depth of 22 mm (0.87 in) on a vertical wall.
Make sure the two holes are aligned horizontally with a spacing of 80 mm (3.15 in) for the UR105G-P.
2. Insert an expansion anchor into each hole and make sure the anchor is all flush with the wall surface.
3. Fasten the two screws into the expansion anchors, leaving at least 7 mm (0.28 in) between the screw caps and the wall surface.
4. Hang the device on the screws.
Connecting the cables
1. Connect one end of the grounding cable to the grounding hole of the device.
2. Wind the other end of the grounding cable to the grounding strip. Alternatively, attach a ring terminal to the grounding cable and then connect the grounding cable to the grounding strip, as shown in the following figure.
Connecting the power cords
CAUTION: · To prevent adapter damage because of insufficient power, use the power adapter that came with the device for power supply. · Before connecting the power cord, make sure the device is reliably grounded. |
Connecting a power adapter
1. Connect one end of the power cord into the power receptacle.
2. Connect the other end of the power cord to an external AC power source.
3 Logging in to the device
NOTE: As a best practice, use Chrome 64, Firefox 78, Edge 79, or a browser of a later version to access the Web management interface. |
1. Connect a PC to a LAN port of the device and configure the PC to automatically obtain an IP address.
2. Check the proxy settings of the PC. If the PC uses a proxy server to access the Internet, you must first disable the proxy service.
3. Run the Web browser. Enter the management address displayed on the device nameplate in the address bar of the browser, and then press Enter (the default management address is uweb.h3c.com).
4. Enter the UWEB network-wide management interface and perform the deployment.
