02-Appendix A | 244.27 KB |
Appendix A Hardware Information and Specifications
LEDs
Figure1-1 LEDs
Table1-1 LED descriptions
LED status |
Off |
No power is present or the LED has been turned off. |
Yellow |
Steady on |
The AP is initializing, or an initialization exception has occurred. |
Flashing (twice per second) |
The Ethernet interfaces are down and no mesh links are established. |
Green |
Steady on |
The AP is in standby state and has connected to the cloud platform, but does not have any associated clients. |
Flashing (once per second) |
The AP has connected to the cloud platform and has associated clients. |
The AP is upgrading the image. |
Blue |
Steady on |
The AP is in standby state, but has not connected to the cloud platform and does not have associated clients. |
The AP has not connected to the cloud platform, but has associated clients. |
Ports
The AP provides the following ports:
· One UpLink GE/PoE_IN port.
· One GE port.
The AP also has a reset button.
Figure1-2 Ports on the AP
(1) RESET button |
(1) 10/100/1000M Ethernet port |
(1) UpLink GE/PoE_IN port |
Table1-2 Port descriptions
Port |
Standards and protocols |
RESET |
N/A |
· To reboot the AP, press and hold the button for no more than 5 seconds. · To reset the password, press and hold the button for 5 to 10 seconds until the LED is flashing yellow at 1 Hz. · To restore the AP to the factory defaults, press and hold the button for more than 10 seconds until the LED is flashing yellow at 4 Hz. |
· IEEE802.3i · IEEE802.3u · IEEE802.3ab · IEEE802.3af |
10/100/1000M Ethernet copper port, used for connecting the AP to an uplink device for Internet or MAN access. It can also receive PoE power from the uplink device. |
· IEEE802.3i · IEEE802.3u · IEEE802.3ab |
10/100/1000M Ethernet copper port, used for connecting the AP to an downlink device for Internet or MAN access. |
Technical specifications
Table1-3 Technical specifications
Item |
Specification |
Protocol |
IEEE802.11a/b/g/n/ac/ax IEEE802.3af |
Dimensions (H × W × D) |
86 × 86 × 38 mm (3.39 × 3.39 × 1.50 in) |
Weight |
150 g (0.33 lb) |
Antenna |
Built-in antenna: |
≤11.65 W |
