H3C FS5500-EI & FS5500V2-EI & FS5300-EI iOptic Switch Series Installation Guide-6W100
HomeSupportSwitchesFS SeriesFS5500V2-EI SeriesTechnical DocumentsInstall & UpgradeInstallation GuidesH3C FS5500-EI & FS5500V2-EI & FS5300-EI iOptic Switch Series Installation Guide-6W100
01-Text
01-Text 987.26 KB
1 Product models and technical specifications
Product models
This document is applicable to the FS5500-EI switch series. Table1-1 describes the FS5500-EI switch series models.
Table1-1 FS5500-EI switch series models
Switch series
Model
Product code
FS5500-30UXS4Y2Q-EI
LS-FS5500-30UXS4Y2Q-EI
FS5500-48UXS4Y2Q-EI
LS-FS5500-48UXS4Y2Q-EI
FS5500-24UX2C-EI
LS-FS5500-24UX2C-EI
Technical specifications
Table1-2 Technical specifications
Item
FS5500-30UXS4Y2Q-EI
FS5500-48UXS4Y2Q-EI
FS5500-24UX2C-EI
Dimensions (H × W × D)
43.6 × 440 × 400 mm (1.72 × 17.32 × 15.75 in)
Weight
7.4 kg (16.31 lb)
7.5 kg (16.53 lb)
7.2 kg (15.87 lb)
Console port
1
1
1
USB port
1
1
1
Management Ethernet port
1
1
1
PSFP photoelectric hybrid port
24
42
N/A
PSFP+ photoelectric hybrid port
6
6
24
SFP28 port
4
4
N/A
QSFP+ port
2
2
N/A
Power supply slot
2, on the rear panel
Fan tray slot
Input voltage
AC input:
·     Rated voltage range: 100 VAC to 240 VAC @ 50 or 60 Hz
·     Max voltage range: 90 VAC to 290 VAC@ 47 to 63 Hz
Power consumption (static)
Single AC input: 47 W
Dual AC inputs: 56 W
Single AC input: 50 W
Dual AC inputs: 59 W
Single AC input: 44 W
Dual AC inputs: 52 W
Power consumption (typical)
Single AC input: 54 W
Dual AC inputs: 65 W
Single AC input: 65 W
Dual AC inputs: 80 W
Single AC input: 51 W
Dual AC inputs: 60 W
Power consumption (fully loaded)
Depends on the power supply configuration. For more information, see Table1-3.
PoE power capacity
Depends on the power supply configuration. For more information, see Table1-4.
Chassis leakage current compliance
UL62368-1/EN62368-1/IEC62368-1/UL60950-1/IEC60950-1/GB4943.1
Cooling system
From the side panels and port side to the power supply side
Melting current of power supply fuse
·     PSR600-54A-B: 10 A/250 V
·     PSR920-54A-B: 16 A/250 V
·     PSR1600-54A-B: 16 A/250 V
Operating temperature
–5ºC to +45ºC (23°F to 113°F)
Note:
The maximum acceptable temperature decreases by 0.33°C (32.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft).
Operating relative humidity
5% to 95%, noncondensing
Fire resistance compliance
Table1-3 Power consumption of the FS5500-EI switch series (fully loaded)
Power supply configuration
FS5500-30UXS4Y2Q-EI
FS5500-48UXS4Y2Q-EI
FS5500-24UX2C-EI
1 × PSR600-54A-B
613 W
632 W
614 W
1 × PSR920-54A-B
998 W
1020 W
1001 W
1 × PSR1600-54A-B (90 VAC to 176 VAC)
1026 W
1047 W
1024 W
1 × PSR1600-54A-B (176 VAC to 290 VAC or 180 VDC to 320 VDC)
1671 W
1680 W
1669 W
2 × PSR600-54A-B
1281 W
1299 W
1281 W
2 × PSR920-54A-B
1945 W
1965 W
1944 W
2 × PSR1600-54A-B (90 VAC to 176 VAC)
1974 W
1996 W
1974 W
2 × PSR1600-54A-B (176 VAC to 290 VAC or 180 VDC to 320 VDC)
3205 W
3210 W
2727 W
Table1-4 PoE power capacity of the FS5500-EI switch series
FS5500-30UXS4Y2Q-EI
FS5500-48UXS4Y2Q-EI
FS5500-24UX2C-EI
Total PoE power capacity
Max PoE power capacity per port
1 × PSR600-54A-B
450 W
100 W
450 W
100 W
450 W
100 W
1 × PSR920-54A-B
770 W
100 W
770 W
100 W
770 W
100 W
770 W
100 W
770 W
100 W
770 W
100 W
1450 W
100 W
1450 W
100 W
1450 W
100 W
2 × PSR600-54A-B
1020 W
100 W
1020 W
100 W
1020 W
100 W
1 × PSR600-54A-B and 1 × PSR920-54A-B
1020 W
100 W
1020 W
100 W
1020 W
100 W
2 × PSR920-54A-B
1600 W
100 W
1600 W
100 W
1600 W
100 W
1 × PSR920-54A-B and 1 × PSR1600-54A-B (90 VAC to 176 VAC)
1260 W
100 W
1260 W
100 W
1260 W
100 W
1 × PSR920-54A-B and 1 × PSR1600-54A-B (176 VAC to 290 VAC or 180 VDC to 320 VDC)
1600 W
100 W
1600 W
100 W
1600 W
100 W
1600 W
100 W
1600 W
100 W
1600 W
100 W
1 × PSR1600-54A-B (90 VAC to 176 VAC) and 1 × PSR1600-54A-B (176 VAC to 290 VAC or 180 VDC to 320 VDC)
1600 W
100 W
1600 W
100 W
1600 W
100 W
2850 W
100 W
2850 W
100 W
2850 W
100 W
IMPORTANT
IMPORTANT:
Do not install a PSR600-54A-B and a PSR1600-54A-B on the same switch.
2 Chassis views
FS5500-30UXS4Y2Q-EI
Figure2-1 Front panel
(1) PSFP port LED
(2) PSFP port
(3) PSFP+ port
(4) PSFP+ port LED
(5) SFP28 port LED
(6) SFP28 port
(7) QSFP+ port
(8) QSFP+ port LED
(9) Removable power supply 1 status LED (PWR1)
(10) Removable power supply 2 status LED (PWR2)
(11) Mode LED (MODE)
(12) System status LED (SYS)
(13) USB port
(14) Console port (CONSOLE)
(15) Mode button
Figure2-2 Rear panel
(1) Grounding screw
(2) Management Ethernet port
(3) Removable fan tray 1
(4) Removable fan tray 2
(5) Removable power supply 1
(6) Removable power supply 2
The FS5500-30UXS4Y2Q-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-2, two PSR600-54A-B power supplies are installed in the power supply slots.
The FS5500-30UXS4Y2Q-EI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-2, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
FS5500-48UXS4Y2Q-EI
Figure2-3 Front panel
(1) PSFP port LED
(2) PSFP port
(3) PSFP+ port
(4) PSFP+ port LED
(5) SFP28 port LED
(6) SFP28 port
(7) QSFP+ port
(8) QSFP+ port LED
(13) USB port
(15) Mode button
Figure2-4 Rear panel
(1) Grounding screw
The FS5500-48UXS4Y2Q-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-4, two PSR600-54A-B power supplies are installed in the power supply slots.
The FS5500-48UXS4Y2Q-EI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-4, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
FS5500-24UX2C-EI
Figure2-5 Front panel
(1) PSFP+ port LED
(2) PSFP+ port
(3) QSFP28 port LED
(4) QSFP28 port
(5) Removable power supply 1 status LED (PWR1)
(6) Removable power supply 2 status LED (PWR2)
(7) Mode LED (MODE)
(8) System status LED (SYS)
(9) USB port
(10) Console port (CONSOLE))
(11) Mode button
By default, the QSFP28 ports on the FS5500-24UX2C-EI switch operate at 40 Gbps. To configure the ports to operate at 100 Gbps, install a license and then execute the active port basic-license command to active the license. For more information about the command, see Interface Command Reference in the command references that come with the switch.
Figure2-6 Rear panel
(1) Grounding screw
The FS5500-24UX2C-EI switch came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-6, two PSR600-54A-B power supplies are installed in the power supply slots.
The FS5500-24UX2C-EI switch came with the two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-6, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
3 Removable components
The switch supports removable components. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between the switch and removable components
Removable component model
FS5500-30UXS4Y2Q-EI
FS5500-48UXS4Y2Q-EI
FS5500-24UX2C-EI
Removable power supplies
PSR600-54A-B
Yes
PSR920-54A-B
Yes
PSR1600-54A-B
Yes
Removable fan trays
LSPM1FANSB-SN
Yes
CAUTION
CAUTION:
You can power on the switch only when the switch has two fan trays of the same model installed.
IMPORTANT
IMPORTANT:
·     The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supplies you have installed on the device.
·     You can install one power supply, or two power supplies for 1+1 redundancy on the switch. PoE capabilities vary by power supply configuration. When a power supply fails, PoE capabilities of the switch might degrade. For more information about PoE power capacity, see Table1-4.
The switch uses removable power supplies and supports the PSR600-54A-B, PSR920-54A-B, and PSR1600-54A-B power supplies.
Table3-2 Removable power supplies available for the switch
Power supply model
Item
Specifications
Reference
PSR600-54A-B
Rated input voltage range
100 VAC to 240 VAC @ 50 Hz or 60 Hz
H3C PSR600-54A-B Power Module User Manual
Max input voltage range
90 VAC to 290 VAC @ 47 Hz to 63 Hz
Max output power
600 W
PSR920-54A-B
H3C PSR920-54A-B Power Module User Manual
Max output power
920 W
PSR1600-54A-B
H3C PSR1600-54A-B Power Module User Manual
Max output power
1600 W
Removable fan trays
CAUTION
CAUTION:
The switch uses removable fan trays and supports the LSPM1FANSB-SN fan tray.
Table3-3 Removable fan trays
Item
Specifications
Dimensions
40 × 40.6 × 105 mm (1.57 × 1.60 × 4.13 in)
Fan speed
20000 R.P.M
Max airflow
20 CFM (0.57 m3/min)
Airflow direction
Draws air from the port side to the power supply side
Input voltage
12 V
Power consumption
9.8 W
Reference
H3C LSPM1FANSA-SN & LSPM1FANSB-SN Fan Trays User Guide
4 Ports and LEDs
Ports
Console port
Table4-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local PC running terminal emulation program.
Available switch models
All switch models
Table4-2 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Transmission rate, duplex mode, and auto MDI/MDI-X
·     10 Mbit/s, half/full-duplex
·     100 Mbit/s, half/full-duplex
·     1000 Mbit/s, full-duplex
·     MDI/MDI-X, autosensing
Transmission medium
Category-5 (or above) twisted pair cable
Max transmission distance
100 m (328.08 ft)
Compatible standards
·     IEEE 802.3i
·     IEEE 802.3u
·     IEEE 802.3ab
Functions and services
Connects to a computer or remote network management work station for upgrading and managing applications and Boot ROM
All switch models
USB port
Table4-3 USB port specifications
Item
Specifications
Interface type
USB 2.0
Compliant standard
OHC
Port transmission rate
Uploads and downloads data at a rate up to 480 Mbps
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files
All switch models
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
PSFP port
PSFP ports can provide 1 Gbps data links and supply power for wireless APs or powered switches through hybrid copper-fiber cables.
Table4-4 PSFP port specifications
Item
Specifications
Available transceiver modules and cables
·     FE SFP transceiver modules in Table4-5
·     GE SFP transceiver modules and cables in Table4-7
FS5500-30UXS4Y2Q-EI, FS5500-48UXS4Y2Q-EI
·     A PSFP port can provide 1 Gbps data links and supply PoE power at the same time only when it is installed with an SFP-GE-POE transceiver module
·     You can install a maximum of 20 SFP-GE-T transceiver modules on an FS5500-48UXS4Y2Q-EI switch
Table4-5 FE SFP transceiver modules available for the PSFP ports
Central wavelength (nm)
Connector
Fiber type and diameter (µm)
SFP-FE-SX-MM1310-A
1310
LC
Multi-mode, 50/125
2 km (1.24 miles)
Multi-mode, 62.5/125
SFP-FE-LX-SM1310-A
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
Single-mode, 9/125
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
Single-mode, 9/125
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-BX15-U-SM1310
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module.
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
PSFP+ port
PSFP+ ports can provide 1 Gbps or 10 Gbps data links and supply power for wireless APs or powered switches through hybrid copper-fiber cables.
Table4-6 PSPF+ port specifications
Item
Specifications
·     10-GE SFP+ transceiver modules and cables in Table4-8 and Table4-9
All switch models
·     A PSFP+ port can provide 10 Gbps data links and receive or supply PoE power at the same time only when it is installed with an SFP-XG-POE-MR transceiver module
·     A PSFP+ port can provide 1 Gbps data links and receive or supply PoE power at the same time only when it is installed with an SFP-GE-POE transceiver module
Table4-7 GE SFP transceiver modules and cables
GE SFP transceiver module/cable
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz*km)
Max. transmission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-POE
1310
LC
SMF
N/A
10 km (6.21 miles)
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
200 m (656.17 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500/400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
Table4-8 10-GE SFP+ transceiver modules
Connector
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-POE-MR
1310
LC
SMF
N/A
1.4 km (0.87 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-BIDI
TX: 1550
RX: 1490
Single-mode, 9/125
N/A
80 km (49.71 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, the SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table4-9 SFP+ copper and fiber cables available for the PSFP+ ports
Item
Cable length
SFP+ copper cable
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure4-1 SFP+ cable
(1) Connector
(2) Pull latch
SFP28 port
Table4-10 SFP28 port specifications
Item
Specifications
Compatible transceiver modules and cables
·     25-GE SFP28 transceiver modules and cables in Table4-11 and Table4-12
Compatible devices
Table4-11 25-GE SFP28 transceiver modules available for the SFP28 ports
Connector
Maximum transmission distance
SFP-25G-SR-MM850
850
LC
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Table4-12 25G SFP28 copper and fiber cables available for the SFP28 ports
Item
Cable length
25G SFP28 copper cable
SFP-25G-D-CAB-1M
1 m (3.28 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
25G SFP28 fiber cable
SFP-25G-D-AOC-3M
3 m (9.84 ft)
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
Figure4-2 SFP28 cable
(1) Connector
(2) Pull latch
QSFP+ port
Table4-13 QSFP+ port specifications
Item
Specifications
QSFP+ transceiver modules and cables in Table4-14 and Table4-15
Table4-14 QSFP+ transceiver modules available for the QSFP+ ports
Connector
Modal bandwidth (MHz × km)
QSFP-40G-SR4-MM850
850
MPO
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-CSR4-MM850
850
MPO
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.34 ft)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 50/125
N/A
2 km (1.24 miles)
QSFP-40G-BIDI-SR-MM850
850
LC
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-BIDI-WDM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
240 m (787.40 ft)
4700
350 m (1148.29 ft)
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 50/125
N/A
40 km (24.86 miles)
Table4-15 40G QSFP+ copper and fiber cables available for the QSFP+ ports
Item
Cable length
QSFP+ copper cable
LSWM1QSTK0
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
QSFP+ fiber cable
QSFP-40G-D-AOC-3M
3 m (9.84 ft)
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
Figure4-3 40G QSFP+ cable
(1) Connector
(2) Pull latch
Figure4-4 40G QSFP+ to 4x10G SFP+ cable
(1) QSFP+ connector
(2) QSFP+ side pull latch
(3) SFP+ side pull latch
(4) SFP+ connector
QSFP28 port
Table4-16 QSFP28 port specifications
Item
Specifications
·     QSFP+ transceiver modules and cables in Table4-14 and Table4-15
·     QSFP28 transceiver modules and cables in Table4-17 and Table4-18
FS5500-24UX2C-EI
Table4-17 QSFP28 transceiver modules available for the QSFP28 ports
Connector
QSFP-100G-SR4-MM850
850
MPO
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-LR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
SMF
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-100G-BIDI-MM850
Two lanes:
·     855
·     908
MMF
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
Table4-18 100G QSFP28 fiber and copper cables available for the QSFP28 ports
Item
Cable length
QSFP28 fiber cable
QSFP-100G-D-AOC-7M
7 m (22.97 ft)
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
QSFP28 copper cable
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table4-19 System status LED description
LED mark
Status
SYS
Steady green
The switch has started correctly.
Flashing green (1 Hz)
The switch is performing power-on self test (POST).
Steady red
The switch has failed POST or is faulty.
Off
The switch is powered off.
Power supply status LED
The switch provides PWR1 and PWR2 LEDs on the front panel to indicate the operating status of the power supplies.
Table4-20 Power supply status LED description
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or no power is being supplied to the power supply.
Off
No power supply is installed in the power supply slot.
Mode LED (MODE)
The mode LED works in conjunction with the port LEDs to indicate the operating state of the ports and the switch.
The mode LED indicates the type of information that the port LEDs are showing.
You can use the mode button to change the indication of the mode LED. After you press the mode button for the mode LED to steady yellow, flashing green, or flashing yellow, the mode LED keeps that state for only 45 seconds and then turns steady green automatically.
Table4-21 Description for the mode LED
LED mark
Status
Mode LED (MODE)
Steady green
The port LEDs are showing link state of the ports.
Flashing green
The port LEDs are showing the PoE status of the ports.
Flashing yellow
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4.
PSFP port LED
Table4-22 PSFP port LED description
Status
Mode LED
PSFP port LED
Steady green (rate mode)
Steady green
A link is present on the port and the port is operating at 1000 Mbps.
Flashing green
The port is sending or receiving data at 1000 Mbps.
Steady yellow
A link is present on the port and the port is operating at 100 Mbps.
Flashing yellow
The port is sending or receiving data at 100 Mbps.
Off
No link is present on the port.
Flashing green (PoE mode)
Steady green
PoE power supply is normal.
Flashing green
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Steady yellow
The port has failed to supply power.
Off
The port is not supplying power through PoE.
Flashing yellow (IRF mode)
Steady green
The PSFP port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green and the other port LEDs are off, the IRF member ID of the switch is 4.
PSFP+ port LED
Table4-23 PSFP+ port LED description
Status
Mode LED
PSFP+ port LED
Steady green
A link is present on the port and the port is operating at 10 Gbps.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
A link is present on the port and the port is operating at 1 Gbps.
Flashing yellow
The port is sending or receiving data at 1 Gbps.
Off
Steady green
Flashing green
Steady yellow
Off
Off
The mode LED is operating in IRF mode.
SFP28 port LED
Table4-24 SFP28 port LED description
SFP28 port LED status
Steady green
A link is present on the port and the port is operating at 25 Gbps.
Flashing green
The port is sending or receiving data at 25 Gbps.
Steady yellow
Flashing yellow (3 Hz)
Off
No transceiver module is installed in the port or no link is present on the port.
QSFP+ port LED
Table4-25 QSFP+ port LED description
QSFP+ port LED status
Steady green
A link is present on the port and the port is operating at 40 Gbps.
Flashing green
The port is sending or receiving data at 40 Gbps.
Off
·     No transceiver module is installed in the port or no link is present on the port.
·     The mode LED is operating in IRF mode.
QSFP28 port LED
Table4-26 QSFP28 port LED description
QSFP28 port LED status
Steady green
A link is present on the port and the port is operating at 100 Gbps.
Flashing green
The port is sending or receiving data at 100 Gbps.
Steady yellow
Flashing yellow
Off
5 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
The switch uses removable fan trays. For adequate heat dissipation, you must install two fan trays of the same model for the switch.
Table5-1 Fan trays available for the switch
Device model
Fan tray type
Airflow direction
FS5500-30UXS4Y2Q-EI
FS5500-48UXS4Y2Q-EI
FS5500-24UX2C-EI
LSPM1FANSB-SN
Figure5-1 Airflow direction (FS5500-48UXS4Y2Q-EI)
