| 03-Data buffer commands | 53.64 KB |
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
· Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
· Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
· Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer usage
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer usage for all IRF member devices.
# Display buffer usage.
<Sysname> display buffer usage
Egress total-shared cell buffer usage on uiSlot 1 :
Total: 2053 KB
Used: 0 KB
Free: 2053 KB
5sec 1min 5min
Block 1 0% 0% 0%
GigabitEthernet1/0/1 0% 0% 0%
GigabitEthernet1/0/2 0% 0% 0%
GigabitEthernet1/0/3 0% 0% 0%
GigabitEthernet1/0/4 0% 0% 0%
GigabitEthernet1/0/5 0% 0% 0%
GigabitEthernet1/0/6 0% 0% 0%
GigabitEthernet1/0/7 0% 0% 0%
GigabitEthernet1/0/8 0% 0% 0%
GigabitEthernet1/0/9 0% 0% 0%
GigabitEthernet1/0/10 0% 0% 0%
GigabitEthernet1/0/11 0% 0% 0%
GigabitEthernet1/0/12 0% 0% 0%
GigabitEthernet1/0/13 0% 0% 0%
GigabitEthernet1/0/14 0% 0% 0%
GigabitEthernet1/0/15 0% 0% 0%
GigabitEthernet1/0/16 0% 0% 0%
GigabitEthernet1/0/17 0% 0% 0%
GigabitEthernet1/0/18 0% 0% 0%
GigabitEthernet1/0/19 0% 0% 0%
GigabitEthernet1/0/20 0% 0% 0%
GigabitEthernet1/0/21 0% 0% 0%
GigabitEthernet1/0/22 0% 0% 0%
GigabitEthernet1/0/23 0% 0% 0%
GigabitEthernet1/0/24 0% 0% 0%
Ten-GigabitEthernet1/0/25 0% 0% 0%
Ten-GigabitEthernet1/0/26 0% 0% 0%
Ten-GigabitEthernet1/0/27 0% 0% 0%
Ten-GigabitEthernet1/0/28 0% 0% 0%
Block |
Block where the port resides. The block where the ports on the front panel of the device reside is fixed to Block 1. |
Total |
Total size of the data buffer. |
Used |
Size of used data buffer. |
Free |
Size of free data buffer. |
5sec |
Percentage of the buffer that the port uses for the last 5 seconds. |
1min |
Percentage of the buffer that the port uses for the last 1 minute. |
5min |
Percentage of the buffer that the port uses for the last 5 minutes. |
