01-Fundamentals Command Reference
HomeSupportSwitchesS5570S-EI SeriesReference GuidesCommand ReferencesH3C S5570S-EI & S5500V3-SI Command References-R11xx-6W10301-Fundamentals Command Reference
00-Preface
00-Preface 110.83 KB
Preface
This command reference describes commands that help you get started with the switch, including:
·     CLI.
·     RBAC, switch login, and switch access control.
·     Management of the switch, file systems, and configuration files.
·     FTP and TFTP.
·     Tcl and Python.
·     Common software upgrade.
·     Automatic configuration.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the S5570S-EI and S5500V3-SI switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
