- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-IPsec commands
- 12-SSH commands
- 13-SSL commands
- 14-TCP attack prevention commands
- 15-IP source guard commands
- 16-ARP attack protection commands
- 17-ND attack defense commands
- 18-SAVI commands
- 19-MFF commands
- 20-Crypto engine commands
- 21-FIPS commands
- 22-802.1X client commands
| 07-User profile commands | 54.57 KB |
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
display user-profile [ name profile-name ] [ slot slot-number ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter and must be unique. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user profile configuration and online user information for all member devices.
# Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
User-Profile: aaa
Inbound:
CIR 64 (kbps), CBS 512 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
Policy: p1
Outbound:
IGMP access policy:
2000, 3000
MLD access policy:
2000, 3000
IGMP Snooping access policy:
2000, 3000
MLD Snooping access policy:
2000, 3000
User user_1:
Authentication type: 802.1X
Network attributes:
Interface : GigabitEthernet1/0/1
MAC address : 0000-1111-2222
Failed action list:
Inbound: Policy p1
Inbound: CIR 64 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
User-Profile |
User profile name. |
Inbound |
Policy applied to incoming traffic. |
Outbound |
Policy applied to outgoing traffic. |
Policy |
Policy name. |
User user_1 |
Username of a user account with which a user profile is associated. |
Authentication type |
Authentication type: · 802.1X—802.1X authentication. · Portal—Portal authentication. · PPP—PPP authentication. · IPoE—IPoE authentication. · MACA—MAC authentication. |
Network attributes |
Online user information. |
Failed action list |
Actions that failed to be applied to the user. |
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name
undo user-profile profile-name
No user profiles exist.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. A user profile name can only contain English letters, digits, and underscores (_), and it must start with an English letter. The name must be unique.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
