08-ACL and QoS Configuration Guide
HomeSupportSwitchesS5170-EI SeriesConfigure & DeployConfiguration GuidesH3C S5170-EI Configuration Guides-R11xx-6W10408-ACL and QoS Configuration Guide
03-Data buffer configuration
03-Data buffer configuration 51.49 KB
Configuring data buffers
Enabling the Burst feature
The Burst feature enables the device to automatically allocate cell and packet resources. It is well suited to the following scenarios:
·     Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·     Traffic comes in and goes out in one of the following ways:
¡     Enters a device from a high-speed interface and goes out of a low-speed interface.
¡     Enters from multiple same-rate interfaces at the same time and goes out of an interface with the same rate.
2.     Enable the Burst feature.
burst-mode enable
By default, the Burst feature is disabled.
Display and maintenance commands for data buffers
Display data buffer usage.
display buffer usage [ slot slot-number ]
