05-Layer 3—IP Routing Configuration Guide
HomeSupportSwitchesS5170-EI SeriesConfigure & DeployConfiguration GuidesH3C S5170-EI Configuration Guides-R11xx-6W10405-Layer 3—IP Routing Configuration Guide
10-Routing policy configuration
10-Routing policy configuration 158.21 KB
Configuring routing policies
About routing policies
Routing policies control routing paths by filtering and modifying routing information.
Routing policies can filter advertised, received, and redistributed routes, and modify attributes for specific routes.
Implementation of a routing policy
To configure a routing policy:
1.     Configure filters based on route attributes.
2.     Create a routing policy and apply filters to the routing policy.
Filters
Routing policies can use the following filters to match routes.
ACL
An ACL can match the destination or next hop of routes.
For more information about ACLs, see ACL and QoS Configuration Guide.
IP prefix list
An IP prefix list matches the destination address of routes.
An IP prefix list can contain multiple items that specify prefix ranges. Each destination IP address prefix of a route is compared with these items in ascending order of their index numbers. A prefix matches the IP prefix list if it matches one item in the list.
RD list
A route distinguisher (RD) list matches the RD of routes.
An RD list is identified by an RD list number and can contain multiple items that specify RD ranges. Each item is identified by an index number. The RD of a route is compared with these items in ascending order of their index numbers. An RD matches the RD list if it matches one item in the list.
Routing policy
A routing policy can contain multiple nodes, which are in a logical OR relationship. A node with a smaller number is matched first. A route matches the routing policy if it matches one node (except the node configured with the continue clause) in the routing policy.
Each node has a match mode of permit or deny.
·     permit—Specifies the permit match mode for a routing policy node. If a route meets all the if-match clauses of the node, it is handled by the apply clauses of the node. The route is not compared with the next node unless the continue clause is configured. If a route does not meet all the if-match clauses of the node, it is compared with the next node.
·     deny—Specifies the deny match mode for a routing policy node. The apply and continue clauses of a deny node are never executed. If a route meets all the if-match clauses of the node, it is denied without being compared with the next node. If a route does not meet all the if-match clauses of the node, it is compared with the next node.
A node can contain a set of if-match, apply, and continue clauses.
·     if-match clauses—Specify the match criteria that match the attributes of routes. The if-match clauses of different types are in a logical AND relationship and the if-match clauses of the same type are in a logical OR relationship. A route must meet if-match clauses of all types to match the node.
·     apply clauses—Specify the actions to be taken on permitted routes, such as modifying a route attribute.
·     continue clause—Specifies the next node. A route that matches the current node (permit node) must match the specified next node in the same routing policy. The continue clause combines the if-match and apply clauses of the two nodes to improve flexibility of the routing policy. After you configure a continue clause, a route can pass the routing policy even if it does not match the specified next node. To reject such a route, add a deny node without clauses.
Follow these guidelines when you configure if-match, apply, and continue clauses:
·     If you only want to filter routes, do not configure apply clauses.
·     If you do not configure any if-match clauses for a permit node, the node will permit all routes.
·     Configure a permit node containing no if-match or apply clauses following multiple deny nodes to allow unmatched routes to pass.
Routing policy tasks at a glance
To configure a routing policy, perform the following tasks:
1.     (Optional.) Configure filters:
¡     Configuring an IPv4 prefix list
¡     Configuring an IPv6 prefix list
¡     Configuring an RD list
2.     Configuring a routing policy:
a.     Creating a routing policy
b.     Configuring if-match clauses
c.     Configuring apply clauses
d.     Configuring the continue clause
If all the items are set to deny mode, no routes can pass the IPv4 prefix list. To permit unmatched IPv4 routes, you must configure the permit 0.0.0.0 0 less-equal 32 item following multiple deny items.
2.     Configure an IPv4 prefix list.
If all items are set to deny mode, no routes can pass the IPv6 prefix list. To permit unmatched IPv6 routes, you must configure the permit :: 0 less-equal 128 item following multiple deny items.
2.     Configure an IPv6 prefix list.
ipv6 prefix-list prefix-list-name [ index index-number ] { deny | permit } ipv6-address { inverse inverse-prefix-length | prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ] }
You can configure multiple items for an RD list that is identified by a number. The relationship between the items is logical OR. A route matches the RD list if it matches one item in the list.
2.     Configure an RD list.
A routing policy must have a minimum of one permit node. If all the nodes are in deny mode, no routes can pass the routing policy.
2.     Create a routing policy and a node, and enter routing policy node view.
You can either specify no if-match clauses or multiple if-match clauses for a routing policy node. If no if-match clause is specified for a permit node, all routes can pass the node. If no if-match clause is specified for a deny node, no routes can pass the node.
When you configure if-match clauses, follow these restrictions and guidelines:
·     The if-match clauses of a routing policy node have a logical AND relationship. A route must meet all if-match clauses before it can be executed by the apply clauses of the node. If an if-match command exceeds the maximum length, multiple if-match clauses of the same type are generated. These clauses have a logical OR relationship. A route only needs to meet one of them.
·     All IPv4 routes match a node if the if-match clauses of the node use only IPv6 ACLs. All IPv6 routes match a node if the if-match clauses of the node use only IPv4 ACLs.
·     If the ACL used by an if-match clause does not exist or the ACL is not configured with any rules, the clause is always matched. When the ACL of an if-match clause is configured with rules, a route cannot match the if-match clause in one of the following scenarios:
¡     The route cannot match any rule of the specified ACL.
¡     The route matches a deny-mode rule of the specified ACL.
·     If the prefix list used by an if-match clause does not exist, the clause is always matched. If no rules of the specified prefix list are matched, the clause is not matched.
·     The rule [ rule-id ] permit ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command can create a rule for an advanced ACL to match specific routes. The source sour-addr sour-wildcard option represents the destination network address and the destination dest-addr dest-wildcard option represents the mask in dotted decimal notation. For example, to match route 3.3.3.0/24, the rule configuration should be rule [ rule-id ] permit ip source 3.3.3.0 0.0.0.255 destination 255.255.255.0 0.0.0.255.
2.     Enter routing policy node view.
3.     Match routes whose destination, next hop, or source address matches an ACL or prefix list.
IPv4:
IPv6:
if-match ipv6 { address | next-hop | route-source } { acl ipv6-acl-number | prefix-list prefix-list-name }
By default, no ACL or prefix list match criterion is configured.
The ACL specified in an if-match clause must be a non-VPN ACL.
4.     Configure route match criteria.
¡     Match routes having the specified cost.
if-match cost cost-value
¡     Match routes having the specified output interface.
¡     Match routes having the specified route type.
if-match route-type { external-type1 | external-type1or2 | external-type2 | internal | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 } *
¡     Match IGP routes having the specified tag value.
if-match tag tag-value
By default, no route match criteria are configured.
5.     Match routes whose RD matches the specified RD list.
By default, no RD match criterion is configured.
6.     Match IPv6 route prefixes of the specified length whose last bit is an odd or even number.
¡     Match IPv6 route prefixes of the specified length whose last bit is an odd number.
if-match ipv6 odd-prefix-length prefix-length-number
By default, no match criterion is configured to match the length and last bit of IPv6 route prefixes.
¡     Match IPv6 route prefixes of the specified length whose last bit is an even number.
if-match ipv6 even-prefix-length prefix-length-number
3.     Configure the route cost and cost type.
¡     Set a cost for routes.
By default, no cost is set for routes.
¡     Set a cost type for routes.
apply cost-type  { type-1 | type-2 }
By default, no cost type is set for routes.
4.     Set the next hop for routes.
IPv4:
IPv6:
By default, no next hop is set for routes.
The configuration does not apply to redistributed routes.
5.     Configure route priorities.
¡     Set an IP precedence for matching routes.
By default, no IP precedence is set.
¡     Set a preference.
apply preference preference
By default, no preference is set.
¡     Set a prefix priority.
By default, the prefix priority is low.
6.     Set a local QoS ID for matching routes.
apply qos-local-id { local-id-value | clear }
By default, no local QoS ID is set.
7.     Set a tag value for IGP routes.
apply tag tag-value
By default, no tag value is set for IGP routes.
8.     Set a backup link for fast reroute (FRR).
IPv4:
IPv6:
By default, no backup link is set for FRR.
When you configure the continue clause to combine multiple nodes, follow these restrictions and guidelines:
·     If you configure an apply clause that sets different attribute values on all the nodes, the apply clause of the node configured most recently takes effect.
If you configure the apply cost clause with the + or keyword on all the nodes, the apply clause of each node takes effect.
3.     Specify the next node to be matched.
continue [ node-number ]
By default, no continue clause is configured.
The specified next node must have a larger number than the current node.
Configuring the routing policy change delay timer
This feature makes a routing policy take effect after a delayed time interval, which prevents incomplete routing policy configuration from being issued to cause incorrect route advertisement. The system automatically starts the timer when a routing policy changes. The changes will not take effect on the policy until the change delay timer expires.
A routing policy changes when one of the following events occurs:
·     A routing policy is created.
·     A routing policy node, if-match clause, or apply clause is added, modified, or deleted for a routing policy.
·     You add, modify, or delete one of the following lists:
¡     IPv4 prefix list.
¡     IPv6 prefix list.
·     The ACL used by an if-match clause changes.
2.     Set the routing policy change delay timer.
route-policy-change delay-time { time-value | unlimited }
By default, routing policy changes immediately take effect, but the routing protocol waits five seconds before processing routes from the new routing policy.
When the delay timer expires, the routing protocol waits five seconds before processing routes from the new routing policy.
Display and maintenance commands for routing policies
Display IPv4 prefix list statistics.
Display RD list information.
Display IPv6 prefix list statistics.
Display routing policy information.
Clear IPv4 prefix list statistics.
Clear IPv6 prefix list statistics.
Routing policy configuration examples
Example: Configuring a routing policy for redistributing static routes to RIP
As shown in Figure 1, Switch A exchanges routing information with Switch B by using RIP.
On Switch A, configure three static routes. Use a routing policy to configure Switch B to redistribute networks 20.1.1.1/32 and 40.1.1.1/32 and block network 30.1.1.1/32.
Figure 1 Network diagram
1.     Configure Switch A:
# Configure IP addresses for interfaces VLAN-interface 100 and VLAN-interface 200.
[SwitchA-vlan-interface100] ip address 10.1.1.1 30
[SwitchA-vlan-interface100] quit
[SwitchA-vlan-interface200] ip address 11.1.1.1 30
[SwitchA-vlan-interface200] quit
# Enable RIP on interface VLAN-interface 100.
[SwitchA-vlan-interface100] rip 1 enable
# Configure three static routes and set the next hop of the three routes to 11.1.1.2.
[SwitchA] ip route-static 20.1.1.1 32 11.1.1.2
[SwitchA] ip route-static 30.1.1.1 32 11.1.1.2
[SwitchA] ip route-static 40.1.1.1 32 11.1.1.2
# Configure a routing policy.
[SwitchA] ip prefix-list a index 10 permit 30.1.1.1 32
[SwitchA] route-policy static2rip deny node 0
[SwitchA-route-policy-static2rip-0] if-match ip address prefix-list a
[SwitchA-route-policy-static2rip-0] quit
[SwitchA] route-policy static2rip permit node 10
[SwitchA-route-policy-static2rip-10] quit
# Enable RIP and apply routing policy static2rip to filter redistributed static routes.
[SwitchA] rip
[SwitchA-rip-1] import-route static route-policy static2rip
2.     Configure Switch B:
# Configure an IP address for interface VLAN-interface 100.
[SwitchB-vlan-interface100] ip address 10.1.1.2 30
# Enable RIP.
[SwitchB] rip
[SwitchB-rip-1] quit
# Enable RIP on the interface.
[SwitchB-vlan-interface100] rip 1 enable
[SwitchB-vlan-interface100] quit
# Display the routing table information on Switch B.
<SwitchB> display ip routing-table
Destinations : 14       Routes : 14
10.1.1.0/30        Direct  0   0           10.1.1.2        Vlan100
10.1.1.0/32        Direct  0   0           10.1.1.2        Vlan100
10.1.1.2/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.3/32        Direct  0   0           10.1.1.2        Vlan100
20.0.0.0/8         RIP     100 1           10.1.1.1        Vlan100
40.0.0.0/8         RIP     100 1           10.1.1.1        Vlan100
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop
Example: Configuring a routing policy for IPv6 route redistribution
As shown in Figure 2:
·     Run RIPng on Switch A and Switch B.
·     Configure three static routes on Switch A.
·     On Switch A, apply a routing policy to redistribute static routes 20::/32 and 40::/32 and deny route 30::/32.
Figure 2 Network diagram
# Configure IPv6 addresses for VLAN-interface 100 and VLAN-interface 200.
[SwitchA-Vlan-interface100] ipv6 address 10::1 32
[SwitchA-Vlan-interface200] ipv6 address 11::1 32
# Enable RIPng on VLAN-interface 100.
[SwitchA-Vlan-interface100] ripng 1 enable
# Configure three static routes with next hop 11::2, and make sure the static routes are active.
[SwitchA] ipv6 route-static 20:: 32 11::2
[SwitchA] ipv6 route-static 30:: 32 11::2
[SwitchA] ipv6 route-static 40:: 32 11::2
[SwitchA] ipv6 prefix-list a index 10 permit 30:: 32
[SwitchA] route-policy static2ripng deny node 0
[SwitchA-route-policy-static2ripng-0] if-match ipv6 address prefix-list a
[SwitchA-route-policy-static2ripng-0] quit
[SwitchA] route-policy static2ripng permit node 10
[SwitchA-route-policy-static2ripng-10] quit
# Enable RIPng and apply the routing policy to static route redistribution.
[SwitchA] ripng
[SwitchA-ripng-1] import-route static route-policy static2ripng
# Configure the IPv6 address for VLAN-interface 100.
[SwitchB-Vlan-interface100] ipv6 address 10::2 32
# Enable RIPng.
[SwitchB] ripng
[SwitchB-ripng-1] quit
[SwitchB-Vlan-interface100] ripng 1 enable
# Display the RIPng routing table on Switch B.
[SwitchB] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect, D - Direct
                O - Optimal, F - Flush to RIB
 Peer FE80::7D58:0:CA03:1 on Vlan-interface 100
 Destination 20::/32,
     via FE80::7D58:0:CA03:1, cost 1, tag 0, A, 8 secs
 Destination 40::/32,
     via FE80::7D58:0:CA03:1, cost 1, tag 0, A, 3 secs
 Local route
 Destination 10::/32,
     via ::, cost 0, tag 0, DOF
