14-Industrial Protocols Configuration Guide
HomeSupportSwitchesIE4320 SeriesConfigure & DeployConfiguration GuidesH3C IE4320-EI[IEF4320-EI] Switch Series Configuration Guides-R68xx-6W10014-Industrial Protocols Configuration Guide
01-Modbus configuration
01-Modbus configuration 538.10 KB
Configuring Modbus
About Modbus
Modbus is an open, standardized, easy-to-use, and reliable communication protocol in the industrial field. It enables client/server communication between devices connected to different types of buses or networks, suitable for automation control scenarios. Currently, the Modbus protocol is widely used for communication among various control devices in automation control systems, instruments, robot control, and mobile device control. Modbus holds a significant position especially in smart manufacturing and industrial internet fields.
Benefits
Modbus provides the following benefits:
·     The Modbus protocol standards are openly available, allowing for data exchange between devices from different manufacturers.
·     Modbus, an application layer protocol, defines message structures that can be understood and used by industrial controllers and does not define the physical layer, enabling data transmission within various network architectures. Modbus not only supports multiple electrical interfaces such as RS485 and TCP/IP, but also transmits data through various media including twisted pair cables and optical fibers.
·     The Modbus protocol has a simple and easy-to-understand message format, which facilitates user understanding and usage, as well as development and integration by manufacturers in industrial control networks.
Modbus network model
Modbus communication layer
Modbus supports deployment on a serial link or an Ethernet TCP/IP network. It utilizes network layers for communication in different networks as shown in Figure 1.
Figure 1 Modbus communication layer
Modbus communication mechanism
As shown in Figure 2, Modbus uses a client/server structure. In Modbus communication, only the client sends requests, and the server responds to the requests. Data is transmitted between the client and server over Modbus. On an industrial control network, PLC devices typically act as clients, and peripheral I/O sensors, valves, network drives, or other measuring devices act as servers.
Figure 2 Modbus network model
Modbus data model
With the Modbus protocol, a Modbus client can perform read/write operations on the data stored in a Modbus server to perform data analysis and state control over the industrial network.
As shown in Figure 3, Modbus assigns logical address ranges for various device applications, with each application having a unique range. When the Modbus client requests data, it only needs to provide the Modbus server with the start address and the length of the desired data, and the server can then accurately send the requested data back to the client.
Figure 3 Communication mechanism
For information about Modbus-TCP address mappings for H3C devices, see "Appendix Modbus-TCP address mappings."
Modbus transmission messages
Modbus has two types of transmission messages, Modbus-RTU messages and Modbus-TCP messages.
Modbus-RTU messages
In Modbus-RTU transmission mode, the format of the Application Data Unit (ADU) uses the structure, as shown in Figure 4.
Figure 4 Modbus-RTU ADU
The fields in the Modbus-RTU ADU structure are as follows:
·     Server address—Address of the server, which is the target of the Modbus request sent by the client. The address length is one byte.
·     Function code—Instruction sent by the client to the server, such as reading/writing data from the server. The instruction length is one byte.
·     Function-specific data—Describes the content of a specific request or response instruction based on different function codes. The data length varies.
·     Error checking—Checks the correctness of the received data to avoid errors during message transmission. The filed length is two bytes.
Modbus-TCP messages
In Modbus-TCP transmission mode, the format of the Application Data Unit (ADU) uses the structure, as shown in Figure 5.
Figure 5 Modbus-TCP ADU
Different from Modbus messages transmitted over a serial link, the Modbus-TCP ADU does not require an error checking field, as the TCP/UDP protocols inherently provide error checking capabilities. In addition, the Modbus-TCP ADU no longer needs an address field; and addressing is achieved via encapsulation through the network and data link layers on the Ethernet network. To distinguish Modbus messages on the Ethernet network, a Modbus Application Header (MBAP) is encapsulated onto the PDU of the Modbus-TCP ADU. The fields in the Modbus-TCP ADU are as follows:
·     Transaction identifier—Identifies the transaction of the Modbus request or response. The field length is two bytes.
·     Protocol identifier—Value 0 identifies the Modbus protocol. The field length one byte.
·     Length identifier—Identifies the subsequent field length. The field length is two bytes.
·     Unit identifier—Used for system internal routing, identifying the remote servers connected via serial links or other buses, The field length is one byte.
Restrictions and guidelines: Modbus configuration
H3C industrial switches can act only as Modbus servers in a Modbus network.
This feature is not supported in an IRF fabric.
Enabling Modbus-TCP for the device
With this feature enabled, an H3C device can establish a TCP connection with a Modbus client and communicates with that client through Modbus-TPC. H3C devices uses port 502 to establish TCP connections with Modbus clients. H3C industrial switches can enable or disable a port and obtain port, ring network, and alarm information through Modbus-TCP.
By default, a Modbus client can read and write information from the device through Modbus TCP. Changing the device status without permission can pose a severe security risk. To address this issue, you can execute this command to set the operating mode of Modbus TCP on the device to read only, allowing Modbus clients to only read information from the device through Modbus TCP.
To obtain Modbus data addresses mapped to ports on devices, execute the display modbus-tcp information interface command.
A Modbus client can read and edit the status of a maximum of 128 ports on an H3C device.
2.     Enable Modbus-TCP for the device.
modbus-tcp enable
By default, Modbus-TCP is disabled for the device.
3.     (Optional.) Set the operating mode of Modbus-TCP to read only.
modbus-tcp working-mode read-only
By default, Modbus-TCP operates in read write mode. The device can read its information and edit its status through Modbus-TCP.
Display and maintenance commands for Modbus
Display information required for the device to read local port information using the Modbus-TCP protocol.
display modbus-tcp information interface { interface-type interface-number | interface-name }
Device information (0X0000-0X0FFF)
Node name
Start address (hex)
Data length
(Unit: words)
Data type
Example
Company Name
0x0000
255
ASCII
Company name
Company Name = “H3C”
Word 0 Hi byte = ‘H’
Word 0 Lo byte = ‘3’
Word 1 Hi byte = ‘C’
Word 1 Lo byte = ‘\0’
Word 2 Hi byte = ‘\0’
Word 2 Lo byte = ‘\0’
Dev Type
0x0100
255
ASCII
Product name
Device Type = “SWITCH”
Word 0 Hi byte = ‘S’
Word 0 Lo byte = ‘W’
Word 1 Hi byte = ‘I’
Word 1 Lo byte = ‘T’
Word 2 Hi byte = ‘C’
Word 2 Lo byte = ‘H’
Word 3 Hi byte = ‘\0’
Word 3 Lo byte = ‘\0’
Company location
0x0200
257
ASCII
Company location
Location = “Hangzhou, China”
Word 0 Lo byte = ‘a’
Word 1 Hi byte = ‘n’
Word 1 Lo byte = ‘g’
Word 2 Hi byte = ‘z’
Word 2 Lo byte = ‘h’
Word 3 Hi byte = ‘o’
Word 3 Lo byte = ‘u’
Word 4 Hi byte = ‘,’
Word 4 Lo byte = ‘ ’ (space)
Word 5 Hi byte = ‘C’
Word 5 Lo byte = ‘h’
Word 6 Hi byte = ‘i’
Word 6 Lo byte = ‘n
Word 7 Hi byte = ‘a’
Word 7 Lo byte = ‘\0’
Word 8 Hi byte = ‘\0’
Word 8 Lo byte = ‘\0’
Contact
0x0400
257
ASCII
Contact
 Contact
 = “New H3C Technologies Co., Ltd”
Word 0 Hi byte = ‘N’
Word 0 Lo byte = ‘e’
Word 1 Hi byte = ‘w’
Word 1 Lo byte = ‘ ’ (space)
Word 2 Hi byte = ‘H’
Word 2 Lo byte = ‘3’
Word 3 Hi byte = ‘C’
Word 3 Lo byte = ‘ ’ (space)
Word 4 Hi byte = ‘T’
Word 4 Lo byte = ‘e’
Word 5 Hi byte = ‘c’
Word 6 Hi byte = ‘n’
Word 6 Lo byte = ‘o’
Word 7 Hi byte = ‘l’
Word 7 Lo byte = ‘o’
Word 8 Hi byte = ‘g’
Word 8 Lo byte = ‘i
Word 9 Hi byte = ‘e’
Word 9 Lo byte = ‘s’
Word 10 Hi byte = ‘ ’ (space)
Word 10 Lo byte = ‘C’
Word 11 Hi byte = ‘o’
Word 11 Lo byte = ‘.’
Word 12 Hi byte = ‘,’
Word 12 Lo byte = ' '(space)
Word 13 Hi byte = ‘L’
Word 13 Lo byte = ‘t’
Word 14 Hi byte = ‘d’
Word 14 Lo byte = ‘.’
Word 15 Hi byte = ‘\0’
Word 15 Lo byte = ‘\0’
Product Type
0x0600
129
ASCII
Product category
Product Type
 = “H3C IE4320-52S”
Word 2 Hi byte = ‘I’
Word 2 Lo byte = ‘E’
Word 3 Hi byte = ‘4’
Word 3 Lo byte = ‘3’
Word 4 Hi byte = ‘2’
Word 4 Lo byte = ‘0’
Word 5 Hi byte = ‘-’
Word 5 Lo byte = ‘5’
Word 6 Hi byte = ‘2’
Word 6 Lo byte = ‘S
Word 7 Hi byte = ‘\0’
Serial Num
0x0690
17
ASCII
Serial number
Serical Num =  “219801A2DD9209Q00009”
Word 0 Hi byte = ‘2’
Word 0 Lo byte = ‘1’
Word 1 Hi byte = ‘9’
Word 1 Lo byte = ‘8’
Word 2 Hi byte = ‘0’
Word 2 Lo byte = ‘1’
Word 3 Hi byte = ‘A’
Word 3 Lo byte = ‘2’
Word 4 Hi byte = ‘D’
Word 4 Lo byte = ‘D’
Word 5 Hi byte = ‘9’
Word 5 Lo byte = ‘2’
Word 6 Hi byte = ‘0’
Word 6 Lo byte = ‘9’
Word 7 Hi byte = ‘Q’
Word 7 Lo byte = ‘0’
Word 8 Hi byte = ‘0’
Word 8 Lo byte = ‘0’
Word 9 Hi byte = ‘0’
Word 9 Lo byte = ‘9’
Word 10 Hi byte = ‘\0’
Word 10 Lo byte = ‘\0’
Bootware Version
0x06B0
32
ASCII
BootWare version
Bootware Version = “150”
Word 0 Hi byte = ‘1’
Word 0 Lo byte = ‘5’
Word 1 Hi byte = ‘0’
Software Version
0x06D0
32
ASCII
Software version
Bootware Version = “7.1.070 Release 6350”
Word 0 Hi byte = ‘7’
Word 0 Lo byte = ‘.’
Word 1 Hi byte = ‘1’
Word 1 Lo byte = ‘.’
Word 2 Lo byte = ‘7’
Word 3 Hi byte = ‘0’
Word 4 Hi byte = ‘R’
Word 5 Hi byte = ‘l’
Word 5 Lo byte = ‘e’
Word 6 Hi byte = ‘a’
Word 6 Lo byte = ‘s’
Word 7 Hi byte = ‘e’
Word 7 Lo byte = ‘ ’
Word 8 Hi byte = ‘6’
Word 8 Lo byte = ‘3’
Word 9 Hi byte = ‘5’
Word 9 Lo byte = ‘0’
Hardware Version
0x06F0
128
ASCII
Hardware version
Hardware Version = “Ver.A”
Word 0 Hi byte = ‘V’
Word 1 Hi byte = ‘r’
Word 2 Hi byte = ‘A’
Logical Version
0x0770
20
ASCII
Logical version
N/A
IP Addr
0x0800
2
HEX
IP address
IP address=1.2.3.4
Word 0 Hi byte = 0x01
Word 0 Lo byte = 0x02
Word 1 Hi byte = 0x03
Word 1 Lo byte = 0x04
Start Mac
0x0802
3
HEX
MAC address of the device
MAC address=98F1-81CD-434A
Word 0 Hi byte = 0x98
Word 0 Lo byte = 0xf1
Word 1 Hi byte = 0x81
Word 1 Lo byte = 0xcd
Word 0 Hi byte = 0x43
Word 0 Lo byte = 0x4a
MAC Number
0x0805
2
HEX
Number of MAC addresses of the MPU
MAC quantity=56
Word 0 Hi byte = 0x00
Word 0 Lo byte = 0x00
Word 1 Hi byte = 0x00
Word 1 Lo byte = 0x38
Power1 State
0x0807
1
HEX
·     1—up
·     0—down
Power supply 1 status is up=1
Power2 State
0x0808
1
HEX
·     1—up
·     0—down
Power supply 1 status is down=0
Word 0 Lo byte = 0x01
Cpu Long Usage
0x0809
2
HEX
Average CPU usage (%) of the device in 5 minutes
CPU usage=6%
Word 1 Lo byte = 0x06
Cpu Short Usage
0x080B
2
HEX
Average CPU usage (%) of the device in 1 minute
CPU usage=4%
Mem Size Total
0x080D
2
HEX
Total memory size of the device (KB)
Total memory size of the device=506408
Word 0 Lo byte = 0x07
Word 1 Hi byte = 0xba
Word 1 Lo byte = 0x28
Mem Free
0x080F
2
HEX
Free memory of the device (KB)
Total memory size of the device=176376
Word 1 Hi byte = 0xb0
Word 1 Lo byte = 0xf8
Run Time
0x0811
4
HEX
Current time (UTC)
Uptime=1357233936
Word 1 Lo byte = 0x00
Word 2 Hi byte = 0x50
Word 2 Lo byte = 0xe5
Word 3 Hi byte = 0xbf
Word 3 Lo byte = 0x10
Run Time Total
0x0815
4
HEX
Total uptime of the device (min)
Total uptime=982
Word 2 Hi byte = 0x00
Word 2 Lo byte = 0x00
Word 3 Hi byte = 0x03
Word 3 Lo byte = 0xd6
Temperature
0x0819
2
HEX
Device temperature (°C)
N/A
Port information (1-32) (0X1000-0X1FFF)
Node name
Start address (hex)
Data length
(Unit: words)
Data type
Example
IfName
0x1000
32
ASCII
Name of the port (length: 2-47)
IfDescr =
“GigabitEthernet2/0/2”
Word 0 Hi byte = ‘G’
Word 0 Lo byte = ‘i’
Word 1 Hi byte = ‘g’
Word 1 Lo byte = ‘a’
Word 2 Hi byte = ‘b’
Word 2 Lo byte = ‘i’
Word 3 Hi byte = ‘t’
Word 3 Lo byte = ‘E’
Word 4 Hi byte = ‘t’
Word 4 Lo byte = ‘h’
Word 5 Hi byte = ‘e’
Word 5 Lo byte = ‘r’
Word 6 Lo byte = ‘e’
Word 7 Hi byte = ‘t’
Word 7 Lo byte = ‘2’
Word 8 Hi byte = ‘/’
Word 9 Hi byte = ‘/’
Word 9 Lo byte = ‘2’
IfStatus
0x1040
1
HEX
read:
·     0—disable
·     1—up
·     2—down
A port is enabled if it is in up or down state
write:
·     1—enable
·     2—disable
Port state down:
IfSpeed
0x1041
1
HEX
·     0—Auto
·     1—2Mbps
·     2—10Mbps
·     3—100Mbps
·     4—155Mbps
·     5—622bps
·     6—1Gbps
·     7—2Gbps
·     8—2.5Gbps
·     9—4Gbps
·     10—5Gbps
·     11—8Gbps
·     12—10Gbps
·     13—16Gbps
·     14—20Gbps
·     15—25Gbps
·     16—32Gbps
·     17—40Gbps
·     18—100Gbps
1G port speed:
Word 0 Lo byte = 0x06
Duplex
0x1042
1
HEX
·     1—Full
·     2—Half
·     3—Auto
Full duplex mode:
FlowControl
0x1043
1
HEX
·     1—Enable
·     2—Disable
Flow control enabled:
InPkts
0x1044
4
HEX
Number of received packets
Total number of received packets on the port: 10359115
Word 0 Lo byte = 0x9e
Word 0 Hi byte = 0x11
Word 0 Lo byte = 0x4b
InOctets
0x1048
4
HEX
Number of received bytes (byte)
Total number of received bytes: 1325966720
Word 0 Hi byte = 0x4F
Word 0 Lo byte = 0x08
Word 0 Hi byte = 0xA5
Word 0 Lo byte = 0x80
OutPkts
0x104C
4
HEX
Number of sent packets
Number of sent packets: 21919
Word 0 Hi byte = 0x55
Word 0 Lo byte = 0x9F
OutOctets
0x1050
4
HEX
Number of sent bytes (byte)
Total number of sent bytes: 1470550
Word 0 Lo byte = 0x16
Word 0 Hi byte = 0x70
Word 0 Lo byte = 0x56
InUcastPkts
0x1054
4
HEX
Number of received unicast packets
Number of received unicast packets: 5641988
Word 0 Hi byte = 0x17
Word 0 Lo byte = 0x04
InMulticastPkts
0x1058
4
HEX
Number of received multicast packets
Number of received multicast packets: 2605221
Word 0 Lo byte = 0x27
Word 0 Hi byte = 0xC0
Word 0 Lo byte = 0xA5
InBrdcastPkts
0x105C
4
HEX
Number of received broadcast packets
Number of received broadcast packets: 2111906
Word 0 Lo byte = 0x20
Word 0 Hi byte = 0x39
Word 0 Lo byte = 0xA2
OutUcastPkts
0x1060
4
HEX
Number of sent unicast packets
Number of sent unicast packets: 21234
Word 0 Hi byte = 0x52
Word 0 Lo byte = 0xF2
OutMulticastPkts
0x1064
4
HEX
Number of sent multicast packets
Number of sent multicast packets: 4998
Word 0 Hi byte = 0x13
Word 0 Lo byte = 0x86
OutBrdcastPkts
0x1068
4
HEX
Number of sent broadcast packets
Number sent broadcast packets: 3329
Word 0 Hi byte = 0x0D
InPauses
0x106C
4
HEX
Number of received pause frames
Number of received pause frames: 680
Word 0 Hi byte = 0x02
Word 0 Lo byte = 0xA8
OutPauses
0x1070
4
HEX
Number of sent pause frames
Number of sent pause frames: 680
InErrCRCFrames
0x1074
4
HEX
Number of received CRC error packets
Number of received CRC error packets: 2872808
Word 0 Lo byte = 0x2B
Word 0 Hi byte = 0xD5
Word 0 Lo byte = 0xE8
·     The start port ID is 1.
·     The node data address for each port (1-32) = node start address + 0x80 * (port ID - start port ID).
Port information (33-64) (0X2000-0X2FFF)
Node name
Start address (hex)
Data length
(Unit: words)
Data type
Example
IfDescr
0x2000
32
ASCII
Name of the port (length: 2 to 47)
IfDescr =
IfStatus
0x2040
1
HEX
read:
·     0—disable
·     1—up
·     2—down
write:
·     1—enable
·     2—disable
N/A
IfSpeed
0x2041
1
HEX
·     0—Auto
·     1—2Mbps
·     2—10Mbps
·     3—100Mbps
·     4—155Mbps
·     5—622bps
·     6—1Gbps
·     7—2Gbps
·     8—2.5Gbps
·     9—4Gbps
·     10—5Gbps
·     11—8Gbps
·     12—10Gbps
·     13—16Gbps
·     14—20Gbps
·     15—25Gbps
·     16—32Gbps
·     17—40Gbps
·     18—100Gbps
N/A
Duplex
0x2042
1
HEX
·     1—Full
·     2—Half
·     3—Auto
N/A
FlowControl
0x2043
1
HEX
Enable flow
control
·     2—Disable
·     3—Only enable
flow control
packet receiving
N/A
InPkts
0x2044
4
HEX
N/A
InOctets
0x2048
4
HEX
N/A
OutPkts
0x204C
4
HEX
N/A
OutOctets
0x2050
4
HEX
N/A
InUcastPkts
0x2054
4
HEX
N/A
InMulticastPkts
0x2058
4
HEX
N/A
InBrdcastPkts
0x205C
4
HEX
N/A
OutUcastPkts
0x2060
4
HEX
N/A
OutMulticastPkts
0x2064
4
HEX
N/A
OutBrdcastPkts
0x2068
4
HEX
N/A
InPauses
0x206C
4
HEX
N/A
OutPauses
0x2070
4
HEX
N/A
InErrCRCFrames
0x2074
4
HEX
N/A
·     The start port ID is 33.
·     The node data address for each port (33-64) = node start address + 0x80 * (port ID - start port ID).
Port information (65-96) (0X3000-0X3FFF)
Node name
Start address (hex)
Data length
(Unit: words)
Data type
Example
IfName
0x3000
32
ASCII
IfDescr =
IfStatus
0x3040
1
HEX
read:
·     0—disable
·     1—up
·     2—down
A port is enabled is in up or down state.
write:
·     1—enable
·     2—disable.
Port state down:
IfSpeed
0x3041
1
HEX
·     0—Auto
·     1—2Mbps
·     2—10Mbps
·     3—100Mbps
·     4—155Mbps
·     5—622bps
·     6—1Gbps
·     7—2Gbps
·     8—2.5Gbps
·     9—4Gbps
·     10—5Gbps
·     11—8Gbps
·     12—10Gbps
·     13—16Gbps
·     14—20Gbps
·     15—25Gbps
·     16—32Gbps
·     17—40Gbps
·     18—100Gbps
1G port speed:
Duplex
0x3042
1
HEX
·     1—Full
·     2—Half
·     3—Auto
Full duplex mode:
FlowControl
0x3043
1
HEX
·     1—Enable
·     2—Disable
InPkts
0x3044
4
HEX
Total number of received packets: 10359115
InOctets
0x3048
4
HEX
OutPkts
0x304C
4
HEX
OutOctets
0x3050
4
HEX
InUcastPkts
0x3054
4
HEX
InMulticastPkts
0x3058
4
HEX
InBrdcastPkts
0x305C
4
HEX
OutUcastPkts
0x3060
4
HEX
OutMulticastPkts
0x3064
4
HEX
OutBrdcastPkts
0x3068
4
HEX
InPauses
0x306C
4
HEX
OutPauses
0x3070
4
HEX
InErrCRCFrames
0x3074
4
HEX
·     The start port ID is 65.
·     The node data address for each port (65-96) = node start address + 0x80 * (port ID - start port ID).
Port information (97-128) (0X4000-0X4FFF)
Node name
Start address (hex)
Data length
(Unit: words)
Data type
Example
IfDescr
0x4000
32
ASCII
IfDescr =
IfStatus
0x4040
1
HEX
read:
·     0—disable
·     1—up
·     2—down
write:
·     1—enable
·     2—disable.
N/A
IfSpeed
0x4041
1
HEX
·     0—Auto
·     1—2Mbps
·     2—10Mbps
·     3—100Mbps
·     4—155Mbps
·     5—622bps
·     6—1Gbps
·     7—2Gbps
·     8—2.5Gbps
·     9—4Gbps
·     10—5Gbps
·     11—8Gbps
·     12—10Gbps
·     13—16Gbps
·     14—20Gbps
·     15—25Gbps
·     16—32Gbps
·     17—40Gbps
·     18—100Gbps
N/A
Duplex
0x4042
1
HEX
·     1—Full
·     2—Half
·     3—Auto
N/A
FlowControl
0x4043
1
HEX
Enable flow
control
·     2—Disable
·     3—Only enable
flow control
packet receiving
N/A
InPkts
0x4044
4
HEX
N/A
InOctets
0x4048
4
HEX
N/A
OutPkts
0x404C
4
HEX
N/A
OutOctets
0x4050
4
HEX
N/A
InUcastPkts
0x4054
4
HEX
N/A
InMulticastPkts
0x4058
4
HEX
N/A
InBrdcastPkts
0x405C
4
HEX
N/A
OutUcastPkts
0x4060
4
HEX
N/A
OutMulticastPkts
0x4064
4
HEX
N/A
OutBrdcastPkts
0x4068
4
HEX
N/A
InPauses
0x406C
4
HEX
N/A
OutPauses
0x4070
4
HEX
N/A
InErrCRCFrames
0x4074
4
HEX
N/A
·     The start port ID is 97.
·     The node data address for each port (97-128) = node start address + 0x80 * (port ID - start port ID).
Alarm information (0X5000-0X5FFF)
Node name
Start address (hex)
Data length
Unit: words
Data type
Example
Remarks
Port Status Alarm
0x5000
1
HEX
·     0—disable
·     1—normal
·     2—alarm
Normal state
The alarm data length for each port is 0x10.
The alarm node data address for each port (1-128) = node start address + 0x10 * (port ID - start port ID).
Port Input Alarm
0x5001
1
HEX
·     1—normal.
·     2—alarm
Normal state
Port Output Alarm
0x5002
1
HEX
·     1—normal.
·     2—alarm
Normal state
Port Crc Alarm
0x5003
1
HEX
·     1—normal.
·     2—alarm
Normal state
Temperature Alarm
0x5800
1
HEX
·     1—normal.
·     2—alarm
Normal state
N/A
Cpu Usage Alarm
0x5801
1
HEX
·     1—normal.
·     2—alarm
Normal state
N/A
Mem Usage Alarm
0x5802
1
HEX
·     1—normal.
·     2—alarm
Normal state
N/A
Power Status Alarm
0x5803
1
HEX
·     0—disable
·     1—normal.
·     2—Alarm for power supply 1
·     3—Alarm for power supply 2
Normal state
N/A
·     The alarm node data address for each port (1-128) = alarm node start address + 0x10 * (port ID - start port ID).
RSTP information (0X6000-0X6FFF)
Node name
Start address (hex)
Data length
Unit: words
Data type
Example
Remarks
RSTP_PROTOCOL_STATUS
0x6000
1
HEX
·     0—disable
·     1—enable
Normal state
N/A
RSTP_ROOTBRIAGE_ID
0x6001
4
HEX
Root bridge ID
8 bytes
RootId=0x80004CB302A30100
Word 0 Hi byte = 0x80
Word 1 Hi byte = 0x4c
Word 1 Lo byte = 0xb3
Word 2 Hi byte = 0x02
Word 2 Lo byte = 0xa3
Word 3 Hi byte = 0x01
Word 3 Lo byte = 0x00
N/A
RSTP_BRIAGE_ID
0x6005
4
HEX
Network bridge ID
8 bytes
BridgeId=0x80004CB302A30100
N/A
RSTP_PRIORITY
0x6009
2
HEX
Priority, in the range of o to 61440
Priority=32768
Word 1 Hi byte = 0x80
N/A
RSTP_HELLO_TIME
0x600B
2
HEX
Interval for the root device to send BPDUs, in the range of 1 to 10
HelloTime=2
Word 1 Lo byte = 0x02
N/A
RSTP_MAX_AGE_TIME
0x600D
2
HEX
Max age timer for BPDUs, in the range of 6 to 40
MaxAge = 20
Word 1 Lo byte = 0x14
N/A
RSTP_FORWARD_DELAY_TIME
0x600F
2
HEX
Forward delay timer, in the range of 4 to 30
ForwardDelay = 15
Word 1 Lo byte = 0x0f
N/A
RSTP_PORT_PROTOCOL_STATUS
0x6020
1
HEX
·     0—disable
·     1—enable
Enabling state
The data length for each port is 0x10.
The node data address for each port (1-128) = node start address + 0x10 * (port ID - start port ID).
RSTP_PORT_PRIORITY
0x6021
2
HEX
Port priority, in the range of o to 240
Priority = 128
RSTP_PATH_COST
0x6023
2
HEX
Path cost, in the range of 0 to 200000000
PathCost = 0
RSTP_PORT_ROLE
0x6025
2
HEX
·     0—Disabled port
·     1—Alternate port
·     2—Backup port
·     3—Root port
·     4—Designated port
·     5—Master port
Role = 4
RSTP_PORT_STATUS
0x6027
2
HEX
·     1—Discarding
·     2—Learning
·     3—Forwarding
State = 3
Word 0 Lo byte = 0x03
·     The STP data address for each port (1-128) = node start address + 0x10 * (port ID - start port ID).
ERPS information (1-7) (0X7000-0x7FFF)
Node name
Start address (hex)
Data length
Unit: words
Data type
Remarks
MODBUS_REG_ADDR_ERPS_PROTOCOL_STATUS
0x7000
1
HEX
·     0—disable
·     1—enable
N/A
ERPS ring ID
MODBUS_REG_ADDR_ERPS_RING_ID
0x7001
1
HEX
The ID is in the range of 1 to 8.
The data length for each ERPS ring is 0x243.
The start ring ID is 1.
The node data address for each ERPS ring = node start address + 0x243 * (ring ID - start ring ID).
MODBUS_REG_ADDR_ERPS_PORT0
0x7002
1
HEX
N/A
N/A
ERPS ring member port
MODBUS_REG_ADDR_ERPS_PORT1
0x7003
1
HEX
N/A
N/A
MODBUS_REG_ADDR_ERPS_INSTANCE_ID
0x7004
1
HEX
Value range: 1 to 64
The data length for each ERPS instance is 0x9.
The start instance ID is 1.
The node data address for each ERPS instance = node start address + 0x243 * (ring ID - start ring ID) + 0x9 * (instance ID - start instance ID).
MODBUS_REG_ADDR_ERPS_CONTROL_VLAN
0x7005
1
HEX
Value range: 2 to 4094.
N/A
MODBUS_REG_ADDR_ERPS_NODE_ROLE
0x7006
1
HEX
·     0—owner
·     1—neighbor
·     2—normal
·     3—interconnection
N/A
MODBUS_REG_ADDR_ERPS_NODE_STATE
0x7007
1
HEX
·     0—Undefined
·     1—init
·     2—idle
·     3—protection
·     4—MS
·     5—FS
·     6—Pending
N/A
MODBUS_REG_ADDR_ERPS_INSTANCE_ENABLE_STATUS
0x7008
1
HEX
·     0—false
·     1—true
N/A
MODBUS_REG_ADDR_ERPS_PORT0_PORT_ROLE
0x7009
1
HEX
·     0—RPL
·     1—Non-RPL
·     2—Undefined
N/A
MODBUS_REG_ADDR_ERPS_PORT0_PORT_STATUS
0x700A
1
HEX
·     0—Block
·     1—Up
·     2—Down
·     3—Undefined
N/A
0x700B
1
HEX
Value range: 1 to 128
N/A
MODBUS_REG_ADDR_ERPS_PORT1_PORT_STATUS
0x700C
1
HEX
·     0—Block
·     1—Up
·     2—Down
·     3—Undefined
N/A
·     The start ring ID and instance ID are both 1.
·     The node data address for each ring = node start address + 0x243 * (ring ID - start ring ID).
·     The node address for an instance = node start address + (0x243 * (ring ID - start ring ID)) + (0x9 * (instance ID - start instanceID)).
ERPS ring information (8) (0X7000-0x8FFF)
Node name
Start address (hex)
Data length
Unit: words
Data type
Remarks
0x8001
1
HEX
The start ring ID is 8.
0x8002
1
HEX
N/A
N/A
0x8003
1
HEX
N/A
N/A
0x8004
1
HEX
0x8005
1
HEX
N/A
0x8006
1
HEX
·     0—owner
·     1—neighbor
·     2—normal
·     3—interconnection
N/A
0x8007
1
HEX
·     0—Undefined
·     1—init
·     2—idle
·     3—protection
·     4—MS
·     5—FS
·     6—Pending
N/A
0x8008
1
HEX
·     0—false
·     1—true
N/A
0x8009
1
HEX
·     0—RPL.
·     1—Non-RPL.
·     2—Undefined
N/A
0x800A
1
HEX
·     0—Block
·     1—Up
·     2—Down
·     3—Undefined
N/A
0x800B
1
HEX
N/A
0x800C
1
HEX
·     0—Block
·     1—Up
·     2—Down
·     3—Undefined
N/A
·     The start ring ID is 8 and the start instance ID is 1.
·     The node address for an ERPS instance = node start address + (0x243 * (ring ID - start ring ID) ) + (0x9 * (instance ID - start instance ID)).
RRPP information (1-2) (0X9000-0x9FFF)
Node name
Start address (hex)
Data length
Unit: words
Data type
Remarks
MODBUS_REG_ADDR_RRPP_PROTOCOL_STATUS
0x9000
1
HEX
·     0—disable
·     1—enable
N/A
MODBUS_REG_ADDR_RRPP_DOMAIN_ID
0x9001
1
HEX
Value range: 1 to 8
The data length for each RRPP domain is 0x582.
The start domain ID is 1.
The node data address for each domain = node start address + 0x582 * (domain ID - start domain ID).
MODBUS_REG_ADDR_RRPP_CONTROL_VLAN
0x9002
1
HEX
N/A
MODBUS_REG_ADDR_RRPP_RING_ID
0x9003
1
HEX
The data length for each RRPP ring is 0xB.
The node data address for each RRPP ring = node start address + 0x582 * (domain ID - start domain ID) + 0xB * (ring ID - start ring ID).
MODBUS_REG_ADDR_RRPP_NODE_MODE
0x9004
1
HEX
·     0—transit
·     1—master
·     2—edge
·     3—assistant edge
N/A
MODBUS_REG_ADDR_RRPP_PRIMARY_PORT
0x9005
1
HEX
N/A
MODBUS_REG_ADDR_RRPP_PRIMARY_PORT_STATUS
0x9006
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
MODBUS_REG_ADDR_RRPP_SECONDARY_PORT
0x9007
1
HEX
N/A
MODBUS_REG_ADDR_RRPP_SECONDARY_PORT_STATUS
0x9008
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
MODBUS_REG_ADDR_RRPP_EDGE_PORT
0x9009
1
HEX
N/A
MODBUS_REG_ADDR_RRPP_EDGE_PORT_STATUS
0x900A
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
MODBUS_REG_ADDR_RRPP_RING_LEVEL
0x900B
1
HEX
·     0—major ring
·     1—sub ring
N/A
MODBUS_REG_ADDR_RRPP_RING_ENABLE
0x900C
1
HEX
·     0—false
·     1—true
N/A
MODBUS_REG_ADDR_RRPP_RING_STATE
0x900D
1
HEX
·     0—Completed
·     1—Failed
·     2—LinkUp
·     3—LinkDown
·     4—PreForward
·     5—LinkUpNotify
·     6—LinkDnNotify
·     7—PreForwardNotify
·     8—Unknown
N/A
·     The start domain ID and start instance ID are both 1.
·     The node data address for each domain = node start address + 0x582 * (domain ID - start domain ID).
·     The node data address for each instance = node start address +  (0x582 * (domain ID - start domain ID)) + (0xB * (ring ID - start ring ID)).
RRPP information (3-4) (0XA000-0xAFFF)
Node name
Start address (hex)
Data length
Unit: words
Data type
Remarks
0xA001
1
HEX
Value range: 1 to 8
The start domain ID is 3.
0xA002
1
HEX
N/A
0xA003
1
HEX
0xA004
1
HEX
·     0—transit
·     1—master
·     2—edge
·     3—assistant edge
N/A
Master Port
0xA005
1
HEX
N/A
0xA006
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xA007
1
HEX
N/A
0xA008
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xA009
1
HEX
N/A
0xA00A
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xA00B
1
HEX
·     0—major ring
·     1—sub ring
N/A
0xA00C
1
HEX
·     0—false
·     1— true
N/A
0xA00D
1
HEX
·     0—Completed
·     1—Failed
·     2—LinkUp
·     3—LinkDown
·     4—PreForward
·     5—LinkUpNotify
·     6—LinkDnNotify
·     8—Unknown
N/A
·     The start domain ID is 3 and the start ring ID is 1.
·     The node data address for an instance = node start address + (0x582 * (domain ID - start domain ID)) + (0xB * (ring ID - start ring ID)).
RRPP information (5-6) (0XB000-0xBFFF)
Node name
Start address (hex)
Data length
Unit: words
Data type
Remarks
0xB001
1
HEX
The start domain ID is 5.
0xB002
1
HEX
N/A
0xB003
1
HEX
0xB004
1
HEX
·     0—transit
·     1—master
·     2—edge
·     3—assistant edge.
N/A
0xB005
1
HEX
N/A
0xB006
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xB007
1
HEX
N/A
0xB008
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xB009
1
HEX
N/A
0xB00A
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xB00B
1
HEX
·     0—major ring
·     1—sub ring
N/A
0xB00C
1
HEX
·     0— false
·     1— true
N/A
0xB00D
1
HEX
·     0—Completed
·     1—Failed
·     2—LinkUp
·     3—LinkDown
·     4—PreForward
·     5—LinkUpNotify
·     6—LinkDnNotify
·     8—Unknown
N/A
·     The start domain ID is 5 and the start ring ID is 1.
RRPP information (7-8) (0XC000-0xCFFF)
Node name
Start address (hex)
Data length
Unit: words
Data type
Remarks
0xC001
1
HEX
The start domain ID is 7.
0xC002
1
HEX
N/A
0xC003
1
HEX
0xC004
1
HEX
·     0—transit
·     1—master
·     2—edge
·     3—assistant edge
N/A
0xC005
1
HEX
N/A
0xC006
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xC007
1
HEX
N/A
0xC008
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xC009
1
HEX
N/A
0xC00A
1
HEX
·     0—down
·     1—up
·     2—blocked
N/A
0xC00B
1
HEX
·     0—major ring
·     1—sub ring
N/A
0xC00C
1
HEX
·     0— false
·     1— true
N/A
0xC00D
1
HEX
·     0—Completed
·     1—Failed
·     2—LinkUp
·     3—LinkDown
·     4—PreForward
·     5—LinkUpNotify
·     6—LinkDnNotify
·     8—Unknown
N/A
·     The start domain ID is 7 and the start ring ID is 1.
Modbus relay
About Modbus relay
Typically, a Modbus client resides on the Ethernet network and sends Modbus-TCP messages. Modbus servers are connected via serial links and can identify only Modbus-RTU messages. As a result, the Modbus client cannot directly communicate with the Modbus servers. An H3C industrial switch acts as a relay gateway, enabling Modbus messages to be successfully exchanged between the client and servers, as shown in Figure 6.
Figure 6 Network diagram
Operating mechanism of the Modbus relay gateway
On a Modbus network, an H3C industrial switch physically connects to a Modbus client via an Ethernet interface and to Modbus servers via an RS485 serial interface. The switch must establish a TCP or UDP connection with the Modbus client so that the Ethernet TCP/IP network can carry Modbus messages. The switch also uses an RS485 serial interface to support the Modbus protocol. The RS485 serial interface enables the switch to establish a TCP or UDP connection and Ethernet communication with the Modbus client and serial communication with the Modbus servers.
An RS485 serial interface supports the following forwarding modes:
·     Transparent mode—Typically, a Modbus client sends Modbus-TCP messages. However, a high-performance Modbus client can directly generate Modbus-RTU messages when it detects that a Modbus server supports only Modbus-RTU messages. The Modbus client then sends Modbus-RTU messages to the H3C industrial switch via the TCP/IP Ethernet path, as shown in Figure 7.
In transparent mode, an RS485 serial interface on the H3C industrial switch transparently transmits Modbus-RTU messages between the Modbus client and Modbus servers.
Figure 7 Transparent mode of the relay gateway
·     Agent mode—An RS485 serial interface on the H3C industrial switch converts the Modbus-TCP messages received from a Modbus client to Modbus-RTU messages, and then forwards the converted messages to Modbus servers. The switch changes the Modbus-RTU messages received from a Modbus server to Modbus-TCP messages, and then forwards the converted messages to the Modbus client, as shown in Figure 8.
Figure 8 Agent mode of the relay gateway
The correspondence between the forwarding mode and the transport layer connection established for RS485 serial interfaces is as listed in Table 1.
Table 1 Correspondence between the forwarding mode and the transport layer connection for RS485 serial interfaces
Forwarding mode
Transport layer connection to be established
Transparent mode
As Modbus-RTU messages have no requirements for the transport layer protocol on the Ethernet network, an RS485 serial interface can establish both TCP and UDP connections with the client. In addition, the RS485 serial interface can act as either the client or server during the establishment of TCP and UDP connections.
Agent mode
The Modbus-TCP protocol supports only TCP, so an RS485 serial interface must establish a TCP connection with the client, and must act as the TCP server.
Modbus relay tasks at a glance
To configure Modbus relay, perform the following tasks:
1.     Configuring operating parameters of an RS485 serial interface
2.     Enabling Modbus and specifying the Modbus mode
3.     Configure an RS485 serial interface to establish a TCP or UDP connection with the client
¡     Configuring an RS485 serial interface to establish a TCP connection with a Modbus client
¡     Configuring an RS485 serial interface to establish a UDP connection with a Modbus client
Only one type of connection can be configured for an RS485 serial interface. You can repeat the steps on multiple RS485 serial ports to establish multiple connections.
4.     (Optional.) Optimizing Modbus performance
5.     Restoring the default settings for an RS485 serial interface
About RS485 serial interfaces
An industrial switch acts as a relay device for Modbus protocol communication between the client and servers. The switch establishes a physical connection with a Modbus server via an RS485 serial interface. To ensure connectivity of RS485 links, make sure the parameters of the RS485 serial interface matches those for the industrial switch.
2.     Enter RS485 serial interface view.
interface uart interface-number
3.     Configure the description for the RS485 serial interface.
By default, the description for an interface is interface name Interface (for example, UART1/0/1 Interface).
4.     Configure the flow control mode.
flow-control none
By default, no flow control mode is configured for an RS485 serial interface.
5.     Set the baud rate.
baudrate baudrate-value
By default, the baud rate is 9600 bps.
6.     Specify the number of data bits
databits 8
By default, the number of data bits is 8.
7.     Specify the number of stop bits.
stopbits { 1 | 2 }
By default, the number of stop bits for an RS485 serial interface is 1.
8.     Specify the parity.
parity none
By default, the setting is none. No parity is used.
After you specify the forwarding mode for an RS485 serial interface, Modbus on this interface is enabled.
You cannot edit the forwarding mode for an RS485 serial interface by repeating the modbus mode command. To edit the forwarding mode, execute the undo modbus mode command to remove the forwarding mode configuration, and then execute the modbus mode command to reconfigure the forwarding mode.
Executing the undo modbus mode command will restore the Modbus configuration to the factory defaults, which might cause a Modbus communication interruption.
3.     Enable Modbus and specify a forwarding mode for the RS485 serial interface and enter the corresponding Modbus mode view.
¡     Specify the agent mode for the RS485 serial interface and enter the Modbus agent mode view.
modbus mode agent
¡     Specify the transparent mode for the RS485 serial interface and enter the Modbus transparent mode view.
modbus mode raw
By default, no forwarding mode is specified for an RS485 serial interface. This indicates that the RS485 serial interface is disabled with Modbus and cannot process Modbus messages.
In agent mode, an H3C industrial switch acts as a Modbus server for a Modbus client and needs to receive Modbus-TCP messages from the client. Then, a TCP server connection is required. In transparent mode, an RS485 serial interface on an H3C industrial switch can act as a TCP server or TCP client to establish a TCP connection with a Modbus client for reliable transparent transmission of Modbus-RTU messages.
You can execute the modbus packet-size command to edit the minimum length of TCP packets that an RS485 serial interface sends to a Modbus client, accommodating various network environments. Increasing the minimum length enables multiple messages to be encapsulated into one TCP packet, which reduces system resource consumption caused by multiple packet encapsulations.
You can configure this feature multiple times to configure an RS485 interface as a TCP client to establish TCP connections with a maximum of four Modbus clients. Do not specify TCP or UDP servers that have the same IP address for different RS485 serial interfaces on the device.
The tcp client, tcp server, udp client, and udp server commands are mutually exclusive. Do not execute two or more of these commands in the same view.
To ensure correct operation of Modbus and other services, specify an unused port number.
Configuring an RS485 serial interface as a TCP server to establish a TCP connection with a Modbus client
3.     (Optional.) Set the minimum length of TCP packets that an RS485 serial interface sends to a Modbus client.
modbus packet-size size
By default, the minimum length of TCP packets that an RS485 serial interface sends to a Modbus client is not configured. The TCP packet length varies by actual data size.
4.     Enter the Modbus transparent mode view or Modbus agent mode view.
modbus mode { agent | raw }
5.     Configure an RS485 serial interface as a TCP server to establish a TCP connection with a Modbus client (TCP client).
tcp server [ server-port server-port ] [ vpn-instance vpn-instance-name ]
By default, no role is configured for an RS485 serial interface in establishing a transport layer connection. The interface does not establish any connection with a Modbus client at the transport layer.
Configuring an RS485 serial interface as a TCP client to establish a TCP connection with a Modbus client
4.     Enter the Modbus transparent view.
modbus mode raw
5.     Configure an RS485 serial interface as a TCP client to establish a TCP connection with a Modbus client (TCP server).
tcp client server-ip server-ip server-port server-port [ vpn-instance vpn-instance-name ]
The Modbus-TCP transmission mode depends on the TCP protocol. During the establishment of a UDP connection between an RS485 serial interface and a Modbus client, only transparent mode can be used to transmit Modbus-RTU messages. Establishing a UDP connection is efficient in message transmission.
You can configure this feature multiple times to configure an RS485 serial interface to establish UDP connections with a maximum of four Modbus clients. Do not specify TCP or UDP servers that have the same IP addresses for different RS485 serial interfaces on the device.
Configuring an RS485 serial interface as a UDP server to establish a UDP connection with a Modbus client
3.     Enter the Modbus transparent view.
modbus mode raw
4.     Configure an RS485 serial interface as a UDP server to establish a UDP connection with a Modbus client (UDP client)
udp server [ server-port server-port ] [ vpn-instance vpn-instance-name ]
Configuring an RS485 serial interface as a UDP client to establish a UDP connection with a Modbus client
modbus mode raw
4.     Configure an RS485 serial interface as a UDP client to establish a UDP connection with a Modbus client (UDP server).
udp client server-ip server-ip server-port server-port [ local-port local-port ] [ vpn-instance vpn-instance-name ]
Configuring minimum interval for an RS485 serial interface to send Modbus-RTU messages to a Modbus server
Modbus servers vary in type and their ability to process Modbus-RTU messages also differs. For low-performance Modbus servers, set a long Modbus-RTU message sending interval to avoid packet congestion. For high-performance Modbus servers, set a short Modbus-RTU message sending interval to accelerate the speed at which a Modbus client receives responses.
3.     Configure the minimum interval for the RS485 serial interface to send Modbus-RTU messages to a Modbus server.
modbus packet-time interval
By default, an RS485 serial interface sends Modbus-RTU messages to a Modbus server at least every 100 milliseconds.
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to identify these commands, and use their undo forms or follow the Modbus command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to solve the problem.
3.     Restore the default settings for the RS485 serial interface.
default
Display and maintenance commands for Modbus relay
Display information about RS485 serial interfaces.
display interface [ uart [ interface-number ] ] [ brief [ description ] ]
Display TCP sessions for an RS485 serial interface.
display modbus session [ interface interface-type interface-number ]
