H3C S12500R Switch Router Series Hardware Reference-6W106
HomeSupportSwitchesS12500R SeriesProduct LiteratureHardware Information & SpecificationsH3C S12500R Switch Router Series Hardware Reference-6W106
01-Hardware Information and Specifications
01-Hardware Information and Specifications 13.50 MB
1 Chassis· 1-1
Chassis views· 1-1
Chassis components· 1-3
Technical specifications· 1-7
Weights and dimensions· 1-7
Module power consumption and system power consumption· 1-10
Heat dissipation· 1-13
Environmental specifications· 1-13
2 Modules· 2-1
Naming conventions· 2-1
SEU naming conventions· 2-1
Interface module naming conventions· 2-2
Fabric module naming conventions· 2-2
Module compatibility matrixes· 2-3
Restriction and guidelines· 2-3
SEUs· 2-3
Interface modules· 2-4
Fabric modules· 2-4
SEUs· 2-5
LSXM1SUPER1· 2-5
LSXM1SUPEAR1· 2-8
LSXM1SUP04TR1· 2-11
LSXM1SUP02LR1· 2-13
LSXM1SUP02TR1· 2-16
LSXM2SUP02LR1· 2-18
Type K 400G interface modules· 2-20
LSXM1CDQ24KB1· 2-20
LSXM1CDQ24KBR1· 2-22
LSXM1CDQ18KCR1· 2-23
Type K 200G interface modules· 2-24
LSXM1CCQ48KBR1· 2-24
Type K 100G interface modules· 2-26
LSXM1CGQ72KCR1· 2-26
LSXM1CGQ48KB1· 2-28
LSXM2CGQ48KBR1· 2-29
LSXM1CGMS48KBR1· 2-30
LSXM1CGQ48KBR1· 2-32
LSXM1CGQFX16KBR1· 2-33
Type K 24KBR flexible line processing platform modules· 2-34
LSXM1MOD24KBR1· 2-34
Type H 100G interface modules· 2-35
LSXM1CGQ36HBR1· 2-35
LSXM1CGQ36HFR1· 2-36
LSXM1CGQ18QGHBR1· 2-38
LSXM1CGQ18QGHFR1· 2-39
LSXM1CGQ6QGHFR1· 2-41
Type H 10G interface modules· 2-42
LSXM1TGS48HBR1· 2-42
LSXM1TGS48HFR1· 2-43
Interface modules available for the LSXM1MOD24KBR1 flexible line processing platform module· 2-44
LSXM1CGQ18C1· 2-45
LSXM1CGQ8C1· 2-46
LSXM1TGS24C1· 2-48
Type K fabric modules· 2-49
LSXM1SFK16ER1· 2-49
LSXM1SFK16GR1· 2-50
LSXM1SFK08ER1· 2-51
LSXM1SFK08GR1· 2-52
LSXM1SFK04FR1· 2-53
Type H fabric modules· 2-54
LSXM2SFH16CR1· 2-54
LSXM1SFH16ER1· 2-55
LSXM1SFH08CR1· 2-56
LSXM1SFH08DR1· 2-57
LSXM1SFH04DR1· 2-58
Fabric module filler panels· 2-59
Slide rails· 2-59
LSXM1BSR· 2-59
LSTM2KSGD0· 2-60
LSVM1BSR10· 2-61
3 Power supplies· 3-1
PSR2400-54A· 3-2
View· 3-2
Technical specifications· 3-2
LEDs· 3-3
PSR2400-54D·· 3-4
View· 3-4
Technical specifications· 3-4
LEDs· 3-5
PSR3000-54A· 3-6
View· 3-6
Technical specifications· 3-6
LEDs· 3-7
PSR3000-54AHD·· 3-8
View· 3-8
Technical specifications· 3-8
LEDs· 3-9
PSR2400-54AA-B· 3-10
View· 3-10
Technical specifications· 3-10
LEDs· 3-11
PSR1800-56A· 3-12
View· 3-12
Technical specifications· 3-12
LEDs· 3-13
PSR1800-56D·· 3-14
View· 3-14
Technical specifications· 3-14
LEDs· 3-15
4 Fan trays· 4-1
LSXM116XFANH (high performance) 4-2
View· 4-2
Technical specifications· 4-2
LEDs· 4-4
LSXM116XFAN· 4-5
View· 4-5
Technical specifications· 4-5
LEDs· 4-7
LSXM108XFANH (high performance) 4-8
View· 4-8
Technical specifications· 4-9
LEDs· 4-10
LSXM108XFAN· 4-11
View· 4-11
Technical specifications· 4-11
LEDs· 4-13
LSXM104XFANH (high performance) 4-14
View· 4-14
Technical specifications· 4-15
LEDs· 4-15
LSXM104XFAN· 4-17
View· 4-17
Technical specifications· 4-17
LEDs· 4-18
FAN-120-1-A· 4-20
View· 4-20
Technical specifications· 4-20
LEDs· 4-21
5 Cables· 5-1
DC power cord· 5-1
AC power cord· 5-2
Console cable· 5-2
Connecting a DB9-to-RJ45 console cable· 5-3
Connecting a USB-to-RJ45 console cable· 5-4
Ethernet twisted pair cable· 5-6
Introduction· 5-6
Application scenarios· 5-6
Maximum transmission distance· 5-6
RJ-45 connector 5-6
Cable pinouts· 5-6
Cable type· 5-7
Pin assignments· 5-8
Making an Ethernet twisted pair cable· 5-9
Optical fiber 5-9
Introduction· 5-10
Precautions· 5-11
SFP+/SFP28 copper cable· 5-11
SFP+ AOC/SFP28 AOC cable· 5-12
QSFP+ copper cable· 5-12
QSFP28 copper cable· 5-13
QSFP+ AOC/QSFP28 AOC cable· 5-13
QSFP-DD copper cable· 5-13
QSFP+ to SFP+/QSFP28 to SFP28 copper cable· 5-14
6 Ordering information· 6-1
1 Chassis
H3C S12500R Ethernet Switch Router Series is a new generation of rack switch routers designed for data center core networks. It optimizes the CLOS switching fabric architecture and uses the variable cell-based traffic scheduling and control forwarding mechanism to deliver higher forwarding efficiency, more refined congestion control, and hierarchical scheduling.
Unless otherwise stated, supervisor engine units (SEUs), interface modules, and fabric modules are collectively referred to as "modules" in this document.
Chassis views
The chassis views in this section are for illustration only.
H3C S12500R switch router series includes the S12516R, S12508R, S12504R, S12500R-2XL, and S12500R-2L models.
Figure1-1 S12516R
Figure1-2 S12508R
Figure1-3 S12504R
Figure1-4 S12500R-2XL
Figure1-5 S12500R-2L
Chassis components
The device has the following sections: interface module section, power supply section, fan tray section, fabric module section, and SEU section. The S12500R-2XL and S12500R-2L switch routers do not have a fabric module section. The following figures use the S12500R-2L and S12516R switch routers for illustration.
Figure1-6 Front and rear views of the S12500R-2L switch router
(1) SEU section
(2) Interface module section
(3) Power supply section
(4) Fan tray section
Table1-1 Section descriptions for the S12500R-2L switch router
Section
Location identification
SEU section
The SEU slot number and SEU module identifier are pink marked.
SEUs are required. (No SEUs are provided with the device. Purchase SEUs yourself.)
·     The device has two SEU slots. You can install one SEU, or two SEUs for redundancy on the device.
·     To install only one SEU on the device, you can install it in either of the SEU slots.
The ejector lever pillow blocks on the interface module slots are purple marked. The interface module edges and ejector levers are also purple marked to suggest the corresponding installation location.
Interface modules are required. (No interface modules are provided with the device. Purchase interface modules yourself.)
·     The device has two interface module slots. You can install one or two interface modules for the device as needed.
·     To install only one interface module for the device, you can install it in either of the interface module slots.
N/A
Power supplies are required. (No power supplies are provided with the device. Purchase power supplies yourself.)
·     The device has four power supply slots, with two on each side of the chassis rear.
·     The device supports N+N (dual power inputs) or N+1 (single power input) power supply redundancy. Determine the number of power supplies based on the power supply mode and system power consumption.
·     You can install a power supply in any of the empty power supply slots.
Fan tray section
The fan tray section is at the rear of the chassis.
Fan trays are required. (No fan trays are provided with the device. Purchase fan trays yourself.)
The S12500R-2L provides two fan tray slots FAN1 and FAN2. As a best practice, install two fan trays for redundancy.
For the S12500R-2XL, fan trays are provided with the device.
Figure1-7 Front and rear views of the S12516R switch router
(1) SEU section
(5) Fabric module section
Table1-2 Section descriptions for the S12516R switch router
Section
SEU section
·     S12516R and S12508R—Ejector levers of the SEUs and ejector lever pillow blocks on the SEU slots are pink marked. The SEU slots are above the interface module slots.
·     S12504RThe SEU slot numbers and SEU module identifiers are pink marked. The SEU slots are below the interface module slots.
·     The S12500R switch router has two SEU slots. You can install one SEU, or two SEUs for redundancy on the device.
The ejector lever pillow blocks on interface module slots are purple marked. The interface module edges and ejector levers are also purple marked to suggest the corresponding installation location.
·     S12516R—16 interface module slots.
·     S12508R—8 interface module slots.
·     S12504R—4 interface module slots.
You can install an interface module in any of the empty interface module slots.
N/A
·     S12516R—16 power supplies slots, with eight on each side of the chassis rear.
·     S12508R—8 power supplies slots, with four on each side of the chassis rear.
·     S12504R4 power supplies slots, with two on each side of the chassis rear.
Fan tray section
The fan tray section is at the rear of the chassis. Each fan tray covers three fabric module slots.
The device provides two fan tray slots FAN1 and FAN2. It can operate correctly with one fan tray. As a best practice, install two fan trays for redundancy.
The device installed with only one fan tray can still operate correctly for a short time if the fan tray fails. As a best practice, replace the faulty fan tray as soon as possible.
Covered by the fan trays.
Fabric modules are required. (No fabric modules or fabric module filler panels are provided with the device. Purchase fabric modules and fabric module filler panels yourself.)
·     The device comes with the fabric module slots empty. Install two to six fabric modules on the device for N+M redundancy. Install fabric module filler panels in empty fabric module slots.
·     Each fan tray covers three fabric module slots. To replace a fabric module, remove the fan tray above it.
Table1-3 describes the slot arrangement for removable components.
Table1-3 Slot arrangement for removable components
Model
SEU
Interface module
Fabric module
Power supply
Fan tray
S12516R
Slots 0 and 1
Slots 2 to 17
Slots 18 to 23
·     Slots 18 to 20 are covered by FAN 1.
·     Slots 21 to 23 are covered by FAN 2.
PWR 1 to PWR 16
FAN 1 and FAN 2
S12508R
Slots 0 and 1
Slots 2 to 9
Slots 10 to 15
·     Slots 10 to 12 are covered by FAN 1.
·     Slots 13 to 15 are covered by FAN 2.
PWR 1 to PWR 8
FAN 1 and FAN 2
S12504R
Slots 4 and 5
Slots 0 to 3
Slots 6 to 11
·     Slots 6 to 8 are covered by FAN 1.
·     Slots 9 to 11 are covered by FAN 2.
PWR 1 to PWR 4
FAN 1 and FAN 2
S12500R-2XL
Slots 2 and 3
Slots 0 and 1
N/A
PWR 1 to PWR 4
FAN 1 and FAN 2
S12500R-2L
Slots 0 and 1
Slots 2 and 3
N/A
PWR 1 to PWR 4
FAN 1 and FAN 2
The device uses modular design. Its weight includes the chassis (including mounting brackets and filler panels) and its removable components (including modules, power supplies, fan trays, interface modules, and other removable components).
Table1-4 Chassis weights and dimensions
Model
Weight
Height
Width
Depth
S12516R
86.1 kg (189.81 lb)
931 mm (36.65 in)/21 RU
440 mm (17.32 in)
857 mm (33.74 in)
S12508R
47.0 kg (103.62 lb)
531 mm (20.91 in)/12 RU
440 mm (17.32 in)
857 mm (33.74 in)
S12504R
36.0 kg (79.37 lb)
264 mm (10.39 in)/6 RU
440 mm (17.32 in)
857 mm (33.74 in)
S12500R-2L
22.6 kg (49.82 lb)
133 mm (5.24 in)/3 RU
440 mm (17.32 in)
895 mm (35.24 in)
S12500R-2XL
46.8 kg (103.17 lb)
440 mm (17.32 in)
857 mm (33.74 in)
·     Rack height is measured in RUs. One RU is 44.45 mm (1.75 in).
·     Table1-4 lists dimensions for the device, excluding the mounting brackets, cable management brackets, modules, and power supplies.
Table1-5 Module weights and dimensions
Model
Weight
Height
Width
Depth
LSXM1SUPER1
6.2 kg (13.67 lb)
43.7 mm (1.72 in)
432.6 mm (17.03 in)
511.7 mm (20.15 in)
LSXM1SUPEAR1
6.4 kg (14.11 lb)
43.7 mm (1.72 in)
432.6 mm (17.03 in)
511.7 mm (20.15 in)
LSXM1SUP02LR1
2.1 kg (4.63 lb)
22.5 mm (0.89 in)
193.0 mm (7.60 in)
364.3 mm (14.34 in)
LSXM1SUP02TR1
2.1 kg (4.63 lb)
22.5 mm (0.89 in)
193.0 mm (7.60 in)
364.3 mm (14.34 in)
LSXM1SUP04TR1
2.7 kg (5.95 lb)
39.8 mm (1.57 in)
200.5 mm (7.89 in)
411.0 mm (16.18 in)
LSXM2SUP02LR1
2.1 kg (4.63 lb)
22.5 mm (0.89 in)
193.0 mm (7.60 in)
364.3 mm (14.34 in)
LSXM2SFH16CR1
7.9 kg (17.42 lb)
39.8 mm (1.57 in)
853.0 mm (33.58 in)
278.4 mm (10.96 in)
LSXM1SFH16ER1
9.7 kg (21.38 lb)
39.8 mm (1.57 in)
853.0 mm (33.58 in)
278.4 mm (10.96 in)
LSXM1SFH08CR1
4.6 kg (10.14 lb)
39.8 mm (1.57 in)
453.0 mm (17.83 in)
278.4 mm (10.96 in)
LSXM1SFH08DR1
4.9 kg (10.80 lb)
39.8 mm (1.57 in)
453.0 mm (17.83 in)
278.4 mm (10.96 in)
LSXM1SFH04DR1
2.8 kg (6.17 lb)
39.8 mm (1.57 in)
243.0 mm (9.57 in)
278.4 mm (10.96 in)
LSXM1SFK16ER1
10.0 kg (22.05 lb)
39.8 mm (1.57 in)
853.0 mm (33.58 in)
278.4 mm (10.96 in)
LSXM1SFK16GR1
11.3 kg (24.91 lb)
39.8 mm (1.57 in)
853.0 mm (33.58 in)
278.4 mm (10.96 in)
LSXM1SFK08ER1
4.8 kg (10.58 lb)
39.8 mm (1.57 in)
453.0 mm (17.83 in)
278.4 mm (10.96 in)
LSXM1SFK08GR1
5.9 kg (13.01 lb)
39.8 mm (1.57 in)
453.0 mm (17.83 in)
278.4 mm (10.96 in)
LSXM1SFK04FR1
3.0 kg (6.67 lb)
39.8 mm (1.57 in)
243.0 mm (9.57 in)
278.4 mm (10.96 in)
LSXM1CGQ48KB1
9.3 kg (20.50 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM2CGQ48KBR1
9.3 kg (20.50 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CDQ24KB1
10.0 kg (22.05 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CCQ48KBR1
10.5 kg (23.15 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CDQ24KBR1
10.0 kg (22.05 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CDQ18KCR1
9.0 kg (19.84 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGMS48KBR1
9.7 kg (21.38 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGQFX16KBR1
10.6 kg (23.37 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGQ36HBR1
11.1 kg (24.47 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGQ36HFR1
12.3 kg (27.12 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGQ48KBR1
9.3 kg (20.50 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGQ72KCR1
14.7 kg (32.41 lb)
100.8 mm (3.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1TGS48HFR1
7.6 kg (16.75 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGQ18QGHFR1
9.0 kg (19.84 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGQ6QGHFR1
7.3 kg (16.09 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1TGS48HBR1
7.5 kg (16.53 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1CGQ18QGHBR1
8.3 kg (18.30 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
LSXM1MOD24KBR1
7.4 kg (16.31 lb)
50.0 mm (1.97 in)
432.6 mm (17.03 in)
519.8 mm (20.46 in)
Module dimensions are expressed in Height (H) × Width (W) × Depth (D) format:
·     Height—Height of the front panel of the module.
·     Width—Width of the front panel of the module.
·     Depth—Depth from the front panel of the module to the connector (including the connector, but excluding the ejector levers and captive screws).
Table1-6 Weights and dimensions of the interface modules available for the LSXM1MOD24KBR1
Model
Weight
Height
Width
Depth
LSXM1CGQ18C1
1.78 kg (3.92 lb)
44.0 mm (1.73 in)
191.0 mm (7.52 in)
271.0 mm (10.67 in)
LSXM1CGQ8C1
1.50 kg (3.31 lb)
44.0 mm (1.73 in)
191.0 mm (7.52 in)
271.0 mm (10.67 in)
LSXM1TGS24C1
1.53 kg (3.37 lb)
44.0 mm (1.73 in)
191.0 mm (7.52 in)
271.0 mm (10.67 in)
Table1-7 Weights and dimensions of the fabric module slot filler panels
Model
Weight
Height
Width
Depth
S12516R fabric module slot filler panel
2.8 kg (6.17 lb)
39.8 mm (1.57 in)
853.6 mm (33.60 in)
136.0 mm (5.35 in)
S12508R fabric module slot filler panel
1.6 kg (3.53 lb)
40.0 mm (1.57 in)
453.0 mm (17.83 in)
133.0 mm (5.24 in)
S12504R fabric module slot filler panel
0.9 kg (1.98 lb)
40.0 mm (1.57 in)
243.0 mm (9.57 in)
136.0 mm (5.35 in)
Table1-8 Weights and dimensions of power supplies
Model
Weight
Height
Width
Depth
PSR1800-56A
1.6 kg (3.53 lb)
40.1 mm (1.58 in)
82.6 mm (3.25 in)
297.7 mm (11.72 in)
PSR1800-56D
2.0 kg (4.41 lb)
40.1 mm (1.58 in)
82.6 mm (3.25 in)
297.7 mm (11.72 in)
PSR2400-54A
1.9 kg (4.19 lb)
41.0 mm (1.61 in)
100.0 mm (3.93 in)
332.0 mm (13.07 in)
PSR2400-54D
1.9 kg (4.19 lb)
41.0 mm (1.61 in)
100.0 mm (3.93 in)
332.0 mm (13.07 in)
PSR3000-54A
2.1 kg (4.63 lb)
41.0 mm (1.61 in)
100.0 mm (3.93 in)
332.0 mm (13.07 in)
PSR3000-54AHD
2.1 kg (4.63 lb)
41.0 mm (1.61 in)
100.0 mm (3.93 in)
332.0 mm (13.07 in)
PSR2400-54AA-B
2.0 kg (4.41 lb)
41.0 mm (1.61 in)
100.0 mm (3.93 in)
332.0 mm (13.07 in)
Table1-9 Weights and dimensions of fan trays
Model
Weight
Height
Width
Depth
S12516R fan tray—LSXM116XFAN
6.7 kg (14.77 lb)
144.0 mm (5.67 in)
927.0 mm (36.50 in)
183.0 mm (7.20 in)
S12516R fan tray —LSXM116XFANH
8.4 kg (18.52 lb)
144.0 mm (5.67 in)
927.0 mm (36.50 in)
183.0 mm (7.20 in)
S12508R fan tray—LSXM108XFAN
3.8 kg (8.38 lb)
144.0 mm (5.67 in)
527.0 mm (20.75 in)
183.0 mm (7.20 in)
S12508R fan tray—LSXM108XFANH
4.4 kg (9.70 lb)
144.0 mm (5.67 in)
527.0 mm (20.75 in)
183.0 mm (7.20 in)
S12504R fan tray—LSXM104XFAN
1.8 kg (3.97 lb)
144.0 mm (5.67 in)
263.0 mm (10.35 in)
97.0 mm (3.82 in)
S12504R fan tray—LSXM104XFANH
3.0 kg (6.61 lb)
144.0 mm (5.67 in)
263.0 mm (10.35 in)
136.0 mm (5.35 in)
S12500R-2XL fan tray—LSXM104XFANH
3.0 kg (6.61 lb)
144.0 mm (5.67 in)
263.0 mm (10.35 in)
136.0 mm (5.35 in)
S12500R-2L fan tray—FAN-120-1-A
1.6 kg (3.53 lb)
123.0 mm (4.84 in)
214.0 mm (8.43 in)
123.0 mm (4.84 in)
The device supports varieties of modules that are different in power consumptions. For a module, its power consumption varies by its state. Table1-10 shows the power consumption for different module models.
·     The static power consumption of a module refers to the power consumed by the module when module is running but all ports on the module are down and when no transceiver module is available on the optical interface of the module.
·     The dynamic power consumption of a module refers to the power consumed by the module when all the ports on the module are link up and send broadcasts.
Table1-10 Module power consumption
Model
Minimum static power consumption
Typical power consumption
Maximum dynamic power consumption
LSXM1SUPER1
52 W
52 W
70 W
LSXM1SUPEAR1
55 W
55 W
65 W
LSXM1SUP02LR1
28 W
28 W
35 W
LSXM1SUP02TR1
26 W
26 W
29 W
LSXM1SUP04TR1
24 W
24 W
35 W
LSXM2SUP02LR1
28 W
28 W
35 W
LSXM2SFH16CR1
194 W
281 W
308 W
LSXM1SFH16ER1
487 W
752 W
816 W
LSXM1SFH08CR1
84 W
117 W
135 W
LSXM1SFH08DR1
159 W
231 W
255 W
LSXM1SFH04DR1
86 W
124 W
140 W
LSXM1SFK16ER1
159 W
226 W
293 W
LSXM1SFK16GR1
471 W
647 W
822 W
LSXM1SFK08ER1
90 W
146 W
157 W
LSXM1SFK08GR1
206 W
277 W
366 W
LSXM1SFK04FR1
91 W
147 W
158 W
LSXM1CGQ48KB1
395 W
447 W
765 W
LSXM2CGQ48KBR1
395 W
447 W
765 W
LSXM1CDQ24KB1
469 W
696 W
1020 W
LSXM1CCQ48KBR1
412 W
564 W
1142 W
LSXM1CDQ24KBR1
469 W
696 W
1020 W
LSXM1CDQ18KCR1
195 W
380 W
850 W
LSXM1CGMS48KBR1
525 W
675 W
1040 W
LSXM1CGQFX16KBR1
330 W
385 W
485 W
LSXM1CGQ36HBR1 (*)
608 W
662 W
1070 W
LSXM1CGQ36HFR1 (*)
585 W
819 W
1100 W
LSXM1CGQ48KBR1
395 W
447 W
765 W
LSXM1CGQ72KCR1
530 W
635 W
980 W
LSXM1TGS48HFR1
136 W
161 W
230 W
LSXM1CGQ18QGHFR1
316 W
425 W
650 W
LSXM1CGQ6QGHFR1
132 W
171 W
325 W
LSXM1TGS48HBR1
111 W
127 W
210 W
LSXM1CGQ18QGHBR1
256 W
326 W
525 W
LSXM1MOD24KBR1
135 W
350 W
577 W
IMPORTANT
IMPORTANT:
High-performance fan trays are required when the device uses the interface modules marked by (*) in the preceding table. For information about high-performance fan trays, see "Fan trays."
Power consumption of interface modules available for the LSXM1MOD24KBR1
Table1-11 Power consumption of interface modules available for the LSXM1MOD24KBR1
Interface module model
Minimum power consumption
Maximum power consumption
LSXM1CGQ18C1
90 W
101 W
169 W
LSXM1CGQ8C1
38 W
49 W
79 W
LSXM1TGS24C1
33 W
35 W
63 W
Fan tray power consumption
The device uses fan trays that can automatically adjust the fan speed based on the device temperature. The power consumed by a fan tray depends on the fan speed.
Table1-12 Fan tray power consumption
Device model
Fan tray model
S12516R
LSXM116XFAN
33 W
206 W
793 W
LSXM116XFANH
59 W
725 W
2030 W
S12508R
LSXM108XFAN
17 W
103 W
395 W
LSXM108XFANH
35 W
410 W
1000 W
S12504R
LSXM104XFAN
14 W
66 W
255 W
S12504R
LSXM104XFANH
19.4 W
87 W
588 W
S12500R-2XL
LSXM104XFANH
19.4 W
87 W
588 W
S12500R-2L
FAN-120-1-A
17 W
31 W
269 W
System power consumption
The system power consumption of the device depends on the type and number of modules and the fan tray power consumption.
·     The minimum system power consumption is the total static power consumption of all modules plus the minimum fan tray power consumption.
·     The maximum system power consumption is the total dynamic power consumption of all modules plus the maximum fan tray power consumption.
For example, for an S12516R switch router that has two LSXM1SUPKR1 SEUs, two LSXM1CGQ48KBR1 interface modules, six LSXM1SFK16GR1 fabric modules, and five LSXM116XFANH fan trays, the minimum system power consumption of the device is 2 × 50 + 2 × 395 + 6 × 471 + 5 × 33 = 3881 W. The maximum system power consumption of the device is 2 × 60 + 2 × 765 + 6 × 822 + 5 × 793 = 10547 W.
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121 BTU/h.
The heat generated by the device is closely related to its power consumption. It is typically assumed that 90% of the power consumption is converted to heat, and the power supply's conversion efficiency is 90%. Heat dissipation/hour of the device is 0.9 × (total power consumption of the modules plus power consumption of the fan trays)/0.9 × 3.4121.
For the power consumption of the modules and fan trays, see "Module power consumption and system power consumption."
Table1-13 Environmental specifications
Operating
Non-operating
Temperature
0°C to 40°C (32°F to 104°F)
–40°C to +70°C (–40°F to +158°F)
Relative humidity
5% to 95%, noncondensing
2 Modules
IMPORTANT
IMPORTANT:
·     You cannot use the speed command to change the speed of a split interface on a module.
·     You can only use QSFP+ to SFP+ cables for 10GE interfaces split from a 100GE interface.
For the transceiver modules or cables available for modules, see H3C S12500R Switch Router Series Modules and Transceiver Modules Compatibility Matrixes
·     The minimum power consumption of a module refers to the power consumed by the module when it is running with all its ports down and its fiber ports not installed with transceiver modules.
·     The typical power consumption of a module refers to the power consumed by the module when it is running with 50% of its ports connected and at 50% load.
·     The maximum power consumption of a module refers to the power consumed by the module when it is running with all its ports connected and at full load.
Naming conventions
Figure2-1 SEU naming conventions
Table2-1 SEU naming conventions
No.
1
Product line. LS represents the switch router product line.
2
Product series, which is fixed at X.
3
Distinguisher.
4
Module type.
5
SEU type.
6
Extended attribute.
Figure2-2 Interface module naming conventions
Table2-2 Interface module naming conventions
No.
1
2
3
Distinguisher.
4
Main interface type.
5
Number of main interfaces.
6
Interface module type.
7
Extended attribute.
Figure2-3 Fabric module naming conventions
Table2-3 Fabric module naming conventions
No.
1
2
3
Distinguisher.
4
Module type. SF represents the fabric module.
5
Fabric module type. Values include:
·     K—Type K fabric module.
·     H—Type H fabric module.
6
Compatible device model:
·     16 represents that the fabric module is compatible with the S12516R.
·     08 represents that the fabric module is compatible with the S12508R.
·     04 represents that the fabric module is compatible with the S12504R.
7
Fabric module class.
8
Extended attribute.
Table2-4 Module compatibility matrix
Device model
SEU
Fabric module
Interface module
S12516R
·     LSXM1SUPER1
·     LSXM1SUPEAR1
·     LSXM2SFH16CR1
·     LSXM1SFH16ER1
·     LSXM1SFK16ER1
·     LSXM1SFK16GR1
Type H interface modules (LSXM1TGS48HFR1 for example) and Type K interface modules (LSXM1CGQ48KBR1 for example)
S12508R
·     LSXM1SFH08CR1
·     LSXM1SFH08DR1
·     LSXM1SFK08ER1
·     LSXM1SFK08GR1
S12504R
LSXM1SUP04TR1
·     LSXM1SFH04DR1
·     LSXM1SFK04FR1
S12500R-2L
·     LSXM1SUP02LR1
·     LSXM1SUP02TR1
·     LSXM2SUP02LR1
N/A
Type K interface modules, excluding the LSXM1CDQ24KBR1, LSXM1CCQ48KBR1, and LSXM1CDQ18KCR1
S12500R-2XL
LSXM1SUP04TR1
N/A
·     LSXM1CGQ72KCR1
·     LSXM1CDQ18KCR1
To verify compatibility of modules with the software release you are using, see the release notes.
For the transceiver modules or cables available for modules, see H3C S12500R Switch Router Series Modules and Transceiver Modules Compatibility Matrixe.
SEUs
SEUs are the core component of the system control plane. You can install one SEU, or two SEUs for redundancy on the device. Do not install SEUs of different models on the same device.
You can access and configure the device through the serial console port or the mini USB console port. Only one port is active at a time.
To connect a USB device to the module, make sure the USB device is in good condition.
Set the same speed and duplex mode for a management Ethernet port and its peer port.
If multiple management ports are connected to one remote switch router, you must assign their peer ports to different VLANs on the remote switch router. Then, you can transfer startup software images to the flash on the device through TFTP or FTP.
Interface modules
To obtain the fabric module models on an operating device, execute the display device command.
The LSXM1MOD24KBR1 flexible line processing platform module supports various interface modules. For more information, see "Interface modules available for the LSXM1MOD24KBR1 flexible line processing platform module."
Fabric modules
Before you install a fabric module, remove the protection box from it.
The fabric module slots are covered by fan trays. You must install the fabric modules before you install the fan trays. To remove a fabric module, first remove the fan tray that covers it.
Before you install a fabric module, press the buttons on the ejector levers to release them. After the fabric module is fully seated into slot, close the ejector levers. Before you remove a fabric module, press the buttons on the ejector levers to release them, open the ejector levers, and then pull the fabric module out of the slot.
Before you install a fabric module, make sure the air baffle is closed. After you remove a fabric module, close the air baffle.
Do not install fabric modules of different models on the same device.
SEUs
LSXM1SUPER1
View
Figure2-4 LSXM1SUPER1 view
Table2-5 Technical specifications
Item
Specification
Processor
Intel processor (quad-core) @ 2.2 GHz
DDR
32 GB DDR4 (two DIMM slots)
Flash
4 GB EMMC
NVRAM
512 KB
SSD
240 GB (SATA)
Power consumption
52 W to 70 W
Connector type
·     RJ-45
·     LC
·     USB (Type A)
·     Mini USB (Type AB)
Port
·     1 × RJ-45 console port
·     1 × mini USB console port
·     2 × 10/100/1000BASE-T management and upgrade ports
·     2 × GE SFP management and upgrade ports
·     1 × USB port (USB 3.0, host port)
·     2 × 1PPS/TOD time synchronization ports
·     2 × SMB clock input ports
·     2 × SMB clock output ports
Transmission baud rate
·     Console port: ≤ 115200 bps. The default value is 9600 bps.
·     10/100/1000BASE-T port: 10/100/1000 Mbps
·     SFP port: 1000 Mbps
Transmission medium and max transmission distance of the console port
Common asynchronous serial interface cable, with a maximum transmission distance of 15 m (49.21 ft)
Transmission medium and max transmission distance of the 10/100/1000BASE-T port
Category-5 twisted pair cable, with a transmission distance of 100 m (328.08 ft)
Hot swapping
Supported
Compliant standard
·     Serial console port: Duplex Universal Asynchronous Receiver/Transmitter (duplex UART)
·     Mini USB console port: Universal Asynchronous Receiver/Transmitter (UART)
·     10/100/1000BASE-T management port: IEEE802.3ab
·     SFP management port: IEEE802.3z
·     USB: IEEE802.3ba
Compatible device models
·     S12516R
·     S12508R
Ports and LEDs
Figure2-5 LSXM1SUPER1 front panel
(1) 10/100/1000BASE-T management Ethernet port LED (LINK)
(2) 10/100/1000BASE-T management Ethernet port  LED (ACT)
(3) SEU active/standby status LED (ACT)
(4) Power supply status LED (PWR)
(5) Fan tray status LED (FAN)
(6) SFP management Ethernet port LED (LINK/ACT)
(7) Module status LED (SLOT)
Table2-6 LED description
LED
LED status
LINK: Off
ACT: Off
No link is present on the port.
LINK: Steady green
ACT: Off
A 1000 Mbps link is present on the port.
LINK: Steady orange
ACT: Off
A 10/100 Mbps link is present on the port.
LINK: Steady green
ACT: Flashing yellow
The port is receiving or sending data at 1000 Mbps.
LINK: Steady orange
The port is receiving or sending data at 10/100 Mbps.
Flashing
The port is receiving or sending data.
On
A link is present on the port.
Off
Fan tray status LED
Steady green
All fan trays are present and operating correctly.
Steady red
A fan tray is faulty, or no or only one fan tray is operating correctly.
Off
The device is not powered on.
Steady green
All present power supplies are operating correctly.
Steady red
One or more power supplies are faulty.
Off
Module status LED
Flashing green (once every two seconds)
The module in the corresponding slot is operating correctly.
Flashing green (four times per second)
The module in the corresponding slot is loading software.
If the module remains in this state, the software version running on the device is incompatible with the module.
Steady green
The module in the corresponding slot is starting up.
Steady red
A high severity alarm has occurred on the module in the corresponding slot or the module in the corresponding slot has failed.
Flashing red (once every four seconds)
The temperature of the module in the corresponding slot is abnormal. The temperature is higher than the upper temperature threshold or lower than the lower temperature threshold.
Off
The module is not present or the module is faulty.
On
The SEU is in active state.
Off
The following are the possible causes:
·     The SEU is in standby state.
·     The SEU is faulty. To further determine the SEU status, see the module status LED description.
LSXM1SUPEAR1
View
Figure2-6 LSXM1SUPEAR1 view
Table2-7 Technical specifications
Item
Specification
Processor
DDR
Flash
4 GB EMMC
NVRAM
512 KB
Power consumption
54 W to 64 W
Connector type
·     RJ-45
·     LC
·     USB (Type A)
Port
Hot swapping
Supported
Compliant standard
·     Serial console port: Duplex Console port: Duplex Universal Asynchronous Receiver/Transmitter (duplex UART)
·     Management 10/100/1000BASE-T port: IEEE802.3ab
·     USB: IEEE802.3ba
·     S12516R
·     S12508R
Ports and LEDs
Figure2-7 LSXM1SUPEAR1 front panel
(1) Module status LED (SLOT)
(2) SFP management Ethernet port LED (LINK/ACT)
(3) SFP management Ethernet port LED (LINK/ACT)
(4) 10/100/1000BASE-T management Ethernet port  LED (LINK)
(5) 10/100/1000BASE-T management Ethernet port LED (ACT)
(6) Fan tray status LED (FAN)
(7) Power supply status LED (PWR)
(8) SEU active/standby status LED (ACT)
Table2-8 LED description
LED
LED status
LINK: Off
ACT: Off
LINK: Steady green
ACT: Off
LINK: Steady orange
ACT: Off
LINK: Steady green
LINK: Steady orange
Flashing
On
Off
Fan tray status LED
Steady green
Steady red
Off
Steady green
Steady red
Off
Module status LED
Steady green
Steady red
Off
On
Off
LSXM1SUP04TR1
View
Figure2-8 LSXM1SUP04TR1 view
Table2-9 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM (two DIMM slots)
Flash
8 GB EMMC
NVRAM
512 KB
Power consumption
24 W to 35 W
Connector type
·     RJ-45
·     LC
·     USB (Type A)
Port
·     1 × console port
·     1 × 10/100/1000BASE-T management and upgrade port
·     1 × GE SFP management and upgrade port
·     1 × USB port (USB 2.0, host port)
Hot swapping
Supported
Compliant standard
·     SFP management port LED: IEEE802.3z
·     USB: IEEE802.3ba
S12504R
Ports and LEDs
Figure2-9 LSXM1SUP04TR1 front panel
(1) Power supply status LED (PWR)
(2) SEU active/standby status LED (ACTIVE)
(3) Module status LED (SLOT)
(4) Fan tray status LED (FAN)
Table2-10 LED description
LED
LED status
Management Ethernet port LED
Flashing
On
Off
Fan tray status LED
Steady green
Steady red
Off
Steady green
Steady red
Off
Module status LED
Steady green
Steady red
Off
On
Off
LSXM1SUP02LR1
View
Figure2-10 LSXM1SUP02LR1 view
Table2-11 Technical specifications
Item
Specification
Processor
SDRAM
One 16 GB DDR4 SDRAM (two DIMM slots)
Flash
8 GB EMMC
NVRAM
512 KB
Power consumption
28 W to 35 W
Connector type
·     RJ-45
·     LC
·     USB (Type A)
Port
·     1 × console port
Hot swapping
Supported
Compliant standard
·     USB: IEEE802.3ba
S12500R-2L
Ports and LEDs
Figure2-11 LSXM1SUP02LR1 front panel
(2) Module status LED (SLOT)
(3) SEU active/standby status LED (ACTIVE)
(5) SFP management Ethernet port LED
Table2-12 LED description
LED
LED status
Flashing
On
Off
Fan tray status LED
Steady green
Steady red
Off
Steady green
Steady red
Off
Module status LED
Steady green
Steady red
Off
On
Off
LSXM1SUP02TR1
View
Figure2-12 LSXM1SUP02TR1 view
Table2-13 Technical specifications
Item
Specification
Processor
SDRAM
Flash
8 GB EMMC
NVRAM
512 KB
Power consumption
28 W to 35 W
Connector type
·     RJ-45
·     LC
·     USB (Type A)
·     Coaxial RF connector
Port
·     1 × console port
·     1 × SMB clock input port
·     1 × SMB clock output port
·     1 × 1PPS/TOD time synchronization port
Hot swapping
Supported
Compliant standard
·     USB: IEEE802.3ba
S12500R-2L
Ports and LEDs
Figure2-13 LSXM1SUP02TR1 front panel
(1) Fan tray status LED (FAN)
(2) Power supply status LED (PWR)
(4) SEU active/standby status LED (ACTIVE)
(6) 10/100/1000BASE-T management Ethernet port LED
Table2-14 LED description
LED
LED status
Flashing
On
Off
Fan tray status LED
Steady green
Steady red
Off
Steady green
Steady red
Off
Module status LED
Steady green
Steady red
Off
On
Off
LSXM2SUP02LR1
View
Figure2-14 LSXM2SUP02LR1 view
Table2-15 Technical specification
Item
Specification
Processor
SDRAM
32 GB DDR4 SDRAM
Flash
8 GB EMMC
NVRAM
512 KB
Power consumption
28 W to 35 W
Connector type
·     RJ-45
·     LC
·     USB (Type A)
Port
·     1 × console port
S12500R-2L
Ports and LEDs
Figure2-15 LSXM2SUP02LR1 front panel
Table2-16 LED description
LED
LED status
Flashing
On
Off
Fan tray status LED
Steady green
Steady red
Off
Steady green
Steady red
Off
Module status LED
Steady green
Steady red
Off
On
Off
LSXM1CDQ24KB1
View
Figure2-16 LSXM1CDQ24KB1 view
Table2-17 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
469 W to 1020 W
Port
24 × 400G QSFP-DD ports
400 Gbps
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
Compatible fabric modules
Ports and LEDs
Figure2-17 LSXM1CDQ24KB1 front panel
(1) 400G QSFP-DD port
(2) 400G QSFP-DD port LED
Table2-18 LED description
LED
LED status
QSFP-DD fiber port LED
Flashing
The QSFP-DD port is sending or receiving data.
On
A link is present on the QSFP-DD port.
Off
No link is present on the QSFP-DD port.
LSXM1CDQ24KBR1
View
Figure2-18 LSXM1CDQ24KBR1 view
Table2-19 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
469 W to 1020 W
Port
400 Gbps
·     S12516R
·     S12508R
·     S12504R
Ports and LEDs
Figure2-19 LSXM1CDQ24KBR1 front panel
Table2-20 LED description
LED
LED status
Flashing
On
Off
LSXM1CDQ18KCR1
View
Figure2-20 LSXM1CDQ18KCR1 view
Table2-21 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
195 W to 850 W
Port
18 × 400G QSFP-DD ports
400 Gbps
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2XL
Ports and LEDs
Figure2-21 LSXM1CDQ18KCR1 front panel
Table2-22 LED description
LED
LED status
Flashing
On
Off
LSXM1CCQ48KBR1
View
Figure2-22 LSXM1CCQ48KBR1 view
Table2-23 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
412 W to 1142 W
Port
48 × 200G QSFP56 ports
200 Gbps
·     S12516R
·     S12508R
·     S12504R
Ports and LEDs
Figure2-23 LSXM1CCQ48KBR1 front panel
(1) 200G QSFP56 port
(2) 200G QSFP56 port LED
Table2-24 LED description
LED
LED status
QSFP56 fiber port LED
Flashing
The QSFP56 port is sending or receiving data.
On
A link is present on the QSFP56 port.
Off
No link is present on the QSFP56 port.
LSXM1CGQ72KCR1
View
Figure2-24 LSXM1CGQ72KCR1 view
Table2-25 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
335 W to 865 W
Port
Three kinds of interface modes:
·     72 ×100G QSFP28 ports
·     36 × 200G QSFP56 ports
·     18 × 200G QSFP56 fiber ports and 36 × 100G QSFP28 fiber ports
A QSFP56 fiber port acts as a QSFP28 fiber port when it operates at 100 Gbps.
·     QSFP28 port: 100 Gbps and 40 Gbps
·     QSFP56 port: 200 Gbps, 100 Gbps, and 40 Gbps
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
·     S12500R-2XL
Type K fabric modules (build-in design for S12500R-2L and S12500R-2XL)
Ports and LEDs
Figure2-25 LSXM1CGQ72KCR1 front panel
(1) 200G QSFP56 port LED
(2) 100G QSFP56 port
(3) 100G QSFP28 port
(4) 200G QSFP28 port LED
Table2-26 LED description
LED
LED status
QSFP28 fiber port LED
Flashing
The QSFP56 or QSFP28 port is sending or receiving data.
On
A link is present on the QSFP56 or QSFP28 port.
Off
No link is present on the QSFP56 or QSFP28 port.
LSXM1CGQ48KB1
View
Figure2-26 LSXM1CGQ48KB1 view
Table2-27 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
395 W to 765 W
Port
48 × 100G QSFP28 ports
100 Gbps
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
Ports and LEDs
Figure2-27 LSXM1CGQ48KB1 front panel
(1) 100G QSFP28 fiber port
(2) 100G QSFP28 fiber port LED
Table2-28 LED description
LED
LED status
QSFP28 port LED
Flashing
The QSFP28 port is sending or receiving data.
On
A link is present on the QSFP28 port.
Off
No link is present on the QSFP28 port.
LSXM2CGQ48KBR1
View
Figure2-28 LSXM2CGQ48KBR1 view
Table2-29 Technical specifications
Item
Specification
Processor
SDRAM
32 GB DDR4 SDRAM
Power consumption
395 W to 765 W
Port
100 Gbps
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
Ports and LEDs
Figure2-29 LSXM2CGQ48KBR1 front panel
Table2-30 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
LSXM1CGMS48KBR1
View
Figure2-30 LSXM1CGMS48KBR1 view
Table2-31 Technical specifications
Item
Specification
Processor
x86 (quad-core) @ 2.2 GHz
SDRAM
16 GB DDR4 SDRAM
Power consumption
525 W to 1039 W
Port
48 × 100G QSFP28 ports (support MACsec)
100 Gbps
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
Ports and LEDs
Figure2-31 LSXM1CGMS48KBR1 front panel
Table2-32 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
LSXM1CGQ48KBR1
View
Figure2-32 LSXM1CGQ48KBR1 view
Table2-33 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
395 W to 765 W
Port
100 Gbps
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
Ports and LEDs
Figure2-33 LSXM1CGQ48KBR1 front panel
(1) 100G QSFP28 fiber port LED
Table2-34 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
LSXM1CGQFX16KBR1
View
Figure2-34 LSXM1CGQFX16KBR1 view
Table2-35 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
332 W to 484 W
Port
16 × 100G QSFP28 ports (support FlexE)
100 Gbps and 40Gbps
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
Ports and LEDs
Figure2-35 LSXM1CGQFX16KBR1 front panel
Table2-36 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
LSXM1MOD24KBR1
View
Figure2-36 LSXM1MOD24KBR1 view
(1) Interface module slot 1 (installed with a subcard filler panel)
(2) Interface module slot 2 (installed with a subcard filler panel)
Table2-37 Technical specifications
Item
Specification
Processor
SDRAM
16 GB DDR4 SDRAM
Power consumption
135 W to 557 W
(The actual power consumption depends on the interface modules installed on the module.)
Slots
You can install two interface modules on the module. For the compatible interface modules, see "Interface modules available for the LSXM1MOD24KBR1 flexible line processing platform module."
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
LSXM1CGQ36HBR1
View
Figure2-37 LSXM1CGQ36HBR1 view
Table2-38 Technical specifications
Item
Specification
Processor
MIPS 64 (dual-core) @ 1.2 GHz
SDRAM
16 GB DDR3 SDRAM
Power consumption
608 W to 1070 W
Port
36 × QSFP28 ports
Hot swapping
Supported
·     S12516R (configured with high performance fan trays)
·     S12508R (configured with high performance fan trays)
·     S12504R (configured with high performance fan trays)
Ports and LEDs
Figure2-38 LSXM1CGQ36HBR1 front panel
Table2-39 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
LSXM1CGQ36HFR1
View
Figure2-39 LSXM1CGQ36HFR1 view
Table2-40 Technical specifications
Item
Specification
Processor
MIPS64 (dual-core) @ 1.2 GHz
SDRAM
16 GB DDR3 SDRAM
Power consumption
585 W to 1100 W
Port
36 × USB 2.0 ports
Hot swapping
Supported
Ports and LEDs
Figure2-40 LSXM1CGQ36HFR1 front panel
Table2-41 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
LSXM1CGQ18QGHBR1
View
Figure2-41 LSXM1CGQ18QGHBR1 view
Table2-42 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
256 W to 525 W
Port
18 × 100G QSFP28 ports and 18 × 40G QSFP+ ports
Or
36 × 40G QSFP+ ports
A QSFP28 port acts as a QSFP+ port when it operates at 40 Gbps.
Hot swapping
Supported
·     S12516R
·     S12508R
·     S12504R
Ports and LEDs
Figure2-42 LSXM1CGQ18QGHBR1 front panel
(3) 40G QSFP+ fiber port
(4) 40G QSFP+ fiber port LED
Table2-43 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
QSFP+ port LED
Flashing
The QSFP+ port is sending or receiving data.
On
A link is present on the QSFP+ port.
Off
No link is present on the QSFP+ port.
LSXM1CGQ18QGHFR1
View
Figure2-43 LSXM1CGQ18QGHFR1 view
Table2-44 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
316 W to 650 W
Port
18 × 100G QSFP 28 ports and 18 × 40G QSFP+ ports
Or
·     100G QSFP28 port: 100/40 Gbps
·     40G QSFP+ port: 40 Gbps
Hot swapping
Supported
·     S12516R
·     S12508R
·     S12504R
Ports and LEDs
Figure2-44 LSXM1CGQ18QGHFR1 front panel
Table2-45 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
QSFP+ port LED
Flashing
On
Off
LSXM1CGQ6QGHFR1
View
Figure2-45 LSXM1CGQ6QGHFR1 view
Table2-46 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
132 W to 325 W
Port
6 × 100G QSFP28 ports and 6 × 40G QSFP+ ports
Or
12 × 40G QSFP+ ports
·     100G QSFP28 ports: 100 Gbps and 40 Gbps
Hot swapping
Supported
·     S12516R
·     S12508R
·     S12504R
Ports and LEDs
Figure2-46 LSXM1CGQ6QGHFR1 front panel
(1) 40G QSFP+ fiber port
(2) 40G QSFP+ fiber port LED
(3) 100G QSFP28 fiber port
(4) 100G QSFP28 fiber port LED
Table2-47 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
QSFP+ port LED
Flashing
On
Off
LSXM1TGS48HBR1
View
Figure2-47 LSXM1TGS48HBR1 view
Table2-48 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
111 W to 210 W
Port
48 × 10G SFP+ ports
10 Gbps
Hot swapping
Supported
·     S12516R
·     S12508R
·     S12504R
Ports and LEDs
Figure2-48 LSXM1TGS48HBR1 front panel
(1) SFP+ fiber port
(2) SFP+ fiber port LED
Table2-49 LED description
LED status
Flashing
The SFP+ port is sending or receiving data.
On
A link is present on the SFP+ port.
Off
No link is present on the SFP+ port.
LSXM1TGS48HFR1
View
Figure2-49 LSXM1TGS48HFR1 view
Table2-50 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
136 W to 230 W
Port
48 × 10G SFP+ ports
10 Gbps
Hot swapping
Supported
·     S12516R
·     S12508R
·     S12504R
Ports and LEDs
Figure2-50 LSXM1TGS48HFR1 front panel
(1) SFP+ fiber port
Table2-51 LED description
LED status
Flashing
On
Off
Table2-52 Interface modules available for the LSXM1MOD24KBR1
Model
Port quantity and type
LSXM1CGQ18C1
18-port 100GBASE Ethernet optical interface module
18 × QSFP28 ports
LSXM1CGQ8C1
8 × QSFP28 ports
LSXM1TGS24C1
24-port 10GBASE Ethernet optical interface module
24 × SFP+ ports
LSXM1CGQ18C1
View
Figure2-51 LSXM1CGQ18C1 view
Table2-53 Technical specifications
Item
Specification
Port
18 × QSFP28 ports
Dimensions (H × W × D)
44.0 × 191.0 × 271.0 mm (1.73 × 7.52 × 10.67 in)
Weight
1.78 kg (3.92 lb)
Power consumption (static)
90 W
Power consumption (typical)
101 W
Power consumption (at full load)
169 W
Operating temperature
Operating relative humidity
5% RH to 95% RH, noncondensing
Ports and LEDs
Figure2-52 LSXM1CGQ18C1 front panel
Table2-54 LED descriptions
LED
LED status
QSFP+ port LED
Flashing
On
Off
LSXM1CGQ8C1
View
Figure2-53 LSXM1CGQ8C1 view
Table2-55 Technical specifications
Item
Specification
Port
8 × QSFP28 ports
Weight
1.50 kg (3.31 lb)
38 W
49 W
79 W
Ports and LEDs
Figure2-54 LSXM1CGQ8C1 front panel
Table2-56 LED description
LED
LED status
QSFP28 port LED
Flashing
On
Off
LSXM1TGS24C1
View
Figure2-55 LSXM1TGS24C1 view
Table2-57 Technical specifications
Item
Specification
Port
24 × SFP+ ports
Weight
1.53 kg (3.37 lb)
33 W
35 W
63 W
Ports and LEDs
Figure2-56 LSXM1TGS24C1 front panel
(1) 10G SFP+ fiber port
(2) 10G SFP+ fiber port LED
Table2-58 LED description
LED
LED status
SFP+ port LED
Flashing
On
Off
LSXM1SFK16ER1
View
Figure2-57 LSXM1SFK16ER1 view
Table2-59 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
159 W to 293 W
S12516R
Applicable interface modules
Buttons and LEDs
Figure2-58 LSXM1SFK16ER1 front panel
(1) RUN/ALM LED
Table2-60 LED description
LED
LED status
RUN/ALM LED
Green
The fabric module is operating correctly.
Red
The fabric module has failed or is loading software.
Off
The fabric module is not powered on or has not started loading software.
LSXM1SFK16GR1
View
Figure2-59 LSXM1SFK16GR1 view
Table2-61 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
471 W to 822 W
S12516R
Buttons and LEDs
Figure2-60 LSXM1SFK16GR1 front panel
(1) RUN/ALM LED
Table2-62 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
LSXM1SFK08ER1
View
Figure2-61 LSXM1SFK08ER1 view
Table2-63 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
90 W to 157 W
S12508R
Buttons and LEDs
Figure2-62 LSXM1SFK08ER1 front panel
(1) RUN/ALM LED
Table2-64 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
LSXM1SFK08GR1
View
Figure2-63 LSXM1SFK08GR1 view
Table2-65 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
350 W to 450 W
S12508R
Buttons and LEDs
Figure2-64 LSXM1SFK08GR1 front panel
(1) RUN/ALM LED
Table2-66 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
LSXM1SFK04FR1
View
Figure2-65 LSXM1SFK04FR1 view
Table2-67 Technical specifications
Item
Specification
Processor
SDRAM
8 GB DDR4 SDRAM
Power consumption
104 W to 212 W
S12504R
Hot swapping
Supported
Buttons and LEDs
Figure2-66 LSXM1SFK04FR1 front panel
(1) RUN/ALM LED
Table2-68 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
LSXM2SFH16CR1
Table2-69 Technical specifications
Item
Specification
Processor
MIPS64 (dual-core) @ 1GHz
SDRAM
4 GB DDR3 SDRAM
Power consumption
194 W to 308 W
S12516R
Hot swapping
Supported
Buttons and LEDs
Figure2-67 LSXM2SFH16CR1 front panel
(1) RUN/ALM LED
Table2-70 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
LSXM1SFH16ER1
View
Figure2-68 LSXM1SFH16ER1 view
Table2-71 Modules functionalities
Item
Specification
Processor
SDRAM
4 GB DDR3 SDRAM
Power consumption
487 W to 816 W
S12516R
Hot swapping
Supported
Buttons and LEDs
Figure2-69 LSXM1SFH16ER1 front panel
(1) RUN/ALM LED
Table2-72 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
LSXM1SFH08CR1
View
Figure2-70 LSXM1SFH08CR1 view
Table2-73 Technical specifications
Item
Specification
Processor
MIPS64 (dual-core) @ 1 GHz
SDRAM
4 GB DDR3 SDRAM
Power consumption
84 W to 135 W
S12508R
Hot swapping
Supported
Buttons and LEDs
Figure2-71 LSXM1SFH08CR1 front panel
(1) RUN/ALM LED
Table2-74 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
LSXM1SFH08DR1
View
Figure2-72 LSXM1SFH08DR1 view
Table2-75 Modules functionalities
Item
Specification
Processor
SDRAM
4 GB DDR3 SDRAM
Power consumption
159 W to 255 W
S12508R
Hot swapping
Supported
Buttons and LEDs
Figure2-73 LSXM1SFH08DR1 front panel
(1) RUN/ALM LED
Table2-76 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
LSXM1SFH04DR1
View
Figure2-74 LSXM1SFH04DR1 view
Table2-77 Modules functionalities
Item
Specification
Processor
SDRAM
4 GB DDR3 SDRAM
Power consumption
86 W to 140 W
S12504R
Hot swapping
Supported
Buttons and LEDs
Figure2-75 LSXM1SFH04DR1 front panel
(1) RUN/ALM LED
Table2-78 LED description
LED
LED status
RUN/ALM LED
Green
Red
Off
The device comes with fabric module slots empty. To ensure adequate dissipation, purchase and install fabric module filler panels in empty fabric module slots.
Table2-79 Fabric module filler panels
Quantity per chassis
S12516R fabric module filler panel
0 to 4
S12508R fabric module filler panel
S12504R fabric module filler panel
Slide rails
LSXM1BSR
View
Figure2-76 LSXM1BSR view
(1) Bottom-support rail installation hole
(2) Sign
(3) Chassis rail
(4) Front plate installation hole
(5) Locating tab
No slide rails are provided with the device. Purchase slide rails yourself as needed. Table2-80 shows the weights of the compatible chassis when they are fully configured and the slide rail technical specifications.
Table2-80 Technical specifications
Model
Max chassis weight
(fully configured)
Applicable slide rail
Adjustment range
Occupied rack space
S12516R
400 kg (881.83 lb)
LSXM1BSR
630 mm to 900 mm
(24.80 in to 35.43)
1 RU
S12508R
220 kg (485.01 lb)
LSTM2KSGD0
View
Figure2-77 LSTM2KSGD0 view
(1) Chassis rail
(2) Installation sign
(3) Installation hole
No slide rails are provided with the device. Purchase slide rails yourself as needed. Table2-81 shows the weights of the compatible chassis when they are fully configured and the slide rail technical specifications.
Table2-81 Technical specifications
Model
Max chassis weight
(fully configured)
Adjustment range
Occupied rack space
S12508R
220 kg (485.01 lb)
LSTM2KSGD0
500 mm to 800 mm
(19.69 in to 31.50 in)
2 RUs
LSVM1BSR10
View
Figure2-78 LSVM1BSR10 view
(1) Sign
(2) Chassis rail
(3) Air vent
(4) Installation hole
No slide rails are provided with the device. Purchase slide rails yourself as needed. Table2-82 shows the weights of the compatible chassis when they are fully configured and the slide rail technical specifications.
Table2-82 Technical specifications
Model
Max chassis weight
(fully configured)
Adjustment range
Occupied rack space
S12504R
S12500R-2XL
120 kg (264.55 lb)
LSVM1BSR10
630 mm to 850 mm
(24.80 in to 33.46 in)
N/A
S12500R-2L
70 kg (154.32 lb)
3 Power supplies
CAUTION
CAUTION:
Do not install power supplies of different models on the same device.
The device supports N+N (dual power inputs) or N+1 (single power input) power supply redundancy. Determine the number of power supplies based on the power supply mode and system power consumption. Make sure the total maximum output power of the installed power supplies is greater than the system power consumption. As a best practice, reserve 20% of the maximum output power. Table3-1 shows the power supplies available for the device.
When the temperature of a power supply exceeds the upper limit or drops below the lower limit, the power supply shuts down automatically. When the temperature restores into the normal range, the power supply starts up automatically.
Table3-1 Power supplies available for the device
Device model
Available power supplies
S12516R
S12508R
S12504R
S12500R-2XL
·     PSR2400-54A
·     PSR2400-54D
·     PSR3000-54A
·     PSR3000-54AHD
·     PSR2400-54AA-B
S12500R-2L
·     PSR1800-56A
·     PSR1800-56D
PSR2400-54A
View
Figure3-1 PSR2400-54A power supply view
Table3-2 Technical specifications
Item
Specification
Net weight
1.9 kg (4.19 lb)
41 × 100 × 332 mm (1.61 × 3.94 × 13.07 in)
Rated input voltage range
100 VAC to 240 VAC @ 50 Hz or 60 Hz
Rated output voltage
54 VDC
Max input current
16 A
Maximum output current
44.5 A
Max output power
1200 W @ 110 VAC
2400 W @ 220 VAC
Heat dissipation
Equipped with fans, rear-to-front airflow
Hot swapping
Supported
–10°C to +55°C (14°F to 131°F)
Storage temperature
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2XL
LEDs
Figure3-2 PSR2400-54A front panel
(1) Input status LED (AC OK)
(2) Output status LED (DC OK)
Table3-3 LED description
LED
Mark
Status
Input status LED
AC OK
Off
No power input.
The input voltage is too low and the power supply has entered self-protection state.
Green
Normal power input.
Output status LED
DC OK
Green
Normal power output.
Red
Power output of the power supply system is abnormal. The power supply has an output short circuit, output overcurrent, output overvoltage, input undervoltage, or remote shutdown alarm and has entered self-protection state.
Orange
An overtemperature alarm occurred on the power supply.
PSR2400-54D
View
Figure3-3 PSR2400-54D power supply view
Table3-4 Technical specifications
Item
Specification
Net weight
1.9 kg (4.19 lb)
–48 to –60 VDC
54 VDC
Max input current
80 A
44.5 A
Max output power
2400 W
Heat dissipation
Equipped with fans, rear-to-front airflow.
Hot swapping
Supported
Storage temperature
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2XL
LEDs
Figure3-4 PSR2400-54D front panel
(1) Input status LED (INPUT OK)
(2) Output status LED (OUTPUT OK)
Table3-5 LED description
LED
Mark
Status
Input status LED
INPUT OK
Off
No power input.
Green
Normal power input.
Output status LED
OUTPUT OK
Green
Red
Orange
PSR3000-54A
View
Figure3-5 PSR3000-54A power supply view
Table3-6 Technical specifications
Item
Specification
Net weight
2.1 kg (4.63 lb)
AC input: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
HVDC input: 240 VDC
54 VDC
Max input current
16 A
55.6 A
Max output power
1200 W @ 110 VAC
2400 W @ 175 VAC to 200 VAC
3000 W @ 220 VAC
3000 W @ 240 VDC
Heat dissipation
Hot swapping
Supported
Storage temperature
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2XL
LEDs
Figure3-6 PSR3000-54A front panel
Table3-7 LED description
LED
Mark
Status
Input status LED
AC OK
Off
No power input.
Green
Normal power input.
Output status LED
DC OK
Green
Red
Orange
PSR3000-54AHD
View
Figure3-7 PSR3000-54AHD power supply view
Table3-8 Technical specifications
Item
Specification
Net weight
2.1 kg (4.63 lb)
54 VDC
Max input current
16 A
44.5 A
Max output power
1200 W @ 110 VAC
2400 W @ 220 VAC
Heat dissipation
Hot swapping
Supported
Storage temperature
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2XL
LEDs
Figure3-8 PSR3000-54AHD front panel
(1) Input status LED (IN OK)
(2) Output status LED (OUT OK)
Table3-9 LED description
LED
Mark
Status
Status
Input status LED
IN OK
Off
No power input.
Green
Normal power input.
Output status LED
OUT OK
Green
Orange
Red
Power output of the power supply system is abnormal. The power supply has an output overcurrent, output overvoltage, input undervoltage, or remote shutdown alarm and has entered self-protection state.
PSR2400-54AA-B
View
Figure3-9 PSR2400-54AA-B power supply view
Table3-10 Technical specifications
Item
Specification
Net weight
1.95 kg (4.30 lb)
54 VDC
Max input current
16 A
44.5 A
Max output power
1200 W @ 110 VAC
2400 W @ 220 VAC
Heat dissipation
Hot swapping
Supported
Storage temperature
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2XL
LEDs
Figure3-10 PSR2400-54AA-B front panel
Table3-11 LED description
LED
Mark
Status
Input1 status LED
IN1
Off
No power input.
Green
Normal power input.
Red
The input voltage is too low.
Input2 status LED
IN2
Off
No power input.
Green
Normal power input.
Red
Output status LED
OUT
Off
No power output.
Green
Red
Orange
PSR1800-56A
View
Figure3-11 PSR1800-56A power supply view
Table3-12 Technical specifications
Item
Specification
Net weight
1.6 kg (3.53 lb)
40.1 × 82.6 × 297.7 mm (1.58 × 3.25 × 11.72 in)
240 VDC
Max input current
13 A @ 110 VAC
9 A @ 220 VAC
32.2 A (201 V to 240 V input voltage)
19.6 A @ 100 V to 200 V
32.2 A @ 240 VDC
Max output power
1800 W @ 201 V to 240 V
1100 W @ 100 V to 200 V
1800 W @ 240 VDC
Heat dissipation
Hot swapping
Supported
Storage temperature
S12500R-2L
LEDs
Figure3-12 PSR1800-56A front panel
(2) AC-input power receptacle
(3) Latch
(4) Power supply handle (The handle is in red, indicating the air ventilation is performed by exhausting air from the inside to the outside.)
(5) Output status LED (DC OK)
Table3-13 LED description
LED
Mark
Status
Input status LED
AC OK
Steady green
Normal power input.
Off
·     No power input.
·     Abnormal power input.
Output status LED
DC OK
Steady green
Steady red
Abnormal power output.
Off
No power output.
PSR1800-56D
View
Figure3-13 PSR1800-56D power supply view
Table3-14 Technical specifications
Item
Specification
Net weight
2.0 kg (4.41 lb)
–48 VDC to –60 VDC
56 VDC
Max input current
45 A
32.2 A
Max output power
1800 W
Heat dissipation
Hot swapping
Supported
Storage temperature
S12500R-2L
LEDs
Figure3-14 PSR1800-56D front panel
Table3-15 LED description
LED
Mark
Status
Input status LED
IN OK
Steady green
Normal power input.
Off
·     No power input.
Output status LED
OUT OK
Steady green
Steady red
Off
No power output.
4 Fan trays
For S12516G-AF and S12508G-AF, the fabric module status LEDs on the fan tray correspond to the fabric modules that the fan tray covers from left to right, as shown in Figure4-1 and Figure4-2.
Figure4-1 Corresponding relations between the LEDs on the S12508G-AF fan trays and fabric module slots
(1) LEDs for fabric module slots 10 to 12
(2) LEDs for fabric module slots 13 to 15
Figure4-2 Corresponding relations between the LEDs on the S12504G-AF fan trays and fabric module slots
(1) LEDs for fabric module slot 6
(2) LEDs for fabric module slot 8
(3) Fabric module slot number
(4) LEDs for fabric module slot 9
(5) LEDs for fabric module slot 11
View
Figure4-3 LSXM116XFANH (high performance) fan tray view
Table4-2 Technical specifications
Item
Specification
Net weight
8.4 kg (18.52 lb)
144 × 927 × 154 mm (5.67 × 36.50 × 6.06 in)
Power consumption
·     Minimum: 59 W
·     Typical: 725 W
·     Maximum: 2030 W
Fan number
6
Fan diameter
134 mm (5.28 in)
Maximum air flow rate
1860 CFM (52.67 m3/min)
Airflow direction
Air drawn in from the faceplate
Noise reduction after poweron
Supported
Auto speed adjustment
Supported
Alarm detection
Supported
Electronic label
Supported
Hot swapping
Supported
S12516R
LEDs
Figure4-4 Front panel
(2) Fabric module status LED (SWITCHING FABRIC)
Table4-3 Fan tray LED description
OK
FAIL
On
Off
The fan tray is operating correctly.
Off
On
The fan tray is faulty.
Off
Off
The fan tray is not powered on.
Table4-4 Description for fabric module status LEDs on the fan tray
RUN
ALM
Flashing (once per second)
Off
Off
On
The fabric module is faulty.
On
·     The fabric module is loading software.
·     The fabric module is operating incorrectly. For example, the operating temperature exceeds the acceptable range.
Off
Off
The fabric module has not started or is not powered on.
On
On
The fabric module is starting up.
LSXM116XFAN
View
Figure4-5 LSXM116XFAN fan tray view
Table4-5 Technical specifications
Item
Specification
Net weight
6.7 kg (14.77 lb)
Power consumption
·     Minimum: 33 W
·     Typical: 206 W
·     Maximum: 793 W
Fan number
6
Fan diameter
120 mm (4.72 in)
1020 CFM (28.88 m3/min)
Airflow direction
Supported
Supported
Alarm detection
Supported
Electronic label
Supported
Hot swapping
Supported
S12516R
LEDs
Figure4-6 Front panel
Table4-6 Fan tray LED description
OK
FAIL
On
Off
Off
On
Off
Off
Table4-7 Description for fabric module status LEDs on the fan tray
RUN
ALM
Off
Off
On
On
Off
Off
On
On
View
Figure4-7 LSXM108XFANH (high performance) fan tray view
Table4-8 Technical specifications
Item
Specification
Net weight
4.4 kg (9.70 lb)
144 × 527 × 154 mm (5.67 × 20.75 × 6.06 in)
Power consumption
·     Minimum: 35 W
·     Typical: 410 W
·     Maximum: 1000 W
Fan number
3
Fan diameter
134 mm (5.28 in)
930 CFM (26.33 m3/min)
Airflow direction
Supported
Supported
Alarm detection
Supported
Electronic label
Supported
Hot swapping
Supported
S12508R
LEDs
Figure4-8 Front panel
Table4-9 Fan tray LED description
OK
FAIL
On
Off
Off
On
Off
Off
Table4-10 Description for fabric module status LEDs on the fan tray
RUN
ALM
Off
Off
On
On
Off
Off
On
On
LSXM108XFAN
View
Figure4-9 LSXM108XFAN fan tray view
Table4-11 Technical specifications
Item
Specification
Net weight
3.8 kg (8.38 lb)
Power consumption
·     Minimum: 17 W
·     Typical: 103 W
·     Maximum: 395 W
Fan number
3
Fan diameter
120 mm (4.72 in)
510 CFM (14.44 m3/min)
Airflow direction
Supported
Supported
Alarm detection
Supported
Electronic label
Supported
Hot swapping
Supported
S12508R
LEDs
Figure4-10 Front panel
Table4-12 Fan tray LED description
OK
FAIL
On
Off
Off
On
Off
Off
Table4-13 Description for fabric module status LEDs on the fan tray
RUN
ALM
Off
Off
On
On
Off
Off
On
On
View
Figure4-11 LSXM104XFANH (high performance) fan tray view
Table4-14 Technical specifications
Item
Specification
Net weight
3.0 kg (6.61 lb)
144 × 263 × 102 mm (5.67 × 10.35 × 4.02 in)
Power consumption
·     Minimum: 19.4 W
·     Typical: 86.4 W
·     Maximum: 590 W
Fan number
2
Fan diameter
120 mm (4.72 in)
560 CFM (15.86 m3/min)
Airflow direction
Supported
Supported
Alarm detection
Supported
Electronic label
Supported
Hot swapping
Supported
S12504R
LEDs
Figure4-12 Front panel
Table4-15 Fan tray LED description
OK
FAIL
On
Off
Off
On
Off
Off
Table4-16 Description for fabric module status LEDs on the fan tray
RUN
ALM
Off
Off
On
On
Off
Off
On
On
LSXM104XFAN
View
Figure4-13 LSXM104XFAN fan tray view
Table4-17 Technical specifications
Item
Specification
Net weight
1.8 kg (3.97 lb)
144 × 263 × 67 mm (5.67 × 10.35 × 2.64 in)
Power consumption
·     Minimum: 14 W
·     Typical: 66 W
·     Maximum: 255 W
Fan number
2
Fan diameter
120 mm (4.72 in)
340 CFM (9.63 m3/min)
Airflow direction
Supported
Supported
Alarm detection
Supported
Electronic label
Supported
Hot swapping
Supported
S12504R
LEDs
Figure4-14 Front panel
Table4-18 Fan tray LED description
OK
FAIL
On
Off
Off
On
Off
Off
Table4-19 Description for fabric module status LEDs on the fan tray
RUN
ALM
Off
Off
On
On
Off
Off
On
On
FAN-120-1-A
View
Figure4-15 FAN-120-1-A fan tray view
Table4-20 Technical specifications
Item
Specification
Net weight
1.61 kg (3.55 lb)
123 × 214 × 123 mm (4.84 × 8.43 ×4.84 in)
Power consumption
·     Minimum: 17 W
·     Typical: 31 W
·     Maximum: 269 W
Fan number
2
Fan diameter
280 CFM (7.93 m3/min)
Air exhausted from the fan tray faceplate
Airflow direction
Supported
Supported
Supported
Alarm detection
Supported
Electronic label
Supported
Hot swapping
S12500R-2L
LEDs
Figure4-16 Front panel
(1) Fan tray status LED (RUN/ALM)
Table4-21 Fan tray LED description
Status
Steady green
Steady red
Off
5 Cables
The device supports varies interface modules that provide different types of ports. The cable used varies by port type. For more information, see Table5-1.
Table5-1 Cable description
Cable
Port type
Function
DC power cord
DC power receptacle
Connects a DC power supply to the external DC power supply system
AC power cord
AC power receptacle
Connects an AC power supply to the external AC power supply system
Console cable
·     RJ-45 port at one end and DB-9 port at the other end
·     RJ-45 port at one end and USB port at the other end
Connects the console port of the device to the console terminal
RJ-45 Ethernet ports
Connects RJ-45 Ethernet ports to transmit data
Optical fiber
SFP/SFP+/SFP28/QSFP+/QSFP28 ports
Connects the fiber ports to transmit data
SFP+/SFP28 ports
Connects SFP+/SFP28 ports to transmit data
SFP+/SFP28 ports
QSFP+ copper cable
QSFP+ ports
Connects QSFP+ ports to transmit data
QSFP28 copper cable
QSFP28 ports
Connects QSFP28 ports to transmit data
QSFP+/QSFP28 ports
Connects QSFP+/QSFP28 ports to transmit data
QSFP-DD ports
Connects QSFP-DD ports to transmit data
QSFP+ port at one end and SFP+ port at the other end
Connects QSFP+ port at one end and SFP+ port at the other end
QSFP28 port at one end and SFP28 port at the other end
Connects QSFP28 port at one end and SFP28 port at the other end
DC power cord
DC power cords are used for connecting the DC power supplies of the device to the external DC power supply system. Table5-2 shows the DC power cords supported by the device.
Table5-2 DC power cords supported by the device
Compatible power supply
Cable length
PSR2400-54D
3 m (9.84 ft)
Connects the DC power supply to an external DC power supply system.
15 m (49.21 ft)
PSR3000-54AHD
3 m (9.84 ft)
Connects the 3000W AC & 240V to 380V HVDC power supply to an external DC power supply system.
PSR1800-56D
3 m (9.84 ft)
Connects the DC power supply to an external DC power source.
15 m (49.21 ft)
AC power cord
AC power cords are used for connecting the AC power supplies of the device to the external AC power supply system.
To select an AC power cord for an AC power supply, consider the following items:
·     Power capacity of the power supply.
·     Current-carrying capacity of the power cord.
·     Region-and country-specific plug type.
AC power supplies of the device require 16A AC power cords. For power plugs required by different countries or regions, see H3C Power Cords & Cables User Guide.
Console cable
As shown in Table5-3, two types of serial console cables can be used for connecting the device to a configuration terminal. The device is not provided with a serial console cable.
Table5-3 Connection methods and console cables
Connection method
Console cable type
Configuration terminal-side connector
Device-side connector
Using the serial console port for connection
DB9-to-RJ45 console cable
DB-9 female connector
RJ-45 connector
USB-to-RJ45 console cable
USB connector
RJ-45 connector
The signal pinout for the RJ-45 connector of a serial console cable varies by vendor. To avoid abnormal configuration terminal display, use a serial console cable provided by H3C. For more information, see Table5-4. To prepare a serial console cable yourself, make sure the signal pinout for the RJ-45 connector is the same as that shown in Table5-5.
Table5-4 Console cable views
Console cable type
Console cable view
Product code for the recommended H3C console cable
04042967
0404A1EE
Connecting a DB9-to-RJ45 console cable
CAUTION
CAUTION:
Follow these guidelines when you connect a DB9-to-RJ45 console cable:
·     Identify the mark on the console port and make sure you are connecting to the correct port.
·     The serial ports on PCs do not support hot swapping. To connect a PC to an operating device, first connect the PC end. To disconnect a PC from an operating device, first disconnect the device end.
A DB9-to-RJ45 console cable is an 8-core shielded cable, with a crimped RJ-45 connector at one end for connecting to the console port of the device, and a DB-9 female connector at the other end for connecting to the serial port on the console terminal.
Figure5-1 Console cable
Table5-5 DB9-to-RJ45 console cable signal pinout
RJ-45
Signal
DB-9
Signal
1
RTS
8
CTS
2
DTR
6
DSR
3
TXD
2
RXD
4
SG
5
SG
5
SG
5
SG
6
RXD
3
TXD
7
DSR
4
DTR
8
CTS
7
RTS
To connect the device to a configuration terminal (for example, a PC) by using a DB9-to-RJ45 console cable:
1.     Plug the DB-9 female connector of the DB9-to-RJ45 console cable to the serial port on the PC.
2.     Connect the RJ-45 connector to the console port on the device.
Connecting a USB-to-RJ45 console cable
IMPORTANT
IMPORTANT:
·     To use a USB-to-RJ45 console cable to connect the device to a configuration terminal, first download and install the USB-to-RJ45 console driver on the configuration terminal, and then connect the USB-to-RJ45 console cable to the configuration terminal.
·     If you have connected a USB-to-RJ45 console cable to the configuration terminal before driver installation, reconnect the USB-to-RJ45 console cable to the configuration terminal.
For information about the signal pinout for the RJ-45 connector of a USB-to-RJ45 console cable, see Table5-5.
The following installs the driver on the Windows system. To install the driver on other operating systems, see the installation guide in the driver compression package named by using the corresponding operating system.
To connect the device to a configuration terminal by using a USB-to-RJ45 console cable:
1.     Click the following link, or copy it to the address bar on your browser and download the USB-to-RJ45 console driver.
http://www.h3c.com/en/home/USB_to_RJ45_Console/
2.     View the TXT file Read me in the Windows folder to identify whether the Windows system of the configuration terminal supports the driver.
3.     If the Windows system supports the driver, install PL23XX-M_LogoDriver_Setup_v200_20190815.exe.
4.     Click Next on the welcome page of the driver installation wizard.
Figure5-2 Driver installation wizard
5.     Click Finish after the drive installation is completed.
Figure5-3 Finishing the driver installation
6.     Connect the standard USB connector of the cable to the USB port of the configuration terminal.
7.     Connect the RJ-45 connector of the cable to the console port of the device.
Ethernet twisted pair cable
Introduction
An Ethernet twisted pair cable consists of four pairs of insulated copper wires twisted together. Every wire uses a different color, and has a diameter of about 1 mm (0.04 in).
Application scenarios
An Ethernet twisted pair cable typically transmits analog signals and is advantageous in transmitting data over shorter distances. It is the commonly used transmission media of the Ethernet.
Maximum transmission distance
The maximum transmission distance of the Ethernet twisted pair cable is 100 m (328.08 ft). To extend the transmission distance, you can connect two twisted pair cable segments with a repeater. At most four repeaters can be added, which means five segments can be joined together to provide a transmission distance of 500 m (1640.42 ft).
RJ-45 connector
An Ethernet twisted pair cable connects network devices through the RJ-45 connectors at the two ends. Figure5-4 shows the pinouts of an RJ-45 connector.
Figure5-4 RJ-45 connector pinout diagram
Cable pinouts
EIA/TIA cabling specifications define two standards: 568A and 568B, for cable pinouts.
·     Standard 568A—pin 1: white/green stripe, pin 2: green solid, pin 3: white/orange stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: orange solid, pin 7: white/brown stripe, pin 8: brown solid.
·     Standard 568B—pin 1: white/orange stripe, pin 2: orange solid, pin 3: white/green stripe, pin 4: blue solid, pin 5: white/blue stripe, pin 6: green solid, pin 7: white/brown stripe, pin 8: brown solid.
Cable type
Based on performance
Ethernet twisted pair cables can be classified into category 3, category 4, category 5, category 5e, category 6, category 6A, and category 7 cables based on performance. In LANs, category 5, category 5e, and category 6 are commonly used.
Table5-6 Description for commonly used Ethernet twisted pair cables
Cable type
Category 5
Suitable for data transmission at a maximum speed of 100 Mbps, with a bandwidth of 100 MHz.
Category 5e
Suitable for data transmission at a maximum speed of 1000 Mbps, with a bandwidth of 100 MHz.
Category 6
Suitable for data transmission at a maximum speed of 1 Gbps, with a bandwidth of 250 MHz.
Category 6A
Suitable for data transmission at a maximum speed of 10 Gbps, with a bandwidth of 500 MHz.
Category 7
Suitable for data transmission at a maximum speed of 10 Gbps, with a bandwidth of 600 MHz.
Based on pinouts
Ethernet twisted pair cables can be classified into straight-through and crossover cables based on their pinouts.
·     Straight-through—The pinouts at both ends comply with standard 568B, as shown in Figure5-5.
·     Crossover—The pinouts at one end comply with standard 568B, and those at the other end comply with standard 568A, as shown in Figure5-6.
Figure5-5 Straight-through cable
Figure5-6 Crossover cable
Pin assignments
Select an Ethernet twisted pair cable according to the RJ-45 Ethernet port type on your device. An RJ-45 Ethernet port can be MDI (for routers and PCs) or MDIX (for the device). Table5-7 and Table5-8 show their pinouts.
Table5-7 RJ-45 MDI port pinouts
Pin
10Base-T/100Base-TX
1000Base-T
Signal
Function
Signal
Function
1
Tx+
Sends data
BIDA+
Bi-directional data cable A+
2
Tx-
Sends data
BIDA-
Bi-directional data cable A-
3
Rx+
Receives data
BIDB+
Bi-directional data cable B+
4
Reserved
N/A
BIDC+
Bi-directional data cable C+
5
Reserved
N/A
BIDC-
Bi-directional data cable C-
6
Rx-
Receives data
BIDB-
Bi-directional data cable B-
7
Reserved
N/A
BIDD+
Bi-directional data cable D+
8
Reserved
N/A
BIDD-
Bi-directional data cable D-
Table5-8 RJ-45 MDIX port pinouts
Pin
10Base-T/100Base-TX
1000Base-T
Signal
Function
Signal
Function
1
Rx+
Receives data
BIDB+
2
Rx-
Receives data
BIDB-
3
Tx+
Sends data
BIDA+
4
Reserved
N/A
BIDD+
5
Reserved
N/A
BIDD-
6
Tx-
Sends data
BIDA-
7
Reserved
N/A
BIDC+
8
Reserved
N/A
BIDC-
To ensure normal communication, the pins for sending data on one port must correspond to the pins for receiving data on the peer port. When both ports on the two devices are MDI or MDIX, use a crossover Ethernet cable. When one port is MDI and the other is MDIX, use a straight-through Ethernet cable. To summarize, straight-through and crossover cables connect the following devices:
·     Straight-through cables connect devices of different types—For example, switch router to PC and switch router to router.
·     Crossover cables connect devices of the same type—For example, switch router to switch router, router to router, and PC to PC.
An RJ-45 Ethernet port with MDI/MDIX autosensing enabled can automatically negotiate pin roles. The RJ-45 Ethernet ports on the device support auto-MDI/MDIX. By default, auto-MDI/MDIX is enabled on a port.
Making an Ethernet twisted pair cable
To make an Ethernet twisted pair cable:
1.     Cut the cable to a required length with the crimping tool.
2.     Strip off an appropriate length of the cable sheath. The length is typically that of the RJ-45 connector.
3.     Untwist the pairs so that they can lie flat, and arrange the colored wires based on the wiring specifications.
4.     Cut the top of the wires even with one another and insert the wires into the RJ-45 connector. Make sure the wires extend to the front of the RJ-45 connector and make good contact with the metal contacts in the RJ-45 connector and in the correct order.
5.     Crimp the RJ-45 connector with the crimping tool until you hear a click.
6.     Repeat the above steps with the other end of the cable.
7.     Use a cable tester to verify the connectivity of the cable.
Optical fiber
CAUTION
CAUTION:
Use the same types of transceiver modules, pigtail cords, patch cords, and fiber cables. If you use single-mode optical fibers, the transceiver modules, pigtail cords, patch cords, and fiber cables must be single-mode.
Introduction
Optical fiber
Optical fibers are widely used in fiber-optic communications, which are advantageous for long-distance communications.
Optical fibers can be classified into the following types:
·     Single-mode fiber (SMF)—It has a core size of 10 µm or smaller, and has a lower modal dispersion. It carries only a single ray of light and is mostly used for communication over longer distances.
·     Multimode fiber (MMF)—It has a core size of 50 µm, 62.5 µm, or higher, and has a higher modal dispersion than the single-mode optical fiber. It is typically used for communication over shorter distances.
Table5-9 Allowed maximum tensile force and crush load
Period of force
Tensile load (N)
Crush load (N/mm)
Short period
150
500
Long term
80
100
Optical fiber cable
An optical fiber cable is a cable that contains one or more optical fibers. The optical fiber elements are typically individually coated with plastic layers and contained in a protective tube. Optical fiber cables can be classified into single-mode optical fiber cables and multimode optical fiber cables.
Patch cord
A fiber that has connectors at both ends is called a patch cord. A patch cord connects one optical device to another for signal routing. Patch cords can be classified into single-mode patch cords and multimode patch cords.
·     Single-mode patch cord—The jacket is yellow. It permits transmission over longer distances.
·     Multimode patch cord—The jacket is orange. It permits transmission over shorter distances.
Patch cords are classified into SC, LC, FC, and so on based on interface type. The length of a patch cord can be 0.5 m (1.64 ft), 1 m (3.28 ft), 2 m (6.56 ft), 3 m (9.84 ft), 5 m (16.40 ft), 10 m (32.81 ft) and so on.
Pigtail cord
A pigtail cord is an optical fiber that has an optical connector at one end and a length of exposed fiber at the other. The end of the pigtail is fusion spliced to a fiber, connecting the fiber cable and transceiver.
Pigtail cords can be classified into single-mode (yellow) pigtail cords and multimode (orange) pigtail cords, and can also be classified into SC, LC, FC, and so on based on interface type.
Fiber connector
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient and the transit dispatching of the system more flexible.
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient. There are multiple types of fiber connectors. Figure5-7 and Figure5-8 show an MPO connector and an LC connector, respectively.
Figure5-7 MPO connector
Figure5-8 LC connector
Precautions
·     Make sure the fiber connector and fiber type match the transceiver module type.
·     The fiber ports on the device are provided with dust plugs. To prevent particles from entering the ports, insert the dust plugs into the fiber ports that you are not to use.
·     Fiber connectors must be protected under safe and reliable outer packing, and be fitted with dust caps. Fiber connectors must be installed with dust caps when they are not in use. Take care not to scratch their end face. Replace the dust cap if it is loose or polluted.
·     Before you connect an optical fiber, use dust free paper and absolute alcohol to clean the end face of the fiber connector. You can brush the end faces only in one direction.
·     Never bend or curve a fiber during connection. After a fiber is installed well, make sure the bend radius is not less than 40 mm or 1.57 in (the minimum dynamic bend radius is 20 D, and the minimum static bend radius is 10 D. D indicates the outer diameter of dust caps).
·     If the fiber has to pass through a metallic board hole, the hole must have a sleek and fully filleted surface (the filleting radius must be not less than 2 mm or 0.08 in). When the fiber passes through a metallic board hole or bend along the acute side of mechanical parts, it must wear jackets or cushions.
·     Do not use excessive force when you insert or remove a fiber connector. Never pull, press, or extrude the fiber fiercely. For the allowed maximum tensile load and crush load, see Table5-9.
SFP+/SFP28 copper cable
You can use SFP+ copper cables to connect the SFP+ ports. The SFP+ copper cables available for the device are 10G SFP+ DAC cables, as shown in Figure5-9.
You can use SFP28 copper cables to connect the SFP28 ports. The SFP28 copper cables are similar to SFP+ copper cables in appearance.
Figure5-9 SFP+ copper cable
(1) Connector
(2) Pull latch
SFP+ AOC/SFP28 AOC cable
You can use SFP+ AOC cables to connect the SFP+ ports.
You can use SFP28 AOC cables to connect the SFP28 ports. The SFP28 AOC cables are similar to SFP+ AOC cables in appearance.
Figure5-10 SFP+ AOC cable
(1) Connector
(2) Pull latch
QSFP+ copper cable
You can use QSFP+ copper cables to connect the QSFP+ ports.
Figure5-11 QSFP+ copper cable
(1) Connector
(2) Pull latch
QSFP28 copper cable
You can use QSFP28 copper cables to connect the QSFP28 ports.
Figure5-12 QSFP28 copper cable
(1) Connector
(2) Pull latch
QSFP+ AOC/QSFP28 AOC cable
You can use QSFP+ AOC cables to connect the QSFP+ ports.
You can use QSFP28 AOC cables to connect the QSFP28 ports. The QSFP28 AOC cables are similar to QSFP+ AOC cables in appearance.
Figure5-13 QSFP+ AOC cable
(1) Connector
(2) Pull latch
QSFP-DD copper cable
You can use QSFP-DD copper cables to connect the QSFP-DD ports.
Figure5-14 QSFP-DD copper cable
QSFP+ to SFP+/QSFP28 to SFP28 copper cable
A QSFP+ to SFP+ copper cable is a cable with one QSFP+ module at one end and four SFP+ modules at the other end.
A QSFP28 to SFP28 copper cable is a cable with one QSFP28 module at one end and four SFP28 modules at the other end. The QSFP28 to SFP28 copper cables are similar to QSFP+ to SFP+ copper cables in appearance.
Figure5-15 QSFP+ to SFP+ copper cable
(1) QSFP+ connector
(2) QSFP+ pull latch
(3) SFP+ connector
(4) SFP+ pull latch
6 Ordering information
To purchase an S12500R chassis or chassis components, contact the sales agent or H3C sales personnel.
Table6-1 S12500R chassis ordering information
Product code
Product name
0235A2FL
S12516R
H3C S12516R Ethernet switch router chassis
0235A2FN
S12508R
H3C S12508R Ethernet switch router chassis
0235A2FM
S12504R
H3C S12504R Ethernet switch router chassis
0235A2JM
S12500R-2L
H3C S12500R-2L Ethernet switch router chassis
0235A2TG
S12500R-2XL
H3C S12500R-2XL Ethernet switch router chassis
Table6-2 S12500R chassis component ordering information
Product code
Product name
SEUs
0231AE3C
LSXM1SUPER1
H3C S12500R supervisor engine unit
0231ADRF
LSXM1SUP04TR1
H3C S12504R supervisor engine unit
0231ABV3
LSXM1SUP02LR1
H3C S12500R-2L supervisor engine unit
0231AG2Q
LSXM1SUP02TR1
0231AKY6
LSXM2SUP02LR1
0231AH9W
LSXM1SUPEAR1
H3C S12500R AI supervisor engine unit
Fabric modules
0231AD26
LSXM2SFH16CR1
H3C S12516R fabric module, Type H (Class C)
0231AD2A
LSXM1SFH16ER1
H3C S12516R fabric module, Type H (Class E)
0231AD28
LSXM1SFH08CR1
H3C S12508R fabric module, Type H (Class C)
0231AD27
LSXM1SFH08DR1
H3C S12508R fabric module, Type H(Class D)
0231AD29
LSXM1SFH04DR1
H3C S12504R fabric module, Type H(Class D)
0231AFCT
LSXM1SFK16ER1
H3C S12516R fabric module, Type K(Class E)
0231AE48
LSXM1SFK16GR1
H3C S12516R fabric module, Type K(Class G)
0231AFCU
LSXM1SFK08ER1
H3C S12508R fabric module, Type K(Class E)
0231AETV
LSXM1SFK08GR1
H3C S12508R fabric module, Type K(Class G)
0231AETW
LSXM1SFK04FR1
H3C S12504R fabric module, Type K(Class F)
Interface modules
0231AD2D
LSXM1CGQ36HBR1
H3C S12500R 36-Port 100GBASE Ethernet optical interface module (QSFP28) (HB)
0231AD2E
LSXM1CGQ36HFR1
H3C S12500R 36-Port 100GBASE Ethernet optical interface module (QSFP28) (HF)
0231AEM6
LSXM1TGS48HFR1
H3C S12500R 48-port 10GBASE Ethernet optical interface module (SFP+,LC)(HF)
0231AEM8
LSXM1CGQ18QGHFR1
H3C S12500R 18-port 100GBASE Ethernet optical interface (QSFP28)/36-port 40GBASE Ethernet optical interface module (QSFP+)(HF)
0231AEM7
LSXM1CGQ6QGHFR1
H3C S12500R 6-port 100GBASE Ethernet optical interface (QSFP28)/12-port 40GBASE Ethernet optical interface module (QSFP+)(HF)
0231AE03
LSXM1TGS48HBR1
H3C S12500R 48-port 10GBASE Ethernet optical interface module (SFP+,LC)(HB)
0231AE04
LSXM1CGQ18QGHBR1
H3C S12500R 18-port 100GBASE Ethernet optical interface (QSFP28)/36-port 40GBASE Ethernet Optical interface module (QSFP+)(HB)
0231AHS0
LSXM1CGQ48KB1
H3C S12500X-AF 48-port 100GBASE Ethernet optical interface module (QSFP28) (KB)
0231AKY5
LSXM2CGQ48KBR1
H3C S12500R 48-port 100GBASE Ethernet optical interface module (QSFP28)(KB)
0231ABS3
LSXM1CDQ24KB1
H3C S12500X-AF 24-port 400GBASE Ethernet optical interface module(QSFP-DD)(KB)
0231AE39
LSXM1CDQ24KBR1
H3C S12500R 24-port 400GBASE Ethernet optical interface module (QSFP-DD) (KB)
0231AE3B
LSXM1CGQ48KBR1
H3C S12500R 48-port 100GBASE Ethernet optical interface module (QSFP28) (KB)
0231AM6Y
LSXM1CDQ18KCR1
H3C S12500R 18-port 400GBASE Ethernet optical interface module (QSFP-DD)(KC)
0231AFPW
LSXM1CCQ48KBR1
H3C S12500R 48-port 200GBASE Ethernet optical interface module (QSFP56) (KB)
0231AG0A
LSXM1MOD24KBR1
H3C S12500R 24KBR flexible line processing platform module
0231AG2P
LSXM1CGQFX16KBR1
H3C S12500R 16-port 100GBASE FlexE Ethernet optical interface module(QSFP28)
0231AH8C
LSXM1CGMS48KBR1
H3C S12500R 48-port 100GBASE MACsec Ethernet optical interface module (QSFP28)
0231AGX6
LSXM1CGQ72KCR1
H3C S12500R 36-port 200GBASE Ethernet optical interface (QSFP56)/72-port 100GBASE Ethernet optical interface module (QSFP28)(KC)
0231AFVG
LSXM1CGQ18C1
18-port 100GBASE Ethernet optical interface module (QSFP28)
0231AG38
LSXM1CGQ8C1
0231AG2N
LSXM1TGS24C1
24-port 100GBASE Ethernet optical interface module (SFP+,LC)
Fan trays
0231A2T1
LSXM116XFAN
Fan module for the H3C S12516R
0231A2UH
LSXM108XFAN
Fan module for the H3C S12508R
0231A2X9
LSXM104XFAN
Fan module for the H3C S12504R
0231A4WX
LSXM116XFANH
High speed fan module for the H3C S12516R
0231A4X0
LSXM108XFANH
High speed fan module for the H3C S12508R
0231A4X1
LSXM104XFANH
High speed fan module for the H3C S12504R
0231ABVR
LSXM102LFAN
H3C S12500R-2L Ethernet switch router fan module
Power supplies
0231A2KX
LSVM3PSRA
1800W AC power supply
0231A2KY
PSR1800-56D
1800W DC power supply
0231A2SN
PSR2400-54A
2400W AC power supply
0231A2X7
PSR2400-54D
2400W DC power supply
0231A5CH
PSR3000-54A
3000W AC power supply
0231A6PS
PSR3000-54AHD
3000W AC & 240V-380V HVDC power supply
0231AK4Y
PSR2400-54AA-B
Dual input 2400W AC power supply
Power cords
0404A0E1
CAB-DC Pwr-3m-2
External DC power cable, 3m, 13mm^2, PWR63A-B-2, 6UL10455BL+6UL10455B, 2*(T16-12G)+2*OT(16-6-0)!+2*OT(16-8-0)!
0404A0E2
CAB-DC Pwr-15m-2
External DC power cable, 15m, 13mm^2, PWR63A-B-2, 6UL10455BL+6UL10455B, 2*(T16-12G)+2*OT(16-6-0)!+2*OT(16-8-0)!
0404A0H4
CAB-AC-CHI-C19RA-3m
Chinese AC power cable (C19 right angle), 3.0m, 1.5mm^2, black, PI250V16AAM, 227 IEC 53(RVV)3*1.5mm^2B, C19-250V16ARAF
04043396
CAB-AC Pwr CHI-3m
Chinese AC power cable 220V16A, 3m, 3*1.5mm^2, black, I-Type angle plug, 227IEC53-1.5^2(3C), C19 straight connector
0404A0C2
CAB-AC Pwr 3C-3m-PDU
External power cable, Chinese AC power cable 220V16A, 3m, 3*1.5mm^2, black, C20 straight plug, 227IEC53-1.5^2(3C), C19 straight connector, PDU
0404A0GE
CAB-HVDC-16A-PDU-3m-Y
High voltage DC power cable (yellow), 3m, 1.5mm^2, pantone yellow 121C, C20-250V16A, 227IEC53(RVV)3*1.5mm^2 pantone yellow 121C, C19-250V16A
0404A0GK
CAB-HVDC-250V16A-3m-Y
High voltage DC power cable (yellow), 3m, 1.5mm^2, pantone yellow 121C, PI angle plug, 227IEC53(RVV)3*1.5mm^2PANTONE YELLOW 121C, C19-250V16A
0404A0HS
CAB-AC-PWR-3m-C20-C19RA
External AC power cable, 3m, 3*1.5mm^2, black, C20-250V16A, 227IEC53(RVV)3*1.5mm^2B, C19RA-250V16A
0404A0LH
CAB-HVDC-16A-PDU-5m-Y
High voltage DC power cable (yellow), 5m, 1.5mm^2, pantone yellow 121C, C20-250V16A, 227IEC53(RVV)3*1.5mm^2 pantone yellow 121C, C19-250V16A
0404A0NH
CAB-PDU PWR-3m-C19A-C20
Chinese PDU power cable (C19A-C20) yellow, 3.0m, 3*1.5mm^2, pantone yellow 121C, C20-250V16ASM, 227 IEC 53(RVV)3*1.5mm^2 pantone yellow 121C,C19-250V16AAF
0404A0RQ
CAB-AC-Pwr-3m-PW3C450V
External AC power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC53(RVV)3*1.5mm^2B, PI-16A250V-SM
0404A0RP
CAB-PDU Pwr-3m-PW3C450V
External AC PDU power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC 53(RVV)3*1.5mm^2B, C20-16A250V
0404A0RL
CAB-HVDC Pwr-3m-336V
336V high voltage DC power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC53(RVV)3*1.5mm^2B, 3*T1.5mm^2-8R+3*OT(2.5-6-0)!
Fabric module slot filler panels
0231A3RK
LSXM1BFP16A
16 fabric blank filler panel
0231A3RL
LSXM1BFP08A
08 fabric blank filler panel
0231A3RM
LSXM1BFP04A
04 fabric blank filler panel
Slide rails
0231A4EK
LSXM1BSR
1U bottom-support rails, 630mm-900mm
0231A0PL
LSTM2KSGD0
Slide rail accessories, 500mm-800mm
0231A2VL
LSVM1BSR10
H3C S9810 bottom support rails, 630mm-900mm
