08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
18-IP-MIB
18-IP-MIB 283.57 KB
IP-MIB
About this MIB
Use this MIB to obtain device IP and ICMP basic information and packet statistics.
MIB file name
rfc4293-ip.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ipMIB(48)
Tabular objects
ipAddrTable
About this table
This table contains IPv4 address information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is ipAdEntAddr.
Object (OID)
Access
Value range
Implementation
ipAdEntAddr (1.3.6.1.2.1.4.20.1.1)
read-only
IpAddress
Standard MIB values.
IP address.
As per the MIB.
ipAdEntIfIndex (1.3.6.1.2.1.4.20.1.2)
read-only
INTEGER
INTEGER (1..2147483647)
Index of the interface corresponding to the entry.
As per the MIB.
ipAdEntNetMask (1.3.6.1.2.1.4.20.1.3)
read-only
IpAddress
Subnet mask of the IP address.
As per the MIB.
ipAdEntBcastAddr (1.3.6.1.2.1.4.20.1.4)
read-only
INTEGER
INTEGER (0..1)
Value of the least-significant bit in the IP broadcast address used for sending packets on the (logical) interface associated with the IP address of this entry.
For example, when the Internet standard all-ones broadcast address is used, the value is 1.
As per the MIB.
ipAdEntReasmMaxSize (1.3.6.1.2.1.4.20.1.5)
read-only
INTEGER
INTEGER (0..65535)
Maximum size of an IP packet which the entry can reassemble from fragments.
As per the MIB.
ipNetToMediaTable
About this table
This table contains IPv4 address-to-physical address mappings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipNetToMediaIfIndex and ipNetToMediaNetAddress.
Object (OID)
Access
Value range
Implementation
ipNetToMediaIfIndex (1.3.6.1.2.1.4.22.1.1)
read-create
INTEGER
Supports only the read operation.
ipNetToMediaPhysAddress (1.3.6.1.2.1.4.22.1.2)
read-create
PhysAddress
SIZE(0..65535)
Physical address of the media.
ipNetToMediaNetAddress (1.3.6.1.2.1.4.22.1.3)
read-create
IpAddress
IP address corresponding to the media’s physical address.
ipNetToMediaType (1.3.6.1.2.1.4.22.1.4)
read-create
INTEGER
other(1),
invalid(2),
dynamic(3),
static(4)
Mapping type.
Setting this object to the value invalid(2) invalidates the corresponding entry in the ipNetTomediaTable.
You can use this object to disassociate the interface from the mapping.
ipv6InterfaceTable
About this table
This table contains detailed IPv6 information about each interface.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is ipv6InterfaceIfIndex.
Object (OID)
Access
Value range
Implementation
ipv6InterfaceIfIndex (1.3.6.1.2.1.4.30.1.1)
not-accessible
InterfaceIndex
As per the MIB.
ipv6InterfaceReasmMaxSize (1.3.6.1.2.1.4.30.1.2)
read-only
Unsigned32
Unsigned32 (1500..65535)
Maximum size of an IPv6 packet that the entry can reassemble from fragments received on the interface.
As per the MIB.
ipv6InterfaceIdentifier (1.3.6.1.2.1.4.30.1.3)
read-only
Ipv6AddressIfIdentifierTC
Interface identifier.
An IPv6 interface address is an interface identifier attached with an address prefix.
By default, the Interface Identifier is auto-configured according to the rules of the interface link type.
The length of an interface identifier might be zero for specific interfaces, such as a loopback interface.
As per the MIB.
ipv6InterfaceEnableStatus (1.3.6.1.2.1.4.30.1.5)
read-write
INTEGER
up(1),
down(2)
IPv6 enablement status on the interface.
ipv6InterfaceReachableTime (1.3.6.1.2.1.4.30.1.6)
read-only
Unsigned32
Time used to reach a neighbor based on the received reachability confirmation.
As per the MIB.
ipv6InterfaceRetransmitTime (1.3.6.1.2.1.4.30.1.7)
read-only
Unsigned32
Interval at which Neighbor Solicitation messages are retransmitted during address resolving or neighbor reachability probing.
As per the MIB.
ipv6InterfaceForwarding (1.3.6.1.2.1.4.30.1.8)
read-write
INTEGER
forwarding(1),
notForwarding(2)
Whether the object is an IPv6 router that can forward data packets destined to any other devices.
ipSystemStatsTable
About this table
This table contains IP traffic statistics in the current system.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is ipSystemStatsIPVersion.
Object (OID)
Access
Value range
Implementation
ipSystemStatsIPVersion (1.3.6.1.2.1.4.31.1.1.1)
not-accessible
InetVersion
IP version of the current entry.
Supports only ipv4(1) and ipv6(2).
ipSystemStatsInReceives (1.3.6.1.2.1.4.31.1.1.3)
read-only
Counter32
Number of received IP packets in the system, including error packets.
The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object.
As per the MIB.
ipSystemStatsHCInReceives (1.3.6.1.2.1.4.31.1.1.4)
read-only
Counter64
This object counts the same packets as ipSystemStatsInReceives, but allows for larger values.
As per the MIB.
ipSystemStatsInOctets (1.3.6.1.2.1.4.31.1.1.5)
read-only
Counter32
Total octets of received IP packets in the system, including error packets.
Octets of packets counted in ipSystemStatsInReceives must be counted here.
As per the MIB.
ipSystemStatsHCInOctets (1.3.6.1.2.1.4.31.1.1.6)
read-only
Counter64
This object counts the same octets as ipSystemStatsInOctets, but allows for larger values.
As per the MIB.
ipSystemStatsInHdrErrors (1.3.6.1.2.1.4.31.1.1.7)
read-only
Counter32
Number of received IP packets that were dropped because of IP header errors, including version number mismatch, other format errors, hop count exceeded, and IP option processing errors.
As per the MIB.
ipSystemStatsInNoRoutes (1.3.6.1.2.1.4.31.1.1.8)
read-only
Counter32
Number of received IP packets that were dropped because of no route to the destination can be found.
As per the MIB.
ipSystemStatsInAddrErrors (1.3.6.1.2.1.4.31.1.1.9)
read-only
Counter32
Number of received IP packets that were dropped because of an invalid destination address in the IP header, for example, address 0.0.0.0.
For a non-IP gateway entity, it drops packets destined to any other devices because such entities cannot forward traffic.
As per the MIB.
ipSystemStatsInUnknownProtos (1.3.6.1.2.1.4.31.1.1.10)
read-only
Counter32
Number of received locally-addressed packets that were dropped because of an unknown or unsupported protocol.
As per the MIB.
ipSystemStatsInTruncatedPkts (1.3.6.1.2.1.4.31.1.1.11)
read-only
Counter32
Number of received IP packets that were dropped because of an invalid data length.
Not supported
ipSystemStatsInForwDatagrams (1.3.6.1.2.1.4.31.1.1.12)
read-only
Counter32
Number of forwarded packets.
Forwarded packets are those that are not locally-addressed and require the system to find a route to forward them.
For non-router devices, this counter counts only source-routed packets.
As per the MIB.
ipSystemStatsHCInForwDatagrams (1.3.6.1.2.1.4.31.1.1.13)
read-only
Counter64
This object counts the same packets as ipSystemStatsInForwDatagrams, but allows for larger values.
As per the MIB.
ipSystemStatsReasmReqds (1.3.6.1.2.1.4.31.1.1.14)
read-only
Counter32
Number of received fragments that need to be reassembled.
As per the MIB.
ipSystemStatsReasmOKs (1.3.6.1.2.1.4.31.1.1.15)
read-only
Counter32
Number of packets successfully reassembled.
As per the MIB.
ipSystemStatsReasmFails (1.3.6.1.2.1.4.31.1.1.16)
read-only
Counter32
Number of packet reassembly failures detected by the IP reassembly algorithm because of reasons such as timeout or errors.
The system does not calculate the number of dropped fragments because some algorithms do not record fragment quantity information.
As per the MIB.
ipSystemStatsInDiscards (1.3.6.1.2.1.4.31.1.1.17)
read-only
Counter32
Number of received packets that should be processed, but were dropped because of reasons such as insufficient buffer space.
This value does not include packet fragments dropped because of reassembly timeout.
As per the MIB.
ipSystemStatsInDelivers (1.3.6.1.2.1.4.31.1.1.18)
read-only
Counter32
Number of received packets successfully delivered to IP user-protocols.
As per the MIB.
ipSystemStatsHCInDelivers (1.3.6.1.2.1.4.31.1.1.19)
read-only
Counter64
This object counts the same packets as ipSystemStatsInDelivers, but allows for larger values.
Not supported
ipSystemStatsOutRequests (1.3.6.1.2.1.4.31.1.1.20)
read-only
Counter32
Number of packets that local IP user-protocols (including ICMP) supplied to IP in requests for transmission.
This counter does not include any packets counted in ipSystemStatsOutForwDatagrams.
As per the MIB.
ipSystemStatsHCOutRequests (1.3.6.1.2.1.4.31.1.1.21)
read-only
Counter64
This object counts the same packets as ipSystemStatsOutRequests, but allows for larger values.
Not supported
ipSystemStatsOutNoRoutes (1.3.6.1.2.1.4.31.1.1.22)
read-only
Counter32
Number of IP packets dropped because no route to the destination can be found.
As per the MIB.
ipSystemStatsOutForwDatagrams (1.3.6.1.2.1.4.31.1.1.23)
read-only
Counter32
Number of packets forwarded successfully.
As per the MIB.
ipSystemStatsHCOutForwDatagrams (1.3.6.1.2.1.4.31.1.1.24)
read-only
Counter64
This object counts the same packets as ipSystemStatsOutForwDatagrams, but allows for larger values.
As per the MIB.
ipSystemStatsOutDiscards (1.3.6.1.2.1.4.31.1.1.25)
read-only
Counter32
Number of outgoing packets that should be processed, but were dropped because of reasons such as insufficient buffer space.
This value might be included in the counting of ipSystemStatsOutForwDatagrams.
As per the MIB.
ipSystemStatsOutFragReqds (1.3.6.1.2.1.4.31.1.1.26)
read-only
Counter32
Number of IP packets that require fragmentation for forwarding.
As per the MIB.
ipSystemStatsOutFragOKs (1.3.6.1.2.1.4.31.1.1.27)
read-only
Counter32
Number of IP packets that were fragmented successfully.
As per the MIB.
ipSystemStatsOutFragFails (1.3.6.1.2.1.4.31.1.1.28)
read-only
Counter32
Number of IP packets that need fragmentation but were dropped because of fragmentation failures, including IPv4 packets with the DF flag set and IPv6 packets whose length exceeds the MTU size.
As per the MIB.
ipSystemStatsOutFragCreates (1.3.6.1.2.1.4.31.1.1.29)
read-only
Counter32
Number of packets created because of IP packet fragmentation.
As per the MIB.
ipSystemStatsOutTransmits (1.3.6.1.2.1.4.31.1.1.30)
read-only
Counter32
Number of IP packets supplied to the lower layers for transmission, including both locally generated packets and forwarded packets.
As per the MIB.
ipSystemStatsHCOutTransmits (1.3.6.1.2.1.4.31.1.1.31)
read-only
Counter64
This object counts the same packets as ipSystemStatsOutTransmits, but allows for larger values.
As per the MIB.
ipSystemStatsOutOctets (1.3.6.1.2.1.4.31.1.1.32)
read-only
Counter32
Total octets of IP packets supplied to the lower layers for transmission, including packets counted in ipSystemStatsOutTransmits.
As per the MIB.
ipSystemStatsHCOutOctets (1.3.6.1.2.1.4.31.1.1.33)
read-only
Counter64
Total octets of IP packets supplied to the lower layers for transmission.
This object counts the same octets as ipSystemStatsOutOctets, but allows for larger values.
As per the MIB.
ipSystemStatsInMcastPkts (1.3.6.1.2.1.4.31.1.1.34)
read-only
Counter32
Number of received IP multicast packets.
Not supported
ipSystemStatsHCInMcastPkts (1.3.6.1.2.1.4.31.1.1.35)
read-only
Counter64
This object counts the same packets as ipSystemStatsInMcastPkts, but allows for larger values.
Not supported
ipSystemStatsInMcastOctets (1.3.6.1.2.1.4.31.1.1.36)
read-only
Counter32
Total octets of received IP multicast packets, including packets counted in ipSystemStatsInMcastPkts.
Not supported
ipSystemStatsHCInMcastOctets (1.3.6.1.2.1.4.31.1.1.37)
read-only
Counter64
Total octets of received IP multicast packets.
This object counts the same octets as ipSystemStatsInMcastOctets, but allows for larger values.
Not supported
ipSystemStatsOutMcastPkts (1.3.6.1.2.1.4.31.1.1.38)
read-only
Counter32
Number of sent IP multicast packets.
Not supported
ipSystemStatsHCOutMcastPkts (1.3.6.1.2.1.4.31.1.1.39)
read-only
Counter64
This object counts the same packets as ipSystemStatsOutMcastPkts, but allows for larger values.
Not supported
ipSystemStatsOutMcastOctets (1.3.6.1.2.1.4.31.1.1.40)
read-only
Counter32
Total octets of sent IP multicast packets, including packets counted in ipSystemStatsOutMcastPkts.
Not supported
ipSystemStatsHCOutMcastOctets (1.3.6.1.2.1.4.31.1.1.41)
read-only
Counter64
Total octets of sent IP multicast packets.
This object counts the same octets as ipSystemStatsOutMcastOctets, but allows for larger values.
Not supported
ipSystemStatsInBcastPkts (1.3.6.1.2.1.4.31.1.1.42)
read-only
Counter32
Number of received IP broadcast packets.
Not supported
ipSystemStatsHCInBcastPkts (1.3.6.1.2.1.4.31.1.1.43)
read-only
Counter64
This object counts the same packets as ipSystemStatsInBcastPkts, but allows for larger values.
Not supported
ipSystemStatsOutBcastPkts (1.3.6.1.2.1.4.31.1.1.44)
read-only
Counter32
Number of sent IP broadcast packets.
Not supported
ipSystemStatsHCOutBcastPkts (1.3.6.1.2.1.4.31.1.1.45)
read-only
Counter64
This object counts the same packets as ipSystemStatsOutBcastPkts, but allows for larger values.
Not supported
ipSystemStatsDiscontinuityTime (1.3.6.1.2.1.4.31.1.1.46)
read-only
TimeStamp
The most recent time at which any count in the table was interrupted (sysUpTime).
If no count interrupt has occurred since the last system restart, the value of this object is 0.
Not supported
ipSystemStatsRefreshRate (1.3.6.1.2.1.4.31.1.1.47)
read-only
Unsigned32
Minimum reasonable polling interval for this table.
This object provides an indication of the minimum amount of time required to update the counters in this table.
Not supported
ipIfStatsTable
About this table
This table contains IP traffic statistics about each interface.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipIfStatsIPVersion and ipIfStatsIfIndex.
Object (OID)
Access
Value range
Implementation
ipIfStatsIPVersion (1.3.6.1.2.1.4.31.3.1.1)
not-accessible
InetVersion
ipIfStatsIfIndex (1.3.6.1.2.1.4.31.3.1.2)
not-accessible
InterfaceIndex
As per the MIB.
ipIfStatsInReceives (1.3.6.1.2.1.4.31.3.1.3)
read-only
Counter32
Number of received IP packets, including error packets.
The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object.
As per the MIB.
ipIfStatsHCInReceives (1.3.6.1.2.1.4.31.3.1.4)
read-only
Counter64
This object counts the same packets as ipIfStatsInReceives, but allows for larger values.
As per the MIB.
ipIfStatsInOctets (1.3.6.1.2.1.4.31.3.1.5)
read-only
Counter32
Total octets of received IP packets, including error packets.
Octets of packets counted in ipIfStatsInReceives must be counted here.
As per the MIB.
ipIfStatsHCInOctets (1.3.6.1.2.1.4.31.3.1.6)
read-only
Counter64
This objects counts the same octets as ipIfStatsInOctets, but allows for larger values.
As per the MIB.
ipIfStatsInHdrErrors (1.3.6.1.2.1.4.31.3.1.7)
read-only
Counter32
As per the MIB.
Supports only ipv6(2).
ipIfStatsInNoRoutes (1.3.6.1.2.1.4.31.3.1.8)
read-only
Counter32
As per the MIB.
ipIfStatsInAddrErrors (1.3.6.1.2.1.4.31.3.1.9)
read-only
Counter32
As per the MIB.
ipIfStatsInUnknownProtos (1.3.6.1.2.1.4.31.3.1.10)
read-only
Counter32
Number of received packets destined to the local IP address but dropped because of unsupported protocol or unknown reasons.
As per the MIB.
ipIfStatsInTruncatedPkts (1.3.6.1.2.1.4.31.3.1.11)
read-only
Counter32
As per the MIB.
ipIfStatsInForwDatagrams (1.3.6.1.2.1.4.31.3.1.12)
read-only
Counter32
As per the MIB.
ipIfStatsHCInForwDatagrams (1.3.6.1.2.1.4.31.3.1.13)
read-only
Counter64
This object counts the same packets as ipIfStatsInForwDatagrams, but allows for larger values.
As per the MIB.
ipIfStatsReasmReqds (1.3.6.1.2.1.4.31.3.1.14)
read-only
Counter32
As per the MIB.
ipIfStatsReasmOKs (1.3.6.1.2.1.4.31.3.1.15)
read-only
Counter32
As per the MIB.
ipIfStatsReasmFails (1.3.6.1.2.1.4.31.3.1.16)
read-only
Counter32
Number of packet reassembly failures detected by the IP reassembly algorithm because of reasons such as timeout and errors.
As per the MIB.
ipIfStatsInDiscards (1.3.6.1.2.1.4.31.3.1.17)
read-only
Counter32
As per the MIB.
ipIfStatsInDelivers (1.3.6.1.2.1.4.31.3.1.18)
read-only
Counter32
As per the MIB.
ipIfStatsHCInDelivers (1.3.6.1.2.1.4.31.3.1.19)
read-only
Counter64
This object counts the same packets as ipIfStatsInDelivers, but allows for larger values.
Not supported
ipIfStatsOutRequests (1.3.6.1.2.1.4.31.3.1.20)
read-only
Counter32
This counter does not include any packets counted in ipIfStatsOutForwDatagrams.
As per the MIB.
ipIfStatsHCOutRequests (1.3.6.1.2.1.4.31.3.1.21)
read-only
Counter64
This object counts the same packets as ipIfStatsOutRequests, but allows for larger values.
As per the MIB.
ipIfStatsOutForwDatagrams (1.3.6.1.2.1.4.31.3.1.23)
read-only
Counter32
As per the MIB.
ipIfStatsHCOutForwDatagrams (1.3.6.1.2.1.4.31.3.1.24)
read-only
Counter64
This object counts the same packets as ipIfStatsOutForwDatagrams, but allows for larger values.
As per the MIB.
ipIfStatsOutDiscards (1.3.6.1.2.1.4.31.3.1.25)
read-only
Counter32
This value might be included in the counting of ipIfStatsOutForwDatagrams.
As per the MIB.
ipIfStatsOutFragReqds (1.3.6.1.2.1.4.31.3.1.26)
read-only
Counter32
As per the MIB.
ipIfStatsOutFragOKs (1.3.6.1.2.1.4.31.3.1.27)
read-only
Counter32
As per the MIB.
ipIfStatsOutFragFails (1.3.6.1.2.1.4.31.3.1.28)
read-only
Counter32
As per the MIB.
ipIfStatsOutFragCreates (1.3.6.1.2.1.4.31.3.1.29)
read-only
Counter32
As per the MIB.
ipIfStatsOutTransmits (1.3.6.1.2.1.4.31.3.1.30)
read-only
Counter32
As per the MIB.
ipIfStatsHCOutTransmits (1.3.6.1.2.1.4.31.3.1.31)
read-only
Counter64
This object counts the same packets as ipIfStatsOutTransmits, but allows for larger values.
As per the MIB.
ipIfStatsOutOctets (1.3.6.1.2.1.4.31.3.1.32)
read-only
Counter32
Total octets of IP packets supplied to the lower layers for transmission, including packets counted in ipIfStatsOutTransmits.
As per the MIB.
ipIfStatsHCOutOctets (1.3.6.1.2.1.4.31.3.1.33)
read-only
Counter64
This object counts the same octets as ipIfStatsOutOctets, but allows for larger values.
As per the MIB.
ipIfStatsInMcastPkts (1.3.6.1.2.1.4.31.3.1.34)
read-only
Counter32
As per the MIB.
ipIfStatsHCInMcastPkts (1.3.6.1.2.1.4.31.3.1.35)
read-only
Counter64
This object counts the same packets as ipIfStatsInMcastPkts, but allows for larger values.
Not supported
ipIfStatsInMcastOctets (1.3.6.1.2.1.4.31.3.1.36)
read-only
Counter32
Total octets of received IP multicast packets, including packets counted in ipIfStatsInMcastPkts.
Not supported
ipIfStatsHCInMcastOctets (1.3.6.1.2.1.4.31.3.1.37)
read-only
Counter64
This object counts the same octets as ipIfStatsInMcastOctets, but allows for larger values.
Not supported
ipIfStatsOutMcastPkts (1.3.6.1.2.1.4.31.3.1.38)
read-only
Counter32
As per the MIB.
ipIfStatsHCOutMcastPkts (1.3.6.1.2.1.4.31.3.1.39)
read-only
Counter64
This object counts the same packets as ipIfStatsOutMcastPkts, but allows for larger values.
Not supported
ipIfStatsOutMcastOctets (1.3.6.1.2.1.4.31.3.1.40)
read-only
Counter32
Total octets of sent IP multicast packets, including packets counted in ipIfStatsOutMcastPkts.
Not supported
ipIfStatsHCOutMcastOctets (1.3.6.1.2.1.4.31.3.1.41)
read-only
Counter64
This object counts the same octets as ipIfStatsOutMcastOctets, but allows for larger values.
Not supported
ipIfStatsInBcastPkts (1.3.6.1.2.1.4.31.3.1.42)
read-only
Counter32
Not supported
ipIfStatsHCInBcastPkts (1.3.6.1.2.1.4.31.3.1.43)
read-only
Counter64
This object counts the same packets as ipIfStatsInBcastPkts, but allows for larger values.
Not supported
ipIfStatsOutBcastPkts (1.3.6.1.2.1.4.31.3.1.44)
read-only
Counter32
Not supported
ipIfStatsHCOutBcastPkts (1.3.6.1.2.1.4.31.3.1.45)
read-only
Counter64
This object counts the same packets as ipIfStatsOutBcastPkts, but allows for larger values.
Not supported
ipIfStatsDiscontinuityTime (1.3.6.1.2.1.4.31.3.1.46)
read-only
TimeStamp
Not supported
ipIfStatsRefreshRate (1.3.6.1.2.1.4.31.3.1.47)
read-only
Unsigned32
Not supported
ipAddressPrefixTable
About this table
This table contains information about IP address prefixes.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipAddressPrefixIfIndex, ipAddressPrefixType, ipAddressPrefixPrefix, and ipAddressPrefixLength.
Object (OID)
Access
Value range
Implementation
ipAddressPrefixIfIndex (1.3.6.1.2.1.4.32.1.1)
not-accessible
InterfaceIndex
As per the MIB.
ipAddressPrefixType (1.3.6.1.2.1.4.32.1.2)
not-accessible
InetAddressType
Address type of ipAddressPrefix.
Supports only ipv6(2) and ipv6z(4).
ipAddressPrefixPrefix (1.3.6.1.2.1.4.32.1.3)
not-accessible
InetAddress
Address prefix.
The address type is specified in ipAddressPrefixType.
The address length is the standard length for objects of that type (4 or 16 bytes).
If the prefix length exceeds 114 octets, then OIDs of the instances will have more than 128 sub-identifiers and cannot be accessed by using SNMPv1, SNMPv2c, or SNMPv3.
As per the MIB.
ipAddressPrefixLength (1.3.6.1.2.1.4.32.1.4)
not-accessible
InetAddressPrefixLength
Prefix length.
The value 0 refers to address ::/0.
As per the MIB.
ipAddressPrefixOrigin (1.3.6.1.2.1.4.32.1.5)
read-only
IpAddressPrefixOriginTC
Other(1)
Manual(2)
Wellknown(3)
Dhcp(4)
Routeready(5)
Prefix origin.
As per the MIB.
ipAddressPrefixOnLinkFlag (1.3.6.1.2.1.4.32.1.6)
read-only
TruthValue
true(1),
false(2)
Whether this prefix can be used for on-link determination. The value true(1) indicates yes and the value false(2) indicates no.
For IPv4 prefixes, the default value is true(1).
As per the MIB.
ipAddressPrefixAutonomousFlag (1.3.6.1.2.1.4.32.1.7)
read-only
TruthValue
true(1),
false(2)
Whether this prefix can be used for autonomous address configuration.
For IPv4 prefixes, the default value is false(2).
As per the MIB.
ipAddressPrefixAdvPreferredLifetime (1.3.6.1.2.1.4.32.1.8)
read-only
Unsigned32
Remaining lifetime of the prefix in seconds.
A value of 4,294,967,295 represents infinity.
After the lifetime expires, the prefix will be deprecated. Addresses generated by using a deprecated prefix cannot be used as the source addresses in new communications, but packets received on such an interface are processed as expected.
For IPv4 prefixes, the default lifetime is 4,294,967,295 (infinity).
As per the MIB.
ipAddressPrefixAdvValidLifetime (1.3.6.1.2.1.4.32.1.9)
read-only
Unsigned32
Remaining validity period of the prefix in seconds.
Addresses generated by using an invalid prefix cannot be used as source or destination addresses of packets.
For IPv4 prefixes, the default validity period is 4,294,967,295 (infinity).
As per the MIB.
ipAddressTable
About this table
This table contains IP address information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipAddressAddrType and ipAddressAddr.
Object (OID)
Access
Value range
Implementation
ipAddressAddrType (1.3.6.1.2.1.4.34.1.1)
not-accessible
InetAddressType
Address type of ipAddressAddr.
ipAddressAddr (1.3.6.1.2.1.4.34.1.2)
not-accessible
InetAddress
IP address.
The address type is specified in ipAddressAddrType.
If the address length exceeds 116 octets, then OIDs of the instances will have more than 128 sub-identifiers and cannot be accessed by using SNMPv1, SNMPv2c, or SNMPv3.
As per the MIB.
ipAddressIfIndex (1.3.6.1.2.1.4.34.1.3)
read-create
InterfaceIndex
Index of the interface corresponding to the address.
ipAddressType (1.3.6.1.2.1.4.34.1.4)
read-create
INTEGER
unicast(1),
anycast(2),
broadcast(3)
Address type.
For IPv6 addresses, broadcast(3) is not a valid value.
ipAddressPrefix (1.3.6.1.2.1.4.34.1.5)
read-only
RowPointer
A pointer to the row in the prefix table to which this address belongs.
If the row does not exist, this object is { 0 0 }.
As per the MIB.
ipAddressOrigin (1.3.6.1.2.1.4.34.1.6)
read-only
IpAddressOriginTC
IP address origin.
As per the MIB.
ipAddressStatus (1.3.6.1.2.1.4.34.1.7)
read-create
IpAddressStatusTC
Address status, indicating whether the address can be used for communication.
In the absence of other information, an IPv4 address is always preferred(1).
ipAddressCreated (1.3.6.1.2.1.4.34.1.8)
read-only
TimeStamp
Time at which the entry was created (sysUpTime).
If the entry was created before the most recent system startup, this value is 0.
As per the MIB.
ipAddressLastChanged (1.3.6.1.2.1.4.34.1.9)
read-only
TimeStamp
Time at which the entry was last updated (sysUpTime).
If the last update occurred before the most recent system startup, this value is 0.
As per the MIB.
ipAddressRowStatus (1.3.6.1.2.1.4.34.1.10)
read-create
RowStatus
Status of the entry.
Supports only active(1).
ipAddressStorageType (1.3.6.1.2.1.4.34.1.11)
read-create
StorageType
Storage type of the entry.
The value is fixed to volatile(2).
ipNetToPhysicalTable
About this table
This table contains IP address-to-physical address mappings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipNetToPhysicalIfIndex, ipNetToPhysicalNetAddressType, and ipNetToPhysicalNetAddress.
Object (OID)
Access
Value range
Implementation
ipNetToPhysicalIfIndex (1.3.6.1.2.1.4.35.1.1)
not-accessible
InterfaceIndex
As per the MIB.
ipNetToPhysicalNetAddressType (1.3.6.1.2.1.4.35.1.2)
not-accessible
InetAddressType
Address type of ipNetToPhysicalNetAddress.
ipNetToPhysicalNetAddress (1.3.6.1.2.1.4.35.1.3)
not-accessible
InetAddress
IP address.
The address type is specified in ipNetToPhysicalAddressType.
As per the MIB.
ipNetToPhysicalPhysAddress (1.3.6.1.2.1.4.35.1.4)
read-create
PhysAddress
SIZE(0..65535)
Physical address.
ipNetToPhysicalLastUpdated (1.3.6.1.2.1.4.35.1.5)
read-only
TimeStamp
As per the MIB.
ipNetToPhysicalType (1.3.6.1.2.1.4.35.1.6)
read-create
INTEGER
other(1),
invalid(2),
dynamic(3),
static(4),
local(5)
Address mapping type.
ipNetToPhysicalState (1.3.6.1.2.1.4.35.1.7)
read-only
INTEGER
reachable(1),
stale(2),
delay(3),
probe(4),
invalid(5),
unknown(6),
incomplete(7)
Neighbor unreachability detection state.
If neighbor unreachability detection is not performed, the value is unknown(6).
As per the MIB.
ipNetToPhysicalRowStatus (1.3.6.1.2.1.4.35.1.8)
read-create
RowStatus
ipDefaultRouterTable
About this table
This table contains information about the default routers.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipDefaultRouterAddressType, ipDefaultRouterAddress, and ipDefaultRouterIfIndex.
Object (OID)
Access
Value range
Implementation
ipDefaultRouterAddressType (1.3.6.1.2.1.4.37.1.1)
not-accessible
InetAddressType
Address type of the entry.
ipDefaultRouterAddress (1.3.6.1.2.1.4.37.1.2)
not-accessible
InetAddress
IP address.
The address type is specified in ipDefaultRouterAddressType.
If the address length exceeds 115 octets, then OIDs of the instances will have more than 128 sub-identifiers and cannot be accessed by using SNMPv1, SNMPv2c, or SNMPv3.
As per the MIB.
ipDefaultRouterIfIndex (1.3.6.1.2.1.4.37.1.3)
not-accessible
InterfaceIndex
As per the MIB.
ipDefaultRouterLifetime (1.3.6.1.2.1.4.37.1.4)
read-only
Unsigned32
Unsigned32 (0..65535)
Remaining time that the router can be used as a default router, in seconds.
A value of 0 indicates that the router is no longer used as a default router.
As per the MIB.
ipDefaultRouterPreference (1.3.6.1.2.1.4.37.1.5)
read-only
INTEGER
reserved (-2),
low (-1),
medium (0),
high (1)
Priority of the default router.
The priority value is a 2-bit signed integer that allows for simple arithmetic comparisons.
As per the MIB.
ipv6RouterAdvertTable
About this table
This table contains information used to construct router advertisements.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is ipv6RouterAdvertIfIndex.
Object (OID)
Access
Value range
Implementation
ipv6RouterAdvertIfIndex (1.3.6.1.2.1.4.39.1.1)
not-accessible
InterfaceIndex
As per the MIB.
ipv6RouterAdvertSendAdverts (1.3.6.1.2.1.4.39.1.2)
read-create
TruthValue
A flag indicating whether the router sends periodic router advertisements and responds to router solicitations.
ipv6RouterAdvertMaxInterval (1.3.6.1.2.1.4.39.1.3)
read-create
Unsigned32
Unsigned32 (4..1800)
Maximum interval at which unsolicited router advertisements are sent, in seconds.
ipv6RouterAdvertMinInterval (1.3.6.1.2.1.4.39.1.4)
read-create
Unsigned32
Unsigned32 (3..1350)
Minimum interval at which unsolicited router advertisements are sent, in seconds.
ipv6RouterAdvertManagedFlag (1.3.6.1.2.1.4.39.1.5)
read-create
TruthValue
Value to be placed into the 'managed address configuration' flag field in router advertisements to send.
ipv6RouterAdvertOtherConfigFlag (1.3.6.1.2.1.4.39.1.6)
read-create
TruthValue
Value to be placed into the 'other stateful configuration' flag field in router advertisements to send.
ipv6RouterAdvertLinkMTU (1.3.6.1.2.1.4.39.1.7)
read-create
Unsigned32
Value to be placed in MTU options to send.
A value of zero indicates that no MTU options are sent.
ipv6RouterAdvertReachableTime (1.3.6.1.2.1.4.39.1.8)
read-create
Unsigned32
Unsigned32 (0..3600000)
Value to be placed in the reachable time field in router advertisement messages to send.
A value of zero indicates that no reachable time is specified.
ipv6RouterAdvertRetransmitTime (1.3.6.1.2.1.4.39.1.9)
read-create
Unsigned32
Value to be placed in the retransmit time field in router advertisements to send.
A value of zero indicates that no retransmit time is specified.
ipv6RouterAdvertCurHopLimit (1.3.6.1.2.1.4.39.1.10)
read-create
Unsigned32
Unsigned32 (0..255)
Value to be placed in the current hop limit field in router advertisements to send.
A value of zero indicates that the hops are not limited.
ipv6RouterAdvertDefaultLifetime (1.3.6.1.2.1.4.39.1.11)
read-create
Unsigned32
Unsigned32 (0|4..9000)
Value to be placed in the router lifetime field of router advertisements to send.
A value of zero indicates that the router is no longer used as a default router.
The default value is the ipv6RouterAdvertMaxInterval value multiplied by three.
ipv6RouterAdvertRowStatus (1.3.6.1.2.1.4.39.1.12)
read-create
RowStatus
icmpStatsTable
About this table
This table contains system-level ICMP statistics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is icmpStatsIPVersion.
Object (OID)
Access
Value range
Implementation
icmpStatsIPVersion (1.3.6.1.2.1.5.29.1.1)
not-accessible
InetVersion
IP version of the statistics.
icmpStatsInMsgs (1.3.6.1.2.1.5.29.1.2)
read-only
Counter32
Number of received ICMP messages, including messages counted by icmpStatsInErrors.
As per the MIB.
icmpStatsInErrors
(1.3.6.1.2.1.5.29.1.3)
read-only
Counter32
Number of received ICMP error messages.
Possible errors include ICMP checksum error and length error.
As per the MIB.
icmpStatsOutMsgs (1.3.6.1.2.1.5.29.1.4)
read-only
Counter32
Number of sent ICMP messages, including messages counted by icmpStatsOutErrors.
As per the MIB.
icmpStatsOutErrors (1.3.6.1.2.1.5.29.1.5)
read-only
Counter32
Number of ICMP messages failed to be sent because of reasons such as insufficient buffer space.
Errors occurred outside the ICMP layer are not included.
In some implementations, there may be no types of error which contribute to this counter's value.
The value is fixed to 0.
icmpMsgStatsTable
About this table
This table contains statistics about each IP version and each ICMP message type.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are icmpMsgStatsIPVersion and icmpMsgStatsType.
Object (OID)
Access
Value range
Implementation
icmpMsgStatsIPVersion (1.3.6.1.2.1.5.30.1.1)
not-accessible
InetVersion
icmpMsgStatsType (1.3.6.1.2.1.5.30.1.2)
not-accessible
Integer32
Integer32 (0..255)
ICMP message type.
As per the MIB.
icmpMsgStatsInPkts (1.3.6.1.2.1.5.30.1.3)
read-only
Counter32
Number of received ICMP messages of the type.
As per the MIB.
icmpMsgStatsOutPkts (1.3.6.1.2.1.5.30.1.4)
read-only
Counter32
Number of sent ICMP messages of the type.
As per the MIB.
