04-Interface
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R8530Pxx-6W10004-Interface
03-HH3C-TRAFFIC-STAT-MIB
03-HH3C-TRAFFIC-STAT-MIB 56.63 KB
About this MIB
This MIB monitors and manages cards.
MIB file name
hh3c-traffic-stat.mib
Notifications
hh3cTSSlotMonPacketDropRising
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.222.3.0.1
The number of dropped packets reaches the high threshold.
Error
Major
1.3.6.1.4.1.25506.2.222.3.0.2 (hh3cTSSlotMonPacketDropResume)
ON
Notification triggers
This notification is generated when the number of dropped packets reaches the high threshold during the specified time.
Possible reasons for this issue include:
The high threshold is set too low.
Physical link failures are present on some interfaces.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable slot-monitor packet-drop command.
OFF
CLI: Use the undo snmp-agent trap enable slot-monitor packet-drop command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.222.1.1.1.1.1 (hh3cTSFrameIndex)
Frame index.
hh3cTSFrameIndex
Integer32
0-65535
1.3.6.1.4.1.25506.2.222.1.1.1.1.2 (hh3cTSSlotIndex)
Slot index.
hh3cTSSlotIndex
Integer32
0-65535
1.3.6.1.4.1.25506.2.222.2.1.1.1.1 (hh3cTSSlotMonPacketDropStatistics)
Packet drop statistics.
N/A
CounterBasedGauge64
1-4294967295
1.3.6.1.4.1.25506.2.222.2.2.1.1.1 (hh3cTSSlotMonPacketDropLowThres)
Low threshold.
N/A
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.222.2.2.1.1.2 (hh3cTSSlotMonPacketDropHighThres)
High threshold.
N/A
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.222.2.2.1.1.3 (hh3cTSSlotMonPacketDropInterval)
Interval for reporting threshold exceeding events.
N/A
Unsigned32
0-65535
Recommended action
To resolve the issue:
1.Check if physical interfaces on the card have a link failure.
  - If a link failure is present, fix the issue to recover the link.
  - If no link failure is present, proceed to step 2.
2.Check if the high threshold is set too low. If it is set reasonably, proceed to step 3.
3.If the issue persists, collect alarm and configuration information, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
The number of dropped packets falls below the low threshold.
Recovery
Major
ON
This notification is generated when the number of dropped packets falls below the low threshold during the specified time.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Frame index.
hh3cTSFrameIndex
Integer32
0-65535
Slot index.
hh3cTSSlotIndex
Integer32
0-65535
N/A
CounterBasedGauge64
1-4294967295
Low threshold.
N/A
Unsigned32
1-4294967295
High threshold.
N/A
Unsigned32
1-4294967295
N/A
Unsigned32
0-65535
Recommended action
No action is required.
