14-User Access and Authentication
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R8530Pxx-6W10014-User Access and Authentication
04-HH3C-PORT-SECURITY-MIB
04-HH3C-PORT-SECURITY-MIB 114.95 KB
About this MIB
Use this MIB to configure port security feature settings, obtain user information, and report trap notifications.
MIB file name
hh3c-port-security.mib
Notifications
hh3cSecureAddressLearned
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506. 2.26.1.3.1
A new secure MAC address was learned.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when a new secure MAC address is learned.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable port-security address-learned command.
OFF
CLI: Use the undo snmp-agent trap enable port-security address-learned command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Port index.
ifIndex
INTEGER
INTEGER (1.. 2147483647)
1.3.6.1.4.1.25506.2.26.1.2.2.1.1 (hh3cSecureAddrMAC)
Learned MAC address on a port.
ifIndex
hh3cSecureAddrMAC
hh3cSecureAddrVlanID
MacAddress
Standard MIB values.
Recommended action
No action is required.
hh3cSecureViolation
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.2
Intrusion protection event occurred.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a port receives illegal frames whose source MAC address has not been learned by the port or that fail to pass authentication after you enable intrusion protection.
System impact
The system might be attacked by illegal frames if too many intrusion protection events occur.
Status control
ON
CLI: Use the snmp-agent trap enable port-security intrusion command.
OFF
CLI: Use the undo snmp-agent trap enable port-security intrusion command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
Integer32 (1.. 2147483647)
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
1.3.6.1.2.1.2.2.1.7 (ifAdminStatus)
Link layer status.
ifIndex
INTEGER
up(1) , down(2) , testing(3)
Recommended action
To resolve this issue:
1.Verify that 802.1X authentication, MAC authentication, and secure MAC addresses are configured correctly.
2.Execute the display dot1x, display mac-authentication, and display port-security mac-address security commands in any view to identify whether the number of online users or secure MAC addresses on the port has reached the upper limit.
  - If the number of online users or learned secure MAC addresses on the port has reached the upper limit and the upper limit is too small, change the upper limit.
  - If the numbers of online users and learned secure MAC addresses on the port hasn't reached the upper limit and intrusion protections events occur only occasionally, no action is required.
3.If many intrusion protection events occur, the system might be attacked. In this case, contact Technical Support.
hh3cSecureLoginFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.3
An 802.1X user failed authentication.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an 802.1X user fails authentication.
System impact
The system might be attacked by many authentication packets if too many notifications are generated.
Status control
ON
CLI: Use the snmp-agent trap enable port-security dot1x-failure command.
OFF
CLI: Use the undo snmp-agent trap enable port-security dot1x-failure command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
InterfaceIndex
Integer32 (1..2147483647)
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
1.0.8802.1.1.1.1.2.4.1.9 (dot1xAuthSessionUserName)
Username of an 802.1X authentication user.
SnmpAdminString
OCTET STRING (SIZE (0..255))
Recommended action
1.Verify that 802.1X authentication settings are correct.
2.Execute the dot1x access-user log enable failed-login command to enable logging 802.1X user login failures to identify authentication failure cause. Edit the device or server configuration as needed if an authentication failure is caused by device or server configuration errors, for example:
  - The authentication methods configured for the device and the server are different.
  - The username is not added to the server.
  - The username or password is incorrect.
3.If the system repeatedly generates this notification and the authentication failure log shows that one or multiple 802.1X users continuously failed to pass authentication, the system might be attacked by authentication packets. In this case, contact Technical Support.
hh3cSecureLogon
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.4
An 802.1X user logged on.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an 802.1X user logs on.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security dot1x-logon command.
OFF
CLI: Use the undo snmp-agent trap enable port-security dot1x-logon command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
SnmpAdminString
OCTET STRING(SIZE (0..255))
1.0.8802.1.1.1.1.2.4.1.6 (dot1xAuthSessionAuthenticMethod)
Authentication method.
INTEGER
remoteAuthServer(1) , localAuthServer(2)
1.3.6.1.4.1.25506.2.26.1.1.2 (hh3cSecurePortVlanMembershipList)
VLAN membership assigned to the port on session activation.
N/A
DisplayString
OCTET STRING (0..255)
Recommended action
hh3cSecureLogoff
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.26.1.3.5
An 802.1X user logged off.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when an 802.1X user logs off.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security dot1x-logoff command.
OFF
CLI: Use the undo snmp-agent trap enable port-security dot1x-logoff command.
Object
OID (object name)
Index
Value range
Port index
ifIndex
Integer32
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
SnmpAdminString
OCTET STRING(SIZE (0.. 255))
1.0.8802.1.1.1.1.2.4.1.8 (dot1xAuthSessionTerminateCause)
802.1X session termination cause.
INTEGER
supplicantLogoff(1) , portFailure(2) , supplicantRestart(3) , reauthFailed(4) , authControlForceUnauth(5)  portReInit(6) , portAdminDisabled(7) , notTerminatedYet(999)
VLAN membership assigned to the port on session termination.
N/A
DisplayString
Recommended action
hh3cSecureRalmLoginFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.26.1.3.6
A MAC authentication user failed authentication.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a MAC authentication user fails authentication.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security mac-auth-failure command.
OFF
CLI: Use the undo snmp-agent trap enable port-security mac-auth-failure command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
1.3.6.1.4.1.25506.2.26.1.1.4.4 (hh3cSecureRalmAuthMode)
MAC authentication user account format.
N/A
INTEGER
papUsernameAsMacAddress(1) , papUsernameFixed(2)
1.3.6.1.4.1.25506.2.26.1.1.4.5 (hh3cSecureRalmAuthUsername)
Username of a MAC authentication user.
N/A
DisplayString
OCTET STRING (1..80)
Recommended action
1.Verify that MAC authentication settings are correct.
2.Execute the mac-authentication access-user log enable failed-login command to enable logging MAC authentication user login failures to identify authentication failure cause. Edit the device or server configuration as needed if an authentication failure is caused by device or server configuration errors, for example:
3.If the system repeatedly generates this notification and the authentication failure log shows that users from different MAC addresses continuously failed to pass authentication, the system might be attacked by authentication packets. In this case, contact Technical Support.
hh3cSecureRalmLogon
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.7
A MAC authentication user logged on.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a MAC authentication user logs on.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security mac-auth-logon command.
OFF
CLI: Use the undo snmp-agent trap enable port-security mac-auth-logon command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
N/A
INTEGER
papUsernameAsMacAddress(1)  papUsernameFixed(2)
N/A
DisplayString
N/A
DisplayString
Recommended action
hh3cSecureRalmLogoff
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506. 2.26.1.3.8
A MAC authentication user logged off.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when a MAC authentication user logs off.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable port-security mac-auth-logoff command.
OFF
CLI: Use the undo snmp-agent trap enable port-security mac-auth-logoff command.
Object
OID (object name)
Index
Value range
Port index.
ifIndex
Integer32
Integer32 (0..2147483647)
User MAC address.
ifIndex
hh3cSecureAddrMAC
MacAddress
N/A
INTEGER
Username of an MAC authentication user.
N/A
DisplayString
N/A
DisplayString
Recommended action
