01-HH3C-GRPC-MIB | 93.19 KB |
HH3C-GRPC-MIB
About this MIB
Use this MIB to obtain and manage gRPC information.
MIB file name
hh3c-grpc.mib
Notifications
hh3cGrpcLogin
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.259.2.0.1 |
A gRPC user logged in successfully. |
Informational |
Informational |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when a gRPC user logs in successfully.
System impact
No negative impact on the system.
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.259.1.1.1 (hh3cGrpcUserName) |
Username of the gRPC user. |
N/A |
DisplayString |
OCTET STRING (1..80) |
1.3.6.1.4.1.25506.2.259.1.1.2 (hh3cGrpcUserIPAddressType) |
IP version of the gRPC user. |
N/A |
InetAddressType |
Standard MIB values. |
1.3.6.1.4.1.25506.2.259.1.1.3 (hh3cGrpcUserIPAddress) |
IP address of the gRPC user. |
N/A |
InetAddress |
1.3.6.1.4.1.25506.2.259.1.1.4 (hh3cGrpcSessionId) |
Session ID of the gRPC user. |
N/A |
Integer32 |
Recommended action
No action is required.
hh3cGrpcLoginFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.259.2.0.2 |
A gRPC user failed to log in. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when a gRPC user fails to log in.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
DisplayString |
N/A |
InetAddressType |
N/A |
InetAddress |
Recommended action
To resolve this issue, check the username and password of the gRPC user and check whether the number of gRPC sessions reaches the threshold.
hh3cGrpcLogout
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.259.2.0.3 |
A gRPC user logged out successfully. |
Informational |
Informational |
N/A (N/A) |
ON |
This notification is generated when a gRPC user logs out successfully.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
DisplayString |
1.3.6.1.4.1.25506.2.259.1.1.2 (hh3cGrpcSessionId) |
N/A |
Integer32 |
Recommended action
hh3cGrpcServerFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.259.2.0.4 |
Failed to enable the gRPC service. |
Informational |
Major |
N/A (N/A) |
ON |
This notification is generated when the gRPC service fails to be enabled.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.259.1.1.1 (hh3cGrpcTrapDescription) |
gRPC SNMP notification description (the same as the log message). |
N/A |
DisplayString |
Recommended action
Due to port conflict, a connection fails to be established with the gRPC server. To resolve this issue, check whether the listening port for the gRPC service has been used.
hh3cGrpcServiceStop
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.259.2.0.5 |
gRPC sampling stopped. |
Error |
Major |
1.3.6.1.4.1.25506.2.259.2.0.6 (hh3cGrpcServiceRecover) |
ON |
This notification is generated when sampling stops because the CPU usage of gRPC exceeds the value set by the grpc cpu-usage max-percent command.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
DisplayString |
Recommended action
Reduce sensor paths or set a large sampling interval.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.259.2.0.6 |
gRPC sampling recovered. |
Recovery |
Major |
N/A (N/A) |
ON |
This notification is generated when sampling recovers because the CPU usage of gRPC drops below or reaches the value set by the grpc cpu-usage max-percent command.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
DisplayString |
Recommended action
hh3cGrpcSubscribeEventFailure
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.259.2.0.7 |
Event subscription failed. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when event subscription fails.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.259.1.1.1 (hh3cGrpcEventName) |
Event name. |
N/A |
DisplayString |
Recommended action
hh3cGrpcReceiveSubscription
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.259.2.0.8 |
The device received a subscription request for a module. |
Informational |
Informational |
N/A (N/A) |
ON |
This notification is generated when the device receives a subscription request for a module.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.259.1.1.1 (hh3cGrpcModuleName) |
Module name. |
N/A |
DisplayString |
Recommended action
