11-MPLS
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10011-MPLS
15-MPLS-FRR-GENERAL-STD-MIB
15-MPLS-FRR-GENERAL-STD-MIB 85.91 KB
About this MIB
Use this MIB to manage associations between outgoing interfaces and bypass tunnels for FRR.
MIB file name
rfc6445-mpls-frr-general-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).mplsFrrGeneralMIB(202)
Scalar objects
mplsFrrGeneralProtectionMethod (1.3.6.1.2.1.202.1.1)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
unknown(1)
oneToOneBackup(2)
facilityBackup(3)
FRR protection method supported by the device.
Supports only the read operation.
Supports only facilityBackup(3).
Tabular objects
mplsFrrGeneralConstraintsTable
About this table
This table specifies the FRR bypass tunnel setup constraints.
Support for operations
CreateBefore the create operation, make sure the bypass tunnel identified by mplsFrrGeneralConstraintsTunnelIndex already exists.
The value for mplsFrrGeneralConstraintsTunnelInstance must be 0.
The mplsFrrGeneralConstraintsBandwidth object indicates the bandwidth reserved for a bypass tunnel, and it supports only CT0. If you do not specify this object, the default value 0 is used, indicating that the bypass tunnel provides bandwidth protection in best effort mode. For a bypass tunnel to provide guaranteed bandwidth protection, you must specify a specific bandwidth value for this object.
Edit/ModifyNot supported
DeleteSupported
ReadThe mplsFrrGeneralConstraintsBandwidth object displays no CT information or displays CT0 bandwidth. For other CTs, this object displays 0.
Columns
The table indexes are mplsFrrFacilityProtectedIfIndex, mplsFrrFacilityProtectingTunnelIndex, mplsFrrFacilityBackupTunnelIndex, mplsFrrFacilityBackupTunnelInstance, and mplsFrrFacilityBackupTunnelIngressLSRId.
Object (OID)
Access
Value range
Implementation
mplsFrrGeneralConstraintsIfIndexOrZero (1.3.6.1.2.1.202.1.3.1.1)
not-accessible
Integer32
Integer32
(0..2147483647)
Index of an interface to be protected by an FRR bypass tunnel.
As per the MIB.
mplsFrrGeneralConstraintsTunnelIndex (1.3.6.1.2.1.202.1.3.1.2)
not-accessible
MplsTunnelIndex
Gauge
(0..65535)
Index of the bypass tunnel.
As per the MIB.
mplsFrrGeneralConstraintsTunnelInstance (1.3.6.1.2.1.202.1.3.1.3)
not-accessible
MplsTunnelInstanceIndex
Gauge
(0..65535)
ID of a protected tunnel instance.
Supports only 0 for a set operation.
mplsFrrGeneralConstraintsProtectionType (1.3.6.1.2.1.202.1.3.1.4)
read-create
Integer32
linkProtection(1)
nodeProtection(2)
Protection method.
Supports only nodeProtection(2).
mplsFrrGeneralConstraintsSetupPrio (1.3.6.1.2.1.202.1.3.1.5)
read-create
Unsigned32
Unsigned32
(0..7)
Bypass tunnel setup priority.
mplsFrrGeneralConstraintsHoldingPrio (1.3.6.1.2.1.202.1.3.1.6)
read-create
Unsigned32
Unsigned32
(0..7)
Bypass tunnel holding priority.
mplsFrrGeneralConstraintsInclAnyAffinity (1.3.6.1.2.1.202.1.3.1.7)
read-create
Unsigned32
Unsigned32
(0..65535)
The include-any constraint for the bypass tunnel.
mplsFrrGeneralConstraintsInclAllAffinity (1.3.6.1.2.1.202.1.3.1.8)
read-create
Unsigned32
Unsigned32
(0..65535)
The include-all constraint for the bypass tunnel.
mplsFrrGeneralConstraintsExclAnyAffinity (1.3.6.1.2.1.202.1.3.1.9)
read-create
Unsigned32
Unsigned32(0..2147483647)
The exclude-any constraint for the bypass tunnel.
mplsFrrGeneralConstraintsHopLimit (1.3.6.1.2.1.202.1.3.1.10)
read-create
Unsigned32
Unsigned32
(0..255)
Maximum number of hops that the bypass tunnel can traverse.
Not supported.
The value is always 255.
mplsFrrGeneralConstraintsBandwidth (1.3.6.1.2.1.202.1.3.1.11)
read-create
Unsigned32
Unsigned32
(0..2147483647)
Bandwidth reserved for the bypass tunnel to provide bandwidth protection.
Supports only CT0 bandwidth.
mplsFrrGeneralConstraintsStorageType (1.3.6.1.2.1.202.1.3.1.12)
read-create
Integer32
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)}
Storage type.
Not supported.
The value is always nonvolatile(3).
mplsFrrGeneralConstraintsRowStatus (1.3.6.1.2.1.202.1.3.1.13)
read-create
Integer32
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
mplsFrrGeneralTunnelARHopTable
About this table
Use this table to obtain AR hop information for FRR protected tunnels.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
mplsFrrGeneralTunnelARHopSessionAttributeFlags (1.3.6.1.2.1.202.1.4.1.1)
read-only
BITS
arHopSessionAttrFlagsUnsupported(0)
localProtectionDesired(1)
labelRecordingDesired(2)
sestyleDesired(3)
bandwidthProtectionDesired(4)
nodeProtectionDesired(5)
Values for the SESSION_ATTRIBUTE flags.
As per the MIB.
mplsFrrGeneralTunnelARHopRROSubObjectFlags (1.3.6.1.2.1.202.1.4.1.2)
read-only
BITS
arHopRROSubObjectFlagsUnsupported(0)
localProtectionAvailable(1)
localProtectionInUse(2)
bandwidthProtection(3)
nodeProtection(4)
Flags that are currently in use by the associated Record Route Object (RRO)
sub-object.
As per the MIB.
