08-Layer 3 - IP Services
HomeSupportRoutersH3C SR8800-X Router SeriesReference GuidesMIB CompanionH3C SR8800-X Routers MIB Reference-R8530Pxx-6W10008-Layer 3 - IP Services
16-HH3C-TCP-MIB
16-HH3C-TCP-MIB 159.26 KB
HH3C-TCP-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cTcpConnLocalAddressTCP (1.3.6.1.4.1.25506.2.215.1.1.1) 1
hh3cTcpConnLocalPortTCP (1.3.6.1.4.1.25506.2.215.1.1.2) 1
hh3cTcpConnRemAddressTCP (1.3.6.1.4.1.25506.2.215.1.1.3) 1
hh3cTcpConnRemPortTCP (1.3.6.1.4.1.25506.2.215.1.1.4) 2
hh3cTcpProtocol (1.3.6.1.4.1.25506.2.215.1.1.5) 2
hh3cTcpVrfNameVRF (1.3.6.1.4.1.25506.2.215.1.1.6) 2
hh3cTcpNumExceedState (1.3.6.1.4.1.25506.2.215.1.1.7) 2
hh3cTcpRcvVrfName (1.3.6.1.4.1.25506.2.215.1.1.8) 2
hh3cTcpSndVrfName (1.3.6.1.4.1.25506.2.215.1.1.9) 3
hh3cTcpSynFloodFlowChassis (1.3.6.1.4.1.25506.2.215.2.1.1) 3
hh3cTcpSynFloodFlowSlot (1.3.6.1.4.1.25506.2.215.2.1.2) 3
hh3cTcpSynFloodFlowIpType (1.3.6.1.4.1.25506.2.215.2.1.3) 3
hh3cTcpSynFloodFlowIpAddress (1.3.6.1.4.1.25506.2.215.2.1.4) 3
hh3cTcpSynFloodFlowPort (1.3.6.1.4.1.25506.2.215.2.1.5) 4
hh3cTcpSynFloodFlowVrfName (1.3.6.1.4.1.25506.2.215.2.1.6) 4
hh3cTcpSynFloodFlowPktType (1.3.6.1.4.1.25506.2.215.2.1.7) 4
hh3cTcpSynFloodFlowRate (1.3.6.1.4.1.25506.2.215.2.1.8) 4
hh3cTcpSynFloodIfChassis (1.3.6.1.4.1.25506.2.215.3.1.1) 4
hh3cTcpSynFloodIfSlot (1.3.6.1.4.1.25506.2.215.3.1.2) 5
hh3cTcpSynFloodIfIndex (1.3.6.1.4.1.25506.2.215.3.1.3) 5
hh3cTcpSynFloodIfPktType (1.3.6.1.4.1.25506.2.215.3.1.4) 5
hh3cTcpSynFloodIfRate (1.3.6.1.4.1.25506.2.215.3.1.5) 5
Notifications· 5
hh3cTcpMD5AuthenFail 5
hh3cTcpNumExceedAlarm·· 7
hh3cTcpNumExceedResume· 8
hh3cTcpExceptionClose· 8
hh3cTcpSynFloodFlow· 10
hh3cTcpSynFloodIf 11
HH3C-TCP-MIB
About this MIB
Use this MIB to test whether the MD5 authentication for the current TCP connection is successful.
MIB file name
hh3c-tcp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTcp(215)
Scalar objects
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
OCTET STRING  (0..255)
Local IP address of the TCP connection
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32(0..65535)
Local port number of the TCP connection
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
Remote IP address of the TCP connection
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32(0..65535)
Remote port number of the TCP connection
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
Name of the upper layer protocol of TCP
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
Name of the VRF of the TCP connection
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
established(1)
finWait1(2)
closing(3)
lastAck(4)
finWait2(5)
State of the TCP connection.
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
VPN receiving the TCP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
VPN sending the TCP packet.
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Standard MIB values.
Chassis number
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Slot number
As per the MIB.
Object (OID)
Access
Value range
Implementation
InetAddressType
Address type
As per the MIB.
Object (OID)
Access
Value range
Implementation
InetAddress
Source address of the flow-based SYN attack packets
As per the MIB.
Object (OID)
Access
Value range
Implementation
Integer32
Integer32 (0..65535)
Destination port number of the flow-based SYN attack packets
As per the MIB.
Object (OID)
Access
Value range
Implementation
OCTET STRING
VRF name
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
ip(1)
mpls(2)
Type of the flow-based SYN attack packets
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Rate of the flow-based SYN attack packets
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Chassis number
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Slot number
As per the MIB.
Object (OID)
Access
Value range
Implementation
InterfaceIndex
Index of the interface that received the interface-based SYN attack packets
As per the MIB.
Object (OID)
Access
Value range
Implementation
INTEGER
ip(1)
mpls(2)
Type of the interface-based SYN attack packets
As per the MIB.
Object (OID)
Access
Value range
Implementation
Unsigned32
Rate of the interface-based SYN attack packets
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.215.1.0.1
TCP connection MD5 authentication failed.
Error
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the MD5 keys of the two ends of a TCP connection are different or only one end is configured with an MD5 key.
System impact
The TCP connection cannot be established, upper-layer routing protocols, such as LDP and BGP, cannot establish sessions.
Status control
ON
CLI: Use the snmp-agent trap enable tcp command.
OFF
CLI: Use the undo snmp-agent trap enable tcp command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.215.1.1.1 (hh3cTcpConnLocalAddressTCP)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.215.1.1.2 (hh3cTcpConnLocalPortTCP)
N/A
Integer32
Integer32(0..65535)
1.3.6.1.4.1.25506.2.215.1.1.3 (hh3cTcpConnRemAddressTCP)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.215.1.1.4 (hh3cTcpConnRemPortTCP)
N/A
Integer32
Integer32(0..65535)
1.3.6.1.4.1.25506.2.215.1.1.5 (hh3cTcpProtocol)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.215.1.1.6 (hh3cTcpVrfNameVRF)
N/A
OCTET STRING
Recommended action
To resolve this issue:
1.Use the display current-configuration command on each end to check whether an MD5 key is configured.
  - If only one end is configured with an MD5 key, configure an MD5 key on the other end. If the issue persists, go to step 3.
  - If the MD5 keys configured on the two ends are different, go to step 2.
2.Configure the same MD5 key on the two ends.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.215.1.0.2
The number of TCP connections has exceeded the maximum.
Error
Warning
1.3.6.1.4.1.25506.2.215.1.0.3 (hh3cTcpNumExceedResume)
ON
After Naptha attack prevention is enabled, this notification will be generated when the number of TCP connections of a state exceeds the maximum allowed.
System impact
New TCP connections cannot be established.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.215.1.1.7 (hh3cTcpNumExceedState)
TCP connection state
N/A
INTEGER
established(1), finWait1(2), closing(3), lastAck(4), finWait2(5)
Recommended action
1.Execute the display tcp command to view all TCP connections on the device.
2.Check for attacks, identify and then shut down the attacked services, or configure attack defense features on the firewall.
3.Check for any unnecessary connections and close services that are not needed.
4.If the issue persists, collect configuration data and alarm information, and then contact Technical Support.
Basic information
OID
Event
Severity
Default status
The number of connections dropped below the upper limit.
Recovery
Warning
N/A (N/A)
ON
After Naptha attack prevention is enabled, this notification will be generated when the number of TCP connections of a state returns to normal.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
INTEGER
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.215.1.0.4
The TCP connection was disconnected duo to abnormal TCP packets.
Error
Warning
N/A (N/A)
ON
After TCP connection attack prevention is enabled, if the device receives too many abnormal TCP packets within a certain period, it will disconnect the TCP connection and generate a notification for this event.
System impact
TCP may be vulnerable to attacks, resulting in connections and affecting service operations.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
TCP packet source IP address
N/A
OCTET STRING
TCP message source port ID
N/A
Integer32
Integer32(0..65535)
Destination IP address of the TCP packet.
N/A
OCTET STRING
Destination port number of the TCP packet.
N/A
Integer32
Integer32(0..65535)
1.3.6.1.4.1.25506.2.215.1.1.8 (hh3cTcpRcvVrfName)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.215.1.1.9 (hh3cTcpSndVrfName)
N/A
OCTET STRING
Recommended action
1.As a best practice, capture and analyze the packets received by the device.
2.Identify whether the device is suffered a whitelist attack. Configure attack defense on the firewall.
3.If the issue persists, collect configuration data and alarm information, and then contact Technical Support.
hh3cTcpSynFloodFlow
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.215.2.0.1
A flow-based TCP SYN flood attack occurs.
Error
Warning
N/A (N/A)
ON
System impact
The device is under attack, which might affect normal TCP services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.215.2.1.1 (hh3cTcpSynFloodFlowChassis)
Chassis number
N/A
Unsigned32
 (hh3cTcpSynFloodFlowSlot)
Slot number
N/A
Unsigned32
1.3.6.1.4.1.25506.2.215.2.1.3 (hh3cTcpSynFloodFlowIpType)
Address type
N/A
InetAddressType
1.3.6.1.4.1.25506.2.215.2.1.4 (hh3cTcpSynFloodFlowIpAddress)
Source address of the SYN attack packets
N/A
InetAddress
1.3.6.1.4.1.25506.2.215.2.1.5 (hh3cTcpSynFloodFlowPort)
Destination port number of the SYN attack packets
N/A
Integer32
1.3.6.1.4.1.25506.2.215.2.1.6 (hh3cTcpSynFloodFlowVrfName)
VRF name
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.215.2.1.7 (hh3cTcpSynFloodFlowPktType)
Type of the SYN attack packets
N/A
INTEGER
ip(1), mpls(2)
1.3.6.1.4.1.25506.2.215.2.1.8 (hh3cTcpSynFloodFlowRate)
Rate of the SYN attack packets
N/A
Unsigned32
Recommended action
Check whether attack packets exist in the current network environment.
hh3cTcpSynFloodIf
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.215.3.0.1
An interface-based TCP SYN flood attack occurs.
Error
Warning
N/A (N/A)
ON
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.215.3.1.1 (hh3cTcpSynFloodIfChassis)
Chassis number
N/A
Unsigned32
 (hh3cTcpSynFloodIfSlot)
Slot number
N/A
Unsigned32
1.3.6.1.4.1.25506.2.215.3.1.3 (hh3cTcpSynFloodIfIndex)
Index of the interface that received the SYN attack packets
N/A
InterfaceIndex
1.3.6.1.4.1.25506.2.215.3.1.4 (hh3cTcpSynFloodIfPktType)
N/A
INTEGER
ip(1), mpls(2)
1.3.6.1.4.1.25506.2.215.3.1.5 (hh3cTcpSynFloodIfRate)
N/A
Unsigned32
Recommended action
