18-Security Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)- R9141-6W10018-Security Command Reference
17-IP source guard commands
17-IP source guard commands 145.07 KB
display ip source binding
Use display ip source binding to display IPv4SG bindings.
display ip source binding [ static | [ vpn-instance vpn-instance-name ] [ arp-snooping-vlan | dhcp-snooping | dot1x ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
static: Displays static IPv4SG bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display dynamic IPv4SG bindings for the public network, do not specify a VPN instance.
arp-snooping-vlan: Specifies IPv4SG bindings generated based on ARP snooping for VLANs.
dhcp-snooping: Specifies IPv4SG bindings generated based on DHCP snooping.
dot1x: Specifies IPv4SG bindings generated based on 802.1X. To display dynamic IPv4SG bindings generated based on the 802.1X module, you must also specify the slot through which 802.1X users access the network.
ip-address ip-address: Specifies an IPv4 address.
mac-address mac-address: Specifies a MAC address in H-H-H format.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv4SG bindings for the active MPU.
# Display all IPSG bindings on the public network.
<Sysname> display ip source binding
Total entries found: 5
IP Address      MAC Address    Interface                VLAN Type
10.1.0.5        040a-0000-4000 XGE0/0/6                 1    DHCP snooping
10.1.0.6        040a-0000-3000 XGE0/0/6                 1    DHCP snooping
10.1.0.7        040a-0000-2000 XGE0/0/6                 1    DHCP snooping
10.1.0.9        040a-0000-2000 XGE0/0/7                 N/A  Static
Total entries found
Total number of IPv4SG bindings.
IP Address
IPv4 address in the IPv4SG binding. If no IP address is bound in the binding, this field displays N/A.
MAC Address
MAC address in the IPv4SG binding. If no MAC address is bound in the binding, this field displays N/A.
Interface of the binding. This field displays N/A for a global IPv4SG binding.
VLAN
VLAN information in the IPv4SG binding. If the binding contains no VLAN information, this field displays N/A.
IPSG binding type:
·     Static—Manually configured by using the ip source binding command. Static bindings are for packet filtering in IPSG or used by other modules to provide security services.
·     ARP snooping vlan—Dynamically generated based on ARP snooping for the VLAN. The binding is for packet filtering in IPSG.
·     802.1X—Dynamically generated based on 802.1X. The binding is for packet filtering in IPSG.
·     DHCP snooping—Dynamically generated based on DHCP snooping. The binding is for packet filtering in IPSG.
ip source binding
ip verify source
display ip source binding statistics
Use display ip source binding statistics to display statistics about local and remote IPv4SG bindings that routing protocols synchronize.
You can use this command to monitor the numbers of local and remote IPv4SG bindings that routing protocols synchronize in realtime. Based on the statistics, you can determine whether the maximum number of IPSG bindings is reached and whether attackers exist on the network.
This command displays the statistics only in the most recent hour.
# Display statistics about local and remote IPv4SG bindings that routing protocols synchronize.
<Sysname> display ip source binding statistics
  Time          Remote entry count    Local entry count
  Current       2000                  5200
  1 min ago     1351                  5135
  2 min ago     711                   5071
  3 min ago     708                   4774
  59 min ago    656                   1365
  60 min ago    607                   1300
Time
Time when the statistics were collected.
Remote entry count
Total number of remote IPv4SG bindings that were synchronized by routing protocols.
Local entry count
Total number of local IPv4SG bindings that can be synchronized by routing protocols.
display ip source binding-local
Use display ip source binding-local to display local IPv4SG bindings that can be synchronized by routing protocols.
display ip source binding-local [ interface interface-type interface-number ] [ dhcp-relay ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ slot slot-number ]
dhcp-relay: Specifies dynamic IPv4SG bindings generated based on the DHCP relay module.
ip-address ip-address: Specifies an IP address.
mac-address mac-address: Specifies a MAC address, in the H-H-H format.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays local IPv4SG bindings that can be synchronized by routing protocols on the active MPU.
If you do not specify any parameters, this command displays all local IPv4SG bindings that can be synchronized by routing protocols.
# Display local IPv4SG bindings that can be synchronized by routing protocols.
<Sysname> display ip source binding-local
Total entries found: 1
IP address      MAC address    Interface                VLAN  Type
10.1.0.5        040a-0000-4000 Vlan1                    1     DHCP relay
Total entries found
Number of matching local IPv4SG bindings that can be synchronized by routing protocols.
IP address
MAC address
Interface in the binding. This field displays N/A for a global IPv4SG binding.
VLAN
Type of the IPv4SG binding.
DHCP relay indicates that this binding was dynamically generated based on DHCP relay agent. This binding can be for packet filtering in IPSG.
display ip source binding-remote
Use display ip source binding-remote to display remote IPv4SG bindings synchronized by routing protocols.
display ip source binding-remote [ router-id router-id ] [ dhcp-relay ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ slot slot-number ]
router-id router-id: Specifies a remote device from which the device synchronizes IPv4SG bindings. The argument represents the router ID of the remote device, in IP address format.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays remote IPv4SG bindings synchronized by routing protocols on the active MPU.
If you do not specify any parameters, this command displays all remote IPv4SG bindings synchronized by routing protocols.
# Display remote IPv4SG bindings synchronized by routing protocols.
<Sysname> display ip source binding-remote
IP address      MAC address    Router ID                VLAN  Type
10.1.0.5        040a-0000-4000 1.1.1.1                  1     DHCP relay
Total entries found
Number of matching remote IPv4SG bindings that were synchronized by routing protocols.
IP address
MAC address
Router ID
VLAN
display ipv6 source binding
Use display ipv6 source binding to display IPv6SG address bindings.
display ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-snooping | dot1x | nd-snooping-vlan ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
static: Displays static IPv6SG address bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display dynamic IPv6SG address bindings for the public network, do not specify a VPN instance.
dhcpv6-snooping: Specifies IPv6SG bindings generated based on DHCPv6 snooping.
dot1x: Specifies IPv6SG bindings generated based on 802.1X. To display dynamic IPv6SG address bindings generated based on the 802.1X module, you must also specify the slot through which 802.1X users access the network.
ip-address ipv6-address: Specifies an IPv6 address.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6SG address bindings for the active MPU.
# Display all IPv6SG address bindings on the public network.
<Sysname> display ipv6 source binding
Total entries found: 2
IPv6 Address                MAC Address    Interface      VLAN Type
2012:1222:2012:1222: 000f-2202-0435 XGE1/0/1                1    DHCPv6 snooping
2012:1222:2012:1222
2012:1222:2012:1222: 000f-2202-0436 XGE1/0/1                N/A  Static
2012:1222:2012:1223
Table 5 Command output
Total entries found
Total number of IPv6SG address bindings.
IPv6 Address
IPv6 address in the IPv6SG address binding. If no IPv6 address is bound in the binding, this field displays N/A.
MAC Address
MAC address in the IPv6SG address binding. If no MAC address is bound in the binding, this field displays N/A.
Interface of the IPv6SG address binding. This field displays N/A for a global IPv6SG binding.
VLAN
VLAN information in the IPv6SG address binding. If the binding contains no VLAN information, this field displays N/A.
Type of the IPv6SG address binding:
·     Static—Manually configured by using the ipv6 source binding command. Static bindings are for packet filtering in IPv6SG or used by other modules to provide security services.
·     DHCPv6 snooping—Dynamically generated based on DHCPv6 snooping. The binding is for packet filtering in IPv6SG.
·     802.1X—Dynamically generated based on 802.1X. The binding is for packet filtering in IPv6SG.
·     ND snooping vlan—Dynamically generated based on ND snooping for the VLAN. The binding is for packet filtering in IPv6SG.
ipv6 source binding
ipv6 verify source
display ipv6 source binding pd
Use display ipv6 source binding pd to display IPv6SG prefix bindings.
display ipv6 source binding pd [ vpn-instance vpn-instance-name ] [ prefix prefix/prefix-length ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
Any views
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display IPv6SG prefix bindings for the public network, do not specify a VPN instance.
prefix prefix/prefix-length: Specifies an IPv6 prefix. The value range for the prefix-length argument is 1 to 128. If you do not specify an IPv6 prefix, this command displays all IPv6SG prefix bindings.
mac-address mac-address: Specifies a MAC address in H-H-H format. If you do not specify a MAC address, this command displays IPv6SG prefix bindings for all MAC addresses.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays IPv6SG prefix bindings for all VLANs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPv6SG prefix bindings for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6SG prefix bindings for the active MPU.
IPv6SG prefix bindings are dynamically obtained from the DHCPv6 snooping module.
# Display all IPv6SG prefix bindings.
<Sysname> display ipv6 source binding pd
Total entries found: 3
IPv6 prefix                         MAC address    Interface               VLAN
2012:1111::/64       000f-2202-0435  XGE1/0/1       1     DHCPv6 snooping
2012:2222::/64       000f-2202-0436  XGE2/0/1       2     DHCPv6 snooping
Table 6 Command output
Total entries found
Total number of IPv6SG prefix bindings.
IPv6 prefix
IPv6 prefix and prefix length in the IPv6SG prefix binding.
MAC address
MAC address in the IPv6SG prefix binding.
This field displays N/A if the MAC address is invalid.
Interface to which the IPv6SG prefix binding belongs.
This field displays N/A for a global IPv6SG prefix binding.
VLAN
VLAN information in the IPv6SG prefix binding.
This field displays N/A if the IPv6SG prefix binding does not contain the VLAN information.
ipv6 source binding
ipv6 verify source
display ipv6 source binding statistics
Use display ipv6 source binding statistics to display statistics about local and remote IPv6SG bindings that routing protocols synchronize.
You can use this command to monitor the numbers of local and remote IPv6SG bindings that routing protocols synchronize in realtime. Based on these statistics, you can determine whether the maximum number of IPSG bindings is reached and whether attackers exist on the network.
# Display statistics about local and remote IPv6SG bindings that routing protocols synchronize.
<Sysname> display ipv6 source binding statistics
  Current       2000                  5200
  1 min ago     1351                  5135
  2 min ago     711                   5071
  3 min ago     708                   4774
  59 min ago    656                   1365
  60 min ago    607                   1300
Table 7 Command output
Time
Remote entry count
Total number of remote IPv6SG bindings that were synchronized by routing protocols.
Local entry count
Total number of local IPv6SG bindings that can be synchronized by routing protocols.
display ipv6 source binding-local
Use display ipv6 source binding-local to display local IPv6SG bindings that can be synchronized by routing protocols.
display ipv6 source binding-local [ interface interface-type interface-number ] [ dhcpv6-relay ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ slot slot-number ]
dhcpv6-relay: Specifies dynamic IPv6SG bindings generated based on the DHCPv6 relay module.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays local IPv6SG bindings that can be synchronized by routing protocols on the active MPU.
If you do not specify any parameters, this command displays all local IPv6SG bindings that can be synchronized by routing protocols.
# Display local IPv6SG bindings that can be synchronized by routing protocols.
<Sysname> display ipv6 source binding-local
IPv6 address      MAC address    Interface                VLAN  Type
100::1            04ef-7010-1000 Vlan10                   10    DHCPv6 relay
Table 8 Command output
Total entries found
Number of matching local IPv6SG bindings that can be synchronized by routing protocols.
IPv6 address
IPv6 address in the IPv6SG binding. If no IP address is bound in the binding, this field displays N/A.
MAC address
MAC address in the IPv6SG binding. If no MAC address is bound in the binding, this field displays N/A.
Interface in the binding. This field displays N/A for a global IPv6SG binding.
VLAN
VLAN information in the IPv6SG binding. If the binding contains no VLAN information, this field displays N/A.
Type of the IPv6SG binding.
DHCP relay—Dynamically generated based on DHCP relay agent. This binding is for packet filtering in IPSG.
display ipv6 source binding-remote
Use display ipv6 source binding-remote to display remote IPv6SG bindings synchronized by routing protocols.
display ipv6 source binding-remote [ router-id router-id ] [ dhcpv6-relay ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ slot slot-number ]
router-id router-id: Specifies a remote device from which the device synchronizes IPv6SG bindings. The router-id argument represents the router ID of the remote device, in IP address format.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays remote IPv6SG bindings synchronized by routing protocols on the active MPU.
If you do not specify any parameters, this command displays all remote IPv6SG bindings synchronized by routing protocols.
# Display remote IPv6SG bindings synchronized by routing protocols.
<Sysname> display ipv6 source binding-remote
IPv6 address    MAC address    Router ID                VLAN  Type
100::1          04ef-7010-1000 5.5.5.5                  10    DHCPv6 relay
Table 9 Command output
Total entries found
Number of matching remote IPv6SG bindings that were synchronized by routing protocols.
IPv6 address
MAC address
Router ID
VLAN
ip source binding (interface view)
Use ip source binding to configure a static IPv4SG binding on an interface.
Use undo ip source binding to delete the static IPv4SG bindings configured on an interface.
ip source binding { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
undo ip source binding { all | ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
No static IPv4SG bindings exist on an interface.
all: Removes all static IPv4SG bindings on the interface.
ip-address ip-address: Specifies an IPv4 address for the static binding. The IPv4 address must be a class A, B, or C address, and cannot be 127.x.x.x or 0.0.0.0.
mac-address mac-address: Specifies a MAC address for the static binding. The MAC address must be in H-H-H format, and cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
vlan vlan-id: Specifies a VLAN ID for the static binding. The value range is 1 to 4094. This option is supported only in Layer 2 Ethernet interface view.
Static IPv4SG bindings on an interface filter incoming IPv4 packets on the interface, and check user validity by cooperating with the ARP attack detection feature.
# Configure a static IPv4SG binding on Ten-GigabitEthernet 0/0/6.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] ip source binding ip-address 192.168.0.1 mac-address 0001-0001-0001
ip verify source
Use ip verify source to enable IPv4SG on an interface.
Use undo ip verify source to disable IPv4SG on an interface.
The IPv4SG feature is disabled on an interface.
VLAN view
ip-address: Filters incoming packets by source IPv4 addresses.
ip-address mac-address: Filters incoming packets by source IPv4 addresses and source MAC addresses.
mac-address: Filters incoming packets by source MAC addresses.
After you enable IPv4SG on an interface, this feature uses static and dynamic IPv4SG bindings to match incoming packets on the interface. Packets that match an IPv4SG binding are forwarded and packets that do not match any IPv4SG binding are discarded.
The matching criterion specified by this command applies only to dynamic IPSG. Static IPv4SG uses static bindings configured by using the ip source binding command.
If you enable IPv4SG in a VLAN, IPv4SG is enabled on all Layer 2 Ethernet interfaces that belong to the VLAN.
Do not configure IPv4SG both in a VLAN and on an Ethernet interface that belongs to the VLAN. Before you perform one of the configurations, make sure the other configuration does not exist.
You can configure IPv4SG on an interface or in a VLAN multiple times, the most recent configuration takes effect.
If you re-execute this command to modify the matching criterion, the new criterion applies only to packets of the access users that come online after the command execution.
# Enable IPv4SG on Ethernet interface Ten-GigabitEthernet 0/0/6 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname-Ten-GigabitEthernet0/0/6] ip verify source ip-address mac-address
# Enable IPv4SG in VLAN 10 and verify the source IPv4 address and MAC address for dynamic IPv4SG.
[Sysname] vlan 10
[Sysname-vlan10] ip verify source ip-address mac-address
ipv6 source binding (interface view)
Use ipv6 source binding to configure a static IPv6SG binding.
Use undo ipv6 source binding to delete the static IPv6SG bindings configured on an interface.
ipv6 source binding { ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
undo ipv6 source binding { all | ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
No static IPv6SG bindings exist on an interface.
all: Removes all the static IPv6SG bindings on the interface.
ip-address ipv6-address: Specifies an IPv6 address for the static binding. The IPv6 address cannot be an all-zero address, a multicast address, or a loopback address.
Static IPv6SG bindings on an interface filter incoming IPv6 packets.
# Configure a static IPv6SG binding on Ten-GigabitEthernet 0/0/6.
[Sysname-Ten-GigabitEthernet0/0/6] ipv6 source binding ip-address 2001::1 mac-address 0002-0002-0002
ipv6 verify source
Use ipv6 verify source to enable IPv6SG on an interface.
Use undo ipv6 verify source to disable IPv6SG on an interface.
The IPv6SG feature is disabled on an interface.
ip-address: Filters incoming packets by source IPv6 addresses.
ip-address mac-address: Filters incoming packets by source IPv6 addresses and source MAC addresses.
After you enable IPv6SG on an interface, this feature uses static and dynamic IPv6SG bindings to match incoming packets on the interface. Packets that match an IPv6SG binding are forwarded and packets that do not match any IPv6SG binding are discarded.
The matching criterion specified by this command applies only to dynamic IPv6SG. Static IPv6SG uses static bindings configured by using the ipv6 source binding command.
You can configure IPv6SG on an interface multiple times, the most recent configuration takes effect.
# Enable IPv6SG on Ethernet interface Ten-GigabitEthernet 0/0/6 and verify the source IPv6 address and MAC address for dynamic IPv6SG.
[Sysname-Ten-GigabitEthernet0/0/6] ipv6 verify source ip-address mac-address
