03-IPsec commands | 611.68 KB |
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ipsec sdwan-statistics
ipsec { ipv6-policy | policy } isakmp template
ipsec { ipv6-policy | policy } local-address
ipsec logging negotiation enable
IPsec commands
address
Use address to add a peer IP address to an identity filter set.
Use undo address to remove a peer IP address from an identity filter set.
address { ipv4-address [ mask | mask-length ] | ipv6 ipv6-address [ prefix-length ] }
undo address { ipv4-address [ mask | mask-length ] | ipv6 ipv6-address [ prefix-length ] }
No peer IP address is added to an identity filter set.
Identity filter set view
ipv4-address: Specifies the IPv4 address of a peer.
mask: Specifies the subnet mask of the IPv4 address.
mask-length: Specifies the mask length of the IPv4 address, in the range of 0 to 32.
ipv6 ipv6-address: Specifies the IPv6 address of a peer.
prefix-length: Specifies the prefix length of the IPv6 address, in the range of 1 to 128.
Operating mechanism
Use this command to configure IP address filtering conditions in an identity filter set. During an IPsec negotiation, the local end filters the negotiation initiator based on the specified IP addresses. When the initiator end meets one or more conditions of the identity filter set and the IPsec negotiation parameters on both ends match, the local and remote ends can successfully establish an IPsec tunnel.
To add multiple IP address filtering conditions to an identity filter set, execute this command multiple times.
# Create an identity filter set named identity1 and enter its view.
[Sysname] ipsec ike-identity identity1
# Configure the identity filter set to permit the peer with IP address 2.2.2.2.
[Sysname-ipsec-ike-identity-identity1] address 2.2.2.2 32
ipsec ike-identity
ah authentication-algorithm
Use ah authentication-algorithm to specify authentication algorithms for the AH protocol.
Use undo ah authentication-algorithm to restore the default.
ah authentication-algorithm { aes-xcbc-mac | md5 | sha1 | sha256 | sha384 | sha512 | sm3 } *
AH does not use any authentication algorithms.
IPsec transform set view
aes-xcbc-mac: Specifies the HMAC-AES-XCBC-96 algorithm, which uses a 128-bit key. This keyword is available only for IKEv2.
md5: Specifies the HMAC-MD5-96 algorithm, which uses a 128-bit key.
sha1: Specifies the HMAC-SHA1-96 algorithm, which uses a 160-bit key.
sha256: Specifies the HMAC-SHA256 algorithm, which uses a 256-bit key.
sha384: Specifies the HMAC-SHA384 algorithm, which uses a 384-bit key.
sha512: Specifies the HMAC-SHA512 algorithm, which uses a 512-bit key.
sm3: Specifies the HMAC-SM3-96 algorithm, which uses a 256-bit key. This keyword is available only for IKEv1.
You can specify multiple AH authentication algorithms for one IPsec transform set, and the algorithm specified earlier has a higher priority.
For a manual or IKEv1-based IPsec policy, the first specified AH authentication algorithm takes effect. To make sure an IPsec tunnel can be established successfully, the IPsec transform sets specified at both ends of the tunnel must have the same first AH authentication algorithm.
# Specify HMAC-SHA1 as the AH authentication algorithm for IPsec transform set tran1.
[Sysname] ipsec transform-set tran1
[Sysname-ipsec-transform-set-tran1] ah authentication-algorithm sha1
anti-replay time-based window
Use anti-replay time-based window to set the time-based anti-replay window size.
Use undo anti-replay time-based window to restore the default.
anti-replay time-based window seconds
The device uses the globally configured serial number-based anti-replay window size.
IPsec profile view
seconds: Specifies the size for the time-based anti-replay window, in the range of 1 to 100 seconds. You can adjust the size according to the actual network conditions. When the network latency is relatively high, you can increase the window size to prevent anti-replay checking from affecting normal operation of services. When the network latency is relatively low, you can decrease the window size for better anti-replay checking.
Application scenarios
Compared to serial number-based global anti-replay checking configured in system view, time-based anti-replay checking does not affect the device's forwarding performance. It ensures the forwarding performance while implementing anti-replay. Therefore, to ensure the SDWAN forwarding performance, you can use the time-based anti-replay feature.
Sometimes, the time difference between the sending time and receiving time of a non-replay service packet might be significantly different from the normal time difference. Such a packet might be dropped as a replayed packet by time-based anti-replay checking, affecting normal operation of services. If this happens, disable time-based anti-replay checking or increase the anti-replay window size as needed.
Operating mechanism
In time-based anti-replay checking, the local device adds a timestamp to a sent packet to record the sending time of the packet, and the remote device checks the timestamp upon arrival of the packet. Only packets arriving within the time-based anti-replay window configured by this command will be accepted. Packets arriving outside the anti-replay window will be dropped.
This command is supported only for SDWAN IPsec profiles.
Changing the time-based anti-replay window size affects only the IPsec SAs negotiated later.
This command takes effect only after you have enabled IPsec anti-replay checking (by using the ipsec anti-replay checking command).
If you configure both the time-based anti-replay window size and the global anti-replay window size, only the time-based anti-replay window size takes effect.
# Set the size of the time-based anti-replay window to 50 seconds for SDWAN IPsec profile profile1.
[Sysname] ipsec profile profile1 sdwan
[Sysname-ipsec-profile-sdwan-profile1] anti-replay time-based window 50
ipsec anti-replay window
description
Use description to configure a description for an IPsec policy, IPsec profile, or IPsec policy template.
No description is configured for an IPsec policy, IPsec profile, or IPsec policy template.
IPsec policy view
IPsec policy template view
IPsec profile view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
You can configure different descriptions for IPsec policies, IPsec profiles, or IPsec policy templates to distinguish them.
# Configure the description for IPsec policy policy1 as CenterToA.
[Sysname] ipsec policy policy1 1 isakmp
[Sysname-ipsec-policy-isakmp-policy1-1] description CenterToA
Use display ipsec { ipv6-policy | policy } to display information about IPsec policies.
display ipsec { ipv6-policy | policy } [ policy-name [ seq-number ] ]
ipv6-policy: Displays information about IPv6 IPsec policies.
policy: Displays information about IPv4 IPsec policies.
policy-name: Specifies an IPsec policy by its name, a case-insensitive string of 1 to 63 characters.
seq-number: Specifies an IPsec policy entry by its sequence number in the range of 1 to 65535.
If you do not specify any parameters, this command displays information about all IPsec policies.
If you specify an IPsec policy name and a sequence number, this command displays information about the specified IPsec policy entry. If you specify an IPsec policy name without any sequence number, this command displays information about all IPsec policy entries with the specified name.
# Display information about all IPv4 IPsec policies.
<Sysname> display ipsec policy
IPsec Policy: mypolicy
Sequence number: 1
Mode: Manual
The policy configuration is incomplete:
ACL not specified
Incomplete transform-set configuration
Description: This is my first IPv4 manual policy
Security data flow:
Remote address: 2.5.2.1
Transform set: transform
Inbound AH setting:
AH SPI: 1200 (0x000004b0)
AH string-key: ******
AH authentication hex key:
Inbound ESP setting:
ESP SPI: 1400 (0x00000578)
ESP string-key:
ESP encryption hex key:
ESP authentication hex key:
Outbound AH setting:
AH SPI: 1300 (0x00000514)
Outbound ESP setting:
ESP SPI: 1500 (0x000005dc)
ESP string-key: ******
Sequence number: 2
Mode: ISAKMP
Remote-address not set
ACL not specified
Transform-set not set
Description: This is my first IPv4 Isakmp policy
Traffic Flow Confidentiality: Enabled
Security data flow:
Selector mode: standard
Local address:
Remote address:
Transform set:
IKE profile:
IKEv2 profile:
SA trigger mode: Auto
SA duration(time based): 3600 seconds
SA duration(traffic based): 1843200 kilobytes
SA soft-duration buffer(time based): 1000 seconds
SA soft-duration buffer(traffic based): 43200 kilobytes
SA idle time: 100 seconds
Responder only: Disabled
IPsec Policy: mycompletepolicy
Interface: LoopBack2
Sequence number: 1
Mode: Manual
Description: This is my complete policy
Security data flow: 3100
Remote address: 2.2.2.2
Transform set: completetransform
Inbound AH setting:
AH SPI: 5000 (0x00001388)
ESP SPI: 7000 (0x00001b58)
AH SPI: 6000 (0x00001770)
ESP SPI: 8000 (0x00001f40)
Sequence number: 2
Mode: ISAKMP
Security data flow: 3200
Local address:
Remote address: 5.3.6.9
IKE profile:
IKEv2 profile:
# Display information about all IPv6 IPsec policies.
<Sysname> display ipsec ipv6-policy
Sequence number: 1
Mode: Manual
Description: This is my first IPv6 policy
Security data flow: 3600
Remote address: 1000::2
Transform set: mytransform
Inbound AH setting:
AH SPI: 1235 (0x000004d3)
ESP SPI: 1236 (0x000004d4)
AH SPI: 1237 (0x000004d5)
ESP SPI: 1238 (0x000004d6)
Sequence number: 2
Mode: ISAKMP
Local address:
IKE profile:
IKEv2 profile:
IPsec Policy |
IPsec policy name. |
Interface applied with the IPsec policy. |
Sequence number |
Sequence number of the IPsec policy entry. |
Mode |
Negotiation mode of the IPsec policy: · Manual—Manual mode. · ISAKMP—IKE negotiation mode. · Template—IPsec policy template mode. |
The policy configuration is incomplete |
IPsec policy configuration incomplete. Possible causes include: · The ACL is not configured. · The IPsec transform set is not configured. · The ACL does not have any permit statements. · The IPsec transform set configuration is not complete. · The peer IP address of the IPsec tunnel is not specified. · The SPI and key of the IPsec SA do not match those in the IPsec policy. |
Description of the IPsec policy. |
Traffic Flow Confidentiality |
Whether Traffic Flow Confidentiality (TFC) padding is enabled. |
Security data flow |
ACL used by the IPsec policy. |
Selector mode |
Data flow protection mode of the IPsec policy: standard, aggregation, or per-host. |
Local address |
Local end IP address of the IPsec tunnel (available only for the IKE-based IPsec policy). |
Remote address |
Remote end IP address or host name of the IPsec tunnel. |
Transform set |
Transform set used by the IPsec policy. |
IKE profile |
IKE profile used by the IPsec policy. |
IKEv2 profile |
IKEv2 profile used by the IPsec policy. |
SA trigger mode |
IPsec SA negotiation triggering mode: · Auto—Triggers SA negotiation when required IPsec configuration is complete. · Traffic-based—Triggers SA negotiation when traffic requires IPsec protection. |
SA duration(time based) |
Time-based IPsec SA lifetime, in seconds. |
SA duration(traffic based) |
Traffic-based IPsec SA lifetime, in Kilobytes. |
SA soft-duration buffer(time based) |
Time-based IPsec SA soft lifetime buffer, in seconds. If the time-based IPsec SA soft lifetime buffer is not configured, this field displays two consecutive hyphens (--). |
SA soft-duration buffer(traffic based) |
Traffic-based IPsec SA soft lifetime buffer, in Kilobytes. If the traffic-based IPsec SA soft lifetime buffer is not configured, this field displays two consecutive hyphens (--). |
SA idle time |
Idle timeout of the IPsec SA, in seconds. If the IPsec SA idle timeout is not configured, this field displays two consecutive hyphens (--). |
Responder only |
State of the responder only feature: · Enabled · Disabled |
AH string-key |
AH string key. This field displays ****** if the key is configured and it is empty if the key is not configured. |
AH authentication hex key |
AH authentication hexadecimal key. This field displays ****** if the key is configured and it is empty if the key is not configured. |
ESP string-key |
ESP string key. This field displays ****** if the key is configured and it is empty if the key is not configured. |
ESP encryption hex key |
ESP encryption hexadecimal key. This field displays ****** if the key is configured and it is empty if the key is not configured. |
ESP authentication hex key |
ESP authentication hexadecimal key. This field displays ****** if the key is configured and it is empty if the key is not configured. |
Use display ipsec { ipv6-policy-template | policy-template } to display information about IPsec policy templates
display ipsec { ipv6-policy-template | policy-template } [ template-name [ seq-number ] ]
ipv6-policy-template: Displays information about IPv6 IPsec policy templates.
policy-template: Displays information about IPv4 IPsec policy templates.
template-name: Specifies an IPsec policy template by its name, a case-insensitive string of 1 to 63 characters.
seq-number: Specifies an IPsec policy template entry by its sequence number in the range of 1 to 65535.
If you do not specify any parameters, this command displays information about all IPsec policy templates.
If you specify an IPsec policy template name and a sequence number, this command displays information about the specified IPsec policy template entry. If you specify an IPsec policy template name without any sequence number, this command displays information about all IPsec policy template entries with the specified name.
# Display information about all IPv4 IPsec policy templates.
<Sysname> display ipsec policy-template
IPsec Policy Template: template
Sequence number: 1
Description: This is policy template
Traffic Flow Confidentiality: Disabled
Security data flow :
Local address:
IKE profile:
IKEv2 profile:
Remote address: 162.105.10.2
Transform set: testprop
IPsec SA local duration(time based): 3600 seconds
IPsec SA local duration(traffic based): 1843200 kilobytes
# Display information about all IPv6 IPsec policy templates.
<Sysname> display ipsec ipv6-policy-template
IPsec Policy Template: template6
Sequence number: 1
Local address:
IKE profile:
IKEv2 profile:
Remote address: 200::1
IPsec Policy Template |
IPsec policy template name. |
Sequence number |
Sequence number of the IPsec policy template entry. |
Description of the IPsec policy template. |
ACL used by the IPsec policy template. |
Selector mode |
Data flow protection mode of the IPsec policy template: standard, aggregation, or per-host. |
Local address |
Local end IP address of the IPsec tunnel. |
IKE profile |
IKE profile used by the IPsec policy template. |
IKEv2 profile |
IKEv2 profile used by the IPsec policy template. |
Remote address |
Remote end IP address of the IPsec tunnel. |
Transform set |
Transform set used by the IPsec policy template. |
IPsec SA local duration(time based) |
IPsec SA local duration(traffic based) |
SA idle time |
Responder only |
display ipsec profile
Use display ipsec profile to display information about IPsec profiles.
display ipsec profile [ profile-name ]
profile-name: Specifies an IPsec profile by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify any parameters, this command displays information about all IPsec profiles.
# Display information about all IPsec profiles.
<Sysname> display ipsec profile
IPsec profile: myprofile
Mode: isakmp
Transform set: tran1
IKE profile: profile
Anti-Replay time-based window: 20
IPsec profile: profile
Mode: manual
Transform set: prop1
Inbound AH setting:
AH SPI: 12345 (0x00003039)
AH string-key:
AH authentication hex key: ******
ESP SPI: 23456 (0x00005ba0)
ESP string-key:
ESP encryption hex-key: ******
ESP authentication hex-key: ******
AH string-key:
ESP string-key:
ESP encryption hex key: ******
ESP authentication hex key: ******
Mode: SDWAN
SA duration (time based): 3600 seconds
IPsec profile |
IPsec profile name. |
Mode |
Negotiation mode used by the IPsec profile. · Manual—Manual mode. · ISAKMP—IKE negotiation mode. · SDWAN—SDWAN mode. |
Description of the IPsec profile. |
Transform set |
IPsec transform set used by the IPsec profile. |
IKE profile |
IKE profile used by the IPsec profile. |
Anti-replay time-based window size |
Time-based anti-replay window size, in seconds. |
SA idle time |
IPsec SA idle timeout, in seconds. If the IPsec SA idle timeout is not configured, this field displays two consecutive hyphens (--). |
Responder only |
ipsec profile
display ipsec sa
Use display ipsec sa to display information about IPsec SAs.
display ipsec sa [ brief | count | interface interface-type interface-number | { ipv6-policy | policy } policy-name [ seq-number ] | profile profile-name | remote [ ipv6 ] ip-address ]
brief: Displays brief information about all IPsec SAs.
count: Displays the number of IPsec SAs.
ipv6-policy: Displays detailed information about IPsec SAs created by using a specified IPv6 IPsec policy.
policy: Displays detailed information about IPsec SAs created by using a specified IPv4 IPsec policy.
seq-number: Specifies an IPsec policy entry by its sequence number. The value range is 1 to 65535.
profile: Displays detailed information about IPsec SAs created by using a specified IPsec profile.
remote ip-address: Specifies an IPsec SA by its remote end IP address.
ipv6: Specifies a remote end IPv6 address. To specify an IPv4 address, do not specify this keyword.
If you do not specify any parameters, this command displays detailed information about all IPsec SAs.
# Display brief information about IPsec SAs.
<Sysname> display ipsec sa brief
Interface/Global Dst Address SPI Protocol Status
XGE1/0/1 10.1.1.1 400 ESP Active
XGE1/0/1 255.255.255.255 4294967295 ESP Active
XGE1/0/1 100::1/64 500 AH Active
Global -- 600 ESP Active
Interface/Global |
Interface where the IPsec SA belongs to or global IPsec SA (created by using an IPsec profile). |
Dst Address |
Remote end IP address of the IPsec tunnel. For the IPsec SAs created by using IPsec profiles, this field displays two hyphens (--). |
SPI |
IPsec SA SPI. |
Protocol |
Security protocol used by IPsec. |
Status |
Status of the IPsec SA: Active or Standby. In a VSRP scenario, this field displays either Active or Standby. In standalone mode, this field always displays Active. |
# Display the number of IPsec SAs.
<Sysname> display ipsec sa count
Total IPsec SAs count: 4
# Display detailed information about all IPsec SAs.
Interface: Ten-GigabitEthernet0/0/6
IPsec policy: r2
Sequence number: 1
Mode: ISAKMP
Tunnel id: 3
Encapsulation mode: tunnel
Perfect Forward Secrecy:
Inside VPN: vp1
Extended Sequence Numbers enable: Y
Traffic Flow Confidentiality enable: N
Path MTU: 1443
Transmitting entity: Initiator
Tunnel:
local address/port: 2.2.2.2/500
remote address/port: 1.1.1.2/500
Flow:
sour addr: 192.168.2.0/255.255.255.0 port: 0 protocol: ip
dest addr: 192.168.1.0/255.255.255.0 port: 0 protocol: ip
[Inbound ESP SAs]
SPI: 3564837569 (0xd47b1ac1)
Connection ID: 90194313219
Transform set: ESP-ENCRYPT-AES-CBC-128 ESP-AUTH-SHA1
SA duration (kilobytes/sec): 4294967295/604800
SA remaining duration (kilobytes/sec): 1843200/2686
Max received sequence-number: 5
Anti-replay check enable: Y
Anti-replay window size: 32
UDP encapsulation used for NAT traversal: N
Status: Active
[Outbound ESP SAs]
SPI: 801701189 (0x2fc8fd45)
Connection ID: 64424509441
Max sent sequence-number: 6
Status: Active
Global IPsec SA
Mode: Manual
Encapsulation mode: transport
[Inbound AH SA]
SPI: 1234563 (0x0012d683)
Connection ID: 64426789452
Transform set: AH-SHA1
No duration limit for this SA
[Outbound AH SA]
SPI: 1234563 (0x002d683)
Connection ID: 64428999468
Table 5 Command output
Interface where the IPsec SA belongs. |
IPsec policy |
Name of the IPsec policy. |
IPsec profile |
Name of the IPsec profile. |
Sequence number |
Mode |
Negotiation mode used by the IPsec policy: · Manual—Manual mode. · ISAKMP—IKE negotiation mode. · Template—IPsec policy template mode. |
Tunnel id |
IPsec tunnel ID. |
Encapsulation mode |
Encapsulation mode, transport or tunnel. |
Perfect Forward Secrecy |
Perfect Forward Secrecy (PFS) used by the IPsec policy for negotiation: · 768-bit Diffie-Hellman group (dh-group1). · 1024-bit Diffie-Hellman group (dh-group2). · 1536-bit Diffie-Hellman group (dh-group5). · 2048-bit Diffie-Hellman group (dh-group14). · 2048-bit and 256_bit subgroup Diffie-Hellman group (dh-group24). · 256-bit ECP Diffie-Hellman group (dh-group19). · 384-bit ECP Diffie-Hellman group (dh-group20). |
Extended Sequence Numbers enable |
Whether Extended Sequence Number (ESN) is enabled. |
Traffic Flow Confidentiality enable |
Inside VPN |
VPN instance to which the protected data flow belongs. |
Path MTU |
Path MTU of the IPsec SA. |
Tunnel |
Local and remote addresses of the IPsec tunnel. |
Transmitting entity |
Role of the IKE negotiation entity: Initiator or Responder. |
local address/port |
Local end IP address and port number of the IPsec tunnel. |
remote address/port |
Remote end IP address and port number of the IPsec tunnel. |
Flow |
Information about the data flow protected by the IPsec tunnel. |
sour addr |
Source IP address of the data flow. |
dest addr |
Destination IP address of the data flow. |
port |
Port number. |
protocol |
Protocol type: · ip. · ipv6. |
SPI |
SPI of the IPsec SA. |
Connection ID |
Identifier of the IPsec SA. |
Transform set |
Security protocol and algorithms used by the IPsec transform set. |
SA duration (kilobytes/sec) |
IPsec SA lifetime, in Kilobytes or seconds. |
SA remaining duration (kilobytes/sec) |
Remaining IPsec SA lifetime, in Kilobytes or seconds. |
Max received sequence-number |
Max sequence number in the received packets. |
Max sent sequence-number |
Max sequence number in the sent packets. |
Anti-replay check enable |
Whether anti-replay checking is enabled. |
UDP encapsulation used for NAT traversal |
Whether NAT traversal is used by the IPsec SA. |
Status |
No duration limit for this SA |
The manual IPsec SAs do not have lifetime. |
ipsec sa global-duration
reset ipsec sa
display ipsec sdwan-sa local
Use display ipsec sdwan-sa local to display information about local SDWAN IPsec SAs.
display ipsec sdwan-sa local [ brief | count | interface tunnel tunnel-number | spi spi-number ]
brief:: Displays brief information about all local SDWAN IPsec SAs.
count: Displays the number of local SDWAN IPsec SAs.
interface: Displays information about SDWAN IPsec SAs on an interface.
tunnel tunnel-number: Specifies an SDWAN tunnel interface by the tunnel interface number. The specified SDWAN tunnel interface must have been created.
spi spi-number: Displays information about SDWAN IPsec SA with the specified SPI number. The value range for the spi-number argument is 256 to 4294967295.
If you do not specify any parameters, this command displays detailed information about all local SDWAN IPsec SAs.
# Display detailed information about all local SDWAN IPsec SAs.
<Sysname> display ipsec sdwan-sa local
Interface: Tunnel1
IPsec profile: abc
Mode: SDWAN
Site ID: 1
Device ID: 1
Interface ID: 1
Link ID: 273(0x111)
Local address: 10.1.1.1
[Inbound ESP SAs]
SPI: 2701952073 (0xa10c8449)
SA index: 0
Connection ID: 4294967296
SA duration (sec): 3600
SA remaining duration (sec): 3180
Anti-replay window size: 4096
Anti-replay time-based window size: 50
Status: Active
[Inbound AH SAs]
SA index: 1
Transform set: AH-AUTH-SHA1
Status: Active
# Display detailed information about the local SDWAN IPsec SA with a specific SPI.
<Sysname> display ipsec sdwan-sa local spi 1968608062
Interface: Tunnel0
IPsec profile: 2644
Mode: SDWAN
Site ID: 10
Device ID: 20
Interface ID: 30
Link ID: 660510 (0xa141e)
Local address: 200.200.200.10
[Inbound ESP SAs]
SPI: 1968608062 (0x7556933e)
SA index: 1
Connection ID: 12884901889
Transform set: ESP-ENCRYPT- ESP-AUTH-SHA384
SA remaining duration (sec): 1712
Anti-replay window size: 64
Status: Active
# Display detailed information about the local SDWAN IPsec SA on a specific interface.
<Sysname> display ipsec sdwan-sa local interface tunnel 2
Interface: Tunnel2
IPsec profile: 2644
Mode: SDWAN
Site ID: 10
Device ID: 20
Interface ID: 30
[Inbound ESP SAs]
SPI: 1968 (0x7b0)
SA index: 1
Status: Active
Table 6 Command output
SDWAN tunnel interface where the IPsec SA resides. |
IPsec profile |
Name of the IPsec profile used by the tunnel interface. |
Mode |
Negotiation mode used by the IPsec profile. · Manual—Manual mode. · ISAKMP—IKE negotiation mode. · SDWAN—SDWAN mode. · Template—IKE-based IPsec policy template mode. · GDOI—GDOI mode. |
Link ID |
Link index, which uniquely identifies an SDWAN tunnel. A link ID comprises a site ID, a device ID, and an interface ID. |
IPsec packet encapsulation mode, transport or tunnel. |
Local address |
Local IP address of the IPsec tunnel. |
Inbound ESP SAs |
ESP IPsec SA information in inbound direction. |
Inbound AH SAs |
AH IPsec SA information in inbound direction. |
SPI |
Security parameter index of the local IPsec SA, a globally unique value defined by protocol. |
SA index |
Index of the local IPsec SA. |
Connection ID |
Connection ID of the IPsec SA. |
Transform set |
Security protocols and algorithms used by the IPsec transform set. |
SA duration (sec) |
Lifetime of the IPsec SA, in seconds. If the lifetime is not configured, this field displays two hyphens (--). |
SA remaining duration |
Remaining lifetime of the IPsec SA, in seconds. If the lifetime is not configured, this field displays two hyphens (--). |
Indicates whether the anti-replay feature is enabled. |
Anti-replay window size |
Anti-replay window size, in number of packets. |
Status |
Status of the IPsec SA. · In a VSRP scenario, this field displays either Active or Standby. · In standalone mode, this field always displays Active. |
# Display brief information about all local SDWAN IPsec SAs.
<Sysname> display ipsec sdwan-sa local brief
Site ID Device ID Interface ID Link ID Local address SPI Protocol Status
10 20 30 660510 200.200.200.10 1968 ESP Active
# Displays the number of local SDWAN IPsec SAs.
<Sysname> display ipsec sdwan-sa local count
Total IPsec Sdwan Local SAs count: 1
Table 7 Command output
Link ID |
Local address |
SPI |
Protocol |
Security protocol, AH or ESP. |
Status |
Total IPsec Sdwan Local SAs count |
Total number of local SDWAN IPsec SAs. |
reset ipsec sdwan-sa local
display ipsec sdwan-sa remote
Use display ipsec sdwan-sa remote to display information about remote SDWAN IPsec SAs.
display ipsec sdwan-sa remote [ brief | count ]
brief: Displays brief information about all remote SDWAN IPsec SAs.
count: Displays the number of remote SDWAN IPsec SAs.
If you do not specify any parameters, this command displays detailed information about all remote SDWAN IPsec SAs.
# Display detailed information about all remote SDWAN IPsec SAs.
<Sysname> display ipsec sdwan-sa remote
Mode: SDWAN
Site ID: 20
Device ID: 20
Interface ID: 35
Link ID: 1315875 (0x141423)
Remote address: 200.200.200.20
[Outbound ESP SAs]
SPI: 2360 (0x936)
SA index: 0
Status: Active
Mode: SDWAN
Site ID: 30
Device ID: 30
Interface ID: 30
Link ID: 1973790 (0x1e1e1e)
Remote address: 200.200.200.30
[Outbound ESP SAs]
SPI: 4137 (0x1029)
SA index: 3
Connection ID: 4294967299
Status: Active
Table 8 Command output
Mode |
Site ID |
Site identity |
Device ID |
Device identity |
Interface ID |
Interface index. |
Link ID |
Remote address |
Remote IP address of the IPsec tunnel. |
Outbound ESP SAs |
ESP IPsec SA information in outbound direction. |
Outbound AH SAs |
AH IPsec SA information in outbound direction. |
SPI |
SA index |
Local IPsec SA index |
Connection ID |
Transform set |
Status |
# Display brief information about all remote SDWAN IPsec SAs.
<Sysname> display ipsec sdwan-sa remote brief
Site ID Device ID Interface ID Link ID Remote address SPI Protocol Status
20 20 35 1315875 200.200.200.20 2360 ESP Active
30 30 30 1973790 200.200.200.30 4137 ESP Active
# Displays the number of all remote SDWAN IPsec SAs.
<Sysname> display ipsec sdwan-sa remote count
Total IPsec Sdwan Remote SAs count: 1
Table 9 Command output
Link ID |
Remote address |
SPI |
Protocol |
Status |
Total IPsec Sdwan Remote SAs count |
Total number of remote SDWAN IPsec SAs. |
reset ipsec sdwan-sa remote
Use display ipsec sdwan-statistics to display packet statistics on SDWAN IPsec tunnels.
display ipsec sdwan-statistics [ tunnel-id tunnel-id ]
tunnel-id tunnel-id: Specifies an IPsec tunnel by the tunnel ID. The value range for the tunnel-id argument is 0 to 4294967294.
If you do not specify an IPsec tunnel, this command displays packet statistics on all SDWAN IPsec tunnels.
# Display packet statistics on all SDWAN IPsec tunnels.
<Sysname> display ipsec sdwan-statistics
IPsec packet statistics:
Received/sent packets: 47/64
Received/sent bytes: 3948/5208
Dropped packets (received/sent): 0/45
Dropped packets statistics
No available SA: 0
Wrong SA:
Invalid length: 0
Authentication failure: 0
Encapsulation failure: 0
Decapsulation failure: 0
Replayed packets: 0
MTU check failure: 0
Loopback limit exceeded: 0
Crypto speed limit exceeded: 0
# Display packet statistics on SDWAN IPsec tunnel 1.
<Sysname> display ipsec sdwan-statistics tunnel-id 1
No available SA: 0
Wrong SA:
Invalid length: 0
Replayed packets: 0
Table 10 Command output
Received/sent packets |
Number of received/sent IPsec-protected packets. |
Received/sent bytes |
Number of bytes of received/sent IPsec-protected packets. |
Dropped packets (received/sent) |
Number of dropped IPsec-protected packets (received/sent). |
No available SA |
Number of packets dropped due to lack of available IPsec SA. |
Wrong SA |
Number of packets dropped due to wrong IPsec SA. |
Invalid length |
Number of packets dropped due to invalid packet length. |
Authentication failure |
Number of packets dropped due to authentication failure. |
Encapsulation failure |
Number of packets dropped due to encapsulation failure. |
Decapsulation failure |
Number of packets dropped due to decapsulation failure. |
Replayed packets |
Number of dropped replayed packets. |
MTU check failure |
Number of packets dropped due to MTU check failure. |
Loopback limit exceeded |
Number of packets dropped due to loopback limit exceeded. |
Crypto speed limit exceeded |
Number of packets dropped due to crypto speed limit exceeded. |
reset ipsec sdwan-statistics
display ipsec sdwan-tunnel
Use display ipsec sdwan-tunnel to display information about SDWAN IPsec tunnels.
display ipsec sdwan-tunnel [ brief | count | remote-site site-id device-id interface-id | tunnel-id tunnel-id ]
brief: Displays brief information about SDWAN IPsec tunnels.
count: Displays the number of SDWAN IPsec tunnels.
remote-site site-id device-id interface-id: Specifies an IPsec tunnel by the remote site ID, device ID, and SDWAN tunnel interface ID. The site-id argument represents the site ID, in the range of 1 to 65535. The device-id argument represents the device ID, in the range of 1 to 255. The interface-id argument represents the interface ID, in the range of 1 to 255.
In an SDWAN network, IPsec establishes tunnels between SDWAN devices to protect data transmitted in between. Such IPsec tunnels are referred to as SDWAN IPsec tunnels.
If you do not specify any parameters, this command displays detailed information about all SDWAN IPsec tunnels.
For more information about SDWAN, see SDWAN configuration in SDWAN Configuration Guide.
# Display brief information about all SDWAN IPsec tunnels.
<Sysname> display ipsec sdwan-tunnel brief
Tunnel-ID Src Address Dst Address Inbound SPI Outbound SPI
1 1.2.3.1 2.2.2.2 5000 6000
Table 11 Command output
Tunnel-ID |
ID of the IPsec tunnel. |
Src Address |
Source IP address of the IPsec tunnel. |
Dst Address |
Destination IP address of the IPsec tunnel. |
Inbound SPI |
Valid inbound SPI in the IPsec tunnel. |
Outbound SPI |
Valid outbound SPI in the IPsec tunnel. |
# Displays the number of all SDWAN IPsec tunnels.
<Sysname> display ipsec sdwan-tunnel count
Total SDWAN IPsec tunnels: 2
# Display detailed information about all SDWAN IPsec tunnels.
Tunnel ID: 1
Status: Active
Path MTU: 1432
SA's SPI:
Outbound: 1091054028 (0x410829cc) [ESP]
Inbound: 2400381837 (0x8f12eb8d) [ESP]
Tunnel:
Local address: 11.1.2.1
Remote address: 11.1.3.1
Remote Site:
Site ID: 10
Device ID: 10
Interface ID: 35
# Display detailed information about the SDWAN IPsec tunnel with remote site ID of 10, device ID of 10, and SDWAN tunnel interface ID of 35.
<Sysname> display ipsec sdwan-tunnel remote-site 10 10 35
Tunnel ID: 1
Status: Active
Path MTU: 1432
SA's SPI:
Tunnel:
Remote Site:
Site ID: 10
Device ID: 10
Interface ID: 35
# Display detailed information about the SDWAN IPsec tunnel with tunnel ID of 1.
<Sysname> display ipsec sdwan-tunnel tunnel-id 1
Tunnel ID: 1
Status: Active
SA's SPI:
Tunnel:
Remote Site:
Site ID: 10
Device ID: 10
Interface ID: 35
Table 12 Command output
Tunnel ID |
Status |
Status of the IPsec tunnel. · In a VSRP scenario, this field displays either Active or Standby. · In standalone mode, this field always displays Active. |
Path MTU |
Path MTU of the SDWAN IPsec SA. |
SA's SPI |
SPIs of the inbound and outbound IPsec SAs. |
Outbound |
Inbound |
Tunnel |
Addresses of the local and remote ends of the IPsec tunnel. |
Local address |
Remote address |
Remote Site |
Remote site of the SDWAN IPsec tunnel. |
Site ID |
ID of the site. |
Device ID |
ID of the device. |
Interface ID |
Interface ID of the SDWAN IPsec tunnel interface. |
Link ID |
Link ID assigned to the TTE. A link ID identifies a TTE connection. |
reset ipsec sdwan-tunnel
display ipsec statistics
Use display ipsec statistics to display IPsec packet statistics.
display ipsec statistics [ tunnel-id tunnel-id ]
tunnel-id tunnel-id: Specifies an IPsec tunnel by its ID. The value range for the tunnel-id argument is 0 to 4294967294. You can use the display ipsec tunnel brief command to view the IDs of established IPsec tunnels.
If you do not specify any parameters, this command displays statistics for all IPsec packets.
# Display statistics for all IPsec packets.
<Sysname> display ipsec statistics
No available SA: 0
Wrong SA: 0
Invalid length: 0
Replayed packets: 0
ACL check failure: 45
Responder only limitation: 0
# Display statistics for the packets of IPsec tunnel 1.
<Sysname> display ipsec statistics tunnel-id 1
Received/sent packets: 5124/8231
Received/sent bytes: 52348/64356
Dropped packets (received/sent): 0/0
No available SA: 0
Wrong SA: 0
Invalid length: 0
Replayed packets: 0
ACL check failure: 0
Table 13 Command output
No available SA |
Wrong SA |
Invalid length |
Replayed packets |
ACL check failure |
Number of packets dropped due to ACL check failure. |
MTU check failure |
Responder only limitation |
Number of packets dropped due to responder only limitation. |
reset ipsec statistics
display ipsec transform-set
Use display ipsec transform-set to display information about IPsec transform sets.
display ipsec transform-set [ transform-set-name ]
transform-set-name: Specifies an IPsec transform set by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify an IPsec transform set, this command displays information about all IPsec transform sets.
# Display information about all IPsec transform sets.
<Sysname> display ipsec transform-set
IPsec transform set: mytransform
State: incomplete
ESN: Enabled
PFS:
Transform: ESP
IPsec transform set: completeTransform
State: complete
ESN: Enabled
PFS:
Transform: AH-ESP
AH protocol:
Integrity: SHA1
ESP protocol:
Integrity: SHA1
Encryption: AES-CBC-128
Table 14 Command output
IPsec transform set |
Name of the IPsec transform set. |
State |
Whether the IPsec transform set is complete. |
Encapsulation mode used by the IPsec transform set: transport or tunnel. |
ESN |
PFS |
Transform |
Security protocols used by the IPsec transform set: AH, ESP, or both. If both protocols are configured, IPsec uses ESP before AH. |
AH protocol |
AH settings. |
ESP protocol |
ESP settings. |
Integrity |
Authentication algorithm used by the security protocol. |
Encryption |
Encryption algorithm used by the security protocol. |
ipsec transform-set
Use display ipsec tunnel to display information about IPsec tunnels.
display ipsec tunnel { brief | count | tunnel-id tunnel-id }
brief: Displays brief information about all IPsec tunnels.
count: Displays information about the specified number of IPsec tunnels.
IPsec is a Layer 3 VPN technology that transmits data in a secure channel established between two endpoints (such as two security gateways). Such a secure channel is usually called an IPsec tunnel.
# Display brief information about all IPsec tunnels.
<Sysname> display ipsec tunnel brief
Tunn-id Src Address Dst Address Inbound SPI Outbound SPI Status
0 -- -- 1000 2000 Active
3000 4000
1 1.2.3.1 2.2.2.2 5000 6000 Active
7000 8000
Table 15 Command output
Src Address |
Source IP address of the IPsec tunnel. For IPsec SAs created by using IPsec profiles, this field displays two hyphens (--). |
Dst Address |
Destination IP address of the IPsec tunnel. For IPsec SAs created by using IPsec profiles, this field displays two hyphens (--). |
Inbound SPI |
Valid SPI in the inbound direction of the IPsec tunnel. If the tunnel uses two security protocols, two SPIs in the inbound direction are displayed in two lines. |
Outbound SPI |
Valid SPI in the outbound direction of the IPsec tunnel. If the tunnel uses two security protocols, two SPIs in the outbound direction are displayed in two lines. |
Status |
# Display the number of IPsec tunnels.
<Sysname> display ipsec tunnel count
Total IPsec Tunnel Count: 2
# Display detailed information about all IPsec tunnels.
Tunnel ID: 0
Status: Active
Perfect forward secrecy:
Inside vpn-instance:
SA's SPI:
outbound: 2000 (0x000007d0) [AH]
inbound: 1000 (0x000003e8) [AH]
outbound: 4000 (0x00000fa0) [ESP]
inbound: 3000 (0x00000bb8) [ESP]
Tunnel:
local address:
remote address:
Flow:
Tunnel ID: 1
Status: Active
SA's SPI:
outbound: 6000 (0x00001770) [AH]
inbound: 5000 (0x00001388) [AH]
outbound: 8000 (0x00001f40) [ESP]
inbound: 7000 (0x00001b58) [ESP]
Tunnel:
local address: 1.2.3.1
remote address: 2.2.2.2
Flow:
as defined in ACL 3100
# Display detailed information about IPsec tunnel 1.
<Sysname> display ipsec tunnel tunnel-id 1
Tunnel ID: 1
Status: Active
SA's SPI:
Tunnel:
Flow:
Table 16 Command output
Tunnel ID |
IPsec ID, used to uniquely identify an IPsec tunnel. |
Status |
IPsec tunnel status: Active or Standby. In a VSRP scenario, this field displays either Active or Standby. In standalone mode, this field always displays Active. |
Perfect forward secrecy |
Inside vpn-instance |
Name of the VPN instance to which the IPsec-protected data belongs. |
SA's SPI |
SPIs of the inbound and outbound SAs. |
Tunnel |
local address |
remote address |
Flow |
Information about the data flow protected by the IPsec tunnel, including source IP address, destination IP address, source port, destination port, and protocol. |
as defined in ACL 3001 |
Range of data flow protected by the IPsec tunnel that is established manually. This information shows that the IPsec tunnel protects all data flows defined by ACL 3001. |
domain
Use domain to add a peer domain name to an identity filter set.
Use undo domain to remove a peer domain name from an identity filter set.
domain domain-name
undo domain domain-name
No peer domain name is added to an identity filter set.
domain-name: Specifies the domain name of a peer, a case-sensitive string of 1 to 255 characters.
Operating mechanism
Use this command to configure domain name filtering conditions in an identity filter set. During an IPsec negotiation, the local end filters the negotiation initiator based on the specified domain names. When the initiator end meets one or more conditions of the identity filter set and the IPsec negotiation parameters on both ends match, the local and remote ends can successfully establish an IPsec tunnel.
To add multiple domain name filtering conditions to an identity filter set, execute this command multiple times.
# Configure the identity filter set to permit the peer with domain name domain1.
[Sysname-ipsec-ike-identity-identity1] domain domain1
ipsec ike-identity
encapsulation-mode
Use encapsulation-mode to set the encapsulation mode that the security protocol uses to encapsulate IP packets.
Use undo encapsulation-mode to restore the default.
encapsulation-mode { transport | tunnel }
IP packets are encapsulated in tunnel mode.
transport: Uses the transport mode for IP packet encapsulation.
tunnel: Uses the tunnel mode for IP packet encapsulation.
IPsec supports the following encapsulation modes:
· Transport mode—The security protocols protect the upper layer data of an IP packet. Only the transport layer data is used to calculate the security protocol headers. The calculated security protocol headers and the encrypted data (only for ESP encapsulation) are placed after the original IP header. You can use the transport mode when end-to-end security protection is required (the secured transmission start and end points are the actual start and end points of the data). The transport mode is typically used for protecting host-to-host communications.
· Tunnel mode—The security protocols protect the entire IP packet. The entire IP packet is used to calculate the security protocol headers. The calculated security protocol headers and the encrypted data (only for ESP encapsulation) are encapsulated in a new IP packet. In this mode, the encapsulated packet has two IP headers. The inner IP header is the original IP header. The outer IP header is added by the network device that provides the IPsec service. You must use the tunnel mode when the secured transmission start and end points are not the actual start and end points of the data packets (for example, when two gateways provide IPsec but the data start and end points are two hosts behind the gateways). The tunnel mode is typically used for protecting gateway-to-gateway communications.
The IPsec transform sets at both ends of the IPsec tunnel must have the same encapsulation mode.
# Configure IPsec transform set tran1 to use the transport mode for IP packet encapsulation.
[Sysname-ipsec-transform-set-tran1] encapsulation-mode transport
ipsec transform-set
esn enable
Use esn enable to enable the Extended Sequence Number (ESN) feature.
Use undo esn enable to disable the ESN feature.
esn enable [ both ]
undo esn enable
The ESN feature is disabled.
both: Specifies IPsec to support both extended sequence number and traditional sequence number. If you do not specify this keyword, IPsec only supports extended sequence number.
The ESN feature extends the sequence number length from 32 bits to 64 bits. This feature prevents the sequence number space from being exhausted when large volumes of data are transmitted at high speeds over an IPsec SA. If the sequence number space is not exhausted, the IPsec SA does not need to be renegotiated.
This feature must be enabled at both the initiator and the responder.
# Enable the ESN feature in IPsec transform set tran1.
[Sysname-ipsec-transform-set-tran1] esn enable
esp authentication-algorithm
Use esp authentication-algorithm to specify authentication algorithms for ESP.
Use undo esp authentication-algorithm to restore the default.
esp authentication-algorithm { aes-xcbc-mac | md5 | sha1 | sha256 | sha384 | sha512 | sm3 } *
ESP does not use any authentication algorithms.
You can specify multiple ESP authentication algorithms for one IPsec transform set, and the algorithm specified earlier has a higher priority.
For a manual or IKEv1-based IPsec policy, the first specified ESP authentication algorithm takes effect. To make sure an IPsec tunnel can be established successfully, the IPsec transform sets specified at both ends of the tunnel must have the same first ESP authentication algorithm.
# Configure IPsec transform set tran1 to use the HMAC-SHA1 algorithm as the ESP authentication algorithm.
[Sysname-ipsec-transform-set-tran1] esp authentication-algorithm sha1
ipsec transform-set
esp encryption-algorithm
Use esp encryption-algorithm to specify encryption algorithms for ESP.
Use undo esp encryption-algorithm to restore the default.
esp encryption-algorithm { 3des-cbc | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | aes-ctr-128 | aes-ctr-192 | aes-ctr-256 | camellia-cbc-128 | camellia-cbc-192 | camellia-cbc-256 | des-cbc | gmac-128 | gmac-192 | gmac-256 | gcm-128 | gcm-192 | gcm-256 | null | sm1-cbc-128 | sm4-cbc } *
ESP does not use any encryption algorithms.
3des-cbc: Specifies the 3DES algorithm in CBC mode, which uses a 168-bit key.
aes-cbc-128: Specifies the AES algorithm in CBC mode, which uses a 128-bit key.
aes-cbc-192: Specifies the AES algorithm in CBC mode, which uses a 192-bit key.
aes-cbc-256: Specifies the AES algorithm in CBC mode, which uses a 256-bit key.
aes-ctr-128: Specifies the AES algorithm in CTR mode, which uses a 128-bit key. This keyword is available only for IKEv2.
aes-ctr-192: Specifies the AES algorithm in CTR mode, which uses a 192-bit key. This keyword is available only for IKEv2.
aes-ctr-256: Specifies the AES algorithm in CTR mode, which uses a 256-bit key. This keyword is available only for IKEv2.
camellia-cbc-128: Specifies the Camellia algorithm in CBC mode, which uses a 128-bit key. This keyword is available only for IKEv2.
camellia-cbc-192: Specifies the Camellia algorithm in CBC mode, which uses a 192-bit key. This keyword is available only for IKEv2.
camellia-cbc-256: Specifies the Camellia algorithm in CBC mode, which uses a 256-bit key. This keyword is available only for IKEv2.
des-cbc: Specifies the DES algorithm in CBC mode, which uses a 64-bit key.
gmac-128: Specifies the GMAC algorithm, which uses a 128-bit key. This keyword is available only for IKEv2.
gmac-192: Specifies the GMAC algorithm, which uses a 192-bit key. This keyword is available only for IKEv2.
gmac-256: Specifies the GMAC algorithm, which uses a 256-bit key. This keyword is available only for IKEv2.
gcm-128: Specifies the GCM algorithm, which uses a 128-bit key. This keyword is available only for IKEv2.
gcm-192: Specifies the GCM algorithm, which uses a 192-bit key. This keyword is available only for IKEv2.
gcm-256: Specifies the GCM algorithm, which uses a 256-bit key. This keyword is available only for IKEv2.
null: Specifies the NULL algorithm, which means encryption is not performed.
sm1-cbc-128: Specifies the SM1 algorithm in CBC mode, which uses a 128-bit key. This keyword is available only for IKEv1.
sm4-cbc: Specifies the SM4 algorithm in CBC mode, which uses a 128-bit key. This keyword is available only for IKEv1.
You can specify multiple ESP encryption algorithms for one IPsec transform set, and the algorithm specified earlier has a higher priority.
For a manual or IKEv1-based IPsec policy, the first specified ESP encryption algorithm takes effect. To make sure an IPsec tunnel can be established successfully, the IPsec transform sets specified at both ends of the tunnel must have the same first ESP encryption algorithm.
GCM and GMAC algorithms are combined mode algorithms. GCM algorithms provide encryption and authentication services. GMAC algorithms only provide authentication service. Combined mode algorithms can be used only when ESP is used alone without AH. Combined mode algorithms cannot be used together with ordinary ESP authentication algorithms.
# Configure IPsec transform set tran1 to use the AES-CBC-128 algorithm as the ESP encryption algorithm.
[Sysname-ipsec-transform-set-tran1] esp encryption-algorithm aes-cbc-128
ipsec transform-set
fqdn
Use fqdn to add a peer FQDN name to an identity filter set.
Use undo fqdn to remove a peer FQDN name from an identity filter set.
fqdn fqdn-name
undo fqdn fqdn-name
No peer FQDN name is added to an identity filter set.
fqdn-name: Specifies the FQDN of a peer, a case-sensitive string of 1 to 255 characters.
Operating mechanism
Use this command to configure FQDN filtering conditions in an identity filter set. During an IPsec negotiation, the local end filters the negotiation initiator based on the specified FQDN names. When the initiator end meets one or more FQDN name conditions of the identity filter set and the IPsec negotiation parameters on both ends match, the local and remote ends can successfully establish an IPsec tunnel.
To add multiple FQDN names to an identity filter set, execute this command multiple times.
# Configure the identity filter set to permit the peer with FQDN name domain1.
[Sysname-ipsec-ike-identity-identity1] fqdn test
ipsec ike-identity
ike-profile
Use ike-profile to specify an IKE profile for an IPsec policy, IPsec profile, or IPsec policy template.
Use undo ike-profile to restore the default.
ike-profile profile-name
undo ike-profile
No IKE profile is specified.
IPsec policy view
IPsec profile view
profile-name: Specifies an IKE profile by its name, a case-insensitive string of 1 to 63 characters.
If no IKE profile is specified for an IPsec policy, IPsec profile, or IPsec policy template, the device selects an IKE profile configured in system view for negotiation. If no IKE profile is configured in system view, the device uses the global IKE settings.
The IKE profile specified for an IPsec policy, IPsec profile, or IPsec policy template defines the parameters used for IKE negotiation.
You can specify only one IKE profile for an IPsec policy, IPsec profile, or IPsec policy template.
# Specify IKE profile profile1 for IPsec policy policy1.
[Sysname] ipsec policy policy1 10 isakmp
[Sysname-ipsec-policy-isakmp-policy1-10] ike-profile profile1
ike profile
ikev2-profile
Use ikev2-profile to specify an IKEv2 profile for an IPsec policy, IPsec profile, or IPsec policy template.
Use undo ikev2-profile to restore the default.
ikev2-profile profile-name
undo ikev2-profile
No IKEv2 profile is specified.
IPsec policy view
IPsec profile view
profile-name: Specifies an IKEv2 profile by its name, a case-insensitive string of 1 to 63 characters.
The IKEv2 profile specified for an IPsec policy, IPsec profile, or IPsec policy template defines the parameters used for IKEv2 negotiation.
You can specify only one IKEv2 profile for an IPsec policy, IPsec profile, or IPsec policy template. On the initiator, an IKEv2 profile is required. On the responder, an IKEv2 profile is optional. If you do not specify an IKEv2 profile, the responder can use any IKEv2 profile for negotiation.
# Specify IKEv2 profile profile1 for IPsec policy policy1.
[Sysname-ipsec-policy-isakmp-policy1-10] ikev2-profile profile1
ikev2 profile
Use ipsec { ipv6-policy | policy } to create an IPsec policy entry and enter its view, or enter the view of an existing IPsec policy entry.
Use undo ipsec { ipv6-policy | policy } to delete an IPsec policy.
ipsec { ipv6-policy | policy } policy-name seq-number [ gdoi | isakmp | manual ]
undo ipsec { ipv6-policy | policy } policy-name [ seq-number ]
No IPsec policies exist.
ipv6-policy: Specifies an IPv6 IPsec policy.
policy: Specifies an IPv4 IPsec policy.
policy-name: Specifies a name for the IPsec policy, a case-insensitive string of 1 to 63 characters.
seq-number: Specifies a sequence number for the IPsec policy entry, in the range of 1 to 65535.
gdoi: Establishes IPsec SAs through Group Domain of Interpretation (GDOI) negotiation.
isakmp: Establishes IPsec SAs through IKE negotiation.
manual: Establishes IPsec SAs manually.
When you create an IPsec policy, you must specify the SA setup mode (gdoi, isakmp or manual). When you enter the view of an existing IPsec policy, you do not need to specify the SA setup mode.
You cannot change the SA setup mode of an existing IPsec policy.
An IPsec policy is a set of IPsec policy entries that have the same name but different sequence numbers. In the same IPsec policy, an IPsec policy entry with a smaller sequence number has a higher priority.
If you specify the seq-number argument, the undo command deletes the specified IPsec policy entry. If you do not specify this argument, the undo command deletes the specified IPsec policy.
An IPv4 IPsec policy and IPv6 IPsec policy can have the same name.
# Create an IKE-based IPsec policy entry and enter the IPsec policy view. The policy name is policy1 and the sequence number is 100.
[Sysname] ipsec policy policy1 100 isakmp
[Sysname-ipsec-policy-isakmp-policy1-100]
# Create a GDOI IPsec policy entry and enter the IPsec policy view. The policy name is policygdoi and the sequence number is 100.
[Sysname] ipsec policy policygdoi 100 gdoi
[Sysname-ipsec-policy-gdoi-policygdoi-100]
# Create a manual IPsec policy entry and enter the IPsec policy view. The policy name is policy1 and the sequence number is 101.
[Sysname] ipsec policy policy1 101 manual
[Sysname-ipsec-policy-manual-policy1-101]
ipsec apply
Use ipsec { ipv6-policy | policy } isakmp template to create an IKE-based IPsec policy entry by using an IPsec policy template.
ipsec { ipv6-policy | policy } policy-name seq-number isakmp template template-name
seq-number: Specifies a sequence number for the IPsec policy, in the range of 1 to 65535. A smaller number indicates a higher priority.
isakmp template template-name: Specifies an IPsec policy template by its name, a case-insensitive string of 1 to 63 characters.
An interface applied with an IPsec policy that is configured by using an IPsec policy template cannot initiate an SA negotiation, but it can respond to a negotiation request. The parameters not defined in the template are determined by the initiator. When the remote end's information (such as the IP address) is unknown, this method allows the remote end to initiate negotiations with the local end.
# Create an IPsec policy entry by using IPsec policy template temp1, and specify the IPsec policy name as policy2 and the sequence number as 200.
[Sysname] ipsec policy policy2 200 isakmp template temp1
Use ipsec { ipv6-policy | policy } local-address to bind an IPsec policy to a source interface.
Use undo ipsec { ipv6-policy | policy } local-address to remove the binding between an IPsec policy and a source interface.
ipsec { ipv6-policy | policy } policy-name local-address interface-type interface-number
undo ipsec { ipv6-policy | policy } policy-name local-address
No IPsec policy is bound to a source interface.
policy-name: Specifies an IPsec policy name, a case-insensitive string of 1 to 63 characters.
local-address interface-type interface-number: Specifies the shared source interface by its type and number.
For high availability, two interfaces can operate in backup mode. After an IPsec policy is applied to the two interfaces, they negotiate with their peers to establish IPsec SAs separately. When one interface fails and a link failover occurs, the other interface needs to take some time to renegotiate SAs, resulting in service interruption.
To solve these problems, bind a source interface to an IPsec policy and apply the policy to both interfaces. This enables the two physical interfaces to use the same source interface to negotiate IPsec SAs. As long as the source interface is up, the negotiated IPsec SAs will not be removed and will keep working, regardless of link failover.
After an IPsec policy is applied to a service interface and IPsec SAs have been established, if you bind the IPsec policy to a source interface, the existing IPsec SAs are deleted.
Only an IKE-based IPsec policy can be bound to a source interface.
An IPsec policy can be bound to only one source interface. If you execute this command multiple times, the most recent configuration takes effect.
A source interface can be bound to multiple IPsec policies.
As a best practice, use a stable interface, such as a Loopback interface, as a source interface.
# Bind IPsec policy map to source interface Loopback 11.
[Sysname] ipsec policy map local-address loopback 11
Use ipsec { ipv6-policy-template | policy-template } to create an IPsec policy template entry and enter its view, or enter the view of an existing IPsec policy template entry.
Use undo ipsec { ipv6-policy-template | policy-template } to delete an IPsec policy template.
ipsec { ipv6-policy-template | policy-template } template-name seq-number
undo ipsec { ipv6-policy-template | policy-template } template-name [ seq-number ]
No IPsec policy templates exist.
ipv6-policy-template: Specifies an IPv6 IPsec policy template.
policy-template: Specifies an IPv4 IPsec policy template.
template-name: Specifies a name for the IPsec policy template, a case-insensitive string of 1 to 63 characters.
seq-number: Specifies a sequence number for the IPsec policy template entry, in the range of 1 to 65535. A smaller number indicates a higher priority.
The configurable parameters for an IPsec policy template are similar to the parameters that you use when you configure an IKE-based IPsec policy. However, all parameters except for the IPsec transform sets and the IKE peer are optional for an IPsec policy template.
An IPsec policy template is a set of IPsec policy template entries that have the same name but different sequence numbers.
With the seq-number argument specified, the undo command deletes an IPsec policy template entry.
An IPv4 IPsec policy template and an IPv6 IPsec policy template can have the same name.
# Create an IPsec policy template entry and enter the IPsec policy template view. The template name is template1 and the sequence number is 100.
[Sysname] ipsec policy-template template1 100
[Sysname-ipsec-policy-template-template1-100]
Use ipsec anti-replay check to enable IPsec anti-replay checking.
Use undo ipsec anti-replay check to disable IPsec anti-replay checking.
IPsec anti-replay checking is enabled.
IPsec packet de-encapsulation involves complicated calculation. De-encapsulation of replayed packets is not necessary but consumes large amounts of resources and degrades performance, resulting in DoS. IPsec anti-replay checking, when enabled, is performed before the de-encapsulation process, reducing resource waste.
In some situations, service data packets are received in a different order than their original order. The IPsec anti-replay feature drops them as replayed packets, which impacts communications. If this happens, disable IPsec anti-replay checking or adjust the size of the anti-replay window as required.
Only IPsec SAs negotiated by IKE support anti-replay checking. Manually created IPsec SAs do not support anti-replay checking. Enabling or disabling IPsec anti-replay checking does not affect manually created IPsec SAs.
# Enable IPsec anti-replay checking.
[Sysname] ipsec anti-replay check
Use ipsec anti-replay window to set the anti-replay window size.
Use undo ipsec anti-replay window to restore the default.
ipsec anti-replay window width
The anti-replay window size is 64.
width: Specifies the size for the anti-replay window. It can be 64, 128, 256, 512, 1024, 2048, or 4096 packets.
Service data packets might be received in a very different order than their original order, and the IPsec anti-replay feature might drop them as replayed packets, affecting normal communications. If this happens, disable IPsec anti-replay checking or adjust the size of the anti-replay window as required.
If you configure both the anti-replay window size (using this command) and the time-based anti-replay window size (using the anti-replay time-based window command) for an SDWAN IPsec profile, only the time-based anti-replay window size takes effect.
Changing the anti-replay window size affects only the IPsec SAs negotiated later.
# Set the size of the anti-replay window to 128.
[Sysname] ipsec anti-replay window 128
ipsec apply
Use ipsec apply to apply an IPsec policy to an interface.
Use undo ipsec apply to remove an IPsec policy application from an interface.
ipsec apply { ipv6-policy | policy } policy-name
undo ipsec apply { ipv6-policy | policy }
No IPsec policy is applied to an interface.
Interface view
On an interface, you can apply a maximum of two IPsec policies: one IPv4 IPsec policy and one IPv6 IPsec policy.
An IKE-based IPsec policy that is bound to a source interface can be applied to multiple interfaces. A manual IPsec policy can be applied to only one interface.
# Apply IPsec policy policy1 to Ten-GigabitEthernet 0/0/6.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] ipsec apply policy policy1
ipsec decrypt-check enable
Use ipsec decrypt-check enable to enable ACL checking for de-encapsulated IPsec packets.
Use undo ipsec decrypt-check to disable ACL checking for de-encapsulated IPsec packets.
undo ipsec decrypt-check enable
ACL checking for de-encapsulated IPsec packets is enabled.
In tunnel mode, the IP packet encapsulated in an inbound IPsec packet might not be under the protection of the ACL specified in the IPsec policy. After being de-encapsulated, such packets bring threats to the network security. In this scenario, you can enable ACL checking for de-encapsulated IPsec packets. All packets failing the checking are discarded, improving the network security.
# Enable ACL checking for de-encapsulated IPsec packets.
[Sysname] ipsec decrypt-check enable
ipsec df-bit
Use ipsec df-bit to configure the DF bit for the outer IP header of IPsec packets on an interface.
Use undo ipsec df-bit to restore the default.
ipsec df-bit { clear | copy | set }
undo ipsec df-bit
The DF bit is not configured for the outer IP header of IPsec packets on an interface. The global DF bit setting is used.
Interface view
clear: Clears the DF bit in the outer IP header. IPsec packets can be fragmented.
copy: Copies the DF bit setting of the original IP header to the outer IP header.
set: Sets the DF bit in the outer IP header. IPsec packets cannot be fragmented.
This command is effective only when the IPsec encapsulation mode is tunnel mode. It is not effective in transport mode because the outer IP header is not added in transport mode.
This command does not change the DF bit for the original IP header of IPsec packets.
If multiple interfaces use an IPsec policy that is bound to a source interface, you must use the same DF bit setting on these interfaces.
Packet fragmentation and reassembly might cause packet forwarding to be delayed. You can set the DF bit to avoid the forwarding delay. However, to prevent the IPsec packets from being discarded, you must make sure the path MTU is larger than the IPsec packet size. As a best practice, clear the DF bit if you cannot make sure the path MTU is larger than the IPsec packet size.
# Set the DF bit in the outer IP header of IPsec packets on Ten-GigabitEthernet 0/0/7.
[Sysname] interface ten-gigabitethernet 0/0/7
[Sysname-Ten-GigabitEthernet0/0/7] ipsec df-bit set
ipsec global-df-bit
ipsec fragmentation
Use ipsec fragmentation to configure the IPsec fragmentation feature.
Use undo ipsec fragmentation to restore the default.
ipsec fragmentation { after-encryption | before-encryption }
The device fragments packets before IPsec encapsulation.
after-encryption: Fragments packets after IPsec encapsulation.
before-encryption: Fragments packets before IPsec encapsulation.
If you configure the device to fragment packets before IPsec encapsulation, the device predetermines the encapsulated packet size before the actual encapsulation. If the encapsulated packet size exceeds the MTU of the output interface and the DF bit is not set, the device fragments the packet before encapsulation. If the packet's DF bit is set, the device drops the packet and sends an ICMP error message.
If you configure the device to fragment packets after IPsec encapsulation, the device directly encapsulates the packets and fragments the encapsulated packets in subsequent service modules.
# Configure the device to fragment packets after IPsec encapsulation.
<Sysname>system-view
[Sysname] ipsec fragmentation after-encryption
ipsec global-df-bit
Use ipsec global-df-bit to configure the DF bit for the outer IP header of IPsec packets on all interfaces.
Use undo ipsec global-df-bit to restore the default.
ipsec global-df-bit { clear | copy | set }
The DF bit setting of the original IP header is copied to the outer IP header for IPsec packets.
Packet fragmentation and reassembly might cause packet forwarding to be delayed. You can set the DF bit to avoid the forwarding delay. However, to prevent IPsec packets from being discarded, you must make sure the path MTU is larger than the IPsec packet size. As a best practice, clear the DF bit if you cannot make sure the path MTU is larger than the IPsec packet size.
# Set the DF bit in the outer IP header of IPsec packets on all interfaces.
[Sysname] ipsec global-df-bit set
ipsec df-bit
ipsec ike-identity
Use ipsec ike-identity to create an identity filter set and enter its view, or enter the view of an existing identity filter set.
Use undo ipsec ike-identity to delete an identity filter set.
ipsec ike-identity identity-name
undo ipsec ike-identity identity-name
No identity filter sets exist.
identity-name: Specifies the name of an identity filter set, a case-insensitive string of 1 to 63 characters.
Operating mechanism
Identity filter sets are used to implement initiator identity control during IPsec tunnel negotiation. Only initiators that match the identity filter sets are permitted to perform IPsec negotiations and establish IPsec tunnels with the responder.
In an identity filter set, you can define filtering conditions (or simply filters) for the initiator, including IP address, domain name, FQDN name, and user FQDN name.
This command can only be configured on the hub in a hub-spoke network.
When the remote end meets one or more conditions of the identity filter set and the IPsec negotiation parameters on both ends match, the local and remote ends can successfully establish an IPsec tunnel.
# Create an identity filter set named identity1 and enter its view.
[Sysname] ipsec ike-identity identity1
match ike-identity
ipsec limit max-tunnel
Use ipsec limit max-tunnel to set the maximum number of IPsec tunnels.
Use undo ipsec limit max-tunnel to restore the default.
ipsec limit max-tunnel tunnel-limit
tunnel-limit: Specifies the maximum number of IPsec tunnels, in the range of 1 to 4294967295.
To maximize concurrent performance of IPsec when memory is sufficient, increase the maximum number of IPsec tunnels. To ensure service availability when memory is insufficient, decrease the maximum number of IPsec tunnels.
# Set the maximum number of IPsec tunnels to 5000.
[Sysname] ipsec limit max-tunnel 5000
ike limit
ipsec logging negotiation enable
Use ipsec logging negotiation enable to enable logging for IPsec negotiation.
Use undo ipsec logging negotiation packet enable to disable logging for IPsec negotiation.
undo ipsec logging negotiation enable
Logging for IPsec negotiation is disabled.
This command enables the device to output logs for the IPsec negotiation process.
# Enable logging for IPsec negotiation.
[Sysname] ipsec logging negotiation enable
ipsec logging packet enable
Use ipsec logging packet enable to enable logging for IPsec packets.
Use undo ipsec logging packet enable to disable logging for IPsec packets.
Logging for IPsec packets is disabled.
After logging for IPsec packets is enabled, the device outputs a log when an IPsec packet is discarded. IPsec packets might be discarded due to lack of inbound SA, AH/ESP authentication failure, or ESP encryption failure. A log contains the source and destination IP addresses, SPI, and sequence number of the packet, and the reason it was discarded.
# Enable logging for IPsec packets.
[Sysname] ipsec logging packet enable
ipsec no-nat-process enable
Use ipsec no-nat-process enable to enable the IPsec no NAT feature.
Use undo ipsec no-nat-process enable to restore the default.
The IPsec no NAT feature is disabled.
Interface view
CAUTION: This feature affects NAT processing. Use it with caution. |
On an interface where both IPsec and NAT are configured, the device performs NAT processing before IPsec processing for outgoing packets. Packets after NAT cannot be identified by IPsec. For packets to be protected by IPsec correctly on the interface, you need to deploy complicated configuration to identify traffic for NAT and that for IPsec.
After the IPsec no NAT feature is enabled, the device does not perform NAT for the traffic to be processed by IPsec. So, you do not need to distinguish traffic for NAT and IPsec, reducing the configuration complexity.
After enabling this feature, you need to execute the reset nat session command in user view to delete existing NAT sessions, so that subsequent IPsec traffic does not undergo NAT translation.
# Enable the IPsec no NAT feature on interface Ten-GigabitEthernet 0/0/6.
[Sysname-Ten-GigabitEthernet0/0/6] ipsec no-nat-process enable
ipsec profile
Use ipsec profile to create an IPsec profile and enter its view, or enter the view of an existing IPsec profile.
Use undo ipsec profile to delete an IPsec profile.
ipsec profile profile-name [ isakmp | manual | sdwan ]
undo ipsec profile profile-name
No IPsec profiles exist.
profile-name: Specifies a name for the IPsec profile, a case-insensitive string of 1 to 63 characters.
isakmp: Specifies the IPsec SA setup mode as IKE.
manual: Specifies the IPsec SA setup mode as manual.
sdwan: Specifies the IPsec SA setup mode as SDWAN.
When you create an IPsec profile, you must specify the IPsec SA setup mode. When you enter the view of an existing IPsec profile, you do not need to specify the IPsec SA setup mode.
A manual IPsec profile is similar to a manual IPsec policy. It is used exclusively for IPsec protection for application protocols, including OSPFv3, IPv6 BGP, and RIPng.
An IKE-based IPsec profile is similar to an IKE-based IPsec policy. It uses IKE negotiation to establish IPsec SAs to protect IPv4 and IPv6 application protocols, such as ADVPN. An IKE-based IPsec profile does not require you to specify the remote end address or an ACL.
An SDWAN IPsec profile is used to generate IPsec SAs on SDWAN devices. It is applied to an SDWAN tunnel interface to protect all the traffic routed to the interface. You do not need to specify the remote end address or an ACL.
# Create a manual IPsec profile named profile1.
[Sysname] ipsec profile profile1 manual
[Sysname-ipsec-profile-manual-profile1]
# Create an IKE-based IPsec profile named profile1.
[Sysname] ipsec profile profile1 isakmp
[Sysname-ipsec-profile-isakmp-profile1]
# Create an SDWAN IPsec profile named profile1.
[Sysname] ipsec profile profile1 sdwan
[Sysname-ipsec-profile-sdwan-profile1]
ipsec redundancy enable
Use ipsec redundancy enable to enable IPsec redundancy.
Use undo ipsec redundancy enable to disable IPsec redundancy.
IPsec redundancy is disabled.
With IPsec redundancy enabled, the system synchronizes the following information from the active device to the standby device at configurable intervals:
· Lower bound values of the IPsec anti-replay window for inbound packets.
· IPsec anti-replay sequence numbers for outbound packets.
The synchronization ensures uninterrupted IPsec traffic forwarding and anti-replay protection when the active device fails.
To configure synchronization intervals, use the redundancy replay-interval command.
# Enable IPsec redundancy.
[Sysname] ipsec redundancy enable
Use ipsec sa global-duration to configure the global IPsec SA lifetime.
Use undo ipsec sa global-duration to restore the default.
ipsec sa global-duration { time-based seconds | traffic-based kilobytes }
undo ipsec sa global-duration { time-based | traffic-based }
The time-based global IPsec SA lifetime is 3600 seconds, and the traffic-based global lifetime is 1843200 Kilobytes.
time-based seconds: Specifies the time-based global lifetime for IPsec SAs, in the range of 180 to 604800 seconds.
traffic-based kilobytes: Specifies the traffic-based global lifetime for IPsec SAs, in the range of 2560 to 4294967295 Kilobytes. When traffic on an SA reaches this value, the SA expires.
You can also configure IPsec SA lifetimes in IPsec policy view or IPsec policy template view. The device prefers the IPsec SA lifetimes configured in IPsec policy view or IPsec policy template view over the global IPsec SA lifetimes.
When IKE negotiates IPsec SAs, it uses the local lifetime settings or those proposed by the peer, whichever are smaller.
An IPsec SA can have both a time-based lifetime and a traffic-based lifetime. The IPsec SA expires when either lifetime expires. Before the IPsec SA expires, IKE negotiates a new IPsec SA, which takes over immediately after its creation.
# Configure the global IPsec SA lifetime as 7200 seconds.
[Sysname] ipsec sa global-duration time-based 7200
# Configure the global IPsec SA lifetime as 10240 Kilobytes.
[Sysname] ipsec sa global-duration traffic-based 10240
display ipsec sa
sa duration
ipsec sa global-soft-duration buffer
Use ipsec sa global-soft-duration buffer to set the global time-based or traffic-based IPsec SA soft lifetime buffer.
Use undo ipsec sa global-soft-duration buffer to restore the default.
ipsec sa global-soft-duration buffer { time-based seconds | traffic-based kilobytes }
undo ipsec sa global-soft-duration buffer { time-based | traffic-based }
The global time-based and traffic-based IPsec SA soft lifetime buffers are not configured.
time-based seconds: Specifies the time-based IPsec SA soft lifetime buffer, in seconds. The value range is 20 to 201600.
traffic-based kilobytes: Specifies the traffic-based IPsec SA soft lifetime buffer, in Kilobytes. The value range is 1000 to 4294901760.
This command takes effect only when IKEv1 is used.
The IPsec SA soft lifetime buffers are used to determine the IPsec SA soft lifetimes.
If no IPsec SA soft lifetime buffers are configured, the system calculates a default time-based and a default traffic-based IPsec SA soft lifetime.
If IPsec SA soft lifetime buffers are configured, the system calculates IPsec SA soft lifetimes as follows:
· Time-based IPsec SA soft lifetime = time-based IPsec SA lifetime – time-based IPsec SA soft lifetime buffer.
If the calculated time-based IPsec SA soft lifetime is shorter than or equal to 20 seconds, the system uses the default time-based IPsec SA soft lifetime.
· Traffic-based IPsec SA soft lifetime = traffic-based IPsec SA lifetime – traffic-based IPsec SA soft lifetime buffer.
If the calculated traffic-based IPsec SA soft lifetime is smaller than or equal to 1000 Kilobytes, the system uses the default traffic-based IPsec SA soft lifetime.
You can also configure IPsec SA soft lifetime buffers in IPsec policy view or IPsec profile view. The device prefers the IPsec SA lifetime buffers configured in IPsec policy view or IPsec profile view over the global lifetime buffers configured in system view.
# Set the global time-based IPsec SA soft lifetime buffer to 600 seconds.
[Sysname] ipsec sa global-soft-duration buffer time-based 600
# Set the global traffic-based IPsec SA soft lifetime buffer to 10000 Kilobytes.
[Sysname] ipsec sa global-soft-duration buffer traffic-based 10000
sa soft-duration buffer
ipsec sa idle-time
Use ipsec sa idle-time to enable the global IPsec SA idle timeout feature and set the idle timeout. If no traffic matches an IPsec SA within the idle timeout interval, the IPsec SA is deleted.
Use undo ipsec sa idle-time to disable the global IPsec SA idle timeout feature.
ipsec sa idle-time seconds
The global IPsec SA idle timeout feature is disabled.
seconds: Specifies the IPsec SA idle timeout in the range of 60 to 86400 seconds.
This feature applies only to IPsec SAs negotiated by IKE.
The IPsec SA idle timeout can also be configured in IPsec policy view, IPsec profile view, or IPsec policy template view, which takes precedence over the global IPsec SA timeout.
# Enable the global IPsec SA idle timeout feature and set the IPsec SA idle timeout to 600 seconds.
[Sysname] ipsec sa idle-time 600
display ipsec sa
sa idle-time
ipsec sdwan-statistics enable
Use ipsec sdwan-statistics enable to enable packet statistics on SDWAN IPsec tunnels.
Use undo ipsec sdwan-statistics enable to disable packet statistics on SDWAN IPsec tunnels.
Packet statistics on SDWAN IPsec tunnels are enabled.
With this command enabled, the device generates a large amount of statistics when processing a high volume of SDWAN traffic, occupying significant storage space and affecting the SDWAN forwarding performance. In this case, you can use the undo command to disable packet statistics on SDWAN IPsec tunnels to ensure the SDWAN forwarding performance. When the SDWAN traffic is low or service issues arise, you can enable packet statistics on SDWAN IPsec tunnels to collect packet statistics or assist in troubleshooting. To display packet statistics on SDWAN IPsec tunnels, execute the display ipsec sdwan-statistics command.
# Disable packet statistics on SDWAN IPsec tunnels.
[Sysname] undo ipsec sdwan-statistics enable
ipsec transform-set
Use ipsec transform-set to create an IPsec transform set and enter its view, or enter the view of an existing IPsec transform set.
Use undo ipsec transform-set to delete an IPsec transform set.
ipsec transform-set transform-set-name
undo ipsec transform-set transform-set-name
No IPsec transform sets exist.
transform-set-name: Specifies a name for the IPsec transform set, a case-insensitive string of 1 to 63 characters.
An IPsec transform set, part of an IPsec policy, defines the security parameters for IPsec SA negotiation, including the security protocol, encryption algorithms, authentication algorithms, and encapsulation mode.
# Create an IPsec transform set named tran1 and enter its view.
[Sysname] ipsec transform-set tran1
[Sysname-transform-set-tran1]
local-address
Use local-address to configure the local IP address for the IPsec tunnel.
Use undo local-address to restore the default.
local-address { ipv4-address | ipv6 ipv6-address }
undo local-address
The primary IPv4 address of the interface to which the IPsec policy is applied is used as the local IPv4 address. The first IPv6 address of the interface to which the IPsec policy is applied is used as the local IPv6 address.
IPsec policy view
ipv4-address: Specifies the local IPv4 address for the IPsec tunnel.
ipv6 ipv6-address: Specifies the local IPv6 address for the IPsec tunnel.
The remote IP address on the IKE negotiation initiator must be the same as the local address on the IKE negotiation responder.
In a VRRP network, the local IP address must be the virtual IP address of the VRRP group to which the IPsec-applied interface belongs.
# Configure local address 1.1.1.1 for the IPsec tunnel.
[Sysname] ipsec policy map 1 isakmp
[Sysname-ipsec-policy-isakmp-map-1] local-address 1.1.1.1
remote-address
match ike-identity
Use match ike-identity to specify an identity filter set for an IPsec profile or IPsec policy template.
Use undo match ike-identity to restore the default.
match ike-identity identity-name
undo match ike-identity identity-name
No identity filter set is specified for an IPsec profile or IPsec policy template.
IPsec profile view
Operating mechanism
During IPsec negotiation, if an identity filter set is specified for an IPsec profile or IPsec policy template, the IPsec profile or IPsec policy template will filter the initiator peers based on the set's conditions. Only the matching peers can access the local end.
An identity filter set is typically specified for an IPsec profile or IPsec policy template.
When the device has multiple IPsec profiles applied to different Tunnel interfaces, use different identity parameters in each identity filter set specified for these IPsec profiles.
# Specify an identity filter set for an IPsec profile.
[Sysname-ipsec-ike-identity-identity1] fqdn peer
[Sysname-ipsec-ike-identity-identity1] quit
[Sysname-ipsec-profile-isakmp-profile1] match ike-identity identity1
ipsec ike-identity
ipsec profile
pfs
Use pfs to enable the Perfect Forward Secrecy (PFS) feature for an IPsec transform set.
Use undo pfs to restore the default.
pfs { dh-group1 | dh-group2 | dh-group5 | dh-group14 | dh-group19 | dh-group20 | dh-group24 }
undo pfs
The PFS feature is disabled for the IPsec transform set.
IPsec transform set view
dh-group1: Uses 768-bit Diffie-Hellman group.
dh-group2: Uses 1024-bit Diffie-Hellman group.
dh-group5: Uses 1536-bit Diffie-Hellman group.
dh-group14: Uses 2048-bit Diffie-Hellman group.
dh-group24: Uses 2048-bit and 256-bit subgroup Diffie-Hellman group.
dh-group19: Uses 256-bit ECP Diffie-Hellman group. This keyword is available only for IKEv2.
dh-group20: Uses 384-bit ECP Diffie-Hellman group. This keyword is available only for IKEv2.
In terms of security and required calculation time, the following groups are in descending order:
· 384-bit ECP Diffie-Hellman group (dh-group20).
· 256-bit ECP Diffie-Hellman group (dh-group19).
· 2048-bit and 256-bit subgroup Diffie-Hellman group (dh-group24).
· 2048-bit Diffie-Hellman group (dh-group14).
· 1536-bit Diffie-Hellman group (dh-group5).
· 1024-bit Diffie-Hellman group (dh-group2).
· 768-bit Diffie-Hellman group (dh-group1).
If IKEv1 is used, the security level of the Diffie-Hellman group of the initiator must be higher than or equal to that of the responder. This restriction does not apply to IKEv2.
The end without the PFS feature performs IKE negotiation according to the PFS requirements of the peer end.
# Enable PFS using 2048-bit Diffie-Hellman group for IPsec transform set tran1.
[Sysname-ipsec-transform-set-tran1] pfs dh-group14
policy enable
Use policy enable to enable an IPsec policy entry or IPsec policy template entry.
Use undo policy enable to disable an IPsec policy entry or IPsec policy template entry.
policy enable
undo policy enable
An IPsec policy entry or IPsec policy template entry is enabled.
IPsec policy view
This command applies only to IKE-based IPsec policies and IKE-based IPsec policy templates.
You can use this command to disable an IPsec policy entry or IPsec policy template entry without deleting the entry. Disabling an IPsec policy entry or IPsec policy template entry will delete all IPsec SAs established based on that entry. A disabled IPsec policy entry or IPsec policy template entry cannot be used for SA negotiation until it is enabled.
# Disable the IPsec policy entry whose name is policy1 and sequence number is 10.
[Sysname-ipsec-policy-isakmp-policy1-10] undo policy enable
protocol
Use protocol to specify a security protocol for an IPsec transform set.
Use undo protocol to restore the default.
protocol { ah | ah-esp | esp }
undo protocol
The IPsec transform set uses the ESP protocol.
ah: Specifies the AH protocol.
ah-esp: Specifies using the ESP protocol first and then using the AH protocol.
The two tunnel ends must use the same security protocol in the IPsec transform set.
# Specify the AH protocol for the IPsec transform set.
[Sysname-ipsec-transform-set-tran1] protocol ah
qos pre-classify
Use qos pre-classify to enable the QoS pre-classify feature.
Use undo qos pre-classify to disable the QoS pre-classify feature.
qos pre-classify
The QoS pre-classify feature is disabled. QoS uses the new IP header of IPsec packets to perform traffic classification.
IPsec policy view
The QoS pre-classify feature enables QoS to classify packets by using the IP header of the original IP packets.
# Enable the QoS pre-classify feature.
[Sysname] ipsec policy policy1 100 manual
[Sysname-ipsec-policy-manual-policy1-100] qos pre-classify
Use redundancy replay-interval to set the anti-replay window lower bound value synchronization interval for inbound packets and the sequence number synchronization interval for outbound packets.
Use undo redundancy replay-interval to restore the default.
redundancy replay-interval inbound inbound-interval outbound outbound-interval
The active device synchronizes the anti-replay window lower bound value every time it receives 1000 packets and synchronizes the sequence number every time it sends 100000 packets.
IPsec policy view
inbound inbound-interval: Specifies the interval at which the active device synchronizes the lower bound value of the IPsec anti-replay window to the standby device. This interval is expressed in the number of received packets, in the range of 0 to 1000. If you set the value to 0, the lower bound value of the anti-replay window will not be synchronized.
outbound outbound-interval: Specifies the interval at which the active device synchronizes the IPsec anti-replay sequence number to the standby device. This interval is expressed in the number of sent packets, in the range of 1000 to 100000.
The intervals take effect only after you enable IPsec redundancy by using the ipsec redundancy enable command.
A short interval improves the anti-replay information consistency between the active device and the standby device, but it sacrifices the forwarding performance of the devices.
# Set the anti-replay window lower bound value synchronization interval for inbound packets to 800. Set the sequence number synchronization interval for outbound packets to 50000.
[Sysname] ipsec policy test 1 manual
[sysname-ipsec-policy-manual-test-1] redundancy replay-interval inbound 800 outbound 50000
remote-address
Use remote-address to configure the remote IP address for the IPsec tunnel.
Use undo remote-address to restore the default.
remote-address { [ ipv6 ] host-name | ipv4-address | ipv6 ipv6-address }
undo remote-address
No remote IP address is configured for the IPsec tunnel.
IPsec policy view
ipv6: Specifies the remote address or host name of an IPv6 IPsec tunnel. To specify the remote address or host name of an IPv4 IPsec tunnel, do not specify this keyword.
hostname: Specifies the remote host name, a case-insensitive string of 1 to 253 characters. The host name can be resolved to an IP address by the DNS server.
ipv4-address: Specifies a remote IPv4 address.
ipv6-address: Specifies a remote IPv6 address.
This remote IP address configuration is required on the IKE negotiation initiator and optional on the responder if the responder uses an IPsec policy template.
A manual IPsec policy does not support DNS. Therefore, you must specify a remote IP address rather than a remote host name for the manual IPsec policy.
If you configure a remote host name, make sure the local end can always resolve the host name into the latest IP address of the remote end.
· If a DNS server is used for resolution, the local end queries the remote IP address again from the DNS server after the previously cached remote IP address expires. This mechanism ensures that the local end can always obtain the latest remote IP address.
· If a static DNS entry is used for resolution, you must reconfigure the remote-address command whenever the remote IP address changes. Without the reconfiguration, the local end cannot obtain the latest remote IP address.
For example, the local end has a static DNS entry which maps the host name test to the IP address 1.1.1.1. Configure the following commands:
# Configure the remote host name to test for the IPsec tunnel in the IPsec policy policy1.
[Sysname] ipsec policy policy1 1 isakmp
[Sysname-ipsec-policy-isakmp-policy1-1] remote-address test
# Change the IP address for the host test to 2.2.2.2.
[Sysname] ip host test 2.2.2.2
In this case, you must reconfigure the remote host name for the IPsec policy policy1 so that the local end can obtain the latest IP address of the remote host.
# Reconfigure the remote host name to test for the IPsec tunnel in the IPsec policy policy1.
[Sysname -ipsec-policy-isakmp-policy1-1] remote-address test
# Specify remote IP address 10.1.1.2 for the IPsec tunnel.
[Sysname] ipsec policy policy1 10 manual
[Sysname-ipsec-policy-manual-policy1-10] remote-address 10.1.1.2
ip host (Layer 3—IP Services Command Reference)
local-address
reset ipsec sa
Use reset ipsec sa to clear IPsec SAs.
reset ipsec sa [ { ipv6-policy | policy } policy-name [ seq-number ] | profile policy-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-num ]
{ ipv6-policy | policy } policy-name [ seq-number ]: Clears IPsec SAs for the specified IPsec policy.
· ipv6-policy: Specifies an IPv6 IPsec policy.
· policy: Specifies an IPv4 IPsec policy.
· policy-name: Specifies the name of the IPsec policy, a case-insensitive string of 1 to 63 characters.
· seq-number: Specifies the sequence number of an IPsec policy entry, in the range of 1 to 65535. If you do not specify this argument, all the entries in the IPsec policy are specified.
profile profile-name: Clears IPsec SAs for the IPsec profile specified by its name, a case-insensitive string of 1 to 63 characters.
remote: Clears IPsec SAs for the specified remote address.
ipv6 ipv6-address: Specifies a remote IPv6 address.
spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-num: Clears IPsec SAs matching the specified SA triplet: the remote address, the security protocol, and the SPI.
· ipv4-address: Specifies a remote IPv4 address.
· ipv6 ipv6-address: Specifies a remote IPv6 address.
· ah: Specifies the AH protocol.
· esp: Specifies the ESP protocol.
spi-num: Specifies the security parameter index in the range of 256 to 4294967295.
If you do not specify any parameters, this command clears all IPsec SAs.
If you specify an SA triplet, this command clears the IPsec SA matching the triplet, and all the other IPsec SAs that were established during the same negotiation process, including the corresponding IPsec SA in the other direction, and the inbound and outbound IPsec SAs using the other security protocol (AH or ESP).
An outbound SA is uniquely identified by an SA triplet and an inbound SA is uniquely identified by an SPI. To clear IPsec SAs by specifying a triplet in the outbound direction, you should provide the remote IP address, the security protocol, and the SPI, where the remote IP address can be any valid address if the SAs are established by IPsec profiles. To clear IPsec SAs by specifying a triplet in the inbound direction, you should provide the SPI and use any valid values for the other two parameters.
After a manual IPsec SA is cleared, the system automatically creates a new SA based on the parameters of the IPsec policy. After IKE negotiated SAs are cleared, the system creates new SAs only when IKE negotiation is triggered by packets.
# Clear all IPsec SAs.
<Sysname> reset ipsec sa
# Clear the inbound and outbound IPsec SAs for the triplet of SPI 256, remote IP address 10.1.1.2, and security protocol AH.
<Sysname> reset ipsec sa spi 10.1.1.2 ah 256
# Clear all IPsec SAs for remote IP address 10.1.1.2.
<Sysname> reset ipsec sa remote 10.1.1.2
# Clear all IPsec SAs for entry 10 of IPsec policy policy1.
<Sysname> reset ipsec sa policy policy1 10
# Clear all IPsec SAs for IPsec policy policy1.
display ipsec sa
reset ipsec sdwan-sa
Use reset ipsec sdwan-sa to clear SDWAN IPsec SAs.
reset ipsec sdwan-sa [ local [ interface tunnel tunnel-number ] | remote ]
local: Clears local SDWAN IPsec SAs.
interface: Clears SDWAN IPsec SAs on an interface.
tunnel tunnel-number: Specifies an SDWAN tunnel interface by the tunnel interface number.
remote: Clears remote SDWAN IPsec SAs.
If you do not specify any parameters, this command clears all SDWAN IPsec SAs.
After the local SDWAN IPsec SAs are cleared, the device will regenerate the SDWAN IPsec SAs according to the IPsec configuration and synchronize them to the remote device.
After the remote SDWAN IPsec SAs saved locally are cleared, the device will re-obtain the SDWAN IPsec SAs from the remote device.
# Clear all local SDWAN IPsec SAs.
<RouterA> reset ipsec sdwan-sa local
# Clear local SDWAN IPsec SAs on tunnel 1.
<RouterA> reset ipsec sdwan-sa local interface tunnel 1
# Clear all remote SDWAN IPsec SAs.
<RouterA> reset ipsec sdwan-sa remote
display ipsec sdwan-sa
reset ipsec sdwan-statistics
Use reset ipsec sdwan-statistics to clear packet statistics on SDWAN IPsec SA tunnels.
reset ipsec sdwan-statistics [ tunnel-id tunnel-id ]
tunnel-id tunnel-id: Specifies an IPsec tunnel by its ID. The value range for the tunnel-id argument is 0 to 4294967294.
If you do not specify an IPsec tunnel, this command clears packet statistics on all SDWAN IPsec tunnels.
# Clear packet statistics on all SDWAN IPsec tunnels.
<RouterA> reset ipsec sdwan-statictics
reset ipsec sdwan-tunnel
Use reset ipsec sdwan-tunnel to clear information about SDWAN IPsec tunnels.
reset ipsec sdwan-tunnel [ tunnel-id tunnel-id ]
tunnel-id tunnel-id: Specifies an IPsec tunnel by the tunnel ID. The value range for the tunnel-id argument is 0 to 4294967294. If you do not specify an IPsec tunnel, this command clears information about all SDWAN IPsec tunnels.
In an SDWAN network, IPsec establishes tunnels between SDWAN devices to protect data transmitted in between. Such IPsec tunnels are referred to as SDWAN IPsec tunnels.
# Clear information about SDWAN IPsec tunnel 1.
<Sysname> reset ipsec sdwan-tunnel tunnel-id 1
display ipsec sdwan-tunnel
reset ipsec statistics
Use reset ipsec statistics to clear IPsec packet statistics.
reset ipsec statistics [ tunnel-id tunnel-id ]
tunnel-id tunnel-id: Clears IPsec packet statistics for the specified IPsec tunnel. The value range for the tunnel-id argument is 0 to 4294967294. If you do not specify this option, the command clears all IPsec packet statistics.
# Clear IPsec packet statistics.
<Sysname> reset ipsec statistics
display ipsec statistics
responder-only enable
Use responder-only enable to enable the responder-only mode.
Use undo responder-only enable to disable the responder-only mode.
The responder-only mode of the device is disabled.
IPsec profile view
IPsec policy view
As a best practice, configure this feature on the hub device in a hub-spoke network.
By default, two IPsec peers will both initiate the establishment of an IPsec SA when they both use an IKE-based IPsec profile to established IPsec SAs. In this case, the two IPsec peers use two IPsec negotiation processes to establish one IPsec SA, wasting CPU resources. To resolve this issue, you can enable the responder-only mode. After you configure a device as a responder-only device, the device will not initiate IPsec SAs but respond to negotiations initiated by its peers.
# In IPsec profile prof1, configure the device as responder-only for IPsec SA negotiation.
[Sysname] ipsec profile prof1 isakmp
[Sysname-ipsec-profile-prof1] responder-only enable
# In IPsec policy map, configure the device as responder-only for IPsec SA negotiation.
[Sysname-ipsec-policy-isakmp-map-1] responder-only enable
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ipsec profile
reverse-route dynamic
Use reverse-route dynamic to enable IPsec reverse route inject (RRI).
Use undo reverse-route dynamic to disable IPsec RRI.
reverse-route [ next-hop [ ipv6 ] ip-address ] dynamic
IPsec RRI is disabled.
IPsec policy view
next-hop: Specifies a next hop IP address for the IPsec RRI-created static route. If you do not specify a next hop IP address, the static route uses the remote IP address of the IPsec tunnel as the next hop IP address.
ipv6: Specifies an IPv6 address.
ip-address: Specifies the next hop IPv4 or IPv6 address.
IPsec RRI is usually used on a gateway device at the headquarters side in an IPsec VPN. After IPsec RRI is enabled for an IPsec policy or an IPsec policy template on a gateway device, the gateway device automatically creates a static route upon IPsec SA creation according to this IPsec policy or IPsec policy template. By default, the static route uses the protected peer private network as the destination IP address and the remote IP address of the IPsec tunnel as the next hop address. If there are multiple paths to the remote tunnel end, you can use the next-hop keyword to specify a next hop IP address for the static route.
When you enable IPsec RRI for an IPsec policy, the device deletes all IPsec SAs that are created according to this IPsec policy. Upon IPsec SAs are renegotiated, the static routes are created.
When you disable IPsec RRI for an IPsec policy, the device deletes all IPsec SAs that are created according to this IPsec policy, and the associated static routes.
To display the static routes created by RRI, use the display ip routing-table command.
# Enable IPsec RRI to create a static route according to the IPsec SA negotiated by the specified IPsec policy. The destination IP address is the protected peer private network 3.0.0.0/24, and the next hop is the IP address (1.1.1.2) of the remote tunnel interface.
[Sysname] ipsec policy 1 1 isakmp
[Sysname-ipsec-policy-isakmp-1-1] reverse-route dynamic
[Sysname-ipsec-policy-isakmp-1-1] quit
# Display the routing table. You can see a created static route. (Other information is not shown.)
[Sysname] display ip routing-table
3.0.0.0/24 Static 60 0 1.1.1.2 XGE0/0/6
# Enable IPsec RRI to create a static route according to the IPsec SA negotiated by the specified IPsec policy. Set the next hop IP address of the static route to 2.2.2.3.
[Sysname-ipsec-policy-isakmp-1-1] reverse-route next-hop 2.2.2.3 dynamic
4.0.0.0/24 Static 60 0 2.2.2.3 XGE0/0/6
display ip routing-table (Layer 3—IP Routing Command Reference)
ipsec policy
reverse-route preference
Use reverse-route preference to set the preference of the static routes created by IPsec RRI.
Use undo reverse-route preference to restore the default.
reverse-route preference number
The preference for the static routes created by IPsec RRI is 60.
IPsec policy view
number: Specifies a preference value. The value range is 1 to 255. A smaller value represents a higher preference.
When you change this preference in an IPsec policy, the device deletes all IPsec SAs created according to this IPsec policy, and the associated static routes.
# Change the preference to 100 for static routes created by IPsec RRI.
[Sysname-ipsec-policy-isakmp-1-1] reverse-route preference 100
ipsec policy
reverse-route tag
Use reverse-route tag to set a route tag for the static routes created by IPsec RRI.
Use undo reverse-route tag to restore the default.
reverse-route tag tag-value
The route tag value is 0 for the static routes created by IPsec RRI.
IPsec policy view
tag-value: Specifies a tag value. The value range is 1 to 4294967295.
The tag value set by this command helps in implementing flexible route control through routing policies.
When you change this tag value in an IPsec policy, the device deletes all IPsec SAs created by this IPsec policy, and all associated static routes.
# Set the tag value to 50 for the static routes created by IPsec RRI.
[Sysname-ipsec-policy-isakmp-1-1] reverse-route tag 50
ipsec policy
sa df-bit
Use sa df-bit to configure the DF bit for the outer IP header of IPsec packets.
Use undo sa df-bit to restore the default.
sa df-bit { clear | copy | set }
undo sa df-bit
The DF bit is not configured for the outer IP header of IPsec packets. The interface-specific or global DF bit setting is used.
IPsec policy view
IPsec profile view
This command is supported only when the IKE negotiation mode is used for IPsec SA setup.
Packet fragmentation and reassembly might cause packet forwarding to be delayed. You can set the DF bit to avoid the forwarding delay. If the DF bit is set, make sure the path MTU is larger than the IPsec packet size to prevent the IPsec packets from being discarded. Clear the DF bit if you cannot make sure the path MTU is larger than the IPsec packet size.
If the DF bit setting is not configured in the IPsec policy, IPsec profile, or IPsec policy template, the interface-specific DF bit setting is used. If the interface-specific DF bit setting is not configured either, the global DF bit setting is used.
# Set the DF bit in the outer IP header of IPsec packets in IPsec policy policy1.
[Sysname-ipsec-policy-isakmp-policy1-100] sa df-bit set
ipsec df-bit
ipsec global-df-bit
sa duration
Use sa duration to set an SA lifetime.
Use undo sa duration to remove an SA lifetime.
sa duration { time-based seconds | traffic-based kilobytes }
undo sa duration { time-based | traffic-based }
The SA lifetime of an IPsec policy, IPsec profile, or IPsec policy template is the current global SA lifetime.
IPsec policy view
IPsec profile view
time-based seconds: Specifies the time-based SA lifetime in the range of 180 to 604800 seconds.
traffic-based kilobytes: Specifies the traffic-based SA lifetime in the range of 2560 to 4294967295 Kilobytes. An SDWAN IPsec profile does not support this option.
IKE prefers the SA lifetime of the IPsec policy, IPsec profile, or IPsec policy template over the global SA lifetime configured by the ipsec sa global-duration command. If the IPsec policy, IPsec profile, or IPsec policy template is not configured with the SA lifetime, IKE uses the global SA lifetime for SA negotiation.
During SA negotiation, IKE selects the shorter SA lifetime between the local SA lifetime and the remote SA lifetime.
# Set the SA lifetime to 7200 seconds for IPsec policy policy1.
[Sysname-ipsec-policy-isakmp-policy1-100] sa duration time-based 7200
# Set the SA lifetime to 20 MB for IPsec policy policy1. The IPsec SA expires after transmitting 20480 Kilobytes.
[Sysname-ipsec-policy-isakmp-policy1-100] sa duration traffic-based 20480
# Set the SA lifetime to 500 seconds for SDWAN IPsec profile profile1.
[Sysname-ipsec-profile-sdwan-profile1] sa duration time-based 500
display ipsec sa
sa hex-key authentication
Use sa hex-key authentication to configure a hexadecimal authentication key for manual IPsec SAs.
Use undo sa hex-key authentication to remove the hexadecimal authentication key.
sa hex-key authentication { inbound | outbound } { ah | esp } { cipher | simple } string
undo sa hex-key authentication { inbound | outbound } { ah | esp }
No hexadecimal authentication key is configured for manual IPsec SAs.
IPsec policy view
IPsec profile view
inbound: Specifies a hexadecimal authentication key for the inbound SA.
outbound: Specifies a hexadecimal authentication key for the outbound SA.
ah: Uses AH.
esp: Uses ESP.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its encrypted form is a case-sensitive string of 1 to 85 characters. Its plaintext form is a case-insensitive hexadecimal string and the key length varies by algorithm.
The following matrix shows the key length for the algorithms:
Algorithm |
Key length (bytes) |
HMAC-AES-XCBC-96 |
16 |
HMAC-MD5 |
16 |
HMAC-SHA1 |
20 |
HMAC-SHA-256 |
32 |
HMAC-SHA-384 |
48 |
HMAC-SHA-512 |
64 |
HMAC-SM3 |
32 |
This command applies only to manual IPsec policies and IPsec profiles.
You must set an authentication key for both the inbound and outbound SAs.
The local inbound SA must use the same authentication key as the remote outbound SA, and the local outbound SA must use the same authentication key as the remote inbound SA.
In an IPsec profile to be applied to an IPv6 routing protocol, the local authentication keys of the inbound and outbound SAs must be identical.
The keys for the IPsec SAs at the two tunnel ends must be input in the same format (either in hexadecimal or character format). Otherwise, they cannot establish an IPsec tunnel.
If you execute this command multiple times for the same protocol and direction, the most recent configuration takes effect.
# Configure plaintext authentication keys 0x112233445566778899aabbccddeeff00 and 0xaabbccddeeff001100aabbccddeeff00 for the inbound and outbound SAs that use AH.
[Sysname-ipsec-policy-manual-policy1-100] sa hex-key authentication inbound ah simple 112233445566778899aabbccddeeff00
[Sysname-ipsec-policy-manual-policy1-100] sa hex-key authentication outbound ah simple aabbccddeeff001100aabbccddeeff00
display ipsec sa
sa string-key
sa hex-key encryption
Use sa encryption-hex configure a hexadecimal encryption key for manual IPsec SAs.
Use undo sa encryption-hex remove the hexadecimal encryption key.
sa hex-key encryption { inbound | outbound } esp { cipher | simple } string
undo sa hex-key encryption { inbound | outbound } esp
No hexadecimal encryption key is configured for manual IPsec SAs.
IPsec policy view
IPsec profile view
inbound: Specifies a hexadecimal encryption key for the inbound SA.
outbound: Specifies a hexadecimal encryption key for the outbound SA.
esp: Uses ESP.
string: Specifies the key. Its encrypted form is a case-sensitive string of 1 to 117 characters. Its plaintext form is a case-insensitive hexadecimal string and the key length varies by algorithm.
Algorithm |
DES-CBC |
8 |
3DES-CBC |
24 |
AES128-CBC |
16 |
AES192-CBC |
24 |
AES256-CBC |
32 |
SM1128-CBC |
16 |
SM4128-CBC |
16 |
AES128-CTR |
16 |
AES192-CTR |
24 |
AES256-CTR |
32 |
CAMELLIA128-CBC |
16 |
CAMELLIA192-CBC |
24 |
CAMELLIA256-CBC |
32 |
GMAC-128 |
16 |
GMAC-192 |
24 |
GMAC-256 |
32 |
GCM-128 |
16 |
GCM-192 |
24 |
GCM-256 |
32 |
You must set an encryption key for both the inbound and outbound SAs.
The local inbound SA must use the same encryption key as the remote outbound SA, and the local outbound SA must use the same encryption key as the remote inbound SA.
In an IPsec profile to be applied to an IPv6 routing protocol, the local encryption keys of the inbound and outbound SAs must be identical.
The keys for the IPsec SAs at the two tunnel ends must be configured in the same format (either in hexadecimal or character format). Otherwise, they cannot establish an IPsec tunnel.
If you execute this command multiple times for the same direction, the most recent configuration takes effect.
# Configure plaintext encryption keys 0x1234567890abcdef and 0xabcdefabcdef1234 for the inbound and outbound IPsec SAs that use ESP.
[Sysname-ipsec-policy-manual-policy1-100] sa hex-key encryption inbound esp simple 1234567890abcdef
[Sysname-ipsec-policy-manual-policy1-100] sa hex-key encryption outbound esp simple abcdefabcdef1234
display ipsec sa
sa string-key
sa idle-time
Use sa idle-time to set the IPsec SA idle timeout. If no traffic matches an IPsec SA within the idle timeout interval, the IPsec SA is deleted.
Use undo sa idle-time to restore the default.
undo sa idle-time
An IPsec policy, IPsec profile, or IPsec policy template uses the global IPsec SA idle timeout.
IPsec policy view
IPsec profile view
This feature applies only to IPsec SAs negotiated by IKE and takes effect after the ipsec sa idle-time command is configured.
The IPsec SA idle timeout configured by this command takes precedence over the global IPsec SA timeout configured by the ipsec sa idle-time command. If the IPsec policy, IPsec profile, or IPsec policy template is not configured with the SA idle timeout, IKE uses the global SA idle timeout.
# Set the IPsec SA idle timeout to 600 seconds for IPsec policy map.
[Sysname] ipsec policy map 100 isakmp
[Sysname-ipsec-policy-isakmp-map-100] sa idle-time 600
display ipsec sa
ipsec sa idle-time
Use sa soft-duration buffer to set the time-based or traffic-based IPsec SA soft lifetime buffer.
Use undo sa soft-duration buffer to restore the default.
sa soft-duration buffer { time-based seconds | traffic-based kilobytes }
undo sa soft-duration buffer { time-based | traffic-based }
The time-based and traffic-based IPsec SA soft lifetime buffers are not configured.
IPsec policy view
IPsec profile view
time-based seconds: Specifies the time-based IPsec SA soft lifetime buffer in seconds. The value range is 20 to 201600.
traffic-based kilobytes: Specifies the traffic-based IPsec SA soft lifetime buffer in Kilobytes. The value range is 1000 to 4294901760.
# Set the time-based IPsec SA soft lifetime buffer to 600 seconds in IPsec policy example 1.
[Sysname] ipsec policy example 1 isakmp
[Sysname-ipsec-policy-isakmp-example-1] sa soft-duration buffer time-based 600
# Set the traffic-based IPsec SA soft lifetime buffer to 10000 Kilobytes in IPsec policy example 1.
[Sysname-ipsec-policy-isakmp-example-1] sa soft-duration buffer traffic-based 10000
sa spi
Use sa spi to configure an SPI for IPsec SAs.
Use undo sa spi to remove the SPI.
sa spi { inbound | outbound } { ah | esp } spi-number
undo sa spi { inbound | outbound } { ah | esp }
No SPI is configured for IPsec SAs.
IPsec policy view
IPsec profile view
inbound: Specifies an SPI for inbound SAs.
outbound: Specifies an SPI for outbound SAs.
ah: Uses AH.
esp: Uses ESP.
spi-number: Specifies a security parameters index (SPI) in the range of 256 to 4294967295.
You must configure an SPI for both inbound and outbound SAs, and make sure the SAs in each direction are unique: For an outbound SA, make sure its triplet (remote IP address, security protocol, and SPI) is unique. For an inbound SA, make sure its SPI is unique.
The local inbound SA must use the same SPI as the remote outbound SA, and the local outbound SA must use the same SPI as the remote inbound SA.
When you configure an IPsec profile for an IPv6 routing protocol, follow these guidelines:
· The local inbound and outbound SAs must use the same SPI.
· The IPsec SAs on the devices in the same scope must have the same SPI. The scope is defined by protocols. For OSPFv3, the scope consists of OSPFv3 neighbors or an OSPFv3 area. For RIPng, the scope consists of directly-connected neighbors or a RIPng process. For BGP4+, the scope consists of BGP4+ peers or a BGP4+ peer group.
# Set the SPI for the inbound SA to 10000 and the SPI for the outbound SA to 20000 in a manual IPsec policy.
[Sysname-ipsec-policy-manual-policy1-100] sa spi inbound ah 10000
[Sysname-ipsec-policy-manual-policy1-100] sa spi outbound ah 20000
display ipsec sa
sa string-key
Use sa string-key to set a key string (a key in character format) for manual IPsec SAs.
Use undo sa string-key to remove the key string.
sa string-key { inbound | outbound } { ah | esp } { cipher | simple } string
undo sa string-key { inbound | outbound } { ah | esp }
No key string is configured for manual IPsec SAs.
IPsec policy view
IPsec profile view
inbound: Sets a key string for inbound IPsec SAs.
outbound: Sets a key string for outbound IPsec SAs.
ah: Uses AH.
esp: Uses ESP.
cipher: Specifies a key string in encrypted form.
simple: Specifies a key string in plaintext form. For security purposes, the key string specified in plaintext form will be stored in encrypted form.
string: Specifies the key string. Its encrypted form is a case-sensitive string of 1 to 373 characters. Its plaintext form is a case-sensitive string of 1 to 255 characters. Using the key string, the system automatically generates keys that meet the algorithm requirements. When the protocol is ESP, the system automatically generates keys for the authentication algorithm and encryption algorithm.
You must set a key for both inbound and outbound SAs.
The local inbound SA must use the same key as the remote outbound SA, and the local outbound SA must use the same key as the remote inbound SA.
· The local inbound and outbound SAs must use the same key.
· The IPsec SAs on the devices in the same scope must have the same key. The scope is defined by protocols. For OSPFv3, the scope consists of OSPFv3 neighbors or an OSPFv3 area. For RIPng, the scope consists of directly-connected neighbors or a RIPng process. For BGP, the scope consists of BGP peers or a BGP peer group.
# Configure the inbound and outbound SAs that use AH to use plaintext keys abcdef and efcdab, respectively.
[Sysname-ipsec-policy-manual-policy1-100] sa string-key inbound ah simple abcdef
[Sysname-ipsec-policy-manual-policy1-100] sa string-key outbound ah simple efcdab
# In an IPv6 IPsec policy, configure the inbound and outbound SAs that use AH to use plaintext key abcdef.
[Sysname] ipsec ipv6-policy policy1 100 manual
[Sysname-ipsec-ipv6-policy-manual-policy1-100] sa string-key inbound ah simple abcdef
[Sysname-ipsec-ipv6-policy-manual-policy1-100] sa string-key outbound ah simple abcdef
display ipsec sa
sa hex-key
sa trigger-mode
Use sa trigger-mode to set the IPsec SA negotiation triggering mode.
Use undo sa trigger-mode to restore the default.
sa trigger-mode { auto | traffic-based }
IPsec SA negotiation is triggered when traffic requires IPsec protection.
IPsec policy view
auto: Triggers IPsec SA negotiation when required IPsec configuration is complete.
traffic-based: Triggers IPsec SA negotiation when traffic requires IPsec protection.
You can specify the IPsec SA negotiation triggering mode only for IKE-based IPsec policies.
Compared to the auto mode, the traffic-based mode is more economical in terms of resource usage because it triggers IPsec SA negotiation only when traffic requires IPsec protection. However, the traffic-based mode leaves traffic unprotected before IPsec SAs are successfully established.
The IPsec SA negotiation triggering modes on the local and remote ends of an IPsec tunnel can be different.
Modifying the IPsec SA negotiation triggering mode does not affect existing IPsec SAs.
If the IPsec SA negotiation triggering mode is set to auto, change the mode to traffic-based as a best practice after IPsec SA establishment is complete.
# Set the IPsec SA negotiation triggering mode to auto for IPsec policy policy1.
[Sysname] ipsec policy policy1 10 isakmp
[Sysname-ipsec-policy-isakmp-policy1-10] sa trigger-mode auto
security acl
Use security acl to specify an ACL for an IPsec policy or IPsec policy template.
Use undo security acl to restore the default.
security acl [ ipv6 ] { acl-number | name acl-name } [ aggregation | per-host ]
undo security acl
An IPsec policy or IPsec policy template does not use any ACL.
IPsec policy view
ipv6: Specifies an IPv6 ACL.
acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters.
aggregation: Specifies the data protection mode as aggregation. The device does not support protecting IPv6 data flows in aggregation mode.
per-host: Specifies the data protection mode as per-host.
An IKE-based IPsec policy supports the following data flow protection modes:
· Standard mode—One IPsec tunnel protects one data flow. The data flow permitted by an ACL rule is protected by one IPsec tunnel that is established solely for it. The standard mode is used if you do not specify the aggregation or the per-host mode.
· Aggregation mode—One IPsec tunnel protects all data flows permitted by all the rules of an ACL. This mode is only used to communicate with old-version devices.
· Per-host mode—One IPsec tunnel protects one host-to-host data flow. One host-to-host data flow is identified by one ACL rule and protected by one IPsec tunnel established solely for it. This mode consumes more system resources when multiple data flows exist between two subnets to be protected.
A manual IPsec policy supports only the aggregation mode.
If the specified ACL does not exist or does not contain rules, the IPsec policy does not take effect.
If the vpn-instance keyword is specified in an ACL rule, the rule applies only to VPN packets. If the vpn-instance keyword is not specified in an ACL rule, the rule applies only to public network packets.
# Specify IPv4 advanced ACL 3001 for IPsec policy policy1.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit tcp source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname-ipsec-policy-manual-policy1-100] security acl 3001
# Specify IPv4 advanced ACL 3002 for IPsec policy policy2 and specify the data protection mode as aggregation.
[Sysname] acl advanced 3002
[Sysname-acl-ipv4-adv-3002] rule 0 permit ip source 10.1.2.1 0.0.0.255 destination 10.1.2.2 0.0.0.255
[Sysname-acl-ipv4-adv-3002] rule 1 permit ip source 10.1.3.1 0.0.0.255 destination 10.1.3.2 0.0.0.255
[Sysname-acl-ipv4-adv-3002] quit
[Sysname] ipsec policy policy2 1 isakmp
[Sysname-ipsec-policy-isakmp-policy2-1] security acl 3002 aggregation
display ipsec sa
display ipsec tunnel
snmp-agent trap enable ipsec
Use snmp-agent trap enable ipsec command to enable SNMP notifications for IPsec.
Use undo snmp-agent trap enable ipsec command to disable SNMP notifications for IPsec.
snmp-agent trap enable ipsec [ auth-failure | connection-start | connection-stop | decrypt-failure | encrypt-failure | global | invalid-sa-failure | no-sa-failure | policy-add | policy-attach | policy-delete | policy-detach | tunnel-start | tunnel-stop] *
undo snmp-agent trap enable ipsec [ auth-failure | connection-start | connection-stop | decrypt-failure | encrypt-failure | global | invalid-sa-failure | no-sa-failure | policy-add | policy-attach | policy-delete | policy-detach | tunnel-start | tunnel-stop] *
All SNMP notifications for IPsec are disabled.
auth-failure: Specifies notifications about authentication failures.
connection-start: Specifies notifications about successful establishment of the first IPsec tunnel under IPsec policy entries with the same description.
connection-stop: Specifies notifications about successful removal of the last IPsec tunnel under IPsec policy entries with the same description.
decrypt-failure: Specifies notifications about decryption failures.
encrypt-failure: Specifies notifications about encryption failures.
global: Specifies notifications globally.
invalid-sa-failure: Specifies notifications about invalid-SA failures.
no-sa-failure: Specifies notifications about SA-not-found failures.
policy-add: Specifies notifications about events of adding IPsec policies.
policy-attach: Specifies notifications about events of applying IPsec policies to interfaces.
policy-delete: Specifies notifications about events of deleting IPsec policies.
policy-detach: Specifies notifications about events of removing IPsec policies from interfaces.
tunnel-start: Specifies notifications about events of creating IPsec tunnels.
tunnel-stop: Specifies notifications about events of deleting IPsec tunnels.
If you do not specify any keywords, this command enables or disables all SNMP notifications for IPsec.
To generate and output SNMP notifications for a specific IPsec failure type or event type, perform the following tasks:
1. Enable SNMP notifications for IPsec globally.
2. Enable SNMP notifications for the failure type or event type.
# Enable SNMP notifications for IPsec globally.
[Sysname] snmp-agent trap enable ipsec global
# Enable SNMP notifications for events of creating IPsec tunnels.
[Sysname] snmp-agent trap enable ipsec tunnel-start
tfc enable
Use tfc enable to enable Traffic Flow Confidentiality (TFC) padding.
Use undo tfc enable to disable TFC padding.
tfc enable
undo tfc enable
TFC padding is disabled.
IPsec policy view
TFC padding applies only to IPsec SAs negotiated by IKEv2.
TFC padding can hide the length of the original packet, and might affect the packet encapsulation and de-encapsulation performance. This feature takes effect on UDP packets encapsulated by ESP in transport mode and on original IP packets encapsulated by ESP in tunnel mode.
# Enable TFC padding for IPsec policy policy1.
[Sysname-ipsec-policy-isakmp-policy1-10] tfc enable
display ipsec ipv6-policy
display ipsec policy
transform-set
Use transform-set to specify an IPsec transform set for an IPsec policy, IPsec profile, or IPsec policy template.
Use undo transform-set to remove the IPsec transform set specified for an IPsec policy, IPsec profile, or IPsec policy template.
transform-set transform-set-name&<1-6>
undo transform-set [ transform-set-name ]
No IPsec transform set is specified for an IPsec policy, IPsec profile, or IPsec policy template.
IPsec policy view
IPsec profile view
transform-set-name&<1-6>: Specifies a space-separated list of up to six IPsec transform sets. The specified transform set names must be different. A transform set name is a case-insensitive string of 1 to 63 characters.
You can specify only one IPsec transform set for a manual IPsec policy or SDWAN IPsec policy. If you execute this command multiple times, the most recent configuration takes effect.
You can specify a maximum of six IPsec transform sets for an IKE-based IPsec policy or IPsec profile. During an IKE negotiation, IKE searches for a fully matched IPsec transform set at the two ends of the IPsec tunnel. If no match is found, no SA can be set up, and the packets expecting to be protected will be dropped.
If you do not specify the transform-set-name argument, the undo transform-set command removes all IPsec transform sets specified for the IPsec policy, IPsec profile, or IPsec policy template.
# Specify IPsec transform set prop1 for IPsec policy policy1.
[Sysname] ipsec transform-set prop1
[Sysname-ipsec-transform-set-prop1] quit
[Sysname-ipsec-policy-manual-policy1-100] transform-set prop1
ipsec profile
ipsec transform-set
tunnel protection ipsec
Use tunnel protection ipsec to apply an IPsec profile to a tunnel interface.
Use undo tunnel protection ipsec to restore the default.
tunnel protection ipsec profile profile-name [ acl [ ipv6 ] { acl-number | name acl-name } ]
undo tunnel protection ipsec profile
No IPsec profile is applied to a tunnel interface.
Tunnel interface view
profile profile-name: Specify an IPsec profile by its name, a case-insensitive string of 1 to 63 characters. The specified IPsec profile must be an IKE-based IPsec profile.
ipv6: Specifies an IPv6 ACL. To specify an IPv4 ACL, do not specify this keyword.
After an IPsec profile is applied to a tunnel interface, the peers negotiate an IPsec tunnel through IKE to protect data transmitted through the tunnel interface.
If you specify an ACL when applying an IPsec profile to a tunnel interface, only the ACL-permitted data on the tunnel interface can be protected by IPsec. To protect the traffic of a VPN instance on the tunnel interface, do not specify the VPN instance in the ACL. If you do so, the IPsec profile cannot initiate IPsec negotiation. Instead, you should bind the VPN instance to the tunnel interface. Therefore, the VPN instance of the IPsec SAs negotiated by using the IPsec profile is the VPN instance bound to the tunnel interface.
Specify an IPv4 ACL if the IPsec profile is applied to an IPv4 tunnel interface.
Specify an IPv6 ACL if the IPsec profile is applied to an IPv6 tunnel interface.
After an SDWAN IPsec profile is applied to an SDWAN tunnel interface on an SDWAN device, if the IPsec profile configuration is complete, the SDWAN device creates a local IPsec SA and advertises the IPsec SA to the remote SDWAN device through the SDWAN tunnel. The IPsec SA then is the remote IPsec SA on the remote device. The remote device must use this remote IPsec SA to encrypt the packets sent to the local device. The local device uses the local IPsec SA to decrypt the received packets and discards those unencrypted.
IPsec SAs are unidirectional. Packet encryption and decryption use different IPsec SAs. Typically, the device uses local IPsec SAs for encryption and remote IPsec SAs for decryption.
SDWAN tunnel interfaces do not support specifying the ACL parameters in this command.
# Apply IPsec profile prf1 to tunnel interface Tunnel 1.
[Sysname] interface tunnel 1 mode advpn gre
[Sysname-Tunnel1]tunnel protection ipsec profile prf1
# Apply IPsec profile prf1 to IPv4 tunnel interface Tunnel 1 and use IPv4 ACL 3000 to filter the data to be protected by IPsec on the tunnel interface.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 0 permit ip source 1.0.0.0 0.0.0.255 destination 2.0.0.0 0.0.0.255
[Sysname] interface tunnel 1 mode ipsec
[Sysname-Tunnel1] tunnel protection ipsec profile prf1 acl 3000
# Apply IPsec profile prf1 to IPv6 tunnel interface Tunnel 1 and use IPv6 ACL 3000 to filter the data to be protected by IPsec on the tunnel interface.
[Sysname-acl-ipv6-adv-3000] rule 0 permit ipv6 source 1:1::/64 destination 2:2::/64
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] interface tunnel 1 mode ipsec ipv6
[Sysname-Tunnel1] tunnel protection ipsec profile prf1 acl ipv6 3000
# Apply SDWAN IPsec profile profile1 to SDWAN tunnel interface Tunnel 1.
[Sysname] interface tunnel 1 mode sdwan udp
[Sysname-Tunnel1] tunnel protection ipsec profile profile1
interface tunnel (Interface Command Reference)
display interface tunnel (Interface Command Reference)
ipsec profile
user-fqdn
Use user-fqdn to add a peer user FQDN name to an identity filter set.
Use undo user-fqdn to remove a peer user FQDN name from an identity filter set.
user-fqdn fqdn-name
undo user-fqdn fqdn-name
No peer domain name is added to an identity filter set.
Identity filter set view
fqdn-name: Specifies the user FQDN of a peer, a case-sensitive string of 1 to 255 characters.
Operating mechanism
Use this command to configure the user FQDN name filtering conditions in an identity filter set. During an IPsec negotiation, the local end filters the negotiation initiator based on the specified user FQDN names. When the initiator end meets one or more user FQDN name conditions of the identity filter set and the IPsec negotiation parameters on both ends match, the local and remote ends can successfully establish an IPsec tunnel.
To add multiple user FQDN names to an identity filter set, execute this command multiple times.
# Create an identity filter set named identity1 and enter its view.
[Sysname] ipsec ike-identity identity1
# Configure the identity filter set to permit the peer with user FQDN name example.com.
[Sysname-ipsec-ike-identity-identity1] user-fqdn example.com
ipsec ike-identity
