| 08-Tunnel interface commands | 178.65 KB |
destination
Use destination to specify the destination address for a tunnel interface.
Use undo destination to restore the default.
destination { ipv4-address | ipv6-address }
undo destination
No tunnel destination address is configured.
Tunnel interface view
ipv4-address: Specifies the tunnel destination IPv4 address.
ipv6-address: Specifies the tunnel destination IPv6 address.
For a manual tunnel interface, you must configure the destination address. For an automatic tunnel interface, you do not need to configure the destination address.
The tunnel destination address must be the address of the receiving interface on the tunnel peer. It is used as the destination address of tunneled packets.
The destination address of the local tunnel interface must be the source address of the peer tunnel interface. The source address of the local tunnel interface must be the destination address of the peer tunnel interface.
Do not specify the same tunnel source and destination addresses for the tunnel interfaces on the same device.
# The interface Ten-GigabitEthernet 0/0/6 on Sysname 1 uses the IP address 193.101.1.1 and the interface Ten-GigabitEthernet 0/0/6 on Sysname 2 uses the IP address 192.100.1.1. Configure the source address 193.101.1.1 and destination address 192.100.1.1 for the tunnel interface on Sysname 1.
<Sysname1> system-view
[Sysname1] interface tunnel 1 mode gre
[Sysname1-Tunnel1] source 193.101.1.1
[Sysname1-Tunnel1] destination 192.100.1.1
# Configure the source address 192.100.1.1 and destination address 193.101.1.1 for the tunnel interface on Sysname 2.
<Sysname2> system-view
[Sysname2] interface tunnel 1 mode gre
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
display interface tunnel
display tunnel-interface
interface tunnel
source
Use display interface tunnel to display tunnel interface information.
display interface [ tunnel [ number ] ] [ brief [ description | down ] ]
tunnel [ number ]: Specifies a tunnel interface. The number argument specifies the tunnel interface number. The specified tunnel interface must have been created. If you do not specify the tunnel keyword, this command displays information about all interfaces on the device. If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Tunnel 1.
<Sysname> display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 1476
Tunnel source 2002::1:1 (Vlan-interface10), destination 2001::2:1
Tunnel TOS 0xC8, Tunnel TTL 255
Tunnel protocol/transport GRE/IPv6
GRE key disabled
Checksumming of GRE packets disabled
Tunnel1 |
Information about the tunnel interface Tunnel 1. |
Current state |
Physical link state of the tunnel interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the interface belongs has been shut down by using the shutdown command. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol is down. |
Description of the tunnel interface. |
Bandwidth |
Expected bandwidth of the tunnel interface. |
Maximum transmission unit |
MTU of the tunnel interface. |
Internet protocol processing |
IP packet processing capability of the interface when the interface is not assigned an IP address: · Disabled—The interface cannot process IP packets. · Enabled—The interface can process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · BOOTP-allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in Multicast Configuration Guide. |
Tunnel source |
Source address of the tunnel. If a source interface is specified for the tunnel interface, this field also displays the source interface in parentheses. |
destination |
Destination address of the tunnel. |
Tunnel TOS |
ToS of tunneled packets. |
Tunnel TTL |
TTL of tunneled packets. |
Tunnel protocol/transport |
Tunnel mode and transport protocol: · CR_LSP—MPLS TE tunnel mode. · GRE/IP—GRE/IPv4 tunnel mode. · GRE/IPv6—GRE/IPv6 tunnel mode. · GRE_P2MP/IP—GRE/IPv4 P2MP tunnel mode. · GRE_P2MP/IPv6—GRE/IPv6 P2MP tunnel mode. · IPsec/IP—IPsec/IPv4 tunnel mode. · IPsec/IPv6—IPsec/IPv6 tunnel mode. · IP/IP—IPv4 over IPv4 tunnel mode. · IPv6—IPv6 tunnel mode. · IPv6/IP—IPv6 over IPv4 manual tunnel mode. · IPv6/IP 6RD—IPv6 over IPv4 6RD tunnel mode. · IPv6/IP 6to4—IPv6 over IPv4 6to4 tunnel mode. · IPv6/IP auto-tunnel—Automatic IPv6 over IPv4 tunnel mode. · IPv6/IP ISATAP—IPv6 over IPv4 ISATAP tunnel mode. · IPv6/IPv6—IPv6 over IPv6 tunnel mode. · UDP_VXLAN/IP—UDP-encapsulated IPv4 VXLAN tunnel mode. · UDP_SDWAN/IPv6—UDP-encapsulated IPv6 SDWAN tunnel mode. · GRE_SDWAN-EX/IP—GRE-encapsulated IPv4 SDWAN extended tunnel mode. · GRE_SDWAN-EX/IPv6—GRE-encapsulated IPv6 SDWAN extended tunnel mode. · MAPE—MAP-E tunnel mode. |
GRE key disabled |
No GRE tunnel interface key is configured. |
Checksumming of GRE packets disabled |
The GRE packet checksum feature is disabled. |
Output queue - Urgent queuing: Size/Length/Discards 0/100/0 |
Urgent output queue statistics: · Number of packets in the queue. · Maximum number of packets that the queue can contain. · Number of packets discarded in the queue. |
Output queue - Protocol queuing: Size/Length/Discards 0/500/0 |
Protocol output queue statistics: · Number of packets in the queue. · Maximum number of packets that the queue can contain. · Number of packets discarded in the queue. |
Output queue - FIFO queuing: Size/Length/Discards 0/75/0 |
FIFO output queue statistics: · Number of packets in the queue. · Maximum number of packets that the queue can contain. · Number of packets discarded in the queue. When a CBQ or WFQ queue is configured, this field displays statistics for the CBQ or WFQ queue. |
Last clearing of counters |
Last time when counters were cleared. |
Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average input rate in the last 300 seconds. |
Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average output rate in the last 300 seconds. |
Input: 0 packets, 0 bytes, 0 drops |
Total input packets, total input bytes, and total input packets dropped. |
Output: 0 packets, 0 bytes, 0 drops |
Total output packets, total output bytes, and total output packets dropped. |
# Display brief information about Tunnel 1.
<Sysname> display interface tunnel 1 brief
Protocol: (s) - spoofing
Tun1 UP UP 1.1.1.1 aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about Tunnel 1, including the complete interface description.
<Sysname> display interface tunnel 1 brief description
Tun1 UP UP 1.1.1.1 aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
<Sysname> display interface tunnel brief down
Interface Link Cause
Tun0 DOWN Not connected
Tun1 DOWN Not connected
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Description of the interface. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—The tunnel is not established. · DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the tunnel interface belongs has been shut down by using the shutdown command. |
destination
interface tunnel
source
Use display tunnel-interface to display tunnel interface information.
display tunnel-interface [ number ]
number: Specifies a tunnel interface by its number. The specified tunnel interface must have been created. If you do not specify a tunnel interface, this command displays information about all existing tunnel interfaces.
# Display information about tunnel interface 1.
<Sysname> display tunnel-interface 1
Tunnel ID : 1
Tunnel mode : VXLAN
Tunnel VPN instance : vpn1
Tunnel TTL : 255
Tunnel ToS : 0
Source interface : LoopBack1
Source address : 1.1.1.1
Destination address : 2.2.2.2
Tunnel BFD : Enabled
BFD source IP : -
BFD destination IP : -
BFD destination MAC : -
Tunnel VPN instance |
VPN instance to which the tunnel interface belongs. If the tunnel interface belongs to the public network, this field displays two hyphens (--). |
Tunnel TTL |
TTL for tunneled packets. |
Tunnel ToS |
ToS for tunneled packets. |
Tunnel BFD |
Status of the BFD feature. |
BFD source IP |
BFD source IP address. |
BFD destination IP |
BFD destination IP address. |
BFD destination MAC |
BFD destination MAC address. |
destination
interface tunnel
source
encapsulation-limit
Use encapsulation-limit to set the maximum number of nested encapsulations of a packet allowed on a tunnel interface.
Use undo encapsulation-limit to restore the default.
encapsulation-limit number
There is no limit to the nested encapsulations of a packet.
number: Specifies the number of nested encapsulations, in the range of 0 to 10.
A packet added with excessive headers becomes oversized. If it exceeds the MTU, it must be fragmented. The fragmentation decreases forwarding rate and increases processing complexity. To avoid this situation, use this command to limit the number of encapsulations.
This command is applicable only to IPv6 over IPv6 tunnels.
# Set the maximum number of nested encapsulations to 3 on Tunnel 1.
[Sysname] interface tunnel 1 mode ipv6-ipv6
[Sysname-Tunnel1] encapsulation-limit 3
interface tunnel
Use interface tunnel to create a tunnel interface, specify the tunnel mode, and enter tunnel interface view, or enter the view of an existing tunnel interface.
Use undo interface tunnel to delete a tunnel interface.
interface tunnel number [ mode { ds-lite-aftr | gre [ ipv6 ] | gre-p2mp [ ipv6 ] | ipsec [ ipv6 ] | ipv4-ipv4 | ipv4-ipv6 | ipv6 | ipv6-ipv4 [ 6rd | 6to4 | auto-tunnel | isatap ] | ipv6-ipv6 | map-e | mpls-te | sdwan udp [ ipv6 ] | sdwan-ex gre [ ipv6 ] | vxlan } ]
undo interface tunnel number
No tunnel interfaces exist.
number: Specifies the number of the tunnel interface. The value range for tunnel interface numbers is 0 to 20479. The number of tunnel interfaces that can be created is restricted by the total number of interfaces and the memory.
mode ds-lite-aftr: Specifies the DS-Lite tunnel mode on the AFTR.
mode gre: Specifies the GRE/IPv4 tunnel mode.
mode gre ipv6: Specifies the GRE/IPv6 tunnel mode.
mode gre-p2mp: Specifies the GRE/IPv4 P2MP tunnel mode.
mode gre-p2mp ipv6: Specifies the GRE/IPv6 P2MP tunnel mode.
mode ipsec: Specifies the IPsec/IPv4 tunnel mode.
mode ipsec ipv6: Specifies the IPsec/IPv6 tunnel mode.
mode ipv4-ipv4: Specifies the IPv4 over IPv4 tunnel mode.
mode ipv4-ipv6: Specifies the IPv4 over IPv6 tunnel mode.
mode ipv6: Specifies the IPv6 tunnel mode. When you configure an IPv4 over IPv6 manual tunnel or IPv6 over IPv6 tunnel, you must specify the IPv6 tunnel mode.
mode ipv6-ipv4: Specifies the IPv6 over IPv4 manual tunnel mode.
mode ipv6-ipv4 6rd: Specifies the 6RD tunnel mode.
mode ipv6-ipv4 6to4: Specifies the 6to4 tunnel mode.
mode ipv6-ipv4 auto-tunnel: Specifies the IPv4-compatible IPv6 automatic tunnel mode.
mode ipv6-ipv4 isatap: Specifies the ISATAP tunnel mode.
mode ipv6-ipv6: Specifies the IPv6 over IPv6 tunnel mode.
mode map-e: Specifies the MAP-E tunnel mode.
mode mpls-te: Specifies the MPLS TE tunnel mode.
mode sdwan udp: Specifies the UDP-encapsulated IPv4 SDWAN tunnel mode.
mode sdwan udp ipv6: Specifies the UDP-encapsulated IPv6 SDWAN tunnel mode.
mode sdwan-ex gre: Specifies the GRE-encapsulated IPv4 SDWAN extended tunnel mode.
mode sdwan-ex gre ipv6: Specifies the GRE-encapsulated IPv6 SDWAN extended tunnel mode.
mode sr ipv6: Specifies the SRv6 tunnel mode.
mode vxlan: Specifies the VXLAN tunnel mode.
To create a new tunnel interface, you must specify the tunnel mode in this command. To enter the view of an existing tunnel interface, you do not need to specify the tunnel mode.
A tunnel interface number is locally significant. The tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
You do not need to use the ip address or ipv6 address command to configure an IPv4 or IPv6 address for an IPv4 VXLAN or IPv6 VXLAN tunnel interface.
# Create VXLAN tunnel interface Tunnel 1 and enter tunnel interface view.
[Sysname] interface tunnel 1 mode vxlan
[Sysname-Tunnel1]
destination
source
mtu
Use mtu to set the MTU on a tunnel interface.
mtu size
undo mtu
If the tunnel interface has never been up, the MTU is 8100 bytes.
If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers. The outgoing interface is automatically obtained through routing table lookup based on the tunnel destination address.
size: Specifies the MTU, in the range of 100 to 8100 bytes.
If you do not configure an MTU for a tunnel interface or the configured MTU is 8100 bytes, the effective MTU depends on the tunnel interface status.
· If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers.
· If the tunnel interface is down, the device does not calculate or update the MTU of the tunnel interface.
If you configure an MTU for a tunnel interface and the MTU is not 8100 bytes, the configured MTU applies regardless of the tunnel interface status (up/down) and the outgoing interface MTU.
To avoid fragmentation after tunnel encapsulation, set the tunnel interface MTU no greater than the value of the outgoing interface MTU minus the length of the tunnel headers.
# Set the MTU on Tunnel 1 to 8000 bytes.
[Sysname-Tunnel1] mtu 8000
snmp-agent trap enable tunnel
Use snmp-agent trap enable tunnel to enable SNMP notifications for the tunneling module.
Use undo snmp-agent trap enable tunnel to disable SNMP notifications for the tunneling module.
snmp-agent trap enable tunnel [ max-threshold-reached | vxlan-config-failure | vxlan-decap-failure | vxlan-tunnel-status | vxlan-ipv6-tunnel-status ] *
undo snmp-agent trap enable tunnel [ max-threshold-reached | vxlan-config-failure | vxlan-decap-failure | vxlan-tunnel-status | vxlan-ipv6-tunnel-status ] *
SNMP notifications for the tunneling module are disabled.
max-threshold-reached: Enables notification for tunnel interfaces count exceeding the warning threshold.
vxlan-config-failure: Enables notification for VXLAN tunnel configuration deployment failure.
vxlan-decap-failure: Enables notification for VXLAN packet decapsulation failure.
vxlan-tunnel-status: Enables VXLAN over IPv4 tunnel status notification.
vxlan-ipv6-tunnel-status: Enables VXLAN over IPv6 tunnel status notification.
After you enable the max-threshold-reached notification, when the number of tunnel interfaces exceeds the warning threshold (80% of the maximum), the device generates SNMP notifications that record the chassis number and slot number of the exceeding tunnel interfaces.
After you enable the vxlan-config-failure notification, when a VXLAN tunnel failed to be deployed, the device generates an SNMP notification that records the interface number of the tunnel.
After you enable the vxlan-decap-failure notification, when a VXLAN packet failed to be decapsulated, the device generates an SNMP notification that records the source IP type, source IP address, destination IP type, and destination IP address of the VXLAN packet.
After you enable the vxlan-tunnel-status notification, the device generates SNMP notifications for VXLAN over IPv4 tunnels when the tunnel status changes.
After you enable the vxlan-ipv6-tunnel-status notification, the device generates SNMP notifications for VXLAN over IPv6 tunnels when the tunnel status changes.
If you do not specify any parameters, this command enables SNMP notifications for both VXLAN over IPv4 and VXLAN over IPv6 tunnel status change events.
To output tunnel notifications correctly, you must also configure parameters for sending SNMP notifications.
For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable VXLAN over IPv6 tunnel status notification.
[Sysname] snmp-agent trap enable tunnel vxlan-ipv6-tunnel-status
source
Use source to specify the source address or source interface for a tunnel interface.
Use undo source to restore the default.
source { ipv4-address | ipv6-address | interface-type interface-number }
undo source
No source address or source interface is specified for a tunnel interface.
ipv4-address: Specifies the tunnel source IPv4 address.
ipv6-address: Specifies the tunnel source IPv6 address.
The specified source address or the address of the specified source interface is used as the source address of tunneled packets. To display the configured tunnel source address, use the display interface tunnel command.
# Specify Ten-GigabitEthernet 0/0/6 as the source interface of Tunnel 1.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1] source ten-gigabitethernet 0/0/6
# Specify 192.100.1.1 as the source address of Tunnel 1.
[Sysname-Tunnel1] source 192.100.1.1
destination
interface tunnel
tunnel accelerate
Use tunnel accelerate to enable tunnel traffic forwarding acceleration.
Use undo tunnel accelerate to disable tunnel traffic forwarding acceleration.
tunnel accelerate
Tunnel traffic forwarding acceleration is disabled.
Use this command to accelerate the forwarding of tunneled packets when the NAT, IPsec, and AFT services are not deployed.
# Enable tunnel traffic forwarding acceleration.
[Sysname] tunnel accelerate
tunnel dfbit enable
Use tunnel dfbit enable to set the Don't Fragment (DF) bit for tunneled packets.
Use undo tunnel dfbit enable to restore the default.
tunnel dfbit enable
The DF bit is not set for tunneled packets.
To avoid fragmentation and delay, set the DF bit for tunneled packets. Make sure the path MTU is larger than the tunneled packet length. To avoid discarding tunneled packets whose length is larger than the path MTU, do not set the DF bit.
# Set the DF bit for tunneled packets on Tunnel 1.
[Sysname-Tunnel1] tunnel dfbit enable
tunnel discard ipv4-compatible-packet
Use tunnel discard ipv4-compatible-packet to enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
Use undo tunnel discard ipv4-compatible-packet to restore the default.
IPv6 packets that use IPv4-compatible IPv6 addresses are not dropped.
This command enables the device to check the source and destination IPv6 addresses of the de-encapsulated IPv6 packets from a tunnel. If a packet uses an IPv4-compatible IPv6 address as the source or destination address, the device discards the packet.
# Enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
[Sysname] tunnel discard ipv4-compatible-packet
tunnel out-interface
Use tunnel out-interface to specify an output interface for tunneled packets.
Use undo tunnel out-interface to restore the default.
tunnel out-interface interface-type interface-number
No output interface is specified for tunneled packets of a tunnel interface. If ECMP routes exist, the device randomly selects an output interface to forward the tunneled packets.
Use this command to control the forwarding path of tunneled packets. To ensure successful packet forwarding, the specified output interface must meet the following requirements:
· The interface is up.
· The interface has an IP address.
· The interface has a route to reach the destination.
This command is available only for GRE/IPv4, GRE/IPv6, IPv4 SDWAN, IPv6 SDWAN, IPv4 SDWAN extended, IPv6 SDWAN extended, and VXLAN tunnel interfaces.
# Specify Ten-GigabitEthernet 0/0/6 as the output interface of GRE packets on tunnel interface Tunnel 0.
[Sysname] interface tunnel 0 mode gre
[Sysname-Tunnel0] tunnel out-interface ten-gigabitethernet 0/0/6
tunnel path-mtu enable
Use tunnel path-mtu enable to enable path MTU learning on a tunnel interface.
Use undo tunnel path-mtu enable to disable path MTU learning on a tunnel interface.
Path MTU learning is disabled on a tunnel interface.
If the size of a tunneled packet exceeds the MTU of an interface in the tunnel path, the packet will be discarded. With the path MTU learning feature, the tunnel source can adjust the MTU of the tunnel interface according to the MTU information in received ICMP destination unreachable messages. After MTU adjustment, the tunnel source will resend the oversized tunneled packets, improving the forwarding reliability of tunnel packets.
This command cannot be used together with the mtu command on a tunnel interface.
This command is supported only on GRE/IPv4, GRE/IPv6, and VXLAN tunnel interfaces.
If path MTU learning is enabled on a GRE/IPv4 tunnel interface and the passenger protocol is IPv4, make sure the MTU of all interfaces in the tunnel path is equal to or greater than 1312 bytes. If the MTU of an interface in the tunnel path is less than 1312 bytes, forwarding failure will occur.
If path MTU learning is enabled on a GRE/IPv6 tunnel interface and the passenger protocol is IPv6, make sure the MTU of all interfaces in the tunnel path is equal to or greater than 1332 bytes. If the MTU of an interface in the tunnel path is less than 1332 bytes, forwarding failure will occur.
# Enable path MTU learning on tunnel interface Tunnel 0.
[Sysname-Tunnel0] tunnel path-mtu enable
tunnel tos
Use tunnel tos to set the ToS of tunneled packets.
Use undo tunnel tos to restore the default.
tunnel tos tos-value
undo tunnel tos
The ToS of tunneled packets is the same as the ToS of the original packets.
tos-value: Specifies the ToS of tunneled packets, in the range of 0 to 255.
After you configure this command, all the tunneled packets of different services sent on the tunnel interface will use the same configured ToS. For more information about ToS, see ACL and QoS Configuration Guide.
# Set the ToS of tunneled packets to 20 on Tunnel 1.
[Sysname-Tunnel1] tunnel tos 20
tunnel ttl
Use tunnel ttl to set the Time to Live (TTL) of tunneled packets.
Use undo tunnel ttl to restore the default.
tunnel ttl ttl-value
undo tunnel ttl
The TTL of tunneled packets is 255.
ttl-value: Specifies the TTL of tunneled packets, in the range of 1 to 255.
The TTL determines the maximum number of hops that the tunneled packets can pass. When the TTL expires, the tunneled packets are discarded to avoid loops.
# Set the TTL of tunneled packets to 100 on Tunnel 1.
[Sysname-Tunnel1] tunnel ttl 100
tunnel vpn-instance
Use tunnel vpn-instance to specify a VPN instance for the destination address of a tunnel interface.
Use undo tunnel vpn-instance to restore the default.
tunnel vpn-instance vpn-instance-name
The destination address of a tunnel interface belongs to the public network.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
After this command is executed, the device looks up the routing table of the specified VPN instance to forward tunneled packets on the tunnel interface.
For a tunnel interface to come up, the tunnel source and destination must belong to the same VPN instance. To specify a VPN instance for the tunnel source, use the ip binding vpn-instance command on the tunnel source interface.
# Specify VPN instance vpn10 for the tunnel destination on Tunnel 1.
[Sysname] ip vpn-instance vpn10
[Sysname-vpn-instance-vpn10] route-distinguisher 1:1
[Sysname-vpn-instance-vpn10] vpn-target 1:1
[Sysname-vpn-instance-vpn10] quit
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] ip binding vpn-instance vpn10
[Sysname-Ten-GigabitEthernet0/0/6] ip address 1.1.1.1 24
[Sysname-Ten-GigabitEthernet0/0/6] quit
[Sysname-Tunnel1] destination 1.1.1.2
[Sysname-Tunnel1] tunnel vpn-instance vpn10
ip binding vpn-instance (MPLS Command Reference)
