01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C IE4300[IE4300-M][IE4320] Switch Series Command References-R63xx-6W10201-Fundamentals Command Reference
11-Automatic configuration commands
11-Automatic configuration commands 34.40 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
This command is supported only if the device has standard (not micro or mini) USB interfaces.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
