12-VXLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR1000[2600][3600] Routers Command Reference(V9)-R9141-6W10012-VXLAN Command Reference
01-Basic VXLAN commands
01-Basic VXLAN commands 255.21 KB
The device does not support VXLAN-DCI or EVPN-DCI.
arp suppression enable
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
arp suppression enable [ no-broadcast ]
ARP flood suppression is disabled.
VSI view
no-broadcast: Disables the device from flooding the ARP requests that do not match any ARP flood suppression entry.
ARP flood suppression reduces ARP request broadcasts by enabling the VTEP to reply to ARP requests on behalf of VMs.
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ARP flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
display arp suppression vsi
reset arp suppression vsi
arp suppression mode
Use arp suppression mode to set the ARP flood suppression mode.
Use undo arp suppression mode to restore the default.
arp suppression mode { proxy-reply | unicast-forward } [  mismatch-discard ]
If ARP flood suppression is enabled, the default ARP flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the ARP requests that are not targeted at the device and do not match any ARP flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device replies to the ARP request on behalf of the target IP address. The ARP reply carries the following information:
·     Sender IP address—Target IP address in the ARP request.
·     Sender MAC address—MAC address in the matching ARP flood suppression entry.
·     Source MAC address—MAC address in the matching ARP flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device acts as follows:
1.     Replaces the target MAC address and destination MAC address in the ARP request with the MAC address in the entry.
2.     Unicasts the ARP request.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an ARP request that is not targeted at the device and does not match any ARP flood suppression entry. If you do not specify this keyword, the device will broadcast such an ARP request.
The device does not forward ARP requests in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ARP entry learning errors caused by the delay in refreshing ARP flood suppression entries at the expense of high system resource usage.
# Enable ARP flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression mode unicast-forward
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU.
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address      MAC address    VSI name                    Link ID    Aging(min)
1.1.1.2         000f-e201-0101 vsi1                        0x70000    14
1.1.1.3         000f-e201-0202 vsi1                        0x80000    18
1.1.1.4         000f-e201-0203 vsi2                        0x90000    10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI.
Aging
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted.
display ipv6 nd suppression vsi
Use display ipv6 nd suppression vsi to display ND flood suppression entries.
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
count: Displays the number of ND flood suppression entries that match the command.
# Display ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi
IPv6 address            MAC address     VSI name         Link ID    Aging (min)
1000::2                 000f-e201-0101  vsi1             0x70000    5
1000::3                 000f-e201-0202  vsi1             0x80000    5
1000::4                 000f-e201-0203  vsi2             0x90000    5
# Display the number of ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
Link ID
Aging (min)
Remaining lifetime (in minutes) of the ND flood suppression entry. When the timer expires, the entry is deleted.
ipv6 nd suppression enable
reset ipv6 nd suppression vsi
display l2vpn interface
Use display l2vpn interface to display L2VPN information for Layer 3 interfaces that are mapped to VSIs.
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
verbose: Displays detailed information about Layer 3 interfaces. If you do not specify this keyword, the command displays brief information about Layer 3 interfaces.
If you do not specify any parameters, this command displays brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
# Display brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface
Total number of interfaces: 1, 1 up, 0 down
Interface                                       Owner                           Link ID  State    Type
GE0/0/1                                         1                               0        Up       VSI
Layer 3 interface name.
Owner
VSI name.
Link ID
The interface's link ID on the VSI.
Physical state of the interface:
·     Up—The interface is physically up.
·     Down—The interface is physically down.
L2VPN type of the interface. This field displays VSI for the VXLAN feature.
# Display detailed L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface verbose
Interface: GE0/0/1
    Owner         : vsi1
    Link ID       : 0
    State         : Up
    Type          : VSI
    Statistics    : Enabled
    Input Statistics:
      Octets   :994496
      Packets  :15539
    Output Statistics:
      Octets   :0
      Packets  :0
Interface: GE0/0/2
    Owner         : vsi2
    Link ID       : 0
    State         : Down
    Type          : VSI
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
Owner
VSI name.
Link ID
Statistics
Packet statistics state:
·     Enabled—The packet statistics feature is enabled for the interface.
·     Disabled—The packet statistics feature is disabled for the interface.
Input Statistics
Incoming traffic statistics:
·     Octets—Number of incoming bytes.
·     Packets—Number of incoming packets.
Output Statistics
Outgoing traffic statistics:
·     Octets—Number of outgoing bytes.
·     Packets—Number of outgoing packets.
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
·     Dynamic remote- and local-MAC entries.
·     Remote-MAC entries advertised through BGP EVPN.
·     Manually added static remote- and local-MAC entries.
·     Remote-MAC entries issued through OpenFlow.
count: Displays the number of MAC address entries.
verbose: Displays detailed information about MAC address entries.
If you do not specify the count or verbose keyword, this command displays brief information about MAC address entries.
# Display brief information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000b   Static   vpn1                            Tunnel10      NotAging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
--- 3 mac address(es) found  ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
Table 5 Command output
Entry state:
·     Dynamic—Local- or remote-MAC entry dynamically learned in the data plane.
·     Static—Static local- and remote-MAC entry.
·     EVPN—Remote-MAC entry advertised through BGP EVPN.
·     OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow.
Link ID/Name
For a local MAC address, this field displays the interface name if the AC is a Layer 3 interface. If the AC is an Ethernet service instance, this field displays the name of the interface that hosts the Ethernet service instance for the MAC address.
For a remote MAC address, this field displays the tunnel interface name.
Aging
Entry aging state:
·     Aging.
·     NotAging.
# Display detailed information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name    : vpn1
VXLAN ID    : 123
Interface   : GE0/0/1
Link ID     : 1
State       : Dynamic
Aging       : Aging
Table 6 Command output
Link ID
Entry state:
·     Static—Static local- or remote-MAC entry.
Aging
Entry aging state:
·     Aging.
·     NotAging.
reset l2vpn mac-address
display l2vpn mac-address mac-move
Use display l2vpn mac-address mac-move to display MAC move records for VSIs.
display l2vpn mac-address mac-move [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays MAC move records on the active MPU.
When a MAC address frequently moves between two interfaces, Layer 2 loops might occur in the network. To discover and locate loops, you can view the MAC address move records.
This command displays the MAC move events that have occurred on VSIs since startup of the device. The MAC move records with the same MAC address, VSI name, source port, and current port are considered to be one record.
A card can generate a maximum of 200 MAC address move records.
# Display MAC move records for all VSIs.
<Sysname> display l2vpn mac-address mac-move
MAC address : 0000-4900-03e7      VSI name   : 3
Current port: GE0/0/1             Source port: GE0/0/2
Last time   : 2019-02-19 20:44:15 Move count : 1
MAC address : 0000-4900-03e8      VSI name   : 3
Current port: GE0/0/1             Source port: GE0/0/3
Last time   : 2019-02-19 20:44:16 Move count : 1
---  2 MAC address moving records found  ---
Table 7 Command output
Current port
Interface to which the MAC address was moved.
Source port
Interface from which the MAC address was moved.
Last time
Last time when the MAC address was moved.
Move count
Number of times that the MAC address has moved.
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name | evpn-srv6 | evpn-vpls | evpn-vxlan | vpls | vxlan ] [ count | verbose ]
evpn-srv6: Specifies VSIs of EVPN VPLS over SRv6.
evpn-vpls: Specifies VSIs of EVPN VPLS.
evpn-vxlan: Specifies VSIs of EVPN VXLAN.
vpls: Specifies VSIs of VPLS.
vxlan: Specifies VSIs of VXLAN.
count: Displays VSI state statistics.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
If you do not specify a VSI or network type, this command displays information about all VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 2, 1 up, 1 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpls1                           0               1500   Up
vpls2                           1               1500   Down
# Display state statistics about all VSIs.
<Sysname> display l2vpn vsi count
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
Table 8 Command output
VSI state:
·     Up—The VSI is up.
·     Down—The VSI is down.
·     Admin down—The VSI has been manually shut down by using the shutdown command.
# Display detailed information about all VSIs of EVPN VXLAN.
<Sysname> display l2vpn vsi evpn-vxlan verbose
VSI Name: vpna
  VSI Index               : 0
  VSI Description         : vsi for vxlan10
  VSI State               : Up
  MTU                     : -
  Diffserv Mode           : -
  Bandwidth               : -
  Broadcast Restrain      : -
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Learning            : -
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  PW Redundancy Mode      : Independent
  DSCP                    : -
  Service Class           : -
  ESI                     : 0000.0000.0000.0000.0000
  Redundancy Mode         : All-active
  Input statistics        :
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Output statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  EVPN Encapsulation      : VXLAN
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel1              0x5000001  Up     Manual    Disabled
    Tunnel2              0x5000002  Up     Manual    Disabled
  ACs:
    AC                                                           Link ID    State         Type
    GE0/0/1                                                      0x0        Up            Manual
    Statistics: Disabled
# Display detailed information about all VSIs of EVPN VPLS.
<Sysname> display l2vpn vsi evpn-vpls verbose
VSI Name: 1
  VSI Index               : 0
  VSI State               : Up
  Diffserv Mode           : -
  Bandwidth               : -
  Broadcast Restrain      : 5120 kbps
  Multicast Restrain      : 5120 kbps
  Unknown Unicast Restrain: 5120 kbps
  MAC Table Limit         : Unlimited
  MAC Learning rate       : Unlimited
  Drop Unknown            : Disabled
  PW Redundancy Mode      : Slave
  DSCP                    : -
  Service Class           : -
  Statistics              : Disabled
  EVPN Encapsulation      : MPLS
  EVPN MPLS labels:
    MPLS label      : 775115
    IMET MPLS label : 775114
  EVPN PWs:
    Peer            Remote Service ID  Link ID    State       Flag
    1.1.1.1         -                  8          Up          Main
    Create time: 2020-07-22 05:49:28
    Last time status changed: 2020-07-22 05:49:28
    Last time PW went down: 2020-07-22 05:49:28
    3.3.3.3         -                  9          Up          Main
    Create time: 2020-07-22 05:49:29
    Last time status changed: 2020-07-22 05:49:29
    Last time PW went down: 2020-07-22 05:49:29
  ACs:
Table 9 Command output
VSI Description
Description of the VSI. If the VSI does not have a description, the command does not display this field.
VSI State
VSI state:
·     Up—The VSI is up.
·     Administratively down—The VSI has been manually shut down by using the shutdown command.
MTU
MTU on the VSI.
Diffserv Mode
DiffServ mode.
Bandwidth
Bandwidth limit in kbps.
If no bandwidth limit is set for the VSI, Unlimited is displayed.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps).
If the broadcast restraint bandwidth is not set, Unlimited is displayed.
Multicast Restrain
Multicast restraint bandwidth (in kbps).
If the multicast restraint bandwidth is not set, Unlimited is displayed.
Unknown unicast restraint bandwidth (in kbps).
If the unknown unicast restraint bandwidth is not set, Unlimited is displayed.
MAC Learning
State of the MAC learning feature.
MAC Table Limit
Maximum number of MAC address entries on the VSI.
MAC Learning rate
MAC address entry learning rate of the VSI.
Drop Unknown
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached.
PW Redundancy Mode
PW redundancy operation mode:
·     Slave—Master/slave mode and the local PE operates as the slave node.
·     Master—Master/slave mode and the local PE operates as the master node.
·     Independent—Independent mode.
DSCP
DSCP value of outgoing VXLAN packets.
Service Class
Service class value of outgoing VXLAN packets.
Flooding
State of the VSI's flooding feature:
·     Enabled—Flooding is enabled on the VSI.
·     Disabled—Flooding is disabled on the VSI.
ESI
ESI assigned to the VSI.
Redundancy Mode
ES redundancy mode for the VSI:
·     A—All-active mode.
·     S—Single-active mode.
Statistics
·     Enabled—The packet statistics feature is enabled for the VSI.
·     Disabled—The packet statistics feature is disabled for the VSI.
Input statistics
·     Errors—Number of error packets.
·     Discards—Number of discarded packets.
Output statistics
Input Rate
Incoming traffic rate for the VSI, in Bps and pps.
Output Rate
Outgoing traffic rate for the VSI, in Bps and pps.
Gateway Interface
VSI interface name.
EVPN Encapsulation
EVPN encapsulation type:
·     VXLAN.
·     MPLS.
·     SRv6.
EVPN MPLS Labels
MPLS labels for the VSI.
MPLS label
MPLS label in MAC/IP advertisement routes.
IMET MPLS label
MPLS label in IMET routes.
Peer
IP address of the remote PE.
Link ID
Link ID of the EVPN PW in the VSI.
State of the EVPN PW:
·     Up.
·     Down.
Flag
PW attribute flag.
Create time
Time when the EVPN PW was created.
Time when the most recent EVPN PW state change occurred.
Tunnel state:
·     Up—The tunnel is operating correctly.
·     Down—The tunnel interface is down.
Tunnel assignment method:
·     Auto—The tunnel was automatically assigned to the VXLAN:
¡     For an EVPN network, VXLAN tunnels are automatically assigned to VXLANs.
¡     For a multicast-mode VXLAN, the tunnel (MTunnel) was automatically created and assigned to the VXLAN to transmit flood traffic.
·     Manual—The tunnel was manually assigned to the VXLAN.
Flood proxy
Flood proxy state.
Private-VSI type
Private VSI type:
·     Community—A secondary VSI whose ACs have Layer 2 connectivity to one another.
·     Isolated—A secondary VSI whose ACs are isolated at Layer 2.
·     Primary.
Associated secondary VSIs
Secondary VSIs associated with the VSI.
Associated primary VSI
Primary VSI associated with the VSI.
ACs
ACs that are bound to the VSI.
Link ID
AC's link ID on the VSI.
AC state:
·     Up.
·     Down.
Type and traffic match mode of the Ethernet service instance:
·     Dynamic (M-LAG)—Dynamic Ethernet service instance created on the peer link, in VLAN-based traffic match mode.
·     Dynamic (MAC-based)—Dynamic Ethernet service instance in MAC-based traffic match mode.
·     Dynamic (VLAN-based)—Dynamic Ethernet service instance in VLAN-based traffic match mode.
·     Manual—Static Ethernet service instance in VLAN-based traffic match mode.
Statistics
State of AC traffic statistics:
·     Enabled.
·     Disabled.
display vxlan tunnel
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 2 (2 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
Table 10 Command output
Link ID
Tunnel's link ID in the VXLAN.
Tunnel state:
Flood proxy
Flood proxy state.
tunnel
vxlan
flooding disable (VSI view)
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction ]
Flooding is enabled for a VSI.
VSI view
all: Specifies broadcast, unknown unicast, and unknown multicast traffic.
broadcast: Specifies broadcast traffic.
unknown-multicast: Specifies unknown multicast traffic.
unknown-unicast: Specifies unknown unicast traffic.
all-direction: Disables flooding traffic received from an AC, VXLAN tunnel interface, or PW to any other ACs and VXLAN tunnel interfaces or PWs of the same VSI. If you do not specify this keyword, the command only disables flooding traffic received from ACs to VXLAN tunnel interfaces or PWs of the VSI.
By default, the device floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
·     All site-facing interfaces except for the incoming interface.
·     All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, use this command to disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
You cannot specify the unknown-multicast or unknown-unicast keyword alone. If you specify one of the keywords, you must also specify the other.
# Disable flooding of local broadcast traffic to remote sites for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
igmp host enable
Use igmp host enable to enable the IGMP host feature on an interface.
Use undo igmp host enable to disable the IGMP host feature on an interface.
igmp host enable
The IGMP host feature is disabled on an interface.
Interface view
You must configure an interface as an IGMP host if its IP address is the source IP address of multicast VXLAN packets. The IGMP host feature enables the interface to send IGMP reports in response to IGMP queries before it can receive traffic from a multicast group.
For this command to take effect, you must use the multicast routing command to enable IP multicast routing.
# Enable IP multicast routing, and then enable the IGMP host feature on GigabitEthernet 0/0/1.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname] interface gigabitethernet 0/0/1
[Sysname-GigabitEthernet0/0/1] igmp host enable
display igmp host group
group
multicast routing (IP Multicast Command Reference)
Use ipv6 nd suppression enable to enable ND flood suppression.
Use undo ipv6 nd suppression enable to disable ND flood suppression.
ipv6 nd suppression enable [ no-broadcast ]
ND flood suppression is disabled.
VSI view
no-broadcast: Disables the device from flooding the ND requests that do not match any ND flood suppression entry.
ND flood suppression reduces ND request multicasts by enabling the VTEP to reply to ND requests on behalf of user terminals.
This feature snoops ND packets to populate the ND flood suppression table with local and remote MAC addresses. If an ND request has a matching entry, the VTEP replies to the request on behalf of the user terminal. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ND flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable
ipv6 nd suppression mode
Use ipv6 nd suppression mode to set the ND flood suppression mode.
Use undo ipv6 nd suppression mode to restore the default.
ipv6 nd suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
If ND flood suppression is enabled, the default ND flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the NS packets that are not targeted at the device and do not match any ND flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device replies to the NS packet on behalf of the target IP address. The replied NA packet carries the following information:
·     Sender IP address—Target IP address in the NS packet.
·     Source MAC address—MAC address in the matching ND flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device acts as follows:
1.     Replaces the destination MAC address in the NS packet with the MAC address in the entry.
2.     Unicasts the NS packet.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an NS packet that is not targeted at the device and does not match any ND flood suppression entry. If you do not specify this keyword, the device will broadcast such an NS packet.
The device does not forward NS packets in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ND entry learning errors caused by the delay in refreshing ND flood suppression entries at the expense of high system resource usage.
# Enable ND flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] nd suppression mode unicast-forward
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn statistics interval
Use l2vpn statistics interval to set the L2VPN statistics collection interval.
Use undo l2vpn statistics interval to restore the default.
l2vpn statistics interval interval
The L2VPN statistics collection interval is 15 minutes.
interval: Sets the L2VPN statistics collection interval in seconds, in the range of 5 to 65535.
# Set the L2VPN statistics collection interval to 30 seconds.
[Sysname] l2vpn statistics interval 30
mac-address static vsi
Use mac-address static vsi to add a static MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove a static MAC address entry for a VXLAN VSI.
mac-address static mac-address interface  tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] interface tunnel tunnel-number vsi vsi-name
VXLAN VSIs do not have static MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
interface tunnel tunnel-number: Specifies a VXLAN tunnel interface by its tunnel interface number. The tunnel interface must already exist. This option applies to remote MAC addresses.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through BGP EVPN.
When you add a remote MAC address entry, make sure the VSI's VXLAN has been specified on the VXLAN or VXLAN-DCI tunnel.
Do not configure static remote-MAC entries for tunnels that are automatically established by using EVPN.
·     EVPN re-establishes tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
·     EVPN re-establishes tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
mapping vni (EVPN Command Reference)
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
Use reset ipv6 nd suppression vsi to clear ND flood suppression entries on VSIs.
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ND flood suppression entries on all VSIs.
# Clear ND flood suppression entries on all VSIs.
<Sysname> reset ipv6 nd suppression vsi
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
selective-flooding mac-address
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote unicast or multicast MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are up.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
tunnel
Use tunnel to assign VXLAN tunnels to a VXLAN.
Use undo tunnel to remove VXLAN tunnels from a VXLAN.
tunnel { tunnel-number | all }
undo tunnel { tunnel-number | all }
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The value range for this argument is 0 to 10239.The tunnel must be a VXLAN tunnel.
all: Specifies all VXLAN tunnels.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
To assign a pair of primary and backup VXLAN tunnels to the VXLAN, specify the backup-tunnel tunnel-number option. When the primary VXLAN tunnel is operating correctly, the backup VXLAN tunnel does not forward traffic. When the primary VXLAN tunnel goes down, traffic is switched to the backup VXLAN tunnel.
If you assign VXLAN tunnels to a VXLAN one by one, you cannot remove all the VXLAN tunnels by using the undo tunnel all command.
If you assign all VXLAN tunnels to a VXLAN by using the tunnel all command, you cannot remove the VXLAN tunnels one by one. You can only use the undo tunnel all command to remove all the VXLAN tunnels.
As a best practice, use the tunnel all command only when batch VXLAN tunnel assignment is necessary.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
No global source address is specified for VXLAN tunnels.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify the ipv6 keyword when using the undo form of the command, the global IPv4 address is deleted.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels (VXLAN-DCI tunnels not included).
IPv4 VXLAN tunnels use the global IPv4 source address. IPv6 VXLAN tunnels use the global IPv6 source address.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
vxlan invalid-udp-checksum discard
Use vxlan invalid-udp-checksum discard to enable the device to drop the VXLAN packets that fail UDP checksum check.
Use undo vxlan invalid-udp-checksum discard to restore the default.
The device does not check the UDP checksum of VXLAN packets.
This command enables the device to check the UDP checksum of VXLAN packets.
The device always sets the UDP checksum of VXLAN packets to 0. For compatibility with third-party devices, a VXLAN packet can pass the check if its UDP checksum is 0 or correct. If its UDP checksum is incorrect, the VXLAN packet fails the check and is dropped.
# Enable the device to drop the VXLAN packets that fail UDP checksum check.
[Sysname] vxlan invalid-udp-checksum discard
vxlan invalid-vlan-tag discard
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to notify the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see System Management Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
vxlan source udp-port five-tuple
Use vxlan source udp-port five-tuple to configure a VXLAN tunnel interface to generate the source UDP port number in the VXLAN encapsulation based on the IP five-tuple of the inner Ethernet frame.
Use undo vxlan source udp-port five-tuple to restore the default.
The source UDP port number in the VXLAN encapsulation is generated based on the source and destination MAC addresses of the inner Ethernet frame.
VXLAN tunnel interface view
This command takes effect only on IPv4-based VXLAN. Only manually created VXLAN tunnel interfaces support this command.
# Configure VXLAN tunnel interface Tunnel 1 to generate the source UDP port number in the VXLAN encapsulation based on the IP five-tuple of the inner Ethernet frame.
[Sysname] interface tunnel 1 mode vxlan
[Sysname-Tunnel1] vxlan source udp-port five-tuple
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } | leaf ]
undo xconnect vsi
An AC is not mapped to any VSI.
Interface view
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies an access mode. The default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
To monitor the status of an AC, associate it with track entries.
For traffic that matches the AC, the system uses the VSI's MAC address table to make a forwarding decision.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
·     VLAN access mode—Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
¡     For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
¡     For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
·     Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
¡     For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
¡     For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
# Map GigabitEthernet 0/0/1 to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet0/0/1] xconnect vsi vpn1
encapsulation
vsi
