11-Segment Routing Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR1000[2600][3600] Routers Configuration Guides(V9)-R9141-6W10011-Segment Routing Configuration Guide
08-EVPN VPLS over SRv6 configuration
08-EVPN VPLS over SRv6 configuration 772.53 KB
Configuring EVPN VPLS over SRv6· 1
About EVPN VPLS over SRv6· 1
Basic principle· 1
BGP EVPN route advertisement 1
Traffic forwarding· 1
EVPN VPLS over SRv6 multihoming· 3
EVPN E-tree· 5
EVPN VPLS over SRv6 tasks at a glance· 6
Creating a VSI 6
Configuring an EVPN instance· 7
About this task· 7
Creating an EVPN instance in VSI view· 7
Configuring SRv6 SIDs· 8
Applying a locator to an EVPN instance· 8
About this task· 8
Applying a locator to an EVPN instance in VSI view· 8
Configuring unicast traffic forwarding based on End.DX2 and End.DX2L SIDs· 9
Configuring the route recursion mode· 9
About this task· 9
Prerequisites· 10
Configuring the route recursion mode for an EVPN instance in VSI view· 10
Configuring SRv6 TE policy traffic steering· 10
Restrictions and guidelines for SRv6 TE policy traffic steering· 10
Configuring color-based traffic steering· 10
Configuring tunnel policy-based traffic steering· 12
Mapping ACs to a VSI 13
Mapping a Layer 3 interface to a VSI 13
Configuring PEs to exchange BGP EVPN routes· 13
Specifying a source address for the outer IPv6 header of SRv6-encapsulated EVPN VPLS packets· 14
Configuring EVPN VPLS over SRv6 multihoming· 14
Restrictions and guidelines for EVPN VPLS over SRv6 multihoming· 14
Assigning an ESI to an interface or VSI 14
Setting the redundancy mode· 15
Configuring local FRR for EVPN VPLS over SRv6· 15
Enabling VSIs to ignore the state of ACs· 16
Enabling ARP flood suppression· 17
Configuring EVPN E-tree· 17
About this task· 17
Restrictions and guidelines· 18
Configuring EVPN E-tree for an EVPN instance in VSI view· 18
Configuring SRv6 PW packet statistics· 18
Test the connectivity of an SRv6 PW·· 19
Using ping to test the connectivity of an SRv6 PW·· 19
Using tracert to test the connectivity of an SRv6 PW·· 19
Verifying and maintaining EVPN VPLS over SRv6· 20
Displaying BGP EVPN route information· 20
Displaying EVPN VPLS over SRv6 running status· 20
Displaying MAC address and ARP entries· 21
Displaying EVPN VPLS over SRv6 forwarding entries· 21
Displaying and clearing EVPN VPLS over SRv6 statistics· 22
EVPN VPLS over SRv6 configuration examples· 22
Example: Setting up an SRv6 tunnel between single-homed EVPN VPLS sites· 22
Example: Configuring EVPN VPLS over SRv6 multihoming (static link aggregation dual-homed) 26
Example: Configuring EVPN VPLS over SRv6 multihoming (S-Trunk dual-homed) 32
Configuring distributed SRv6 gateways· 39
About distributed SRv6 gateways· 39
Distributed SRv6 gateway deployment 39
Control plane working mechanisms· 39
Data plane traffic forwarding· 40
Restrictions and guidelines: Distributed SRv6 gateway configuration· 41
Distributed SRv6 gateway tasks at a glance· 41
Prerequisites for distributed SRv6 gateway configuration· 41
Creating a VSI 41
Configuring an EVPN instance· 42
Configuring SRv6 SIDs· 43
Configuring a VSI interface as a distributed SRv6 gateway· 43
Configuring the route recursion mode· 44
Configuring SRv6 TE policy traffic steering· 45
Restrictions and guidelines for SRv6 TE policy traffic steering· 45
Configuring color-based traffic steering· 45
Configuring tunnel policy-based traffic steering· 46
Mapping ACs to a VSI 47
Mapping a Layer 3 interface to a VSI 47
Configuring PEs to exchange BGP EVPN routes· 48
Specifying a source address for the IPv6 packets encapsulated by a distributed SRv6 gateway· 48
Configuring BGP EVPN route redistribution and advertisement 49
Redistributing MAC/IP advertisement routes into BGP unicast routing tables· 49
Enabling BGP EVPN route advertisement to the local site· 49
Managing remote MAC address entries and remote ARP learning· 50
Disabling MAC address advertisement 50
Disabling learning of MAC addresses from ARP information· 50
Verifying and maintaining distributed SRv6 gateways· 51
Distributed SRv6 gateway configuration examples· 51
Example: Configuring distributed SRv6 gateways· 51
EVPN VPLS over SRv6 uses SRv6 tunnels to carry EVPN VPLS services. This technology establishes point-to-multipoint connections for customer sites over the IPv6 backbone network and transparently forwards Layer 2 customer traffic over the IPv6 backbone network. For more information about EVPN VPLS configuration, see EVPN Configuration Guide.
Basic principle
As shown in Figure 1, PEs set up an SRv6 tunnel by advertising End.DT2M SIDs, End.DT2U SIDs, and End.DX2 SIDs to each other through BGP EVPN routes. On a PE, this SRv6 tunnel is used as a PW to encapsulate and forward Layer 2 data packets received from the local site and destined for a remote site. The devices on the IPv6 backbone transport network forward the SRv6-encapsulated packets according to the optimal routes calculated by an IGP. As a result, Layer 2 data packets of one customer site can be transparently forwarded to another site over the IPv6 backbone transport network.
Figure 1 EVPN VPLS over SRv6 network diagram
A PE adds the End.DT2M SID and End.DT2U SID of a local VSI or the End.DX2 SID of an AC to BGP EVPN routes and advertises the routes to remote PEs. The routes help the PE establish an SRv6 tunnel to each remote PE.
·     The End.DT2M SID is carried in IMET routes and is used to deliver EVPN VPLS broadcast, unknown unicast, and multicast (BUM) traffic.
·     The End.DT2U or End.DX2 SID is carried in MAC/IP advertisement routes and is used to deliver EVPN VPLS known unicast traffic.
A pair of PEs both advertise End.DT2M SIDs and End.DT2U or End.DX2 SIDs, and they establish two SRv6 tunnels at two directions. The two SRv6 tunnels form a PW to carry Layer 2 customer traffic.
Traffic forwarding
EVPN VPLS over SRv6 supports the following route recursion modes:
·     SRv6 BE mode.
·     SRv6 TE mode.
·     SRv6 TE and SRv6 BE hybrid mode.
The packet forwarding process differs by the route recursion mode in use.
SRv6 BE mode
This mode is also called SID-based forwarding mode. In this mode, a PE forwards an SRv6 packet by searching the IPv6 routing table based on the End.DT2U, End.DX2, or End.DT2M SID encapsulated in the packet.
As shown in Figure 1, a Layer 2 known unicast packet is forwarded from CE 1 to CE 2 as follows:
1.     CE 1 sends the Layer 2 packet to PE 1.
2.     After PE 1 receives the packet on the AC connected to CE 1, it searches the MAC address table of the VSI associated with that AC for the destination MAC address. PE 1 finds that the output interface is an SRv6 tunnel and obtains the End.DT2U or End.DX2 SID of the SRv6 tunnel.
3.     PE 1 encapsulates an outer IPv6 header for the packet. The End.DT2U or End.DX2 SID is encapsulated in the outer IPv6 header as the destination IPv6 address. The source IPv6 address is the source address specified for the outer IPv6 header of SRv6-encapsulated EVPN VPLS packets.
4.     PE 1 searches the IPv6 routing table based on the End.DT2U or End.DX2 SID for the optimal IGP route and forwards the packet to P through the optimal IGP route.
5.     P searches the IPv6 routing table based on the End.DT2U or End.DX2 SID for the optimal IGP route and forwards the packet to PE 2 through the optimal IGP route.
6.     PE 2 searches the local SID forwarding table for the End.DT2U or End.DX2 SID. According to the SID type, PE 2 removes the outer IPv6 header from the packet and performs the following operations:
¡     If the SID is an End.DT2U SID, PE 2 matches the packet to a VSI and searches the MAC address table of the VSI for the destination MAC address. Then, PE 2 forwards the packet to CE 2.
¡     If the SID is an End.DX2 SID, PE 2 forwards the packet to the AC associated with the End.DX2 SID.
As shown in Figure 1, a Layer 2 broadcast, multicast, or unknown unicast packet is forwarded as follows:
2.     After PE 1 receives the packet on the AC connected to CE 1, it searches all End.DT2M SIDs received from remote PEs on the VSI associated with the AC.
3.     PE 1 encapsulates an outer IPv6 header for the packet. An End.DT2M SID is encapsulated in the outer IPv6 header as the destination IPv6 address. The source IPv6 address is the source address specified for the outer IPv6 header of SRv6-encapsulated EVPN VPLS packets.
If PE 1 has received End.DT2M SIDs from multiple remote PEs, it encapsulates each End.DT2M SID to the Layer 2 packet and floods the packet to all remote PEs.
4.     PE 1 searches the IPv6 routing table based on the End.DT2M SID for the optimal IGP route and forwards the packet to P through the optimal IGP route.
5.     P searches the IPv6 routing table based on the End.DT2M SID for the optimal IGP route and forwards the packet to PE 2 through the optimal IGP route.
6.     PE 2 searches the local SID forwarding table for the End.DT2M SID and performs the following operations:
a.     Removes the outer IPv6 header.
b.     Matches the packet to a VSI based on the End.DT2M SID.
c.     Floods the packet in the VSI.
SRv6 TE mode
This mode is also called SRv6 TE policy-based forwarding mode. In this mode, when the PE forwards a customer packet, it first searches for a matching SRv6 TE policy based on the packet attributes. Then, the PE adds an SRH to the packet. The SRH includes the destination End.DT2M SID or End.DT2U or End.DX2 SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet based on the SRv6 TE policy.
The following modes are available to steer traffic to an SRv6 TE policy:
·     Color—The device searches for an SRv6 TE policy that has the same color and endpoint address as the color and nexthop address of a BGP EVPN route. If a matching SRv6 TE policy exists, the device recurses the BGP EVPN route to that SRv6 TE policy. When the device receives packets that match the BGP EVPN route, it forwards the packets through the SRv6 TE policy.
·     Tunnel policy—The device searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route. Configure a preferred tunnel or load sharing tunnel policy that uses the SRv6 TE policy. In this way, the SRv6 TE policy will be used as the public tunnel to carry the SRv6 PW that forwards the packets of private network packets.
For more information about tunnel policies, see MPLS Configuration Guide. For more information about SRv6 TE policies, see "Configuring SRv6 TE policies."
In this mode, the PE preferentially uses the SRv6 TE mode to forward a customer packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
About EVPN VPLS over SRv6 multihoming
As shown in Figure 2, EVPN VPLS over SRv6 supports deploying multiple PEs at a site for redundancy and high availability. On the redundant PEs, Ethernet links connected to the site form an Ethernet segment (ES) that is uniquely identified by an ES identifier (ESI). EVPN VPLS over SRv6 supports only dualhoming.
Figure 2 EVPN VPLS over SRv6 multihoming
Redundancy mode
The device supports single-active redundancy mode and all-active redundancy mode of EVPN VPLS over SRv6 multihoming.
·     All-active mode—This mode allows all redundant PEs to a multihomed site to load share unicast traffic.
·     Single-active mode—This mode allows one of the redundant PEs to forward traffic. When the primary PE becomes unavailable because of device failure or link failure, traffic is switched to the backup PE for forwarding. A designated forwarder (DF) is elected from the redundant PEs as the primary PE. For more information about DF election, see EVPN VPLS configuration in EVPN Configuration Guide.
Route advertisement
The redundant PEs at a multihomed site both advertise End.DT2U or End.DX2 SIDs and End.DT2M SIDs to remote PEs. In addition, they advertise the redundancy mode of the multihomed site and their roles (primary or secondary) to remote PEs. A remote PE handles BGP EVPN routes advertised by the redundant PEs based on the redundancy mode.
·     In all-active mode, the remote PE treats the routes advertised by the redundant PEs as ECMP routes that can load share traffic.
·     In single-active mode, the remote PE treats the routes advertised by the primary PE as the optimal routes and only uses the optimal routes to forward traffic.
Local FRR for EVPN VPLS over SRv6
As shown in Figure 3, CE 1 is dualhomed to PE 1 and PE 2, and PE 1 is the DF. When the AC on PE 1 fails, PE 1 deletes the corresponding MAC address entries and advertises the local unreachable event to PE 2 and remote PEs (PE 3 in this example). Then, the remote PEs will switch traffic destined for CE 1 to the tunnels to PE 2. This process takes some time. PE 1 might receive packets destined for CE 1 before the remote PEs are notified of the unreachable event and perform link switchover. In this situation, PE 1 drops the packets, because the AC's MAC address entries have been deleted. To resolve this issue, enable local FRR on PE 1. If an AC fails, PE 1 changes the output interface of the AC's MAC address entries to the index of the bypass SRv6 PW between PE 1 and PE 2. When receiving packets from remote PEs after its AC fails, PE 1 forwards the packets to PE 2 over the bypass SRv6 PW to prevent traffic loss.
Figure 3 Local FRR network diagram
A loop might exist if PE 1 and PE 2 establish a bypass SRv6 PW between them through End.DT2U or End.DX2 SIDs. When the AC on PE 1 or PE 2 fails, PE 1 or PE 2 forwards the packets received from its peer back to its peer through the bypass SRv6 PW. To resolve this issue, use End.DT2UL or End.DX2L SIDs to establish a bypass SRv6 PW between PE 1 and PE 2. The packets from a bypass SRv6 PW carry an End.DT2UL or End.DX2L SID. A PE does not forward the packets back to the bypass SRv6 PW.
PEs preferentially use End.DT2UL or End.DX2L SIDs to establish a bypass SRv6 PW. If no End.DT2UL or End.DX2L SIDs are available, the PEs use End.DT2U or End.DX2 SIDs to establish a bypass SRv6 PW.
EVPN E-tree
About EVPN E-tree
In an EVPN VPLS over SRv6 network, EVPN E-tree isolates unicast and flood traffic (broadcast, multicast, and unknown unicast) of ACs in the same EVPN instance based on the AC roles. With EVPN E-tree, the device isolates unicast and flood traffic of ACs in the same EVPN instance as follows:
·     Leaf ACs can access root ACs.
·     Leaf ACs cannot access each other.
·     Root ACs can access each other and access leaf ACs.
Figure 4 EVPN E-tree network diagram
Local traffic isolation
EVPN E-tree isolates traffic between local ACs on a PE as follows:
·     When the PE receives packets from a leaf AC on a VSI, it forwards the packets only to root ACs on the VSI.
·     When the PE receives packets from a root AC on a VSI, it forwards the packets to all local ACs on the VSI except the incoming AC.
Remote known unicast traffic isolation
With EVPN E-tree, PEs perform MAC address learning for hosts attached to leaf ACs as follows:
1.     When a PE receives a packet from a leaf AC, it learns the source MAC address of the packet and adds the Leaf flag to the MAC address.
2.     The PE advertises the MAC address to the remote PE in a MAC/IP advertisement route. The route carries the E-tree extended community attribute that contains the Leaf flag.
3.     The remote PE adds the MAC address that carries the Leaf flag to the MAC address table.
When one PE receives a packet destined for a host on another PE from a local AC, it searches the MAC address table for the destination MAC address. If the entry of the destination MAC address has the Leaf flag and the packet is also from a leaf AC, the PE discards the packet. In other situations, the PE forwards the packet.
Remote flood traffic isolation
With EVPN E-tree, a PE sets the Args value of SRv6 SIDs to 1 for leaf ACs. The PE adds the Args value to Ethernet auto-discovery routes and advertises the routes to remote PEs.
EVPN E-tree isolates flood traffic from one PE to another PE as follows:
1.     When a PE receives a flood packet from a leaf AC on a VSI, it recalculates the End.DT2M SID based on the End.DT2M SID advertised by the remote PE and the Args value of 1. Then, the local PE adds the newly calculated End.DT2M SID to the packet and forwards the packet to the remote PE.
2.     The remote PE checks the Args value of the End.DT2M SID and finds that the value is 1. Then, the PE forwards the packet only to local root ACs on the same VSI.
If a PE receives a flood packet from a root AC, it directly adds the End.DT2M SID advertised by the remote PE to the packet and forwards the packet to the remote PE. The Args value of the End.DT2M SID is 0 by default. When the remote PE receives the packet, it forwards the packet to both local root ACs and local leaf ACs.
To configure EVPN VPLS over SRv6, perform the following tasks:
1.     Creating and configuring an EVPN instance
a.     Creating a VSI
b.     Configuring an EVPN instance
2.     Applying for SRv6 SIDs from a locator
a.     Configuring SRv6 SIDs
b.     Applying a locator to an EVPN instance
3.     Configuring packet forwarding methods
¡     (Optional.) Configuring unicast traffic forwarding based on End.DX2 and End.DX2L SIDs
¡     Configuring the route recursion mode
¡     Configuring SRv6 TE policy traffic steering
This task is required if the route recursion mode is SRv6 TE mode or SRv6 TE and SRv6 BE hybrid mode.
4.     Mapping ACs to a VSI
5.     Configuring PEs to exchange BGP EVPN routes
6.     Specifying a source address for the outer IPv6 header of SRv6-encapsulated EVPN VPLS packets
7.     (Optional.) Enabling ARP flood suppression
8.     (Optional.) Configuring EVPN E-tree
9.     (Optional.) Maintaining the EVPN VPLS over SRv6 network
¡     Configuring SRv6 PW packet statistics
¡     Test the connectivity of an SRv6 PW
Creating a VSI
For more information about the commands in this section, see VPLS commands in MPLS Command Reference.
2.     Enable L2VPN.
l2vpn enable
By default, L2VPN is disabled.
3.     Create a VSI and enter VSI view.
vsi vsi-name
4.     Bring up the VSI.
By default, a VSI is not administratively down.
The BGP EVPN routes advertised by a PE carry the RD and route targets configured for the EVPN instance of the routes.
2.     Enter VSI view.
vsi vsi-name
For more information about this command, see EVPN Command Reference.
3.     Create an EVPN instance and enter VSI EVPN instance view.
evpn encapsulation srv6
4.     Configure an RD for the EVPN instance.
By default, no RD is configured for an EVPN instance.
5.     Configure route targets for the EVPN instance.
vpn-target { vpn-target&<1-8> } [ both | export-extcommunity | import-extcommunity ]
By default, an EVPN instance does not have route targets.
Parameter
export-extcommunity
Do not specify the same export targets for the EVPN instances of different VSIs.
Do not specify the same export targets for the EVPN instances created in different views (VSI view, VPN instance view, public instance view, and cross-connect group view).
As a best practice, the export targets configured for the following objects do not match the import targets configured for the EVPN instances created in cross-connect group view:
·     VPN instances.
·     The public instance.
·     EVPN instances created in VSI view, VPN instance view, and public instance view.
import-extcommunity
As a best practice, the import targets configured for the following objects do not match the export targets configured for the EVPN instances created in cross-connect group view:
·     VPN instances.
6.     (Optional.) Apply a tunnel policy to the EVPN instance.
tunnel-policy tunnel-policy-name
By default, no tunnel policy is applied to an EVPN instance.
2.     Enable SRv6 and enter SRv6 view.
segment-routing ipv6
3.     Configure a locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
4.     Configure the opcode portion.
¡     Configure End.DT2U SIDs.
opcode { opcode | hex hex-opcode } end-dt2u vsi vsi-name
¡     Configure End.DT2UL SIDs.
opcode { opcode | hex hex-opcode } end-dt2ul vsi vsi-name
¡     Configure End.DX2 SIDs.
opcode { opcode | hex hex-opcode } end-dx2 vsi vsi-name interface interface-type interface-number
¡     Configure End.DX2L SIDs.
opcode { opcode | hex hex-opcode } end-dx2l vsi vsi-name interface interface-type interface-number
¡     Configure End.DT2M SIDs.
opcode { opcode | hex hex-opcode } end-dt2m vsi vsi-name
Perform this task to allocate SRv6 SIDs from a locator to an EVPN instance.
You can perform this task in VSI view. The locator specified in VSI view applies to only the VSI. To apply the locator to other VSIs, specify the locator separately for each of the VISs.
2.     Enter VSI view.
vsi vsi-name
3.     Enter VSI EVPN instance view.
4.     Apply a locator to the EVPN instance.
segment-routing ipv6 locator locator-name [ dt2u-locator dt2u-locator-name ] [ dt2ul-locator dt2ul-locator-name ] [ dx2-locator dx2-locator-name ] [ dx2l-locator dx2l-locator-name ] [ auto-sid-disable ]
By default, no locator is applied to the EVPN instance on a VSI.
By default, when a PE receives a packet that includes an End.DT2U or End.DT2UL SID, it looks up the MAC address table of the SID's VSI to forward the packet.
To improve forwarding efficiency, use this feature. This feature enables the PE to allocate an End.DX2 or End.DX2L SID to each AC associated with a VSI and advertise the SIDs to remote PEs through MAC/IP advertisement routes. When the PE receives an SRv6 packet that includes a locally allocated End.DX2 or End.DX2L SID, it does not look up the MAC address table. The PE directly forwards the packet to the AC that is associated with the SID after removing the SRv6 encapsulation.
2.     Enter VSI view.
vsi vsi-name
4.     Configure unicast traffic forwarding based on End.DX2 and End.DX2L SIDs.
unicast-forwarding dx2-based
By default, unicast traffic is forwarded based on End.DT2U and End.DT2UL SIDs.
After a PE receives a customer packet destined for an End.DT2M, End.DT2U, End.DT2UL, End.DX2, or End.DX2L SID, it forwards the packet according to the route recursion mode.
·     SRv6 BE mode—In this mode, the PE first encapsulates the SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the packet.
·     SRv6 TE mode—In this mode, the PE first searches for a matching SRv6 TE policy based on the color attribute or next hop address of a matching route. Then, the PE adds an SRH to the packet. The SRH includes the End.DT2M, End.DT2U, End.DT2UL, End.DX2, or End.DX2L SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy. For more information, see "Configuring SRv6 TE policies."
·     SRv6 TE and SRv6 BE hybrid mode—In this mode, the PE preferentially uses the SRv6 TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
To use the SRv6 TE mode or the SRv6 TE and SRv6 BE hybrid mode, you must configure SRv6 TE policy traffic steering. For more information, see "Configuring SRv6 TE policy traffic steering."
2.     Enter VSI view.
vsi vsi-name
4.     Configure the route recursion mode.
segment-routing ipv6 { best-effort | traffic-engineering [ best-effort ] }
By default, a PE searches the IPv6 routing table based on the next hop of a matching EVPN route to forward traffic.
Color-based traffic steering takes precedence over tunnel policy-based traffic steering.
In an EVPN VPLS over SRv6 network, the PE searches for an SRv6 TE policy that has the same color and endpoint address as the color and next hop address of a BGP EVPN route. If a matching SRv6 TE policy exists, the device recurses the route to that SRv6 TE policy. When the device receives packets that match the route, it forwards the packets through the SRv6 TE policy.
Use one of the following methods to configure colors for BGP EVPN routes:
·     Routing policy-based coloring—Configure a routing policy to add the color extended community attribute to BGP EVPN routes or modify the existing color extended community attribute in BGP EVPN routes.
·     Default color—Specify a color as the default color for BGP EVPN routes. A BGP EVPN route uses the default color for color-based traffic steering if the route does not have the color extended community attribute or match a routing policy to obtain a color.
To use routing policy-based traffic steering, you need to add the color extended community to BGP EVPN routes by using routing policy or other methods. For information about the routing policy configuration, see Layer 3—IP Routing Configuration Guide.
Traffic steering is based on the greatest value among the color extended community attributes when the following conditions exist:
·     You specify the additive keyword for the apply extcommunity color clause in a routing policy, and specify the routing policy for the import route-policy command.
·     The received BGP EVPN routes carry the color extended community attribute.
Configuring a routing policy
2.     Enter routing policy node view.
For more information about this command, see routing policy commands in Layer 3—IP Routing Command Reference.
3.     Set the color extended community attribute for BGP routes.
apply extcommunity color color [ additive ]
By default, no color extended community attribute is set for BGP routes.
4.     Return to system view.
Applying the routing policy to an EVPN instance in VSI view
2.     Enter VSI view.
vsi vsi-name
4.     Apply the routing policy as an import policy to the EVPN instance.
By default, no import routing policy is applied to an EVPN instance. The EVPN instance does not filter received routes.
5.     Apply the routing policy as an export policy to the EVPN instance.
By default, no export routing policy is applied to an EVPN instance. The EVPN instance does not filter advertised routes.
Configuring the default color for BGP EVPN routes
2.     Enter VSI view.
vsi vsi-name
4.     Configure the default color for BGP EVPN routes.
default color color-value
By default, no default color is configured for BGP EVPN routes.
The device searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route and uses the paths in the SRv6 TE policy as public tunnels to forward private network packets. For more information about tunnel policies, see MPLS Configuration Guide.
Configuring a tunnel policy
2.     Create a tunnel policy and enter tunnel policy view.
tunnel-policy tunnel-policy-name [ default ]
3.     Configure the tunnel policy. Choose a minimum of one option:
¡     Bind tunnels to a destination IP address in a tunnel policy, so the tunnels can be used only for a specific VPN service.
binding-destination dest-ipv6-address { srv6-policy group srv6-policy-group-id | srv6-policy { name policy-name | end-point ipv6 ipv6-address color color-value } } [ ignore-destination-check ] [ down-switch ]
By default, a tunnel policy does not bind tunnels to a destination IP address.
¡     Specify an SRv6 TE policy as a preferred tunnel of the tunnel policy.
preferred-path srv6-policy { name srv6-policy-name | end-point ipv6 ipv6-address color color-value }
By default, no preferred tunnel is specified for a tunnel policy.
¡     Configuring SRv6 TE policy load sharing for the tunnel policy.
select-seq srv6-policy load-balance-number number
By default, no load sharing tunnel policy is configured.
For more information about the tunnel policy commands, see MPLS Command Reference.
Specifying the tunnel policy for an EVPN instance in VSI view
2.     Enter VSI view.
vsi vsi-name
4.     Specify a tunnel policy for the EVPN instance.
By default, no tunnel policy is specified for an EVPN instance.
To assign the customer traffic on a Layer 3 interface to a VSI, map that interface to the VSI. The VSI uses its MAC address table to forward the customer traffic.
For more information about the command in this task, see VPLS commands in MPLS Command Reference.
2.     Enter Layer 3 interface view.
3.     Map the Layer 3 interface to a VSI.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ]
By default, a Layer 3 interface is not mapped to a VSI.
For more information about BGP commands, see Layer 3—IP Routing Command Reference.
3.     Configure an IPv6 peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } as-number as-number
4.     Specify the source interface of TCP connections to a peer or peer group.
By default, BGP uses the IPv6 address of the output interface in the optimal route to the BGP peer or peer group as the source address of TCP connections to the peer or peer group.
5.     Enter BGP EVPN address family view.
address-family l2vpn evpn
6.     Enable BGP to exchange EVPN routes with an IPv6 peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } enable
By default, BGP cannot exchange EVPN routes with an IPv6 peer or peer group.
7.     Enable BGP to advertise SRv6-encapsulated EVPN routes to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6
By default, BGP advertises VXLAN-encapsulated EVPN routes to a peer or peer group.
To ensure correct VPN traffic forwarding in an EVPN VPLS over SRv6 network, you must specify a source address for the outer IPv6 header of SRv6-encapsulated EVPN VPLS packets.
You cannot specify a loopback address, link-local address, multicast address, or unspecified address as the source IPv6 address. You must specify an IPv6 address of the local device as the source IPv6 address, and make sure the IPv6 address has been advertised by a routing protocol. As a best practice, specify a loopback interface address of the local device as the source IPv6 address.
2.     Enter SRv6 view.
3.     Specify a source address for the outer IPv6 header of SRv6-encapsulated EVPN VPLS packets.
encapsulation source-address ipv6-address [ ip-ttl ttl-value ]
By default, no source address is specified for the outer IPv6 header of SRv6-encapsulated EVPN VPLS packets.
You can assign ESIs to a main interface and its subinterfaces.
·     If you assign an ESI to a subinterface, the subinterface-specific ESI and redundancy mode take precedence over those configured on the main interface.
·     If you do not assign an ESI to a subinterface, it inherits the ESI and redundancy mode of the main interface. In this scenario, the redundancy mode on the subinterface does not take effect.
An ESI uniquely identifies an ES. The links on interfaces or VSIs with the same ESI belong to the same ES. Traffic of the ES can be distributed among the links for load sharing.
2.     Enter interface view.
¡     Enter Layer 2 Ethernet interface view.
¡     Enter Layer 2 aggregate interface view.
¡     Enter Layer 3 Ethernet interface view.
¡     Enter Layer 3 aggregate interface view.
3.     Assign an ESI to the interface.
esi esi-id
By default, no ESI is assigned to an interface.
EVPN VPLS over SRv6 multihoming provides the single-active redundancy mode and all-active redundancy mode.
The redundant PEs at a dualhomed site each establish an EVPN PW to a remote PE. To use one PW as a backup of the other PW, use the single-active mode. To distribute traffic across the PWs for load sharing, use the all-active mode.
Setting the redundancy mode for an interface
3.     Set the redundancy mode.
evpn redundancy-mode { all-active | single-active }
By default, the all-active redundancy mode is used.
About local FRR for EVPN VPLS over SRv6
Local fast reroute (FRR) enables two PEs at a multihomed EVPN VPLS over SRv6 network site to set up a bypass SRv6 PW between them. This feature helps reduce the traffic loss caused by AC failure.
Restrictions and guidelines for local FRR configuration for EVPN VPLS over SRv6
On an EVPN instance, EVPN instance-specific local FRR configuration takes precedence over global local FRR configuration.
If you have executed the evpn frr local enable command on an EVPN instance, the undo evpn multihoming vpls-frr local command does not disable local FRR for the EVPN instance.
Perform this task on redundant PEs at a multihomed site.
Enabling local FRR globally
2.     Enable local FRR globally for EVPN VPLS over SRv6.
By default, local FRR is disabled globally for EVPN VPLS over SRv6.
Configuring local FRR on an EVPN instance
2.     Enter VSI view.
vsi vsi-name
4.     Configure local FRR on the EVPN instance.
evpn frr local { disable | enable }
By default, an EVPN instance uses the global local FRR configuration of EVPN VPLS over SRv6.
This task helps reduce the traffic loss caused by AC failure at a multihomed site that uses single-active redundancy mode in an EVPN VPLS over SRv6 network.
At a multihomed site that uses single-active redundancy mode in an EVPN VPLS over SRv6 network, CE 1 is dualhomed to PE 1 and PE 2 through a smart trunk. PE 1 is the primary PE, and PE 2 is the secondary PE. When the AC on PE 1 fails, PE 1 and PE 2 act as follows:
·     PE 1 withdraws advertised Ethernet auto-discovery routes.
·     PE 2 brings up its AC and advertises Ethernet auto-discovery routes to remote PEs.
The remote PEs switch traffic to the paths to PE 2 only after receiving the Ethernet auto-discovery routes advertised by PE 2, and traffic loss occurs during path switchover. To resolve this issue, enable VSIs to ignore the state of ACs on PE 2. This feature allows PE 2 to advertise Ethernet auto-discovery routes to remote PEs regardless of the state of ACs and speeds up path switchover when the AC on PE 1 fails.
Restrictions and guidelines for AC state ignore configuration
On a VSI, VSI-specific AC state ignore configuration takes precedence over global AC state ignore configuration.
Perform this task together with the feature of generating MAC address entries for received MAC/IP advertisement routes.
Enabling VSIs to ignore the state of ACs globally
2.     Enable VSIs to ignore the state of ACs globally.
l2vpn ignore-ac-state [ evpn-vpls ]
By default, VSIs does not ignore the state of ACs.
Configuring a VSI to ignore the state of ACs
2.     Enter VSI view.
vsi vsi-name
3.     Enable a VSI to ignore the state of ACs or disable a VSI from ignoring the state of ACs.
ignore-ac-state { enable | disable }
By default, a VSI uses the global AC state ignore configuration.
ARP flood suppression reduces ARP request broadcasts by enabling a PE to reply to ARP requests on behalf of VMs.
This feature snoops ARP requests, ARP responses, and BGP EVPN routes to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the PE replies to the request on behalf of the VM. If no match is found, the PE floods the request to both local and remote sites.
2.     Enter VSI view.
vsi vsi-name
3.     Enable ARP flood suppression.
arp suppression enable
By default, ARP flood suppression is disabled.
For more information about this command, see VXLAN Command Reference.
Use EVPN E-tree to isolate traffic between ACs based on the AC roles. This feature can better control AC access and improve security.
Inter-site EVPN E-tree controls communication between local ACs and remote ACs. You do not need to enable this feature if you want to control communication between local ACs.
2.     Enter VSI view.
vsi vsi-name
4.     Enable inter-site EVPN E-tree.
e-tree enable
By default, inter-site EVPN E-tree is disabled.
5.     Return to system view.
6.     Execute the following commands to configure a Layer 3 interface as a leaf AC:
a.     Enter Layer 3 interface view.
b.     Configure the AC as a leaf AC.
xconnect vsi vsi-name leaf
If you do not specify the leaf keyword for an AC, the AC acts as a root AC.
For more information about this command, see VPLS commands in MPLS Command Reference.
This task enables the packet statistics feature for all SRv6 PWs in a VSI EVPN isntance.
To display inbound packet statistics for all SRv6 PWs, use the display l2vpn statistics srv6-pw inbound command.
To display outbound packet statistics for each SRv6 PW, use the display l2vpn peer srv6 verbose command.
To clear SRv6 PW packet statistics, use the reset l2vpn statistics srv6-pw command.
2.     Enter VSI view.
vsi vsi-name
4.     Enable SRv6 PW packet statistics.
statistics enable
By default, SRv6 PW packet statistics is disabled.
In an EVPN VPLS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Perform this task to test the connectivity of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs.
The test process is as follows:
1.     The local PE constructs an MPLS echo request packet and searches for the SRv6 tunnel that matches the specified VSI. After obtaining the End.DT2U SID of the SRv6 tunnel, the PE adds a UDP header and an IPv6 header to the packet and forwards the packet to the remote PE.
2.     Upon receiving the MPLS echo request packet, the remote PE replies to the request packet.
3.     The local PE identifies the connectivity of the SRv6 PW based on whether it has received MPLS echo reply packets from the remote PE and the reply response time. In addition, the local PE outputs statistics about the ping operation.
To test the connectivity of an SRv6 PW from the local PE to the remote PE in an EVPN VPLS over SRv6 network, execute the following command in any view:
ping evpn vpls srv6 vsi vsi-name mac mac-address [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | -t time-out | -tc tc ] *
In an EVPN VPLS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Perform this task to trace the path of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs. This task helps you locate the failed nodes on the path.
1.     The local PE constructs an MPLS echo request packet and searches for the SRv6 tunnel that matches the specified VSI. After obtaining the End.DT2U SID of the SRv6 tunnel, the PE adds a UDP header and an IPv6 header to the packet and forwards the packet to the remote PE. In the IPv6 header, the value of the Hop limit field is set to 1.
2.     When the next node receives the packet, the value of the Hop limit field changes to 0. Then, the node sends an ICMPv6 timeout packet to the first node (the local PE).
3.     When the local PE receives the ICMPv6 timeout packet, it increases the value of the Hop limit field by one in the MPLS echo request packet. Then, the local PE forwards the request packet to the remote PE. The value of the Hop limit field is 2.
4.     The value of the Hop limit field decreases by one each time the request packet reaches a node. When the value of the Hop limit field decreases to 0, the node that receives the request packet responds to the first node with an ICMPv6 timeout packet. If the node that receives the request packet is the destination node, it sends an MPLS echo reply packet to the first node.
5.     The local PE repeats the previous step until one of the following conditions exist:
¡     The local PE has not received any reply packets before the reply timeout time expires for all request packets.
¡     The local PE receives a reply packet from the remote PE.
6.     The local PE identifies the connectivity of the SRv6 PW based on whether it has received MPLS echo reply packets from the remote PE and the reply response time. In addition, the local PE outputs statistics about the tracert operation.
To trace the path of an SRv6 PW from the local PE to the remote PE in an EVPN VPLS over SRv6 network, execute the following command in any view:
tracert evpn vpls srv6 vsi vsi-name mac mac-address [ -a source-ip | -h hop-limit | -r reply-mode | -t time-out | -tc tc ] *
·     Display BGP peer group information.
display bgp [ instance instance-name ] group l2vpn evpn [ group-name group-name ]
For more information about this command, see Layer 3—IP Routing Command Reference.
·     Display BGP peer or peer group information.
display bgp [ instance instance-name ] peer l2vpn evpn [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
·     Display information about BGP update groups.
display bgp [ instance instance-name ] update-group l2vpn evpn [ ipv4-address ]
·     Display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | imet | mac-ip } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
·     Display information about peers that are automatically discovered through BGP.
display evpn auto-discovery { mac-ip [ srv6 ] [ peer ip-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
·     Display EVPN ES information.
display evpn es { local [ count | [ vsi vsi-name ] [ verbose ] ] | remote [ vsi vsi-name ] [ nexthop next-hop ] [ verbose ]}
·     Display VSI information.
display l2vpn vsi [ evpn-srv6 | name vsi-name ] [ count | verbose ]
·     Display L2VPN SRv6 information.
display l2vpn peer srv6 [ vsi vsi-name ] [ state-machine | verbose ]
·     Display PW class information.
display l2vpn pw-class [ class-name ] [ verbose ]
For more information about this command, see MPLS Command Reference.
·     Display EVPN MAC address entries.
display evpn route mac [ srv6 ] [ local | remote ] [ vsi vsi-name ] [ mac-address mac-address ] [ count ]
·     Display information about L2VPN MAC address entries.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
·     Display EVPN ARP flood suppression entries.
display evpn route arp suppression [ srv6 ] [ local | remote ] [ vsi vsi-name ] [ ip ip-address ] [ count ]
·     Display EVPN VSI forwarding entries.
display l2vpn forwarding evpn [ vsi [ name vsi-name ] [ verbose ] ] [ slot slot-number ]
·     Display site-facing interfaces excluded from traffic forwarding by split horizon.
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | tunnel tunnel-number } [ slot slot-number ]
·     Display L2VPN SRv6 forwarding entries.
display l2vpn forwarding srv6 [ vsi vsi-name ] [ slot slot-number ] [ verbose ]
To display inbound packet statistics for SRv6 PWs, execute the following command in any view:
display l2vpn statistics srv6-pw inbound [ vsi vsi-name ]
To clear SRv6 PW packet statistics, execute the following command in user view:
reset l2vpn statistics srv6-pw [ vsi vsi-name [ peer ipv6-address ] ]
As shown in Figure 5, set up an SRv6 tunnel between PE 1 and PE 2 for users in site 1 and site 2 to communicate through EVPN VPLS over the IPv6 backbone network.
Figure 5 Network diagram
Device
IP address
Device
IP address
CE 1
GE0/0/1
10::1/64
P
Loop0
3::3/128
PE 1
Loop0
1::1/128
GE0/0/1
20::2/64
GE0/0/1
GE0/0/2
30::1/64
GE0/0/2
20::1/64
PE 2
Loop0
2::2/128
CE 2
GE0/0/1
10::2/64
GE0/0/1
GE0/0/2
30::2/64
1.     Configure CE 1.
<CE1> system-view
[CE1] interface gigabitethernet 0/0/1
[CE1-GigabitEthernet0/0/1] ipv6 address 10::1 64
[CE1-GigabitEthernet0/0/1] quit
2.     Configure PE 1:
# Run OSPFv3 on PE 1 and use OSPFv3 to advertise SIDs.
<PE1> system-view
[PE1] ospfv3
[PE1-ospfv3-1] router-id 1.1.1.1
[PE1-ospfv3-1] segment-routing ipv6 locator aaa
[PE1-ospfv3-1] area 0.0.0.0
[PE1-ospfv3-1-area-0.0.0.0] quit
[PE1-ospfv3-1] quit
# Configure interface Loopback 0.
[PE1] interface loopback 0
[PE1-LoopBack0] ipv6 address 1::1 128
[PE1-LoopBack0] ospfv3 1 area 0
[PE1-LoopBack0] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure GigabitEthernet 0/0/2, the interface connected to P.
[PE1] interface gigabitethernet 0/0/2
[PE1-GigabitEthernet0/0/2] ipv6 address 20::1 64
[PE1-GigabitEthernet0/0/2] ospfv3 1 area 0
[PE1-GigabitEthernet0/0/2] undo shutdown
[PE1-GigabitEthernet0/0/2] quit
# Configure PE 1 to establish IBGP neighbor relationship with PE 2 and enable BGP EVPN to advertise routes in SRv6 encapsulation to PE 2.
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default] peer 2::2 as-number 100
[PE1-bgp-default] peer 2::2 connect-interface loopback 0
[PE1-bgp-default] address-family l2vpn evpn
[PE1-bgp-default-evpn] peer 2::2 enable
[PE1-bgp-default-evpn] peer 2::2 advertise encap-type srv6
[PE1-bgp-default-evpn] quit
[PE1-bgp-default] quit
# Create VSI vpna, create an EVPN instance for it, and enable SRv6 encapsulation. Configure an RD and route targets for the EVPN instance, enable the SID-route-recursion feature, and apply a locator to the EVPN instance.
[PE1] vsi vpna
[PE1-vsi-vpna] evpn encapsulation srv6
[PE1-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[PE1-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE1-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE1-vsi-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE1-vsi-vpna-evpn-srv6] segment-routing ipv6 locator aaa
[PE1-vsi-vpna-evpn-srv6] quit
# Map GigabitEthernet 0/0/1 to the VSI.
[PE1] interface gigabitethernet 0/0/1
[PE1-GigabitEthernet0/0/1] xconnect vsi vpna
[PE1-GigabitEthernet0/0/1] quit
# Specify a source IP address for the outer IPv6 header of SRv6-encapsulated packets, and configure a locator to apply for End.DT2U SIDs and End.DT2M SIDs.
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 100:: 64 static 32
[PE1-segment-routing-ipv6-locator-aaa] quit
[PE1-segment-routing-ipv6] quit
3.     Configure PE 2:
# Run OSPFv3 on PE 2 and use OSPFv3 to advertise SIDs.
<PE2> system-view
[PE2] ospfv3
[PE2-ospfv3-1] router-id 2.2.2.2
[PE2-ospfv3-1] segment-routing ipv6 locator aaa
[PE2-ospfv3-1] area 0.0.0.0
[PE2-ospfv3-1-area-0.0.0.0] quit
[PE2-ospfv3-1] quit
[PE2] interface loopback 0
[PE2-LoopBack0] ipv6 address 2::2 128
[PE2-LoopBack0] ospfv3 1 area 0
[PE2-LoopBack0] quit
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] interface gigabitethernet 0/0/2
[PE2-GigabitEthernet0/0/2] ipv6 address 30::2 64
[PE2-GigabitEthernet0/0/2] ospfv3 1 area 0.0.0.0
[PE2-GigabitEthernet0/0/2] undo shutdown
[PE2-GigabitEthernet0/0/2] quit
# Configure PE 2 to establish IBGP neighbor relationship with PE 1, and enable BGP EVPN to advertise routes in SRv6 encapsulation to PE 1.
[PE2] bgp 100
[PE2-bgp-default] router-id 2.2.2.2
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn evpn
[PE2-bgp-default-evpn] peer 1::1 enable
[PE2-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE2-bgp-default-evpn] quit
[PE2-bgp-default] quit
[PE2] vsi vpna
[PE2-vsi-vpna] evpn encapsulation srv6
[PE2-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[PE2-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE2-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE2-vsi-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE2-vsi-vpna-evpn-srv6] segment-routing ipv6 locator aaa
[PE2-vsi-vpna-evpn-srv6] quit
[PE2] interface gigabitethernet 0/0/1
[PE2-GigabitEthernet0/0/1] xconnect vsi vpna
[PE2-GigabitEthernet0/0/1] quit
[PE2] segment-routing ipv6
[PE2-segment-routing-ipv6] encapsulation source-address 2::2
[PE2-segment-routing-ipv6] locator aaa ipv6-prefix 200:: 64 static 32
[PE2-segment-routing-ipv6-locator-aaa] quit
[PE2-segment-routing-ipv6] quit
4.     Configure P:
# Run OSPFv3 on P.
<P> system-view
[P] ospfv3
[P-ospfv3-1] router-id 3.3.3.3
[P-ospfv3-1] area 0.0.0.0
[P-ospfv3-1-area-0.0.0.0] quit
[P-ospfv3-1] quit
# Configure IPv6 addresses for interfaces and run OSPFv3 on the interfaces.
[P] interface loopback 0
[P-LoopBack0] ipv6 address 3::3 128
[P-LoopBack0] ospfv3 1 area 0
[P-LoopBack0] quit
[P] interface gigabitethernet 0/0/1
[P-GigabitEthernet0/0/1] ipv6 address 20::2 64
[P-GigabitEthernet0/0/1] ospfv3 1 area 0
[P-GigabitEthernet0/0/1] quit
[P] interface gigabitethernet 0/0/2
[P-GigabitEthernet0/0/2] ipv6 address 30::1 64
[P-GigabitEthernet0/0/2] ospfv3 1 area 0
[P-GigabitEthernet0/0/2] quit
5.     Configure CE 2.
<CE2> system-view
[CE2] interface gigabitethernet 0/0/1
[CE2-GigabitEthernet0/0/1] ipv6 address 10::2 64
[CE2-GigabitEthernet0/0/1] quit
# Verify that an SRv6 tunnel has been established between PE 1 and PE 2.
[PE1] display l2vpn peer srv6
Total number of SRv6 Tunnels: 1
1 up, 0 blocked, 0 down
VSI Name: vpna
   Peer            : 2::2
   Flag            : Main
   State           : Up
# Verify that the SRv6 forwarding information on PE 1 is correct.
[PE1] display l2vpn forwarding srv6
Total number of VSIs: 1
Total number of SRv6 tunnels: 1, 1 up, 0 blocked, 0 down
VSI Name : vpna
Link ID             : 0x9000000   Type: BE    State: Up
In SID   : 100::1:0:1
Out SID  : 200::1:0:0
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
As shown in Figure 6, CE 1 is dual-homed to PE 1 and PE 2 through static link aggregation. Configure EVPN VPLS over SRv6 for dual-homed site 1 and single-homed site 2 to communicate over the IPv6 backbone network through an SRv6 tunnel.
Figure 6 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
1::1/128
CE 1
RAGG1
100::1/64
GE0/0/1
CE 2
GE0/0/1
100::2/64
GE0/0/2
10::1/64
PE 3
Loop0
3::3/128
GE0/0/3
20::1/64
GE0/0/1
PE 2
Loop0
2::2/128
GE0/0/2
10::3/64
GE0/0/1
GE0/0/3
30::3/64
GE0/0/2
30::2/64
GE0/0/3
20::2/64
1.     Configure CE 1:
# Create static Layer 3 aggregate interface 1 and assign it an IPv6 address.
<CE1> system-view
[CE1] interface route-aggregation 1
[CE1-Route-Aggregation1] ipv6 address 100::1 64
[CE1-Route-Aggregation1] quit
# Assign GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2 to aggregation group 1.
[CE1-GigabitEthernet0/0/1] port link-aggregation group 1
[CE1] interface gigabitethernet 0/0/2
[CE1-GigabitEthernet0/0/2] port link-aggregation group 1
[CE1-GigabitEthernet0/0/2] quit
2.     Configure PE 1:
# Run OSPFv3 on PE 1.
<PE1> system-view
[PE1] ospfv3
[PE1-ospfv3-1] quit
# Enable L2VPN.
[PE1] l2vpn enable
# Configure GigabitEthernet 0/0/2, the interface connected to PE 3.
[PE1-GigabitEthernet0/0/2] ipv6 address 10::1/64
# Configure GigabitEthernet 0/0/3, the interface connected to PE 2.
[PE1] interface gigabitethernet 0/0/3
[PE1-GigabitEthernet0/0/3] ipv6 address 20::1/64
[PE1-GigabitEthernet0/0/3] ospfv3 1 area 0
[PE1-GigabitEthernet0/0/3] undo shutdown
[PE1-GigabitEthernet0/0/3] quit
# Configure PE 1 to establish IBGP neighbor relationships with PE 2 and PE 3, and enable BGP EVPN to advertise routes in SRv6 encapsulation to PE 2 and PE 3.
[PE1] bgp 100
[PE1-bgp-default] peer 3::3 as-number 100
[PE1-bgp-default] peer 3::3 connect-interface loopback 0
[PE1-bgp-default-evpn] peer 3::3 enable
[PE1-bgp-default-evpn] peer 3::3 advertise encap-type srv6
# Create VSI vpna, create an EVPN instance for it, and enable SRv6 encapsulation. Configure an RD and route targets for the EVPN instance, enable SRv6 BE route recursion mode, and apply a locator to the EVPN instance.
[PE1] vsi vpna
# Assign an ESI to site-facing interface GigabitEthernet 0/0/1, set the redundancy mode of the interface to all-active, and map the interface to VSI vpna.
[PE1-GigabitEthernet0/0/1] esi 1.1.1.1.1
[PE1-GigabitEthernet0/0/1] evpn redundancy-mode all-active
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 111:: 64 static 32
3.     Configure PE 2:
# Run OSPFv3 on PE 2.
<PE2> system-view
[PE2] ospfv3
[PE2-ospfv3-1] quit
# Enable L2VPN.
[PE2] l2vpn enable
# Configure GigabitEthernet 0/0/3, the interface connected to PE 1.
[PE2] interface gigabitethernet 0/0/3
[PE2-GigabitEthernet0/0/3] ipv6 address 20::2 64
[PE2-GigabitEthernet0/0/3] ospfv3 1 area 0
[PE2-GigabitEthernet0/0/3] undo shutdown
[PE2-GigabitEthernet0/0/3] quit
# ConfigureGigabitEthernet 0/0/2, the interface connected to PE 3.
# Configure PE 2 to establish IBGP neighbor relationships with PE 1 and PE 3, and enable BGP EVPN to advertise routes in SRv6 encapsulation to PE 1 and PE 3.
[PE2] bgp 100
[PE2-bgp-default] peer 3::3 as-number 100
[PE2-bgp-default] peer 3::3 connect-interface loopback 0
[PE2-bgp-default-evpn] peer 3::3 enable
[PE2-bgp-default-evpn] peer 3::3 advertise encap-type srv6
[PE2] vsi vpna
[PE2-GigabitEthernet0/0/1] esi 1.1.1.1.1
[PE2-GigabitEthernet0/0/1] evpn redundancy-mode all-active
[PE2-segment-routing-ipv6] locator aaa ipv6-prefix 222:: 64 static 32
4.     Configure PE 3:
# Run OSPFv3 on PE 3.
<PE3> system-view
[PE3] ospfv3
[PE3-ospfv3-1] router-id 3.3.3.3
[PE3-ospfv3-1] segment-routing ipv6 locator aaa
[PE3-ospfv3-1] area 0
[PE3-ospfv3-1-area-0.0.0.0] quit
[PE3-ospfv3-1] quit
[PE3] interface loopback 0
[PE3-LoopBack0] ipv6 address 3::3 128
[PE3-LoopBack0] ospfv3 1 area 0
[PE3-LoopBack0] quit
# Enable L2VPN.
[PE3] l2vpn enable
# Configure GigabitEthernet 0/0/2, the interface connected to PE 1.
[PE3] interface gigabitethernet 0/0/2
[PE3-GigabitEthernet0/0/2] ipv6 address 10::3 64
[PE3-GigabitEthernet0/0/2] ospfv3 1 area 0
[PE3-GigabitEthernet0/0/2] undo shutdown
[PE3-GigabitEthernet0/0/2] quit
[PE3] interface gigabitethernet 0/0/3
[PE3-GigabitEthernet0/0/3] ipv6 address 30::3 64
[PE3-GigabitEthernet0/0/3] ospfv3 1 area 0
[PE3-GigabitEthernet0/0/3] undo shutdown
[PE3-GigabitEthernet0/0/3] quit
# Configure PE 3 to establish IBGP neighbor relationships with PE 1 and PE 2, and enable BGP EVPN to advertise routes in SRv6 encapsulation to PE 1 and PE 2.
[PE3] bgp 100
[PE3-bgp-default] router-id 3.3.3.3
[PE3-bgp-default] peer 1::1 as-number 100
[PE3-bgp-default] peer 1::1 connect-interface loopback 0
[PE3-bgp-default] peer 2::2 as-number 100
[PE3-bgp-default] peer 2::2 connect-interface loopback 0
[PE3-bgp-default] address-family l2vpn evpn
[PE3-bgp-default-evpn] peer 1::1 enable
[PE3-bgp-default-evpn] peer 2::2 enable
[PE3-bgp-default-evpn] peer 1::1 advertise encap-type srv6
[PE3-bgp-default-evpn] peer 2::2 advertise encap-type srv6
[PE3-bgp-default-evpn] quit
[PE3-bgp-default] quit
[PE3] vsi vpna
[PE3-vsi-vpna] evpn encapsulation srv6
[PE3-vsi-vpna-evpn-srv6] route-distinguisher 1:1
[PE3-vsi-vpna-evpn-srv6] vpn-target 1:1 export-extcommunity
[PE3-vsi-vpna-evpn-srv6] vpn-target 1:1 import-extcommunity
[PE3-vsi-vpna-evpn-srv6] segment-routing ipv6 best-effort
[PE3-vsi-vpna-evpn-srv6] segment-routing ipv6 locator aaa
[PE3-vsi-vpna-evpn-srv6] quit
[PE3] interface gigabitethernet 0/0/1
[PE3-GigabitEthernet0/0/1] xconnect vsi vpna
[PE3-GigabitEthernet0/0/1] quit
[PE3] segment-routing ipv6
[PE3-segment-routing-ipv6] encapsulation source-address 3::3
[PE3-segment-routing-ipv6] locator aaa ipv6-prefix 333:: 64 static 32
[PE3-segment-routing-ipv6-locator-aaa] quit
[PE3-segment-routing-ipv6] quit
5.     Configure CE 2.
<CE2> system-view
[CE2-GigabitEthernet0/0/1] ipv6 address 100::2 64
# Verify that PE 3 has established SRv6 tunnels to PE 1 and PE 2. The SRv6 tunnels are ECMP tunnels that can load share traffi.
[PE3] display l2vpn peer srv6
Total number of SRv6 Tunnels: 2
2 up, 0 blocked, 0 down
VSI Name: vpna
   Peer            : 1::1
   Flag            : Main
   State           : Up
   Peer            : 2::2
   Flag            : Main
   State           : Up
# Verify that the SRv6 forwarding information on PE 3 is correct.
[PE3] display l2vpn forwarding srv6
Total number of SRv6 tunnels: 2, 2 up, 0 blocked, 0 down
VSI Name : vpna
In SID   : 333::1:0:4
Out SID  : 111::1:0:4
Link ID             : 0x9000001   Type: BE    State: Up
In SID   : 333::1:0:4
Out SID  : 222::1:0:3
# Verify that CE 1 and CE 2 can ping each other when the PW on PE 1 or PE 2 fails. (Details not shown.)
As shown in Figure 7, CE 1 is dual-homed to PE 1 and PE 2 through S-Trunk. Configure EVPN VPLS over SRv6 for dual-homed site 1 and single-homed site 2 to communicate over the IPv6 backbone network through an SRv6 tunnel.
Figure 7 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
1::1/128
PE 2
Loop0
2::2/128
GE0/0/1
N/A
GE0/0/1
N/A
GE0/0/2
10::1/64
GE0/0/2
30::2/64
GE0/0/3
20::1/64
GE0/0/3
20::2/64
GE0/0/3
10.1.2.1/24
GE0/0/3
10.1.2.2/24
PE 3
Loop0
3::3/128
CE 1
RAGG1
100::1/64
GE0/0/1
N/A
CE 2
GE0/0/1
100::2/64
GE0/0/2
10::3/64
GE0/0/3
30::3/64
1.     Configure CE 1:
# Create dynamic Layer 3 aggregate interface 1 and assign it an IPv6 address and prefix.
<CE1> system-view
[CE1-Route-Aggregation1] link-aggregation mode dynamic
2.     Configure PE 1:
<PE1> system-view
[PE1] ospfv3
[PE1-ospfv3-1] quit
# Enable L2VPN.
[PE1] l2vpn enable
[PE1] bgp 100
[PE1] vsi vpna
# Configure S-Trunk for CE 1 to be dual-homed to PE 1 and PE 2.
[PE1] lacp system-priority 10
[PE1] lacp system-mac 1-1-1
[PE1] lacp system-number 1
[PE1] s-trunk id 1
[PE1-s-trunk1] s-trunk ip destination 10.1.2.2 source 10.1.2.1
[PE1-s-trunk1] quit
[PE1] interface route-aggregation 1
[PE1-Route-Aggregation1] link-aggregation mode dynamic
[PE1-Route-Aggregation1] s-trunk 1
[PE1-Route-Aggregation1] s-trunk port-role primary
[PE1-Route-Aggregation1] quit
[PE1-GigabitEthernet0/0/1] port link-aggregation group 1
# Assign an ESI to site-facing interface Route-Aggregation 1, set the redundancy mode of the interface to all-active, and map the interface to VSI vpna.
[PE1-Route-Aggregation1] esi 1.1.1.1.1
[PE1-Route-Aggregation1] evpn redundancy-mode all-active
[PE1-Route-Aggregation1] xconnect vsi vpna
3.     Configure PE 2:
<PE2> system-view
[PE2] ospfv3
[PE2-ospfv3-1] quit
# Enable L2VPN.
[PE2] l2vpn enable
[PE2] bgp 100
[PE2] vsi vpna
[PE2] lacp system-priority 10
[PE2] lacp system-mac 1-1-1
[PE2] lacp system-number 2
[PE2] s-trunk id 1
[PE2-s-trunk1] s-trunk ip destination 10.1.2.1 source 10.1.2.2
[PE2-s-trunk1] quit
[PE2] interface route-aggregation 1
[PE2-Route-Aggregation1] link-aggregation mode dynamic
[PE2-Route-Aggregation1] s-trunk 1
[PE2-Route-Aggregation1] s-trunk port-role primary
[PE2-Route-Aggregation1] quit
[PE2-GigabitEthernet0/0/1] port link-aggregation group 1
[PE2-Route-Aggregation1] esi 1.1.1.1.1
[PE2-Route-Aggregation1] evpn redundancy-mode all-active
[PE2-Route-Aggregation1] xconnect vsi vpna
4.     Configure PE 3:
<PE3> system-view
[PE3] ospfv3
[PE3-ospfv3-1] quit
# Enable L2VPN.
[PE3] l2vpn enable
[PE3] bgp 100
[PE3] vsi vpna
5.     Configure CE 2.
<CE2> system-view
VSI Name: vpna
   Peer            : 1::1
   Flag            : Main
   State           : Up
   Peer            : 2::2
   Flag            : Main
   State           : Up
VSI Name : vpna
In SID   : 333::1:0:4
In SID   : 333::1:0:4
Distributed SRv6 gateways provide Layer 3 forwarding for traffic in different subnets across sites and provide Layer 3 connectivity to the external network.
As shown in Figure 8, each site's PE acts as a distributed SRv6 gateway to perform Layer 3 forwarding for the traffic of the local site. A PE acts as a border gateway to the external Layer 3 network. On all the SRv6 gateways and border gateway, you must create VSI interfaces as gateway interfaces. The same VSI interface on multiple SRv6 gateways must be assigned the same IP address. This IP address will be used as the gateway address for users in the EVPN VPLS over SRv6 network.
Figure 8 Distributed SRv6 gateway deployment
A distributed SRv6 gateway allocates an End.DT4 or End.DT46 SID to a MAC/IP advertisement route to identify the VPN instance to which the packets that match the route belong.
As shown in Figure 9, the ARP learning and BGP EVPN route advertisement process is as follows:
1.     CE 2 sends an ARP request to obtain the MAC address of the gateway (a VSI interface on PE 2).
2.     When PE 2 receives the ARP request from an AC, it identifies the VSI of the AC, and searches for the VSI interface associated with the VSI.
3.     PE 2 relies to the ARP request with the MAC address of the VSI interface. At the same time, PE 2 learns the ARP information of CE 2 to the VPN instance bound to the VSI interface and generates a FIB entry for the ARP information.
4.     PE 2 advertises the ARP information to PE 1 in a MAC/IP advertisement route. The route includes the End.DT4 or End.DT46 SID allocated by PE 2 to the VPN instance.
5.     PE 1 matches the route targets in the route with the local import route targets for a matching VPN instance. If a matching VPN instance is found, PE 1 learns the ARP information to the ARP table of the matching VPN instance and generates a FIB entry for the ARP information. The FIB entry includes the End.DT4 or End.DT46 SID allocated by PE 2.
In this process, both PE 1 and PE 2 have learned the ARP information of CE 2 and CE 2 has learned the MAC address of the gateway. In the same way, PE 1 and PE 2 can learn the ARP information of CE 1 and CE 1 can learn the MAC address of the gateway.
Figure 9 Control plane working mechanisms
A distributed SRv6 gateway supports SRv6 BE mode, SRv6 TE mode, and SRv6 TE and SRv6 BE hybrid mode.
The following information uses the SRv6 BE mode as an example to illustrate the forwarding process for traffic from CE 1 to CE 2:
1.     CE 1 sends a packet destined for CE 2 to gateway PE 1. The destination MAC address of the packet is the MAC address of a VSI interface on PE 1.
2.     When PE 1 receives the packet from an AC, it finds that the destination MAC address of the packet is the MAC address of a local VSI interface. Then, PE 1 performs the following operations:
a.     Removes the frame header of the packet.
b.     Searches for a matching entry in the FIB of the VPN instance bound to the VSI interface based on the destination IP address of the packet. The matching entry contains the End.DT4 or End.DT46 SID allocated by PE 2 to the VPN instance.
3.     PE 1 encapsulates an outer IPv6 header to the packet and forwards the packet to PE 2.
¡     The destination IPv6 address of the outer IPv6 header is the End.DT4 or End.DT46 SID.
¡     The source IPv6 address of the outer IPv6 header is manually configured.
4.     When PE 2 receives the packet, it searches the FIB of the VPN instance identified by the End.DT4 or End.DT46 SID for the output interface. The output interface is an AC. Then, PE 2 removes the outer IPv6 header from the packet andforwards the packet out of the AC to CE 2.
Make sure a VSI interface uses the same MAC address to provide service on distributed SRv6 gateways connected to IPv4 sites.
If both ARP flood suppression and local proxy ARP are enabled on a distributed SRv6 gateway, only local proxy ARP takes effect. As a best practice, do not use these features together on distributed SRv6 gateways.
To configure a distributed SRv6 gateway:
1.     Creating a VSI
2.     Configuring an EVPN instance
3.     Configuring SRv6 SIDs
4.     Configuring a VSI interface as a distributed SRv6 gateway
5.     Configuring packet forwarding methods
This task is required when the SRv6 TE or SRv6 TE and SRv6 BE hybrid mode is used.
6.     Mapping ACs to a VSI
7.     Configuring PEs to exchange BGP EVPN routes
8.     Specifying a source address for the IPv6 packets encapsulated by a distributed SRv6 gateway
9.     Configuring BGP EVPN route redistribution and advertisement
10.     Managing remote MAC address entries and remote ARP learning
For a VM that requires access to the external network at Layer 3, specify the VM's VSI interface on the border gateway as the next hop by using one of the following methods:
·     Configure a static route.
·     Configure a routing policy, and apply the policy by using the apply default-next-hop or apply next-hop command. For more information about configuring routing policies, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
Creating a VSI
For more information about the commands in this task, see VPLS commands in MPLS Command Reference.
2.     Enable L2VPN.
l2vpn enable
vsi vsi-name
2.     Enter VSI view.
vsi vsi-name
3.     Create an EVPN instance and enter EVPN instance view.
4.     Specify an RD for the EVPN instance.
By default, no RD is specified for an EVPN instance.
Parameter
export-extcommunity
Do not specify the same export targets for different EVPN instances.
·     VPN instances.
import-extcommunity
·     VPN instances.
For more information about the commands in this task, see SRv6 commands in Segment Routing Command Reference.
¡     Configure End.DT4 SIDs.
opcode opcode end-dt4 [ vpn-instance vpn-instance-name [ evpn ] ]
The specified VPN instance must exist. You cannot configure the same End.DT4 SID for different VPN instances.
¡     Configure End.DT46 SIDs.
opcode opcode end-dt46 [ vpn-instance vpn-instance-name [ evpn ] ]
The specified VPN instance must exist. You cannot configure the same End.DT46 SID for different VPN instances.
To save Layer 3 interface resources on a distributed SRv6 gateway, multiple EVPN VPLS networks can share one VSI interface. You can assign multiple IPv4 addresses to the VSI interface for the EVPN VPLS networks to use as gateway addresses.
When multiple EVPN VPLS networks share a VSI interface, you must specify the subnet of each VSI for the VSI interface to identify the VSI of a packet. The subnets must be unique.
2.     Create a VSI interface and enter VSI interface view.
interface vsi-interface vsi-interface-id
3.     Assign an IP address to the VSI interface.
By default, no IP address is assigned to a VSI interface.
4.     Assign a MAC address to the VSI interface.
By default, no MAC address is configured for a VSI interface.
To ensure correct forwarding after VM migration, you must assign the same MAC address to the VSI interfaces of an EVPN VPLS network on all distributed SRv6 gateways.
5.     Specify the VSI interface as a distributed gateway.
distributed-gateway local
By default, a VSI interface is not a distributed gateway.
6.     (Optional.) Enable local proxy ARP.
local-proxy-arp enable [ ip-range startIP to endIP ]
By default, local proxy ARP is disabled.
For more information about this command, see proxy ARP commands in Layer 3—IP Services Command Reference.
7.     Return to system view.
8.     Enter VSI view.
vsi vsi-name
9.     Specify the VSI interface as the gateway interface for the VSI.
gateway vsi-interface vsi-interface-id
By default, no gateway interface is specified for a VSI.
10.     Assign a subnet to the VSI.
gateway subnet ipv4-address wildcard-mask
By default, no subnet exists on a VSI.
After a PE receives a customer packet destined for an End.DT4 or End.DT46 SID, it forwards the packet according to the route recursion mode.
·     SRv6 TE mode—In this mode, the PE first searches for a matching SRv6 TE policy based on the color attribute or next hop address of a matching route. Then, the PE adds an SRH to the packet. The SRH includes the End.DT4 or End.DT46 SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy.
Prerequsites
2.     Enter VSI view.
vsi vsi-name
3.     Enter EVPN instance view.
Restrictions and guidelines for SRv6 TE policy traffic steering
Configuring color-based traffic steering
The device searches for an SRv6 TE policy that has the same color and endpoint address as the color and next hop address of a BGP EVPN route. If a matching SRv6 TE policy exists, the device recurses the route to that SRv6 TE policy. When the device receives packets that match the route, it forwards the packets through the SRv6 TE policy.
To use color-based traffic steering, you need to add the color extended community to BGP EVPN routes by using routing policy or other methods. For information about the routing policy configuration, see Layer 3—IP Routing Configuration Guide.
5.     Enter VSI view.
vsi vsi-name
6.     Enter VSI EVPN instance view.
7.     Apply the routing policy as an import policy to the EVPN instance.
8.     Apply the routing policy as an export policy to the EVPN instance.
Configuring tunnel policy-based traffic steering
The device searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route and uses the paths in the policy as public tunnels to forward private network packets. For more information about tunnel policies, see MPLS Configuration Guide.
Creating a tunnel policy
Specifying a tunnel policy for an EVPN instance
2.     Enter VSI view.
vsi vsi-name
Mapping a Layer 3 interface to a VSI
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
By default, BGP uses the IPv6 address of the output interface in the optimal route to a BGP peer or peer group as the source address of TCP connections to the peer or peer group.
To ensure that a distributed SRv6 gateway can forward data traffic, you must specify s source address for the outer IPv6 header encapsulated by the distributed SRv6 gateway.
You can specify any IPv6 address as the source address. As a best practice, specify an unused IPv6 address.
2.     Enter SRv6 view.
3.     Specify a source address for the IPv6 packets encapsulated by the distributed SRv6 gateway.
By default, no source address is specified for the IPv6 packets encapsulated by a distributed SRv6 gateway.
Redistributing MAC/IP advertisement routes into BGP unicast routing tables
This task enables the device to redistribute received MAC/IP advertisement routes that contain ARP information into a BGP unicast routing table.
·     If you perform this task for the BGP IPv4 unicast address family, the device will redistribute the routes into the BGP IPv4 unicast routing table. In addition, the device will advertise the routes to the local site.
·     If you perform this task for the BGP-VPN IPv4 unicast address family, the device will redistribute the routes into the BGP-VPN IPv4 unicast routing table of the corresponding VPN instance. To advertise the routes to the local site, you must configure the advertise l2vpn evpn command.
3.     Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
¡     Enter BGP IPv4 unicast address family view.
address-family ipv4
¡     Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view.
address-family ipv4
4.     Redistribute MAC/IP advertisement routes that contain ARP information into the BGP-VPN IPv4 unicast routing table and allow advertisement of these routes.
import evpn mac-ip
By default, MAC/IP advertisement routes that contain ARP information can be redistributed into the BGP IPv4 unicast routing table in an SRv6 network, but advertisement of these routes is not allowed.
Enabling BGP EVPN route advertisement to the local site
This feature enables the device to advertise BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance.
3.     Enter BGP-VPN instance view.
4.     Enter BGP-VPN IPv4 unicast address family view.
5.     Enable BGP EVPN route advertisement to the local site.
By default, BGP EVPN route advertisement to the local site is enabled.
Disabling MAC address advertisement
The MAC information and ARP information advertised by the PE overlap. To avoid duplication, disable MAC address advertisement and withdraw the MAC addresses advertised to remote PEs.
2.     Enter VSI view.
vsi vsi-name
4.     Disable MAC address advertisement and withdraw advertised MAC addresses.
mac-advertising disable
By default, MAC address advertisement is enabled.
Disabling learning of MAC addresses from ARP information
The MAC information and ARP information advertised by a remote PE overlap. To avoid duplication, disable the learning of MAC addresses from ARP information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
2.     Enter VSI view.
vsi vsi-name
4.     Disable the EVPN instance from learning MAC addresses from ARP information.
arp mac-learning disable
By default, an EVPN instance learns MAC addresses from ARP information.
Verifying and maintaining distributed SRv6 gateways
·     Display EVPN ARP information.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
·     Display EVPN routing table information.
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
·     Display IPv4 routing table information.
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
Distributed SRv6 gateway configuration examples
Example: Configuring distributed SRv6 gateways
As shown in Figure 10, PE 1 and PE 2 are distributed SRv6 gateways in the EVPN VPLS over SRv6 network. They forward Layer 3 traffic in different subnets across sistes.
Figure 10 Network diagram
Device
IP address
Device
IP address
PE 1
Loop0
1::1/128
PE 2
Loop0
2::2/128
VSI-int1
100.1.1.1/24
GE0/0/1
GE0/0/1
GE0/0/2
30::2/64
GE0/0/2
20::1/64
VSI-int1
100.1.2.1/24
P
Loop0
3::3/128
CE 1
GE0/0/1
100.1.1.10/24
GE0/0/1
20::2/64
CE 2
GE0/0/1
100.1.2.20/24
GE0/0/2
30::1/64
1.     Configure IP address and unicast routing settings:
# On CE 1, configure a default route and specify gateway address 100.1.1.1 for the route.
<CE1> system-view
[CE1] ip route-static 0.0.0.0 0 100.1.1.1
# On CE2, configure a default route and specify gateway address 100.1.2.1 for the route.
<CE2> system-view
[CE2] ip route-static 0.0.0.0 0 100.1.2.1
# Configure IP addresses and masks for the interfaces, as shown in Figure 10. (Details not shown.)
# In the IPv6 network, configure OSPFv3 to ensure that the devices can reach each other. (Details not shown.)
2.     Configure PE 1:
# Enable L2VPN.
<PE1> system-view
[PE1] l2vpn enable
# Configure RD and route target settings for VPN instance vpn1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 1:1
[PE1-vpn-instance-vpn1] address-family ipv4
[PE1-vpn-ipv4-vpn1] vpn-target 1:1 import-extcommunity
[PE1-vpn-ipv4-vpn1] vpn-target 1:1 export-extcommunity
[PE1-vpn-ipv4-vpn1] quit
[PE1-vpn-instance-vpn1] address-family evpn
[PE1-vpn-evpn-vpn1] vpn-target 2:2 import-extcommunity
[PE1-vpn-evpn-vpn1] vpn-target 2:2 export-extcommunity
[PE1-vpn-evpn-vpn1] quit
[PE1-vpn-instance-vpn1] quit
# Configure VSI-interface 1.
[PE1] interface vsi-interface 1
[PE1-Vsi-interface1] ip binding vpn-instance vpn1
[PE1-Vsi-interface1] ip address 100.1.1.1 255.255.255.0
[PE1-Vsi-interface1] mac-address 0001-0001-0001
[PE1-Vsi-interface1] local-proxy-arp enable
[PE1-Vsi-interface1] distributed-gateway local
[PE1-Vsi-interface1] quit
# Configure VSI vpna.
[PE1] vsi vpna
[PE1-vsi-vpna] gateway vsi-interface 1
[PE1-vsi-vpna-evpn-srv6] route-distinguisher 6:6
[PE1-vsi-vpna-evpn-srv6] vpn-target 6:6 import-extcommunity
[PE1-vsi-vpna-evpn-srv6] vpn-target 6:6 export-extcommunity
[PE1-vsi-vpna] quit
# Configure a locator for SRv6 SID allocation.
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 1:1:: 64 static 32
# Configure BGP peers.
[PE1] bgp 100
# Configure the BGP EVPN address family.
# Configure the BGP IPv4 VPN instance.
[PE1-bgp-default-ipv4-vpn1] import evpn mac-ip
[PE1-bgp-default-ipv4-vpn1] advertise l2vpn evpn
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort evpn
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa evpn
# Map GigabitEthernet 0/0/1 (the interface connected to CE 1) with VSI vpna.
3.     Configure PE 2:
# Enable L2VPN.
<PE2> system-view
[PE2] l2vpn enable
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 1:1
[PE2-vpn-instance-vpn1] address-family ipv4
[PE2-vpn-ipv4-vpn1] vpn-target 1:1 import-extcommunity
[PE2-vpn-ipv4-vpn1] vpn-target 1:1 export-extcommunity
[PE2-vpn-ipv4-vpn1] quit
[PE2-vpn-instance-vpn1] address-family evpn
[PE2-vpn-evpn-vpn1] vpn-target 2:2 import-extcommunity
[PE2-vpn-evpn-vpn1] vpn-target 2:2 export-extcommunity
[PE2-vpn-evpn-vpn1] quit
[PE2-vpn-instance-vpn1] quit
[PE2] interface vsi-interface 1
[PE2-Vsi-interface1] ip binding vpn-instance vpn1
[PE2-Vsi-interface1] ip address 100.1.2.1 255.255.255.0
[PE2-Vsi-interface1] mac-address 0001-0001-0001
[PE2-Vsi-interface1] local-proxy-arp enable
[PE2-Vsi-interface1] distributed-gateway local
[PE2-Vsi-interface1] quit
[PE2] vsi vpna
[PE2-vsi-vpna] gateway vsi-interface 1
[PE2-vsi-vpna-evpn-srv6] route-distinguisher 6:6
[PE2-vsi-vpna-evpn-srv6] vpn-target 6:6 import-extcommunity
[PE2-vsi-vpna-evpn-srv6] vpn-target 6:6 export-extcommunity
[PE2-vsi-vpna] quit
[PE2-segment-routing-ipv6] locator aaa ipv6-prefix 2:2:: 64 static 32
[PE2] bgp 100
[PE2-bgp-default] ip  vpn-instance vpn1
[PE2-bgp-default-ipv4-vpn1] import evpn mac-ip
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort evpn
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa evpn
# Map GigabitEthernet 0/0/1 (the interface connected to CE 2) with VSI vpna.
# On PE 1, display routing table information for VPN instance vpn1 and verify that PE 1 has learned the host route of CE 2.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11       Routes : 11
0.0.0.0/32         Direct  0   0           127.0.0.1       InLoop0
100.1.1.0/24       Direct  0   0           100.1.1.1       Vsi1
100.1.1.0/32       Direct  0   0           100.1.1.1       Vsi1
100.1.1.1/32       Direct  0   0           127.0.0.1       InLoop0
100.1.1.255/32     Direct  0   0           100.1.1.1       Vsi1
100.1.2.20/32      BGP     255 0           2:2::           GE0/0/2
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
# On PE 2, display routing table information for VPN instance vpn1 and verify that PE 2 has learned the host route of CE 1.
[PE2] display ip routing-table vpn-instance vpn1
100.1.2.0/24       Direct  0   0           100.1.1.1       Vsi1
100.1.2.0/32       Direct  0   0           100.1.1.1       Vsi1
100.1.2.1/32       Direct  0   0           127.0.0.1       InLoop0
100.1.1.10/32      BGP     255 0           1:1::           GE0/0/2
100.1.2.255/32     Direct  0   0           100.1.1.1       Vsi1
