03-Interface Command Reference
HomeSupportRoutersSR6600-M SeriesReference GuidesCommand ReferencesH3C SR6608-M Router Command Reference-R9141-6W10103-Interface Command Reference
07-Loopback, null, and inloopback interface commands
display interface inloopback
Use display interface inloopback to display information about the inloopback interface.
display interface [ inloopback [ 0 ] ] [ brief [ description | down ] ]
inloopback [ 0 ]: Specifies Inloopback 0. If you do not specify the inloopback keyword, the command displays information about all interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions. The description of an inloopback interface is always InLoopBack0 Interface and cannot be configured.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
The device has only one inloopback interface Inloopback 0. If you specify the inloopback keyword, the command displays information about the interface Inloopback 0 regardless of whether you specify the 0 keyword.
# Display detailed information about Inloopback 0.
<Sysname> display interface inloopback
InLoopBack0
Current state: UP
Line protocol state: UP(spoofing)
Description: InLoopBack0 Interface
Maximum transmission unit: 1536
Physical: InLoopBack
Current state
Physical link state of the interface, which is always UP, meaning that the inloopback interface can receive and transmit packets.
Line protocol state
Data link layer state of the interface, which is always UP(spoofing). UP(spoofing) represents that the data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Description of the interface, which is always InLoopBack0 Interface and cannot be configured.
MTU of the interface, which is always 1536 and cannot be configured
The physical type of the interface is inloopback.
Average input rate during the last 300 seconds (displayed when the interface supports traffic statistics collection):
·     bytes/sec—Average number of bytes received per second.
·     bits/sec—Average number of bits received per second.
·     packets/sec—Average number of packets received per second.
Average output rate over the last 300 seconds (displayed when the interface supports traffic statistics collection):
·     bytes/sec—Average number of bytes sent per second.
·     bits/sec—Average number of bits sent per second.
·     packets/sec—Average number of packets sent per second.
Total number and size (in bytes) of incoming packets of the interface and the number of dropped packets (displayed when the interface supports traffic statistics collection).
Total number and size (in bytes) of outgoing packets of the interface and the number of dropped packets (displayed when the interface supports traffic statistics collection).
# Display brief information about Inloopback 0.
<Sysname> display interface inloopback 0 brief
Protocol: (s) - spoofing
InLoop0              UP   UP(s)    --
Link
Physical link state of the interface, which is always UP, meaning that the link is physically up.
Protocol
Data link layer protocol state of the interface, which is always UP(s). UP(s) represents that the data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
IP address of the interface.
Because inloopback interfaces do not support CLI configuration, this field does not display a value.
Description of the interface. Because inloopback interfaces do not support CLI configuration, this field does not display a value.
display interface loopback
Use display interface loopback to display information about the specified or all existing loopback interfaces.
display interface [ loopback [ interface-number ] ] [ brief [ description | down ] ]
loopback interface-number: Specifies a loopback interface by its number, which can be the number of any existing loopback interface. If you do not specify the loopback keyword, the command displays information about all interfaces. If you specify the loopback keyword but do not specify the interface-number argument, the command displays information about all existing loopback interfaces on the device.
This command is supported only after a loopback interface is created.
# Display detailed information about Loopback 0.
<Sysname> display interface loopback 0
LoopBack0
Current state: UP
Description: LoopBack0 Interface
Bandwidth: 1000 kbps
Physical: Loopback
Last clearing of counters:  Never
Current state
Physical link state of the interface:
·     UP—The loopback interface can receive and transmit packets.
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
Line protocol state
Data link layer state of the interface. UP (spoofing) means that the data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Bandwidth
Expected bandwidth of the interface. This field is not displayed when the value is 0.
MTU of the interface.
IP packet processing capability of the interface when the interface is not assigned an IP address:
·     Disabled—The interface cannot process IP packets.
·     Enabled—The interface can process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
Physical: Loopback
The physical type of the interface is loopback.
Time when statistics on the logical interface were last cleared by using the reset counters interface command.
If the statistics of the interface have never been cleared by using the reset counters interface command since the device started, this field displays Never.
# Display brief information about all loopback interfaces.
<Sysname> display interface loopback brief
Loop1                UP   UP(s)    --              forLAN1
# Display information about all loopback interfaces in down state and the causes.
<Sysname> display interface loopback brief down
Interface            Link Cause
Loop1                ADM  Administratively
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Primary IP
Primary IP address of the interface.
Cause
Cause for the physical link state of the interface to be DOWN. Administratively represents that the interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
interface loopback
reset counters interface loopback
display interface null
Use display interface null to display information about the null interface.
display interface [ null [ 0 ] ] [ brief [ description | down ] ]
null [ 0 ]: Specifies Null 0. If you do not specify the null keyword, the command displays information about all interfaces.
The device has only one null interface Null 0. If you specify the null keyword, the command displays information about the interface Null 0 regardless of whether you specify the 0 keyword.
# Display detailed information about Null 0.
<Sysname> display interface null 0
NULL0
Current state: UP
Description: NULL0 Interface
Bandwidth: 1000000 kbps
Physical: NULL DEV
# Display brief information about Null 0.
<Sysname> display interface null 0 brief
NULL0                UP   UP(s)    --
For the command output, see Table 3 and Table 4.
interface null
reset counters interface null
interface loopback
Use interface loopback to create a loopback interface and enter its view, or enter the view of an existing loopback interface.
Use undo interface loopback to remove a loopback interface.
interface loopback interface-number
undo interface loopback interface-number
No loopback interfaces exist.
interface-number: Specifies a loopback interface by its number. The value range for this argument is 0 to 1023.
The physical layer state and link layer protocols of a loopback interface are always up unless the loopback interface is manually shut down. You can use a loopback interface to achieve the following purposes:
·     Prevent the connection from being affected by the physical state of the interface.
·     Improve the reliability of the connection.
For example, you can configure a loopback interface as the source interface for establishing an FTP connection, or use the loopback interface address as the Router ID in BGP.
# Create Loopback 1.
[Sysname] interface loopback 1
[Sysname-LoopBack1]
interface null
Use interface null to enter null interface view.
interface null 0
A device has only one null interface (Null 0), which cannot be created or deleted.
0: Specifies Null 0. The null interface number is always 0.
# Enter Null 0 interface view.
[Sysname] interface null 0
[Sysname-NULL0]
