- 19-Security Command Reference
- 01-Object group commands
- 02-Keychain commands
- 03-Public key management commands
- 04-PKI commands
- 05-Crypto engine commands
- 06-SSH commands
- 07-SSL commands
- 08-Security zone commands
- 09-Packet filter commands
- 10-ASPF commands
- 11-Security policy commands
- 12-Session management commands
- 13-ARP attack protection commands
- 14-ND attack defense commands
- 15-Attack detection and prevention commands
- 16-mGRE commands
- 17-Connection limit commands
- 18-IP-based attack prevention commands
- 19-IP source guard commands
- 20-uRPF commands
- 21-APR commands
- 22-FIPS commands
| 07-SSL commands | 163.00 KB |
certificate-chain-sending enable
ciphersuite server-preferred enable
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
SSL commands
Use certificate-chain-sending enable to enable the SSL server to send the complete certificate chain to the client during SSL negotiation.
Use undo certificate-chain-sending enable to restore the default.
During SSL negotiation, the SSL server sends the server certificate rather than the complete certificate chain to the client.
This feature causes additional overheads in the SSL negotiation process. Enable it only when the SSL client does not have the complete certificate chain to verify the server certificate.
# Enable the SSL server to send the complete certificate chain to the client during SSL negotiation.
[Sysname] ssl server-policy policy1
[Sysname-ssl-server-policy-policy1] certificate-chain-sending enable
ciphersuite
Use ciphersuite to specify the cipher suites supported by an SSL server policy.
Use undo ciphersuite to restore the default.
In non-FIPS mode:
ciphersuite { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_128_cbc_sha256 | dhe_rsa_aes_256_cbc_sha | dhe_rsa_aes_256_cbc_sha256 | ecc_sm2_sm1_sm3 | ecc_sm2_sm4_sm3 | ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_sm2_sm1_sm3 | ecdhe_sm2_sm4_sm3 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | exp_rsa_des_cbc_sha | exp_rsa_rc2_md5 | exp_rsa_rc4_md5 | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 |rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 | rsa_des_cbc_sha | rsa_sm1_sha | rsa_sm1_sm3 | rsa_sm4_sha | rsa_sm4_sm3 | rsa_rc4_128_md5 | rsa_rc4_128_sha } *<1-11>
In FIPS mode:
ciphersuite { ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 } *<1-11>
undo ciphersuite
In non-FIPS mode, an SSL server policy supports all cipher suites except the following: exp_rsa_des_cbc_sha, exp_rsa_rc2_md5, exp_rsa_rc4_md5, rsa_3des_ede_cbc_sha, rsa_des_cbc_sha, rsa_rc4_128_md5, and rsa_rc4_128_sha.
In FIPS mode, an SSL server policy supports all cipher suites.
dhe_rsa_aes_128_cbc_sha: Specifies the cipher suite that uses key exchange algorithm DHE RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
dhe_rsa_aes_128_cbc_sha256: Specifies the cipher suite that uses key exchange algorithm DHE RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA256.
dhe_rsa_aes_256_cbc_sha: Specifies the cipher suite that uses key exchange algorithm DHE RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA.
dhe_rsa_aes_256_cbc_sha256: Specifies the cipher suite that uses key exchange algorithm DHE RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA256.
ecc_sm2_sm1_sm3: Specifies the cipher suite that uses key exchange algorithm ECC SM2, data encryption algorithm 128-bit SM1, and MAC algorithm SM3.
ecc_sm2_sm4_sm3: Specifies the cipher suite that uses key exchange algorithm ECC SM2, data encryption algorithm SM4, and MAC algorithm SM3.
ecdhe_ecdsa_aes_128_cbc_sha256: Specifies the cipher suite that uses key exchange algorithm ECDHE ECDSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA256.
ecdhe_ecdsa_aes_128_gcm_sha256: Specifies the cipher suite that uses key exchange algorithm ECDHE ECDSA, data encryption algorithm 128-bit AES_GCM, and MAC algorithm SHA256.
ecdhe_ecdsa_aes_256_cbc_sha384: Specifies the cipher suite that uses key exchange algorithm ECDHE ECDSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA384.
ecdhe_ecdsa_aes_256_gcm_sha384: Specifies the cipher suite that uses key exchange algorithm ECDHE ECDSA, data encryption algorithm 256-bit AES_GCM, and MAC algorithm SHA384.
ecdhe_rsa_aes_128_cbc_sha256: Specifies the cipher suite that uses key exchange algorithm ECDHE RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA256.
ecdhe_rsa_aes_128_gcm_sha256: Specifies the cipher suite that uses key exchange algorithm ECDHE RSA, data encryption algorithm 128-bit AES_GCM, and MAC algorithm SHA256.
ecdhe_rsa_aes_256_cbc_sha384: Specifies the cipher suite that uses key exchange algorithm ECDHE RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA384.
ecdhe_rsa_aes_256_gcm_sha384: Specifies the cipher suite that uses key exchange algorithm ECDHE RSA, data encryption algorithm 256-bit AES_GCM, and MAC algorithm SHA384.
ecdhe_sm2_sm1_sm3: Specifies the cipher suite that uses key exchange algorithm ECDHE SM2, data encryption algorithm 128-bit SM1, and MAC algorithm SM3.
ecdhe_sm2_sm4_sm3: Specifies the cipher suite that uses key exchange algorithm ECDHE SM2, data encryption algorithm SM4, and MAC algorithm SM3.
exp_rsa_des_cbc_sha: Specifies the export cipher suite that uses key exchange algorithm RSA, data encryption algorithm DES_CBC, and MAC algorithm SHA.
exp_rsa_rc2_md5: Specifies the export cipher suite that uses key exchange algorithm RSA, data encryption algorithm RC2, and MAC algorithm MD5.
exp_rsa_rc4_md5: Specifies the export cipher suite that uses key exchange algorithm RSA, data encryption algorithm RC4, and MAC algorithm MD5.
rsa_3des_ede_cbc_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 3DES_EDE_CBC, and MAC algorithm SHA.
rsa_aes_128_cbc_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
rsa_aes_128_cbc_ sha256: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA256.
rsa_aes_128_gcm_sha256: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit AES_GCM, and MAC algorithm SHA256.
rsa_aes_256_cbc_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA.
rsa_aes_256_cbc_ sha256: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 256-bit AES_CBC, and MAC algorithm SHA256.
rsa_aes_256_gcm_sha384: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 256-bit AES_GCM, and MAC algorithm SHA384.
rsa_des_cbc_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm DES_CBC, and MAC algorithm SHA.
rsa_rc4_128_md5: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit RC4, and MAC algorithm MD5.
rsa_rc4_128_sha: Specifies key exchange algorithm RSA, data encryption algorithm 128-bit RC4, and MAC algorithm SHA.
rsa_sm1_sha: Specifies key exchange algorithm RSA, data encryption algorithm 128-bit SM1, and MAC algorithm SHA.
rsa_sm1_sm3: Specifies key exchange algorithm RSA, data encryption algorithm 128-bit SM1, and MAC algorithm SM3.
rsa_sm4_sha: Specifies key exchange algorithm RSA, data encryption algorithm SM4, and MAC algorithm SHA.
rsa_sm4_sm3: Specifies key exchange algorithm RSA, data encryption algorithm SM4, and MAC algorithm SM3.
<1-11>: Specifies a maximum of 11 cipher suites.
SSL employs the following algorithms:
· Data encryption algorithms—Encrypt data to ensure privacy. Commonly used data encryption algorithms are symmetric key algorithms. When a symmetric key algorithm is used, the SSL server and the SSL client must use the same key.
· Message Authentication Code (MAC) algorithms—Calculate the MAC value for data to ensure integrity. Commonly used MAC algorithms include MD5 and SHA. When a MAC algorithm is used, the SSL server and the SSL client must use the same key.
· Key exchange algorithms—Implement secure exchange of the keys used by the symmetric key algorithm and the MAC algorithm. Commonly used key exchange algorithms are usually asymmetric key algorithms, such as RSA.
After the SSL server receives cipher suites from a client, the server compares the received cipher suites with the cipher suites it supports. If a match is found, the cipher suite negotiation succeeds. If no match is found, the negotiation fails. The cipher suite matching can use the server-preferred order or the client-preferred order, depending on the configuration of the ciphersuite server-preferred enable command.
The earlier a cipher suite is configured, the higher priority it has during the cipher suite negotiation.
When executing the ciphersuite command, you can specify a maximum of 11 cipher suites at a time. If you execute this command multiple times, the SSL server policy supports all the specified cipher suites.
# Configure SSL server policy policy1 to support the following cipher suites:
· Key exchange algorithm DHE RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
· Key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
[Sysname-ssl-server-policy-policy1] ciphersuite dhe_rsa_aes_128_cbc_sha rsa_aes_128_cbc_sha
display ssl server-policy
prefer-cipher
Use ciphersuite server-preferred enable to enable the server-preferred order for the cipher suite negotiation between the SSL server and SSL client.
Use undo ciphersuite server-preferred enable to restore the default.
The SSL server uses the client-preferred order to choose a cipher suite during the cipher suite negotiation.
During the SSL connection negotiation process, the SSL server and client present a list of cipher suites that they each support, in order of preference. By default, the SSL server uses the order of cipher suites presented by the client to negotiate the cipher suite. That is, the SSL server chooses the first cipher suite in the client's list that matches any one of the server's cipher suites. If no match is found, the negotiation fails.
After this command is executed, the server-preferred order is used for cipher suite negotiation. That is, the SSL server chooses the first cipher suite in its list that matches any one of the client's cipher suites. If no match is found, the negotiation fails.
# Enable the server-preferred order for cipher suite negotiation.
[Sysname-ssl-server-policy-policy1] ciphersuite server-preferred enable
ciphersuite
prefer-cipher
client-verify
Use client-verify to enable mandatory or optional SSL client authentication.
Use undo client-verify to restore the default.
undo client-verify
SSL client authentication is disabled. The SSL server does not authenticate SSL clients based on digital certificates.
enable: Enables mandatory SSL client authentication.
optional: Enables optional SSL client authentication.
SSL uses digital certificates to authenticate communicating parties. For more information about digital certificates, see public key management in Security Configuration Guide.
Mandatory SSL client authentication—The SSL server requires an SSL client to submit its digital certificate for identity authentication. The SSL client can access the SSL server only after it passes identity authentication.
Optional SSL client authentication—The SSL server does not require an SSL client to submit its digital certificate for identity authentication.
· If an SSL client submits its certificate to the SSL server, the server authenticates the client identity. The client must pass authentication to access the server.
· If an SSL client does not submit its certificate to the SSL server, the server does not authenticate the client identity. The client can access the SSL server without authentication.
If SSL client authentication is disabled, the SSL server does not authenticate SSL clients regardless of whether the clients submit digital certificates or not. SSL clients can access the SSL server without authentication.
When authenticating a client by using the digital certificate, the SSL server performs the following operations:
· Verifies the certificate chain presented by the client.
· Checks that the certificates in the certificate chain (except the root CA certificate) are not revoked.
# Enable mandatory SSL client authentication.
[Sysname-ssl-server-policy-policy1] client-verify enable
# Enable optional SSL client authentication.
[Sysname-ssl-server-policy-policy1] client-verify optional
# Disable SSL client authentication.
[Sysname-ssl-server-policy-policy1] undo client-verify
display ssl client-policy
Use display ssl client-policy to display SSL client policy information.
display ssl client-policy [ policy-name ]
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a policy name, this command displays information about all SSL client policies.
# Display information about the SSL client policy policy1.
<Sysname> display ssl client-policy policy1
SSL client policy: policy1
SSL version: SSL 3.0
PKI domain: client-domain
Preferred ciphersuite:
RSA_AES_128_CBC_SHA
Server-verify: enabled
Server-verify |
Indicates whether the client is enabled to use digital certificates to authenticate servers. |
Use display ssl server-policy to display SSL server policy information.
display ssl server-policy [ policy-name ]
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a policy name, this command displays information about all SSL server policies.
# Display information about the SSL server policy policy1.
<Sysname> display ssl server-policy policy1
SSL server policy: policy1
Version info:
SSL3.0: Disabled
TLS1.0: Enabled
TLS1.1: Disabled
TLS1.2: Enabled
TLS1.3: Enabled
GM-TLS1.1: Disabled
PKI domains: server-domain, server-secdomain
Ciphersuites:
DHE_RSA_AES_128_CBC_SHA
RSA_AES_128_CBC_SHA
TLS_AES_128_GCM_SHA256
TLS_CHACHA20_POLY1305_SHA256
TLS_AES_256_GCM_SHA384
TLS_AES_128_CCM_8_SHA256
TLS_AES_128_CCM_SHA256
Session cache size: 600
Caching timeout: 3600 seconds
Client-verify: Enabled
Ciphersuite server-perferred: Disabled
Server name: 123.exmaple.com
Version info |
Enabling status of the SSL protocol versions in the SSL server policy. The SSL server can use only the enabled SSL protocol versions for session negotiation. Possible SSL protocol versions include: · SSL 3.0. This version is supported only in non-FIPS mode. · TLS 1.0. This version is supported only in non-FIPS mode. · TLS 1.1. · TLS 1.2. · TLS 1.3. This version is supported only in non-FIPS mode. · GM-TLS 1.1. |
Caching timeout |
Session cache timeout time in seconds. |
Client-verify |
SSL client authentication mode, including: · Disabled—SSL client authentication is disabled. · Enabled—SSL client authentication is mandatory. · Optional—SSL client authentication is optional. |
Server name |
Server name associated with the SSL server policy. |
Use pki-domain to specify a PKI domain for an SSL client policy.
Use undo pki-domain to restore the default.
pki-domain domain-name
undo pki-domain
No PKI domain is specified for an SSL client policy.
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters.
If you specify a PKI domain for an SSL client policy, the SSL client that uses the SSL client policy will obtain its digital certificate through the specified PKI domain.
# Specify PKI domain client-domain for SSL client policy policy1.
[Sysname] ssl client-policy policy1
[Sysname-ssl-client-policy-policy1] pki-domain client-domain
pki domain
Use pki-domain to specify a PKI domain for an SSL server policy.
pki-domain domain-name&<1-2>
undo pki-domain
No PKI domain is specified for an SSL server policy.
domain-name&<1-2>: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. &<1-2> represents that you must specify one or two PKI domains.
If you specify a PKI domain for an SSL server policy, the SSL server that uses the SSL server policy will obtain its digital certificate through the specified PKI domain.
Some services (such as load balancing, and proxy policy) might require using two digital certificates on the server. To meet the requirement, you can use this command to specify two PKI domains in the SSL server policy at a time. Make sure the two digital certificates in the specified PKI domains use different types of public key algorithms. If they use the same type of public key algorithms, only the digital certificate obtained through the second PKI domain takes effect.
# Specify PKI domain server-domain for SSL server policy policy1.
[Sysname-ssl-server-policy-policy1] pki-domain server-domain
pki domain
prefer-cipher
Use prefer-cipher to specify a preferred cipher suite for an SSL client policy.
Use undo prefer-cipher to restore the default.
In non-FIPS mode:
prefer-cipher { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_128_cbc_sha256 | dhe_rsa_aes_256_cbc_sha | dhe_rsa_aes_256_cbc_sha256 | ecc_sm2_sm1_sm3 | ecc_sm2_sm4_sm3 | ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_sm2_sm1_sm3 | ecdhe_sm2_sm4_sm3 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | exp_rsa_des_cbc_sha | exp_rsa_rc2_md5 | exp_rsa_rc4_md5 | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 | rsa_des_cbc_sha | rsa_sm1_sha | rsa_sm1_sm3 | rsa_sm4_sha | rsa_sm4_sm3 | rsa_rc4_128_md5 | rsa_rc4_128_sha } *<1-11>
undo prefer-cipher
In FIPS mode:
prefer-cipher { ecdhe_ecdsa_aes_128_cbc_sha256 | ecdhe_ecdsa_aes_128_gcm_sha256 | ecdhe_ecdsa_aes_256_cbc_sha384 | ecdhe_ecdsa_aes_256_gcm_sha384 | ecdhe_rsa_aes_128_cbc_sha256 | ecdhe_rsa_aes_128_gcm_sha256 | ecdhe_rsa_aes_256_cbc_sha384 | ecdhe_rsa_aes_256_gcm_sha384 | rsa_aes_128_cbc_sha | rsa_aes_128_cbc_sha256 | rsa_aes_128_gcm_sha256 | rsa_aes_256_cbc_sha | rsa_aes_256_cbc_sha256 | rsa_aes_256_gcm_sha384 }
undo prefer-cipher *<1-11>
In non-FIPS mode, an SSL client policy supports the following cipher suites: dhe_rsa_aes_256_cbc_sha, rsa_aes_256_cbc_sha, dhe_rsa_aes_128_cbc_sha, and rsa_aes_128_cbc_sha.
In FIPS mode, an SSL client policy supports the following cipher suites: rsa_aes_256_cbc_sha and rsa_aes_128_cbc_sha.
rsa_aes_256_gcm_ sha384: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 256-bit AES_GCM, and MAC algorithm SHA384.
rsa_rc4_128_sha: Specifies the cipher suite that uses key exchange algorithm RSA, data encryption algorithm 128-bit RC4, and MAC algorithm SHA.
· Data encryption algorithms—Encrypt data to ensure privacy. Commonly used data encryption algorithms are usually symmetric key algorithms. When using a symmetric key algorithm, the SSL server and the SSL client must use the same key.
· Message Authentication Code (MAC) algorithms—Calculate the MAC value for data to ensure integrity. Commonly used MAC algorithms include MD5 and SHA. When using a MAC algorithm, the SSL server and the SSL client must use the same key.
· Key exchange algorithms—Implement secure exchange of the keys used by the symmetric key algorithm and MAC algorithm. Commonly used key exchange algorithms are asymmetric key algorithms, such as RSA.
The SSL client sends the preferred cipher suites to the SSL server. The server compares the received cipher suites with the cipher suites it supports. If a match is found, the cipher suite negotiation succeeds. If no match is found, the negotiation fails.
When executing the prefer-cipher command, you can specify a maximum of 11 cipher suites at a time. If you execute this command multiple times, the SSL server policy supports all the specified cipher suites.
# Configure SSL client policy policy1 to support the key exchange algorithm RSA, data encryption algorithm 128-bit AES_CBC, and MAC algorithm SHA.
[Sysname-ssl-client-policy-policy1] prefer-cipher rsa_aes_128_cbc_sha
ciphersuite
security-enhanced level
Use security-enhanced level to specify a security enhanced level for the device.
Use undo security-enhanced level to restore the default.
security-enhanced level level-value
The security enhanced level for the device is 2.
level-value: Specifies the security enhanced level, which can be 1 and 2.
The security enhanced level for the device can be 1 and 2, and level 2 indicates a higher security level. If the security enhanced level is set to 2, the following rules apply:
· SSL client policies and SSL server policies do not support cipher suites that contain DES, 3DES, MD5, RC4, and RC2.
· SSL client policies and SSL server policies do not support SSL protocol versions lower than TLS 1.1.
· SSL session renegotiation cannot be enabled.
You can specify a security enhanced level as needed.
After you change the security enhanced level, for services associated with SSL policies, you must re-enable these services to update the associated policies.
# Set the security enhanced level to 2 for the device.
[Sysname] security-enhanced level 2
server-name
Use server-name to associate a server name with an SSL server policy.
Use undo server-name to restore the default.
server-name server-name
undo server-name
No server name is associated with an SSL server policy.
server-name: Specifies a server name, a case-insensitive string of 1 to 255 characters.
Support for VMs allows a server to use different domain names with the same IP address to provide HTTPS service. However, the server cannot identify which server name corresponds to the HTTPS request from the client. In this case, the server cannot obtain the corresponding digital certificate based on the server name to return the certificate to the client for authentication.
To resolve this issue, use the Server Name Indication (SNI) extension. The HTTPS request from the client contains the SNI extension. The server can identify its associated SSL server policy according to the received SNI extension, and associate the HTTPS service with the SSL server policy that matches. Through a PKI domain for the SSL server policy, the SSL server can obtain a digital certificate during interaction with the client.
The specified server name matches the SNI extension from the client through the following match types:
· Exact match—Specifies a complete server name to match with the SNI extension in the request from the client. For example, if you execute this command to specify the server name as abc.example.com, the match operation succeeds only when the server name in the SNI extension is abc.example.com. If the server name in the SNI extension is dfabc.example.com, the match operation fails.
· Fuzzy match—Specifies a server name that contains wildcards to match with the SNI extension in the request from the client. For example, if you execute this command to specify the server name as *abc.example.com, the match operation succeeds as long as the server name in the SNI extension is suffixed with abc.example.com. If the server name in the SNI extension is dfabc.example.com, the match operation succeeds.
An SSL server policy can be associated with only one server name, but a server name can be associated with multiple SSL server policies.
# Associate server name 123.example.com with SSL server policy policy1.
[Sysname-ssl-server-policy-policy1] server-name 123.example.com
server-verify enable
Use server-verify enable to enable the SSL client to use digital certificates to authenticate the SSL server.
Use undo server-verify enable to disable SSL server authentication. The SSL client does not authenticate the SSL server.
The SSL client uses digital certificates to authenticate the SSL server.
If you execute the server-verify enable command, the SSL server must send its digital certificate to the SSL client for authentication. The client can access the SSL server only after the server passes the authentication.
# Enable the SSL client to use digital certificates to authenticate the SSL server.
[Sysname-ssl-client-policy-policy1] server-verify enable
session
Use session to set the maximum number of sessions that the SSL server can cache and the timeout time for cached sessions.
Use undo session to restore the default.
undo session { cachesize | timeout } *
The SSL server can cache a maximum of 500 sessions, and the timeout time for cached sessions is 3600 seconds.
cachesize size: Sets the maximum number of cached sessions, in the range of 100 to 20480.
timeout time: Sets the session cache timeout in the range of 1 to 4294967295 seconds.
The SSL server caches SSL sessions to reuse negotiated session parameters to simplify SSL handshake. Use this command to limit the maximum number and timeout time for cached sessions. When the number of cached sessions reaches the maximum, SSL does not cache new sessions. When the timeout timer for a cached session expires, SSL deletes the session.
# Set the maximum number of cached sessions to 600, and the timeout time for cached sessions to 1800 seconds.
[Sysname-ssl-server-policy-policy1] session cachesize 600 timeout 1800
ssl client-policy
Use ssl client-policy to create an SSL client policy and enter its view, or enter the view of an existing SSL client policy.
Use undo ssl client-policy to delete an SSL client policy.
ssl client-policy policy-name
undo ssl client-policy policy-name
No SSL client policies exist.
This command creates an SSL client policy for which you can configure SSL parameters that the client uses to establish a connection to the server. The parameters include a PKI domain and a preferred cipher suite. An SSL client policy takes effect only after it is associated with an application such as DDNS.
# Create an SSL client policy named policy1 and enter its view.
ssl renegotiation disable
Use ssl renegotiation disable to disable SSL session renegotiation.
Use undo ssl renegotiation disable to restore the default.
SSL session renegotiation is disabled.
The SSL session renegotiation feature enables the SSL client and server to reuse a previously negotiated SSL session for an abbreviated handshake.
Disabling session renegotiation causes more computational overhead to the system but it can avoid potential risks. Disable SSL session renegotiation only when explicitly required.
#Disable SSL session renegotiation.
[Sysname] ssl renegotiation disable
ssl server-policy
Use ssl server-policy to create an SSL server policy and enter its view, or enter the view of an existing SSL server policy.
Use undo ssl server-policy to delete an SSL server policy.
ssl server-policy policy-name
undo ssl server-policy policy-name
No SSL server policies exist.
policy-name: Specifies a name for the SSL server policy, a case-insensitive string of 1 to 31 characters.
This command creates an SSL server policy for which you can configure SSL parameters such as a PKI domain and supported cipher suits.
# Create an SSL server policy named policy1 and enter its view.
ssl version disable
Use ssl version disable to disable the SSL server from using specific SSL protocol versions for session negotiation.
Use undo ssl version disable restore the default.
In non-FIPS mode:
ssl version { gm-tls1.1 | ssl3.0 | tls1.0 | tls1.1 | tls1.2 | tls1.3 } * disable
undo ssl version { gm-tls1.1 | ssl3.0 | tls1.0 | tls1.1 | tls1.2 | tls1.3 } * disable
In FIPS mode:
ssl version { tls1.1 | tls1.2 } * disable
undo ssl version { tls1.1 | tls1.2 } * disable
In non-FIPS mode, an SSL server can use versions GM-TLS 1.1, TLS 1.1, TLS 1.2, and TLS 1.3 for session negotiation.
In FIPS mode, an SSL server can use versions TLS 1.1 and TLS 1.2 for session negotiation.
gm-tls1.1: Specifies GM-TLS1.1.
ssl3.0: Specifies SSL 3.0.
tls1.0: Specifies TLS 1.0.
tls1.1: Specifies TLS 1.1.
tls1.2: Specifies TLS 1.2.
tls1.3: Specifies TLS 1.3.
Make sure the SSL server is allowed to use a minimum of one SSL protocol version for session negotiation.
This command allows you to disable SSL protocol versions in system view. You can also enable or disable an SSL protocol version in SSL server policy view by using the version disable command. An SSL server policy prefers the policy-specific setting over the system global setting.
Disabling an SSL protocol version does not affect the availability of earlier SSL protocol versions. For example, if you execute the ssl version tls1.1 disable command, TLS 1.1 is disabled but TLS 1.0 is still available for the SSL server.
# Disable TLS 1.0.
[Sysname] ssl version tls1.0 disable
version
Use version to specify an SSL protocol version for an SSL client policy.
Use undo version to restore the default.
In non-FIPS mode:
undo version
In FIPS mode:
undo version
An SSL client policy uses SSL protocol version TLS 1.1.
gm-tls1.1: Specifies GM-TLS 1.1.
To ensure security, do not specify SSL 3.0 for an SSL client policy.
# Set the SSL protocol version to TLS 1.0 for SSL client policy policy1.
[Sysname-ssl-client-policy-policy1] version tls1.0
version disable
Use version disable to disable SSL protocol versions for the SSL server in an SSL server policy.
Use undo version disable restore the default.
In non-FIPS mode:
version { gm-tls1.1 | ssl3.0 | tls1.0 | tls1.1 | tls1.2| tls1.3 } * disable
undo version { gm-tls1.1 | ssl3.0 | tls1.0 | tls1.1 | tls1.2| tls1.3 } * disable
In FIPS mode:
version { tls1.1 | tls1.2} * disable
undo version { tls1.1 | tls1.2 } * disable
An SSL protocol version is enabled in an SSL sever policy unless it is explicitly disabled in system view by using the ssl version disable command.
You can enable or disable an SSL protocol version in system view or in SSL server policy view. An SSL server can use an SSL protocol version for session negotiation only when the status of the SSL protocol version in the SSL server policy is Enabled. The status of an SSL protocol version in an SSL server policy is determined in the following sequence:
1. Configuration of the version disable command in SSL server policy view.
2. Configuration of the ssl version disable command in system view.
3. Default setting (Enabled).
Disabling an SSL protocol version does not affect the availability of earlier SSL protocol versions. For example, if you execute the version tls1.1 disable command in SSL server policy view, TLS 1.1 is disabled but TLS 1.0 is still available for the SSL server.
# Disable TLS 1.0 in SSL server policy policy1.
[Sysname-ssl-server-policy-policy1] version tls1.0 disable
ssl version disable
