- 19-Security Command Reference
- 01-Object group commands
- 02-Keychain commands
- 03-Public key management commands
- 04-PKI commands
- 05-Crypto engine commands
- 06-SSH commands
- 07-SSL commands
- 08-Security zone commands
- 09-Packet filter commands
- 10-ASPF commands
- 11-Security policy commands
- 12-Session management commands
- 13-ARP attack protection commands
- 14-ND attack defense commands
- 15-Attack detection and prevention commands
- 16-mGRE commands
- 17-Connection limit commands
- 18-IP-based attack prevention commands
- 19-IP source guard commands
- 20-uRPF commands
- 21-APR commands
- 22-FIPS commands
| 01-Object group commands | 155.60 KB |
network (IPv4 address object group view)
network (IPv6 address object group view)
network exclude (IPv4 address object group view)
Network exclude (IPv6 address object group view)
service (service object group view)
description
Use description to configure a description for an object group.
No description is configured for an object group.
Object group view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as This is an IPv4 object-group for an IPv4 address object group.
[Sysname] object-group ip address ipgroup
[Sysname-obj-grp-ip-ipgroup] description This is an IPv4 object-group
display object-group
Use display object-group to display information about object groups.
display object-group [ { { ip | ipv6 } address | port | service } [ default ] [ name object-group-name ] | name object-group-name ]
ip address: Specifies the IPv4 address object groups.
ipv6 address: Specifies the IPv6 address object groups.
port: Specifies the port object groups.
service: Specifies the service object groups.
default: Specifies the default object groups.
name object-group-name: Specifies an object group by its name, a case-insensitive string of 1 to 63 characters.
# Display information about all object groups.
<Sysname> display object-group
IP address object group obj1: 0 object(in use)
IP address object group obj2: 6 objects(out of use)
0 network host address 1.1.1.1
10 network host name host
20 network subnet 1.1.1.1 255.255.255.0
30 network range 1.1.1.1 1.1.1.2
40 network group-object obj1
IPv6 address object-group obj3: 0 object(in use)
IPv6 address object-group obj4: 5 objects(out of use)
0 network host address 1::1:1
20 network subnet 1::1:0 112
30 network range 1::1:1 1::1:2
40 network group-object obj3
Service object-group obj5: 0 object(in use)
Service object-group obj6: 6 objects(out of use)
0 service 200
10 service tcp source lt 50 destination range 30 40
20 service udp source range 30 40 destination gt 30
30 service icmp 20 20
40 service icmpv6 20 20
50 service group-object obj5
Port object-group obj7: 0 object(in use)
Port object-group obj8: 3 objects(out of use)
0 port lt 20
10 port range 20 30
20 port group-object obj7
# Display information about object group obj2.
<Sysname> display object-group name obj2
IP address object-group obj2: 5 objects(out of use)
# Display information about all IPv4 address object groups.
<Sysname> display object-group ip address
IP address object-group obj1: 0 object(in use)
# Display information about IPv6 address object group obj4.
<Sysname> display object-group ipv6 address name obj4
in use |
The object group is used by an ACL or object group. |
out of use |
The object group is not used. |
display object-group host
Use display object-group host to display IPv4 or IPv6 addresses for host names.
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } *
object-group-name object-group-name: Specifies an object group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about the specified host name.
name host-name: Specifies a host by its name, a case-insensitive string of 1 to 253 characters. If you do not specify this option, the command displays information about all the included and excluded host names in the specified object group.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the host belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the host resides on the public network, do not specify this option.
# Display IPv4 addresses for host name www.a.com in object group group1.
[Sysname] display object-group ip host object-group-name group1 name www.a.com
Object group : group1
Object ID : 0
Host name : www.a.com
VPN instance : -
Updated at : 2019-05-20 11:04:24
IP addresses :
169.0.0.10
169.0.0.11
# Display IPv6 addresses for all host names in object group group1.
[Sysname] display object-group ipv6 host object-group-name group1
Object ID : 0
VPN instance : -
IP addresses :
169:0::0:10
169:0::0:11
Object ID : 10
Host name : www.b.com
VPN instance : -
IP addresses :
169:0::0:11
169:0::0:12
VPN instance |
VPN of which the host belongs to. |
object-group
Use network to configure an IPv4 address object.
Use undo network to delete an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name }
undo network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name }
undo object-id
No IPv4 address objects exist.
object-id: Specifies an object ID in the range of 0 to 4294967294. If you do not specify an object ID, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the system automatically assigns 30.
host: Configures an IPv4 address object with the host address or name.
address ip-address: Specifies an IPv4 host address.
name host-name: Specifies a host name, a case-insensitive string of 1 to 253 characters. This parameter supports fuzzy matching. You can add an asterisk (*) to the front, end, or both of a string to indicate all host names that include the string. If no asterisks are attached, the system performs exact matching with the specified host name.
subnet ip-address { mask-length | mask | wildcard wildcard }: Configures an IPv4 address object with the subnet address followed by a mask length in the range of 0 to 32 or a mask in dotted decimal notation. The wildcard wildcard option specifies a wildcard mask in dotted decimal notation. A wildcard mask of zeros represents a host address.
range ip-address1 ip-address2: Configures an IPv4 address object with the address range.
group-object object-group-name: Specifies an IPv4 address object group by its name, a case-insensitive string of 1 to 63 characters.
This command fails if you use it to configure or change an IPv4 address object to be identical with an existing object.
This command creates an IPv4 address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
If you configure a subnet with the mask length of 32 or the mask of 255.255.255.255, the system configures the object with a host address.
When you use the range ip-address1 ip-address2 option, follow these guidelines:
· If ip-address1 is equal to ip-address2, the system configures the object with a host address.
· If ip-address1 is not equal to ip-address2, the system compares the two IPv4 addresses, configures a range starting with the lower IPv4 address, and performs the following operations:
¡ Configures the object with an address range if the two addresses are in different subnets.
¡ Configures the object with a subnet address if the two addresses are in the same subnet.
When you use the group-object object-group-name option, follow these guidelines:
· The object group to be used must be an IPv4 address object group.
· If the specified object group does not exist, the system creates an IPv4 address object group with the name you specified and uses the object group for the object.
· Two object groups cannot use each other at the same time.
· The system supports a maximum of five object group hierarchy layers. For example, if groups 1, 2, 3, and 4 use groups 2, 3, 4, and 5, respectively, group 5 cannot use another group and group 1 cannot be used by another group.
# Configure an IPv4 address object with the host address of 192.168.0.1.
[Sysname-obj-grp-ip-ipgroup] network host address 192.168.0.1
# Configure an IPv4 address object with exact-matching host name pc3.
[Sysname-obj-grp-ip-ipgroup] network host name pc3
# Configure an IPv4 address object with fuzzy-matching host name abc.
[Sysname] object-group ip address ipgroup1
[Sysname-obj-grp-ip-ipgroup1] network host name *abc*
# Configure an IPv4 address object with the IPv4 address of 192.167.0.0 and mask length of 24.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.167.0.0 24
# Configure an IPv4 address object with the IPv4 address of 192.166.0.0 and mask of 255.255.0.0.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.166.0.0 255.255.0.0
# Configure an IPv4 address object with the address range of 192.165.0.100 to 192.165.0.200.
[Sysname-obj-grp-ip-ipgroup] network range 192.165.0.100 192.165.0.200
# Configure an IPv4 address object using object group ipgroup2.
[Sysname-obj-grp-ip-ipgroup] network group-object ipgroup2
# Configure an IPv4 address object with the IPv4 address of 192.168.0.1 and wildcard mask of 0.0.255.0.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.168.0.1 wildcard 0.0.255.0
Use network to configure an IPv6 address object.
Use undo network to delete an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address ipv6-address2 | group-object object-group-name }
undo network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name }
undo object-id
No IPv6 address objects exist.
object-id: Specifies an object ID in the range of 0 to 4294967294. If you do not configure an object ID, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the system automatically assigns 30.
host: Configures an IPv6 address object with the host address or name.
address ipv6-address: Specifies an IPv6 host address.
subnet ipv6-address prefix-length: Configures an IPv6 address object with the subnet address followed by the prefix length in the range of 1 to 128.
range ipv6-address1 ipv6-address2: Configures an IPv6 address object.
group-object object-group-name: Specifies an IPv6 address object group by its name, a case-insensitive string of 1 to 63 characters.
This command fails if you use it to configure or change an IPv6 address object to be identical with an existing object.
This command creates an IPv6 address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
If you configure a subnet address with the prefix length of 128, the system configures the object with a host address.
When you use the range ipv6-address1 ipv6-address2 option, follow these guidelines:
· If ipv6-address1 is equal to ipv6-address2, the system configures the object with a host address.
· If ipv6-address1 is not equal to ipv6-address2, the system compares the two IPv6 addresses, configures a range starting with the lower IPv6 address, and performs the following operations:
· The object group to be used must be an IPv6 address object group.
· If the specified object group does not exist, the system creates an IPv6 address object group with the name you specified and uses the object group for the object.
# Configure an IPv6 address object with the host address of 1::1.
[Sysname] object-group ipv6 address ipv6group
[Sysname-obj-grp-ipv6-ipv6group] network host address 1::1
# Configure an IPv6 address object with exact-matching host name pc3.
[Sysname-obj-grp-ipv6-ipv6group] network host name pc3
# Configure an IPv6 address object with fuzzy-matching host name abc.
[Sysname] object-group ipv6 address ipv6group1
[Sysname-obj-grp-ipv6-ipv6group1] network host name *abc*
# Configure an IPv6 address object with the IPv6 address of 1:1:1::1 and prefix length of 24.
[Sysname-obj-grp-ipv6-ipv6group] network subnet 1:1:1::1 24
# Configure an IPv6 address object with the address range of 1:1:1::1 to 1:1:1::100
[Sysname-obj-grp-ipv6-ipv6group] network range 1:1:1::1 1:1:1::100
# Configure an IPv6 address object using object group ipv6group2.
[Sysname-obj-grp-ipv6-ipv6group] network group-object ipv6group2
Use network exclude to exclude an IPv4 address or a subnet from an address object.
Use undo network exclude to restore the default.
object-id network exclude { ip-address | subnet ip-address { mask-length | mask } }
undo object-id network exclude { ip-address | subnet ip-address { mask-length | mask } }
No IPv4 address or subnet in an address object is excluded.
object-id: Specifies an address object by its ID in the range of 1 to 4294967294. The specified address object must have been created.
ip-address: Specifies the IPv4 address to be excluded.
subnet ip-address { mask-length | mask }: Specifies the IPv4 address and mask of a subnet to be excluded. You can specify the mask length or specify the mask in dotted decimal notation. The mask length is in the range of 0 to 32.
You can execute this command multiple times to exclude multiple IPv4 addresses or subnets from an address object.
The configuration fails if either of the following conditions exists:
· The specified address is the same as an existing excluded address or is contained in an existing excluded subnet.
· The specified subnet contains an existing excluded address or overlaps with an existing excluded subnet.
# Configure an IPv4 address object with the IPv4 address of 192.166.0.0 and mask of 255.255.0.0. Exclude IPv4 address 192.166.0.10 and subnet 192.166.1.0/24 from the address object.
[Sysname-obj-grp-ip-ipgroup] 10 network subnet 192.166.0.0 255.255.0.0
[Sysname-obj-grp-ip-ipgroup] 10 network exclude 192.166.0.10
[Sysname-obj-grp-ip-ipgroup] 10 network exclude subnet 192.166.1.0 255.255.255.0
Use network exclude to exclude an IPv6 address or a subnet from an address object.
object-id network exclude { ipv6-address | subnet ipv6-address prefix-length }
undo object-id network exclude { ipv6-address | subnet ipv6-address prefix-length }
No IPv6 address or subnet in an address object is excluded.
ip-address: Specifies the IPv6 address to be excluded.
subnet ipv6-address prefix-length: Specifies the IPv6 subnet to be excluded. The prefix length is in the range of 1 to 128.
You can execute this command multiple times to exclude multiple IPv6 addresses or subnets from an address object.
# Configure an IPv6 address object with the IPv6 address of 1:1:1::1 and prefix length of 24. Exclude IPv6 address 1:1:1::10 and subnet 1:1:1::2:0 with a prefix length of 112 from the address object.
[Sysname-obj-grp-ipv6-ipv6group] 10 network subnet 1:1:1::1 24
[Sysname-obj-grp-ipv6-ipv6group] 10 network exclude 1:1:1::10
[Sysname-obj-grp-ipv6-ipv6group] 10 network exclude subnet 1:1:1::2:0 112
network exclude host-name
Use network exclude host-name to exclude a host name from an address object.
Use undo network exclude host-name to restore the default.
object-id network exclude host-name host-name [ vpn-instance vpn-instance-name ]
undo object-id network exclude host-name host-name [ vpn-instance vpn-instance-name ]
No host name in an address object is excluded.
host-name: Specifies the host name to be excluded, a string of case-insensitive string of 1 to 253 characters.
With an excluded host name configured, the device sends the host name to the DNS server and excludes the translated IPv4 or IPv6 address from the address object.
You can execute this command multiple times to exclude multiple host names from an address object.
To use this feature, you must configure the DNS client first. For more information about DNS client, see DNS in Layer 3—IP Services Configuration Guide.
# Configure an IPv4 address object with the IPv4 address of 192.166.0.0 and mask of 255.255.0.0, and exclude host name www.a.com from the address object.
[Sysname] object-group ip address ipv4
[Sysname-obj-grp-ip-ipv4] 0 network subnet 192.166.0.0 255.255.0.0
[Sysname-obj-grp-ip-ipv4] 0 network exclude host-name www.a.com
# Configure an IPv6 address object with the IPv6 address of 1:1:1::1 and prefix length of 24, and exclude host name www.a.com from the address object.
[Sysname-obj-grp-ipv6-ipv6] 0 network subnet 1:1:1::1 24
[Sysname-obj-grp-ipv6-ipv6] 0 network exclude host-name www.b.com
object description
Use object description to specify an object description.
Use undo object description to restore the default.
object object-id description text
undo object object-id description
No description is specified for an object.
Object group view
object-id: Specifies an object by its ID in the range of 0 to 4294967294. Make sure the object already exists.
text: Specifies the description, a case-sensitive string of 1 to 127 characters.
# Specify the description for object 0 as This is a description for object 0.
[Sysname-obj-grp-ip-ipgroup] 0 network host address 1.2.3.4
[Sysname-obj-grp-ip-ipgroup] object 0 description This is a description for object 0
object-group
Use object-group to create an object group and enter its view, or enter the view of an existing object group.
Use undo object-group to delete an object group.
object-group { { ip | ipv6 } address | port | service } object-group-name
undo object-group { { ip | ipv6 } address | port | service } object-group-name
Default object groups exist.
ip address: Creates an IPv4 address object group.
ipv6 address: Creates an IPv6 address object group.
port: Creates a port object group.
service: Creates a service object group.
object-group-name: Specifies an object group name, a case-insensitive string of 1 to 63 characters. The object group name must be globally unique.
The object-group command execution results vary with the specified object group.
· If the specified group does not exist, the system creates a new object group and enters the object group view.
· If the specified group exists but the group type is different from that in the command, the command fails.
The undo object-group command execution results vary with the specified object group.
· If the specified group does not exist, the system executes the command without any system prompt.
· If the specified group exists and the group type is the same as that in the command, the system deletes the group.
· If the specified object group is being used by an ACLor another object group, the command fails.
Default object groups cannot be deleted.
# Create an IPv4 address object group named ipgroup.
# Create an IPv6 address object group named ipv6group.
# Create a port object group named portgroup.
[Sysname] object-group port portgroup
# Create a service object group named servicegroup.
[Sysname] object-group service servicegroup
object-group rename
Use object-group rename to rename an object group.
object-group rename old-object-group-name new-object-group-name
old-object-group-name: Specifies the name of the object group to be renamed, a case-insensitive string of 1 to 63 characters.
new-object-group-name: Specifies a new name for the object group, a case-insensitive string of 1 to 63 characters. The object group name must be globally unique.
You can only rename non-default object groups.
# Rename object group ipgroup1 to ipgroup2.
[Sysname] object-group rename ipgroup1 ipgroup2
object-group
port (port object group view)
Use port to configure a port object.
Use undo port to delete a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
undo port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
undo object-id
No port objects exist.
Port object group view
eq: Configures a port object with a port number equal to the specified port.
lt: Configures a port object with a port number smaller than the specified port.
gt: Configures a port object with a port number greater than the specified port.
port: Specifies a port number in the range of 0 to 65535.
range port1 port2: Configures a port object with a port range. The value range for the port1 and port2 arguments is 0 to 65535.
group-object object-group-name: Specifies a port object group by its name, a case-insensitive string of 1 to 63 characters.
This command fails if you use it to configure or change a port object to be identical with an existing object.
This command creates a port object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
When you use the lt port option, follow these guidelines:
· The value of port cannot be 0.
· If the value of port is 1, the system configures the object with a port number of 0.
· If the value of port is in the range of 2 to 65535, the system configures the object with a port number range of [0, port–1].
When you use the gt port option, follow these guidelines:
· The value of port cannot be 65535.
· If the value of port is 65534, the system configures the object with a port number of 65535.
· If the value of port is in the range of 0 to 65533, the system configures the object with a port number range of [port+1, 65535].
When you use the range port1 port2 option, follow these guidelines:
· If port1 is equal to port2, the system configures the object with the port number port1.
· If port1 is smaller than port2, the system configures the object with the port number range.
· If port1 is greater than port2, the system changes the range to [port2, port1] and configures the object with the changed port number range.
· If port1 is 0, the range is displayed as lt port2+1.
· If port2 is 65535, the range is displayed as gt port1–1.
· The object group to be used must be a port object group.
· If the specified object group does not exist, the system creates a port object group with the name you specified and uses the object group for the object.
# Configure a port object with a port number of 100.
[Sysname-obj-grp-port-portgroup] port eq 100
# Configure a port object with a port number smaller than 20.
[Sysname-obj-grp-port-portgroup] port lt 20
# Configure a port object with a port number greater than 60000.
[Sysname-obj-grp-port-portgroup] port gt 60000
# Configure a port object with a port number in the range of 1000 to 2000.
[Sysname-obj-grp-port-portgroup] port range 1000 2000
# Configure a port object using object group portgroup2.
[Sysname-obj-grp-port-portgroup] port group-object portgroup2
security-zone
Use security-zone to specify a security zone for an IP address object group.
Use undo security-zone to restore the default.
security-zone security-zone-name
undo security-zone
No security zone is specified for an IP address object group.
security-zone-name: Specifies the security zone name, a case-insensitive string of 1 to 31 characters. The string cannot contain hyphens (-) or percent signs (%) and cannot be any.
This feature enables fast selection of IP address object groups when you specify IP address filtering criteria for a security policy from the Web interface. If a security policy uses an IP address object group specified with a security zone, you can specify only IP address object groups from the same or no security zone for the policy.
You can specify only one security zone for an IP address object group. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the security zone for IPv4 address object group 1 as Local.
[Sysname] object-group ip address 1
[Sysname-obj-grp-ip-1] security-zone Local
object-group
Use service to configure a service object.
Use undo service to delete a service object.
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
undo service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
undo object-id
No service objects exist.
Service object group view
object-id: Configures an object ID in the range of 0 to 4294967294. If you do not configure an ID for the object, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the automatically assigned ID is 30.
protocol: Configures the protocol number in the range of 0 to 255, or the protocol name such as TCP, UDP, ICMP, and ICMPv6.
source: Configures a service object with a source port when the protocol is TCP or UDP.
destination: Configures a service object with a destination port when the protocol is TCP or UDP.
eq: Configures a port equal to the specified port.
lt: Configures a port smaller than the specified port.
gt: Configures a port greater than the specified port.
range port1 port2: Configures a service object with a port range. The value range for the port1 and port2 arguments is 0 to 65535.
icmp-type: Configures the ICMP message type in the range of 0 to 255.
icmp-code: Configures the ICMP message code in the range of 0 to 255.
icmpv6-type: Configures the ICMPv6 message type in the range of 0 to 255.
icmpv6-code: Configures the ICMPv6 message code in the range of 0 to 255.
group-object object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 63 characters.
This command fails if you use it to configure or change a service object to be identical with an existing object.
This command creates a service object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
When use the group-object object-group-name option, follow these guidelines:
· The object group to be used must be a service object group.
· If the specified object group does not exist, the system creates a service object group with the name you specified and uses the object group for the object.
# Configure a service object with a protocol number of 100.
[Sysname-obj-grp-service-servicegroup] service 100
# Configure a service object with the source and destination port numbers for the TCP service.
[Sysname-obj-grp-service-servicegroup] service tcp source eq 100 destination range 10 100
# Configure a service object with the message type and code for the ICMP service.
[Sysname-obj-grp-service-servicegroup] service icmp 100 150
# Configure a service object using object group servicegroup2.
[Sysname-obj-grp-service-servicegroup] service group-object servicegroup2
