| 01-EVPN commands | 728.56 KB |
address-family evpn (public instance view)
address-family evpn (VPN instance view)
address-family ipv4 (public instance view)
display bgp l2vpn evpn inlabel
display evpn ipv6 auto-discovery
display evpn route arp suppression
display evpn route arp-mobility
display evpn route mac-mobility
display evpn route nd suppression
display evpn route nd-mobility
display evpn route xconnect-group
display l2vpn forwarding evpn split-horizon
evpn df-election ac-influence enable
evpn df-election algorithm (interface view)
evpn df-election algorithm (system view)
evpn df-election preference non-revertive
evpn local-service-id remote-service-id
evpn mac-ip advertise distributed-gateway
evpn multihoming advertise disable
evpn multihoming advertise ignore-ethernet-tag
evpn multihoming timer df-delay
evpn route arp-mobility suppression
evpn route mac-mobility suppression
evpn route nd-mobility suppression
ipv6 nd ra tunnel-broadcast global enable
peer advertise encap-type mpls
peer advertise vpn-reoriginate ibgp (BGP EVPN address family view)
peer default-gateway no-advertise
reset evpn route arp-mobility suppression
reset evpn route mac-mobility suppression
reset evpn route nd-mobility suppression
Basic EVPN commands
The device does not support VXLAN-DCI, EVPN-DCI, Ethernet service instance ACs, or EVPN instance view.
ac interface
Use ac interface to map an interface to a cross-connect.
Use undo ac interface to delete the mapping between a cross-connect and an interface.
ac interface interface-type interface-number [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-15> ]
undo ac interface interface-type interface-number
No interface is mapped to a cross-connect.
Cross-connect view
access-mode: Specifies an access mode. The default access mode varies by AC type.
· For a VLAN interface, the default access mode is VLAN. For a Layer 3 interface of another type, the default access mode is Ethernet.
· For a Layer 3 subinterface, the default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
track track-entry-number&<1-15>: Specifies a space-separated list of up to 15 track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
After you execute this command, packets received from the mapped Layer 3 interface are forwarded to the PW or another AC bound to the cross-connect.
The access mode determines how the PE treats the VLAN tag in Ethernet frames received from the AC. It also determines how the PE forwards Ethernet frames out of the AC.
· VLAN access mode—Ethernet frames received from the AC must carry a VLAN tag in the Ethernet header. The VLAN tag is called a P-tag, which is assigned by the service provider. Ethernet frames sent out of the AC must also carry the P-tag.
· Ethernet access mode—If Ethernet frames from the AC have a VLAN tag in the header, the VLAN tag is called a U-tag, and the PE ignores it. Ethernet frames sent out of the AC do not carry the P-tag.
# Map GigabitEthernet 1/0/1 to cross-connect aaa in cross-connect group vpna.
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] connection aaa
[Sysname-xcg-vpna-aaa] ac interface gigabitethernet 1/0/1
connection (MPLS Command Reference)
display l2vpn interface (MPLS Command Reference)
encapsulation (MPLS Command Reference)
pw-type (MPLS Command Reference)
Use address-family evpn to enter public instance EVPN view.
Use undo address-family evpn to delete all settings in public instance EVPN view.
address-family evpn
Public instance view
You can configure EVPN settings such as route targets in public instance EVPN view.
# Enter public instance EVPN view.
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
Use address-family evpn to enter VPN instance EVPN view.
Use undo address-family evpn to delete all settings in VPN instance EVPN view.
address-family evpn
VPN instance view
You can configure EVPN settings such as route targets and routing policies in VPN instance EVPN view.
# Enter EVPN view of VPN instance tenant.
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
Use address-family ipv4 to enter public instance IPv4 address family view.
Use undo address-family ipv4 to delete all settings in public instance IPv4 address family view.
address-family ipv4
# Enter public instance IPv4 address family view.
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family l2vpn evpn
Use address-family l2vpn evpn to create the BGP EVPN address family and enter its view, or enter the view of the existing BGP EVPN address family.
Use undo address-family l2vpn evpn to delete the BGP EVPN address family and all settings in BGP EVPN address family view.
The BGP EVPN address family does not exist.
BGP instance view
Configuration made in BGP EVPN address family view takes effect only on routes and peers of the BGP EVPN address family that are on the public network.
# Create the BGP EVPN address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise l2vpn evpn
Use advertise l2vpn evpn to enable BGP EVPN route advertisement to the local site.
Use undo advertise l2vpn evpn to disable BGP EVPN route advertisement to the local site.
BGP EVPN route advertisement to the local site is enabled.
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
This command enables the device to advertise private BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance.
# Enable BGP EVPN route advertisement to the local site for VPN instance vpn1.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
arp mac-learning disable
Use arp mac-learning disable to disable an EVPN instance from learning MAC addresses from ARP information.
Use undo arp mac-learning disable to restore the default.
An EVPN instance learns MAC addresses from ARP information.
EVPN instance view
VSI EVPN instance view
The MAC information and ARP information advertised by a remote VTEP or PE overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ARP information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable an EVPN instance from learning MAC addresses from ARP information.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
arp proxy-send enable
Use arp proxy-send enable to enable ARP request proxy.
Use undo arp proxy-send enable to disable ARP request proxy.
ARP request proxy is disabled on VSI interfaces.
VSI interface view
ARP request proxy allows a VSI interface to send an ARP request sourced from itself when the VTEP forwards an ARP request. This feature helps resolve certain communication issues.
In an EVPN VXLAN network, VM 1 and VM 2 are attached to VTEP 1 and VTEP 2, respectively, and the VMs are in the same subnet. The gateway interfaces of VM 1 and VM 2 are VSI-interface 1 on VTEP 1 and VSI-interface 2 on VTEP 2, respectively. The following conditions exist on the VTEPs:
· The VTEPs have established BGP EVPN neighbor relationships.
· EVPN is disabled from learning MAC addresses from ARP information.
· MAC address advertisement is disabled, and advertised MAC addresses are withdrawn.
· Remote-MAC address learning is disabled.
· Local proxy ARP is enabled on the VSI interfaces.
· The VSI interfaces use different IP addresses and MAC addresses.
In this network, when VM 1 attempts to communicate with VM 2, the following procedure occurs:
1. VM 1 sends an ARP request.
2. VTEP 1 learns the MAC address of VM 1 from the ARP request, replies to VM 1 on behalf of VM 2, and sends an ARP request to obtain the MAC address of VM 2.
3. VTEP 2 forwards the ARP request, and VM 2 replies to VTEP 1.
4. VTEP 2 forwards the ARP reply sent by VM 2 without learning the MAC address of VM 2 because EVPN is disabled from learning MAC addresses from ARP information.
5. VTEP 1 does not learn the MAC address of VM 2 because remote-MAC address learning is disabled.
As a result, VM 1 fails to communicate with VM 2.
For VM 1 to communicate with VM 2, enable ARP request proxy on VSI-interface 2 of VTEP 2. When receiving the ARP request sent by VTEP 1, VTEP 2 forwards it and sends an ARP request sourced from VSI-interface 2 simultaneously, and VM 2 replies to both ARP requests. Then, VTEP 2 learns the MAC address of VM 2 from the ARP reply destined from VSI-interface 2 and advertises the MAC address to VTEP 1 through BGP EVPN routes. In this way, VTEP 1 obtains the MAC address of VM 2, and VM 1 and VM 2 can communicate.
# Enable ARP request proxy on VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-vsi-interface100] arp proxy-send enable
local-proxy-arp enable (Layer 3—IP Services Command Reference)
arp-advertising disable
Use arp-advertising disable to disable ARP information advertisement for an EVPN instance.
Use undo arp-advertising disable to restore the default.
ARP information advertisement is enabled for an EVPN instance.
EVPN instance view
In an EVPN VXLAN network with distributed gateways, you can disable ARP information advertisement for a VXLAN network to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN network will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information. When ARP information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
# Disable ARP information advertisement for an EVPN instance of EVPN VXLAN.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] arp-advertising disable
bestroute ipv6-nexthop
Use bestroute ipv6-nexthop to enable BGP to prefer routes with an IPv6 next hop during optimal route selection.
Use undo bestroute ipv6-nexthop to restore the default.
BGP prefers routes with an IPv4 next hop during optimal route selection.
Execute this command for the VXLAN packets in an EVPN network to be forwarded through IPv6 routes when both IPv4 and IPv6 routes exist.
# In BGP EVPN address family view, enable BGP to prefer routes with an IPv6 next hop during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] bestroute ipv6-nexthop
Use display bgp l2vpn evpn to display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type{ auto-discovery | es | igmp-js | igmp-ls | imet | ip-prefix | mac-ip | smet } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info | as-path | cluster-list | community | ext-community ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | rt route-target | soo site-of-origin | color color ]&<1-32> [ whole-match ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP EVPN routes for the default BGP instance.
peer { ipv4-address | ipv6-address }: Specifies a peer by its IPv4 address or IPv6 address.
advertised-routes: Specifies the routes advertised to the specified peer.
received-routes: Specifies the routes received from the specified peer.
statistics: Displays BGP EVPN route statistics.
route-distinguisher route-distinguisher: Specifies a route distinguisher (RD), a string of 3 to 21 characters. The RD can use one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
route-type: Specifies a route type.
auto-discovery: Specifies Ethernet auto-discovery routes.
es: Specifies Ethernet segment (ES) routes.
igmp-ls: Specifies IGMP leave synch routes.
igmp-js: Specifies IGMP join synch routes.
imet: Specifies inclusive multicast Ethernet tag (IMET) routes.
ip-prefix: Specifies IP prefix advertisement routes.
mac-ip: Specifies MAC/IP advertisement routes.
smet: Specifies selective multicast Ethernet tag (SMET) routes.
evpn-route: Specifies a BGP EVPN route, a case-insensitive string of 1 to 512 characters.
route-length: Specifies the route length in bits, in the range of 0 to 65535.
evpn-prefix: Specifies a BGP EVPN route in the format of evpn-route/route-length, a case-insensitive string of 1 to 512 characters.
advertise-info: Displays advertisement information for BGP EVPN routes.
as-path: Specifies the AS path attribute.
cluster-list: Specifies the cluster list attribute.
community: Specifies the community attribute.
ext-community: Specifies the extended community attribute.
ipv4-address: Specifies an IPv4 address.
ipv6-address: Specifies an IPv6 address.
mac-address: Specifies a MAC address in MAC/IP advertisement routes. If you specify the route-type keyword, to use this argument, you must also specify the mac-ip keyword.
community-number&<1-32>: Specifies a community sequence number. The value range for the community-number argument is 1 to 4294967295. &<1-32> indicates that a maximum of 32 numbers can be specified.
aa:nn&<1-32>: Specifies a community number. Both aa and nn are in the range of 0 to 65535. &<1-32> indicates that a maximum of 32 numbers can be specified.
internet: Specifies the INTERNET community attribute. Routes with this attribute can be advertised to all BGP peers. By default, all routes have this attribute.
no-advertise: Specifies the NO_ADVERTISE community attribute. Routes with this attribute cannot be advertised to any BGP peers.
no-export: Specifies the NO_EXPORT community attribute. Routes with this attribute cannot be advertised outside the local AS or confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Specifies the NO_EXPORT_SUBCONFED community attribute. Routes with this attribute cannot be advertised outside the local AS or to other sub-ASs in the confederation.
whole-match: Displays BGP EVPN routes that exactly match the specified community list, community numbers, or extended community attribute. If you do not specify this keyword, the command displays BGP EVPN routes that include the specified community list, community numbers, or extended community attribute.
community-list: Specifies a community list to match BGP EVPN unicast routes.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
bandwidth link-bandwidth-value: Specifies the link bandwidth extended community attribute, a string of 3 to 16 characters. This attribute is in the format of 16-bit AS number:32-bit self-defined number, 100:3 for example. The value range is 0 to 65535 for an AS number and 0 to 4294967295 for a self-defined number.
color color: Specifies the color extended community attribute, a string of 4 to 13 characters. This attribute is in the format of binary Color-Only flag:decimal color value, 10:3 for example. The value range is 00 to 11 for the Color-Only flag and 0 to 4294967295 for the color value.
rt route-target: Specifies a route target, a string of 3 to 24 characters.
soo site-of-origin: Specifies the Site of Origin (SoO) extended community attribute, a string of 3 to 24 characters.
A route target or SoO attribute has the following forms:
· 16-bit AS number:32-bit self-defined number. For example, 101:3. The value range is 0 to 65535 for an AS number and 0 to 4294967295 for a self-defined number.
· 32-bit IP address:16-bit self-defined number. For example, 192.168.122.15:1. The value range is 0 to 65535 for a self-defined number.
· 32-bit AS number:16-bit self-defined number. For example, 70000:3. The value range is 65536 to 4294967295 for an AS number and 0 to 65535 for a self-defined number.
· 32-bit IP address/IPv4 address mask length:16-bit user-defined number. For example, 192.168.122.15/24:1.
· 32-bit AS number in dotted format:16-bit user-defined number. For example, 65535.65535:1.
&<1-32>: Specifies a maximum of 32 items.
If you do not specify any parameter, this command displays brief information about all BGP EVPN routes.
This command displays BGP EVPN routes that carry any community attribute and the whole-match keyword does not take effect if you do not specify the following parameters:
· community-number
· aa:nn
· internet
· no-advertise
· no-export
· no-export-subconfed
This command displays BGP EVPN routes that carry any extended community attribute and the whole-match keyword does not take effect if you do not specify the following parameters:
· bandwidth
· color
· rt
· soo
# Display brief information about all BGP EVPN routes.
<Sysname> display bgp l2vpn evpn
BGP local router ID is 1.1.1.9
a – additional-path
Total number of routes from all PEs: 6
Route distinguisher: 100:1
Total number of routes: 3
* > [2][0][48][00aa.00bb.00cc][4][0.0.0.0]/136
10.1.1.2 0 32768 ?
* e 10.1.1.1 0 0 65410?
* > [3][300][16][::ffff:1.1.1.1]/176
127.0.0.1 0 32768 ?
Route distinguisher: 200:1
Total number of routes: 2
* >i [2][0][48][00aa.00cc.00dd][4][1.1.1.1]/136
3.3.3.9 0 100 0 ?
* >i [3][300][16][::ffff:2.2.2.2]/176
3.3.3.9 0 100 0 65420?
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >e [2][0][48][0011.0022.0033][32][11.22.33.55]/136
30.30.1.2 0 0 100i
# Display all BGP EVPN routes that carry community attributes.
<Sysname> display bgp l2vpn evpn community
a – additional-path
Network NextHop MED LocPrf PrefVal Path/Ogn Community
10.1.1.2 0 32768 ? <1:2>
* e 10.1.1.1 0 0 65410? <2:3>
127.0.0.1 0 32768 ? <3:4>
# Display all BGP EVPN routes that carry extended community attributes.
<Sysname> display bgp l2vpn evpn ext-community
a – additional-path
Network NextHop MED LocPrf PrefVal Path/Ogn Ext-Community
10.1.1.2 0 32768 ? <RT 1:2>
* e 10.1.1.1 0 0 65410? <RT 2:3>
127.0.0.1 0 32768 ? <RT 3:4>
Status codes |
Route status codes: · * - valid—Valid route. · > - best—Optimal route. · d - dampened—Dampened route. · h - history—History route. · i - internal—Internal route. · e - external—External route. · s - suppressed—Suppressed route. · S - stale—Stale route. · a - additional-path—Add-Path optimal route. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. The origin of routes advertised by using the network command is IGP. · e – EGP—Learned through EGP. · ? – incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete. |
Network |
BGP EVPN route/route length. For example, in the entry [2][0][48][1485-247c-0506][32][10.1.2.20]/136, [2][0][48][1485-247c-0506][32][10.1.2.20] is the route, and 136 is the route length in bytes. BGP EVPN routes are as follows: · [1][ESI][EthernetTagID] ¡ 1—Ethernet auto-discovery route. ¡ ESI—Ethernet segment identifier (ESI). ¡ EthernetTagID—Ethernet tag ID. · [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress] ¡ 2—MAC/IP advertisement route. ¡ EthernetTagID—Ethernet tag ID. ¡ MACLength—MAC address length. ¡ MAC—MAC address. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address. · [3][EthernetTagID][IPAddressLength][IPAddress] ¡ 3—IMET route. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [4][ESI][IPAddressLength][IPAddress] ¡ 4—ES route. ¡ ESI—ESI. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [5][EthernetTagID][IPAddressLength][IPAddress] ¡ 5—IP prefix advertisement route. ¡ EthernetTagID—Ethernet tag ID. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [6][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 6—Selective multicast Ethernet tag route. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. · [7][ESI][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP] ¡ 7—IGMP join synch route. ¡ ESI—ESI. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. · [8][ESI][EthernetTagID] [Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP][ [LeaveGroup Synchronization] ¡ 8—IGMP leave synch route. ¡ ESI—ESI. ¡ EthernetTagID—Ethernet tag ID. ¡ Source Len—Length of the multicast source address. This field displays 0 if the multicast source is any (*, G). ¡ Source IP—Source IP address of IGMP membership reports. This field is not displayed if the multicast source is any (*, G). ¡ Group Len—Length of the multicast group address. ¡ Group IP—Multicast group address of IGMP membership reports. ¡ Originator Len—Length of the originating router's IP address. ¡ Originator IP—IP address of the originating router. ¡ LeaveGroup Synchronization—Leave group synchronization sequence number. |
NextHop |
Next hop IP address. |
MED |
Multi-Exit Discriminator (MED) attribute. |
LocPrf |
Local precedence. |
PrefVal |
Preferred value. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route. |
Community |
Community attribute. |
Ext-Community |
Extended community attribute. |
# Display detailed information about BGP EVPN route [1][00:01:02:03:04:05:06:07:08:09][5]/120 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][00:01:02:03:04:05:06:07:08:09][5] 120
BGP local router ID: 172.16.250.133
Local AS number: 100
Route distinguisher: 1.1.1.1:100
Paths: 1 available, 1 best
BGP routing table information of [1][00:01:02:03:04:05:06:07:08:09][5]/120:
Rely nexthop : 10.1.1.2
Original nexthop: 10.1.1.2
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN >, <ESI Label: Flag 0,
Label 1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Ethernet auto-discovery route
ESI : 00:01:02:03:04:05:06:07:08:09
Ethernet tag ID : 5
MPLS label : 10
Paths |
Number of routes: · available—Number of valid routes. · best—Number of optimal routes. |
From |
IP address of the BGP peer that advertised the route. |
Rely nexthop |
Next hop after route recursion. If no next hop is found, this field displays not resolved. |
Original nexthop |
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message. |
OutLabel |
Outgoing label of the route. |
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ESI Label. |
RxPathID |
Add-Path ID value of the received route. This field is not supported by the BGP EVPN address family. |
TxPathID |
Add-Path ID value of the sent route. This field is not supported by the BGP EVPN address family. |
AS-path |
AS_PATH attribute of the route. This attribute records the ASs the route has passed and avoids routing loops. |
Origin |
Origin of the route: · igp—Originated in the AS. The origin of routes advertised by using the network command is IGP. · egp—Learned through EGP. · incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete. |
Attribute value |
Attributes of the route: · MED—MED value for the destination network. · localpref—Local preference value. · pref-val—Preferred value. · pre—Route preference value. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · localredist—The route is redistributed from a local VPN instance or public instance. · reoriginated. |
IP precedence |
IP precedence in the range of 0 to 7. N/A indicates that the IP precedence is invalid. |
QoS local ID |
QoS local ID in the range of 1 to 4095. N/A indicates that the QoS local ID is invalid. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the traffic index is invalid. |
MPLS label |
MPLS label. The current software version does not support this field. |
# Display detailed information about BGP EVPN route [2][5][48][0001-0203-0405][32][4.5.5.5]/136 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
OutLabel : 0
Ext-Community : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
>, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
>, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>, <MicroSegment-id:
Type 0x83fe, ID 1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : MAC/IP advertisement route
Ethernet tag ID : 5
MAC address : 0001-0203-0405
IP address : 5.5.5.5/32
MPLS label1 : 10
MPLS label2 : 0
Re-origination : Enable
Route distinguisher: 2.2.2.2:100
OutLabel : 0
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
State : valid, external, best, reoriginated, remoteredist
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
ESI : 0001.0203.0405.0607.0809
Ethernet tag ID : 5
MPLS label1 : 200
MPLS label2 : 300
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · Router's Mac. · MAC Mobility—MAC mobility. ¡ Flag—Indicates whether the MAC address can move. A value of 1 indicates that the MAC address cannot move, and a value of 0 indicates that the MAC address can move. ¡ SeqNum—Identifies the most recent move of the MAC address. · Default GateWay—Route for the default gateway. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. · reoriginated—Reoriginated route. · remoteredist—MAC/IP advertisement route generated based on a remote route. |
MPLS label1 |
VXLAN ID used for Layer 2 forwarding. |
MPLS label2 |
L3 VXLAN ID used for Layer 3 forwarding. |
Re-origination |
State of route reorigination: · Enable. · Disable. |
# Display detailed information about BGP EVPN route [3][0][32][5.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
BGP routing table information of [3][0][32][4.5.5.5]/80:
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
Attribute value : MED 0,pref-val 0
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Inclusive multicast Ethernet tag route
Ethernet tag ID : 0
Origin address : 5.5.5.5/32
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. |
Origin address |
IP address of the originating router. |
# Display detailed information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128
BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32] [4.5.5
.5]/128:
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, <ES-Import RT: 1:1>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Ethernet segment route
ESI : 00:00:00:00:00:00:00:00:00:0a
Origin address : 4.5.5.5/32
Table 5 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ES-Import RT. |
Origin address |
# Display detailed information about BGP EVPN route [5][10][32][4.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
BGP routing table information of [5][10][32][4.5.5.5]/80:
OutLabel : 0
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
0006-0708-0910>, <Priority-Color: (1:10:10)>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IP prefix advertisement route
Ethernet tag ID : 10
IP address : 4.5.5.5/32
Gateway address : 0.0.0.0
MPLS Label : 1
Table 6 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · Router's Mac. · Priority-Color. |
IP address |
IP address and prefix length. |
MPLS Label |
# Display detailed information about BGP EVPN route [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1] 160
BGP routing table information of [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160:
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : Selective multicast Ethernet tag route
Ethernet tag ID : 0
Source length : 32
Source address : 10.1.1.1
Group length : 32
Group address : 224.224.224.224
Origin address : 192.168.3.1
IGMP flags : v3, include
Table 7 Command output
Ext-Community |
Source length |
Length of the multicast source address. |
Source address |
Multicast source address. |
Group length |
Length of the multicast group address. |
Group address |
Multicast group address. |
Origin address |
# Display detailed information about BGP EVPN route [7][00:00:00:00:00:00:00:00:00][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][16][224.224.224.224][32][192.168.3.1] 240
BGP routing table information of [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 0:0>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IGMP join synch route
ESI : 0000.0000.0000.0000.0000
Ethernet tag ID : 0
Source length : 32
Group length : 32
Table 8 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · EVI-RT—Route target associated with EVI. |
Source length |
Source address |
Group length |
Group address |
Origin address |
# Display detailed information about BGP EVPN route [8][ 00:00:00:00:00:00:00:00:00][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0] 272
BGP routing table information of [8][0000.0000.0000.0000.0000] [0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 1:200>
RxPathID : 0x0
TxPathID : 0x0
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
EVPN route type : IGMP leave synch route
Ethernet tag ID : 0
Source length : 32
Group length : 32
Leave group sync: 0
Max ResponseTime: 2500ms
Max ResponseCode: 25
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ESI-RT—Route target associated with the ESI. |
Source length |
Source address |
Group length |
Group address |
Origin address |
Leave group sync |
Max ResponseTime |
Maximum response time in milliseconds. |
Max ResponseCode |
Maximum response time in the received packet, in deciseconds. |
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a] [32][4.5.5.5] 128 advertise-info
Paths: 1 best
BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128:
10.2.1.2
Inlabel : 1279
Table 10 Command output
Paths |
Advertised to peers (1 in total) |
Peers to whom the route has been advertised and the number of the peers. |
InLabel |
Incoming label, which is the private network label assigned by the local PE. |
# Display community attribute information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 community
BGP local router ID: 1.1.1.9
Community: no-export
# Display extended community attribute information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 ext-community
Ext-Community: <RT 1:1>
# Display the AS path attribute of BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 as-path
As-path: 80
# Display the cluster ID list attribute of BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 cluster-list
Cluster list: 80
Table 11 Command output
Paths |
Numbers of available routes and optimal routes. |
Community |
Ext-Community |
As-path |
AS path attribute. |
Cluster-list |
Cluster ID list attribute. |
# Display statistics about the BGP EVPN routes with community attributes.
<Sysname> display bgp l2vpn evpn statistics community
Total number of routes from all PEs: 1
Route distinguisher: 100:1(vpn1)
Total number of routes: 4
Use display bgp l2vpn evpn inlabel to display incoming labels for IP prefix advertisement routes.
display bgp [ instance instance-name ] l2vpn evpn inlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays route information for the default BGP instance.
Use this command to display the private network labels that the local PE assigns to IP prefix advertisement routes.
# Display incoming labels for IP prefix advertisement routes.
<Sysname> display bgp l2vpn evpn inlabel
a - additional-path
Origin: i - IGP, e - EGP, ? – incomplete
Route distinguisher: 100:2
Network NextHop OutLabel InLabel
* >e [5][0][24][192.168.1.0]/80
192.168.1.10 NULL 1151
Table 12 Command output
Status codes |
Route status codes: · * - valid—Valid route. · > - best—Optimal route. · d - dampened—Dampened route. · h - history—History route. · i - internal—Internal route. · e - external—External route. · s - suppressed—Suppressed route. · S - Stale—Stale route. · a - additional-path—Add-Path optimal route. |
Origin |
Network |
BGP EVPN route in the format of [5][EthernetTagID][IPAddressLength][IPAddress]: · 5—IP prefix advertisement route. · EthernetTagID—Ethernet tag ID. · IPAddressLength—IP address length. · IPAddress—IP address of the originating router. |
OutLabel |
Outgoing label, which is the private network label assigned by the peer PE. If the peer PE assigns a null label, this field displays NULL. |
InLabel |
evpn mpls routing-enable
display evpn auto-discovery
Use display evpn auto-discovery to display information about peers that are automatically discovered through BGP.
display evpn auto-discovery { { imet [ vxlan ] | mac-ip [ vxlan ] } [ peer peer-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet: Specifies peers discovered through IMET routes.
peer peer-address: Specifies a peer by its IP address. If you do not specify this option, the command displays information about all automatically discovered peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays peer information for all VSIs.
macip-prefix: Specifies peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays peer information for all next hops.
count: Displays the number of peers. If you do not specify this keyword, the command displays detailed peer information.
If you do not specify a network type, this command displays peer information for all network types.
# Display information about peers discovered through IMET routes for EVPN VXLAN.
<Sysname> display evpn auto-discovery imet vxlan
Total number of automatically discovered peers: 2
VSI name: vpna
EVPN instance: -
RD PE_address Tunnel_address Tunnel mode VXLAN ID
1:10 2.2.2.2 2.2.2.2 VXLAN 10
2:100 3.3.3.3 3.3.3.3 VXLAN 10
Table 13 Command output
EVPN instance |
EVPN instance name. If the EVPN instance is created on a VSI, this field displays a hyphen (-). |
PE_address |
Identifier of the remote VTEP on the VSI. |
Tunnel_address |
Tunnel destination IP address. |
Tunnel mode |
Tunnel mode: · VXLAN. · VXLAN-DCI. · PW. · SRv6. |
In/Out label |
Incoming and outgoing labels for the PW. If the labels are invalid, this field displays a hyphen (-). |
In SID |
Incoming SID. |
Out SID |
Outgoing SID. |
# Display information about IPv4 peers discovered through MAC/IP advertisement routes for EVPN VXLAN.
<Sysname> display evpn auto-discovery mac-ip vxlan
Total number of automatically discovered peers: 1
VSI name: vpna
EVPN instance: -
Destination IP Source IP VXLAN ID Tunnel mode Tunnel name
6.6.6.6 1.1.1.9 100 VXLAN Tunnel1
Table 14 Command output
EVPN instance |
Tunnel mode |
Tunnel mode: · VXLAN. · PW. · SRv6. |
In/Out label |
In SID |
Incoming SID. |
Out SID |
Outgoing SID. |
# Display information about peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
<Sysname> display evpn auto-discovery macip-prefix
Destination IP Source IP L3VNI Tunnel mode Outgoing interface
1.1.1.1 3.3.3.3 200 VXLAN Vsi-interface3
2.2.2.2 3.3.3.3 200 VXLAN Vsi-interface3
# Display the total number of peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
Table 15 Command output
Destination IP |
Source IP |
Tunnel source IP address. |
L3VNI |
Tunnel mode |
Tunnel mode: · VXLAN. · VXLAN-DCI. |
Outgoing interface |
VSI interface associated with the L3 VXLAN ID. |
display evpn df-election
Use display evpn df-election to display DF election information.
display evpn df-election [ vsi vsi-name | xconnect-group group-name ] [ esi esi-id ]
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters.
esi esi-id: Specifies an ES by its ESI in XXXX.XXXX.XXXX.XXXX.XXXX format. Each X represents a hexadecimal digit. The ESI must begin with 00 and cannot be all zeros. If you do not specify this option, the command displays information about all ESs.
If you do not specify a VSI or cross-connect group, this command displays DF election information about all VSIs and cross-connect groups.
# Display DF election information about all VSIs and cross-connect groups.
<Sysname> display evpn df-election
Status codes : * - invalid
VSI name: 1
ESI : 0021.1001.1001.1001.1002
Interface : GigabitEthernet1/0/1
Service instance ID : 1000
Link ID : 1
Ethernet tag ID : 12
DF state : Primary
FSM : DF_DONE
Number of member devices : 2
Originating IP DF state Algorithm Preference Capability
100.100.100.100 Primary Preference 65535 DP
100.100.100.200 Backup Preference 200 DP
ESI : 0002.0002.0002.0002.0002
Interface : GigabitEthernet1/0/2
Link ID : 0
Ethernet tag ID : 0
DF state : -
FSM : DF_CALC
1.1.1.1 - Preference 32767 -
2.2.2.2 - Preference 32767 -
Xconnect-group name : 1
Connection name : 1
ESI : 0001.0001.0001.0001.0001
Interface : GigabitEthernet1/0/3
Link ID : 1
Ethernet tag ID : 0
DF state : -
FSM : DF_CALC
Number of member devices : 1
Table 16 Command output
Status codes |
Status code for a device in DF election. An asterisk (*) indicates that a device cannot participate in DF election. |
Link ID |
The AC's link ID on the VSI. |
DF state |
DF election result: · Backup—The device is a BDF. · Primary—The device is the DF. If DF election has not finished, this field displays a hyphen (-). |
FSM |
State of the finite state machine for DF election: · INIT—Initializing. · DF_WAIT—The DF election delay has not timed out. · DF_CALC—DF election is in progress. · DF_DONE—DF election has finished. |
Originating IP |
IP address of the member device that participates in DF election. |
DF state |
DF election result: · Backup—The member device is a BDF. · Primary—The member device is the DF. If DF election has not finished, this field displays a hyphen (-). |
Algorithm |
Algorithm used in DF election: · modulus—VLAN tag-based algorithm. · Preference—Preference-based algorithm. |
Preference |
DF election preference. |
Capability |
Supported DF election capabilities. DP represents non-revertive mode. If no capability is supported, this field displays a hyphen (-). |
display evpn es
Use display evpn es to display EVPN ES information.
display evpn es { local [ count | [ vsi vsi-name ] [ esi esi-id ] [ verbose ] ] | remote [ vsi vsi-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose ] }
local: Specifies local ES information.
count: Displays the number of local ESs.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ES information about all VSIs.
verbose: Displays detailed ES information. If you do not specify this keyword, the command displays brief ES information.
remote: Specifies remote ES information.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays ES information received from all next hops.
# Display the number of local ESs.
<Sysname> display evpn es local count
Total number of ES entries: 1
Table 17 Command output
Tag ID |
Ethernet tag ID. |
DF address |
Router ID of the VTEP or PE elected as the DF. |
Mode |
Redundancy mode of the ES: · A—All-active mode. · S—Single-active mode. |
State |
State of the ES: · Up. · Down. |
ESI label |
ESI label. |
# Display detailed information about local ESs of all VSIs.
<Sysname> display evpn es local verbose
VSI name : v1
EVPN instance: -
VSI ESI : 0001.0001.0001.0001.0003
Redundancy mode : All-active
ES state : Up
AD-delay remaining time : 10
ESI : 0003.0003.0003.0003.0003
State : Up
ACs :
Link ID Service instance ID Tag ID DF address ESI label
0 1 1 1.1.1.1 1001
1 3 3 3.3.3.3 1002
2 10 10 2.2.2.2 1003
VSI name : vpna
EVPN instance: -
ESI : 0001.0002.0002.0002.0002
State : Up
ACs :
1 - 0 1.1.1.1 -
VSI name : vpnb
EVPN instance: -
Interface : GE1/0/3
State : Down
ACs :
Link ID : 0
Service instance ID : -
Tag ID : 0
DF address : 1.1.1.1
Argument : ::1
Table 18 Command output
VSI ESI |
ESI assigned to the VSI. |
AC |
AC name. This field displays a Layer 3 interface name or a Layer 2 interface name and an Ethernet service instance name. |
Redundancy mode |
ES state |
ES state of the VSI: · Up. · Down. A hyphen (-) indicates that no ESI is manually assigned. |
State |
State of the interface: · Up. · Down. If the ES is not manually assigned an ESI, a hyphen (-) is displayed. |
AD-delay remaining time |
Remaining time of the advertisement delay timer for Ethernet auto-discovery routes, in seconds. |
ACs |
The VSI's ACs on the ES. |
Link ID |
Service instance ID |
Ethernet service instance ID. |
Tag ID |
Ethernet tag ID. |
DF address |
Router ID of the VTEP or PE elected as the DF. If the device is not the DF of an AC, a hyphen (-) is displayed. |
ESI label |
ESI label. For EVPN VXLAN, this field is invalid and displays a hyphen (-). |
Argument |
Argument that identifies a leaf AC. |
# Display information about remote ESs of all VSIs.
<Sysname> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
VSI name : vpna
ESI : 0001.0000.0000.0000.0001
Ethernet segment routes :
1.1.1.1
3.3.3.3
A-D per ES routes :
Peer IP Remote Redundancy mode
1.1.1.1 All-active
3.3.3.3 All-active
A-D per EVI routes :
Tag ID Peer IP
- 1.1.1.1
- 3.3.3.3
ESI : 0001.0002.0003.0004.0005
1.1.1.1
A-D per ES routes :
1.1.1.1 All-active
Tag ID Peer IP
- 1.1.1.1
Xconnect group name : a
123.123.123.123
3.3.3.3
A-D per ES routes :
123.123.123.123 All-active
3.3.3.3 All-active
Tag ID Peer IP Control Flags
2 3.3.3.3 P
4 123.123.123.123 PC
# Display detailed information about remote ESs.
VSI name : vpna
A-D per ES routes :
Peer IP : 2::2
Remote Redundancy mode: All-active
Argument : ::1
Tag ID : 1
Peer IP : 2::2
Xconnect group name : vpna
2::2
A-D per ES routes :
Peer IP : 2::2
Tag ID : 1
Control Flags : P
Peer IP : 2::2
# Display remote ES information received from next hop 3.3.3.3 for VSI vpna.
<Sysname> display evpn es remote vsi vpna nexthop 3.3.3.3
VSI name : vpna
3.3.3.3
A-D per ES routes :
3.3.3.3
Tag ID Peer IP
- 3.3.3.3
Table 19 Command output
Argument |
Ethernet segment routes |
Ethernet segment routes for the ES. |
A-D per Ethernet segment routes |
A-D per Ethernet segment routes for the ES. |
A-D per EVI routes |
A-D per EVI routes for the ES. |
Tag ID |
Ethernet tag ID. |
Peer IP |
IP address of the remote peer. |
Remote Redundancy mode |
Redundancy mode of the remote ES: · All-active. · Single-active. |
Control Flags |
Layer 2 attributes control flags of the remote route: · P—Primary flag. · B—Backup flag. · C—Control word flag. |
display evpn instance
Use display evpn instance to display EVPN instance information.
display evpn instance [ name instance-name | vsi vsi-name | xconnect-group group-name ]
name instance-name: Specifies an EVPN instance by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify any parameters, this command displays information about all EVPN instances.
# Display information about all EVPN instances.
<Sysname> display evpn instance
Total number of EVPN instances: 3
EVPN instance : abc
Route distinguisher : -
Export VPN targets : -
Import VPN targets : -
MAC advertisement : Enabled
ARP advertisement : Enabled
ND advertising : Disabled
ARP-based MAC learning : Enabled
ND-based MAC learning : Enabled
Local fast-reroute : Inherit
Tunnel policy : -
PW class : -
Dt2uLocatorName : -
Dt2ulLocatorName : -
Dt2mLocatorName : -
E-Tree : Disabled
Best-Effort : Disabled
Traffic-Engineering : Disabled
Import routing policy : -
Export routing policy : -
VSI binding list:
VSI name Tag ID
vpna 3
vpnb 5
EVPN instance : - (created on vsi abc)
Encapsulation : VXLAN
VXLAN ID : -
EVPN instance : - (created on vsi aaa)
Encapsulation : MPLS
MPLS label : -
IMET MPLS label : -
Tunnel policy : -
PW class : -
Control Word : Disabled
E-Tree : Disabled
PW type : VLAN
Sequencing : -
Flow label : -
Default color : -
EVPN instance : - (created on Xconnect-group xcga)
Import Route Policy : -
Export Route Policy : -
Table 20 Command output
EVPN instance |
EVPN instance name in one of the following formats: · instance-name—Name of an EVPN instance created in system view. · - (created on VSI vsi-name)—Name of an EVPN instance created on a VSI. · - (created on Xconnect-group xconnect-group-name)—Name of an EVPN instance created on a cross-connect group. |
Encapsulation |
EVPN encapsulation type: · VXLAN. · MPLS. · SRv6. |
MAC advertisement |
Status of MAC address advertisement: · Enabled. · Disabled. |
ARP advertisement |
Status of ARP advertisement: · Enabled. · Disabled. |
ND advertising |
Whether ND information advertisement is enabled: · Enabled. · Disabled. |
ARP-based MAC learning |
Whether EVPN learns MAC addresses from ARP information: · Enabled. · Disabled. |
ND-based MAC learning |
Whether EVPN learns MAC addresses from ND information: · Enabled. · Disabled. |
Local fast-reroute |
State of local FRR on the EVPN instance: · Enabled. · Disabled. · Inherit—Local FRR is not configured in EVPN instance view. The EVPN instance uses the local FRR setting configured in system view. |
Tunnel policy |
Tunnel policy used by the EVPN instance. |
PW class |
PW class used by the EVPN instance. |
Control word |
Status of the control word feature: · Enabled. · Disabled. |
E-Tree |
Status of EVPN E-tree: · Enabled. · Disabled. |
PW type |
PW type: · Ethernet. · VLAN. |
Sequencing |
Sequencing on the PW. The value is Both. A hyphen (-) in this field indicates that sequencing is disabled on the PW. |
Flow label |
Flow label capability: · Both—Flow label sending and receiving capabilities. · Send—Flow label sending capability. · Recv—Flow label receiving capability. This field displays a hyphen (-) if the flow label feature is disabled. |
Dt2uLocatorName |
Locator name used for requesting the DT2U SID. If dynamic SID assignment is disabled, this field displays auto-sid-disable. |
Dt2ulLocatorName |
Locator name used for requesting the DT2UL SID. If dynamic SID assignment is disabled, this field displays auto-sid-disable. |
Dt2mLocatorName |
Locator name used for requesting the DT2M SID. If dynamic SID assignment is disabled, this field displays auto-sid-disable. |
Best-Effort |
Whether SID-route-recursion is enabled: · Enabled. · Disabled. |
Import routing policy |
Importing routing policy used by the EVPN instance. If the EVPN instance does not have an import routing policy, this field displays a hyphen (-). This field is available only when the encapsulation type is MPLS or SRv6. |
Export routing policy |
Exporting routing policy used by the EVPN instance. If the EVPN instance does not have an export routing policy, this field displays a hyphen (-). This field is available only when the encapsulation type is MPLS or SRv6. |
VSI binding list |
VSIs bound to the EVPN instance. |
evpn encapsulation
vsi
Use display evpn ipv6 auto-discovery to display information about IPv6 peers that are automatically discovered through BGP.
display evpn ipv6 auto-discovery { { imet | mac-ip } [ vxlan ] [ peer ipv6-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet: Specifies IPv6 peers discovered through IMET routes.
mac-ip: Specifies IPv6 peers discovered through MAC/IP advertisement routes.
peer ipv6-address: Specifies a peer by its IPv6 address. If you do not specify this option, the command displays information about all automatically discovered IPv6 peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv6 peer information for all VSIs.
macip-prefix: Specifies IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays IPv6 peer information for all next hops.
count: Displays the number of IPv6 peers. If you do not specify this keyword, the command displays detailed IPv6 peer information.
# Display information about IPv6 peers discovered through IMET routes for EVPN VXLAN.
<Sysname> display evpn ipv6 auto-discovery imet
VSI name: vpna
EVPN instance : -
RD : 1:10
PE address : 11::8
Tunnel address : 11::8
Tunnel mode : VXLAN
VXLAN ID : 10
RD : 2:100
PE address : 12::8
Tunnel address : 12::8
Tunnel mode : VXLAN
VXLAN ID : 10
Table 21 Command output
EVPN instance |
EVPN instance name. This field displays a hyphen (-) if no EVPN instance exists. |
PE address |
Tunnel address |
Tunnel mode |
Tunnel mode: · VXLAN. · VXLAN-DCI. · SRv6. |
In SID |
Incoming SID of the SRv6 tunnel. |
Out SID |
Outgoing SID of the SRv6 tunnel. |
# Display information about IPv6 peers discovered through MAC/IP advertisement routes that do not carry L3 VXLAN IDs for EVPN VXLAN.
<Sysname> display evpn ipv6 auto-discovery mac-ip
VSI name: vpna
Destination IP : 6:6::6:8
Source IP : 1:1::1:7
VXLAN ID : 100
Tunnel mode : VXLAN
Tunnel name : Tunnel1
Table 22 Command output
Destination IP |
Source IP |
Tunnel mode |
Tunnel mode: · VXLAN. · SRv6. |
In SID |
Out SID |
# Display information about IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
<Sysname> display evpn ipv6 auto-discovery macip-prefix
L3VNI : 100
Tunnel mode : VXLAN
OutInterface : Vsi-interface3
# Display the total number of IPv6 peers discovered through MAC/IP advertisement routes that carry L3 VXLAN IDs or IP prefix advertisement routes that carry L3 VXLAN IDs.
<Sysname> display evpn ipv6 auto-discovery macip-prefix count
Total number of entries: 1
Table 23 Command output
Destination IP |
Source IP |
L3VNI |
Tunnel mode |
OutInterface |
Use display evpn route arp to display EVPN ARP entries.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ip ipv4-address ] [ count ]
local: Specifies local ARP entries.
remote: Specifies remote ARP entries.
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
ip ipv4-address: Specifies an IPv4 address in dotted decimal notation. If you do not specify this option, the command displays all ARP entries that match the criteria you specify.
count: Displays the number of ARP entries. If you do not specify this keyword, the command displays detailed information about ARP entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays EVPN ARP entries for the public instance and all VPN instances.
# Display all EVPN ARP entries.
<Sysname> display evpn route arp
Flags: D - Dynamic B - BGP L - Local active
G - Gateway S - Static M - Mapping I - Invalid
E - Multihoming ES sync F - Leaf
VPN instance: vpn1 Interface: Vsi-interface1
IP address MAC address Router MAC VSI index Flags
10.1.1.1 0003-0003-0003 a0ce-7e40-0400 0 GL
10.1.1.11 0001-0001-0001 a0ce-7e40-0400 0 DL
10.1.1.12 0001-0001-0011 a0ce-7e41-0401 0 B
10.1.1.13 0001-0001-0021 a0ce-7e42-0402 0 B
Public instance Interface: Vsi-interface2
11.1.1.1 0033-0033-0033 a0ce-7e40-0400 0 GL
11.1.1.11 0011-0011-0011 a0ce-7e40-0400 0 DL
# Display the total number of EVPN ARP entries.
<Sysname> display evpn route arp count
Total number of entries: 6
Table 24 Command output
VSI interface. |
Router MAC |
Router MAC address of the device. A hyphen (-) is displayed for an SRv6 network with distributed gateways. |
Flags |
ARP entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. · E—The entry is synchronized between devices at a multihomed site. · F—The entry is from a leaf AC of EVPN E-tree. |
Use display evpn route arp suppression to display EVPN ARP flood suppression entries.
display evpn route arp suppression [ vxlan ] [ local | remote ] [ vsi vsi-name ] [ ip ipv4-address ] [ count ]
vxlan: Specifies the EVPN VXLAN network.
local: Specifies local ARP flood suppression entries.
remote: Specifies remote ARP flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ARP flood suppression entries for all VSIs.
ip ipv4-address: Specifies an IPv4 address in dotted decimal notation. If you do not specify this option, the command displays all ARP flood suppression entries that match the criteria you specify.
count: Displays the number of ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about ARP flood suppression entries.
If you do not specify a network type, this command displays EVPN ARP flood suppression entries for all network types. If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP flood suppression entries.
# Display all EVPN ARP flood suppression entries.
<Sysname> display evpn route arp suppression
VSI name: vpna
EVPN instance: -
IP address MAC address Flags Encap
10.1.1.12 0002-0002-0002 B VXLAN
10.1.1.13 0002-0002-0002 BI VXLAN
10.1.1.101 0001-0011-0101 BS VXLAN
10.1.1.102 0001-0011-0102 DL VXLAN
# Display the total number of ARP flood suppression entries.
<Sysname> display evpn route arp suppression count
Table 25 Command output
EVPN instance |
Flags |
ARP flood suppression entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. · E—The entry is synchronized between devices at a multihomed site. · F—The entry is from a leaf AC of EVPN E-tree. |
Encap |
Packet encapsulation type: · MPLS. · VXLAN. |
display evpn route arp-mobility
Use display evpn route arp-mobility to display EVPN ARP mobility information.
display evpn route arp-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ] [ verbose ]
ip ip-address: Specifies an IPv4 address in dotted decimal notation. If you do not specify an IP address, this command displays ARP mobility information about all IP addresses of the public instance or MPLS L3VPN instance.
verbose: Displays detailed ARP mobility information. If you do not specify this keyword, the command displays brief ARP mobility information.
If you do not specify any parameters, this command displays ARP mobility information about the public instance and all VPN instances.
# Display EVPN ARP mobility information about the public instance and all VPN instances.
<Sysname> display evpn route arp-mobility
Flags: S - Suppressed, N - Not suppressed
VPN instance : vpn1
Interface : Vsi-interface1
IP address Move count Moved from Flags Suppressed at
192.168.156.120 5 GE1/0/1 S 17:24:33 2018/04/01
192.168.56.20 - - N -
Public instance
Interface : Vsi-interface2
192.168.156.120 5 GE1/0/2 S 17:24:33 2018/04/01
192.168.56.20 5 2.2.2.2 S 17:24:33 2018/04/01
Table 26 Command output
Move count |
Number of ARP moves from the interface to other interfaces. |
Moved from |
Source interface or source VTEP/PE IP address for the ARP move. |
Flags |
Whether the ARP move was suppressed: · S—Suppressed. · N—Not suppressed. |
Suppressed at |
Time when the ARP move was suppressed. |
# Display detailed EVPN ARP mobility information about the public instance and all VPN instances.
<Sysname> display evpn route arp-mobility verbose
VPN instance : vpn1
IP address : 192.168.156.120
Move count : 5
Moved from : GE1/0/1
Flags : Suppressed
Suppressed at : 17:24:33 2018/04/01
Suppression threshold: 5
Detection cycle : 180s
Suppression-time : Permanent
Table 27 Command output
Moved from |
Flags |
Whether the ARP move was suppressed: · Suppressed. · Not suppressed. |
Suppressed at |
Suppression threshold |
ARP mobility suppression threshold, which is the number of ARP moves from the local site to a remote site. If ARP mobility suppression is disabled or ARP moves are not suppressed, this field displays a hyphen (-). |
Detection cycle |
ARP mobility detection cycle in seconds. If ARP mobility suppression is disabled or ARP moves are not suppressed, this field displays a hyphen (-). |
Suppression time |
ARP mobility suppression time in seconds. Permanent indicates that ARP moves are suppressed permanently. If ARP mobility suppression is disabled or ARP moves are not suppressed, this field displays a hyphen (-). |
evpn route arp-mobility suppression
display evpn route mac
Use display evpn route mac to display EVPN MAC address entries.
display evpn route mac [ vxlan ] [ local | remote ] [ vsi vsi-name ] [ mac-address mac-address ] [ count ]
local: Specifies local MAC address entries.
remote: Specifies remote MAC address entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays MAC address entries for all VSIs.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a MAC address, this command displays all MAC address entries that match the criteria you specify.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
If you do not specify a network type, this command displays EVPN MAC address entries for all network types. If you do not specify the local or remote keyword, this command displays both local and remote EVPN MAC address entries.
# Display all EVPN MAC address entries for EVPN VXLAN.
<Sysname> display evpn route mac
VSI name: bbb
EVPN instance: -
MAC address Link ID/Name Flags Encap Next hop
0000-0000-000a 1 DL VXLAN -
0000-0000-0009 Tunnel1 B VXLAN 2.2.2.2
0001-2000-4000 - BI VXLAN 3.3.3.3
# Display the total number of EVPN MAC address entries.
<Sysname> display evpn route mac count
Table 28 Command output
EVPN instance |
Link ID/Name |
For a local MAC address, this field displays the AC's link ID on the VSI. For a remote MAC address, this field displays the tunnel interface name. |
Flags |
MAC address entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. · E—The entry is synchronized between devices at a multihomed site. · F—The entry is from a leaf AC of EVPN E-tree. |
Encap |
Packet encapsulation type: · MPLS. · SRv6. · VXLAN. |
Next hop |
IP address of the remote VTEP. If the MAC address entry is a local entry, a hyphen (-) is displayed. |
Type |
Outgoing interface type: · BE—SRv6 best-effort tunnel. · TE—SRv6 TE policy tunnel. |
Color |
Color attribute of the MAC address entry. If the MAC address entry does not have this attribute, a hyphen (-) is displayed. This field is available only when the encapsulation type is SRv6. |
Delete delay |
Delay time in seconds for deleting MAC address entries after receiving a MAC/IP advertisement route withdrawal message. If the delay is not set, this field displays a hyphen (-). |
SID |
SRv6 SID assigned to the MAC address. |
display evpn route mac-mobility
Use display evpn route mac-mobility to display EVPN MAC mobility information.
display evpn route mac-mobility [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac-address mac-address ] [ verbose ]
evpn-instance instance-name: Specifies an EVPN instance by its name, a case-sensitive string of 1 to 31 characters.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC mobility information about all VSIs.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a MAC address, this command displays MAC mobility information about all MAC addresses in the specified VSI or all VSIs.
verbose: Displays detailed MAC mobility information. If you do not specify this keyword, the command displays brief MAC mobility information.
If you do not specify any parameters, this command displays IPv4 EVPN MAC mobility information about all VSIs.
# Display IPv4 EVPN MAC mobility information about all VSIs.
<Sysname> display evpn route mac-mobility
VSI name : vsia
EVPN instance : -
MAC address Move count Moved from Flags Suppressed at
1000-0000-0000 10 GE1/0/1 S 15:30:30 2018/03/30
1000-0000-0001 - - N -
VSI name : vsib
EVPN instance : -
1000-0000-0003 2 GE1/0/2 N -
1000-0000-0005 10 5.5.5.5 S 17:24:33 2018/04/01
Table 29 Command output
EVPN instance |
EVPN instance name. If the EVPN instance is created on a VSI, this field displays a hyphen (-). This field is supported only by EVPN VXLAN. |
Move count |
Number of MAC moves from the interface to other interfaces. |
Moved from |
Source interface or source VTEP/PE IP address for the MAC move. |
Flags |
Whether the MAC move was suppressed: · S—Suppressed. · N—Not suppressed. |
Suppressed at |
Time when the MAC move was suppressed. |
# Display detailed IPv4 EVPN MAC mobility information about all VSIs.
<Sysname> display evpn route mac-mobility verbose
VSI name : vsia
MAC Address : 1000-0000-0000
Move count : 10
Flags : Suppressed
Suppressed at : 15:30:30 2018/03/30
Suppression threshold: 10
Table 30 Command output
Moved from |
Flags |
Whether the MAC move was suppressed: · Suppressed. · Not suppressed. |
Suppressed at |
MAC mobility suppression threshold, which is the number of MAC moves from the local site to a remote site. If MAC mobility suppression is disabled or MAC moves are not suppressed, this field displays a hyphen (-). |
Detection cycle |
MAC mobility detection cycle in seconds. If MAC mobility suppression is disabled or MAC moves are not suppressed, this field displays a hyphen (-). |
Suppression time |
MAC mobility suppression time in seconds. Permanent indicates that MAC moves are suppressed permanently. If MAC mobility suppression is disabled or MAC moves are not suppressed, this field displays a hyphen (-). |
evpn route mac-mobility suppression
display evpn route nd
Use display evpn route nd to display EVPN ND entries.
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ count ]
local: Specifies local ND entries.
remote: Specifies remote ND entries.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify this option, the command displays all ND entries that match the criteria you specify.
count: Displays the number of ND entries. If you do not specify this keyword, the command displays detailed information about ND entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ND entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays EVPN ND entries for the public instance and all VPN instances.
# Display all EVPN ND entries.
<Sysname> display evpn route nd
IPv6 address : AD80:0300:1000:0050:0200:0300:0100:0012
MAC address : 0001-0001-0001 Router MAC : a0ce-7e40-0400
VSI index : 0 Flags : GL
IPv6 address : AD10:0300:1000:0020:0200:0300:0100:0022
MAC address : 0001-0001-0002 Router MAC : a0ce-7e40-0411
Public instance Interface: Vsi-interface1
IPv6 address : BC80:0300:1000:0050:0200:0300:0100:0033
MAC address : 0002-0002-0001 Router MAC : a0ce-7e40-0422
IPv6 address : BC10:0300:1000:0020:0200:0300:0100:0034
MAC address : 0002-0002-0002 Router MAC : a0ce-7e40-0433
# Display the total number of EVPN ND entries.
<Sysname>display evpn route nd count
Table 31 Command output
VSI interface. |
Flags |
ND entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
display evpn route nd suppression
Use display evpn route nd suppression to display EVPN ND flood suppression entries.
display evpn route nd suppression [ local | remote ] [ vsi vsi-name ] [ ipv6 ipv6-address ] [ count ] [ verbose ]
local: Specifies local ND flood suppression entries.
remote: Specifies remote ND flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ND flood suppression entries for all VSIs.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify this option, the command displays all ND flood suppression entries that match the criteria you specify.
count: Displays the number of ND flood suppression entries. If you do not specify this keyword, the command displays detailed information about ND flood suppression entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ND flood suppression entries.
# Display all EVPN ND flood suppression entries.
<Sysname> display evpn route nd suppression
VSI name: vpna
IPv6 address MAC address Flags Encap
11::8 72cb-ce9b-0a06 DL VXLAN
11::9 0001-0001-0001 B VXLAN
# Display the total number of ND flood suppression entries.
<Sysname> display evpn route nd suppression count
Table 32 Command output
Flags |
ARP flood suppression entry type: · D—The entry is dynamically learned. · B—The entry is learned from BGP EVPN routes. · L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active. · G—The entry for the gateway is active. · S—The static entry is active. · M—The entry from a remote VXLAN mapped to a local VXLAN is active. · I—The entry is invalid. Possible reasons: ¡ The VSI has been administratively shut down by using the shutdown command. ¡ The outgoing tunnel interface does not exist. |
Encap |
display evpn route nd-mobility
Use display evpn route nd-mobility to display EVPN ND mobility information.
display evpn route nd-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ verbose ]
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays ND mobility information about all IPv6 addresses of the public instance or MPLS L3VPN instance.
verbose: Displays detailed ND mobility information. If you do not specify this keyword, the command displays brief ND mobility information.
If you do not specify any parameters, this command displays ND mobility information about the public instance and all VPN instances.
# Display brief EVPN ND mobility information about the public instance and all VPN instances.
<Sysname> display evpn route nd-mobility
VPN instance : vpn1
IPv6 address : 1::1
Move count : 5
Flags : S
Suppressed at : 15:30:30 2020/03/30
Public instance
IPv6 address : 2::2
Move count : 5
Moved from : 20::20
Flags : S
Suppressed at : 17:24:33 2020/04/01
Table 33 Command output
Move count |
Number of ND moves from the interface to other interfaces. |
Moved from |
Source interface or source VTEP/PE IP address for the ND move. |
Flags |
Whether the ND move was suppressed: · Suppressed. · Not suppressed. |
Suppressed at |
Time when the ND move was suppressed. |
# Display detailed EVPN ND mobility information about the public instance and all VPN instances.
<Sysname> display evpn route nd-mobility verbose
VPN instance : vpn1
IPv6 address : 1::1
Move count : 5
Flags : Suppressed
IPv6 address : 1::1
Move count : 5
Flags : Suppressed
Table 34 Command output
Moved from |
Flags |
Suppressed at |
ND mobility suppression threshold, which is the number of ND moves from the local site to a remote site. If ND mobility suppression is disabled or ND moves are not suppressed, this field displays a hyphen (-). |
Detection cycle |
ND mobility detection cycle in seconds. If ND mobility suppression is disabled or ND moves are not suppressed, this field displays a hyphen (-). |
Suppression time |
Suppression time in seconds. If this field displays Permanent, ND moves are suppressed permanently. If ND mobility suppression is disabled or ND moves are not suppressed, this field displays a hyphen (-). |
evpn route nd-mobility suppression
display evpn route xconnect-group
Use display evpn route xconnect-group to display EVPN information about cross-connects.
display evpn route xconnect-group [ name group-name [ connection connection-name ] ] [ count ]
name group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a cross-connect group, this command displays EVPN information about all cross-connect groups.
connection connection-name: Specifies a cross-connect by its name, a case-sensitive string of 1 to 20 characters excluding hyphens (-). If you do not specify a cross-connect, this command displays EVPN information about all cross-connects in the specified cross-connect group.
count: Displays the number of EVPN cross-connects. If you do not specify this keyword, the command displays detailed EVPN information.
If you do not specify any parameters, this command displays detailed EVPN information about all cross-connects.
# Display detailed EVPN information about all cross-connects.
<Sysname> display evpn route xconnect-group
Ctrl Flags: P - Primary, B - Backup, C - Control word
Xconnect group name: aa
Connection name: aaa
Local service ID : 16777215
Remote service ID : 16777214
Control word : Enabled
In label : 502
Local MTU : 1500
AC state : Up
PW type : VLAN
Nexthop ESI Out label Flags MTU State
192.123.123.123 0001.0002.0002.0002.0001 1299 PC 1500 Up
192.1.1.1 0001.0002.0002.0002.0001 1026 B 1500 Down
Connection name: aab
Remote service ID : 2
Control word : Disabled
In label : 323
Local MTU : 1500
AC state : Up
PW type : VLAN
192.1.1.1 0002.0002.0002.0002.0001 1234 P 1500 Up
192.2.1.2 0002.0002.0002.0002.0001 603 P 1500 Up
Connection name: aac
Local service ID : 3
Remote service ID : 4
In label : -
Local MTU : 1500
AC state : Up
PW type : Ethernet
192.1.1.3 0000.0000.0000.0000.0000 555 P 1500 Idle
Xconnect group name: vpna
Connection name: pw1
Encapsulation : SRv6
In SID[DX2] : 100::1
In SID[DX2L] : -
Local MTU : 1500
AC State : Up
SRv6 Tunnel:
Next Hop : 2::2
Out SID : 200::1
Flags : P
MTU : 1500
State : Up
# Display the total number of EVPN cross-connects.
<Sysname> display evpn route xconnect-group count
Table 35 Command output
Xconnect group name |
Cross-connect group name. |
Connection name |
Cross-connect name. |
Encapsulation |
In label |
PW incoming label. |
Local MTU |
Local MTU in bytes. |
AC state |
AC state: · Up. · Down. This field displays a hyphen (-) if no AC is configured. |
PW type |
PW data encapsulation type: · Ethernet. · VLAN. |
Nexthop |
Remote PE address. |
Out label |
PW outgoing label. |
Flags |
PW attribute flags: · P—The received route has the primary flag. A primary PW needs to be set up. · B—The received route has the backup flag. A backup PW needs to be set up. · C—The received route has the control word flag, which indicates that control word is enabled on the peer. For the EVPN PWs to come up, you must enable control word on the local device. |
MTU |
MTU in the received route, in bytes. |
State |
EVPN PW state: · Up. · Down. · Idle—The incoming or outgoing label is not available. |
In SID[DX2] |
Incoming End.DX2 SID. |
In SID[DX2L] |
Incoming End.DX2L SID. |
Out SID |
Outgoing SID. |
display evpn routing-table
Use display evpn routing-table to display EVPN routing table information.
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
ipv6: Specifies IPv6 information. If you do not specify this keyword, the command displays IPv4 information.
count: Displays the number of entries in the routing table. If you do not specify this keyword, the command displays detailed information about the routing table.
# Display the EVPN IPv4 routing table for VPN instance vpn1 of an EVPN network with distributed gateways.
<Sysname> display evpn routing-table vpn-instance vpn1
Flags: E - with valid ESI A – A-D ready L - Local ES exists
VPN instance name: vpn1 Local L3VNI: 7
IP address Nexthop Outgoing interface NibID Flags
10.1.1.11 1.1.1.1 Vsi-interface3 0x18000000 -
10.1.1.12 2.2.2.2 Vsi-interface3 0x18000001 -
# Display the EVPN IPv4 routing table for VPN instance vpnb of an SRv6 network with distributed gateways.
<Sysname> display evpn routing-table vpn-instance vpnb
VPN instance: vpnb
Local SID : BC10:0300:1000:0020:0200:0300:0100:0034
IP address : 10.0.0.2
Nexthop : BC10:0300:1000:0020:0200:0300:0100:0035
NibID : 0x18000000
Flags : EA
Remote SID : BC10:0300:1000:0020:0200:0300:0100:0034
# Display the EVPN IPv4 routing table for the public instance of an EVPN network with distributed gateways.
<Sysname> display evpn routing-table public-instance
Public instance Local L3VNI: 3900
# Display the number of EVPN route entries in the IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1 count
# Display the EVPN IPv6 routing table for VPN instance vpna of an EVPN network with distributed gateways.
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
VPN instance: vpna Local L3VNI: 7
Outgoing interface : Vsi-interface3
Next hop : 1.1.1.1
NibID : 0x18000000
Flags : E
IPv6 address : BC10:0300:1000:0020:0200:0300:0100:0035
Next hop : 2.2.2.2
NibID : 0x18000001
Flags : E
Table 36 Command output
Local L3VNI |
L3 VXLAN ID associated with the VPN instance or the public instance. |
NibID |
Next hop ID. |
Local SID |
SID of the local SRv6 distributed gateway. |
Remote SID |
SID of a remote SRv6 distributed gateway. |
Flags |
Flags of the route: · E—The route carries a valid ESI. · A—An Ethernet auto-discovery route has been received. The ECMP routes to the next hop are ready to be issued. · L—A local active ESI exists. The remote route is not issued. |
display l2vpn forwarding evpn split-horizon
Use display l2vpn forwarding evpn split-horizon to display site-facing interfaces excluded from traffic forwarding by split horizon.
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | tunnel tunnel-number } [ slot slot-number ]
ac interface interface-type interface-number: Specifies a Layer 3 interface by its type and number. These parameters apply to EVPN VPLS.
tunnel tunnel-number: Specifies a VXLAN tunnel interface number. The value range is 0 to 20479. If you do not specify this option, the command displays all site-facing interfaces excluded from traffic forwarding by split horizon. This option applies to EVPN VXLAN.
slot slot-number: Specifies a card by its slot number.
# Display site-facing interfaces excluded from traffic forwarding for Tunnel 0.
<Sysname> display l2vpn forwarding evpn split-horizon tunnel 0
Tunnel name: 0
Total number of filtered interfaces: 2
Filtered interfaces:
GE1/0/1
GE1/0/2
Table 37 Command output
Tunnel name |
VXLAN tunnel interface name. |
Argument |
Filtered interfaces |
Site-facing interfaces that do not forward the flood traffic received from the VXLAN tunnel. |
esi
Use esi to assign an ESI to an interface.
Use undo esi to restore the default.
esi esi-id
undo esi
No ESI is assigned to an interface.
Interface view
An ESI uniquely identifies an ES. The links on interfaces, or VSIs with the same ESI belong to the same ES. Traffic of the ES can be distributed among the links for load sharing.
You can assign ESIs to a main interface and its subinterfaces.
· If you assign an ESI to a subinterface, the subinterface-specific ESI and ES configuration take precedence over those configured on the main interface. The ES configuration includes the following:
¡ evpn redundancy-mode.
¡ evpn df-election algorithm.
¡ evpn df-election preference.
¡ evpn df-election preference non-revertive.
¡ evpn timer es-delay.
· If you do not assign an ESI to a subinterface, it inherits the ESI and redundancy mode (if configured) of the main interface. In this scenario, the redundancy mode configured on the subinterface does not take effect.
You can assign an ESI to a VSI LDP PW or VSI static PW only if you do not specify the no-split-horizon or dci keyword when executing the peer command for the PW.
To modify the ESI of an interface or VSI, first use the undo esi command to delete the original ESI.
# Assign ESI 0000.0001.0002.0003.0004 to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] esi 0000.0001.0002.0003.0004
evpn encapsulation
Use evpn encapsulation to create an EVPN instance and enter its view, or enter the view of an existing EVPN instance.
Use undo evpn encapsulation to restore the default.
In VSI view:
evpn encapsulation [ mpls | vxlan ]
In cross-connect group view:
evpn encapsulation mpls
No EVPN instance exists.
VSI view
Cross-connect group view
mpls: Specifies MPLS encapsulation.
vxlan: Specifies VXLAN encapsulation.
Before you can configure EVPN settings, you must create an EVPN instance.
This command is mutually exclusive with the evpn encapsulation binding instance command on a VSI.
# Create a VSI EVPN instance and enter its view.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan]
evpn global-mac
Use evpn global-mac to configure the EVPN global MAC address.
Use undo evpn global-mac to restore the default.
evpn global-mac mac-address
No EVPN global MAC address is configured.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address, broadcast MAC address, or all-zeros MAC address.
The EVPN global MAC address is used only by VSI interfaces associated with an L3 VXLAN ID.
For a VSI interface associated with an L3 VXLAN ID, the MAC address assigned to it by using the mac-address command takes precedence over the EVPN global MAC address.
Do not use a reserved MAC address as the EVPN global MAC address.
# Configure the EVPN global MAC address as 0001-0001-0001.
[Sysname] evpn global-mac 1-1-1
evpn df-election ac-influence enable
Use evpn df-election ac-influence enable to enable AC state-based DF election.
Use undo evpn df-election ac-influence enable to disable AC state-based DF election.
AC state-based DF election is disabled.
Application scenarios
At a multihomed EVPN network site, all PEs or VTEPs attached to an ES participate in DF election by default, regardless of their AC states. If the AC on the PE or VTEP elected as the DF is down, traffic forwarding will fail. You can configure AC state-based DF election to resolve this issue.
Operating mechanism
After you configure AC state-based DF election, a PE or VTEP participates in DF election only when the AC on the PE or VTEP is up. A PE or VTEP determines that the AC on the remote PE or VTEP is up only when it receives AD per ES and AD per EVI routes from the remote PE or VTEP.
AC state-based DF election takes effect only after you enable this feature on all PEs or VTEPs attached to an ES.
# Enable AC state-based DF election.
[Sysname] evpn df-election ac-influence enable
evpn df-election algorithm (interface view)
Use evpn df-election algorithm to configure the DF election algorithm on an interface.
Use undo evpn df-election algorithm to restore the default.
evpn df-election algorithm algorithm
The DF election algorithm specified in system view takes effect.
Interface view
Algorithm: Specifies a DF election algorithm. The value of this argument can only be preference, which represents the preference-based algorithm.
At a multihomed EVPN network site, you can modify the DF election algorithm with this command to control the DF election result.
You can configure the DF election algorithm in system view and in interface view. The global DF election algorithm takes effect on all ESs, and the interface-specific DF election algorithm takes effect only on the ESs on an interface. The interface-specific DF election algorithm takes precedence over the global DF election algorithm.
# Configure GigabitEthernet 1/0/1 to use the preference-based algorithm for DF election.
[Sysname-GigabitEthernet1/0/1] evpn df-election algorithm preference
evpn df-election algorithm (system view)
Use evpn df-election algorithm to configure the DF election algorithm globally.
The VLAN tag-based algorithm is used for DF election.
# Configure the global DF election algorithm as the preference-based algorithm.
[Sysname] evpn df-election algorithm preference
Use evpn df-election preference to set the DF election preference.
Use undo evpn df-election preference to restore the default.
evpn df-election preference preference
The DF election preference is 32767.
Interface view
Preference: Sets the DF election preference in the range of 0 to 65535. The larger the value, the higher the preference.
Use this command to set the preference used in preference-based DF election. The device with higher preference will be elected as the DF.
This command takes effect after the evpn df-election algorithm preference command is executed in interface view or system view.
# Set the DF election preference to 100.
[Sysname-GigabitEthernet1/0/1] evpn df-election preference 100
Use evpn df-election preference non-revertive to enable non-revertive mode for preference-based DF election.
Use undo evpn df-election preference non-revertive to disable non-revertive mode for preference-based DF election.
Non-revertive mode is disabled for preference-based DF election.
Interface view
Preference-based DF election selects the device with the highest preference as the DF. The BDF takes over the DF role if one of the following events occurs:
· The DF fails.
· The site-facing link on the DF fails.
· The DF election preference of the BDF is set to be higher than that of the DF.
When the original DF or its site-facing link recovers, or its preference is set to be higher than that of the new DF, the original DF will take over the DF role. To avoid undesired traffic loss, you can disable reversion to the original DF by enabling non-revertive mode for preference-based DF election.
# Enable non-revertive mode for preference-based DF election.
[Sysname-GigabitEthernet1/0/1] evpn df-election preference non-revertive
evpn irb asymmetric
Use evpn irb asymmetric to enable asymmetric IRB for EVPN VXLAN.
Use undo evpn irb asymmetric to restore the default.
evpn irb asymmetric [ route-policy route-policy-name ]
Symmetric IRB is enabled for EVPN VXLAN.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The device will perform asymmetric IRB forwarding for the traffic that matches the routing policy. If you do not specify a routing policy or the specified routing policy does not exist, the device performs asymmetric IRB forwarding for all traffic.
Use this command to set the IRB mode for EVPN VXLAN.
# Enable asymmetric IRB for EVPN VXLAN.
[Sysname] evpn irb asymmetric
evpn local-service-id remote-service-id
Use evpn local-service-id remote-service-id to create an EVPN PW.
Use undo evpn local-service-id remote-service-id to delete an EVPN PW.
evpn local-service-id local-service-id remote-service-id remote-service-id [ tunnel-policy tunnel-policy-name ] [ pw-class class-name ]
undo evpn local-service-id local-service-id remote-service-id remote-service-id
No EVPN PWs exist.
Cross-connect view
local-service-id: Specifies a local service ID in the range of 1 to 16777215.
remote-service-id: Specifies a remote service ID in the range of 1 to 16777215.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the PW uses the default tunnel policy.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW data encapsulation type and control word for the PW. If you do not specify a PW class, the PW data encapsulation type is determined by the link type of the interface. The control word feature is not supported for PW data encapsulation types that do not require using control word.
You can use the evpn local-service-id remote-service-id command to concatenate two EVPN PWs on the same cross-connect.
To modify an EVPN PW, first use the undo evpn local-service-id remote-service-id command to delete the original EVPN PW.
If you set up an EVPN PW with a redundant PE at the local site, the device uses the BFD configuration in the PW class specified in the evpn local-service-id remote-service-id command.
· If the EVPN PW is a primary EVPN PW, the device establishes a dynamic BFD session for the EVPN PW.
· If the EVPN PW is a backup or ECMP EVPN PW, the device does not establish a dynamic BFD session for the EVPN PW.
# Create an EVPN PW, and specify tunnel policy aaa and PW class bbb for it.
[Sysname] xconnect-group aaa
[Sysname-xcg-aaa] connection ac2pw
[Sysname-xcg-aaa-ac2pw] evpn local-service-id 2 remote-service-id 4 tunnel-policy aaa pw-class bbb
evpn mac-ip advertise distributed-gateway
Use evpn mac-ip advertise distributed-gateway to enable the device to advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
Use undo evpn mac-ip advertise distributed-gateway to disable the device from advertising ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
By default, the device does not advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
If a distributed EVPN gateway has downstream VTEPs attached, the gateway advertises ARP information for gateway interfaces through IP prefix advertisement routes. Because the VTEPs do not have gateway configuration, they cannot learn the ARP information for the gateway interfaces or forward traffic to the gateway. For the VTEPs to learn ARP information for the gateway interfaces, enable the distributed EVPN gateway to advertise ARP information for the gateway interfaces through MAC/IP advertisement routes.
# Enable the device to advertise ARP information for the distributed EVPN gateway interfaces through MAC/IP advertisement routes.
[Sysname] evpn mac-ip advertise distributed-gateway
Use evpn mpls routing-enable to enable EVPN to advertise the routes of a VPN instance.
Use undo evpn mpls routing-enable to disable EVPN from advertising the routes of a VPN instance.
EVPN does not advertise the routes of VPN instances.
VPN instance IPv4 address family view
VPN instance IPv6 address family view
This command enables devices to exchange the routes of a VPN instance by using IP prefix advertisement routes with MPLS encapsulation. After you execute this command for a VPN instance, the device advertises the routes of the VPN instance through IP prefix advertisement routes. When receiving IP prefix advertisement routes with MPLS encapsulation, the device adds the routes that belong to the VPN instance to the routing table.
For EVPN to add MPLS encapsulation to IP prefix advertisement routes, you must execute the peer advertise encap-type mpls command in BGP EVPN address family view.
# Enable EVPN to advertise the IPv4 routes of VPN instance vpna.
[Sysname-vpn-instance-vpna] address-family ipv4
[Sysname-vpn-ipv4-vpna] evpn mpls routing-enable
evpn multihoming advertise disable
Use evpn multihoming advertise disable to disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
Use undo evpn multihoming advertise disable to restore the default.
The device advertises EVPN multihoming routes.
EVPN multihoming routes include Ethernet auto-discovery routes and Ethernet segment routes.
In a multihomed EVPN network, execute this command on a redundant VTEP or PE before you reboot it. This operation allows other VTEPs or PEs to refresh their EVPN routing table to prevent traffic interruption caused by the reboot.
# Disable advertisement of EVPN multihoming routes and withdraw the EVPN multihoming routes that have been advertised to remote sites.
[Sysname] evpn multihoming advertise disable
evpn multihoming advertise ignore-ethernet-tag
Use evpn multihoming advertise ignore-ethernet-tag to enable the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes.
Use undo evpn multihoming advertise ignore-ethernet-tag to restore the default.
By default, the device advertises Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags.
Use this command on the redundant PEs at a dualhomed site.
This command enables the device to do the following:
· Withdraw the Ethernet auto-discovery routes and MAC/IP advertisement routes that have been advertised.
· Set the Ethernet tag to 0 for the Ethernet auto-discovery routes and MAC/IP advertisement routes and re-advertise them.
After you configure ESIs for ACs on the redundant edge devices at a dualhomed site, the edge devices advertise Ethernet auto-discovery routes and MAC/IP advertisement routes that carry Ethernet tags. If the remote peers are unable to identify Ethernet tags, you must execute this command on the redundant edge devices to enable communication with the peers.
When you use this command, follow these restrictions and guidelines:
· After you assign an ESI to a Layer 2 Ethernet or aggregate interface, you must map the Ethernet service instances created on the interface to different VSIs. If two interfaces use the same ESI, you must map the Ethernet service instances created on them to different VSIs.
· After you assign an ESI to a Layer 3 main interface, its subinterfaces inherit the ESI if they do not have one. In addition, you must map two subinterfaces to different VSIs if the subinterfaces have the same ESI.
# Enable the device to ignore the Ethernet tag when advertising Ethernet auto-discovery routes and MAC/IP advertisement routes.
[Sysname] evpn multihoming advertise ignore-ethernet-tag
esi
evpn multihoming timer df-delay
Use evpn multihoming timer df-delay to set the DF election delay.
Use undo evpn multihoming timer df-delay to restore the default.
evpn multihoming timer df-delay delay-value
The DF election delay is 3 seconds.
delay-value: Specifies the DF election delay, in the range of 1 to 1200 seconds.
DF election delay defines the minimum interval allowed between two DF elections.
The DF election can be triggered by site-facing interface status changes, redundant VTEP or PE membership changes, and interface ESI changes. To prevent frequent DF elections from degrading network performance, set the DF election delay.
To fast elect a DF and avoid traffic interruption upon DF failure, set the DF election delay to 0 seconds.
# Set the DF election delay to 5 seconds.
[Sysname] evpn multihoming timer df-delay 5
Use evpn route arp-mobility suppression to enable ARP mobility event suppression.
Use undo evpn route arp-mobility suppression to disable ARP mobility event suppression.
evpn route arp-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
ARP mobility event suppression is disabled.
EVPN instance view
VSI EVPN instance view
Layer 3 interface view
detect-cycle detect-time: Sets the ARP mobility detection cycle in seconds, in the range of 60 to 900. The default value is 180 seconds.
detect-threshold move-times: Sets the ARP mobility suppression threshold, in the range of 3 to 10. The default is 5. This threshold is the number of ARP moves from the local site to remote sites.
suppression-time: Sets the ARP mobility suppression time. A suppressed ARP entry cannot move until the ARP mobility suppression time expires. If you do not set this parameter, the default setting permanent applies.
suppression-time: Specifies the ARP mobility suppression time in seconds, in the range of 120 to 3600 seconds.
permanent: Suppresses ARP moves permanently.
On an EVPN VXLAN network, misconfiguration of IP addresses might cause two sites to contain the same IP address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN ARP entries and determine that ARP mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ARP entry synchronization traffic. To eliminate loops and suppress those ARP mobility events, enable ARP mobility event suppression on the VTEPs.
The ARP mobility event suppression feature allows an IP address to move at most the specified number of times (ARP mobility suppression threshold) out of a site within an ARP mobility detection cycle. If the suppression threshold has been reached for an IP address within a detection cycle, the VTEP at the site suppresses the subsequent move after the IP address moves back to the site. In addition, the VTEP learns ARP information for the IP address but does not advertise the ARP information.
After you execute the undo evpn route arp-mobility suppression command or when the ARP mobility suppression time expires, a VTEP acts as follows:
· Advertises ARP information immediately for the suppressed ARP entries that have not aged out.
· Relearns ARP information for the suppressed ARP entries that have aged out and advertises the ARP information.
ARP mobility event suppression takes effect only on an EVPN VXLAN network configured with distributed VXLAN IP gateways.
The ARP mobility event suppression setting configured in system view takes effect on all EVPN instances. The ARP mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The ARP mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The ARP mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The ARP mobility event suppression settings configured in the following views are in descending order of priority:
1. Layer 3 interface view.
2. EVPN instance view or VSI EVPN instance view.
3. System view.
# Enable ARP mobility event suppression.
[Sysname] evpn route arp-mobility suppression
Use evpn route mac-mobility suppression to enable MAC mobility event suppression.
Use undo evpn route mac-mobility suppression to disable MAC mobility event suppression.
evpn route mac-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
MAC mobility event suppression is disabled.
EVPN instance view
detect-cycle detect-time: Sets the MAC mobility detection cycle in seconds, in the range of 60 to 900. The default value is 180 seconds.
detect-threshold move-times: Sets the MAC mobility suppression threshold, in the range of 3 to 10. The default is 5. This threshold is the number of MAC moves from the local site to remote sites.
suppression-time: Sets the MAC mobility suppression time. A suppressed MAC entry cannot move until the MAC mobility suppression time expires. If you do not set this parameter, the default setting permanent applies.
suppression-time: Specifies the MAC mobility suppression time in seconds, in the range of 120 to 3600 seconds.
permanent: Suppresses MAC moves permanently.
On an EVPN VXLAN network, misconfiguration of MAC addresses might cause two sites to contain the same MAC address. In this condition, VTEPs or PEs at the two sites constantly synchronize and update EVPN MAC entries and determine that MAC mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by MAC entry synchronization traffic. To eliminate loops and suppress those MAC mobility events, enable MAC mobility event suppression on the VTEPs or PEs.
The MAC mobility event suppression feature allows a MAC address to move at most the specified number of times (MAC mobility suppression threshold) out of a site within an MAC mobility detection cycle. If the suppression threshold has been reached for a MAC address within a detection cycle, the VTEP or PE at the site suppresses the subsequent move after the MAC address moves back to the site. In addition, the VTEP or PE learns the MAC address but does not advertise it.
After you execute the undo evpn route mac-mobility suppression command or when the MAC mobility suppression time expires, a VTEP or PE acts as follows:
· Advertises MAC address entries immediately for the suppressed MAC address entries that have not aged out.
· Relearns the MAC addresses for the suppressed MAC address entries that have aged out and advertises the MAC address entries.
The MAC mobility event suppression setting configured in system view takes effect on all EVPN instances. The MAC mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The MAC mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The MAC mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The MAC mobility event suppression settings configured in the following views are in descending order of priority:
3. System view.
# Enable MAC mobility event suppression.
[Sysname] evpn route mac-mobility suppression
Use evpn route nd-mobility suppression to enable ND mobility event suppression.
Use undo evpn route nd-mobility suppression to disable ND mobility event suppression.
evpn route nd-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
ND mobility event suppression is disabled.
EVPN instance view
detect-cycle detect-time: Specifies the ND mobility detection cycle in seconds. The value range for the detect-time argument is 60 to 900, and the default is 180.
detect-threshold move-times: Specifies the ND mobility suppression threshold, which is the number of ND moves from the local site to a remote site. The value range for the move-times argument is 3 to 10, and the default is 5.
suppression-time: Specifies the length of time that an ND entry is suppressed. After the suppression time expires, the ND entry can move again. The default suppression time is permanent.
suppression-time: Specifies the suppression time in seconds. The value range for this argument is 120 to 3600.
permanent: Suppresses ND moves permanently.
On an EVPN VXLAN network, misconfiguration of IP addresses might cause two sites to contain the same IP address. In this condition, VTEPs at the two sites constantly synchronize and update EVPN ND entries and determine that ND mobility events occur. As a result, an inter-site loop might occur, and the bandwidth is occupied by ND entry synchronization traffic. To eliminate loops and suppress those ND mobility events, enable ND mobility event suppression on the VTEPs. This feature allows an IP address to move a specified number of times (the ND mobility suppression threshold) from a site within an ND mobility detection cycle. If an IP address moves more than the ND mobility suppression threshold, the VTEP at the site will suppress the last ND move to the local site and will not advertise ND information for the IP address.
After you execute the undo evpn route nd-mobility suppression command or the suppression time expires, a VTEP acts as follows:
· Advertises ND information immediately for the suppressed ND entries that have not aged out.
· Relearns ND information for the suppressed ND entries that have aged out and advertises the ND information.
ND mobility event suppression takes effect only on the following networks:
· EVPN VXLAN network enabled with ND flood suppression.
· EVPN VXLAN network configured with distributed VXLAN IP gateways.
The ND mobility event suppression setting configured in system view takes effect on all EVPN instances. The ND mobility event suppression setting configured in EVPN instance view takes effect on all associated VSIs. The ND mobility event suppression setting configured in VSI EVPN instance view takes effect only on the associated VSI. The ND mobility event suppression setting configured in Layer 3 interface view takes effect only on that interface.
The ND mobility event suppression settings configured in the following views are in descending order of priority:
3. System view.
# Enable ND mobility event suppression.
[Sysname] evpn route nd-mobility suppression
evpn span-segment disable
Use evpn span-segment disable to disable a VSI interface from learning ARP or ND information that does not belong to its subnet from MAC/IP advertisement routes.
Use undo evpn span-segment disable to restore the default.
evpn span-segment { arp-learning | nd-learning } disable
undo evpn span-segment { arp-learning | nd-learning } disable
On a centralized EVPN gateway, a VSI interface can learn the ARP or ND information that does not belong to its subnet from MAC/IP advertisement routes.
VSI interface view
arp-learning: Disables ARP learning.
nd-learning: Disables ND learning.
On an EVPN VXLAN network deployed with a centralized EVPN gateway, VM 1 and VM 2 belong to the same VXLAN in subnet 10.1.1.0/24. The gateway interface is VSI-interface 1 and the gateway is connected to external Layer 3 network 10.1.2.0/24. The VTEP to which VM 2 is attached is configured with ARP or ND flood suppression. The IP address of VM 2 is mistakenly configured as an IP address in subnet 10.1.2.0/24 (for example, 10.1.2.2). In this situation, the VTEP connected to VM 2 advertises MAC/IP advertisement routes that contain ARP or ND information to the gateway. The IP address and MAC address in the routes are the IP address and MAC address of VM 2, respectively. The gateway learns the ARP or ND information and issues the information to the forwarding table. When VM 1 visits 10.1.2.2 in the external network, the gateway will forward the traffic to VM 2. As a result, VM 1 cannot visit 10.1.2.2.
To resolve the above issue, perform this task on the VSI interface to disable the VSI interface from learning ARP or ND information across subnets from MAC/IP advertisement routes.
# Disable a VSI-interface 1 from learning ARP or ND information that does not belong to its subnet from MAC/IP advertisement routes.
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] evpn span-segment arp-learning disable
evpn timer es-delay
Use evpn timer es-delay to set the advertisement delay timer for Ethernet segment routes.
Use undo evpn timer es-delay to delete the advertisement delay setting for Ethernet segment routes.
evpn timer es-delay delay-time
Advertisement of Ethernet segment routes is not delayed.
Interface view
delay-time: Specifies a delay value in the range of 3 to 1200 seconds.
Use this command in combination with the evpn track peer command.
The evpn track peer command excludes unavailable edge devices from DF election at a multihomed site. After an edge device recovers from failure and brings up its CE-facing interface, it starts the advertisement delay timer for Ethernet segment routes and checks the status of the BGP peer specified in this command. If the BGP peer comes up before the timer expires, the edge device advertises Ethernet segment routes to the peer. If the BGP peer is still down when the timer expires, the edge device does not advertise Ethernet segment routes to the peer. The edge devices then perform DF election based on the Ethernet segment routes they have received.
# On GigabitEthernet 1/0/1, set the advertisement delay timer for Ethernet segment routes to 300 seconds.
[Sysname-GigabitEthernet1/0/1] evpn timer es-delay 300
evpn track peer
evpn timer es-recovery
Use evpn timer es-recovery to set the ES route advertisement delay.
Use undo evpn timer es-recovery to restore the default.
evpn timer es-recovery recovery-time
ES route advertisement delay is disabled when preference-based DF election is used.
Interface view
recovery-time: Sets the ES route advertisement delay in the range of 3 to 1200 seconds.
When the DF restarts or the process restarts and a new DF is elected, the original DF will immediately advertise ES routes after the restart to become the DF again. However, access-side connections restore slowly and packet loss might occur after DF switchover. To resolve this issue, set the ES route advertisement delay.
As a best practice, configure this feature when the all-active redundancy mode is used. Do not configure this feature when the single-active redundancy mode is used.
# Set the ES route advertisement delay to 300 seconds.
[Sysname-GigabitEthernet1/0/1] evpn timer es-recovery 300
evpn track peer
Use evpn track peer to enable the device to monitor the BGP peer status of another local edge device.
Use undo evpn track peer to restore the default.
evpn track peer { peer-ipv4-address | peer-ipv6-address }
At a multihomed site, the device does not monitor the BGP peer status of the other edge devices.
Interface view
peer-ipv4-address: Specifies a VTEP or PE by its IPv4 address.
peer-ipv6-address: Specifies a VTEP or PE by its IPv6 address.
Use this command on the CE-facing interfaces of the edge devices multihomed to a site to prevent device reboots from causing inter-site forwarding failure.
This command excludes unavailable edge devices from DF election at a multihomed site. After an edge device recovers from failure and brings up its CE-facing interface, it starts the advertisement delay timer for Ethernet segment routes and checks the status of the BGP peer specified in this command. If the BGP peer comes up before the timer expires, the edge device advertises Ethernet segment routes to the peer. If the BGP peer is still down when the timer expires, the edge device does not advertise Ethernet segment routes to the peer. The edge devices then perform DF election based on the Ethernet segment routes they have received.
# On GigabitEthernet 1/0/1, enable the device to monitor the BGP peer at 1.1.1.1.
[Sysname-GigabitEthernet1/0/1] evpn track peer 1.1.1.1
evpn timer es-delay
export route-policy
Use export route-policy to apply an export routing policy to EVPN.
Use undo export route-policy to restore the default.
No export routing policy is applied to EVPN.
EVPN instance view
Cross-connect group EVPN instance view
VPN instance EVPN view
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter BGP EVPN routes advertised by an EVPN instance or VPN instance or modify their route attributes.
If you execute this command multiple times in the same view, the most recent configuration takes effect.
EVPN can use an export routing policy specified in EVPN instance view, VSI EVPN instance view, cross-connect group EVPN instance view, VPN instance view, or VPN instance EVPN view.
Export routing policy configuration in EVPN instance view, VSI EVPN instance view, or cross-connect group EVPN instance view is used for Layer 2 forwarding.
Export routing policy configuration in VPN instance view or VPN instance EVPN view is used for Layer 3 forwarding. An export routing policy configured in VPN instance EVPN view takes precedence over that configured in VPN instance view.
# Apply export routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
route-policy (Layer 3—IP Routing Command Reference)
igp-metric inherit
Use igp-metric inherit to set the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
Use undo igp-metric inherit to restore the default.
igp-metric inherit
The device sets the metric to 0 when adding BGP EVPN routes a VPN instance's routing table.
After you execute this command, the device sets the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
# Set the metric of a BGP EVPN route added to a VPN instance's routing table to the metric of the IGP route pointing to the next hop in the original BGP EVPN route.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] igp-metric inherit
import evpn mac-ip
Use import evpn mac-ip to enable the device to redistribute received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table and advertise the routes.
Use undo import evpn mac-ip to restore the default.
import evpn mac-ip
For EVPN VXLAN, received MAC/IP advertisement routes (carrying VXLAN IDs) that contain ARP or ND information are not redistributed into any BGP unicast routing table.
For SRv6, received MAC/IP advertisement routes (carrying SIDs) that contain ARP or ND information are redistributed into BGP unicast routing tables, but the routes are not advertised.
BGP IPv4 unicast address family view
BGP IPv6 unicast address family view
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
This command enables the device to redistribute received MAC/IP advertisement routes that contain ARP or ND information into a BGP unicast routing table.
· If you use this command in BGP IPv4 or IPv6 unicast address family view, the device will redistribute the routes into the BGP IPv4 or IPv6 unicast routing table. In addition, the device will advertise the routes to the local site.
· If you use this command in BGP-VPN IPv4 or IPv6 unicast address family view, the device will redistribute the routes into the BGP-VPN IPv4 or IPv6 unicast routing table of the corresponding VPN instance. To advertise the routes to the local site, you must configure the advertise l2vpn evpn command.
# Redistribute received MAC/IP advertisement routes into the BGP-VPN IPv4 unicast routing table of VPN instance vpna and advertise the routes.
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
import route-policy
Use import route-policy to apply an import routing policy to EVPN.
Use undo import route-policy to restore the default.
No import routing policy is applied to EVPN. A VPN instance accepts a route when the export route targets of the route match local import route targets.
EVPN instance view
You can specify an import routing policy to filter BGP EVPN routes received by an EVPN instance or VPN instance or modify their route attributes.
EVPN can use an import routing policy specified in EVPN instance view, VSI EVPN instance view, cross-connect group EVPN instance view, VPN instance view, or VPN instance EVPN view.
Import routing policy configuration in EVPN instance view, VSI EVPN instance view, or cross-connect group EVPN instance view is used for Layer 2 forwarding.
Import routing policy configuration in VPN instance view or VPN instance EVPN view is used for Layer 3 forwarding. An import routing policy configured in VPN instance EVPN view takes precedence over that configured in VPN instance view.
# Apply import routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
ip public-instance
Use ip public-instance to create the public instance and enter its view, or enter the view of the existing public instance.
Use undo ip public-instance to delete the public instance.
ip public-instance
The public instance does not exist.
A distributed EVPN gateway uses the public instance to perform Layer 3 forwarding for the public network and to enable communication between private and public networks. The public instance is similar to a VPN instance. A distributed EVPN gateway processes traffic of the public instance in the same way it does for a VPN instance.
# Create the public instance and enter its view.
[Sysname] ip public-instance
[Sysname-public-instance]
ipv6 nd ra tunnel-broadcast global enable
Use ipv6 nd ra tunnel-broadcast global enable to globally enable VSI interfaces to send RA messages over VXLAN tunnels.
Use undo ipv6 nd ra tunnel-broadcast global enable to globally disable VSI interfaces from sending RA messages over VXLAN tunnels.
VSI interfaces do not send RA messages over VXLAN tunnels.
By default, a distributed EVPN gateway drops the RS messages received from VXLAN tunnels and periodically advertises RA messages only to the local site. As a result, a distributed EVPN gateway does not send RA messages over VXLAN tunnels, and remote gateways cannot update information about the gateway based on RA messages. To resolve the issue, use this command to enable distributed EVPN gateways to reply to remote RS messages with RA messages and periodically advertise RA messages over VXLAN tunnels.
# Globally enable VSI interfaces to send RA messages over VXLAN tunnels.
[Sysname] ipv6 nd ra tunnel-broadcast global enable
ipv6 nd ra interval (Layer 3—IP Services Command Reference)
l3-vni
Use l3-vni to configure an L3 VXLAN ID for a VSI interface or for the public instance.
Use undo l3-vni to remove the L3 VXLAN ID for a VSI interface or for the public instance.
l3-vni vxlan-id
undo l3-vni
No L3 VXLAN ID is configured for a VSI interface or for the public instance.
VSI interface view
Public instance view
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215.
On distributed EVPN gateways, you must configure L3 VXLAN IDs for the gateways to differentiate traffic of different VPN instances.
To forward Layer 3 traffic of a VPN instance, you must assign an L3 VXLAN ID to the VSI interface of the VPN instance. To forward Layer 3 traffic of the public network, you must assign the same L3 VXLAN ID to the public instance and the VSI interface of the public instance.
To modify the L3 VXLAN ID for the public instance, you must first delete the original L3 VXLAN ID.
The L3 VXLAN ID specified by using this command cannot be the same as any VXLAN ID specified by using the mapping vni command.
# Configure the L3 VXLAN ID as 1000 for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] l3-vni 1000
mac-advertising disable
Use mac-advertising disable to disable MAC address advertisement and withdraw advertised MAC addresses.
Use undo mac-advertising disable to restore the default.
MAC address advertisement is enabled.
EVPN instance view
The MAC information and ARP information advertised by the VTEP or PE overlap. To avoid duplication, use this command to disable MAC address advertisement and withdraw the MAC addresses advertised to remote devices.
# Disable MAC address advertisement and withdraw advertised MAC addresses for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
nd-advertising enable
Use nd-advertising enable to enable ND information advertisement.
Use undo nd-advertising enable to disable ND information advertisement and withdraw advertised ND information.
ND information advertisement is enabled.
EVPN instance view
In an EVPN network with distributed gateways, you can disable ND information advertisement for a VXLAN to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN will stop advertising ND information through MAC/IP advertisement routes and withdraw advertised ND information. When ND information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
# Disable ND information advertisement for a VSI EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] undo nd-advertising enable
nd mac-learning disable
Use nd mac-learning disable to disable a VSI EVPN instance from learning MAC addresses from ND information.
Use undo nd mac-learning disable to restore the default.
A VSI EVPN instance learns MAC addresses from ND information.
EVPN instance view
The MAC information and ND information advertised by a remote VTEP or PE overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ND information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable a VSI EVPN instance from learning MAC addresses from ND information.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] nd mac-learning disable
Use peer advertise encap-type mpls to enable MPLS encapsulation for the BGP EVPN routes advertised to a peer or peer group.
Use undo peer advertise encap-type mpls to disable MPLS encapsulation for the BGP EVPN routes advertised to a peer or peer group.
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
undo peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
BGP EVPN routes use VXLAN encapsulation.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv4-address: Specifies a peer by its IPv4 address. the peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
Execute this command on the edge nodes of an EVPN L3VPN network and RRs. On the edge nodes, you must use this command together with the evpn mpls routing-enable command.
# Enable MPLS encapsulation for the BGP EVPN routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
peer advertise vpn-reoriginate ibgp (BGP EVPN address family view)
Use peer advertise vpn-reoriginate ibgp to enable advertising the IP prefix advertisement routes reoriginated for a VPN instance to an IBGP peer or peer group.
Use undo peer advertise vpn-reoriginate ibgp to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise vpn-reoriginate ibgp
undo { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } peer advertise vpn-reoriginate ibgp
The device does not advertise the IP prefix advertisement routes reoriginated for a VPN instance to IBGP peers or peer groups.
ipv4-address: Specifies a peer by its IPv4 address. The peer must exist.
For this command to take effect, you must also execute the advertise route-reoriginate command.
This command enables the device to advertise the IP prefix advertisement routes reoriginated for VPN instances to IBGP peers after the advertise route-reoriginate command is executed for the VPN instances.
# Enable advertising the IP prefix advertisement routes reoriginated for VPN instances to IBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise vpn-reoriginate ibgp
advertise route-reoriginate (MPLS Command Reference)
peer default-gateway no-advertise
Use peer default-gateway no-advertise to remove the default-gateway extended community attribute from the EVPN gateway routes advertised to a peer or peer group.
Use undo peer default-gateway no-advertise to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
EVPN gateway routes advertised to peers and peer groups contain the default-gateway extended community attribute.
An EVPN gateway route is the route for the IP address of a VSI interface on an EVPN gateway. By default, the EVPN gateway routes advertised by an EVPN gateway contain the default-gateway extended community attribute. The EVPN gateway routes with that attribute cannot be used as ECMP routes. You can use this command to remove the default-gateway extended community attribute from EVPN gateway routes for the routes to be used for load sharing.
# Remove the default-gateway extended community attribute from the EVPN gateway routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 default-gateway no-advertise
peer re-originated
Use peer re-originated to enable the device to reoriginate BGP EVPN routes based on the BGP EVPN routes received from a peer or peer group.
Use undo peer re-originated to disable the device from reoriginating BGP EVPN routes based on the BGP EVPN routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ imet | mac-ip ] [ replace-rt ]
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] [ replace-rt ] [ replace-sid ]
peer { group-name | ipv4-address [ mask-length ] } re-originated [ s-pmsi | smet ] [ replace-rt ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ imet | ip-prefix | mac-ip ]
undo peer { group-name | ipv4-address [ mask-length ] } re-originated [ s-pmsi | smet ]
The device does not reoriginate BGP EVPN routes based on received BGP EVPN routes.
imet: Specifies IMET routes.
ip-prefix: Specifies IP prefix advertisement routes.
mac-ip: Specifies MAC/IP advertisement routes.
s-pmsi: Specifies S-PMSI routes.
smet: Specifies SMET routes.
replace-rt: Performs the following actions on IP prefix advertisement routes that match the route targets of a local VPN instance:
· Replaces the L3 VXLAN ID, RD, and route targets of the IP prefix advertisement routes with those of the matching local VPN instance.
· Adds MPLS labels or SRv6 SIDs to the routes, or requests SRv6 SIDs for the routes from the matching local VPN instance.
If you do not specify this keyword, only the L3 VXLAN ID and RD will be replaced, MPLS labels or SRv6 SIDs will be added, or SRv6 SIDs will be requested for the routes from the matching local VPN instance.
replace-sid: Deletes SRv6 SIDs from the received BGP EVPN routes that match the route targets of a local VPN instance, and requests SRv6 SIDs for the routes from the matching local VPN instance. If you do not specify this keyword, the SRv6 SIDs of received BGP EVPN routes will not be modified.
Application scenarios and operating mechanism for EVPN
In an EVPN-DCI network, use this command to hide the L3 VXLAN IDs of data centers or enable communication between data centers that use different L3 VXLAN IDs.
After you execute this command on an ED, the ED performs the following operations after receiving BGP EVPN routes from a VTEP or remote ED:
1. Matches the route targets of the routes with the import route targets of local VPN instances.
2. Replaces the L3 VXLAN ID and RD of the routes with those of the matching local VPN instance.
3. Advertises the routes to a VTEP or remote ED.
Application scenarios and operating mechanism for SRv6
In a network with inter-AS SRv6 VPN deployed in multiple ASs, you can specify the replace-sid keyword to disable inter-AS advertisement of locator network routes for security purposes. SRv6 forwarding path setup between PEs of different ASs will not be affected.
After you execute this command, an ED advertises only reoriginated BGP EVPN routes. The original BGP EVPN routes are not advertised.
If the RD of a received BGP EVPN route is identical to the RD of the matching local VPN instance, an ED does not replace the L3 VXLAN ID of the route or reoriginate the route. As a result, the ED does not advertise the route. As a best practice, assign unique RDs to VPN instances on different EVPN gateways and EDs when you use this command.
If you do not specify a route type, this command applies to IP prefix advertisement routes.
# Replace the L3 VXLAN ID and RD of the BGP EVPN routes received from peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated ip-prefix
peer advertise original-route
peer suppress re-originated
peer suppress original-route
Use peer suppress original-route to suppress advertisement of original BGP EVPN routes to a peer or peer group and withdraw advertised original BGP EVPN routes.
Use undo suppress original-route to disable suppression of original BGP EVPN route advertisement to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress original-route { auto-discovery | es | imet }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress original-route { auto-discovery | es | imet }
The device advertises original BGP EVPN routes to peers and peer groups.
mask-length: Specifies a mask length in the range of 0 to 32. To specify all dynamic peers in a subnet, you must specify both the ipv4-address and mask-length arguments.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify all dynamic peers in a subnet, you must specify both the ipv6-address and prefix-length arguments.
auto-discovery: Specifies original Ethernet auto-discovery routes.
es: Specifies original ES routes.
imet: Specifies original IMET routes.
# In BGP EVPN address family view, suppress advertisement of original Ethernet auto-discovery routes to the peer at 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 suppress original-route auto-discovery
policy vpn-target
Use policy vpn-target to enable route target filtering for BGP EVPN routes.
Use undo policy vpn-target to disable route target filtering for BGP EVPN routes.
policy vpn-target
Route target filtering is enabled for BGP EVPN routes.
When route target filtering is enabled for BGP EVPN routes, the EVPN routing table accepts only BGP EVPN routes of which the export route targets match the local import route targets. If the device must save all BGP EVPN routes, use the undo policy vpn-target command to disable route target filtering for BGP EVPN routes.
# Disable route target filtering for BGP EVPN routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
pw-class
Use pw-class to specify a PW class for a VSI EVPN instance.
Use undo pw-class to restore the default.
pw-class class-name
undo pw-class
No PW class is specified for a VSI EVPN instance.
EVPN instance view
This command is supported whether a VSI EVPN instance uses MPLS encapsulation or SRv6 encapsulation.
The specified PW class will be used to establish all PWs on the VSI EVPN instance.
In EVPN instance view, the specified PW class takes effect on all VSIs associated with the EVPN instance.
# Specify PW class pw100 for the EVPN instance that uses MPLS encapsulation on VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation mpls
[Sysname-vsi-vpna-evpn-mpls] pw-class pw100
# Specify PW class pw100 for the EVPN instance that uses SRv6 encapsulation on VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation srv6
[Sysname-vsi-vpna-evpn-srv6] pw-class pw100
reset evpn route arp-mobility suppression
Use reset evpn route arp-mobility suppression to cancel ARP mobility event suppression.
reset evpn route arp-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ip ip-address ] ]
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
ip ip-address: Specifies an IPv4 address in dotted decimal notation. If you do not specify an IPv4 address, this command cancels the suppression done on all ARP entries of the public instance or specified MPLS L3VPN instance.
Use this command to cancel the ARP mobility event suppression done on IPv4 addresses. After you cancel suppression for an IPv4 address, the IPv4 address can move between sites, and the device advertises ARP information for the IPv4 address. The device still suppresses the IPv4 address if the suppression criteria are met.
If you do not specify the public instance or an MPLS L3VPN instance, this command cancels ARP mobility event suppression for the public instance and all MPLS L3VPN instances.
# Cancel the ARP mobility event suppression done on 1.1.1.1 of VPN instance vpna.
<Sysname> reset evpn route arp-mobility suppression vpn-instance vpna ip 1.1.1.1
display evpn route arp-mobility
reset evpn route mac-mobility suppression
Use reset evpn route mac-mobility suppression to cancel MAC mobility event suppression.
reset evpn route mac-mobility suppression [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac mac-address ]
evpn-instance instance-name: Specifies an EVPN instance by its name, a case-sensitive string of 1 to 31 characters.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command cancels suppression on MAC addresses for all VSIs.
mac mac-address: Specifies a MAC address in the format of H-H-H. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a MAC address, this command cancels suppression all MAC addresses of the specified VSI.
This command is a one-time command.
This command allows the device to advertise suppressed MAC addresses of VSIs for one time. The device will continue suppressing MAC mobility events for the MAC addresses after you execute this command.
If you do not specify any parameters, this command advertises all suppressed MAC addresses.
# Cancel the MAC mobility event suppression done on 1-1-1 of VSI vpna.
<Sysname> reset evpn route mac-mobility suppression vsi vpna mac 1-1-1
display evpn route mac-mobility
reset evpn route nd-mobility suppression
Use reset evpn route nd-mobility suppression to cancel ND mobility event suppression.
reset evpn route nd-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ipv6 ipv6-address ] ]
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command cancels suppression on all ND entries of the public instance or specified MPLS L3VPN instance.
Use this command to cancel the ND mobility event suppression done on IPv6 addresses. After you cancel suppression for an IPv6 address, the IPv6 address can move between sites, and the device advertises ND information for the IPv6 address. The device still suppresses the IPv6 address if the suppression criteria are met.
If you do not specify the public instance or an MPLS L3VPN instance, this command cancels ND mobility event suppression for the public instance and all MPLS L3VPN instances.
# Cancel the ND mobility event suppression done on 1::1 of VPN instance vpna.
<Sysname> reset evpn route nd-mobility suppression vpn-instance vpna ipv6 1::1
display evpn route nd-mobility
route-distinguisher
Use route-distinguisher to configure an RD for an EVPN instance or public instance.
Use undo route-distinguisher to restore the default.
In public instance view, cross-connect group EVPN instance view, EVPN instance view, or VSI EVPN instance (non-VXLAN encapsulation) view:
In VSI EVPN instance (VXLAN encapsulation) view:
route-distinguisher { route-distinguisher | auto }
No RD is configured for an EVPN instance or public instance.
EVPN instance view
Public instance
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD cannot be all zeros and can use one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
auto: Automatically generates an RD in the N:VXLAN ID format. The initial value of N is 1. If N:VXLAN ID is already in use, the system increases the value of N by 1 until the RD is available.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses the RD to differentiate BGP EVPN routes of different EVPN instances.
To modify the RD, first execute the undo route-distinguisher command to remove the original RD.
# Configure 22:1 as the RD of an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
rr-filter { ext-comm-list-number | ext-comm-list-name }
undo rr-filter
An RR does not filter reflected BGP EVPN routes.
ext-comm-list-number: Specifies an extended community attribute list by its number in the range of 1 to 65535.
ext-comm-list-name: Specifies an extended community attribute list by its name, a case-sensitive string of 1 to 63 characters.
This command enables an RR to reflect only received BGP EVPN routes that match the attributes in the specified extended community attribute list.
If a cluster contains multiple RRs, you can configure different reflection policies on the RRs for load sharing among the RRs.
For more information about the extended community attribute list, see Layer 3—IP Routing Configuration Guide.
# Configure a reflection policy for the device to reflect BGP EVPN routes that match extended community attribute list 10.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
snmp-agent trap enable evpn
Use snmp-agent trap enable evpn to enable SNMP notifications for EVPN.
snmp-agent trap enable evpn [ mac-mobility-suppression ]
undo snmp-agent trap enable evpn [ mac-mobility-suppression ]
SNMP notifications are disabled for EVPN.
mac-mobility-suppression: Specifies the MAC mobility suppression notification.
If SNMP notifications are enabled for EVPN, a MAC mobility suppression notification is sent to SNMP module after the MAC mobility suppression threshold is reached. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
If you do not specify any parameter, all EVPN notifications are enabled or disabled.
# Enable SNMP notifications for EVPN.
[Sysname] snmp-agent trap enable evpn
tunnel-policy
Use tunnel-policy to specify a tunnel policy for a VSI EVPN instance.
Use undo tunnel-policy to restore the default.
undo tunnel-policy
No tunnel policy is specified for a VSI EVPN instance.
EVPN instance view
The PWs of the VSI EVPN instance use the specified tunnel policy to select public tunnels.
In EVPN instance view, the specified tunnel policy takes effect on all VSIs associated with the EVPN instance.
If you do not specify a tunnel policy or specify a nonexistent tunnel policy, the default tunnel policy applies. The default tunnel policy selects only one public tunnel for a PW in this order: LSP tunnel, GRE tunnel, CRLSP tunnel, and SRLSP tunnel.
# Specify tunnel policy policy1 for the EVPN instance on VSI aa.
[Sysname] vsi aa
[Sysname-vsi-aa] evpn encapsulation mpls
[Sysname-vsi-aa-evpn-mpls] tunnel-policy policy1
vpn-route cross multipath
Use vpn-route cross multipath to enable ECMP VPN route redistribution.
Use undo vpn-route cross multipath to disable ECMP VPN route redistribution.
ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table.
ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table.
# Enable ECMP VPN route redistribution.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
vpn-target
Use vpn-target to configure route targets for EVPN.
Use undo vpn-target to delete route targets for EVPN.
In VSI EVPN instance view (VXLAN encapsulation):
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN instance EVPN view, public instance view, public instance IPv4 address family view, public instance IPv6 address family view, public instance EVPN view, cross-connect group EVPN instance view, VSI EVPN instance view (non-VXLAN encapsulation), or EVPN instance view:
EVPN does not have route targets.
EVPN instance view
Public instance EVPN view
Public instance IPv4 address family view
Public instance IPv6 address family view
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets. Each route target is a string of 3 to 21 characters in one of the following formats:
auto: Automatically generates a route target in the format of BGP AS number:VXLAN ID.
both: Uses the specified route targets as both import and export targets. If you do not specify the both, export-extcommunity, or import-extcommunity keyword, the both keyword applies.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Specifies all route targets.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses route targets to control the advertisement and acceptance of BGP EVPN routes.
A VTEP sets the export targets for BGP EVPN routes before advertising the routes to remote VTEPs. The VTEP checks the export targets of BGP EVPN routes from remote VTEPs and imports only BGP EVPN routes of which the export targets match the local import targets.
If you execute this command multiple times, all configured route targets take effect.
# Configure import route targets 10:1, 100:1, and 1000:1 for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
