| 01-Basic VXLAN commands | 252.37 KB |
display ipv6 nd suppression vsi
display l2vpn mac-address mac-move
selective-flooding mac-address
vxlan invalid-udp-checksum discard
vxlan source udp-port five-tuple
The device does not support VXLAN-DCI, EVPN-DCI, or Ethernet service instance ACs.
arp suppression enable
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
arp suppression enable [ no-broadcast ]
ARP flood suppression is disabled.
VSI view
no-broadcast: Disables the device from flooding the ARP requests that do not match any ARP flood suppression entry.
ARP flood suppression reduces ARP request broadcasts by enabling the VTEP to reply to ARP requests on behalf of VMs.
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ARP flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
display arp suppression vsi
reset arp suppression vsi
arp suppression mode
Use arp suppression mode to set the ARP flood suppression mode.
Use undo arp suppression mode to restore the default.
arp suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
If ARP flood suppression is enabled, the default ARP flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the ARP requests that are not targeted at the device and do not match any ARP flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device replies to the ARP request on behalf of the target IP address. The ARP reply carries the following information:
· Sender IP address—Target IP address in the ARP request.
· Sender MAC address—MAC address in the matching ARP flood suppression entry.
· Source MAC address—MAC address in the matching ARP flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device acts as follows:
1. Replaces the target MAC address and destination MAC address in the ARP request with the MAC address in the entry.
2. Unicasts the ARP request.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an ARP request that is not targeted at the device and does not match any ARP flood suppression entry. If you do not specify this keyword, the device will broadcast such an ARP request.
The device does not forward ARP requests in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ARP entry learning errors caused by the delay in refreshing ARP flood suppression entries at the expense of high system resource usage.
# Enable ARP flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression mode unicast-forward
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU.
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address MAC address VSI name Link ID Aging(min)
1.1.1.2 000f-e201-0101 vsi1 0x70000 14
1.1.1.3 000f-e201-0202 vsi1 0x80000 18
1.1.1.4 000f-e201-0203 vsi2 0x90000 10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID |
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI. |
Aging |
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted. |
Use display ipv6 nd suppression vsi to display ND flood suppression entries.
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
count: Displays the number of ND flood suppression entries that match the command.
# Display ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi
IPv6 address MAC address VSI name Link ID Aging (min)
1000::2 000f-e201-0101 vsi1 0x70000 5
1000::3 000f-e201-0202 vsi1 0x80000 5
1000::4 000f-e201-0203 vsi2 0x90000 5
# Display the number of ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
Link ID |
Aging (min) |
Remaining lifetime (in minutes) of the ND flood suppression entry. When the timer expires, the entry is deleted. |
ipv6 nd suppression enable
reset ipv6 nd suppression vsi
display l2vpn interface
Use display l2vpn interface to display L2VPN information for Layer 3 interfaces that are mapped to VSIs.
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
verbose: Displays detailed information about Layer 3 interfaces. If you do not specify this keyword, the command displays brief information about Layer 3 interfaces.
If you do not specify any parameters, this command displays brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
# Display brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface
Total number of interfaces: 1, 1 up, 0 down
Interface Owner Link ID State Type
GE1/0/1 1 0 Up VSI
Layer 3 interface name. |
Owner |
VSI name. |
Link ID |
The interface's link ID on the VSI. |
State |
Physical state of the interface: · Up—The interface is physically up. · Down—The interface is physically down. |
Type |
L2VPN type of the interface. This field displays VSI for the VXLAN feature. |
# Display detailed L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface verbose
Interface: GE1/0/1
Owner : vsi1
Link ID : 0
State : Up
Type : VSI
Statistics : Enabled
Input Statistics:
Octets :994496
Packets :15539
Output Statistics:
Octets :0
Packets :0
Interface: GE1/0/2
Owner : vsi2
Link ID : 0
State : Down
Type : VSI
Input Statistics:
Octets :0
Packets :0
Output Statistics:
Octets :0
Packets :0
Owner |
VSI name. |
Link ID |
State |
Type |
Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the interface. · Disabled—The packet statistics feature is disabled for the interface. |
Input Statistics |
Incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. |
Output Statistics |
Outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. |
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
· Dynamic remote- and local-MAC entries.
· Remote-MAC entries advertised through BGP EVPN.
· Manually added static remote- and local-MAC entries.
· Remote-MAC entries issued through OpenFlow.
count: Displays the number of MAC address entries.
verbose: Displays detailed information about MAC address entries.
If you do not specify the count or verbose keyword, this command displays brief information about MAC address entries.
# Display brief information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address State VSI Name Link ID/Name Aging
0000-0000-000b Static vpn1 Tunnel10 NotAging
0000-0000-000c Dynamic vpn1 Tunnel60 Aging
0000-0000-000d Dynamic vpn1 Tunnel99 Aging
--- 3 mac address(es) found ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
Table 5 Command output
State |
Entry state: · Dynamic—Local- or remote-MAC entry dynamically learned in the data plane. · Static—Static local- and remote-MAC entry. · EVPN—Remote-MAC entry advertised through BGP EVPN. · OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow. |
Link ID/Name |
For a local MAC address, this field displays the interface name if the AC is a Layer 3 interface. If the AC is an Ethernet service instance, this field displays the name of the interface that hosts the Ethernet service instance for the MAC address. For a remote MAC address, this field displays the tunnel interface name. |
Aging |
Entry aging state: · Aging. · NotAging. |
# Display detailed information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name : vpn1
VXLAN ID : 123
Interface : GE1/0/1
Link ID : 1
State : Dynamic
Aging : Aging
Table 6 Command output
Link ID |
State |
Entry state: · Dynamic—Local- or remote-MAC entry dynamically learned in the data plane. · Static—Static local- or remote-MAC entry. · EVPN—Remote-MAC entry advertised through BGP EVPN. · OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow. |
Aging |
reset l2vpn mac-address
Use display l2vpn mac-address mac-move to display MAC move records for VSIs.
display l2vpn mac-address mac-move [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays MAC move records on the active MPU.
When a MAC address frequently moves between two interfaces, Layer 2 loops might occur in the network. To discover and locate loops, you can view the MAC address move records.
This command displays the MAC move events that have occurred on VSIs since startup of the device. The MAC move records with the same MAC address, VSI name, source port, and current port are considered to be one record.
A card can generate a maximum of 200 MAC address move records.
# Display MAC move records for all VSIs.
<Sysname> display l2vpn mac-address mac-move
MAC address : 0000-4900-03e7 VSI name : 3
Current port: GE1/0/1 Source port: GE1/0/2
Last time : 2019-02-19 20:44:15 Move count : 1
MAC address : 0000-4900-03e8 VSI name : 3
Current port: GE1/0/1 Source port: GE1/0/3
Last time : 2019-02-19 20:44:16 Move count : 1
--- 2 MAC address moving records found ---
Table 7 Command output
Current port |
Interface to which the MAC address was moved. |
Source port |
Interface from which the MAC address was moved. |
Last time |
Last time when the MAC address was moved. |
Move count |
Number of times that the MAC address has moved. |
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name | evpn-vxlan | vxlan ] [ count | verbose ]
evpn-vxlan: Specifies VSIs of EVPN VXLAN.
vxlan: Specifies VSIs of VXLAN.
count: Displays VSI state statistics.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
If you do not specify a VSI or network type, this command displays information about all VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 2, 1 up, 1 down, 0 admin down
VSI Name VSI Index MTU State
vpls1 0 1500 Up
vpls2 1 1500 Down
# Display state statistics about all VSIs.
<Sysname> display l2vpn vsi count
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
Table 8 Command output
State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Admin down—The VSI has been manually shut down by using the shutdown command. |
# Display detailed information about all VSIs of EVPN VXLAN.
<Sysname> display l2vpn vsi evpn-vxlan verbose
VSI Name: vpna
VSI Index : 0
VSI Description : vsi for vxlan10
VSI State : Up
MTU : -
Diffserv Mode : -
Bandwidth : -
Broadcast Restrain : -
Multicast Restrain : -
Unknown Unicast Restrain: -
MAC Learning : -
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
PW Redundancy Mode : Independent
DSCP : -
Service Class : -
Flooding : Enabled
ESI : 0000.0000.0000.0000.0000
Redundancy Mode : All-active
Input statistics :
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Output statistics:
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Gateway Interface : VSI-interface 100
VXLAN ID : 10
EVPN Encapsulation : VXLAN
Tunnels:
Tunnel Name Link ID State Type Flood proxy
Tunnel1 0x5000001 Up Manual Disabled
Tunnel2 0x5000002 Up Manual Disabled
ACs:
AC Link ID State Type
GE1/0/1 0x0 Up Manual
Statistics: Disabled
# Display detailed information about all VSIs of EVPN VPLS.
<Sysname> display l2vpn vsi evpn-vpls verbose
VSI Name: 1
VSI Index : 0
VSI State : Up
MTU : 1500
Diffserv Mode : -
Bandwidth : -
Broadcast Restrain : 5120 kbps
Multicast Restrain : 5120 kbps
Unknown Unicast Restrain: 5120 kbps
MAC Learning : Enabled
MAC Table Limit : Unlimited
MAC Learning rate : Unlimited
Drop Unknown : Disabled
PW Redundancy Mode : Slave
DSCP : -
Service Class : -
Flooding : Enabled
Statistics : Disabled
EVPN Encapsulation : MPLS
EVPN MPLS labels:
MPLS label : 775115
IMET MPLS label : 775114
EVPN PWs:
Peer Remote Service ID Link ID State Flag
1.1.1.1 - 8 Up Main
Create time: 2020-07-22 05:49:28
Last time status changed: 2020-07-22 05:49:28
Last time PW went down: 2020-07-22 05:49:28
3.3.3.3 - 9 Up Main
Create time: 2020-07-22 05:49:29
Last time status changed: 2020-07-22 05:49:29
Last time PW went down: 2020-07-22 05:49:29
ACs:
Table 9 Command output
VSI Description |
Description of the VSI. If the VSI does not have a description, the command does not display this field. |
VSI State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Administratively down—The VSI has been manually shut down by using the shutdown command. |
MTU |
MTU on the VSI. |
Diffserv Mode |
DiffServ mode. |
Bandwidth |
Bandwidth limit in kbps. If no bandwidth limit is set for the VSI, Unlimited is displayed. |
Broadcast Restrain |
Broadcast restraint bandwidth (in kbps). If the broadcast restraint bandwidth is not set, Unlimited is displayed. |
Multicast Restrain |
Multicast restraint bandwidth (in kbps). If the multicast restraint bandwidth is not set, Unlimited is displayed. |
Unknown Unicast Restrain |
Unknown unicast restraint bandwidth (in kbps). If the unknown unicast restraint bandwidth is not set, Unlimited is displayed. |
MAC Learning |
State of the MAC learning feature. |
MAC Table Limit |
Maximum number of MAC address entries on the VSI. |
MAC Learning rate |
MAC address entry learning rate of the VSI. |
Drop Unknown |
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached. |
PW Redundancy Mode |
PW redundancy operation mode: · Slave—Master/slave mode and the local PE operates as the slave node. · Master—Master/slave mode and the local PE operates as the master node. · Independent—Independent mode. |
DSCP |
DSCP value of outgoing VXLAN packets. |
Service Class |
Service class value of outgoing VXLAN packets. |
Flooding |
State of the VSI's flooding feature: · Enabled—Flooding is enabled on the VSI. · Disabled—Flooding is disabled on the VSI. |
ESI |
ESI assigned to the VSI. |
Redundancy Mode |
ES redundancy mode for the VSI: · A—All-active mode. · S—Single-active mode. |
Statistics |
Packet statistics state: · Enabled—The packet statistics feature is enabled for the VSI. · Disabled—The packet statistics feature is disabled for the VSI. |
Input statistics |
Incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. · Errors—Number of error packets. · Discards—Number of discarded packets. |
Output statistics |
Outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. · Errors—Number of error packets. · Discards—Number of discarded packets. |
Input Rate |
Incoming traffic rate for the VSI, in Bps and pps. |
Output Rate |
Outgoing traffic rate for the VSI, in Bps and pps. |
Gateway Interface |
VSI interface name. |
EVPN Encapsulation |
EVPN encapsulation type: · VXLAN. · MPLS. |
EVPN MPLS Labels |
MPLS labels for the VSI. |
MPLS label |
MPLS label in MAC/IP advertisement routes. |
IMET MPLS label |
MPLS label in IMET routes. |
Peer |
IP address of the remote PE. |
Link ID |
Link ID of the EVPN PW in the VSI. |
State |
State of the EVPN PW: · Up. · Down. |
Flag |
PW attribute flag. |
Create time |
Time when the EVPN PW was created. |
Last time status changed |
Time when the most recent EVPN PW state change occurred. |
State |
Tunnel state: · Up—The tunnel is operating correctly. · Down—The tunnel interface is down. |
Type |
Tunnel assignment method: · Auto—The tunnel was automatically assigned to the VXLAN: ¡ For an EVPN network, VXLAN tunnels are automatically assigned to VXLANs. ¡ For a multicast-mode VXLAN, the tunnel (MTunnel) was automatically created and assigned to the VXLAN to transmit flood traffic. · Manual—The tunnel was manually assigned to the VXLAN. |
Flood proxy |
This field is not supported in the current software version. Flood proxy state. |
Private-VSI type |
Private VSI type: · Community—A secondary VSI whose ACs have Layer 2 connectivity to one another. · Isolated—A secondary VSI whose ACs are isolated at Layer 2. · Primary. |
Associated secondary VSIs |
Secondary VSIs associated with the VSI. |
Associated primary VSI |
Primary VSI associated with the VSI. |
ACs |
ACs that are bound to the VSI. |
Link ID |
AC's link ID on the VSI. |
State |
AC state: · Up. · Down. |
Type |
Type and traffic match mode of the Ethernet service instance: · Dynamic (M-LAG)—Dynamic Ethernet service instance created on the peer link, in VLAN-based traffic match mode. · Dynamic (MAC-based)—Dynamic Ethernet service instance in MAC-based traffic match mode. · Dynamic (VLAN-based)—Dynamic Ethernet service instance in VLAN-based traffic match mode. · Manual—Static Ethernet service instance in VLAN-based traffic match mode. |
Statistics |
State of AC traffic statistics: · Enabled. · Disabled. |
display vxlan tunnel
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 2 (2 up, 0 down, 0 defect, 0 blocked)
Tunnel name Link ID State Type Flood proxy
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
Table 10 Command output
Link ID |
Tunnel's link ID in the VXLAN. |
State |
Type |
Flood proxy |
tunnel
vxlan
flooding disable (VSI view)
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction ]
Flooding is enabled for a VSI.
VSI view
all: Specifies broadcast, unknown unicast, and unknown multicast traffic.
broadcast: Specifies broadcast traffic.
unknown-multicast: Specifies unknown multicast traffic.
unknown-unicast: Specifies unknown unicast traffic.
all-direction: Disables flooding traffic received from an AC, VXLAN tunnel interface, or PW to any other ACs and VXLAN tunnel interfaces or PWs of the same VSI. If you do not specify this keyword, the command only disables flooding traffic received from ACs to VXLAN tunnel interfaces or PWs of the VSI.
By default, the device floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
· All site-facing interfaces except for the incoming interface.
· All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, use this command to disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
You cannot specify the unknown-multicast or unknown-unicast keyword alone. If you specify one of the keywords, you must also specify the other.
# Disable flooding of local broadcast traffic to remote sites for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
igmp host enable
Use igmp host enable to enable the IGMP host feature on an interface.
Use undo igmp host enable to disable the IGMP host feature on an interface.
igmp host enable
The IGMP host feature is disabled on an interface.
Interface view
You must configure an interface as an IGMP host if its IP address is the source IP address of multicast VXLAN packets. The IGMP host feature enables the interface to send IGMP reports in response to IGMP queries before it can receive traffic from a multicast group.
For this command to take effect, you must use the multicast routing command to enable IP multicast routing.
# Enable IP multicast routing, and then enable the IGMP host feature on GigabitEthernet 1/0/1.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-GigabitEthernet1/0/1] igmp host enable
display igmp host group
group
multicast routing (IP Multicast Command Reference)
Use ipv6 nd suppression enable to enable ND flood suppression.
Use undo ipv6 nd suppression enable to disable ND flood suppression.
ipv6 nd suppression enable [ no-broadcast ]
ND flood suppression is disabled.
VSI view
no-broadcast: Disables the device from flooding the ND requests that do not match any ND flood suppression entry.
ND flood suppression reduces ND request multicasts by enabling the VTEP to reply to ND requests on behalf of user terminals.
This feature snoops ND packets to populate the ND flood suppression table with local and remote MAC addresses. If an ND request has a matching entry, the VTEP replies to the request on behalf of the user terminal. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ND flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable
ipv6 nd suppression mode
Use ipv6 nd suppression mode to set the ND flood suppression mode.
Use undo ipv6 nd suppression mode to restore the default.
ipv6 nd suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
If ND flood suppression is enabled, the default ND flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the NS packets that are not targeted at the device and do not match any ND flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device replies to the NS packet on behalf of the target IP address. The replied NA packet carries the following information:
· Sender IP address—Target IP address in the NS packet.
· Source MAC address—MAC address in the matching ND flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device acts as follows:
1. Replaces the destination MAC address in the NS packet with the MAC address in the entry.
2. Unicasts the NS packet.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an NS packet that is not targeted at the device and does not match any ND flood suppression entry. If you do not specify this keyword, the device will broadcast such an NS packet.
The device does not forward NS packets in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ND entry learning errors caused by the delay in refreshing ND flood suppression entries at the expense of high system resource usage.
# Enable ND flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] nd suppression mode unicast-forward
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn statistics interval
Use l2vpn statistics interval to set the L2VPN statistics collection interval.
Use undo l2vpn statistics interval to restore the default.
l2vpn statistics interval interval
The L2VPN statistics collection interval is 15 minutes.
interval: Sets the L2VPN statistics collection interval in seconds, in the range of 5 to 65535.
# Set the L2VPN statistics collection interval to 30 seconds.
[Sysname] l2vpn statistics interval 30
mac-address static vsi
Use mac-address static vsi to add a static MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove a static MAC address entry for a VXLAN VSI.
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] interface tunnel tunnel-number vsi vsi-name
VXLAN VSIs do not have static MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
interface tunnel tunnel-number: Specifies a VXLAN tunnel interface by its tunnel interface number. The tunnel interface must already exist. This option applies to remote MAC addresses.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through BGP EVPN.
When you add a remote MAC address entry, make sure the VSI's VXLAN has been specified on the VXLAN or VXLAN-DCI tunnel.
Do not configure static remote-MAC entries for tunnels that are automatically established by using EVPN.
· EVPN re-establishes tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
· EVPN re-establishes tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
mapping vni (EVPN Command Reference)
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
Use reset ipv6 nd suppression vsi to clear ND flood suppression entries on VSIs.
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ND flood suppression entries on all VSIs.
# Clear ND flood suppression entries on all VSIs.
<Sysname> reset ipv6 nd suppression vsi
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote unicast or multicast MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are up.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
tunnel
Use tunnel to assign VXLAN tunnels to a VXLAN.
Use undo tunnel to remove VXLAN tunnels from a VXLAN.
tunnel { tunnel-number | all }
undo tunnel { tunnel-number | all }
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The value range for this argument is 0 to 20479. The tunnel must be a VXLAN tunnel.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
No global source address is specified for VXLAN tunnels.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify the ipv6 keyword when using the undo form of the command, the global IPv4 address is deleted.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels (VXLAN-DCI tunnels not included).
IPv4 VXLAN tunnels use the global IPv4 source address. IPv6 VXLAN tunnels use the global IPv6 source address.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
Use vxlan invalid-udp-checksum discard to enable the device to drop the VXLAN packets that fail UDP checksum check.
Use undo vxlan invalid-udp-checksum discard to restore the default.
The device does not check the UDP checksum of VXLAN packets.
This command enables the device to check the UDP checksum of VXLAN packets.
The device always sets the UDP checksum of VXLAN packets to 0. For compatibility with third-party devices, a VXLAN packet can pass the check if its UDP checksum is 0 or correct. If its UDP checksum is incorrect, the VXLAN packet fails the check and is dropped.
# Enable the device to drop the VXLAN packets that fail UDP checksum check.
[Sysname] vxlan invalid-udp-checksum discard
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to notify the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see System Management Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
Use vxlan source udp-port five-tuple to configure a VXLAN tunnel interface to generate the source UDP port number in the VXLAN encapsulation based on the IP five-tuple of the inner Ethernet frame.
Use undo vxlan source udp-port five-tuple to restore the default.
The source UDP port number in the VXLAN encapsulation is generated based on the source and destination MAC addresses of the inner Ethernet frame.
VXLAN tunnel interface view
This command takes effect only on IPv4-based VXLAN. Only manually created VXLAN tunnel interfaces support this command.
# Configure VXLAN tunnel interface Tunnel 1 to generate the source UDP port number in the VXLAN encapsulation based on the IP five-tuple of the inner Ethernet frame.
[Sysname] interface tunnel 1 mode vxlan
[Sysname-Tunnel1] vxlan source udp-port five-tuple
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } | leaf ]
undo xconnect vsi
An AC is not mapped to any VSI.
Interface view
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies an access mode. The default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
To monitor the status of an AC, associate it with track entries.
For traffic that matches the AC, the system uses the VSI's MAC address table to make a forwarding decision.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
· VLAN access mode—Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
¡ For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
¡ For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
· Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
¡ For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
¡ For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
# Map GigabitEthernet 1/0/1 to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] xconnect vsi vpn1
vsi
