| 01-Ethernet link aggregation commands | 343.53 KB |
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation troubleshooting
display link-aggregation verbose
lacp default-selected-port disable
link-aggregation auto-aggregation enable
link-aggregation bfd-compatible enable
link-aggregation global load-sharing mode
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mpls enhanced
link-aggregation port-priority
link-aggregation reversion delay
link-aggregation secondary-down
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-aggregation selected-port minimum percentage
display interface
Use display interface to display aggregate interface information.
display interface [ route-aggregation [ interface-number ] ] [ brief [ description | down ] ]
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, the command displays information about all interfaces.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Line protocol state: UP
Description: Route-Aggregation1 Interface
Bandwidth: 1000 kbps
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Input (total): 0 packets, 0 bytes
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1 UP UP --
Route-Aggregation1 |
Layer 3 aggregate interface name. |
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
IP packet frame type |
IPv4 packet framing format. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps. |
Unknown-speed mode, unknown-duplex mode |
The interface speed and duplex mode are unknown. |
Tagged VLANs |
VLAN whose packets are sent out of this interface with a tag. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Last 300 seconds input/output rate |
Average input or output rate over the last 300 seconds. |
Input/Output (total) |
Statistics of all packets received or sent on the interface. |
Input/Output (normal) |
Statistics of all normal packets received or sent on the interface. |
Line protocol state |
Data link layer state of the interface: · UP. · DOWN. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing |
IP packet processing capability of the interface when the interface is not assigned an IP address: · Disabled—The interface cannot process IP packets. · Enabled—The interface can process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-Allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-Negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Cause |
Cause for the physical link state of an interface to be DOWN. |
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Actor System ID: 0x8000, 0000-fc00-6504 |
Local system ID, which contains the LACP system priority (0x8000 in this sample output) and the LACP system MAC address (0000-FC00-6504 in this sample output). |
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ route-aggregation interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The route-aggregation keyword is available only when the corresponding aggregate interfaces exist on the device.
# Display the global link-aggregation load sharing mode. This example displays the default setting.
Link-aggregation load-sharing mode (hardware forwarding):
Layer 2 traffic: destination-mac address source-mac address
Layer 3 traffic: destination-ip address source-ip address ip-protocol
Layer 4 traffic: destination-port source-port MPLS traffic : mpls-label1
Link-aggregation load-sharing mode (software forwarding):
Layer 4 traffic: destination-ip address source-ip address
Link-aggregation load-sharing mode |
Global link-aggregation load sharing mode. By default, this field displays the link-aggregation load sharing modes for Layer 3, Layer 4, and MPLS traffic. If you have configured the global link-aggregation load sharing mode, this field displays the configured mode. |
Route-Aggregation1 load-sharing mode |
Link-aggregation load sharing mode of Layer 3 aggregation group 1. By default, this field displays the global link-aggregation load sharing modes. If you have configured a link-aggregation load sharing mode for this aggregation group, this field displays the configured mode. |
Layer 3 traffic: destination-ip address, source-ip address |
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, Layer 3 traffic is load shared based on source and destination IP addresses. |
Layer 3 traffic: packet type-based sharing |
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, Layer 3 traffic is load shared based on the packet type. |
Layer 4 traffic: destination-port, source-port |
Default link-aggregation load sharing mode for Layer 4 traffic. In this sample output, Layer 4 traffic is load shared based on source and destination ports. |
MPLS traffic : mpls-label1, mpls-label2, mpls-label3 |
Default link-aggregation load sharing mode for MPLS traffic. In this sample output, MPLS traffic is load shared based on Layer 1 through Layer 3 MPLS labels. |
destination-mac address, source-mac address |
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses. |
Dynamic |
User-configured dynamic load sharing mode: · Eligible—Distributes traffic on a per-flowlet basis. The flowlet gap time field displays the flowlet gap in microseconds, which is the idle interval between flowlets. · Fixed—Distributes traffic on a per-flow basis. · Spray—Distributes traffic across the member links on a per-packet basis. · N/A—Dynamic load sharing mode is not configured. |
Static |
The user-configured static load sharing mode. |
Use display link-aggregation member-port to display detailed link aggregation information about the specified member ports.
display link-aggregation member-port [ interface-list | auto ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
auto: Specifies all link aggregation member ports that are enabled with automatic assignment.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed information about GigabitEthernet 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/1
G -- Defaulted, H -- Expired
GigabitEthernet1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed information about GigabitEthernet 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port gigabitethernet 1/0/2
GigabitEthernet1/0/2:
Aggregate Interface: Route-Aggregation10
Local:
Port Number: 2
Oper-Key: 2
Flag: {ACDEF}
Remote:
Port Number: 26
Oper-Key: 2
Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Flags |
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0. · A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive. · B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval. · C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no. · D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no. · E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no. · F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no. · G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no. · H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no. |
Aggregate Interface |
Aggregate interface to which the member port belongs. |
Preferred Aggregate Interface |
Aggregate interface to which you prefer to assign the member port during automatic assignment. |
Local |
Information about the local end. |
Oper-key |
Operational key. |
Flag |
LACP protocol state flag. |
Remote |
Information about the peer end. |
System ID |
Peer system ID, containing the LACP system priority and the LACP system MAC address. |
Received LACP Packets |
Total number of LACP packets received. |
Illegal |
Total number of illegal packets. |
Sent LACP Packets |
Total number of LACP packets sent. |
Use display link-aggregation summary to display brief information about all aggregation groups.
The Partner ID field in the command output always displays None or nothing for a static link aggregation group. This is because the local aggregation system cannot obtain information from the peer system in a static link aggregation.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG AGG Partner ID Selected Unselected Individual Share
Interface Mode Ports Ports Ports Type
RAGG10 S None 1 0 0 NonS
Table 5 Command output
Aggregate Interface Type |
Aggregate interface type: · RAGG—Layer 3. · BLAGG—Blade. This type is not available in the current software version. · SCH-B—S-channel bundle. This type is not available in the current software version. |
Aggregation Mode |
Aggregation group type: · S—Static. · D—Dynamic. |
Loadsharing Type |
Load sharing type: · Shar—Load-sharing. · NonS—Non-load-sharing. |
Actor System ID |
Local system ID, which contains the local LACP system priority and the local LACP system MAC address. |
AGG Interface |
Type and number of the aggregate interface. |
AGG Mode |
Aggregation group type. |
Partner ID |
System ID of the peer system, which contains the peer LACP system priority and the peer LACP system MAC address. |
Selected Ports |
Total number of Selected ports. |
Unselected Ports |
Total number of Unselected ports. |
Individual Ports |
Total number of Individual ports. |
Share Type |
Load sharing type. |
Use display link-aggregation troubleshooting to display the aggregation states of aggregation member ports and the reason why a port was placed in Unselected state.
display link-aggregation troubleshooting [ route-aggregation [ interface-number ] ]
interface-number: Specifies an existing aggregate interface by its number.
If you do not specify an aggregate interface type, the command displays information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregation groups of the specified type.
You can specify the route-aggregation keyword only when aggregate interfaces of the specified type exist on the device.
# Display the aggregation states of aggregation member ports for all aggregation groups and the reason why a port was placed in Unselected state.
<Sysname> display link-aggregation troubleshooting
Aggregate Interface: Route-Aggregation2
Member ports:
GE1/0/2
Status: Selected
GE1/0/3
Status: Unselected
Reason: The physical or line protocol state of the port is down
Advice: Check the connection
Table 6 Command output
Reason |
Reason why the port was placed in Unselected state. |
Advice |
Recommended action. |
Table 7 Reason why the port was placed in Unselected state
The number of Selected ports had reached the upper limit |
Hardware resources were not enough |
The number of Selected ports was below the lower limit |
The link aggregation configuration of the port was incorrect |
The link aggregation configuration of its peer port was incorrect |
The physical or line protocol state of the port was down |
The port's hardware restriction prevented it from being Selected |
The speed configuration of the port was different from that of the reference port |
The duplex mode of the port was different from that of the reference port |
The port and the aggregate interface had different attribute configurations |
The port was in secondary state in a redundancy group |
The BFD session state of the port was down |
The port does not meet the Selected port requirements of the IRF member device where it resides |
The member port has low link quality |
It is the secondary member port in the aggregation group in 1+1 backup mode |
No LACPDU was received by the reference port |
The reference port received its own LACPDUs |
The link of the port was not aggregatable |
The link of the peer port was not aggregatable |
The card that hosts the port was absent |
The port's operational key was invalid |
Link-aggregation traffic redirection was triggered on the local port |
The port had not received LACPDUs |
The operational key of the peer port was different from that of the reference port |
The system MAC address of the peer port was different from that of the peer port for the reference port |
The peer port did not have the Synchronization flag |
The port was in Standby state |
Link-aggregation lacp isolate is configured |
Table 8 Recommended action
Modify the aggregation group configuration |
Release resources |
Modify port configuration |
Modify peer port configuration |
Check the connection |
Use another port |
Change the port rate to be the same as that of the reference port |
Change the port duplex mode to be the same as that of the reference port |
Change the port attribute configuration to be the same as that of the aggregate interface |
Place the port in primary state in the redundancy group |
Check the link that conveys the BFD session |
Check for CRC errors |
Check whether the peer sends LACPDUs correctly |
Check whether the device has a loop |
Make sure the card that hosts the port is installed |
Check whether the port sends LACPDUs correctly |
Change the peer system MAC address to be the same as that of the reference port |
Check the LACPDUs sent by the peer |
Please check the aggregation state of member ports in a few minutes |
Check the configuration |
N/A |
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ route-aggregation [ interface-number ] ] [ all-configuration ]
all-configuration: Specifies all member ports in an aggregation group. If you do not specify this keyword, the command displays the member ports on present cards.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
This command does not display the interfaces that are enabled with automatic assignment if they have not joined an aggregation group.
# Display detailed information about Layer 3 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 10
Port: A -- Auto port, M -- Management port, R -- Reference port
Role: P -- Primary, S -- Secondary
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
Local:
Port Status Priority Index Oper-Key Flag
GE1/0/1 S 32768 61 2 {ACDEF}
GE1/0/2 S 32768 62 2 {ACDEF}
GE1/0/3 S 32768 63 2 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
GE1/0/1(R) 32768 111 2 0x8000, 000f-e267-57ad {ACDEF}
GE1/0/2 32768 112 2 0x8000, 000f-e267-57ad {ACDEF}
GE1/0/3 32768 113 2 0x8000, 000f-e267-57ad {ACDEF}
# Display detailed information about Layer 3 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose route-aggregation 20
Aggregate Interface: Route-Aggregation20
Aggregation Mode: Static
Port Status Priority Oper-Key Role
GE1/0/1(R) S 32768 1 None
GE1/0/2 S 32768 1 None
GE1/0/3 S 32768 1 None
Table 9 Command output
Loadsharing Type |
Port Status |
Port state: · Selected. · Unselected. · Individual. |
Port |
Port type: · Auto port—The port is enabled with automatic assignment. · Management port—The port is a management port. · Reference port—The port is a reference port. |
Flags |
Role |
Role of the port in the aggregation group operating in 1+1 backup mode: · Primary. · Secondary. If the aggregation group is not operating in 1+1 backup mode, None is displayed. |
Name of the aggregate interface. |
Creation Mode |
Creation mode of the dynamic aggregate interface: · Auto. · Manual. |
Aggregation Mode |
Management VLANs |
Management VLANs. If no management VLANs are specified, this field displays None. |
System ID |
Local system ID, containing the local LACP system priority and the local LACP system MAC address. |
Local |
Information about the local end: · Port—Port type and number. · Status—Port state, which can be Selected, Unselected, or Individual. · Priority—Port priority. · Index—Port index. · Oper-Key—Operational key. · Flag—LACP state flag. NOTE: For static aggregation groups, the Index and Flag fields are not displayed. |
Remote |
Information about the peer end: · Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port. · Priority—Priority of the peer port. · Index—Index of the peer port. · Oper-Key—Operational key of the peer port. · System ID—System ID of the peer end. · Flag—LACP state flag of the peer end. |
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 512.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group and all its aggregate subinterfaces. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
jumboframe enable
Use jumboframe enable to allow the jumbo frames on an interface to pass through.
Use undo jumboframe enable to deny jumbo frames on an interface.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
An aggregate interface allows jumbo frames that are within 10240 bytes to pass through.
size: Specifies the maximum length of jumbo frames, in bytes. The value of this argument is fixed at 10240.
# Allow jumbo frames on Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> System-view
[Sysname-Route-Aggregation1] jumboframe enable
Use lacp default-selected-port disable to disable the default port selection action for dynamic aggregation groups.
Use undo lacp default-selected-port disable to enable the default port selection action for dynamic aggregation groups.
The default port selection action is enabled for dynamic aggregation groups.
The default port selection action applies to dynamic aggregation groups.
This action automatically chooses the port with the lowest ID from among all up member ports as a Selected port if none of them has received LACPDUs before the LACP timeout interval expires.
After this action is disabled, a dynamic aggregation group will not have any Selected ports to forward traffic if it has not received LACPDUs before the LACP timeout interval expires.
# Disable the default port selection action.
[Sysname] lacp default-selected-port disable
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 3 aggregate interface Route-Aggregation 1 as an edge aggregate interface.
[Sysname-Route-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp mode passive
lacp period short
Use lacp period short to enable the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
To avoid traffic interruption during an ISSU, do not enable the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Enable the short LACP timeout interval (3 seconds) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] lacp period short
lacp preempt delay
Use lacp select speed to set the preemption delay for an aggregate interface.
Use undo lacp select speed to restore the default.
lacp preempt delay delay-time
undo lacp preempt delay
The preemption delay for an aggregate interface is 0 seconds, which means preemption occurs immediately.
delay-time: Specifies the preemption delay time for the aggregate interface. The value range is 10 to 180 seconds.
For a dynamic aggregate interface, when Selected port A fails, the device selects member port B with the highest priority from the member ports that meet the conditions of becoming a Selected port. If preemption is enabled, port A will replace port B on recovery. To avoid packet loss caused by an unstable port A taking over port B, set a preemption delay time for the aggregate interface.
# Set the preemption delay for an aggregate interface to 100 seconds.
[Sysname-Route-Aggregation1] lacp preempt delay 100
lacp preempt enable
Use lacp preempt enable to enable the preemption feature on an aggregate interface.
Use undo lacp preempt enable to disable the preemption feature on an aggregate interface.
lacp preempt enable
The preemption feature on an aggregate interface is enabled.
For a dynamic aggregate interface, when Selected port A fails, the device selects member port B with the highest priority from the member ports that meet the conditions of becoming a Selected port. If the preemption feature is enabled on the aggregate interface, port A will replace port B on recovery. If the preemption feature is disabled on the aggregate interface, port B will continue to be the Selected port to reduce packet loss caused by selected port switching, even if its priority is lower than port A's.
# Disable the preemption feature on an aggregate interface.
[Sysname-Route-Aggregation1] undo lacp preempt enable
lacp select speed
Use lacp select speed to configure a dynamic aggregation group to use port speed as the prioritized criterion for reference port selection.
lacp select speed
Port ID is the prioritized criterion for reference port selection in a dynamic aggregation group.
CAUTION: Changing reference port selection criteria might cause transient traffic interruption. When you use this command, make sure you understand its impact on your network. |
This command enables a dynamic aggregation group to select a high-speed member port as the reference port.
You must execute this command at both ends of the aggregate link so the peer aggregation systems use the same criteria for reference port selection.
As a best practice, shut down the peer aggregate interfaces before you execute this command and bring up the interfaces after this command is executed on both of them.
This command takes effect only on dynamic aggregate interfaces. On a static aggregate interface, you can execute this command, but the setting cannot take effect.
# Specify port speed as the prioritized criterion for reference port selection on Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
[Sysname-Route-Aggregation1] lacp select speed
lacp system-mac
Use lacp system-mac to set the LACP system MAC address.
Use undo lacp system to restore the default.
lacp system-mac mac-address
undo lacp system-mac
The LACP system MAC address is the bridge MAC address of the device.
mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be an all-zero or all-F MAC address.
LACPDUs carry the LACP system MAC address configured by using this command. To identify the LACP system MAC address used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
You can configure the LACP system MAC address globally and in aggregate interface view. The global LACP system MAC address takes effect on all aggregation groups, and an aggregate-interface-specific LACP system MAC address takes precedence over the global LACP system MAC address.
# Set the LACP system MAC address to 0001-0001-0001.
[Sysname] lacp system-mac 1-1-1
lacp system-number
Use lacp system-number to set the LACP system number used by the local device.
Use undo lacp system-number to restore the default.
lacp system-number number
The LACP system number is not set.
number: Specifies a number in the range of 1 to 3.
You must assign a unique LACP system number to each S-MLAG device.
The LACP system number configured by using this command does not affect the Index field in LACPDUs. You can view the Index field in LACPDUs by using the display link-aggregation verbose command.
# Set the LACP system number to 1.
[Sysname] lacp system-number 1
Use lacp system-priority to set the LACP system priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The LACP system priority is 32768.
priority: Specifies the LACP system priority in the range of 0 to 65535. The smaller the value, the higher the LACP system priority.
LACPDUs carry the LACP system priority configured by using this command. To identify the LACP system priority used by a link aggregation group, examine the System ID field in the output from the display link-aggregation verbose command.
You can configure the LACP system priority globally and in aggregate interface view. The global LACP system priority takes effect on all aggregation groups, and an aggregate-interface-specific LACP system priority takes precedence over the global LACP system priority.
# Set the LACP system priority to 64.
[Sysname] lacp system-priority 64
Use link-aggregation auto-aggregation enable to enable automatic link aggregation.
Use undo link-aggregation auto-aggregation enable to disable automatic link aggregation.
Automatic link aggregation is disabled.
After you enable automatic link aggregation and LLDP on two connected devices, they automatically establish a dynamic link aggregation based on the information in incoming LLDP frames. The devices each automatically create a dynamic aggregate interface and assign the redundant ports connected to the peer to the aggregation group of that interface. If you disable LLDP or automatic link aggregation on one device, that device removes the aggregation member ports from the aggregation group, but it will retain the aggregate interface. This event will not trigger member port removal actions on the peer device.
If automatic link aggregation is enabled, subinterface creation might fail on LLDP-enabled Layer 3 Ethernet interfaces. As a best practice, do not create subinterfaces on LLDP-enabled Layer 3 Ethernet interfaces.
To ensure correct operation of an automatically created aggregate interface, do not modify the configuration on the member ports of its aggregation group. Doing so might cause the member ports to be removed from the aggregation group.
On an interface, the port link-aggregation group setting takes precedence over automatic link aggregation. The interface will not be added to the aggregation group of an automatically created aggregate interface if it has been the member port of a manually created aggregate interface.
# Enable automatic link aggregation.
<Sysname> system
[Sysname] link-aggregation auto-aggregation enable
lldp enable
lldp global enable
Use link-aggregation bfd to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd ipv4 source ipv4-address destination ipv4-address
undo link-aggregation bfd [ ipv4 ]
BFD is disabled for an aggregation group.
ipv4: Specifies IPv4 BFD.
source: Specifies the unicast source IP address of BFD sessions.
destination: Specifies the unicast destination IP address of BFD sessions.
ipv4-address: Specifies an IPv4 address. The address cannot be 0.0.0.0.
ipv6-address: Specifies an IPv6 address. The address cannot be 0::0.
Make sure the source and destination IP addresses are reversed between the two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 at the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 at the peer end. The source and destination IP addresses cannot be the same.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions established by the member ports in its aggregation group. BFD on a link aggregation supports only control packet mode for session establishment and maintenance. The two ends of an established BFD session can only operate in Asynchronous mode. For more information about BFD, see High Availability Configuration Guide.
As a best practice, do not configure BFD for any protocols on a BFD-enabled aggregate interface.
Make sure the number of member ports in the BFD-enabled aggregation group is less than or identical to the number of BFD sessions supported by the device. If the aggregation group contains more member ports than the supported sessions, some Selected ports might change to the Unselected state.
If the number of BFD sessions differs between the two ends of an aggregate link, check their settings for inconsistency in the maximum number of Selected ports. You must make sure the two ends have the same setting for the maximum number of Selected ports.
# Enable BFD for Layer 3 aggregation group 1, and specify the source and destination IP addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions
[Sysname-Route-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
Use link-aggregation bfd-compatible enable to enable BFD compatible mode on an aggregate interface.
Use undo link-aggregation bfd-compatible enable to disable BFD compatible mode on an aggregate interface.
BFD compatible mode is disabled on aggregate interfaces.
BFD compatible mode enables BFD to operate correctly on an aggregate link whose remote end is a third-party device that implements BFD differently from the device.
With BFD compatible mode enabled, all member ports in an aggregation group establish BFD sessions with their peer ports. The BFD sessions are not deleted or re-established when the aggregation states of the member ports change.
# Enable BFD compatible mode on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation bfd-compatible enable
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | mpls-label1 | source-ip | source-mac | source-port } *
The device distributes traffic based on the source and destination IP addresses on aggregate links.
destination-ip: Distributes traffic based on destination IP addresses.
destination-mac: Distributes traffic based on destination MAC addresses.
destination-port: Distributes traffic based on destination ports.
mpls-label1: Distributes MPLS traffic based on Layer 1 labels.
source-ip: Distributes traffic based on source IP addresses.
source-mac: Distributes traffic based on source MAC addresses.
source-port: Distributes traffic based on source ports.
If an unsupported load sharing mode is set, the device displays an error message.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
link-aggregation ignore speed
Use link-aggregation ignore speed to configure the system to ignore port speed when it sets the aggregation states of the member ports in an aggregation group.
Use undo link-aggregation ignore speed to restore the default.
The system does not ignore port speed when it sets the aggregation states of the member ports in an aggregation group.
IMPORTANT: Make sure you are fully aware of the impacts of this command when you execute it on a live network. · When you execute this command or its undo form, the operational key changes and the aggregate interface flaps temporarily. · This command might cause traffic loss on Selected ports operating at a speed lower than the other Selected ports in the aggregation group when traffic is distributed among the ports. |
This command allows ports at a different speed than the reference port to become Selected by ignoring the port speed during operational key calculation.
You must configure the same port speed ignoring setting at the two ends of a static configuration to ensure that the peer ports are placed in the same aggregation state. This requirement does not apply to a dynamic aggregation, on which the two ends negotiate the aggregation state of the peer ports automatically.
# Configure the system to ignore port speed when it sets the aggregation states of member ports in Layer 3 aggregation group 1.
[Sysname-route-aggregation1] link-aggregation ignore speed
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if one of the following events occurs:
· The port is shut down by using the shutdown command.
· The slot that hosts the port reboots, and the aggregation group spans multiple slots.
NOTE: The device does not redirect traffic to member ports that become Selected during the traffic redirection process. |
This feature ensures zero packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
Global link-aggregation traffic redirection settings take effect on all aggregation groups. A link aggregation group preferentially uses the group-specific link-aggregation traffic redirection settings. If group-specific link-aggregation traffic redirection is not configured, the group uses the global link-aggregation traffic redirection settings.
As a best practice, enable link-aggregation traffic redirection on a per-interface basis. If you enable this feature globally, communication with a third-party peer device might be affected if the peer is not compatible with this feature.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode for an aggregation group.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { { destination-ip | destination-port | source-ip | source-port } * | bandwidth-usage | per-packet }
The group-specific load sharing mode is the same as the global load sharing mode.
bandwidth-usage: Distributes traffic based on the bandwidth usage of aggregation member ports.
per-packet: Distributes traffic on a per-packet basis.
# Configure Layer 3 aggregation group 1 to load share packets based on destination IP addresses.
[Sysname] interface route-Aggregation 1
[Sysname-Route-Aggregation1] link-aggregation load-sharing mode destination-ip
Use link-aggregation load-sharing mpls enhanced to enable link-aggregation load sharing enhancement for MPLS packets.
Use undo link-aggregation load-sharing mpls enhanced to disable link-aggregation load sharing enhancement for MPLS packets.
Link-aggregation load sharing enhancement is disabled for MPLS packets.
This command enables an aggregate interface to use the IP five-tuple for MPLS packet distribution. The IP five-tuple contains the source IP address, source port number, destination IP address, destination port number, and protocol number.
Use this command only on the provider (P) device. For information about the P device, see MPLS L3VPN configuration in MPLS Configuration Guide.
# Enable link-aggregation load sharing enhancement for MPLS packets on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation load-sharing mpls enhanced
Use link-aggregation mode to set the aggregation mode of an aggregation group.
Use undo link-aggregation mode to restore the default.
link-aggregation mode { dynamic | static [ backup ] }
An aggregation group operates in static aggregation mode.
dynamic: Specifies dynamic mode and enables LACP.
static: Specifies static mode.
backup: Specifies static 1+1 backup mode. If you do not specify this keyword, 1+1 backup is not enabled. Only Layer 3 aggregate interfaces support this keyword.
When you change the aggregation mode, make sure you understand the impact of the change on services.
Aggregation mode change might cause Selected member ports to become Unselected.
The following restrictions apply to an aggregation group operating in 1+1 backup mode:
· The aggregation group can contain a maximum of two member ports.
· The maximum and minimum limits on the number of Selected ports in the aggregation group do not take effect.
# Configure Layer 3 aggregation group 1 to operate in dynamic aggregation mode.
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 3 Ethernet interface GigabitEthernet 1/0/2.
[Sysname-GigabitEthernet1/0/2] link-aggregation port-priority 64
link-aggregation primary-port
Use link-aggregation primary-port to assign the primary role to a member port in a 1+1 backup aggregation group.
Use undo link-aggregation primary-port to restore the default.
A member port is not assigned the primary role in a 1+1 backup aggregation group.
In a 1+1 backup aggregation group, the primary member port is placed in Selected state to forward all traffic, and the secondary member port is placed in Unselected state as a standby. You can specify a primary member port with this command or let the system to select a primary member port. If you specify a primary member port for a 1+1 backup aggregation group, the aggregation group can revert to the primary member port when that port recovers from failure. As a best practice, use this command to manually specify a primary member port.
If you do not specify a primary member port for an aggregation group, the system acts as follows:
· Assigns the primary role to the reference port if the member ports join the aggregation group simultaneously.
· Assigns the primary role to the member port that first becomes Selected if the member ports join the aggregation group successively.
This command is not available on a port that is not an aggregation group member or is in an aggregation group not operating in 1+1 backup mode.
A 1+1 backup aggregation group can have only one primary member port.
# Assign the primary role to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/1] link-aggregation primary-port
Use link-aggregation reversion delay to set the reversion delay for a 1+1 backup aggregation group.
Use undo link-aggregation reversion delay to restore the default.
link-aggregation reversion delay time-value
A 1+1 backup aggregation group reverts to the primary member port immediately after that port recovers from failure.
time-value: Sets a reversion delay in the range of 1 to 65535 seconds.
The reversion delay is the time a 1+1 backup aggregation group must wait before reverting to the primary member port after that port recovers from failure. This timer prevents link flapping from causing frequent primary/secondary member port switchovers.
For this command to take effect on an aggregation group, first configure the aggregation group to operate in 1+1 backup mode and manually specify its primary member port.
# Set the reversion delay to 5 seconds on Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation reversion delay 5
Use link-aggregation secondary-down to configure a 1+1 backup aggregation group to place its secondary member port in down state.
Use undo link-aggregation secondary-down to restore the default.
In a 1+1 backup aggregation group, the secondary member port is in Unselected state.
If the peer for a 1+1 backup aggregation group is unaware of the member port roles, it might send traffic to the secondary member port, and traffic loss occurs consequently. To prevent traffic loss, configure the aggregation group to place its secondary member port in down state. This allows the peer and local ends to use only up ports to transmit traffic.
For this command to take effect on an aggregation group, first configure the aggregation group to operate in 1+1 backup mode.
# Configure Route-Aggregation 1 to place its secondary member port in down state.
[Sysname-Route-Aggregation1] link-aggregation secondary-down
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number [ lacp-sync ]
The maximum number of Selected ports allowed in an aggregation group depends on hardware limitation.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 16.
lacp-sync: Synchronizes the maximum number of Selected ports through LACPDUs. If you do not specify this keyword, the aggregate interface does not synchronize the maximum number of Selected ports with the peer.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
On a static aggregate link, you must set the maximum number of Selected ports to the same value at its two ends.
On a dynamic aggregate link, you must set the maximum number of Selected ports to the same value at its two ends if you do not specify the lacp-sync keyword. If you specify this keyword, the two ends of the aggregate link compare their maximum Selected port number settings and use the smaller value.
For an aggregation group, the maximum number of Selected ports must be equal to or higher than the minimum number of Selected ports.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
· Maximum number set by using the link-aggregation selected-port maximum command.
· Maximum number of Selected ports allowed by the link aggregation capability.
You can implement backup between two ports by performing the following tasks:
· Assigning two ports to an aggregation group.
· Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port maximum 5
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 12.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
For an aggregation group, the minimum number of Selected ports must be equal to or lower than the maximum number of Selected ports.
# Set the minimum number of Selected ports to 3 for Layer 3 aggregation group 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum 3
Use link-aggregation selected-port minimum percentage to set the minimum percentage of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum percentage to restore the default.
link-aggregation selected-port minimum percentage number
The minimum percentage of Selected ports is not set for an aggregation group.
number: Specifies the minimum percentage of Selected ports. The value range for this argument is 1 to 100.
CAUTION: After you execute this command, aggregate interface flapping might occur when ports join or leave an aggregation group. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
You must set the same minimum percentage of Selected ports at the two ends of an aggregate link.
The minimum number of Selected ports in an aggregation group equals the higher one of the following values:
· The number of member ports in the aggregation group multiplied by the minimum percentage of Selected ports.
· The limit set by using the link-aggregation selected-port minimum command.
# Set the minimum percentage of Selected ports to 50% for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum percentage 50
link-aggregation switchover
Use link-aggregation switchover to perform a primary/secondary member port switchover in a 1+1 backup aggregation group.
CAUTION: This command might cause traffic loss. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
Use this command to switch member port roles for a 1+1 backup aggregation group whose primary member port is set by the system when the state of peer ports changes.
If the link-aggregation secondary-down command has been executed for the aggregation group, the link-aggregation switchover command brings up the down secondary member port for it to take over the primary role.
Before you execute the link-aggregation switchover command for a 1+1 backup aggregation group, verify that the following requirements are met:
· The aggregation group contains one Selected port and one Unselected port.
· The primary member port is set by the system.
· The secondary member port can become Selected.
# Perform a primary/secondary member port switchover in the aggregation group of Route-Aggregation 1.
[Sysname-Route-Aggregation1] link-aggregation switchover
This operation will change the current link status. Continue? [Y/N]:
mtu
Use mtu to set the MTU of a Layer 3 aggregate interface or subinterface.
mtu size
undo mtu
The MTU of Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies an MTU in bytes. The value range for this argument is 46 to 8100. .
# Set the MTU of interface Route-Aggregation 1 to 1430 bytes.
[Sysname-Route-Aggregation1] mtu 1430
display interface
port lacp system-mac
Use port lacp system-mac to set the LACP system MAC address on an aggregate interface.
Use undo port lacp system to restore the default.
port lacp system-mac mac-address
undo port lacp system-mac
# Set the LACP system MAC address to 0002-0002-0002 on an aggregate interface.
[Sysname-Route-Aggregation1] port lacp system-mac 2-2-2
lacp system-mac
port lacp system-priority
Use port lacp system-priority to set the LACP system priority on an aggregate interface.
Use undo port lacp system-priority to restore the default.
port lacp system-priority priority
# Set the LACP system priority to 32 on an aggregate interface.
[Sysname-Route-Aggregation1] port lacp system-priority 32
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
port link-aggregation group { group-id | auto [ group-id ] }
An interface does not belong to any aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 512.
auto: Enables automatic assignment.
A Layer 3 Ethernet interface or subinterface can be assigned only to a Layer 3 aggregation group.
An interface can belong to only one aggregation group.
An interface cannot join an aggregation group if it has different attribute configurations from the aggregate interface. After joining an aggregation group, an interface inherits the attribute configurations on the aggregate interface. You can modify the attribute configurations only on the aggregate interface.
You cannot assign both Ethernet interfaces and Ethernet subinterfaces to the aggregation group.
You cannot create subinterfaces on an Ethernet interface that is in the aggregation group.
You cannot assign an Ethernet interface that has subinterfaces to the aggregation group.
You cannot create aggregate subinterfaces on an aggregate interface if its aggregation group contains Ethernet subinterfaces. You cannot assign Ethernet subinterfaces to an aggregation group if its aggregate interface has aggregate subinterfaces.
Automatic assignment is available only on Layer 3 Ethernet interfaces.
When you enable automatic assignment, you can specify a preferred aggregation group, which must be in dynamic mode.
The device assigns the interface to the preferred aggregation group as long as the LACPDUs received on the interface match the peer information of the reference port in the group.
If you do not specify a preferred group or if the preferred group match fails, the device attempts to select a matching group from the existing dynamic aggregation groups. If no match is found, the device creates a dynamic aggregation group based on the LACPDUs and assigns the interface to that aggregation group.
As a best practice, do not modify the configuration on an automatically created aggregate interface or its member ports.
As a best practice, do not configure both manual member port assignment and automatic member port assignment. If you do that, a port might be assigned to different aggregation groups, causing the member port to fail to be selected.
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/2 to Layer 3 aggregation group 2.
[Sysname-GigabitEthernet1/0/2] port link-aggregation group 2
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number1 argument must be equal to or greater than the value for the interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
service
Use service to specify a traffic processing slot for a Layer 3 aggregate interface.
Use undo service to restore the default.
service slot slot-number
undo service slot
No traffic processing slot is specified for a Layer 3 aggregate interface. Traffic on a Layer 3 aggregate interface is processed on the slot at which the traffic arrives.
slot slot-number: Specifies a card by its slot number.
For all traffic on a Layer 3 aggregate interface to be processed on the same slot, use the service command.
If the aggregate interface contains subinterfaces, traffic on the subinterfaces is also processed on the specified slot.
Make sure the specified traffic processing slot is available. If the specified traffic processing slot is unavailable, traffic on the aggregate interface cannot be processed. When the slot becomes available, traffic processing resumes on the slot.
# Specify a traffic processing slot for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] service slot 2
sub-interface rate-statistic
Use sub-interface rate-statistic to enable rate statistics collection for the subinterfaces of a Layer 3 aggregate interface.
Use undo sub-interface rate-statistic to disable rate statistics collection for the subinterfaces of a Layer 3 aggregate interface.
Rate statistics collection is disabled for Layer 3 aggregate subinterfaces.
Rate statistics collection for Layer 3 aggregate subinterfaces is resource intensive. When you use this feature on a live network, make sure you fully understand its impact.
This command enables the device to periodically refresh rate statistics for the subinterfaces of a Layer 3 aggregate interface. The rate statistics are available in two statistics polling intervals after you execute this command. To set the statistics polling interval, use the flow-interval command.
# Enable rate statistics collection for the subinterfaces of Route-Aggregation 1.
[Sysname-Route-Aggregation1] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
The configuration will take effect after 2 flow intervals.
flow-interval (Interface Command Reference)
