- 04-Interface Command Reference
- 01-Common interface commands
- 02-Bulk interface commands
- 03-Ethernet interface commands
- 04-WAN interface commands
- 05-POS interface commands
- 06-CPOS interface commands
- 07-Loopback, null, and inloopback interface commands
- 08-Tunnel interface commands
- 09-FlexE interface commands
| 00-Preface | 109.34 KB |
Preface
This command reference covers the interface configuration commands.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
