03-System Management Command Reference
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Reference GuidesCommand ReferencesH3C MSR5680-X3 Router Command Reference-R9141-6W10103-System Management Command Reference
04-Process monitoring and maintenance commands
04-Process monitoring and maintenance commands 386.39 KB
The display memory, display process, display process cpu, monitor process and monitor thread commands display information about both user processes and kernel threads. In these commands, "process" refers to both user processes and kernel threads.
display exception context
Use display exception context to display context information for process exceptions.
display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ]
count value: Specifies the number of context information entries, in the range of 1 to 20. The default value is 1.
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command displays context information for process exceptions on the active MPU.
cpu cpu-number: Specifies a CPU by its number.
The system generates a context information entry for each process exception. A context information entry includes the process ID, the crash time, the core dump file directory, stack information, and register information.
# Display the exception context information.
<Sysname> display exception context
Max coredump files limited in system: 30
Max coredump files limited for one server: 5
Total number of core dump files in system: 1
Index 1 of 1
Crashed slot: 1
Crashed PID: 2916 (macd)
Crash signal: SIGBUS
Crash time: Mon Mar 25 16:31:17 2019
Core file path:
flash:/core/node6144_macd_2916_7_-163117_1553531477.core.xz
Exception Information:
rax            0xfffffffffffffffc        -4
rbx            0xffffffff        4294967295
rcx            0x7f2d955c0963    139833756092771
rdx            0x1       1
rsi            0x7ffe19a9c660    140729328977504
rdi            0x9       9
rbp            0x7ffe19a9c660    0x7ffe19a9c660
rsp            0x7ffe19a9c640    0x7ffe19a9c640
r8             0x0       0
r9             0x0       0
r10            0xffffffff        4294967295
r11            0x293     659
r12            0x687140  6844736
r13            0x7ffe19a9c7f8    140729328977912
Traceback (most recent call last):
  File "/bin/core_translator", line 318, in <module>
    controller.translate()
  File "/bin/core_translator", line 274, in translate
    self.update()
  File "/bin/core_translator", line 249, in update
    run_cmd(gdb_cmd)
  File "/bin/core_translator", line 77, in run_cmd
    data = proc.stdout.readline()
KeyboardInterrupt
Filed
Maximum number of coredump files that can be saved on the device.
Value Unlimit indicates that the number is not limited.
Maximum number of coredump files that can be generated by the service (not managed by the SCMD process). (The number of coredump files that can be generated by the service controlled by the SCMD process depends on the setting in the process core maxcore command.)
Total number of coredump files on the device.
Crashed PID
ID of the crashed process.
Crash signal
Signals that led to the crash:
·     SIGABRT—Abort.
·     SIGBUS—Bus error.
·     SIGFPE—Erroneous arithmetic operation.
·     SIGILL—Illegal hardware instructions.
·     SIGQUIT—Quit signal sent by the controlling terminal.
·     SIGSEGV—Invalid memory access.
·     SIGSYS—Invalid system call.
·     SIGTRAP—Trap message.
·     SIGXCPU—CPU usage limit exceeded.
·     SIGXFSZ—File size limit exceeded.
·     SIGUNKNOW—Unknown reason.
Crash time
Time when the crash occurred.
Core file path
Directory where the core dump file is saved.
Backtrace stopped
All stack information has been displayed.
reset exception context
display exception filepath
Use display exception filepath to display the core dump file directory.
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command displays the core dump file directory on the active MPU.
# Display the core dump file directory on the specified slot.
<Sysname> display exception filepath slot 1
The exception filepath on slot 1 is flash:.
display kernel deadloop
Use display kernel deadloop to display kernel thread deadloop information.
display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of deadloops to display, in the range of 1 to 60.
offset: Specifies the offset between the starting deadloop and the most recent deadloop. The value range is 0 to 59. The default value is 0.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command displays kernel thread deadloop information for the active MPU.
# Display brief information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1
----------------- Deadloop record 1 -----------------
Description          : BUG: soft lockup - CPU#0 stuck for 61! [comsh: 16306]
Recorded at          : 2019-05-01  11:16:00.823018
Occurred at          : 2019-05-01  11:16:00.823018
Instruction address  : 0x4004158c
Thread               : comsh (TID: 16306)
Context              : thread context
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Kernel module info   : module name (mrpnc) module address (0xe332a000)
# Display detailed information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Last 5 thread switches : migration/0 (11:16:00.823018)-->
                         swapper (11:16:00.833018)-->
                         kthreadd (11:16:00.833518)-->
                         swapper (11:16:00.833550)-->
                         disk (11:16:00.833560)
Register content:
Reg:       r0, Val = 0x00000000 ; Reg:       r1, Val = 0xe2be5ea0 ;
Reg:       r2, Val = 0x00000000 ; Reg:       r3, Val = 0x77777777 ;
Reg:       r4, Val = 0x00000000 ; Reg:       r5, Val = 0x00001492 ;
Reg:       r6, Val = 0x00000000 ; Reg:       r7, Val = 0x0000ffff ;
Reg:       r8, Val = 0x77777777 ; Reg:       r9, Val = 0x00000000 ;
Reg:      r10, Val = 0x00000001 ; Reg:      r11, Val = 0x0000002c ;
Reg:      r12, Val = 0x057d9484 ; Reg:      r13, Val = 0x00000000 ;
Reg:      r14, Val = 0x00000000 ; Reg:      r15, Val = 0x02000000 ;
Reg:      r16, Val = 0xe2be5f00 ; Reg:      r17, Val = 0x00000000 ;
Reg:      r18, Val = 0x00000000 ; Reg:      r19, Val = 0x00000000 ;
Reg:      r20, Val = 0x024c10f8 ; Reg:      r21, Val = 0x057d9244 ;
Reg:      r22, Val = 0x00002000 ; Reg:      r23, Val = 0x0000002c ;
Reg:      r24, Val = 0x00000002 ; Reg:      r25, Val = 0x24000024 ;
Reg:      r26, Val = 0x00000000 ; Reg:      r27, Val = 0x057d9484 ;
Reg:      r28, Val = 0x0000002c ; Reg:      r29, Val = 0x00000000 ;
Reg:      r30, Val = 0x0000002c ; Reg:      r31, Val = 0x00000000 ;
Reg:       cr, Val = 0x84000028 ; Reg:      nip, Val = 0x057d9550 ;
Reg:      xer, Val = 0x00000000 ; Reg:       lr, Val = 0x0186eff0 ;
Reg:      ctr, Val = 0x682f7344 ; Reg:      msr, Val = 0x00784b5c ;
Reg:     trap, Val = 0x0000b030 ; Reg:      dar, Val = 0x77777777 ;
Reg:    dsisr, Val = 0x40000000 ; Reg:   result, Val = 0x00020300 ;
Dump stack (total 1024 bytes, 16 bytes/line):
0xe2be5ea0: 02 be 5e c0 24 00 00 24 00 00 00 00 05 7d 94 84
0xe2be5eb0: 00 00 00 04 00 00 00 00 00 00 00 28 05 8d 34 c4
0xe2be5ec0: 02 be 60 a0 01 86 ef f0 00 00 00 00 00 00 00 00
0xe2be5ed0: 02 04 05 b4 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ee0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ef0: 95 47 73 35 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f00: a0 e1 64 21 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f10: 00 00 00 00 00 00 00 00 00 00 00 00 01 e9 00 00
0xe2be5f20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f30: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be5f40: 02 be 61 e0 00 00 00 02 00 00 00 00 02 44 b3 a4
0xe2be5f50: 02 be 5f 90 00 00 00 08 02 be 5f e0 00 00 00 08
0xe2be5f60: 02 be 5f 80 00 ac 1b 14 00 00 00 00 00 00 00 00
0xe2be5f70: 05 b4 5f 90 02 be 5f e0 00 00 00 30 02 be 5f e0
0xe2be5f80: 02 be 5f c0 00 ac 1b f4 00 00 00 00 02 45 00 00
0xe2be5f90: 00 03 00 00 00 00 00 00 02 be 5f e0 00 00 00 30
0xe2be5fa0: 02 be 5f c0 00 ac 1b 14 61 f1 2e ae 02 45 00 00
0xe2be5fb0: 02 44 b3 74 02 be 5f d0 00 00 00 30 02 be 5f e0
0xe2be5fc0: 02 be 60 60 01 74 ff f8 00 00 00 00 00 00 08 00
0xe2be5fd0: 02 be 5f f0 00 e8 93 7e 02 be 5f f8 02 be 5f fc
0xe2be5fe0: 00 00 00 00 00 00 00 00 00 00 00 00 02 be 60 18
0xe2be5ff0: 02 be 60 10 00 e9 65 98 00 00 00 58 00 00 2a 4f
0xe2be6000: 02 be 60 10 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6010: 02 be 60 40 00 e8 c6 a0 00 00 11 17 00 00 00 00
0xe2be6020: 02 be 60 40 00 00 00 00 00 00 00 00 02 be 60 98
0xe2be6030: 02 27 00 00 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6040: 02 be 60 60 00 00 00 01 00 00 b0 30 02 be 60 98
0xe2be6050: 00 00 00 04 02 21 00 00 00 00 00 00 01 e9 00 00
0xe2be6060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be6070: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be6080: 02 be 61 e0 00 00 00 02 00 00 00 00 02 be 61 70
0xe2be6090: 00 00 00 00 02 21 00 00 05 8d 34 c4 05 7d 92 44
Call trace:
Function Address = 0x8012a4b4
Function Address = 0x8017989c
Function Address = 0x80179b30
Function Address = 0x80127438
Function Address = 0x8012d734
Function Address = 0x80100a00
Function Address = 0xe0071004
Function Address = 0x8016ce0c
Function Address = 0x801223a0
Instruction dump:
41a2fe9c 812300ec 800200ec 7f890000 409efe8c 80010014 540b07b9 40a2fe80
4bfffe6c 80780290 7f64db78 4804ea35 <807f002c> 38800000 38a00080 3863000c
Description for the kernel thread deadloop, including the CPU number, thread running time, thread name, and thread number.
Recorded at
Time when the kernel thread deadloop was recorded, with microsecond precision.
Occurred at
Time when the kernel thread deadloop occurred, with microsecond precision.
Instruction address
Instruction address for the kernel thread deadloop.
Thread
Name and number of the kernel thread deadloop.
Context
Context for the kernel thread deadloop.
Cpu
Number of the CPU where the kernel thread ran.
VCPU ID
Number of the CPU core where the kernel thread ran.
Kernel module info
Information about kernel modules that had been loaded when the kernel thread deadloop was detected, including:
·     Module name—Kernel module name.
·     Module address—Memory address of the module.
Last five kernel thread switches on the CPU before the kernel thread deadloop was detected, including kernel thread name and kernel thread switching time with microsecond precision.
Register content
Register information:
·     Reg—Name of a register.
·     Val—Value saved in a register.
Dump stack
Stack information.
Call trace
Function call stack information, which shows the instruction address of a called function at each level.
Instruction dump
Instruction code when the kernel thread deadloop was detected. ffffffff indicates an illegitimate instruction code.
No information to display
No kernel thread deadloop information.
reset kernel deadloop
display kernel deadloop configuration
Use display kernel deadloop configuration to display kernel thread deadloop detection configuration.
display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command displays kernel thread deadloop detection configuration for the active MPU.
# Display kernel thread deadloop detection configuration.
<Sysname> display kernel deadloop configuration
Thread dead loop detection: Enabled
Dead loop timer (in seconds): 20
Threads excluded from monitoring: 1
  TID:     15   Name: co0
Dead loop timer (in seconds): n
Time interval (in seconds) to identify a kernel thread deadloop. A kernel thread deadloop occurs if a kernel thread runs more than n seconds.
Kernel threads excluded from kernel thread deadloop detection. This field appears only if the monitor kernel deadloop exclude-thread command is configured.
Name
Kernel thread name.
TID
Kernel thread number.
No thread is excluded from monitoring
All kernel threads are monitored by kernel thread deadloop detection.
display kernel exception
Use display kernel exception to display kernel thread exception information.
display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of kernel exceptions to display. The value range is 1 to 60.
offset: Specifies the offset between the starting exception and the most recent exception. The value range is 0 to 59. The default value is 0.
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command displays kernel thread exception information for the active MPU.
If an exception occurs to a running kernel thread, the system automatically records the exception information.
# Display brief information about the most recent kernel thread exception.
<Sysname> display kernel exception 1
----------------- Exception record 1 -----------------
Description          : Oops[#0]
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
                       module name (disk) module address (0xe00bd000)
# Display detailed information about the most recent kernel thread exception.
<Sysname> display kernel exception 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
                       module name (12500) module address (0xe00bd000)
Register content:
Call trace:
Instruction dump:
For more information about the command output, see Table 4.
reset kernel exception
display kernel reboot
Use display kernel reboot to display reboot information for cards.
display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of reboots to display. The value range is 1 to 60.
offset: Specifies the offset between the starting reboot and the most recent reboot. The value range is 0 to 59. The default value is 0.
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command displays reboot information for the active MPU. Reboot information for cards is recorded in the memory of the active MPU. If the active MPU is powered off, the reboot information is lost.
# Display brief information about the most recent reboot.
<Sysname> display kernel reboot 1
----------------- Reboot record 1 -----------------
Reason               : 0x31
Slot                 : 1
Target Slot          : 0
Cpu                  : 0
VCPU ID              : 0
# Display detailed information about the most recent reboot.
<Sysname> display kernel reboot 1 verbose
Reason               : 0x31
Slot                 : 1
Target Slot          : 0
Cpu                  : 0
VCPU ID              : 0
Call trace:
Recorded at
Time when the reboot was recorded, with microsecond precision.
Occurred at
Time when the reboot occurred, with microsecond precision.
Reason
Reboot reason.
Thread
Name and number of the kernel thread that was running when the reboot occurred.
Context
Context where the reboot occurred.
Slot
Number of the slot that triggered the reboot.
Target Slot
Number of the rebooted slot.
Cpu
Number of the CPU that triggered the reboot.
VCPU ID
Number of the CPU core that triggered the reboot.
Kernel module info
Information about kernel modules that had been loaded when the reboot occurred, including the kernel module names and memory addresses.
Last five kernel thread switches that occurred on the CPU before the reboot, including the kernel thread names and kernel thread switching time points, with microsecond precision.
Dump stack
Stack information for the threads that were running when the reboot occurred.
Call trace
Function call stack information.
No reboot information exists.
reset kernel reboot
display kernel starvation
Use display kernel starvation to display kernel thread starvation information.
display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of thread starvations to display. The value range is 1 to 60.
offset: Specifies the offset between the starting starvation and the most recent starvation. The value range is 0 to 59. The default value is 0.
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command displays kernel thread starvation information for the active MPU.
# Display brief information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1
----------------- Starvation record 1 -----------------
Description          : INFO: task comsh: 16306 blocked for more than 10 seconds.
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
# Display detailed information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Register content:
Call trace:
Instruction dump:
For detailed information about the command output, see Table 4.
reset kernel starvation
display kernel starvation configuration
Use display kernel starvation configuration to display kernel thread starvation detection configuration.
display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays kernel thread starvation detection configuration on the active MPU.
# Display kernel thread starvation detection configuration.
<Sysname> display kernel starvation configuration
Thread starvation detection: Disabled
Starvation timer (in seconds): 10
  TID:    123   Name: co0
Table 5 Command output
Starvation timer (in seconds): n
Time interval (in seconds) to identify a kernel thread starvation. A kernel thread starvation occurs if a kernel thread does not run within n seconds.
Kernel threads excluded from kernel thread starvation detection.
Name
Kernel thread name.
TID
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
display process
Use display process to display process state information.
display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ]
all: Specifies all processes. With the all keyword or without any parameters, the command displays state information for all processes.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. Each process has a fixed job ID.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters that must not contain question marks or spaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays process state information for the active MPU.
# Display state information for the process scmd.
<Sysname> display process name scmd
                             Job ID: 1
                                PID: 1
                         Parent JID: 0
                         Parent PID: 0
                    Executable path: /sbin/scmd
                           Instance: 0
                            Respawn: OFF
                      Respawn count: 1
             Max. spawns per minute: 0
                       Last started: Wed Jun  1 14:45:46 2019
                      Process state: sleeping
                          Max. core: 0
                               ARGS: -
    TID  LAST_CPU    Stack      PRI    State   HH:MM:SS:MSEC  Name
      1      0          0K      120      S     0:0:5:220      scmd
Table 6 Command output
Job ID
Job ID of the process. The job ID never changes.
PID
Number of the process. The number identifies the process, and it might change as the process restarts.
Parent JID
Job ID of the parent process.
Parent PID
Number of the parent process.
Executable path
Executable path of the process. For a kernel thread, this field displays a hyphen (-).
Instance
Instance number of the process. Whether a process can run multiple instances depends on the software implementation.
Respawn
Indicates whether the process restarts when an error occurs:
·     ON—The process automatically restarts.
·     OFF—The process does not automatically restarts.
Respawn count
Times that the process has restarted. The starting value is 1.
Maximum number of times that the process can restart within one minute. If the threshold is reached, the system automatically shuts down the process.
Last started
Time when the most recent restart occurred.
Process state
State of the process:
·     running—Running or waiting in the queue.
·     sleeping—Interruptible sleep.
·     traced or stopped—Stopped.
·     uninterruptible sleep—Uninterruptible sleep.
·     zombie—The process has quit, but some resources are not released.
Max. core
Maximum number of core dump files that the process can create. 0 indicates that the process never creates a core dump file. A process creates a core dump file after it abnormally restarts. If the number of core dump files reaches the maximum value, no more core dump files are created. Core dump files are helpful for troubleshooting.
ARGS
Parameters carried by the process during startup. If the process carries no parameters, this field displays a hyphen (-).
TID
Thread ID.
LAST_CPU
Number of the CPU on which the process is last scheduled.
Stack
Stack size.
PRI
Thread priority.
Thread state:
·     R—Running.
·     S—Sleeping.
·     T—Traced or stopped.
·     D—Uninterruptible sleep.
·     Z—Zombie.
HH:MM:SS:MSEC
Running time since the most recent start.
Name
Process name.
# Display state information for all processes.
<Sysname> display process all
    JID    PID %CPU %MEM STAT PRI TTY HH:MM:SS COMMAND
      1      1  0.0  0.0   S  120  -  00:00:04 scmd
      2      2  0.0  0.0   S  115  -  00:00:00 [kthreadd]
      3      3  0.0  0.0   S   99  -  00:00:00 [migration/0]
      4      4  0.0  0.0   S  115  -  00:00:05 [ksoftirqd/0]
      5      5  0.0  0.0   S   99  -  00:00:00 [watchdog/0]
      6      6  0.0  0.0   S  115  -  00:00:00 [events/0]
      7      7  0.0  0.0   S  115  -  00:00:00 [khelper]
      8      8  0.0  0.0   S  115  -  00:00:00 [kblockd/0]
      9      9  0.0  0.0   S  115  -  00:00:00 [ata/0]
     10     10  0.0  0.0   S  115  -  00:00:00 [ata_aux]
     11     11  0.0  0.0   S  115  -  00:00:00 [kseriod]
     12     12  0.0  0.0   S  120  -  00:00:00 [vzmond]
     13     13  0.0  0.0   S  120  -  00:00:00 [pdflush]
     14     14  0.0  0.0   S  120  -  00:00:00 [pdflush]
     15     15  0.0  0.0   S  115  -  00:00:00 [kswapd0]
     16     16  0.0  0.0   S  115  -  00:00:00 [aio/0]
     17     17  0.0  0.0   S  115  -  00:00:00 [scsi_eh_0]
     18     18  0.0  0.0   S  115  -  00:00:00 [scsi_eh_1]
     19     19  0.0  0.0   S  115  -  00:00:00 [scsi_eh_2]
     35     35  0.0  0.0   D  100  -  00:00:00 [lipc_topology]
---- More ----
Table 7 Command output
JID
Job ID of a process. It never changes.
PID
Number of a process.
%CPU
(Container-incapable devices.) Ratio of CPU resources consumed by the process to the total CPU resources of the device, in percentage.
(Container-capable devices.) Ratio of CPU resources consumed by the process to the total CPU resources of the container, in percentage.
%MEM
(Container-incapable devices.) Ratio of memory consumed by the process to the total memory of the device, in percentage.
(Container-capable devices.) Ratio of memory consumed by the process to the total memory of the container, in percentage.
STAT
State of a process:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
PRI
Priority of a process for scheduling.
TTY
TTY used by a process.
HH:MM:SS
Running time since the most recent start. If the running time reaches or exceeds 100 hours, this field displays only the number of hours.
COMMAND
Name and parameters of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process cpu
Use display process cpu to display CPU usage for all processes.
display process cpu [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays CPU usage for all processes on the active MPU.
# Display CPU usage for all processes.
<Sysname> display process cpu
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7%
    JID      5Sec      1Min      5Min    Name
      1      0.0%      0.0%      0.0%    scmd
      2      0.0%      0.0%      0.0%    [kthreadd]
      3      0.1%      0.0%      0.0%    [ksoftirqd/0]
Table 8 Command output
System CPU usage within the last 5 seconds, 1 minute, and 5 minutes.
JID
5Sec
CPU usage of the process within the last 5 seconds.
1Min
CPU usage of the process within the last minute.
5Min
CPU usage of the process within the last 5 minutes.
Name
Name of the process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process log
Use display process log to display log information for all user processes.
display process log [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays log information for all user processes on the active MPU.
# Display log information for all user processes.
<Sysname> display process log
Process       JobID  PID    Abort Core Exit Kill StartTime      EndTime
knotify       92     92     N     N    0    36   12-17 07:10:27 12-17 07:10:27
knotify       93     93     N     N    0    --   12-17 07:10:27 12-17 07:10:27
automount     94     94     N     N    0    --   12-17 07:10:27 12-17 07:10:28
knotify       111    111    N     N    0    --   12-17 07:10:28 12-17 07:10:28
comsh         121    121    N     N    0    --   12-17 07:10:30 12-17 07:10:30
knotify       152    152    N     N    0    --   12-17 07:10:31 12-17 07:10:31
autocfgd      155    155    N     N    0    --   12-17 07:10:31 12-17 07:10:31
pkg_update    122    122    N     N    0    --   12-17 07:10:30 12-17 07:10:31
Table 9 Command output
Process
Name of a user process.
JobID
Job ID of a user process.
PID
Abort
Indicates whether the process exited abnormally:
·     Y—Yes.
·     N—No.
Core
Indicates whether the process can generate core dump files:
·     Y—Yes.
·     N—No.
Exit
Process exit code. This field displays two hyphens (--) if the process was killed by a signal.
Kill
Code of the signal that killed the process. This field displays two hyphens (--) if the process exited instead of being killed.
StartTime
Time when the user process started.
EndTime
Time when the user process ended.
display process memory
Use display process memory to display memory usage for all user processes.
display process memory [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays memory usage for all user processes on the active MPU.
When a user process starts, it requests the following types of memory from the system:
·     Text memory—Stores code for the user process.
·     Data memory—Stores data for the user process.
·     Stack memory—Stores temporary data.
·     Dynamic memory—Heap memory dynamically assigned and released by the system according to the needs of the user process. To view dynamic memory information, execute the display process memory heap command.
# Display memory usage for all user processes.
<Sysname> display process memory
   JID       Text      Data      Stack    Dynamic    Name
     1        384      1800         16         36    scmd
     2          0         0          0          0    [kthreadd]
     3          0         0          0          0    [ksoftirqd/0]
     4          0         0          0          0    [watchdog/0]
     5          0         0          0          0    [events/0]
     6          0         0          0          0    [khelper]
    29          0         0          0          0    [kblockd/0]
    49          0         0          0          0    [vzmond]
    52          0         0          0          0    [pdflush]
---- More ----
Table 10 Command output
JID
Text
Text memory used by the user process, in KB. The value for a kernel thread is 0.
Data
Data memory used by the user process, in KB. The value for a kernel thread is 0.
Stack
Stack memory used by the user process, in KB. The value for a kernel thread is 0.
Dynamic
Dynamic memory used by the user process, in KB. The value for a kernel thread is 0.
Name
Name of the user process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process memory heap address
display process memory heap size
display process memory fragment free
Use display process memory fragment free to display free memory block information for a user process.
display process memory fragment free job job-id [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays free memory block information on the active MPU.
A user process requests memory from the system when it is running. It will release the memory as a whole, instead of any free memory blocks in it.
Use this command to view the start address and size of free memory blocks that are greater than 32 KB to locate issues such as insufficient memory.
# Display free memory block information for the user process identified by job ID 1.
<Sysname> display process memory fragment free job 1
Free block greater than or equal to 32KB in the main arena:
Address 0x7f2f0f2bd950 size 32kbytes
Free block greater than or equal to 32KB in A1 arena:
Address 0x7f2f0f4bd980 size 34kbytes
the back  chunk is :Address  0x7f2f0f4bd990  size  416   Tag 0
the front chunk is :Address  0x7f2f0f4bd970  size  160   Tag 0
Table 11 Command output
Start address and size of the free memory block that is greater than or equal to 32 KB in the main memory arena.
A process has only one main memory arena.
Start address and size of the free memory block that is greater than or equal to 32 KB in the non-main memory arena.
Found no free block greater than or equal to 32KB.
No free memory block that is greater than or equal to 32 KB is found in the memory arena.
Information about the chunk after the free memory block that is greater than or equal to 32 KB.
Information about the chunk before the free memory block that is greater than or equal to 32 KB.
display process memory fragment used
Use display process memory fragment used to display used memory block information for a user process.
display process memory fragment used used-block job job-id [ slot slot-number [ cpu cpu-number ] ]
used-block: Specifies the number of used memory blocks, in the range of 1 to 102400.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays used memory block information on the active MPU.
# Display used memory block information for the user process identified by job ID 100.
<Sysname> display process memory fragment used 1 job 100
Main arena:
  Top Chunk:
    Address 0x88e9468 size  7064
  Neighboring 84 chunks used:
    Address 0x88e941c size    80
    Address 0x88e93cc size    80
    Address 0x88e93ac size    32
    Address 0x88e935c size    80
    Address 0x88e930c size    80
    Address 0x88e92ec size    32
    Address 0x88e929c size    80
    Address 0x88e924c size    80
    Address 0x88e91fc size    80
    Address 0x88e91dc size    32
    Address 0x88e918c size    80
    Address 0x88e913c size    80
    Address 0x88e90ec size    80
    Address 0x88e909c size    80
    Address 0x88e904c size    80
    Address 0x88e8ffc size    80
    Address 0x88e8fac size    80
    Address 0x88e8f8c size    32
    Address 0x88e8f3c size    80
---- More ----
Table 12 Command output
XX arena
Memory arena. For example, the value can be Main, A1, and A2. A user process can have only one main arena.
Top chunk
Address and size of the top memory block.
Neighboring  1  chunks used:
    Address0x7f2f8f2bd550 size 48 *
Used neighboring memory blocks of the top memory block.
For a 32-bit device, an asterisk (*) is used to identify a memory size that is smaller than 80 bytes.
For a 64-bit device, an asterisk (*) is used to identify a memory size that is smaller than 160 bytes.
Use display process memory heap to display heap memory usage for a user process.
display process memory heap job job-id [ tag [ tag-id ] | verbose ] [ slot slot-number [ cpu cpu-number ] ]
job job-id: Specifies a user process by its job ID, in the range of 1 to 2147483647.
tag [ tag-id ]: Specifies an internal software module by its tag ID, a hexadecimal string in the range of 0 to FFFFFFFF. If you do not specify an internal software module, this command displays heap memory usage for all internal software modules in the process.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays heap memory usage for the user process on the active MPU.
Heap memory comprises fixed-sized blocks such as 16-byte or 64-byte blocks. It stores data and variables used by the user process. When a user process starts, the system dynamically allocates heap memory to the process.
Each memory block has an address represented in hexadecimal format, which can be used to access the memory block. You can view memory block addresses by using the display process memory heap size command, and view memory block contents by using the display process memory heap address command.
# Display brief information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1
Total virtual memory heap space(in bytes)  :  538448
Total physical memory heap space(in bytes) :  356352
Total allocated memory(in bytes)           :  369904
Free memory ratio                          :  0.3%
# Display detailed information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1 verbose
Heap usage:
Size      Free      Used      Total      Free Ratio
32        8         304       312        2.6%
48        1         339       340        0.3%
64        4         250       254        1.6%
80        7         16        23         30.4%
96        2         70        72         2.8%
112       1         1         2          50.0%
128       0         7         7          0.0%
160       0         2         2          0.0%
176       0         8         8          0.0%
192       0         63        63         0.0%
224       0         67        67         0.0%
240       0         1         1          0.0%
256       0         6         6          0.0%
288       0         1         1          0.0%
304       0         16        16         0.0%
336       0         2         2          0.0%
384       0         1         1          0.0%
512       0         1         1          0.0%
528       0         9         9          0.0%
544       0         1         1          0.0%
592       0         1         1          0.0%
608       0         2         2          0.0%
720       0         226       226        0.0%
752       0         1         1          0.0%
1008      0         1         1          0.0%
1072      0         3         3          0.0%
1200      0         1         1          0.0%
1680      0         3         3          0.0%
2000      0         5         5          0.0%
2064      0         5         5          0.0%
2096      0         1         1          0.0%
4112      0         13        13         0.0%
5136      0         1         1          0.0%
8240      0         1         1          0.0%
11280     0         1         1          0.0%
Large Memory Usage:
Used Blocks                :  0
Used Memory(in bytes):  0
Free Blocks                :  2
Free Memory(in bytes):  167120
Large Memory Usage detail:
[32K,64K)      1         0         1          100.0%
[96K,128K)     1         0         1          100.0%
Summary:
# Display brief information about heap memory usage for all modules in the process identified by job ID 1.
<Sysname> display process memory heap job 1 tag
Total allocated memory:  16101568 bytes
Total free memory:  206480 bytes
Heap usage of the job:
Tag            UsedBlocks     UsedBytes      FreeBlocks     FreeBytes
0x0            1289           16101568       17             206480
# Display brief information about heap memory usage for module 0 in the process identified by job ID 1.
<Sysname> display process memory heap job 1 tag 0
Heap usage:
Size           UsedBlocks     UsedBytes      FreeBlocks     FreeBytes
32             269            8608           5              160
48             300            14400          1              48
64             227            14528          2              128
80             14             1120           1              80
96             63             6048           0              0
112            1              112            4              448
128            7              896            1              128
160            2              320            0              0
176            6              1056           1              176
192            59             11328          0              0
224            63             14112          0              0
240            1              240            0              0
Table 13 Command output
Free memory ratio
Ratio of the heap memory that has been released by the process but not returned to the system to the total virtual heap memory of the process.
Size
Size of each memory block, in bytes.
For large memory blocks, this field displays a value range in the [n1,n2) format.
Free
Number of free memory blocks.
Used
Number of used memory blocks.
Total
Total number of memory blocks.
Free Ratio
Ratio of free memory to total memory. It helps identify fragment information.
Large Memory Usage
Large memory usage.
Used Blocks
Used memory size, in bytes.
Free Blocks
Free memory size, in bytes.
Details about large memory usage.
Size of heap memory used by the process, in bytes.
Total free memory
Size of free heap memory for the process, in bytes.
Heap memory usage of the process.
Tag
ID of the system internal software module.
UsedBlocks
UsedBytes
Size of used memory, in bytes.
FreeBlocks
FreeBytes
Size of free memory, in bytes.
Use display process memory heap address to display heap memory content starting from a specified memory block for a process.
display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ]
address starting-address: Specifies the starting memory block by its address.
length memory-length: Specifies the memory block length in the range of 1 to 1024 bytes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays heap memory content information on the active MPU.
When a user process runs abnormally, the command helps locate the problem.
# Display 128-byte memory block content starting from the memory block 0xb7e30580 for the process job 1.
<Sysname> display process memory heap job 1 address b7e30580 length 128
B7E30580:  14 00 EF FF 00 00 00 00 E4 39 E2 B7 7C 05 E3 B7  .........9..|...
B7E30590:  14 00 EF FF 2F 73 62 69 6E 2F 73 6C 62 67 64 00  ..../sbin/slbgd.
B7E305A0:  14 00 EF FF 00 00 00 00 44 3B E2 B7 8C 05 E3 B7  ........D;......
B7E305B0:  14 00 EF FF 2F 73 62 69 6E 2F 6F 73 70 66 64 00  ..../sbin/ospfd.
B7E305C0:  14 00 EF FF 00 00 00 00 A4 3C E2 B7 AC 05 E3 B7  .........<......
B7E305D0:  14 00 EF FF 2F 73 62 69 6E 2F 6D 73 74 70 64 00  ..../sbin/mstpd.
B7E305E0:  14 00 EF FF 00 00 00 00 04 3E E2 B7 CC 05 E3 B7  .........>......
B7E305F0:  14 00 EF FF 2F 73 62 69 6E 2F 6E 74 70 64 00 00  ..../sbin/ntpd..
Use display process memory heap size to display the addresses of heap memory blocks with a specified size used by a process.
display process memory heap job job-id [ tag tag-id ] size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ]
tag [ tag-id ]: Specifies an internal software module by its tag ID, a hexadecimal string in the range of 0 to FFFFFFFF. If you do not specify an internal software module, this command displays the addresses of heap memory blocks for all internal software modules in the process.
size memory-size: Specifies the memory block size in the range of 1 to 4294967295.
offset offset-size: Specifies an offset in the range of 0 to 4294967295. The default value is 128. For example, suppose the system allocates 100 16-byte memory blocks to process job 1, and the process has used 66 blocks. Then if you execute the display process memory heap job 1 size 16 offset 50 command, the output shows the addresses of the 51st through 66th 16-byte blocks used by the process.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays block address information on the active MPU.
The command displays memory block addresses in hexadecimal format. To view memory block content, execute the display process memory heap address command.
# Display the addresses of 16-byte memory blocks used by process job 1.
<Sysname> display process memory heap job 1 size 16
0xb7e300c0  0xb7e300d0  0xb7e300e0  0xb7e300f0
0xb7e30100  0xb7e30110  0xb7e30120  0xb7e30130
0xb7e30140  0xb7e30150  0xb7e30160  0xb7e30170
0xb7e30180  0xb7e30190  0xb7e301a0  0xb7e301b0
0xb7e301c0  0xb7e301d0  0xb7e301e0  0xb7e301f0
0xb7e30200  0xb7e30210  0xb7e30220  0xb7e30230
# Display the addresses of 16-byte memory blocks starting from the fifth block used by process job 1.
<Sysname> display process memory heap job 1 size 16 offset 4
display process memory umem
Use display process memory umem to display umem memory statistics for a user process.
display process memory umem job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays umem memory statistics for the user process on the active MPU.
A user process can request memory from the cache pool created by the umem library or request independent memory from the system cache pool. All such memory belongs to the umem memory of the user process.
The umem memory is used to store data or intermediate variables required by the user process during its operation.
# Display brief umem memory statistics for job 1009 (forward process).
<Sysname> display process all | include forward
      1009       1009  1.3  8.7   S  120   N        -  13:01:57 forward PHASE2
     20258      20258  0.0  0.0   S  120   N     pts/1 00:00:00 grep -E forward
// The output shows that the job ID for the forward process is 1009.
<Sysname> display process memory umem job 1009
Total virtual memory umem space(in bytes)   :  13631488
Total physical memory umem space(in bytes)  :  0
Total allocated memory umem space(in bytes) :  13631488
# Display detailed umem memory statistics for job 1009 (forward process).
# Display detailed umem memory statistics for the process identified by job ID 1003.
<Sysname> display process memory umem job 1009 verbose
Main cache information for the user process:
Name               Inuse        Total        Import       Alloc        Free        Active
mmap_top           13631488     14680064     0            21           0            21
mmap_heap          13631488     13631488     13631488     21           0            21
vmem_internal      524288       524288       524288       2            0            2
vmem_seg           262144       262144       262144       1            0            1
umem_default       5505024      5505024      5505024      21           0            21
Detailed cache information for the user process:
Cachename            Bufsize  Chunksize Activebuf Buftotal  Slabsize  Activeslabs  Total
Cache                Magsize  Color     Fullmag   Emptymag
umem_magazine_143    1152      1152      5          227       262144    1            262144
0x7fc8dd140030       95       64        0         0
umem_magazine_95     768      768       0         0         262144    0           0
Table 14 Command output
Total umem virtual memory size, in bytes.
Total umem physical memory size, in bytes.
Total used umem physical memory size, in bytes.
Information about the main cache pool used by the user process.
Name
Name of the cache pool.
Inuse
Used cache pool size, in bytes.
Total
Total memory size used by the cache pool, in bytes.
Import
Size of memory requested from the upper-level cache, in bytes.
Alloc
Number of memory blocks allocated from the cache pool.
Free
Number of free memory blocks in the cache pool.
Active
Number of active memory blocks in the cache pool.
Detailed information about all cache pools used by the user process.
Cachename
Bufsize
Size of the buffer requested by the user process, in bytes.
Chunksize
Chunk size, in bytes.
Activebuf
Number of buffers in use.
Buftotal
Total number of buffers.
Slabsize
Slab size, in bytes.
Activeslabs
Number of slabs in use.
Total
Total memory size used by the cache, in bytes.
Cache
Start address of the cache pool.
Magsize
Magazine size, in bytes.
Color
Cache color.
Fullmag
Number of full magazines.
Emptymag
Number of empty magazines.
display process
exception filepath
Use exception filepath to specify the directory for saving core dump files.
Use undo exception filepath to remove the specified directory.
exception filepath directory
undo exception filepath directory
The directory for saving core dump files is the root directory of the default file system. For more information about the default file system, see file system management in Fundamentals Configuration Guide.
directory: Specifies the directory for saving core dump files. The directory must be the root directory of a file system.
The system will save core dump files to the core folder in the specified directory on the active MPU. If the core folder does not exist in the specified directory, the system creates the core folder before saving core dump files.
You can use the command to change the directory if there are different types of storage media on the device.
If no directory is specified or the specified directory is not accessible, the system cannot save core dump files.
# Set the directory for saving core dump files to flash:/.
<Sysname> exception filepath flash:/
process core
monitor kernel deadloop enable
Use monitor kernel deadloop enable to enable kernel thread deadloop detection.
Use undo monitor kernel deadloop enable to disable kernel thread deadloop detection.
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command applies to the active MPU.
CAUTION
CAUTION:
Use this command only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
Kernel threads share resources in kernel space. If a kernel thread monopolizes the CPU for a long time, other threads cannot run, resulting in a deadloop.
This command enables the device to detect deadloops. If a thread occupies the CPU regularly, the device considers that a deadloop has occurred.
# Enable kernel thread deadloop detection.
[Sysname] monitor kernel deadloop enable
monitor kernel deadloop time
Use monitor kernel deadloop exclude-thread to exclude a kernel thread from kernel thread deadloop detection.
Use undo monitor kernel deadloop exclude-thread to include a kernel thread in kernel thread deadloop detection.
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection monitors all kernel threads.
tid: Specifies a kernel thread by its ID, in the range of 1 to 2147483647. If you do not specify a kernel thread, the undo command restores the default.
You can exclude up to 128 kernel threads from kernel thread deadloop detection.
# Exclude kernel thread 15 from kernel thread deadloop detection.
[Sysname]monitor kernel deadloop exclude-thread 15
Use monitor kernel deadloop time to set the threshold for identifying a kernel thread deadloop.
Use undo monitor kernel deadloop time to restore the default.
monitor kernel deadloop time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop time [ slot slot-number [ cpu cpu-number ] ]
The threshold for identifying a kernel thread deadloop is 10 seconds.
time time: Specifies the threshold for identifying a kernel thread deadloop, in the range of 1 to 65535 seconds.
If a kernel thread runs for the specified period of time, kernel thread deadloop detection considers that a deadloop has occurred.
# Set the threshold for identifying a kernel thread deadloop to 8 seconds.
[Sysname] monitor kernel deadloop time 8
Use monitor kernel starvation enable to enable kernel thread starvation detection.
Use undo monitor kernel starvation enable to disable kernel thread starvation detection.
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection is disabled.
CAUTION
CAUTION:
Starvation occurs when a thread is unable to access shared resources.
The command enables the system to detect and report thread starvation. If a thread is not executed within an interval, the system considers that a starvation has occurred, and outputs a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
# Enable kernel thread starvation detection.
[Sysname] monitor kernel starvation enable
Use monitor kernel starvation exclude-thread to exclude a kernel thread from kernel thread starvation detection.
Use undo monitor kernel starvation exclude-thread to include a kernel thread in kernel thread starvation detection.
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection, if enabled, monitors all kernel threads.
You can exclude up to 128 kernel threads from kernel thread starvation detection.
# Exclude kernel thread 15 from kernel thread starvation detection.
[Sysname] monitor kernel starvation exclude-thread 15
Use monitor kernel starvation time to set the threshold for identifying a kernel thread starvation.
Use undo monitor kernel starvation time to restore the default.
monitor kernel starvation time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation time [ slot slot-number [ cpu cpu-number ] ]
The threshold for identifying a kernel thread starvation is 120 seconds.
time time: Specifies the threshold for identifying a kernel thread starvation, in the range of 1 to 65535 seconds.
If a thread is not executed within the specified period of time, the system considers that a starvation has occurred, and outputs a starvation message.
# Set the threshold for identifying a kernel thread starvation to 120 seconds.
[Sysname] monitor kernel starvation time 120
monitor process
Use monitor process to display process statistics.
monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
dumbtty: Specifies dumbtty mode. In this mode, the command displays process statistics in descending order of CPU usage without refreshing statistics. If you do not specify this keyword, the command displays statistics for the top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times and process statistics are refreshed every 5 seconds.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays process statistics for the active MPU.
If you do not specify the dumbtty keyword, the command displays process statistics in an interactive mode. In this mode, the system automatically determines the number of displayed processes according to the screen size, and does not display exceeding processes. You can also input interactive commands as shown in Table 15 to perform relevant operations.
Table 15 Interactive commands
Commands
? or h
Displays help information that includes available interactive commands.
1
Displays state information for physical CPUs. For example, if you enter 1 for the first time, the state of each physical CPU is displayed in a separate row. If you enter 1 again, the average value of all CPU states is displayed. If you enter 1 for the third time, separate states are displayed.
By default, the average value of all CPU states is displayed.
c
Sorts processes by CPU usage in descending order, which is the default setting.
d
Sets the interval for refreshing process statistics, in the range of 1 to 2147483647 seconds. The default value is 5 seconds.
f
Sorts processes by the number of open files in descending order. Files are identified by file descriptors (FDs).
k
Kills a process. Because the command can impact system operation, be cautious to use it.
l
Refreshes the screen.
m
Sorts processes by memory usage in descending order.
n
Changes the maximum number of processes displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only processes not exceeding the screen size can be displayed.
q
Quits the interactive mode.
t
Sorts processes by running time in descending order.
Moves sort field to the next left column.
Moves sort field to the next right column.
# Display process statistics in dumbtty mode. In this mode, the system displays process statistics once, and then returns to command view.
<Sysname> monitor process dumbtty
79 processes; 416 threads; 8473 FDs
Thread states: 1 running, 415 sleeping, 0 stopped, 0 zombie
CPU0  states: 95.55% idle, 2.67% user, 1.78% kernel, 0.00% interrupt
CPU1  states: 98.22% idle, 0.89% user, 0.89% kernel, 0.00% interrupt
CPU2  states: 99.12% idle, 0.00% user, 0.88% kernel, 0.00% interrupt
CPU3  states: 86.62% idle, 5.35% user, 8.03% kernel, 0.00% interrupt
Container CPU0  states: 4.46%
Container CPU1  states: 3.57%
Container CPU2  states: 2.65%
Container CPU3  states: 12.50%
Memory: 15952M total, 11880M available, page size 4K
Container memory: 15952M total, 11880M available
       JID        PID  PRI State  FDs      MEM HH:MM:SS    CPU  C-CPU  Name
       920        920  120   S     67  341444K 01:34:07  2.45%  2.79% diagd
       652        652  100   S    711 3060976K 12:00:05  1.47%  1.67% drvuserd
       940        940  120   S   1038 3881152K 04:12:51  0.49%  0.55% forward
         1          1  120   S     45  174952K 00:00:03  0.24%  0.27% scmd
      1077       1077  120   S    132  379140K 00:18:44  0.24%  0.27% ethd
# Display process statistics twice in dumbtty mode.
<Sysname> monitor process dumbtty iteration 2
CPU1  states: 99.10% idle, 0.00% user, 0.90% kernel, 0.00% interrupt
CPU2  states: 92.80% idle, 2.70% user, 4.50% kernel, 0.00% interrupt
CPU3  states: 90.92% idle, 3.63% user, 5.45% kernel, 0.00% interrupt
Container CPU0  states: 5.35%
Container CPU1  states: 3.60%
Container CPU2  states: 2.70%
Container CPU3  states: 10.00%
Memory: 15952M total, 11878M available, page size 4K
Container memory: 15952M total, 11878M available
       920        920  120   S     67  341444K 01:34:07  2.47%  2.57% diagd
       652        652  100   S    711 3060976K 12:00:09  1.12%  1.16% drvuserd
       940        940  120   S   1038 3881152K 04:12:52  0.44%  0.46% forward
      1544       1544  120   S    144  431872K 02:19:58  0.44%  0.46% isisd
         1          1  120   S     45  174952K 00:00:03  0.22%  0.23% scmd
      1077       1077  120   S    132  379140K 00:18:44  0.22%  0.23% ethd
Five seconds later, the system refreshes process statistics as follows (which is the same as executing the monitor process dumbtty command twice at a 5-second interval):
CPU0  states: 95.90% idle, 2.54% user, 1.56% kernel, 0.00% interrupt
CPU1  states: 94.12% idle, 1.96% user, 3.92% kernel, 0.00% interrupt
CPU2  states: 96.88% idle, 1.95% user, 1.17% kernel, 0.00% interrupt
CPU3  states: 98.45% idle, 0.58% user, 0.97% kernel, 0.00% interrupt
Container CPU0  states: 4.69%
Container CPU1  states: 4.50%
Container CPU2  states: 2.34%
Container CPU3  states: 1.76%
       652        652  100   S    711 3060976K 12:00:09  1.58%  1.43% drvuserd
       920        920  120   S     67  341444K 01:34:07  0.70%  0.64% diagd
       940        940  120   S   1038 3881152K 04:12:52  0.54%  0.49% forward
      1544       1544  120   S    144  431872K 02:19:58  0.27%  0.24% isisd
       853        853  120   S     33  194772K 00:27:33  0.10%  0.09% loads
      1573       1573  120   S     79  350424K 00:46:47  0.10%  0.09% nqad
       865        865  120   S    115  541132K 00:00:25  0.05%  0.04% devd
      1094       1094  120   S    103  448796K 00:12:33  0.05%  0.04% staticrtd
# Display process statistics in interactive mode.
79 processes; 416 threads; 8474 FDs
CPU states: 96.53% idle, 1.76% user, 1.71% kernel, 0.00% interrupt
Container CPU states: 3.37% total, 1.68% user, 1.69% system
Memory: 15952M total, 11877M available, page size 4K
Container memory: 15952M total, 11877M available
       652        652  100   S    711 3060976K 12:00:14  1.45%  1.41% drvuserd
       920        920  120   S     67  341444K 01:34:08  0.64%  0.63% diagd
       940        940  120   S   1039 3881152K 04:12:54  0.50%  0.48% forward
      1544       1544  120   S    144  431872K 02:19:59  0.29%  0.29% isisd
      1077       1077  120   S    132  379140K 00:18:45  0.09%  0.09% ethd
      1573       1573  120   S     79  350424K 00:46:47  0.09%  0.09% nqad
       853        853  120   S     33  194772K 00:27:33  0.04%  0.04% loads
       921        921  120   S     65  397888K 00:00:21  0.04%  0.04% lauthd
       928        928  120   S    150  514804K 00:13:14  0.04%  0.04% vland
      1545       1545  125   S    110  449236K 00:24:54  0.04%  0.04% ip6addrd
The system refreshes process statistics every 5 seconds. You can enter interactive commands to perform operation as follows:
·     Enter h or a question mark (?) to display help information as follows:
Help for interactive commands:
      ?,h    Show the available interactive commands
        1    Toggle SMP view: '1' single/separate states
        c    Sort by the CPU field(default)
        d    Set the delay interval between screen updates
        f    Sort by number of open files
        k    Kill a job
        l    Refresh the screen
        m    Sort by memory used
        n    Set the maximum number of processes to display
        q    Quit the interactive display
        t    Sort by run time of processes since last restart
        <    Move sort field to the next left column
        >    Move sort field to the next right column
Press any key to continue
·     Enter d, and then enter a number to modify the refresh interval. If you enter 3, statistics are refreshed every 3 seconds.
Enter the delay interval between updates(1~2147483647): 3
·     Enter n, and then enter a number to modify the maximum number of displayed processes. If you enter 5, statistics for five processes are displayed.
CPU states: 96.06% idle, 1.77% user, 2.17% kernel, 0.00% interrupt
Container CPU states: 3.62% total, 1.68% user, 1.94% system
       652        652  100   S    711 3060976K 12:00:40  1.55%  1.42% drvuserd
       920        920  120   S     67  341444K 01:34:23  1.00%  0.92% diagd
       940        940  120   S   1038 3881152K 04:13:03  0.63%  0.58% forward
      1544       1544  120   S    144  431872K 02:20:04  0.26%  0.24% isisd
      1077       1077  120   S    132  379140K 00:18:45  0.17%  0.16% ethd
·     Enter f to sort processes by FDs in descending order. (You can also enter command c, m, or t to sort processes.)
CPU states: 95.84% idle, 2.08% user, 2.08% kernel, 0.00% interrupt
Container CPU states: 4.49% total, 2.15% user, 2.34% system
       940        940  120   S   1038 3881152K 04:13:04  0.53%  0.57% forward
       652        652  100   S    711 3060976K 12:00:42  1.21%  1.30% drvuserd
       898        898  120   S    278  835480K 00:01:41  0.00%  0.00% ifast
       880        880  100   S    213  681996K 00:00:01  0.00%  0.00% ifmgr
      1078       1078  120   S    194  644916K 00:00:06  0.00%  0.00% qosd
       861        861  100   S    175  829244K 00:00:01  0.00%  0.00% dbmd
      1637       1637  120   S    172  554460K 00:12:16  0.13%  0.14% bgpd
      1440       1440  110   S    168  580800K 00:19:17  0.00%  0.00% laggd
       928        928  120   S    150  514804K 00:13:15  0.13%  0.14% vland
      1076       1076  120   S    149  564588K 00:19:38  0.00%  0.00% macd
·     Enter k and then enter a JID to kill a process. If you enter 884, the process with the JID of 884 is killed.
Enter the JID to kill: 884
78 processes; 414 threads; 8401 FDs
Thread states: 2 running, 412 sleeping, 0 stopped, 0 zombie
CPU states: 96.43% idle, 1.76% user, 1.81% kernel, 0.00% interrupt
Container CPU states: 3.33% total, 1.63% user, 1.70% system
       652        652  100   S    711 3060976K 12:00:48  1.45%  1.35% drvuserd
       920        920  120   S     67  341444K 01:34:26  0.65%  0.60% diagd
       940        940  120   S   1037 3881152K 04:13:06  0.50%  0.46% forward
      1544       1544  120   S    144  431872K 02:20:06  0.29%  0.27% isisd
       928        928  120   S    150  514804K 00:13:15  0.09%  0.09% vland
      1094       1094  120   S    103  448796K 00:12:34  0.09%  0.09% staticrtd
      1573       1573  120   S     79  350424K 00:46:49  0.09%  0.09% nqad
       853        853  120   S     33  194772K 00:27:34  0.04%  0.04% loads
      1076       1076  120   S    149  564588K 00:19:38  0.04%  0.04% macd
      1545       1545  125   S    110  449236K 00:24:56  0.04%  0.04% ip6addrd
·     Enter q to quit interactive mode.
Table 16 Command output
Numbers of processes, threads, and open files.
Statistics of threads in running, sleeping, stopped, and zombie states.
CPU states
CPU usage of the device: Free CPU usage, CPU usage in user space, CPU usage in the kernel space, and CPU usage of interrupts.
CPU usage of the container.
Memory
Memory usage of the device: Total memory size, free memory, and page size, in KB.
Container Memory
Memory usage of the container: Total memory size and free memory size in KB.
JID
Job ID of a process, which never changes.
PID
ID of a process.
PRI
Priority level of a process.
State of a process:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
FDs
Number of open files for a process.
MEM
Memory usage. It displays 0 for a kernel thread.
HH:MM:SS
Running time of a process since last restart.
CPU
CPU usage of a process on the device.
C-CPU
CPU usage of a process in the container.
Name
Name of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
monitor thread
Use monitor thread to display thread statistics.
monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
dumbtty: Specifies dumbtty mode. In this mode, the command displays all thread statistics in descending order of CPU usage without refreshing statistics. If you do not specify the keyword, the command displays statistics for top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays thread statistics for the active MPU.
If you do not specify the dumbtty keyword, the command displays thread statistics in an interactive mode. In this mode, the system automatically determines the number of displayed thread processes according to the screen size and does not display exceeding processes. You can also input interactive commands as shown in Table 17 to perform relevant operations.
Table 17 Interactive commands
Commands
? or h
1
Displays one of the following items in turn when you press 1 again and again:
·     Values of parameters of physical CPUs.
·     Average values of parameters of all CPUs.
By default, the command displays the average values of parameters of all CPUs.
c
Sorts statistics by CPU usage in descending order. By default, the command sorts statistics by CPU usage in descending order.
d
Sets the interval for refreshing statistics. The default interval is 5 seconds.
k
Kills a process. Because the command can impact system operation, be cautious when you use it.
l
n
Changes the maximum number of threads displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only threads not exceeding the screen size can be displayed.
q
Quits interactive mode.
t
Sorts statistics by the running time since the latest startup.
# Display thread statistics in dumbtty mode.
<Sysname> monitor thread dumbtty
72 processes; 326 threads
Thread states: 4 running, 322 sleeping, 0 stopped, 0 zombie
CPU0  states: 0.01% idle, 22.88% user, 77.11% kernel, 0.00% interrupt
CPU1  states: 93.08% idle, 0.00% user, 0.00% kernel, 6.92% interrupt
CPU2  states: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt
CPU3  states: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt
CPU4  states: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt
CPU5  states: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt
CPU6  states: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt
CPU7  states: 100.00% idle, 0.00% user, 0.00% kernel, 0.00% interrupt
Container CPU0  states: 107.46%
Container CPU1  states: 0.00%
Container CPU2  states: 0.00%
Container CPU3  states: 0.46%
Container CPU4  states: 0.00%
Container CPU5  states: 0.46%
Container CPU6  states: 0.00%
Container CPU7  states: 0.00%
Memory: 3932M total, 173M available, page size 4K
Container memory: 3932M total, 173M available
       JID        TID LAST_CPU  PRI State HH:MM:SS   MAX    CPU  C-CPU  Name
       862        862     0     120   R   15:47:52     0  4.54%  4.56% scanengi
       861        861     0     120   R   15:47:52     0  4.36%  4.38% managerd
       897       1001     0     120   R   15:47:48     0  3.42%  3.44% NDClient
       878        878     0     120   S   00:08:06     0  0.08%  0.08% diagd
       897       1027     0     120   S   00:03:23     0  0.08%  0.08% APMGRFW_
      1443       1444     0     120   S   00:01:09     0  0.08%  0.08% ccf_thre
# Display thread statistics in interactive mode.
CPU states: 87.00% idle, 3.73% user, 8.71% kernel, 0.56% interrupt
Container CPU states: 12.55% total, 3.72% user, 8.83% system
       861        861     0     120   R   15:48:07     0  4.06%  3.92% managerd
       897       1001     0     120   R   15:48:03     0  4.06%  3.92% NDClient
       862        862     0     120   R   15:48:07     0  3.95%  3.81% scanengi
         1          1     0     120   S   00:00:00     0  0.11%  0.10% scmd
       897        958     0     120   S   00:06:47     0  0.11%  0.10% AGINGQUE
       897        960     3     120   S   00:05:03     0  0.11%  0.10% AGINGQUE
       897       1002     0     120   S   00:02:48     0  0.11%  0.10% TP_TIMER
       897       1027     0     120   S   00:03:23     0  0.11%  0.10% APMGRFW_
       897       8128     0     120   S   00:00:49     0  0.11%  0.10% ND_MAIN
       897       8134     0     120   S   00:01:15     0  0.11%  0.10% IP6ADDR
          k      Kill a job
          n      Set the maximum number of threads to display
          t      Sort by run time of threads since last restart
Enter the delay interval between screen updates (1~2147483647): 3
·     Enter n, and then enter a number to modify the maximum number of displayed threads. If you enter 5, statistics for five threads are displayed.
Enter the max number of threads to display(0 means unlimited): 5
CPU states: 86.65% idle, 3.37% user, 9.07% kernel, 0.91% interrupt
Container CPU states: 12.54% total, 3.39% user, 9.15% system
       861        861     0     120   R   15:48:17     0  4.26%  4.00% managerd
       862        862     0     120   R   15:48:17     0  4.26%  4.00% scanengi
       897       1001     0     120   R   15:48:13     0  4.26%  4.00% NDClient
       897        958     0     120   S   00:06:47     0  0.04%  0.04% AGINGQUE
       897        960     3     120   S   00:05:03     0  0.04%  0.04% AGINGQUE
·     Enter k and then enter a JID to kill a thread. If you enter 881, the thread with the JID of 881 is killed.
Enter the JID to kill: 861
71 processes; 325 threads
Thread states: 3 running, 322 sleeping, 0 stopped, 0 zombie
CPU states: 86.95% idle, 3.21% user, 9.23% kernel, 0.61% interrupt
Container CPU states: 12.52% total, 3.24% user, 9.28% system
Memory: 3932M total, 175M available, page size 4K
Container memory: 3932M total, 175M available
       897       1001     0     120   R   15:48:21     0  6.23%  5.97% NDClient
       862        862     0     120   R   15:48:25     0  6.21%  5.95% scanengi
       878        878     0     120   S   00:08:07     0  0.07%  0.06% diagd
       897        962     5     120   S   00:04:55     0  0.04%  0.04% AGINGQUE
      8132       8132     0     125   S   00:02:26     0  0.04%  0.04% ip6addrd
Table 18 Command output
Numbers of processes and threads.
Thread states
CPU states
Memory
Container Memory
Memory usage of the container: Total memory size and free memory size, in KB.
JID
Job ID of a thread, which never changes.
TID
ID of a thread.
LAST_CPU
Number of the CPU on which the most recent thread scheduling occurs.
PRI
Priority level of a thread.
State of a thread:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
HH:MM:SS
Running time of a thread since last restart.
MAX
Longest time that a single thread scheduling occupies the CPU, in milliseconds.
CPU
CPU usage of a thread on the device.
C-CPU
CPU usage of a thread in a container.
Name
Name of a thread. If square brackets ([ ]) exist in a thread name, the thread is a kernel thread.
process core
Use process core to enable or disable a process to generate core dump files for exceptions and set the maximum number of core dump files.
process core { maxcore value | off } { job job-id | name process-name } [ slot slot-number [ cpu cpu-number ] ]
A process generates a core dump file for the first exception and does not generate any core dump files for subsequent exceptions.
off: Disables core dump file generation.
maxcore value: Enables core dump file generation and sets the maximum number of core dump files, in the range of 1 to 10.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. The job ID does not change after the process restarts.
cpu cpu-number: Specifies a CPU by its number.
The command applies to all instances of a process.
The command enables the system to generate a core dump file each time the specified process crashes until the maximum number of core dump files is reached. A core dump file records the exception information.
Because the core dump files consume system storage resources, you can disable core dump file generation for processes for which you do not need to review exception information.
# Disable core dump file generation for process routed.
<Sysname> process core off name routed
# Enable core dump file generation for process routed and set the maximum number of core dump files to 5.
<Sysname> process core maxcore 5 name routed
display exception context
exception filepath
reset exception context
Use reset exception context to clear context information for process exceptions.
reset exception context [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command clears context information for process exceptions on the active MPU.
# Clear context information for exceptions.
<Sysname> reset exception context
Use reset kernel deadloop to clear kernel thread deadloop information.
reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command clears kernel thread deadloop information for the active MPU.
# Clear kernel thread deadloop information.
<Sysname> reset kernel deadloop
Use reset kernel exception to clear kernel thread exception information.
reset kernel exception [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command clears kernel thread exception information for the active MPU.
# Clear kernel thread exception information.
<Sysname> reset kernel exception
reset kernel reboot
Use reset kernel reboot to clear kernel thread reboot information.
reset kernel reboot [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command clears kernel thread reboot information for the active MPU.
# Clear kernel thread reboot information.
<Sysname> reset kernel reboot
Use reset kernel starvation to clear kernel thread starvation information.
reset kernel starvation [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an MPU by its slot number. If you do not specify an MPU, this command clears kernel thread starvation information for the active MPU.
# Clear kernel thread starvation information.
<Sysname> reset kernel starvation
