02-License Management Command Reference
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Reference GuidesCommand ReferencesH3C MSR5680-X3 Router Command Reference-R9141-6W10102-License Management Command Reference
01-License management commands
01-License management commands 137.79 KB
display license
Use display license to display detailed license information.
display license [ activation-file | activation-key | license-key ] [ slot slot-number ]
activation-file: Displays license information about activation files.
activation-key: Displays license information about activation keys.
license-key: Displays license information about license keys.
slot slot-number: Specifies the slot number of an MPU. If no slot number is specified, this command displays license information for all MPUs.
If you do not specify any parameters, this command displays detailed information about all licenses.
# Display detailed information about all licenses.
<Sysname> display license
Feature: opt
Feature Description: opt license.
Activation Key: QvkT-%gfS-Xz/4-jR@V-9g%3-79wv-NMFG-kmJ9
Registered at: 2013-02-23 11:36:09
License Type: Days restricted
Time Left (days): 249
Current State: In use
flash:/license/2014072009113494375.ak
Feature: LISP EVB evi mdc SPBM TRILL FCoE
Product Description: Advanced Data Center License
Registered at: 2014-05-07 15:07:39
License Type: Permanent
Feature
Feature name.
Product Description
License description.
Registered at
Time when the license was installed.
License Type
License type by validity period:
·     NA—The system cannot obtain the license type.
·     Permanent—Purchased license that never expires and is always valid.
·     Days restricted—Purchased license that is valid for a period of days, for example, 30 days.
·     Date restricted—Purchased license that is valid for an absolute date range, for example, 2015-05-01 to 2015-05-30.
·     Trial (days restricted)—Free trial license that is valid for a period of days.
·     Trial (date restricted)—Free trial license that is valid for an absolute date range.
Time Left (days)
Remaining days of the license. This field is available for a purchased license.
Trial Time Left (days)
Remaining days of the trial period. This field is available for a trial license.
Validity Period
Start date and end state for a date restricted purchased license. If the license is permanent, this field displays No limit.
Trial Validity Period
Start date and end state for a date restricted trial license. If the license is permanent, this field displays No limit.
Current State
State of the license:
·     In use—The license is being used.
·     Usable—The license is available for use.
¡     If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state.
¡     A date restricted license is in this state if its start date is not reached.
·     Expired—The license has expired.
·     Uninstalled—The license has been uninstalled.
·     Unusable—The license cannot be used.
·     Invalid—The license is invalid and cannot be used.
Uninstall Key
This field is available for licenses that have been uninstalled.
Uninstall Date
Date when the activation file was uninstalled.
display license device-id
Use display license device-id to display SN and DID information.
display license device-id slot slot-number
When you register a license for an MPU, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# Display the SN and DID for the specified slot.
<Sysname> display license device-id slot 1
SN: 210235A1LFX176000002
Device ID: jFvq-zRGA-DpJy-VK@d-$Zz+-QjA7-$pLP-xvzR
display license feature
Use display license feature to display brief license information for features.
# Display brief feature license information.
<Sysname> display license feature
Slot 0:
Total: 64  Usage: 1
Feature                         Licensed        State
EVB                             Y               Trial
FCoE                            Y               Trial
SPBM                            Y               Trial
TRILL                           Y               Trial
evi                             Y               Trial
Total
Total number of licenses that can be installed.
Usage
Number of licenses stored in the license storage.
Feature
Feature that must be licensed before being used.
The device does not support EVI in the current software version.
Licensed
Licensing state of the feature:
·     N—Not licensed.
·     Y—Licensed.
License type by purchasing state:
·     Formal—Purchased license.
·     Pre-licensed—Preinstalled license.
·     Trial—Trial license.
If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license for the feature.
license activation-file install
Use license activation-file install to install an activation file.
license activation-file install file-name slot slot-number
file-name: Specifies the path of an activation file or an activation file package, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
Activation files can be released in either of the following forms:
·     A single .ak file.
To obtain an .ak activation file, purchase a license key, access H3C License Management Platform, and provide the license key, SN and DID information.
·     A .tar file package.
To obtain a .tar activation file package, purchase multiple license keys, access H3C License Management Platform, and provide the license keys, SN and DID information.
The activation file package is a set of .ak activation files corresponding to the license keys. Activation file packages are installed in the same way as single activation files are installed. The use of activation file packages simplifies the management of activation files by reducing the number of times you register and install activation files. However, to uninstall a license, you can uninstall .ak activation files one by one only.
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the specified MPU.
Activation files are MPU locked rather than device locked. A licensed feature can run on the MPU where its activation file is installed even after the MPU is moved between devices.
# Install activation file 20130811.ak to the specified slot.
[Sysname] license activation-file install flash:/license/20130811.ak slot 0
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...
# Install activation file package 20170101.tar to the specified slot.
[Sysname] license activation-file install flash:/license/20170101.tar slot 0
Decompress......Done.
Begain to install test01.ak …Done.
Begain to install test02.ak …Done.
Begain to install test03.ak …Done.
Total Num:3
Success Num:3
Failed Num:0
display license
license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
license activation-file uninstall file-name slot slot-number
file-name: Specifies the file path, a case-sensitive string of 1 to 127 characters.
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# Uninstall activation file flash:/license/20130811.ak from the specified slot.
[Sysname] license activation-file uninstall flash:/license/20130811.ak slot 0
Uninstall file: flash:/license/20130811.uak
display license
license activation-key install
Use license activation-key install to install an activation key.
license activation-key install activation-key-string slot slot-number
activation-key-string: Specifies the activation key. The key must be in the format of XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX. The string is case sensitive and must be valid.
To install a license activation key successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the specified MPU.
Activation keys are MPU locked rather than device locked. A licensed feature can run on the MPU where its activation key is installed even after the MPU is moved between devices.
# Install an activation key on the specified slot.
[Sysname] license activation-key install XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX slot 1
display license
license activation-key uninstall
Use license activation-key uninstall to uninstall an activation key.
license activation-key uninstall activation-key-string slot slot-number
activation-key-string: Specifies the activation key. The key must be in the format of XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX. The string is case sensitive. The activation key must not be expired.
If an activation key is uninstalled, the system creates an Uninstall key. Use this key together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation keys.
Trial licenses are not transferrable. When you uninstall the activation key of a trial license, no Uninstall key is created.
# Uninstall an activation key from the specified slot.
[Sysname] license activation-key uninstall XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX slot 1
Uninstall key: YYYY-YYYY-YYYY-YYYY-YYYY-YYYY-YYYY-YYYY
display license
license compress
Use license compress to compress the license storage.
license compress slot slot-number
The license storage is limited. You can execute this command to clear expired licenses and uninstalled licenses from the license storage.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID or DID file change. Before performing a compression, make sure all licenses registered with the old DID or DID file have been installed. You will be unable to install such licenses after the compression.
# Compress the license storage on the specified slot.
[Sysname] license compress slot 0
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
license license-key install
Use license license-key install to install a license key.
license license-key install license-key-string slot slot-number
license-key-string: Specifies a license key, a string of case-sensitive characters.
License keys are MPU locked rather than device locked. A licensed feature can run on the MPU where its license key is installed even after the MPU is moved between devices.
You can install a license key on multiple devices.
# Install a license key to the specified slot.
[Sysname] license license-key install XXXXXXXX-(XXXX-)XXXXXXXX-XXXXXXXX-XXXXXXXX slot 1
display license license-key
license license-key uninstall
Use license license-key uninstall to uninstall a license key.
license license-key uninstall license-key-string slot slot-number
license-key-string: Specifies a license key, a string of case-sensitive characters. The key must not be expired.
A feature cannot run correctly after you uninstall all of its license keys.
# Uninstall a license key from the specified slot.
[Sysname] license license-key uninstall XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX slot 1
display license
display license [ activation-file ]
Feature
Feature name.
Product Description
Registered at
License Type
·     Date restricted—Purchased license that is valid for an absolute date range, for example, 2013-05-01 to 2013-05-30.
Time Left (days)
Validity Period
Current State
Uninstall Key
Uninstall Date
Each device has a unique SN and DID. When you register a license for a device, you must provide its SN and DID.
# Display the device SN and DID.
Device ID:jFvq-zRGA-DpJy-VK@d-$Zz+-QjA7-$pLP-xvzR
Total: 80  Usage: 1
ACG                             Y               Formal
IPS                             Y               Formal
SSLVPN                          Y               Formal
WEB-CACHE                       Y               Formal
Total
Usage
Feature
The device does not support EVB, LISP, or EVI in the current software version.
Licensed
·     N—Not licensed.
·     Y—Licensed.
file-name: Specifies the file path, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
License registration requires the device's hardware SN and DID.
# Install activation file 20130810.ak.
[Sysname] license activation-file install flash:/license/20130810.ak
display license
# Uninstall activation file flash:/license/20130810.ak.
[Sysname] license activation-file uninstall flash:/license/20130810.ak
Uninstall file: flash:/license/20130810.uak
display license
license compress
license compress
This command clears invalid licenses (expired licenses and uninstalled licenses) and Uninstall keys from the license storage area. Back up the Uninstall keys before you compress the license storage.
# Compress the license storage.
