08-Layer 3—IP Services Configuration Guide
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration GuidesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)-R9141-6W10008-Layer 3—IP Services Configuration Guide
18-Multi-CPU packet distribution configuration
18-Multi-CPU packet distribution configuration 42.49 KB
Configuring multi-CPU packet distribution
About multi-CPU packet distribution
On a multi-CPU device, packets can be distributed among CPUs based on one of the following policies:
·     Flow-based policy—Forwards packets of a flow to the same CPU. A data flow is defined by using the following fields: source IP address, destination IP address, source port number, destination port number, and protocol number. This policy takes the first-in first-out rule.
·     Packet-based policy—Forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
Restrictions and guidelines: Multi-CPU packet distribution configuration
·     If a service requires packets of a flow to be received by the same CPU, you must use the flow-based policy.
·     The packet distribution policy takes effect on all interfaces.
Specifying a multi-CPU packet distribution policy
2.     Specify a packet distribution policy.
forwarding policy { per-flow | per-packet }
By default, flow-based policy is used.
