03-System Management Configuration Guide
HomeSupportRoutersSR6602-I[IE] SeriesConfigure & DeployConfiguration GuidesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Configuration Guides(V9)-R9141-6W10003-System Management Configuration Guide
06-Flow log configuration
06-Flow log configuration 132.50 KB
Configuring flow log
About flow log
Flow log records users' access to external networks based on flows. Each flow is identified by a 5-tuple of the source IP address, destination IP address, source port, destination port, and protocol number.
Flow log creates entries based on NAT sessions.
Flow log export
You can export flow log entries in the following methods:
·     Export flow log entries to log hosts. Flow log entries are sent as binary characters in UDP. One UDP packet can contain multiple log entries.
·     Export flow log entries to the information center. Flow log entries are converted to syslog entries in ASCII format, with the informational severity level. The information center specifies the output destinations for the logs. Available output destinations include the console, log host, and log file. For more information about the information center, see "Configuring the information center."
Log entries in ASCII format are human readable. However, the log data volume is higher in ASCII format than in binary format.
Flow log versions
Flow log has the following versions: version 1.0, version 3.0, and version 7.0. Table 1, Table 2, and Table 3 show the fields available in the versions.
Table 1 Flow log 1.0 fields
SrcIP
Source IP address before NAT.
DestIP
Destination IP address before NAT.
SrcPort
Source TCP/UDP port number before NAT.
DestPort
Destination TCP/UDP port number before NAT.
StartTime
Start time of the flow, in seconds.
EndTime
End time of the flow, in seconds.
This field is 0 if the Operator field is 6 (regular connectivity check record for the active flow).
Protocol
Protocol number.
Operator
Reasons why a flow log entry was generated:
·     0—Reserved.
·     1—Flow was ended normally.
·     2—Flow was aged out because of aging timer expiration.
·     3—Flow was aged out because of configuration change or manual deletion.
·     4—Flow was aged out because of insufficient resources.
·     5—Reserved.
·     6—Regular connectivity check record for the active flow.
·     7—Flow was deleted because a new flow was created when the flow table was full.
·     8—Flow was created.
·     FE—Other reasons.
·     10-FE-1—Reserved for future use.
Reserved
Table 2 Flow log 3.0 fields
Protocol
Protocol number.
Operator
Reasons why a flow log was generated:
·     0—Reserved.
·     3—Flow was aged out because of configuration change.
·     5—Reserved.
·     FE—Other reasons.
IPVersion
IP packet version.
TosIPv4
ToS field of the IPv4 packet.
SourceIP
SrcNatIP
Source IP address after NAT.
DestIP
DestNatIP
Destination IP address after NAT.
SrcPort
SrcNatPort
Source TCP/UDP port number after NAT.
DestPort
DestNatPort
Destination TCP/UDP port number after NAT.
StartTime
EndTime
This field is 0 when the Operator field is 6 (regular connectivity check record for the active flow).
InTotalPkg
Number of packets received for the session.
InTotalByte
Number of bytes received for the session.
OutTotalPkg
Number of packets sent for the session.
OutTotalByte
Number of bytes sent for the session.
InVPNID
ID of the source VPN instance.
OutVPNID
ID of the destination VPN instance.
Reserved1
Reserved field.
AppID
Application protocol ID.
Reserved3
Reserved field.
Table 3 Flow log 7.0 fields
Protocol
Protocol number.
Operator
·     0—Reserved.
·     5—Reserved.
·     FE—Other reasons.
IPVersion
IP packet version.
TosIPv4
SourceIP
SrcNatIP
DestIP
DestNatIP
SrcPort
SrcNatPort
DestPort
DestNatPort
StartTime
EndTime
InTotalPkg
InTotalByte
OutTotalPkg
OutTotalByte
InVPNID
OutVPNID
Reserved1
Reserved field.
AppID
aucDeviceSN
Device SN.
Flow log tasks at a glance
To configure flow log, perform the following tasks:
1.     Specifying a flow log export destination
¡     Specifying a log host as the flow log export destination
¡     Specifying the information center as the flow log export destination
2.     (Optional.) Configuring the flow log version
3.     (Optional.) Specifying a source IP address for flow log packets
4.     (Optional.) Configuring the timestamp of flow log entries
5.     (Optional.) Enabling load balancing for flow log entries
Prerequisites for flow log
Before you configure the flow log feature, complete the following tasks:
·     Enable NAT logging by using the nat log enable command.
·     Enable the following NAT logging features as needed:
¡     Logging of active NAT flows.
¡     Logging of NAT session establishment events.
¡     Logging of NAT session removal events.
For more information about the NAT logging commands, see NAT Command Reference.
Restrictions and guidelines for flow log export destination configuration
You can export flow log entries to a log host or the information center, but not both. If you configure both methods, the system exports flow log entries to the information center.
Flow log entries exported to the information center has the informational severity level.
2.     Specify a log host as the destination for flow log export.
userlog flow export [ vpn-instance vpn-instance-name ] host { hostname | ipv4-address | ipv6 ipv6-address } port udp-port
By default, no log hosts are specified.
You can specify multiple log hosts.
2.     Specify the information center as the destination for flow log export.
userlog flow syslog
By default, flow log entries are not exported to the information center.
Make sure the specified flow log version is supported on the log host.
If you configure the flow log version multiple times, the most recent configuration takes effect.
2.     Configure the flow log version.
userlog flow export version version-number
The default flow log version is 1.0.
By default, the source IP address for flow log packets is the IP address of their outgoing interface. For the log hosts to filter log entries by log sender, specify a source IP address for all flow log packets.
As a best practice, use a Loopback interface's address as the source IP address for flow log packets. A Loopback interface is always up. The setting avoids export failure on interfaces that might go down.
2.     Specify a source IP address for flow log packets.
userlog flow export source-ip { ipv4-address | ipv6 ipv6-address }
The device uses either the local time or the UTC time in the timestamp of flow logs.
·     UTC time—Standard Greenwich Mean Time (GMT).
·     Local time—Standard GMT plus or minus the time zone offset.
The time zone offset can be configured by using the clock timezone command. For more information, see basic device management commands in System Management Command Reference.
2.     Configure the device to use the local time in the flow log timestamp.
userlog flow export timestamp localtime
By default, the UTC time is used in the flow log timestamp.
By default, the device sends a copy of each flow log entry to all configured log hosts. When one log host fails, other log hosts still have complete flow log entries.
In load balancing mode, flow log entries are distributed among log hosts based on the source IP addresses (before NAT) that are recorded in the entries. The flow log entries generated for the same source IP address are sent to the same log host.
In load balancing mode, flow logs are load balanced among all configured log hosts, regardless of whether the log hosts are reachable. If a log host is unreachable, the flow logs sent to it will be lost.
2.     Enable load balancing for flow log entries.
userlog flow export load-balancing
By default, load balancing is disabled.
Verifying and maintaining flow log
Displaying flow log configuration and statistics
To display flow log configuration and statistics, execute the following command in any view:
display userlog export
Clearing flow log statistics
To clear flow log statistics, execute the following command in user view:
reset userlog flow export
Flow log configuration examples
Example: Configuring flow log export
As shown in Figure 1, configure flow log on the device to send flow log entries generated for the user to the log host.
Figure 1 Network diagram
# Configure IP addresses, as shown in Figure 1. Make sure the device, user, and the log host can reach one another. (Details not shown.)
# Enable NAT logging.
[Device] nat log enable
# Enable NAT logging for session establishment events, session removal events, and active flows.
[Device] nat log flow-begin
[Device] nat log flow-end
[Device] nat log flow-active 10
# Set the flow log version to 3.0.
[Device] userlog flow export version 3
# Specify the log host at 1.2.3.6 as the destination for flow log export. Set the UDP port number to 2000.
[Device] userlog flow export host 1.2.3.6 port 2000
# Specify 2.2.2.2 as the source IP address for flow log packets.
[Device] userlog flow export source-ip 2.2.2.2
[Device] quit
# Display the flow log configuration and statistics.
<Device> display userlog export
Flow:
  Export flow log as UDP Packet.
  Version: 3.0
  Source ipv4 address: 2.2.2.2
  Log load balance function: Disabled
  Local time stamp: Disabled
  Number of log hosts: 1
  Log host 1:
    Host/Port: 1.2.3.6/2000
    Total logs/UDP packets exported: 112/87
