| 01-Text | 12.72 MB |
SIC-4FSW/SIC-4FSWP/DSIC-9FSW/DSIC-9FSWP
POS (SDH/SONET) interface modules
Analog modem interface modules
SIC-1FXS/SIC-1FXO/SIC-2FXS/SIC-2FXO
Network data encryption modules
MIM-1E1/MIM-2E1/MIM-4E1/MIM-1E1-F/MIM-2E1-F/MIM-4E1-F
POS terminal access interface modules
HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2
RT-HMIM-4GEE-V2-G/RT-HMIM-8GEE-V2-G
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2
CPOS (SDH/SONET) interface modules
HMIM-1E1/HMIM-2E1/HMIM-4E1/HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F
RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3
HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1/HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F
RT-HMIM-4SAE-V2/RT-HMIM-8SAE-V2
RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2
Digital modem interface modules
RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1
Cables and the connection methods
Synchronous/asynchronous serial ports
ADSL/BS/FXS/FXO/AM/FCM interface
Link mode of interfaces on Ethernet switching modules and interface modules
Frequency bands for 3G/4G/5G interface modules
Interface module net weights and power consumption
SIC/DSIC interface modules
CAUTION: · You can hot swap or perform an online removal and insertion (OIR) operation on an interface module. OIR requires you to execute the remove command or press the REMOVE button before you remove an interface module, and hot swapping does not. · Only the RT-SIC-4GSW-G, RT-SIC-4GSWF-G, and RT-SIC-2E1-G interface modules support hot swapping. · SIC interface modules with a remove button support OIR. To remove a SIC interface module with a remove button while the device is operating, first press the remove button or execute the remove command. For the specific operation instructions, see the description for the SIC interface module. The remove command and the remove button cannot be used simultaneously, as this might cause the SIC interface module to become unusable. · The SIC interface modules, except for the RT-SIC-4GSW-G, RT-SIC-2E1-G, and those with a remove button, do not support hot swapping or OIR. · DSIC interface modules cannot be hot-swapped. |
MSR series routers use modular design and support a wide range of optional smart interface cards (SICs) and double smart interface cards (DSICs). A SIC occupies one SIC slot and a DSIC occupies two SIC slots. The SIC/DSIC series interface modules provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1/T1, ISDN BRI/PRI, ADSL, audio interface, and Layer 2 switching interface.
· SIC-4FSW
· SIC-4FSWP
· DSIC-9FSW
· DSIC-9FSWP
· SIC-4GSW
· RT-SIC-4GSWF
Introduction
The SIC-4FSW/SIC-4FSWP and DSIC-9FSW/DSIC-9FSWP interface modules are 4/9-port 10/100 Mbps Ethernet Layer 2 SIC interface modules that can be used on H3C MSR series routers. They provide up to 4/9 10/100 BASE-Tx Ethernet ports for Layer 2 and Layer 3 switching. A router installed with SIC-4FSW/SIC-4FSWP and DSIC-9FSW/DSIC-9FSWP modules can work as a switching/routing integrated device on a small-sized enterprise network to connect PCs and network devices inside the network directly. SIC-4FSWP/DSIC-9FSWP interface modules can supply power to powered devices (PDs) through power over Ethernet (PoE).
Functions supported by interface modules are as follows:
· Effective transmission distance of 100 m (328.08 ft) with category-5 twisted pair cables (both crossover and straight-through)
· Effective transmission distance of 100 m (328.08 ft) between any interfaces with category-5 twisted pair cables (both crossover and straight-through)
· Operating speeds of both 100 Mbps and 10 Mbps and autosensing
· Both full duplex (in common use) and half-duplex operating modes
Interface specifications
Table 1 describes the interface specifications of the SIC-4FSW, SIC-4FSWP, DSIC-9FSW, and DSIC-9FSWP interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 1 Interface specifications
Item |
SIC-4FSW/SIC-4FSWP |
DSIC-9FSW/DSIC-9FSWP |
Connector |
RJ-45 |
Interface type |
MDI/MDIX |
Number of connectors |
Four 100 Mbps RJ-45 connectors |
Nine 100 Mbps RJ-45 connectors |
Cable |
Standard (straight-through)/cross-over Ethernet cable |
Operation mode |
10/100 Mbps autosensing, full/half duplex |
NOTE: Ethernet interfaces on network adapters are usually medium dependent interfaces (MDIs). Medium dependent interfaces crossover (MDIXs) are another type of Ethernet interfaces, which are usually used on hubs and LAN switches. |
Interface LEDs
Figure 2 SIC-4FSWP panel
Figure 4 DSIC-9FSWP panel
On the panel, each port corresponds to one green LED. The following table describes the LEDs on the panel.
Table 2 LED description
Status |
Steady on |
A link is present, but no data is being transmitted or received. |
Off |
No link is present. |
Flashing |
A link is present and data is being transmitted and received (ACT). |
In addition, there is a PoE LED on each module, which is provided for the corresponding modules (SIC-4FSWP and DSIC-9FSWP) with the PoE function.
Interface cables and the connection methods
For more information about Ethernet interface cables and the connection methods, see "Ethernet interface."
SIC-4GSW
Introduction
The SIC-4GSW interface module is a 4-port 1000 Mbps Ethernet Layer 2 SIC interface module. The SIC-4GSW provides four 1000 Mbps RJ-45 ports. A router installed with SIC-4GSW modules can operate as a switching/routing integrated device on a small-sized enterprise network to connect PCs and network devices inside the network directly.
· Effective transmission distance of 100 m (328.08 ft) over category-5 twisted pair cables (both crossover and straight-through)
· Line rate of 1000 Mbps between any interfaces over category-5e twisted pair cables (both crossover and straight-through)
· Autosensing operating speeds of 1000 Mbps, 100 Mbps, and 10 Mbps
· Both full duplex (typically used) and half-duplex operating modes
Table 3 describes the interface specifications of the SIC-4GSW interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 3 Interface specifications
Item |
Connector |
RJ-45 |
Interface type |
MDI/MDIX |
4 |
Cable |
Operation mode |
10/100/1000 Mbps autosensing |
Interface LEDs
Figure 5 SIC-4GSW panel
The SIC-4GSW interface module provides a double-color (green/yellow) LED for each port to indicate the operating status of the port.
Table 4 LED description
Status |
Off |
Steady green |
A 1000 Mbps link is present. |
Flashing green |
The port is sending and receiving data at 1000 Mbps. |
Steady yellow |
A 10/100 Mbps link is present. |
Flashing yellow |
The port is sending and receiving data at 10/100 Mbps. |
For information about Ethernet interface cables and the connection methods, see "Ethernet interface."
RT-SIC-4GSWF
Introduction
The 4-port 100/1000 Mbps Ethernet Layer 2/Layer 3 SIC interface module RT-SIC-4GSWF provides four fiber ports. It is designed for switching/routing integrated routers on a small-sized enterprise network. You can use it to connect network devices inside the network.
The interface module has the following features:
· Support for multiple 100/1000 Mbps transceiver modules.
· 1000/100 Mbps interface rate.
· Full duplex operating mode.
Table 5 describes the interface specifications of the RT-SIC-4GSWF interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 5 Interface specifications
Item |
Number of interfaces |
4 |
Connector |
SFP/LC |
Standard |
802.3/802.3u/802.3ab |
Operating mode |
1000/100 Mbps, full duplex |
Interface LEDs
The RT-SIC-4GSWF interface module provides a double-color (green/yellow) LED for each port to indicate the operating status of the port.
Table 6 LED description
Status |
Off |
Steady green |
A link is present on the port and the port is operating at 1000 Mbps. |
Flashing green |
Steady yellow |
A link is present on the port and the port is operating at 100 Mbps. |
Flashing yellow |
The port is sending and receiving data at 100 Mbps. |
Transceiver modules, optical fibers, and connection methods
For more information about transceiver modules, optical fibers, and connection methods, see "Fiber port."
Ethernet interface modules
· SIC-1FEA
· SIC-1FEF
· RT-SIC-4GSW-G
· RT-SIC-4GSWF-G
· SIC-1GEC-V2
· RT-SIC-1XPF-G
SIC-1FEA
Introduction
The 1-port 10BASE-T/100BASE-TX Ethernet interface module (SIC-1FEA) is used for communication between the router and LAN. It supports:
Table 7 describes the interface specifications of the SIC-1FEA interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 7 Interface specifications
Item |
Connector type |
RJ-45 |
Interface type |
MDI |
1 |
Cable type |
Straight-through Ethernet cable |
Operating mode |
10/100 Mbps autosensing Full duplex/half duplex |
Interface LEDs
LED |
LINK |
· Off: No link is present; · On: A link is present. |
ACT |
· Off: No data is being transmitted or received; · Flashing: Data is being received or/and transmitted. |
For more information about the Ethernet interface cables and the connection methods, see "Ethernet interface".
SIC-1FEF
Introduction
The 1-port 100 Mbps fiber Ethernet interface module (SIC-1FEF) is used for the communication between the router and LAN.
SIC-1FEF supports:
· Various types of transceiver modules.
· 100 Mbps interface rate.
· Full duplex.
Table 9 describes the interface specifications of the SIC-1FEF interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 9 Interface specifications
Item |
1 |
Connector |
SFP/LC |
Interface standard |
802.3, 802.3u, and 802.3ab |
Operating mode |
100 Mbps Full duplex |
Interface LEDs
Figure 8 SIC-1FEF panel
LED |
Status |
LINK/ACT |
Off |
Steady green |
The optical module has established a 100 Mbps link. |
Flashing green |
Data is being received and transmitted. |
Steady yellow |
Information detection failed. |
RT-SIC-4GSW-G
Introduction
The 4-port 1000 Mbps Ethernet SIC interface module RT-SIC-4GSW-G provides four 1000 Mbps RJ-45 ports and is used for communication between the router and LAN.
· Effective transmission distance of 100 m (328.08 ft) over category-5 twisted pair cables (both crossover and straight-through).
· Line rate of 1000 Mbps between any interfaces over category-5e twisted pair cables (both crossover and straight-through).
· Autosensing operating speeds of 1000 Mbps, 100 Mbps, and 10 Mbps.
Table 11 describes the interface specifications of the RT-SIC-4GSW-G interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 11 Interface specifications
Item |
Connector |
RJ-45 |
Interface type |
MDI/MDIX |
4 |
Cable |
Standard (straight-through)/crossover Ethernet cable |
Operating mode |
Interface LEDs
Figure 9 RT-SIC-4GSW-G panel
On the panel, each port corresponds to one green LED and one yellow LED.
Table 12 LED description
LED |
Status |
LINK/ACT |
Steady green |
Flashing green |
Steady yellow |
A link is present on the port and the port is operating at 10/100 Mbps. |
Flashing yellow |
Off |
RT-SIC-4GSWF-G
Introduction
The 4-port 100/1000 Mbps Ethernet Layer 3 SIC interface module RT-SIC-4GSWF-G provides four SFP fiber ports and is used for communication between the router and LAN. It supports:
· Various types of FE and GE transceiver modules.
· 100/1000 Mbps interface rate.
· Full duplex.
Table 13 describes the interface specifications of the RT-SIC-4GSWF-G interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 13 Interface specifications
Item |
4 |
Connector |
SFP/LC |
802.3, 802.3u, 802.3ab |
Operating mode |
100/1000 Mbps Full duplex |
Interface LEDs
Figure 10 RT-SIC-4GSWF-G panel
The RT-SIC-4GSWF-G interface module provides a double-color (green/yellow) LED for each port to indicate the operating status of the port.
Table 14 LED description
LED |
Status |
LINK/ACT |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
SIC-1GEC-V2
Introduction
The 1-port 10/100/1000 Mbps electrical and fiber Ethernet interface SIC module (SIC-1GEC-V2) has the following functions:
· Receipt, transmission and processing of GE data stream
· CE electrical and fiber port access
· 1000/100/10 Mbps on copper port
· 1000 Mbps on fiber port
Table 15 describes the interface specifications of the SIC-1GEC-V2 interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 15 Interface specifications
Item |
Connector |
RJ-45 |
Interface type |
MDI |
Frame format |
· Ethernet_II · Ethernet_SNAP · IEEE 802.2 · IEEE 802.3 |
Operation mode |
10/100/1000 Mbps autosensing Full/half duplex |
NOTE: The SIC-1GEC-V2 provides combo interfaces. The fiber and copper ports of a combo interface cannot be used simultaneously. By default, the copper port is available. To use the fiber port, execute the related command. |
Interface LEDs
Table 16 LED description for the copper port on the SIC-1GEC-V2 panel
LED |
LINK |
· On: A carrier signal is received. · Off: No carrier signal is received. · Green: Data is being received and transmitted at a speed of 1000 Mbps. · Yellow: Data is being received and transmitted at a speed of 100/10 Mbps. |
ACT |
· Off: No data is being received and transmitted; · Flashing: Data is being received and transmitted. |
Table 17 LED description for the fiber port on the SIC-1GEC-V2 panel
LED |
LINK |
· On: A carrier signal is received. · Off: No carrier signal is received. · Green: Data is being received and transmitted at a speed of 1000 Mbps. · Yellow: Fault. |
ACT |
· Off: No data is being received and transmitted. · Flashing: Data is being received and transmitted. |
For information about transceiver modules, optical fibers, and the connection methods, see "Fiber port."
RT-SIC-1XPF-G
CAUTION: The RT-SIC-1XPF-G interface module is hot swappable. To remove an RT-SIC-1XPF-G interface module, first press and hold the remove button for a minimum of 3 seconds. You can remove the interface module only when the remove LED is turned off. If the remove LED is flashing green, wait for the remove LED to turn off and then remove the interface module. |
Introduction
The 10 Gbps Ethernet interface module RT-SIC-1XPF-G provides one SFP+ fiber port, which is a Layer 3 service port. The interface module supports port type switching between standard Ethernet and FlexE. The FlexE mode allows flexible bandwidth assignment to meet different service requirements.
Table 18 describes the interface specifications of the RT-SIC-1XPF-G interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 18 Interface specifications
Item |
1 |
Connector |
SFP+/LC |
10GBASE-R |
Operating mode |
10 Gbps, full duplex |
Panel and interface LEDs
Figure 12 RT-SIC-1XPF-G panel
Table 19 LED description
LED |
Status |
LINK/ACT |
Steady green |
A link is present on the port and the port is operating at 10 Gbps. |
Flashing green |
The port is sending and receiving data at 10 Gbps. |
Off |
REMOVE |
Steady green |
The module is operating correctly. You can press the remove button to remove the module. |
Flashing green |
· The module is initializing. You cannot press the remove button or remove the module. · The module is being removed. |
Off |
You can remove the module if all the other LEDs on the module are also off. |
CAUTION: During online upgrade of the RT-SIC-1XPF-G interface module, do not remove it. In the upgrade process, the remove LED flashes green, turns off, flashes again, and then remains steady on. |
RT-SIC-1POS-STM1
Introduction
The RT-SIC-1POS-STM1 1-port SDH/SONET interface module provides an interface transmission rate of 155.52 Mbps (STM-1/OC-3).
The RT-SIC-1POS-STM1 supports PPP, Frame Relay, and HDLC protocols at the data link layer and the IP protocol at the network layer. It allows direct transmission of packets over SONET/SDH. It provides a 155.52 Mbps fractional interface and supports various types of transceiver modules. You can purchase transceiver modules for it as required.
Table 20 Interface specifications
Item |
Connector |
SFP/LC |
1 |
SONET OC-3/SDH STM-1 |
Interface rate |
155.52 Mbps |
Interface LEDs
Figure 13 RT-SIC-1POS-STM1 panel
Table 21 LED description
LED |
Status |
ACT/ALM |
Steady green |
A 155.52 Mbps link is present. |
Flashing green |
The port is receiving or sending data at 155.52 Mbps. |
Steady red |
An alarm has occurred. |
Off |
No transceiver module is present or the port is in shutdown state. |
E1/T1 interface modules
· SIC-E1-F
· SIC-2E1-F
· RT-SIC-2E1-G
· SIC-1EPRI
· SIC-T1-F
SIC-E1-F
Introduction
The 1-port fractional E1 interface module (SIC-E1-F) supports:
· Transmission/Receiving and handling of E1 data streams
· CE1 (channelized E1) access
· Remote loopback and local loopback functions, facilitating fault test and location.
The timeslots on an interface in FE1 mode on the SIC-E1-F can be bundled to form one interface (namely, can be bundled into one channel, and the rate of the interface is n No 64 Kbps, where n ranges from 1 to 31.)
The SIC-E1-F does not support the PRI mode.
Table 22 Interface specifications
Item |
Connector type |
D15 |
1 |
· G.703 · G.704 |
Interface rate |
2.048 Mbps |
Cable type |
75-ohm unbalanced coaxial cable (D15 to BNC) |
Operating modes |
· E1 · CE1 |
Supported services |
· Backup · Terminal access |
Interface LEDs
Figure 14 SIC-E1-F panel
Table 23 LED description
LED |
LINK/ACT |
· On: A carrier signal is received. · Flashing: Data is being transmitted or received. · Off: No carrier signal is received. |
LP/AL |
· On: The interface is in loopback mode. · Off: Neither loopback nor alarm is present. · Flashing: No cable is connected to the interface, the cable is damaged or not connected correctly, or the peer device is faulty. |
For more information about E1 interface cables and the connection methods, see "E1 interface."
SIC-2E1-F
Introduction
The 2-port fractional E1 interface module (SIC-2E1-F), where F indicates fractional, supports:
Table 24 Interface specifications
Item |
Connector type |
D15 |
1 |
· G.703 · G.704 |
Interface rate |
2.048 Mbps |
Cable type |
Operating modes |
· E1 · CE1 |
Interface LEDs
Figure 15 SIC-2E1-F panel
Table 25 LED description
LED |
LINK/ACT (left) |
· On: A carrier signal is received on line RX1. · Flashing: Data is being transmitted on line TX1 or received on line RX1. · Off: No carrier signal is received on line RX1. |
LP/AL (left) |
· On: The interface of lines TX1 and RX1 is in loopback mode. · Flashing: No cable is connected to the interface of lines TX1 and RX1, the cable is damaged or not connected correctly, or the peer device is faulty. · Off: Neither loopback nor alarm is present on the interface of lines TX1 and RX1. |
LINK/ACT (right) |
· On: A carrier signal is received on line RX2. · Flashing: Data is being transmitted on line TX2 or received on line RX2. · Off: No carrier signal is received on line RX2. |
LP/AL (right) |
· On: The interface of lines TX2 and RX2 is in loopback mode. · Flashing: No cable is connected to the interface of lines TX2 and RX2, the cable is damaged or not connected correctly, or the peer device is faulty. · Off: Neither loopback nor alarm is present on the interface of lines TX2 and RX2. |
For more information about E1 interface cables and the connections methods, see "E1 interface."
RT-SIC-2E1-G
Introduction
The RT-SIC-2E1-G is a 2-port channelized CE1/PRI and fractional E1 (E1-F) interface module.
The module provides the following features:
· Channelized CE1/PRI mode—The module allows arbitrary grouping of 31 channels and multiple bundles. It transmits/receives and handles E1 data streams, provides CE1 access, and supports ISDN PRI.
· Unchannelized E1 mode—Interfaces on the module are 2.048 Mbps synchronous serial interfaces without timeslot division.
· Fractional E1 (E1-F) mode—The time slots can only be bundled into one n x 64 kbps channel, where the value range of n is 1 to 31. The module does not support PRI mode.
Table 26 Interface specifications
Item |
Connector type |
RJ-45 |
2 |
G.703 |
Interface rate |
2.048 Mbps |
Cable type |
· E1 120-ohm balanced twisted pair cable: 2 m (6.56 ft), 15 m (49.21 ft), or 30 m (98.43 ft) · E1 75-ohm unbalanced coaxial cable · 75-ohm adapter cable · Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter (with BNC connector) |
Operating modes |
· Unchannelized E1 (G.703) · Channelized E1 (CE1/PRI) · Fractional E1 (E1-F) |
· Backup · Terminal access service · ISDN PRI |
NOTE: The E1 cable after extension supports a maximum transmission distance of 100 m (328.08 ft). |
Interface LEDs
Figure 16 RT-SIC-2E1-G panel
Table 27 LED description
LED |
Status |
LINK/ACT (green) |
Steady green |
A carrier signal has been received. |
Flashing green |
Data is being transmitted or/and received. |
Off |
No carrier signal has been received. |
LP/AL (yellow) |
Steady yellow |
The interface is in loopback mode. |
Flashing yellow |
Off |
No loopback or alarm is present. |
Jumper caps
The RT-SIC-2E1-G interface module provides jumper caps, the installation status of which determines the interface impedance. By default, each pin pair is installed with a jumper cap and the impedance of an E1 interface is 75 ohms.
Figure 17 Default installation status of jumper caps
To connect a 75-ohm cable to an E1 interface, install jumper caps on the pins corresponding to the interface. To connect a 120-ohm cable to an E1 interface, remove the jumper caps from the pins corresponding to the interface. Table 28 displays the mapping relations between pins and E1 interfaces.
Table 28 Mapping relations between pins and E1 interfaces
Pins |
E1 interface |
1 and 2 |
E1 interface 0 |
3 and 4 |
E1 interface 0 |
5 and 6 |
E1 interface 1 |
7 and 8 |
E1 interface 1 |
9 and 10 |
Reserved. Keep the jumper cap in its default installation status. |
SIC-1EPRI
Introduction
The SIC-1EPRI is a 1-port E1/CE1/PRI SIC interface module that provides the following features:
· Transmission/Receiving and handling of E1 data streams.
· CE1 (channelized E1) access.
· ISDN PRI function.
You can use the module for multiple purposes through different configurations.
Table 29 Interface specifications
Item |
Connector type |
D15 |
1 |
· G.703 · G.704 |
Interface rate |
2.048 Mbps |
Cable type |
· 75-ohm unbalanced coaxial cable (D15 to BNC) · Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter NOTE: The default resister for the interface on the SIC-1EPRI is 75 ohm. A 75-ohm to 120-ohm adapter must be used when a 120-ohm cable is connected to the SIC-1EPRI. |
Operating mode |
· E1 · CE1 · ISDN PRI |
Supported service |
· Backup · Terminal access · ISDN |
Interface LEDs
Figure 18 SIC-1EPRI panel
Table 30 LED description
LED |
LINK/ACT |
LP/AL |
· On: The interface is in loopback mode. · Flashing: No cable is connected to the interface, the cable is damaged or not connected correctly, or the peer device is faulty. · Off: Neither loopback nor alarm is present. |
SIC-T1-F
Introduction
1-port Fractional T1 interface card (SIC-T1-F) has the following features:
· The timeslots on an interface in FT1 mode on the SIC-T1-F can be bundled to form one interface (namely, can be bundled into one channel, and the rate of the interface is n No 56 Kbps, where n ranges from 1 to 24.).
· The SIC-T1-F does not support the PRI mode.
Table 31 Interface specifications
Item |
Connector type |
RJ-45 |
1 |
· G.703/T1.102 · G.704 · AT&T TR 54016 · AT&T TR 62411 · ANSI T1.403 |
Interface rate |
1.544 Mbps |
Cable type |
T1 cable (100-ohm standard shielded network cable) |
Operating mode |
FT1 |
Supported service |
Interface LEDs
LED |
LINK/ACT |
· On: A carrier signal is received. · Off: No carrier signal is received. · Flashing: Data is being transmitted or/and received. |
LP/AL |
· On: The interface is in loopback mode. · Off: No loopback or alarm is present. · Flashing: No cable is connected to the interface, the cable is damaged or not connected correctly, or the peer device is faulty. |
For more information about T1 interface cables and the connection methods, see "T1 interface."
Serial interface modules
· SIC-8AS
· SIC-16AS
· SIC-1SAE
· SIC-2SAE
· SIC-4SAE
· SIC-4RS
SIC-8AS
Introduction
The 8-port asynchronous serial interface module (SIC-8AS) mainly transmits and processes asynchronous data streams.
SIC-8AS has these features:
· Each asynchronous serial port provides a rate up to 115.2 Kbps.
· Supports the terminal access service and asynchronous dedicated line.
· Serves as the small-/medium-sized ISP dial-up access server when an asynchronous serial port is used for dial-up.
Table 33 Interface specifications
Item |
Connector |
DB60 |
1 |
Interface cable |
Customized cable with 8-port RJ-45 connector |
RS-232 |
Minimum baud rate |
300 bps |
Maximum baud rate |
115.2 Kbps |
· Modem dial-up · Backup · Terminal access service · Asynchronous dedicated line |
Interface LEDs
Figure 20 SIC-8AS front panel
Table 34 LED description
LED |
LINK/ACT |
· Off: No link is present. · On: A link is present. · Flashing: Data is being received or/and transmitted. |
For more information about asynchronous serial port cables and the connection methods, see "Asynchronous serial ports."
SIC-16AS
Introduction
The 16-port asynchronous serial interface module (SIC-16AS) mainly transmits and processes asynchronous data streams.
SIC-16AS features the following:
· Each asynchronous serial port provides a rate of up to 115.2 Kbps.
Table 35 Interface specifications
Item |
Connector |
D28 (male) |
1 |
Interface cable |
Customized cable with 16-port RJ-45 connector (female) |
RS-232 |
Minimum baud rate |
300 bps |
Maximum baud rate |
115.2 Kbps |
Interface LEDs
Figure 21 SIC-16AS panel
Table 36 LED description
LED |
LINK/ACT |
SIC-1SAE/SIC-2SAE/SIC-4SAE
Introduction
The SIC-1SAE/SIC-2SAE/SIC-4SAE is a 1-port/2-port/4-port enhanced high-speed synchronous/asynchronous serial interface module.
Table 37 Interface specifications
Item |
Synchronous |
Asynchronous |
Connector |
D28 |
· 1 (SIC-1SAE) · 2 (SIC-2SAE) · 4 (SIC-4SAE) |
Interface standard and operating mode |
V.24 |
· V.35 · RS449 · X.21 · RS-530 |
RS-232 |
· DTE · DCE |
· DTE · DCE |
Minimum baud rate (bps) |
1200 |
1200 |
300 |
Maximum baud rate (bps) |
64 k |
2.048 M |
115.2 |
Cable |
· V.24 (RS-232) DTE cable · V.24 (RS-232) DCE cable · V.35 DTE cable · V.35 DCE cable · X.21 DTE cable · X.21 DCE cable · RS449 DTE cable · RS449 DCE cable · RS530 DTE cable · RS530 DCE cable |
Supported service |
· DDN leased line · Terminal access service |
· Dialup through modems · Backup · Asynchronous leased line · Terminal access |
Interface LEDs
Figure 23 SIC-2SAE panel
Figure 24 SIC-4SAE panel
The SIC-1SAE provides separate LINK and ACT LEDs for the port and the SIC-2SAE and SIC-4SAE provide one LINK/ACT LED for each port.
Table 38 LED description for the port on the SIC-1SAE
LED |
LINK |
· Off: No link is present. · On: A link is present. |
ACT |
Table 39 LED description for ports on the SIC-2SAE/SIC-4SAE
LED |
LINK/ACT |
For more information about synchronous/asynchronous serial port cables and the connection methods, see "Synchronous/asynchronous serial ports."
SIC-4RS
Introduction
The SIC-4RS is a 4-port asynchronous serial interface module.
The SIC-4RS has these features:
· Allows users to make matching wires connected to the terminal block themselves.
· Supports simultaneous connection to four asynchronous serial ports.
Table 40 Interface specifications
Item |
Connector |
Terminal block |
1 |
Interface cable |
Allows users to make matching cables themselves. |
RS-232/485/422 |
300 |
115200 |
Supported service |
· 4 asynchronous serial port connection · 2-channel digital input (DI) detection |
NOTE: The interface standards and operating mode of the SIC-4RS interface module are switched by using DIP switches. For more information about DIP switches, see "Dual inline package switch." |
Interface LEDs
Figure 25 SIC-4RS panel
Table 41 LED description
LED |
0 to 3 |
The SIC-4RS interface module allows users to make matching cables themselves for connection to it. Figure 26 and Table 42 describe the requirements for making matching cables.
Figure 26 Pin numbering
Pin |
Interface standards and working modes |
RS-232 |
RS-422 |
RS-485 |
RTS0 |
TX0+ |
Data0+ |
2 |
TXD0 |
TX0- |
Data0- |
3 |
RXD0 |
RX0+ |
4 |
CTS0 |
RX0- |
5 |
GND |
6 |
GND |
7 |
RTS1 |
TX1+ |
Data1+ |
8 |
TXD1 |
TX1- |
Data1- |
9 |
RXD1 |
RX1+ |
10 |
CTS1 |
RX1- |
11 |
GND |
12 |
GND |
13 |
RTS2 |
TX2+ |
Data2+ |
TXD2 |
TX2- |
Data2- |
15 |
RXD2 |
RX2+ |
16 |
CTS2 |
RX2- |
17 |
GND |
18 |
GND |
19 |
RTS3 |
TX3+ |
Data3+ |
20 |
TXD3 |
TX3- |
Data3- |
21 |
RXD3 |
RX3+ |
22 |
CTS3 |
RX3- |
23 |
GND |
24 |
GND |
25 |
DN0_P |
26 |
DN0_N |
27 |
DN1_P |
28 |
DN1_N |
The SIC-4RS interface module provides a dual inline package (DIP) switch. The DIP switch setting defines the interface standards and the grounding method. By default, all DIP switches are OFF. That is, the interface standards and the grounding method are RS232.
The SIC-4RS interface module provides two DIP switches, S1 and S2, to control different interfaces, as shown in Table 43. For information about the configuration method and description for switches S1 and S2, as shown in Table 44 and Table 45.
Table 43 DIP switch-to-interface map
DIP |
Corresponding interface |
S1 |
Interfaces 0 and 1 |
S2 |
Interfaces 2 and 3 |
Table 44 DIP switch S1 configuration
Pin and its status |
Port/mode |
1 |
2 |
3 |
4 |
5 |
6 |
N/A |
OFF |
ON |
ON |
0-port RS-232 |
ON |
OFF |
ON |
0-port RS-485 |
ON |
ON |
OFF |
0-port RS-422 |
OFF |
ON |
ON |
1-port RS-232 |
ON |
OFF |
ON |
1-port RS-485 |
ON |
ON |
OFF |
1-port RS-422 |
Table 45 DIP switch S2 configuration
Port/mode |
1 |
2 |
3 |
4 |
5 |
6 |
N/A |
OFF |
ON |
ON |
2-port RS-232 |
ON |
OFF |
ON |
2-port RS-485 |
ON |
ON |
OFF |
2-port RS-422 |
OFF |
ON |
ON |
3-port RS-232 |
ON |
OFF |
ON |
3-port RS-485 |
ON |
ON |
OFF |
3-port RS-422 |
· SIC-1AM
· SIC-2AM
SIC-1AM/SIC-2AM
Introduction
The 1/2-port analog modem interface module (SIC-1AM/SIC-2AM) integrates the functions of asynchronous interface and external modem, that is, allowing 1/2 channel(s) of remote modem subscribers to directly access the Router. They support:
· Data rate of 56 kbps.
· Accessing and handling analog signals and transmitting the processed data to the Router host through the serial interface bus. And also, processing the data received from the host and then transmitting them to the PSTN via the telephone port.
Table 46 Interface specifications
Item |
Connector type |
RJ-11 |
· 1 (SIC-1AM) · 2 (SIC-2AM) |
Cable type |
Telephone cable with ferrite core |
Maximum speed |
56 kbps |
Supported standard |
· ITU-T V.90 · K56flex · V.34 (33.6 kbps) · V.FC · V.32 bis · V.32 · V.22 bis · V.22A/B · V.23 · V.21 · Bell 212A a · Bell 103 |
Supported service |
Modem dial-up |
Interface LEDs
LED |
LINK |
· Off: The link is idle. · On: The connection has been established. · Flashing: The connection is being set up. |
ACT |
· Off: The link is idle. · Flashing: Data is being transmitted or received. |
For more information about the Ethernet interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
XDSL interface modules
· SIC-1ADSL
· SIC-1ADSL-I
SIC-1ADSL
Introduction
The 1-port ADSL over PSTN interface module (SIC-1ADSL) provides an RJ-11 interface that can work as a WAN interface. It allows a LAN subscriber to connect to the digital subscriber's loop access multiplexer (DSLAM) at the central office over a regular analog subscriber line or telephone line. Thus, the subscriber can access the ATM/IP backbone or the Internet to enjoy services such as high-speed data communication and video on demand (VoD).
ADSL transmits data in the high frequency band above 26 kHz. Therefore, it can provide services without interfering with the voice service being provided in the low frequency band (0 to 4 kHz) on the same line. It provides downlink rates in the range 32 kbps to 8 Mbps and uplink rates in the range 32 kbps to 1 Mbps.
The SIC-1ADSL delivers these features:
· Manual ADSL line activation and deactivation, providing a convenient fault location means.
· Interface standards of G. DMT, G. Lite, and T1.413, autosensing.
· Trellis coding (except for G. Lite) on ADSL interfaces, enhancing the stability of ADSL connection.
Table 48 Interface specifications
Item |
Connector |
RJ-11 |
1 |
Interface rate |
· In ADSL full rate mode (ITU-T 992.1 G.DMT/ANSI T1.413): ¡ 8 Mbps (downlink rate) ¡ 1024 kbps (uplink rate) · In ADSL Lite mode (ITU-T 992.2 G.Lite): ¡ 64 kbps to 1 Mbps (downlink rate) ¡ 64 kbps to 512 kbps (uplink rate) · In ADSL2+ full rate mode (ITU-T 992.5): ¡ 24 Mbps (downlink rate) ¡ 1024 kbps (uplink rate) |
· ITU-T 992.1 G.DMT · ITU-T 992.2 G.Lite · ANSI T1.413 Issue 2 · ITU-T 992.3 · ITU-T 992.5 |
Cable |
Telephone cable |
Supported service |
ADSL over the regular telephone line |
Maximum received and sent frame |
1700 bytes |
Interface LEDs
LED |
LINK |
· Off: The loop is inactive. · On: The loop has been activated and has entered the data mode · Flashing: The loop is being activated. |
ACT |
· Off: No data is being transmitted or received. · Flashing: Data is being received or/and transmitted. |
For more information about ADSL interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
SIC-1ADSL-I
Introduction
The 1-port ADSL over ISDN interface module (SIC-1ADSL-I) uses the RJ-11 connector for the WAN interface. It allows a LAN subscriber to connect to the DSLAM at the central office over a regular analog subscriber line or telephone line. Thus, the subscriber can access the ATM/IP backbone or the Internet to enjoy services such as high-speed data communication and video on demand (VoD).
The module transmits data in the high frequency band above 138 kHz. Therefore, it can provide services on the same line without interfering with the ISDN service being provided on the same line. It provides downlink rates in the range 32 kbps to 8 Mbps and uplink rates in the range 32 kbps to 1 Mbps.
The SIC-1ADSL-I interface module delivers these features:
· A G.992.1-compliant interface, autosensing
· Trellis coding on ADSL interfaces, enhancing the stability of ADSL connection
Table 50 Interface specifications
Item |
Connector |
RJ-11 |
1 |
Interface rate |
Interface rate |
· Downlink: 8 Mbps · Uplink: 1024 kbps |
Interface cable |
Regular telephone cable |
ADSL over ISDN |
1700 bytes |
Interface LEDs
Figure 30 SIC-1ADSL-I panel
LED |
LINK |
ACT |
ISDN BRI interface modules
· SIC-1BS
· SIC-2BS
SIC-1BS/SIC-2BS
Introduction
The 1/2-port ISDN BRI S/T interface module (SIC-1BS/SIC-2BS) is mainly used to transmit, receive, and process ISDN BRI S/T traffic flows.
The SIC-1BS/SIC-2BS has two operating modes: dial-up and leased line.
Table 52 Interface specifications
Item |
Connector |
RJ-45 |
· 1 (SIC-1BS) · 2 (SIC-2BS) |
Cable type |
· ITU-T I.430 · Q.921 · Q.931 |
Operating mode |
· ISDN Dial-up · ISDN leased line |
· ISDN · ISDN supplementary services · Multi-subscriber number · Sub-address · Backup |
Interface LEDs
Figure 31 SIC-1BS panel
Table 53 LED description
LED |
B1 |
· Off indicates the B1 channel is idle. · Flashing indicates the B1 channel is being used for data communication. |
B2 |
· Off indicates the B2 channel is idle. · Flashing indicates the B1 channel is being used for data communication. |
ACT |
· Off indicates the inactive state. · Steady on indicates the active state. |
ON |
· Off indicates interface module is powered off. · On indicates the interface module is powered on. |
For more information about BS interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
Voice interface modules
· SIC-1FXS
· SIC-1FXO
· SIC-2FXS
· SIC-2FXO
· SIC-2FXS1FXO
· DSIC-4FXS1FXO
· SIC-1BSV
· SIC-2BSV
· SIC-1VE1
· SIC-1VT1
· SIC-1VE1T1
Introduction
The 1/2-port voice subscriber circuit interface module (SIC-1FXS/SIC-2FXS) and 1/2-port voice AT0 analog trunk interface module (SIC-1FXO/SIC-2FXO) serve to access and handle 1/2 channel(s) of analog voice signals over data communication networks. The differences between SIC-FXS and SIC-FXO are listed below:
· SIC-FXS modules are analog subscriber line modules that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges.
· SIC-FXO modules are loop trunk modules that provide access of common subscriber lines of exchanges.
Table 54 Interface specifications
Item |
Connector type |
RJ-11 |
1 (SIC-1FXS/SIC-1FXO) 2 (SIC-2FXS/SIC-2FXO) |
· Subscriber circuit interface (SIC-1FXS/SIC-2FXS) compliant with ITU Q.512. · Loop trunk interface (SIC-1FXO/SIC-2FXO) compliant with ITU Q.552. · Over-current and over-voltage protection compliant with ITU K.20 |
Cable type |
Telephone cable with ferrite core. |
Dialing mode |
Supports DTMF, not supports pulse dial-up. |
Bandwidth |
300 Hz to 3400 Hz |
Interface LEDs
LED |
LINK |
· Off: The link is idle. · On: The link is being occupied for call connection. |
ACT |
· Off: The link is idle. · On: The link is being occupied for communication. |
For more information about FXS/FXO interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
SIC-2FXS1FXO
Introduction
The 2-port analog subscriber circuit interface module and 1-port voice AT0 loop trunk interface module (SIC-2FXS1FXO) serve to access and handle three channels of analog voice signals over data communication networks. Two FXS interfaces and one FXO interface are available on a SIC-2FXS1FXO module:
· FXS interfaces are analog subscriber line interfaces that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges.
· FXO interfaces are loop trunk interfaces that provide access of common subscriber lines of exchanges.
Table 56 Interface specifications
Item |
Connector type |
RJ-11 |
2 FXS interfaces 1 FXO interface |
· Supports subscriber circuit interface (FXS), compliant with ITU Q.512 · Supports loop trunk interface (FXO), compliant with ITU Q.552 · Over-current and over-voltage protection compliant with ITU K.20 |
Cable type |
Dial-up mode |
Supports DTMF, compliant with GB3378, but does not support pulse dial-up. |
Bandwidth |
300 Hz to 3400 Hz |
Interface LEDs
Figure 37 SIC-2FXS1FXO panel
Table 57 LED description
LED |
LINK/ACT |
· Off: The link is idle. · Steady green: The link is being occupied for call connection. · Flashing yellow: The link is being occupied for communication. |
DSIC-4FXS1FXO
Introduction
The 4-port analog subscriber circuit interface module and 1-port voice AT0 loop trunk interface module (DSIC-4FXS1FXO) serve to access and handle five channels of analog voice signals over data communication networks.
Table 58 Interface specifications
Item |
Connector type |
RJ-11 |
4 FXS interfaces 1 FXO interface |
Cable type |
Dial-up mode |
Bandwidth |
300 Hz to 3400 Hz |
Interface LEDs
Figure 38 DSIC-4FXS1FXO panel
Table 59 LED description
LED |
LINK/ACT |
SIC-1BSV/SIC-2BSV
Introduction
The 1/2-port ISDN BRI S/T voice interface module (SIC-1BSV/SIC-2BSV) is mainly used to process (receive/transmit and compress/decompress) the ISDN interface voice traffic. The interface(s) on the SIC-1BSV/SIC-2BSV module is (are) ITU-T I.430-compliant, adopting pseudo-ternary coding, providing 192 Kbps interface rate, and allowing the maximum transmission distance of 1 km (0.6 miles) in point-to-point mode. In the upstream direction, the SIC-1BSV/SIC-2BSV module can be connected to a user interface on an ISDN switch to receive and decompress, compress and transmit ISDN BRI digital voice traffic. In the downstream direction, the module can be connected to a TE device to forward the voice packets from the TE device to the Internet through a WAN interface on the router, thus implementing VoIP. The module has the following features.
· A BSV interface supports two modes: user and network, respectively for connecting an ISDN network and a TE device.
· When a BSV interface works in network mode, traffic is processed as follows: The digital voice traffic received on the BSV interface is compressed and forwarded through the CPU on the main control board to a WAN interface. The IP voice traffic received on a WAN interface is forwarded through the CPU on the main control board to SIC-1BSV/SIC-2BSV, where the traffic is decompressed and sent to the TE device.
· When a BSV interface works in user mode, traffic is processed as follows: The digital voice traffic received from the B channels on the BSV interface is decompressed and forwarded through the CPU on the main control board to a local FXS or FXO analog voice interface. The voice signals received on the local FXS or FXO analog voice interface are processed by VoIP and forwarded through the CPU on the main control board to SIC-1BSV/SIC-2BSV, where the traffic is compressed and sent out of the BSV interface to the ISDN switch.
· Working in conjunction with the FXS or FXO analog voice interface modules, SIC-2BSV provides flexibility in voice call routing.
· The ISDN BRI D channel signaling is processed separately on CPU.
· A BSV interface supports remote power supply and thus can be connected directly to an ISDN phone, saving extra power supply device.
· The SIC-1BSV/SIC-2BSV is dedicated to voice applications, which is different from the BS interface modules where BRI data applications are supported.
Table 60 Interface specifications
Item |
SIC-1BSV |
SIC-2BSV/ |
Connector |
RJ-45 |
1 |
2 |
Interface rate |
192 Kbps |
Cable |
ISDN S interface cable |
Supported service |
Voice access over ISDN S interface cable |
Interface LEDs
Figure 40 SIC-2BSV panel
LED |
B1 |
Green Flashing indicates data is being transmitted or received on B1 channel. |
B2 |
Green Flashing indicates data is being transmitted or received on B2 channel. |
ACT |
Yellow · Flashing indicates the link is being activated. · Steady on indicates the link is active. |
ON |
Green, power LED. Steady on indicates the module is powered on. |
For more information about BSV interface cables and the connection methods, see "BSV/BSE interface."
SIC-1VE1
Introduction
The 1-port E1 voice interface module (SIC-1VE1) can handle dense voice signals in VoIP system. It provides a CE1/PRI/R2 port, allowing the access of 30 channels of voice signals.
Table 62 Interface specifications
Item |
Connector |
DB 15 |
Number of connector |
1 |
G.703, G.704 |
Interface rate |
2.048 Mbps |
Frame format |
Cable type |
· 75-ohm unbalanced coaxial cable · 120-ohm balanced twisted pair cable · Coaxial connector, network interface connector and 75-ohm to 120-ohm adapter (with BNC connector) |
Operation mode |
CE1 ISDN PRI (only supported by SIC-1VE1) R2 |
Services |
· Backup · Terminal access · ISDN (only supported by SIC-1VE1) |
Interface LEDs
LED |
LINK |
ACT |
SIC-1VT1
Introduction
The 1-port T1 voice interface module (SIC-1VT1) can handle dense voice signals in VoIP system. It provides a CT1/PRI/R2 port, allowing the access of 23 channels of voice signals.
Table 64 Interface specifications
Item |
Connector |
RJ-45 |
1 |
· G.703/T1.102 · G.704 · AT & T TR 54016 · AT & T TR 62411 · ANSI T1.403 |
Interface rate |
1.544 Mbps |
Cable type |
T1 cable (100-ohm standard shielded cable) |
Operation mode |
CT1 ISDN PRI |
Services |
Backup Terminal access ISDN |
Interface LEDs
LED |
LINK |
ACT |
SIC-1VE1T1
Introduction
The 1-port E1/T1 voice interface module SIC-1VE1T1 handles dense voice signals in VoIP and FoIP systems. The E1 module transmits, receives, and processes E1 voice signals. It allows the interface to operate in CE1 mode or ISDN PRI mode to process a maximum of 30 channels of voice signals. The T1 module transmits, receives, and processes T1 voice signals. It allows the interface to operate in CT1 mode or ISDN PRI mode to process a maximum of 23 channels of voice signals.
You can use command lines and a jumper to configure the interface as a 75-ohm E1 interface, 100-ohm T1 interface, or 120-ohm E1 interface. By default, the interface is a 75-ohm E1 interface.
· To configure the interface as a 75-ohm E1 interface, connect the jumper to pins 1 and 2, pins 7 and 8, pins 11 and 12, and pins 13 and 14.
· To configure the interface as a 100-ohm T1 or 120-ohm E1 interface, connect the jumper to pins 1 to 3, pins 5 to 7, pins 9 and 10, and pins 11 to 13.
Figure 43 Jumper connecting methods
Table 66 Interface specifications
Item |
Specification |
Connector |
RJ-45 |
1 |
· G.703 · G.704 |
Interface rate |
· E1 interface: 2.048 Mbps · T1 interface: 1.544 Mbps |
Cable type |
· E1 75-ohm coaxial cable · E1 120-ohm twisted pair cable: 2 m (6.56 ft), 15 m (49.21 ft), or 30 m (98.43 ft) · T1 100-ohm standard shielded cable · Coaxial connector, network interface connector, or 75-to-120-ohm adapter (with BNC connector) |
Operating mode |
· E1 · T1 · CE1T1 · ISDN PRI |
Services |
Backup Terminal access ISDN PRI |
Interface LEDs
Figure 44 SIC-1VE1T1 panel
Table 67 LED description
LED |
LINK/ACT |
· Steady green: Carrier signal has been received. · Flashing green at 4 Hz: Data is being transmitted or received. · Off: No carrier signals have been received. |
LP/AL |
· Steady yellow: The interface is in loopback mode. · Flashing yellow at 0.5 Hz: An AIS, LFA, or RAI alarm is present. · Off: Neither loopback nor alarm is present. |
Interface cables and connection methods
3G interface modules
· SIC-3G-CDMA
· SIC-3G-TD
· SIC-3G-HSPA
SIC-3G-CDMA
Introduction
The SIC-3G-CDMA module is used to access 3G WLANs. It supports:
· CDMA 2000 1x RTT
· 1x EV-DO Rev.0
· 1x EV-DO Rev.A
Table 68 Interface specifications
Item |
Connector type |
· TNC RF: Antenna for accessing WLANs. · RJ-45: For connecting to a third-party WLAN debugging and testing software such as CAIT of Qualcomm. |
· 2 TNC RF · 1 RJ-45 |
· TNC RF: Omni antenna, supporting CDMA 2000 1 No RTT, 1 No EV-DO Rev.0, 1 No EV-DO Rev.A. · RJ-45: RS-232 |
Cable type |
· TNC RF: None · RJ-45: AUX cable |
Rates |
Network standards: · 1 No EV-DO Rev.A (Downlink: 3.1 Mbps, uplink: 1.8 Mbps) · 1 No EV-DO Rev.0 (Downlink: 2.4 Mbps, uplink: 153.6 Kbps) · 1 No RTT (Downlink: 153.6 Kbps, uplink: 153.6 Kbps) |
Services |
· CDMA 2000 1x RTT · 1 No EV-DO Rev.0 · 1 No EV-DO Rev.A |
NOTE: For information about the frequency bands supported by the interface module, see "Frequency bands for 3G/4G/5G interface modules." |
Interface LEDs
Figure 45 SIC-3G-CDMA panel
Table 69 LED description
LED |
WWAN |
· Steady green indicates that a link is present. · Flashing green indicates that data is being transmitted or received. |
RSSI |
· Steady green indicates strong signal. · Flashing green indicates middle or low signal. · Off indicates weak signal or no signal. |
1xRTT |
· Steady yellow indicates the service is valid. · Off indicates no service. |
EVDO |
Antennas, interface cables, and the connection methods
For more information about SIC-3G-CDMA antennas, interface cables, and the connection methods, see "3G interface."
Installing a SIM card
CAUTION: Make sure the beveled corner of the SIM card fits into the beveled corner of the SIM socket. |
To installing a SIM card:
1. Open the SIM card socket in the direction marked OPEN so the holder projects upwards.
2. Insert the SIM card into the SIM card socket along the guide rails.
3. Close the SIM card socket in the direction marked LOCK to lock the card in position.
4. Execute the display cellular [ interface-number ] command after the router is started. When "SIM Status = OK" appears in the output information, the SIM card is identified.
SIC-3G-TD
Introduction
The SIC-3G-TD module provides access to 3 G WLANs. It supports the following features:
· GPRS
· EDGE
· TD-SCDMA
· HSDPA
Table 70 Interface specifications
Item |
Connector type |
TNC: For connecting an antenna and accessing WLANs. RJ-45: For connecting to a third-party WLAN debugging and testing software such as CAIT of Qualcomm. |
1 TNC RF 1 RJ-45 |
TNC RF: Omni antenna, supporting GPRS/EDGE/TD-SCDMA/HSDPA RJ-45: RS-232 |
Cable type |
TNC RF: None RJ-45: AUX cable |
Rates |
· HSDPA (downlink: 2.8 Mbps, uplink: 384 Kbps) · TD-SCDMA (downlink: 384 Mbps, uplink: 384 Kbps) · EDGE (downlink: 236.8 Kbps, uplink: 236.8 Kbps) · GPRS (downlink: 85.6 Kbps, uplink: 85.6 Kbps) |
Services |
GPRS/EDGE/TD-SCDMA/HSDPA |
Interface LEDs
Figure 46 SIC-3G-TD panel
Table 71 LED description
LED |
WWAN |
· Steady green: A link is present. · Flashing green: Data is being transmitted or received. |
RSSI |
· Steady green: Strong signal. · Flashing green: Middle or low signal. · Off: Weak signal or no signal. |
TD |
· Steady yellow: The service is valid. · Off: No service. |
HSDPA |
For more information about SIC-3G-GSM antennas, interface cables, and the connection methods, see "3G interface."
To install a SIM card:
SIC-3G-HSPA
Introduction
The SIC-3G-HSPA module serves to access 3G networks. It supports:
· GPRS
· EDGE
· UMTS
· HSDPA
Table 72 Interface specifications
Item |
Connector type |
2 TNC RF 1 RJ-45 |
TNC RF: Omni antenna, supporting GPRS/EDGE/UMTS/HSDPA. RJ-45: RS-232 |
Cable type |
Rates |
· HSDPA (downlink: 7.2 Mbps) · HSUPA (uplink: 5.76 Mbps) · UMTS (downlink: 384 Mbps, uplink: 384 Kbps) · EDGE (downlink: 236.8 Kbps, uplink: 236.8 Kbps) · GPRS (downlink: 85.6 Kbps, uplink: 85.6 Kbps) |
Services |
GPRS/EDGE/UMTS/HSDPA |
Supported wireless band |
850/900/1900/2100 MHz WCDMA/HSDPA/HSUPA 850/900/1800/1900 MHz GPRS/EDGE |
Interface LEDs
Figure 47 SIC-3G-HSPA panel
Table 73 LED description
LED |
WWAN |
RSSI |
UMTS |
HSDPA |
CAUTION: The 3G antenna provided with the SIC-3G-HSPA must be installed on the antenna port that has a MAIN mark. |
For more information about SIC-3G-HSPA antennas, interface cables, and the connection methods, see "3G interface."
4G interface modules
· SIC-4G-LTE-M
· SIC-4G-CNDE
· RT-SIC-4G-CAT6
· SIC-D4G-CNDE
SIC-4G-LTE-M
Introduction
The SIC-4G-LTE-M module provides 4G WLAN access and supports the following features:
· LTE
· UMTS
· HSPA+
· TD-SCDMA
· CDMA2000 1xRTT
· CDMA2000 1x-Ev-Do
· Quad-Band EDGE
· GPRS
· GSM
Table 74 Interface specifications
Item |
Connector type |
· TNC—For accessing WLANs. · SMA—For accessing GPS. · Mini USB Type AB—For connecting to third-party WLAN debugging and testing software such as CAIT of Qualcomm. |
· 2 TNCs · 1 SMA · 1 Mini USB Type AB |
· TNC—Supports LTE, UMTS, HSPA+, CDMA 1x, EV-DO Rev A, Quad-Band EDGE, GPRS, and GSM · SMA—GPS · Mini USB Type AB—RS-232 |
Cable type |
· SMA—Flexible 174 sized cable · TNC—None · Mini USB Type AB—USB console cable |
Services |
· LTE · UMTS · HSPA+ · TD-SCDMA · CDMA2000 1xRTT · CDMA2000 1x-Ev-Do · Quad-Band EDGE · GPRS · GSM |
Interface LEDs
Figure 48 SIC-4G-LTE-M panel
Table 75 LED description
LED |
WWAN |
· Steady green indicates that a link is present. · Fast flashing green indicates that data is being transmitted or received. · Slowly flashing green indicates network searching. · Off indicates that no link is present. |
RSSI |
· Steady green indicates strong signal (RSSI ≥ –69 dBm). · Fast flashing green indicates middle signal (–89 dBm ≤ RSSI <–69 dBm). · Slowly flashing green indicates low signal (–99 dBm ≤ RSSI < –89 dBm). · Off indicates weak signal or no signal (RSSI < –99 dBm). |
HSPA+ |
· Steady green indicates that the HSPA+ service or HSDPA service is valid. · Flashing green indicates that the EVDO service is valid. · Off indicates no service. |
LTE |
· Steady green indicates that the LTE service is valid. · Off indicates no LTE service. |
GPS |
· Steady green indicates that the GPS service is valid. · Off indicates no GPS service. |
For more information about SIC-4G-LTE-M interface module antennas, interface cables, and the connection methods, see "4G interface."
SIC-4G-CNDE
Introduction
The SIC-4G-CNDE module provides 4G WLAN access and supports the following technologies:
· LTE-TDD
· LTE-FDD
· TD-SCDMA
· UMTS
· GSM
· EVDO
· CDMA1x
Table 76 Interface specifications
Item |
Connectors |
3 SMA connectors |
Supported antenna types |
· GPS · Omnidirectional antenna, support for FDD-LTE/TDD-LTE/TD-SCDMA/UMTS/EDGE/GPRS/GSM/EVDO/CDMA |
Technologies and supported frequency bands |
· LTE-TDD band 38/39/40/41 · LTE-FDD band 1/3/5/7/8 · TD-SCDMA band 34/39 · UMTS band 1/8 · GSM band 2/3/5/8 · EVDO band BC0 · CDMA1x band BC0 |
Interface LEDs
Figure 49 SIC-4G-CNDE panel
Table 77 LED description
LED |
WWAN |
RSSI |
· Steady green indicates strong signal (RSSI ≥ –69 dBm). · Fast flashing green indicates middle signal (–89 dBm ≤ RSSI <–69 dBm). · Slowly flashing green indicates low signal (–99 dBm ≤ RSSI < –89 dBm). · Steady yellow is reserved for future use. · Off indicates weak signal or no signal (RSSI < –99 dBm). |
LTE |
· Steady green indicates the 4G-LTE service is valid. · Flashing green (8 Hz) indicates the high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is valid. · Steady yellow indicates the 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is valid. · Flashing yellow is reserved for future use. · Off indicates no LTE service. |
GPS |
CNDE |
· Steady green indicates that the module is operating correctly and is not sending or receiving data. · Flashing green indicates that the module is operating correctly and is sending or receiving data. · Steady yellow indicates that the module is faulty. · Off indicates that the module is not installed securely, or no power is present. |
For more information about SIC-4G-CNDE interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
Installing Micro SIM card
CAUTION: Make sure the beveled corner of the Micro SIM card is oriented as indicated by the Micro SIM card icon. |
The SIC-4G-CNDE interface module supports Micro SIM cards.
The SIC-4G-CNDE has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM1 slot 1 is active, the SIM2 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
To install a Micro SIM card:
1. Use a Phillips screwdriver to remove the two screws on the SIM card retainer cover.
2. Lift the cover up and away from the retainer.
3. Insert SIM cards into the SIM card slots on the retainer.
4. Reattach the retainer cover and use the two screws to secure the cover.
5. Execute the display cellular [ interface-number ] command after the router is started. If "SIM Status = OK" is displayed in the output information, the Micro SIM card is identified.
Figure 50 Installing Micro SIM cards
RT-SIC-4G-CAT6
IMPORTANT: The RT-SIC-4G-CAT6 module is hot swappable. However, to avoid unexpected reboot of the host, execute the remove command or press the remove button for over 3 seconds and wait for the remove LED to turn off before removing the module. |
Introduction
The RT-SIC-4G-CAT6 module provides 4G WLAN access and supports the following technologies:
· LTE-TDD
· LTE-FDD
· WCDMA
Table 78 Interface specifications
Item |
Connectors |
3 SMA connectors |
Standard and operating mode |
· GNSS: GPS/GLONASS/BDS/Galileo · Omnidirectional antenna: FDD-LTE, TDD-LTE, WCDMA |
· LTE-TDD · LTE-FDD · WCDMA |
Interface LEDs
Figure 51 RT-SIC-4G-CAT6 panel
Table 79 LED description
LED |
Status |
WWAN |
Steady green |
A WWAN link is present. |
Fast flashing green |
Data is being transmitted or received on the WWAN link. |
Slow flashing green |
Searching and connecting to a WWAN network. |
Off |
Not connected to a WWAN. |
WCDMA |
Steady green |
Strong 3G signal strength (RSSI ≥ –70 dBm) |
Medium 3G signal strength (–100 dBm ≤ RSSI < –70 dBm) |
Low 3G signal strength (–125 dBm ≤ RSSI < –100 dBm) |
Off |
No 3G service (RSSI < –125 dBm) |
LTE |
Steady green |
The module is operating in 4G mode and the 4G signal strength is strong (RSSI ≥ –70 dBm). |
The module is operating in 4G mode and the 4G signal strength is medium (–100 dBm ≤ RSSI < –70 dBm). |
The module is operating in 4G mode and the 4G signal strength is low (–125 dBm ≤ RSSI < –100 dBm). |
Off |
No 4G service (RSSI < –125 dBm) |
SIM |
Steady green |
The SIM card in SIM card slot 0 is working. |
Steady yellow |
The SIM card in SIM card slot 1 is working. |
Off |
No SIM cards are present in the two SIM card slots. |
GNSS |
Steady green |
Valid GNSS service. |
Off |
No GNSS service. |
REMOVE |
Steady green |
The module is operating correctly. You can remove it. |
The module is initializing. You cannot remove it. |
Off |
Antennas, interface cables, and connection methods
For more information about RT-SIC-4G-CAT6 module antennas, interface cables, and the connection methods, see "4G interface" and "GNSS interface."
The RT-SIC-4G-CAT6 module supports Micro SIM cards.
The RT-SIC-4G-CAT6 has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM0 slot is active and the SIM1 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
3. Insert SIM cards into the SIM card slots on the retainer. Make sure the beveled corner of the Micro SIM card is oriented as indicated by the Micro SIM card icon.
Figure 52 Installing Micro SIM cards
SIC-D4G-CNDE
Introduction
The SIC-D4G-CNDE module provides 4G WLAN access and supports the following technologies:
· LTE-TDD
· LTE-FDD
· TD-SCDMA
· UMTS
· GSM
· EVDO
· CDMA1x
Table 80 Interface specifications
Item |
Connectors |
5 SMA connectors |
Technologies and supported frequency band |
Interface LEDs
Figure 53 SIC-D4G-CNDE panel
Table 81 LED description
LED |
WWAN |
RSSI |
LTE |
GPS |
CNDE |
For more information about SIC-D4G-CNDE interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
The SIC-D4G-CNDE interface module supports Micro SIM cards.
The SIC-D4G-CNDE has two Micro SIM card slots. The two slots can operate simultaneously. The SIM1 slot uses M0 and M1 antenna ports. M0 is the primary antenna port and M1 is the auxiliary antenna port. The SIM2 slot uses M2 and M3 antenna ports. M2 is the primary antenna port and M3 is the auxiliary antenna port. You must connect an antenna to the primary antenna port. An auxiliary antenna only cannot guarantee reliable connectivity. If the primary antenna fails, replace it immediately.
On the SIC-D4G-CNDE interface module, the space between adjacent antenna ports is insufficient for two antennas. To install 4G antennas for two adjacent ports, use a 4G antenna extension cable to connect one of the antennas.
Figure 54 Installing Micro SIM cards
· RT-SIC-5G
· RT-SIC-5G-CN
RT-SIC-5G
CAUTION: Before removing an RT-SIC-5G module, execute the remove command or press and hold the remove button for more than 3 seconds and wait for the remove LED to turn off. The device might reboot unexpectedly if you remove a SIC-5G module with its remove LED on. |
Introduction
The RT-SIC-5G module provides 5G WLAN access and supports the following technologies:
· 5G NR
· LTE-A
· WCDMA
· FDD-LTE
· TDD-LTE
Table 82 Interface specifications
Item |
Connectors |
4 SMA connectors |
Standard and working mode |
· GNSS: GPS/GLONASS/BeiDou/Galileo · Omnidirectional antenna, support for WCDMA/FDD-LTE/TDD-LTE/5G NR |
Supported service |
· 5G/4G/3G networking · 5G and LTE-A full coverage · NSA and SA modes · Integrating multi-constellation GNSS receiver for fast and precise positioning in different environments |
Interface LEDs
Figure 55 RT-SIC-5G panel
Table 83 LED description
LED |
Status |
WWAN |
Steady green |
Off |
5G |
Steady green (SA mode) |
Strong 5G signal strength (RSRP ≥ –85 dBm) |
Fast flashing green (SA mode) |
Medium 5G signal strength (–100 dBm ≤ RSRP < –85 dBm) |
Slow flashing green (SA mode) |
Low 5G signal strength (–115 dBm ≤ RSRP < –100 dBm) |
Steady yellow (NSA mode) |
Fast flashing yellow (NSA mode) |
Slow flashing yellow (NSA mode) |
Off |
No 5G service |
LTE |
Steady green |
Steady yellow |
The module is operating in 3G mode and the 3G signal strength is strong (RSSI ≥ –70 dBm). |
Fast flashing yellow |
The module is operating in 3G mode and the 3G signal strength is medium (–100 dBm ≤ RSSI < –70 dBm). |
Slow flashing yellow |
The module is operating in 3G mode and the 3G signal strength is low (–125 dBm ≤ RSSI < –100 dBm). |
Off |
No 3G and 4G services. |
SIM |
Steady green |
Steady yellow |
The SIM card in SIM card slot 2 is working. |
Off |
GNSS |
Steady green |
Off |
No GNSS service. |
REMOVE |
Steady green |
The module is operating correctly. You can hot-remove it. |
The module is initializing. You cannot hot-remove it. |
Off |
For more information about RT-SIC-5G interface module antennas, interface cables, and the connection methods, see "5G interface."
Installing a 5G SIM card
CAUTION: To avoid damage to the SIM card or the 5G interface module, insert the SIM card into the slot with the cut corner oriented as shown in the illustration. |
The RT-SIC-5G interface module provides two SIM card slots. You can install one or two SIM cards as required. SIM card 1 is operating by default when two SIM cards are installed on the SIC-5G interface module. In Figure 56, two SIM cards are installed.
To install a 5G SIM card:
1. Use a screwdriver to remove the two screws on the SIM card retainer cover.
2. Lift the cover up and away from the retainer, as shown by callout 2 in Figure 56.
3. Orient the SIM card with the cut corner as shown in the illustration.
4. Insert the SIM card into the SIM card slot along the guide rails.
5. Slightly push SIM card edge to secure it into the slot.
6. Reattach the retainer cover and use the two screws to secure the cover.
7. Execute the display cellular [ interface-number ] command after the router is started. If "SIM Status = OK" is displayed in the output information, the SIM card is identified.
Figure 56 Installing 5G SIM cards
RT-SIC-5G-CN
CAUTION: Before removing an RT-SIC-5G-CN module, execute the remove command or press and hold the remove button for more than 3 seconds and wait for the remove LED to turn off. The device might reboot unexpectedly if you remove a RT-SIC-5G-CN module with its remove LED on. |
Introduction
The RT-SIC-5G-CN module provides 5G WLAN access and supports the following technologies:
· 5G NR
· LTE-A
· WCDMA
· FDD-LTE
· TDD-LTE
Table 84 Interface specifications
Item |
Connectors |
4 SMA connectors |
SMA · Omnidirectional antenna, support for WCDMA/FDD-LTE/TDD-LTE/5G NR |
Supported service |
· 5G/4G/3G networking · 5G and LTE-A full coverage · NSA and SA modes |
Interface LEDs
Figure 57 RT-SIC-5G-CN panel
Table 85 LED description
LED |
Status |
WWAN |
Steady green |
Off |
5G |
Off |
No 5G service |
LTE |
Steady green |
Steady yellow |
Off |
SIM |
Steady green |
Steady yellow |
Off |
REMOVE |
Steady green |
Off |
For more information about RT-SIC-5G-CN interface module antennas, interface cables, and the connection methods, see "5G interface."
CAUTION: To avoid damage to the SIM card and 5G interface module, insert the SIM card into the slot with the cut corner oriented as shown in the illustration. |
The RT-SIC-5G-CN interface module provides two SIM card slots. You can install one or two SIM cards as required. SIM card 1 is operating by default when two SIM cards are installed on the RT-SIC-5G-CN interface module. In Figure 56, two SIM cards are installed.
Figure 58 Installing 5G SIM cards
Network data encryption modules
· SIC-CNDE
· SIC-CNDE-SJK
· SIC-4G-CNDE-SJK
· SIC-D4G-CNDE-SJK
SIC-CNDE
Introduction
The SIC-CNDE is a China Network Data Encryption (CNDE) module. The SIC-CNDE provides high performance and reliable data encryption features for routers by using the SM1 mechanism.
Insert SIC-CNDE module in the SIC slot. The main board forwards IP packets and implements VPN with the encryption feature, where SM1 encryption and decryption is implemented by the encryption module.
Table 86 Interface specifications
Item |
Hardware algorithm |
Key algorithm: · SM1-128 · SM1-256 |
Interface LEDs
Figure 59 SIC-CNDE panel
Table 87 LED description
LED |
ACT |
· Flashing: Data is being transmitted or received between the module and the host. · Steady green: No data is being transmitted or received. |
SIC-CNDE-SJK
Introduction
The SIC-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers.
LEDs
Figure 60 SIC-CNDE-SJK panel
Table 88 LED description
LED |
CNDE |
· Steady green: The module is operating correctly and is not sending or receiving data. · Flashing green: The module is operating correctly and is sending or receiving data. · Steady yellow: The module is faulty. · Off: The module is not installed securely, or no power is present. |
SIC-4G-CNDE-SJK
Introduction
The SIC-4G-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers. The SIC-4G-CNDE-SJK module provides 4G WLAN access and supports the following technologies:
· LTE-TDD
· LTE-FDD
· TD-SCDMA
· UMTS
· GSM
· EVDO
· CDMA1x
Table 89 Interface specifications
Item |
Connectors |
3 × SMA connectors |
· GPS antenna · Omnidirectional antenna, support for FDD-LTE/TDD-LTE/TD-SCDMA/UMTS/EDGE/GPRS/GSM/EVDO/CDMA |
Interface LEDs
Figure 61 SIC-4G-CNDE-SJK panel
Table 90 LED description
LED |
WWAN |
· Steady green: A link is present. · Fast flashing: Data is being transmitted or received. · Slowly flashing: The module is searching for wireless networks. · Off: No link is present. |
RSSI |
· Steady green: Strong signal strength (RSSI ≥ –69 dBm). · Fast flashing: Middle signal strength (–89 dBm ≤ RSSI <–69 dBm). · Slowly flashing green: Low signal strength (–99 dBm ≤ RSSI < –89 dBm). · Off: Weak or no signal strength (RSSI < –99 dBm). |
LTE |
· Steady green: The 4G-LTE service is running. · Flashing green (8 Hz): The high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is running. · Steady yellow: The 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is running. · Off: No LTE service. |
GPS |
· Steady green: The GPS service is running. · Off: No GPS service. |
CNDE |
For more information about SIC-4G-CNDE-SJK interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
Installing a Micro SIM card
The SIC-4G-CNDE-SJK interface module supports Micro SIM cards.
The SIC-4G-CNDE-SJK has two Micro SIM card slots, but only one is active at a time. If you install SIM cards in both slots, the SIM1 slot 1 is active, the SIM2 slot is in standby state by default. To perform an active/standby switchover, execute the sim switch-to command. For more information about the command, see Layer 2—WAN Access Command Reference for the product.
Figure 62 Installing Micro SIM cards
SIC-D4G-CNDE-SJK
Introduction
The SIC-D4G-CNDE-SJK (D4G indicates that the module supports two SIM cards that can operate simultaneously; CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers. The SIC-D4G-CNDE-SJK module provides 4G WLAN access and supports the following technologies:
· LTE-TDD
· LTE-FDD
· TD-SCDMA
· UMTS
· GSM
· EVDO
· CDMA1x
Table 91 Interface specifications
Item |
Connectors |
5 SMA connectors |
Interface LEDs
Figure 63 SIC-D4G-CNDE-SJK panel
Table 92 LED description
LED |
WWAN |
· Steady green: A link is present. · Fast flashing green: Data is being transmitted or received. · Slowly flashing green: The module is searching for wireless networks. · Off: No link is present. |
RSSI |
· Steady green: Strong signal strength (RSSI ≥ –69 dBm). · Fast flashing green: Middle signal strength (–89 dBm ≤ RSSI <–69 dBm). · Slowly flashing green: Low signal strength (–99 dBm ≤ RSSI < –89 dBm). · Off: Weak or no signal strength (RSSI < –99 dBm). |
LTE |
· Steady green: The 4G-LTE service is running. · Flashing green (8 Hz): The high-speed 3G service such as DC-HSPA+, HSPA+, HSDPA, HSUPA, or EVDO is running. · Steady yellow: The 2G or low-speed 3G service such as UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, or GSM is running. · Off: No LTE service is running. |
GPS |
· Steady green: The GPS service is running. · Off: No GPS service is running. |
CNDE |
For more information about SIC-D4G-CNDE-SJK interface module antennas, interface cables, and the connection methods, see "4G interface" and "GPS interface."
The SIC-D4G-CNDE-SJK has two Micro SIM card slots. The two slots can operate simultaneously. The SIM1 slot uses M0 and M1 antenna ports. M0 is the primary antenna port and M1 is the auxiliary antenna port. The SIM2 slot uses M2 and M3 antenna ports. M2 is the primary antenna port and M3 is the auxiliary antenna port. You must connect an antenna to the primary antenna port. An auxiliary antenna only cannot guarantee reliable connectivity. If the primary antenna fails, replace it immediately.
On the SIC-D4G-CNDE-SJK interface module, the space between adjacent antenna ports is insufficient for two antennas. To install 4G antennas for two adjacent ports, use a 4G antenna extension cable to connect one of the antennas.
Figure 64 Installing Micro SIM cards
WLAN interface modules
· SIC-AP220
· SIC-AP320
SIC-AP220
Introduction
The SIC-AP220 WLAN interface module receives and sends wireless data. Two external antennas can be installed on the module. The module supports the 802.11a/b/g/n/ac standard and can operate on both the 2.4 G and 5G frequency bands.
Table 93 Interface specifications
Item |
Connector type |
RJ-45 |
Number of connectors |
Two: one for the FE port and one for the console port |
Interface standard |
FE port: 802.3/802.3u, 10/100Mbps autosensing, full/half duplex Console port: RS/EIA-232 Radio interface: Radio 1 operates on the 5 GHz frequency band and supports the 1×1 MIMO technology. Radio 2 operates on the 2.4 GHz frequency band and support the 2×2 MIMO technology. |
Cable type |
FE port: Standard (straight-through)/cross-over Ethernet cable Console port: Console cable |
Interface LEDs
Figure 65 SIC-AP220 panel
Table 94 LED description
LED |
SYS |
· Steady amber: The module is starting up. · Flashing green: Only the 2.4G radio has associated clients. · Flashing amber: Only the 5G radio has associated clients. · Flashing alternatively between amber and green: Both the 2.4G and 5G radios have associated clients. |
Interface cables and the connection methods
For more information about Ethernet interface cables and the connection methods, see "Ethernet interface."
For more information about WLAN interface cables and the connection methods, see "WLAN interface."
SIC-AP320
Introduction
The SIC-AP320 WLAN interface module receives and sends wireless data. Two external antennas can be installed on the module. The module supports the 802.11a/b/g/n/ac standard and can operate on both the 2.4 G and 5G frequency bands.
Table 95 Interface specifications
Item |
Connector |
1 RJ-45 connector for the console port |
Console port: RS/EIA-232 Radio interface: Radio 1 operates on the 5 GHz frequency band and supports the 2×2 MIMO technology. Radio 2 operates on the 2.4 GHz frequency band and support the 1×1 MIMO technology. |
Cable type |
Console cable for the console port |
Interface LEDs
Figure 66 SIC-AP320 panel
Table 96 LED description
LED |
SYS |
M.2 riser SIC modules
RT-SIC-M2-SATA
CAUTION: · The RT-SIC-M2-SATA module is hot swappable. To remove an RT-SIC-M2-SATA module, first press and hold the remove button for a minimum of three seconds. You can remove the module only when the remove LED is turned off. If the remove LED is flashing green, wait for the remove LED to turn off and then remove the module. · No M.2 SSD drive is provided with the RT-SIC-M2-SATA module. Purchase one as required. · To build a redundant array of independent disks (RAID), install two SSD drives of the same size in two RT-SIC-M2-SATA modules. |
Introduction
The RT-SIC-M2-SATA module is an M.2 SSD riser SIC module that provides high data availability through RAID. RAID combines multiple physical drives into one logical drive to provide better storage performance and data backup than a single drive.
Module specifications
Table 97 Module specifications
Item |
Drive type |
M.2 SATA SSD |
Drive dimensions (D × W) |
80 × 22 mm (3.15 × 0.87 in) |
Number of drives |
1 |
RAID level |
RAID 1 |
Theoretical transmission rate |
1.5/3/6 Gbps |
Interface LEDs
Figure 67 RT-SIC-M2-SATA panel
Table 98 LED description
LED |
Status |
PWR |
Steady green |
The module has normal power input. |
Off |
The module does not have power input. |
SSD |
Steady green |
A SSD drive is present. |
Steady yellow |
The SSD drive is damaged. |
Off |
No SSD drive is present. |
ACT |
Flashing green (8 Hz) |
The system is reading or writing data to the drive. |
Off |
The system is not reading or writing data to the drive. |
REMOVE |
· The module is being initialized. Pressing the remove button or removing the module is not allowed. · A removal operation is being performed. |
Steady green |
The module is operating correctly. Pressing the remove button to remove the module is allowed. |
Off |
The module can be removed. |
Installing an SSD drive on the module
CAUTION: To use the RT-SIC-M2-SATA module, install an SSD drive in it. |
To install an SSD drive on the module:
1. Insert the SSD drive into the M.2 slot on the module at a 45° angle.
2. Slightly press the SSD drive until it is level with the surface of the connector.
3. Use a Phillips screwdriver to screw the SSD drive into place.
Figure 68 Installing an SSD drive
MIM interface modules
CAUTION: MIM interface modules can be hot-swapped. To install a MIM interface module in an HMIM slot, first attach the MIM to an HMIM adapter and then insert the MIM into the HMIM slot. This can be performed when the device is operating. To remove a MIM interface module during device operation, first execute the remove command. |
For the modular MSR series routers, a wide range of optional multiple interface modules (MIMs) are available, which provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1/T1, ISDN BRI/PRI, audio interface, and Layer 2 switching interface.
ATM interface modules
· MIM-1ATM-OC3
MIM-1ATM-OC3
Introduction
The 1-port ATM (Asynchronous Transfer Mode) 155 Mbps optical interface module (MIM-1ATM-OC3) provides ATM interfaces for routers and supports:
· Two frame formats: SDH STM-1 and SONET OC-3
· Scrambling in data transmission
· Both line clock (when working as DTE interface), and internal clock (when working as DCE interface)
· Three types of test measures, that is, local cell loopback, local payload loopback, and remote loopback.
Table 99 Interface specifications
Item |
Number of interfaces |
1 |
Connector |
SFP/LC |
SONET OC-3/SDH STM-1 |
Operating mode |
155 Mbps |
Interface LEDs
Figure 69 MIM-1ATM-OC3 panel
Table 100 LED description
LED |
LINK/ACT |
· On: A carrier signal is received. · Flashing: Data is being received or/and transmitted. · Off: No carrier signal is received. |
LP/AL |
· On: The interface is in loopback mode. · Off: No loopback or alarm is present. · Flashing: An alarm indication signal (AIS), loss of frame alignment (LFA) signal, or remote alarm indication (RAI) signal is present. |
Transceiver modules, optical fibers, and connection methods
For more information about transceiver modules, optical fibers, and the connection methods, see "Fiber port."
POS (SDH/SONET) interface modules
· MIM-1POS
MIM-1POS
Introduction
The 1-port SDH/SONET interface module (MIM-1POS) supports interface rates up to 155.52 Mbps (STM-1/OC-3).
The MIM-1POS can use the protocols such as PPP, Frame Relay and HDLC at the data link layer and IP at the network layer. It allows direct transmission of packets over SONET/SDH. It supports:
· Various types of transceiver modules.
· 155.52 Mbps fractional interface.
Table 101 Interface specifications
Item |
MIM-1POS |
Connector |
SFP/LC |
1 |
Interface rate |
155.52 Mbps |
Interface LEDs
LED |
LINK/ACT |
LP/AL |
E1/T1 interface modules
· MIM-1E1
· MIM-2E1
· MIM-4E1
· MIM-1E1-F
· MIM-2E1-F
· MIM-4E1-F
· MIM-8E1
· MIM-8E1-F
· MIM-2T1
· MIM-4T1-F
MIM-1E1/MIM-2E1/MIM-4E1/MIM-1E1-F/MIM-2E1-F/MIM-4E1-F
Introduction
The 1-/2-/4-port channelized E1/PRI interface module (MIM-1E1/MIM-2E1/MIM-4E1) transmits, receives, and processes E1 data traffic. In addition, you can use the module for other purposes, such as CE1 access and the ISDN PRI function.
· MIM-1E1-F/MIM-2E1-F/MIM-4E1-F
The MIM-1E1-F/MIM-2E1-F/MIM-4E1-F module is different from the MIM-1E1/MIM-2E1/MIM-4E1 module in the sense that:
¡ The FE1 operating mode supported by the E1-F modules allows only one n No 64 kbps bundle to be formed on each interface, where n = 1 to 31. However, an E1 module allows arbitrary grouping of 31 channels and multiple bundles.
¡ The E1-F modules do not support PRI mode.
Table 103 Interface specifications
Item |
MIM-1E1/1E1-F module |
MIM-2E1/2E1-F module |
MIM-4E1/4E1-F module |
Connector |
DB-15 |
DB-15 |
DB-25 |
1 |
2 |
1 |
· G.703 · G.704 |
Interface rate |
2.048 Mbps |
Cable type |
· E1 75-ohm unbalanced coaxial cable · E1 120-ohm balanced twisted pair cable · 120-ohm 4E1 conversion cable (MIM-4E1/MIM-4E1-F modules) · 75-ohm 4E1 conversion cable (MIM-4E1/MIM-4E1-F modules) · Coaxial connector, network interface connector and 75-ohm to 120-ohm adapter (with BNC connector) |
Operating mode |
· E1, CE1, ISDN PRI (only supported by MIM-1E1/MIM-2E1/MIM-4E1) · FE1 (only supported by MIM-1E1-F/MIM-2E1-F/MIM-4E1-F) |
Supported service |
· Backup · Terminal access service · ISDN PRI (only supported by MIM-1E1/MIM-2E1/MIM-4E1) |
Interface LEDs
MIM-1E1 and MIM-1E1-F panels are similar. The following figure illustrates an MIM-1E1 panel.
Figure 71 MIM-1E1 panel
The panels of MIM-2E1 and MIM-2E1-F are similar. The following figure illustrates an MIM-2E1 panel.
Figure 72 MIM-2E1 panel
MIM-4E1 and MIM-4E1-F panels are similar. The following figure illustrates an MIM-4E1 module.
Figure 73 MIM-4E1 panel
LED |
LINK |
· Off: The link is not set up. · On: The link has been set up. |
ACT |
· Off: No data is being transmitted or received; · Flashing: Data is being received or/and transmitted. |
For more information about E1 interface cables and the connections methods, see "E1 interface."
MIM-8E1/MIM-8E1-F
Introduction
· MIM-8E1 module
The 8-port channelized E1/PRI interface module (MIM-8E1) transmits, receives, and processes eight channels of E1 data traffic. In addition, you can use the module for other purposes, such as CE1 access and the ISDN PRI function.
· MIM-8E1-F module
The 8-port fractional E1 interface module (MIM-8E1-F) is different from the MIM-8E1 module in the sense that:
¡ The FE1 operating mode supported by the MIM-8E1-F module allows only one n No 64 kbps bundle to be formed on each interface, where n = 1 to 31. However, an MIM-8E1 module allows arbitrary grouping of 31 channels and therefore multiple bundles.
¡ The MIM-8E1-F module does not support PRI mode.
NOTE: For a MIM-8E1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller E1 interface. |
Table 105 Interface specifications
Item |
Connector |
D68 |
1 |
G.703 |
Interface rate |
2.048 Mbps |
Cable type |
75-ohm 8E1 conversion cable |
Cable characteristic impedance |
75-ohm |
Operating mode |
· E1, CE1, ISDN PRI (only supported by MIM-8E1) · FE1 (only supported by MIM-8E1-F) |
Supported service |
· Backup · Terminal access service · ISDN PRI (only supported by MIM-8E1) |
Interface LEDs
MIM-8E1 and MIM-8E1-F panels are similar.
Figure 74 MIM-8E1 (75-ohm) panel
Figure 75 MIM-8E1-F (75-ohm) panel
LED |
LINK |
ACT |
MIM-2T1/MIM-4T1-F
Introduction
The 2-port channelized T1/PRI interface module (MIM-2T1) serves to transmit/receive and handle T1 data streams, provide CT1 access, and fulfill the function of ISDN PRI. Thereby, one module can be used for multiple purposes.
The 4-port fractional T1 interface module (MIM-4T1-F) provides the following features:
¡ FT1 operating mode supported by T1-F modules allows only one bundle. In other words, the time slots can only be bundled into one n x 64 kbps or 56 kbps channel, where n=1-24.
¡ T1-F does not support PRI mode.
NOTE: For a MIM-1T1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller T1 interface. |
Table 107 Interface specifications
Item |
Connector |
RJ-45 |
· 2 (MIM-2T1 module) · 4 (MIM-4T1-F module) |
Interface rate |
1.544 Mbps |
Cable type |
T1 cable (100-ohm shielding network cable) |
Operating mode |
· CT1/ISDN PRI (MIM-2T1 module) · FT1 (MIM-4T1-F module) |
Supported service |
· Backup · Terminal access service · ISDN PRI (MIM-2T1 module) |
Interface LEDs
Figure 76 MIM-2T1 panel
Figure 77 MIM-4T1-F panel
Table 108 LED description
LED |
LINK/ACT |
LP/AL |
E3/T3 interface modules
· MIM-1CE3
MIM-1CE3
Introduction
The 1-port channelized E3 interface module (MIM-1CE3) serves to:
· Transmit/Receive and handle one channel of E3 fast traffic, as well as provide the accessing of E3 traffic when working in E3 mode.
· Provide the low-speed accessing service at the speed of n No 64 kbps, where n is smaller than or equal to 128, when working in CE3 mode.
NOTE: E3 represents the tertiary group rate of E system in the TDM system, that is, 34.368 Mbps. An E3 channel can be channelized into 16 E1 lines through the demultiplexing processes of E23 and E12, each E1 line supporting both the operating modes of E1 and CE1. E23 is used to indicate either E2-to-E3 multiplex or E3-to-E2 demultiplex, and E12 to indicate E1-to-E2 multiplex or E2-to-E1 demultiplex. "E23" and "E12" discussed here represent the demultiplex process. |
Table 109 Interface specifications
Item |
Connector |
SMB |
2 |
· G.703 · G.704 · G.751 |
Interface rate |
34.368 Mbps |
Interface cable type |
E3 cable (75ohm coaxial cable) |
Operating mode |
E3 CE3 |
Supported service |
E3 leased line |
Interface LEDs
Figure 78 MIM-1CE3 panel
LED |
LINK |
ACT |
For more information about E3 interface cables and the connection methods, see "E3/T3 interface."
· MIM-2SAE
· MIM-4SAE
· MIM-8SAE
· MIM-8ASE
· MIM-16ASE
MIM-2SAE/MIM-4SAE/MIM-8SAE
Introduction
The MIM-2SAE/MIM-4SAE/MIM-8SAE stands for 2/4/8-port enhanced high-speed synchronous/asynchronous serial interface module. In terms of function, SAE modules are the same as SA modules except that SAE modules support more protocols, for example, RS449, X.21, and RS530.
Table 111 Interface specifications
Item |
Synchronous |
Asynchronous |
Connector |
D28 |
2 (MIM-2SAE) 4 (MIM-4SAE) 8 (MIM-8SAE) |
V.24 |
V.35, RS449, X.21, RS530 |
RS-232 |
DTE, DCE |
DTE, DCE |
1200 |
1200 |
300 |
64 k |
2.048 M |
115.2 |
Cable |
Supported service |
· Dialup through modems · Backup · Asynchronous leased line · Dumb terminal access |
Interface LEDs
LED |
LINK |
· Off: No link is present; · On: A link is present. |
ACT |
The MIM-8SAE module provides a LED for each channel. When the LED is on, a link is present. When the LED is flashing, data is being transmitted or received.
MIM-8ASE/MIM-16ASE
Introduction
The 8/16-port enhanced asynchronous serial interface module (MIM-8ASE/MIM-16ASE) transmits/receives and handles asynchronous serial interface data streams. ASE modules, however, use RJ-45 connectors and AUX cables.
Table 113 Interface specifications
Item |
MIM-8ASE module |
MIM-16ASE module |
Connector |
RJ-45 |
8 (MIM-8ASE) 16 (MIM-16ASE) |
RS-232 |
Cable |
· AUX cable · Ethernet straight-through cable · MIM-8ASE/MIM-16ASE dumb terminal cable |
300 |
115.2 k |
Service supported |
· Dialup through Modem · Backup · Terminal access service · Asynchronous leased line service |
Interface LEDs
Each channel on the MIM-8ASE/MIM-16ASE has only one LED.
Table 114 LED description
LED |
LINK/ACT |
· Off: No link is present; · On: A link is present. · Flashing: Data is being transmitted or received. |
For more information about asynchronous serial port cables and the connection methods, see "Asynchronous serial ports."
POS terminal access interface modules
· MIM-6FCM
MIM-6FCM
Introduction
The 6-port fast connect modem interface module (FIC-6FCM) provides services for point of sale (POS) terminal devices to fast dial up to a bank card accounting system.
NOTE: The point of sale (POS) access service refers to a type of smart card service widely used in places such as shopping malls and gasoline service stations. It links a POS terminal device located in a shopping mall or a gasoline service station to a bank card accounting system to provide services. |
Table 115 Interface specifications
Item |
Connector |
RJ-45 |
6 |
Cable |
Supported protocols |
· ITU-T-V.22 (PSK/QPSK) · V.22 BIS (QAM) |
Interface LEDs
Figure 84 MIM-6FCM panel
Each connector of the POS access port has two LEDs: carrier detect (CD) and ACT.
Table 116 LED description
LED |
CD |
· Off: No carrier signals are detected. · On: A carrier signal is detected. |
ACT |
· Flashing: Data is being received or transmitted. · Off: No data is being received or transmitted. |
Interface cable
The MIM-6FCM uses telephone cables with ferrite core.
NOTE: The standard equipment package for the MIM-6FCM includes the appropriate number of interface cables. |
Connecting the interface cable
CAUTION: · Before connecting a port, read its label carefully. A wrong connection might damage the interface module or the device. · Add a special lightning arrester at the input end of the telephone cable for better protection. |
To connect the interface cable:
1. Connect one end of a telephone cable to the RJ-11 or RJ-45 connector of the FCM interface.
2. Connect the other end of the telephone cable to the PSTN network.
3. Check the LED on the MIM-6FCM panel. When the LED is on, the self-test succeeds. The LED is off, the self-test failed. In the latter case, contact your agent.
Upgrading the FCM module software
1. Download the FCM module software to the CF module or flash of the router.
2. After the router that is inserted with the FCM module is powered on and starts up, input bootrom update file cfa0:/ filename slot slotnum all in the user mode to upgrade FCM module software.
3. Run the display version command to display the driver version. If the version number is changed, the upgrade is completed.
The driver version number is just like (Driver) 1.0 in the module information displayed as follows:
[SLOT 5]MIM-6FCM (Hardware)1.0, (Driver)1.0, (Cpld)1.0
· MIM-4FXS
· MIM-4FXO
· MIM-8FXS8FXO
· MIM-16FXS
· MIM-4E&M
· MIM-2VE1
· MIM-2VT1
· MIM-1VE1
· MIM-1VT1
MIM-8FXS8FXO
Introduction
The 8-port voice subscriber circuit and 8-port voice AT0 analog trunk interface module (MIM-8FXS8FXO) serves to access and handle 16 channels of analog voice signals over data communication networks. The module provides eight FXS interfaces and eight FXO interfaces:
CAUTION: While using MIM-8FXS8FXO, make sure the device can be connected to IP networks or other WANs. |
Table 117 Interface specifications
Item |
Connector type |
RJ-11 |
· 8 (FXS interfaces) · 8 (FXO interfaces) |
· Subscriber circuit interface (FXS) compliant with ITU Q.512. · Loop trunk interface (FXO) compliant with ITU Q.552. · Over-current and over-voltage protection compliant with ITU K.20. |
Cable type |
Dial-up mode |
DTMF, compliant with GB3378 (Pulse dial-up is not available.) |
Bandwidth |
300 to 3400 Hz |
Interface LEDs
Figure 85 MIM-8FXS8FXO panel
Table 118 LED description
LED |
LINK/ACT |
· Off: No link is present. · Steady green: A link is present and a call connection is being established. · Flashing yellow: A link is present and there is a call activity. |
MIM-16FXS
Introduction
The 16-port loop trunk interface module (MIM-16FXS) serves to access and handle 16 channels of analog voice signals over data communication networks. The module provides 16 FXS interfaces:
Table 119 Interface specifications
Item |
Connector type |
RJ-11 |
16 (FXS interfaces) |
Subscriber circuit interface (FXS) compliant with ITU Q.512. Over-current and over-voltage protection compliant with ITU K.20. |
Cable type |
Dial-up mode |
Bandwidth |
300 to 3400 Hz |
Interface LEDs
Figure 86 MIM-16FXS panel
Table 120 LED description
LED |
LINK/ACT |
For more information about FXS interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
MIM-2VE1
Introduction
The 2-port E1 voice interface module (MIM-2VE1) handles dense voice signals in a VoIP system. It provides two CE1/PRI/R2 ports, allowing the access of 60 channels of voice signals.
Table 121 Interface specifications
Item |
Connector |
D15 |
2 |
Operating mode |
CE1 ISDN PRI R2 |
Interface rate |
2.048 Mbps |
Cable |
E1 120-ohm balanced twisted pair cable 75ohm-to-120ohm adapter |
Supported service |
· R2 signaling · DSS1 signaling · IP Fax · General VoIP features in Comware |
Interface LEDs
Figure 87 MIM-2VE1 panel
Table 122 LED description
LED |
LINK |
· Off: No link is present. · On: A link is present. |
ACT |
· Off: No data is being transmitted or received on the interface. · Flashing: Data is being transmitted and/or received. |
For more information about E1 interface cables and the connection methods, see "E1 interface."
MIM-2VT1
Introduction
The 2-port T1 voice interface module (MIM-2VT1) can handle dense voice signals in VoIP system. It provides two CT1/PRI ports, allowing the access of 48 channels of voice signals.
Table 123 Interface specifications
Item |
Connector |
RJ-45 |
2 |
Interface rate |
1.544 Mbps |
Cable type |
Operation mode |
· CT1 · ISDN PRI |
Services |
· Backup · Terminal access · ISDN |
Interface LEDs
Figure 88 MIM-2VT1 panel
Table 124 LED description
LED |
LINK |
ACT |
For more information about T1 interface cables and the connection methods, see "T1 interface."
MIM-1VE1
Introduction
The 1-port E1 voice interface module (MIM-1VE1) can handle dense voice signals in VoIP system. It provides a CE1/PRI/R2 port, allowing the access of 30 channels of voice signals.
Table 125 Interface specifications
Item |
Connector |
D15 |
1 |
Operating mode |
CE1 ISDN PRI R2 |
Interface rate |
2.048 Mbps |
Cable |
E1 120-ohm balanced twisted pair cable 75-ohm-to-120-ohm adapter (with BNC connector) |
Supported service |
Interface LEDs
Figure 89 MIM-1VE1 panel
Table 126 LED description
LED |
LINK |
ACT |
MIM-1VT1
Introduction
The 1-port T1 voice interface module (MIM-1VT1) can handle dense voice signals in VoIP system.
The MIM-1VT1 module is structured in the form of board plus VCPM module plus VPM strip. It provides a CT1/PRI port, allowing the access of 24 channels of voice signals.
Table 127 Interface specifications
Item |
Connector |
RJ-45 |
1 |
Interface rate |
1.544 Mbps |
Cable type |
Operation mode |
CT1 ISDN PRI |
Services |
Interface LEDs
Figure 90 MIM-1VT1 panel
Table 128 LED description
LED |
LINK |
ACT |
MIM-4FXS/MIM-4FXO
Introduction
· The 4-port voice subscriber circuit interface module (MIM-4FXS) serves to access and handle 4 channels of ordinary analog phone, fax, or AT0 loop trunk of telephone exchange.
· The 4-port voice AT0 analog trunk interface module (MIM-4FXO) serves to access and handle 4 channels of common user lines of telephone exchange.
These modules make it possible to transfer voice signals over data communication networks.
Table 129 Interface specifications
Item |
Connector |
RJ-45 |
4 |
Cable |
· Telephone cable with ferrite core · E&M trunk (for E&M module, which should be made by users depending on the actual needs at the site.) |
· ITU Q.512-compliant subscriber circuit interface (MIM-4FXS) · ITU Q.552-compliant loop trunk interface (MIM-4FXO) · ITU K.20-compliant overcurrent and overvoltage protection |
Dial-up mode |
DTMF (Dual-Tone Multi-Frequency) but not pulse dial-up |
Bandwidth |
300 Hz to 3400 Hz |
Interface LEDs
Figure 91 MIM-4FXS panel
Figure 92 MIM-4FXO panel
LED |
LINK |
ACT |
· Off: The channel is idle. · On: There is call activity. |
MIM-4E&M
Introduction
The 4-port voice E&M analog trunk interface module (MIM-4E&M) serves to access and handle 2/4 channels of E&M analog trunks.
Table 131 Interface specifications
Item |
Connector |
RJ-45 |
4 |
Cable |
· G.712-compliant E&M trunk interface, E&M interface (supporting Bell type I, II, III, V, and support 4-wire). · ITU K.20-compliant overcurrent and overvoltage protection |
Dial-up mode |
Bandwidth |
300 Hz to 3400 Hz |
Interface LEDs
Figure 93 MIM-4E&M panel
Table 132 LED description
LED |
LINK |
ACT |
For more information about E&M interface cables and the connection methods, see "E&M interface."
HMIM/DHMIM interface modules
CAUTION: · HMIM interface modules can be hot-swapped. To remove a HMIM when the device is operating, first execute the remove command or press the remove button. If you fail to do so, the device might reboot unexpectedly. For the specific operation instructions, see the description for the HMIM interface module. The remove command and the remove button cannot be used simultaneously, as this might cause the HMIM interface module to become unusable. · DHMIM interface modules can be hot-swapped. To remove a DHMIM when the device is operating, first execute the remove command. |
For the modular MSR series routers, a wide range of optional high-performance multiplex interface modules (HMIMs) and double high-performance multiplex interface modules (DHMIMs) are available, which provide abundant interfaces, including synchronous/asynchronous serial interface, Ethernet interface, E1/T1, ISDN BRI/PRI, audio interface, and Layer 2 switching interface.
Ethernet switching modules
· HMIM-8GSW
· HMIM-24GSW
· HMIM-24GSW-PoE
· HMIM-8GSWF
HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE
Introduction
The HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE module is an 8/24/24 1000 Mbps Ethernet Layer 2 switching HMIM interface module. Each HMIM-8GSW/HMIM-24GSW module provides 8/24 1000 Mbps RJ-45 ports. HMIM-8GSW/HMIM-24GSW modules are suitable for a small enterprise network to act as a switching and routing device, which can be directly connected to PCs and network devices of the enterprise. The HMIM-24GSW-PoE can supply power to remote PDs.
The HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE supports the following functions:
· A transmission distance of 100 m (328.08 ft) over a category-5 twisted pair cable (crossover or straight-through cable).
· 1000 Mbps wire-speed forwarding between any two ports connected with a category-5 twisted pair cable (crossover or straight-through cable).
· Autosensing at a rate of 10 Mbps, 100 Mbps, or 1000 Mbps.
· Full duplex (typically used) and half duplex operating modes.
Table 133 describes the interface specifications of the HMIM-8GSW, HMIM-24GSW, and HMIM-24GSW-PoE interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 133 Interface specifications
Item |
Connector type |
RJ-45 |
Interface type |
MDI/MDIX |
· 8 (HMIM-8GSW) · 24 (HMIM-24GSW and HMIM-24GSW-PoE) |
Cable type |
Standard (straight-through) Ethernet cable/crossover Ethernet cable |
Operation mode |
Autosensing 10/100/1000 Mbps, full duplex/half duplex |
NOTE: Ethernet interfaces on network adapters are usually medium dependent interfaces (MDIs). Cross medium dependent interfaces (MDIXs) are another type of Ethernet interfaces, which are usually used on hubs and LAN Switches. |
Interface LEDs
Figure 94 HMIM-8GSW panel
Figure 95 HMIM-24GSW panel
Figure 96 HMIM-24GSW-PoE panel
Each 1000 Mbps Ethernet interface on the panel has one LED.
Table 134 LED description
LED status |
Off |
Steady green |
A 1000 Mbps link is present. |
Flashing green |
The port is sending and receiving data at 1000 Mbps. |
Steady yellow |
A 10/100 Mbps link is present. |
Flashing yellow |
The port is sending and receiving data at 10/100 Mbps. |
For more information about the Ethernet interface cables and the connection methods, see "Ethernet interface."
HMIM-8GSWF
Introduction
The 8-port 100/1000 Mbps Ethernet Layer 2/Layer 3 HMIM interface module HMIM-8GSWF provides four SFP fiber ports and four combo interfaces. It is designed for a switching/routing integrated device on a small-sized enterprise network. You can connect it to network devices inside the network.
Functions supported by interface modules are as follows:
· Operating speeds of 1000 Mbps and 100 Mbps.
· Full duplex operating mode.
Table 135 describes the interface specifications of the HMIM-8GSWF interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 135 Interface specifications
Item |
Number of ports |
8 |
Connector type |
SFP/LC/RJ-45 |
· 802.3 · 802.3u · 802.3ab |
Operation mode |
100/1000 Mbps, full duplex |
Interface LEDs
Figure 97 HMIM-8GSWF panel
Table 136 SFP fiber port LED description
LED status |
Off |
Steady green |
Flashing green |
Steady yellow |
A 100 Mbps link is present. |
Flashing yellow |
The port is sending and receiving data at 100 Mbps. |
Table 137 RJ-45 port LED description
LED |
Green LED |
· Off: No link is present. · On: A 1000 Mbps link is present. · Flashing: The port is sending and receiving data at 1000 Mbps. |
Yellow LED |
· Off: No link is present. · On: A100 Mbps link is present. · Flashing: The port is sending and receiving data at 100 Mbps. |
Ethernet interface modules
· HMIM-2GEE
· HMIM-4GEE
· HMIM-8GEE
· RT-HMIM-4GEE-V2
· RT-HMIM-8GEE-V2
· HMIM-2GEF
· HMIM-4GEF
· HMIM-8GEF
· RT-HMIM-4GEF-V2
· RT-HMIM-8GEF-V2
· RT-HMIM-4XP
HMIM-2GEE/HMIM-4GEE/HMIM-8GEE
Introduction
The HMIM-GEE module is used to complete the communication between a router and a LAN, which includes the following types:
· HMIM-2GEE—2-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
· HMIM-4GEE—4-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
· HMIM-8GEE—8-port 10BASE-T/100BASE-TX/1000BASE-T Ethernet copper interface module
The HMIM-2GEE/HMIM-4GEE/HMIM-8GEE supports:
· 100 m (328.08 ft) of transmission distance over a category-5 twisted-pair cable.
· Operation at 10/100/1000 Mbps and autosensing.
· Full duplex and half-duplex, autonegotiation.
Table 138 describes the interface specifications of the HMIM-2GEE, HMIM-4GEE, and HMIM-8GEE interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 138 Interface specifications
Item |
HMIM-2GEE |
HMIM-4GEE |
HMIM-8GEE |
Connector type |
RJ-45 |
2 |
4 |
8 |
Interface type |
MDI/MDIX |
Supported cable |
Ethernet cable |
Operating mode |
· 10/100/1000 Mbps, autosensing · Full duplex/half-duplex, autonegotiation |
Interface LEDs
Figure 98 HMIM-2GEE panel
Figure 99 HMIM-4GEE panel
Figure 100 HMIM-8GEE panel
Table 139 LED description
LED |
Green LED |
Yellow LED |
· Off: No link is present. · On: A 10/100 Mbps link is present. · Flashing: The port is sending and receiving data at 10/100 Mbps. |
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2
CAUTION: The RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The 4/8-port 10Base-T/100Base-TX/1000Base-T Ethernet copper interface module (RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2) is used to complete the communication between a router and a LAN.
The RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2 supports:
Table 140 describes the interface specifications of the RT-HMIM-4GEE-V2 and RT-HMIM-8GEE-V2 interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 140 Interface specifications
Item |
RT-HMIM-4GEE-V2 |
RT-HMIM-8GEE-V2 |
Connector type |
RJ-45 |
4 |
8 |
Interface type |
MDI/MDIX |
Supported cable |
Ethernet cable |
Operating mode |
Interface LEDs
Figure 101 RT-HMIM-4GEE-V2 panel
Figure 102 RT-HMIM-8GEE-V2 panel
Table 141 LED description
LED |
Status |
LINK/ACT |
Green |
A 1000 Mbps link is present on the port. |
Flashing green |
Yellow |
A 10/100 Mbps link is present on the port. |
Flashing yellow |
Off |
No link is present on the port. |
RUN |
Steady green |
The interface module is operating correctly. You cannot remove it. |
Off |
The interface module is not recognized and you can remove it, or the interface module has been removed. |
RT-HMIM-4GEE-V2-G/RT-HMIM-8GEE-V2-G
CAUTION: The RT-HMIM-4GEE-V2-G/RT-HMIM-8GEE-V2-G module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The 4/8-port 10Base-T/100Base-TX/1000Base-T Ethernet copper interface module (RT-HMIM-4GEE-V2-G/RT-HMIM-8GEE-V2-G) is used to complete the communication between a router and a LAN.
The RT-HMIM-4GEE-V2-G/RT-HMIM-8GEE-V2-G supports:
Table 142 describes the interface specifications of the RT-HMIM-4GEE-V2-G and RT-HMIM-8GEE-V2-G interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 142 Interface specifications
Item |
RT-HMIM-4GEE-V2-G |
RT-HMIM-8GEE-V2-G |
Connector type |
RJ-45 |
4 |
8 |
Interface type |
MDI/MDIX |
Supported cable |
Ethernet cable |
Operating mode |
Interface LEDs
Figure 103 RT-HMIM-4GEE-V2-G panel
Figure 104 RT-HMIM-8GEE-V2-G panel
Table 143 LED description
LED |
Status |
LINK/ACT |
Green |
Flashing green |
Yellow |
Flashing yellow |
Off |
RUN |
Steady green |
Off |
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF
Introduction
The HMIM-GEF module is used to complete the communication between a router and a LAN, which includes the following types:
· HMIM-2GEF—2-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
· HMIM-4GEF—4-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
· HMIM-8GEF—8-port 1000BASE-SX/1000BASE-LX Ethernet fiber interface module
The HMIM-2GEF/HMIM-4GEF/HMIM-8GEF supports:
· Operation at 1000 Mbps.
· Full duplex.
Table 144 describes the interface specifications of the HMIM-2GEF, HMIM-4GEF, and HMIM-8GEF interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 144 Interface specifications
Item |
HMIM-2GEF |
HMIM-4GEF |
HMIM-8GEF |
2 |
4 |
8 |
Connector type |
SFP/LC |
Operating mode |
· 1000 Mbps · Full duplex |
Interface LEDs
Figure 105 HMIM-2GEF panel
Figure 106 HMIM-4GEF panel
Figure 107 HMIM-8GEF panel
Table 145 LED description
Status |
Steady green |
Flashing green |
Data is being transmitted and/or received at 1000 Mbps. |
Steady yellow |
Flashing yellow |
Data is being transmitted and/or received at 100 Mbps. |
Off |
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2
CAUTION: The RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The 4/8-port 1000Base-SX/1000Base-LX Ethernet fiber interface module (RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2) is used to complete the communication between a router and a LAN.
The RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2 supports:
· Full duplex.
Table 146 describes the interface specifications of the RT-HMIM-4GEF-V2 and RT-HMIM-8GEF-V2 interface modules. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 146 Interface specifications
Item |
RT-HMIM-4GEF-V2 |
RT-HMIM-8GEF-V2 |
4 |
8 |
Connector type |
SFP/LC |
Operating mode |
Interface LEDs
Figure 108 RT-HMIM-4GEF-V2 panel
Figure 109 RT-HMIM-8GEF-V2 panel
Table 147 LED description
LED |
Status |
LINK/ACT |
Green |
Flashing green |
Yellow |
A 100 Mbps link is present on the port. |
Flashing yellow |
Off |
RUN |
Steady green |
Off |
RT-HMIM-4XP
CAUTION: The RT-HMIM-4XP interface module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The RT-HMIM-4XP is a 10GBASE-R Ethernet interface module that provides four SFP+ ports. Each port is a Layer 3 service port. The RT-HMIM-4XP module supports SFP transceiver modules and 10 Gbps SFP+ transceiver modules.
Table 148 describes the interface specifications of the RT-HMIM-4XP interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 148 Interface specifications
Item |
4 |
Connector |
SFP+/LC |
10GBASE-R |
Interface rate and duplex mode |
1000 Mbps/10 Gbps autosensing, full duplex |
Interface LEDs
Figure 110 RT-HMIM-4XP panel
Table 149 LED description
LED |
Status |
RUN |
Steady green |
The interface module is operating correctly. |
Off |
The interface module has not been recognized or is not present. You can remove the module when the RUN LED is off. |
LINK/ACT |
Steady green |
A 10 Gbps link is present on the port. |
Flashing green (12 Hz) |
Data is being transmitted and/or received at 10 Gbps on the port. |
Steady yellow |
Flashing yellow (12 Hz) |
Data is being transmitted and/or received at 1000 Mbps on the port. |
Off |
· HMIM-1ATM-OC3
HMIM-1ATM-OC3
Introduction
The 1-port ATM (Asynchronous Transfer Mode) 155 Mbps optical interface module (HMIM-1ATM-OC3) provides ATM interfaces for routers and supports the following features:
· Three types of test measures: local cell loopback, local payload loopback, and remote loopback.
Table 150 Interface specifications
Item |
1 |
Connector |
SFP/LC |
· SONET OC-3 · SDH STM-1 |
Operating mode |
155 Mbps |
Interface LEDs
Figure 111 HMIM-1ATM-OC3 panel
Table 151 LED description
LED |
LINK/ACT |
LP/AL |
· On: The interface is in loopback mode. · Off: No loopback or alarm is present. · Flashing: An alarm is present. |
· HMIM-1POS
· RT-HMIM-2POS-STM1
· RT-HMIM-4POS-STM1/4
HMIM-1POS
Introduction
The 1-port SDH/SONET interface module (HMIM-1POS) supports interface rates up to 155.52 Mbps (STM-1/OC-3).
The HMIM-1POS can use the protocols such as PPP, Frame Relay, and HDLC at the data link layer and IP at the network layer. It allows direct transmission of packets over SONET/SDH.
The HMIM-1POS provides 155.52 Mbps fractional interface and supports various types of transceiver modules.
Table 152 Interface specifications
Item |
1 |
Connector type |
SFP/LC |
Interface rate |
155.52 Mbps |
Interface LEDs
Figure 112 HMIM-1POS front panel
Table 153 LED description
LED |
LINK/ACT |
LP/AL |
RT-HMIM-2POS-STM1
CAUTION: The RT-HMIM-2POS-STM1 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The RT-HMIM-2POS-STM1 2-port SDH/SONET interface module provides an interface transmission rate of 155.52 Mbps (STM-1/OC-3).
The RT-HMIM-2POS-STM1 module supports the PPP, Frame Relay, and HDLC protocols at the data link layer and the IP protocol at the network layer. It allows direct transmission of packets over SONET/SDH.
The RT-HMIM-2POS-STM1 module provides 155.52 Mbps fractional interface and supports various types of transceiver modules.
Table 154 Interface specifications
Item |
2 |
Connector type |
SFP/LC |
Interface rate |
155.52 Mbps |
Interface LEDs
Figure 113 RT-HMIM-2POS-STM1 front panel
Table 155 LED description
LED |
Status |
ACT/ALM |
Steady green |
A 155.52 Mbps link is present on the port. |
Flashing green |
Data is being transmitted and/or received at 155.52 Mbps on the port. |
Steady red |
An alarm has occurred on the port. |
Off |
No transceiver module is present on the port or the port is in shutdown state. |
RUN |
Steady green |
Flashing green |
The interface module is upgrading firmware. |
Steady red |
The interface module is faulty. |
Off |
RT-HMIM-4POS-STM1/4
CAUTION: The RT-HMIM-4POS-STM1/4 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The RT-HMIM-4POS-STM1/4 4-port SDH/SONET interface module provides an interface transmission rate of 155.52 Mbps (STM-1/OC-3) or 622.08 Mbps (STM-4/OC-12).
The RT-HMIM-4POS-STM1/4 module supports the PPP, Frame Relay, and HDLC protocols at the data link layer and the IP protocol at the network layer. It allows direct transmission of packets over SONET/SDH.
You can execute the speed command to configure the POS ports on the RT-HMIM-4POS-STM1/4 module to operate at STM-1/OC-3 POS or STM-4/OC-12 POS mode. The operation mode configuration applies to the ports rather than the whole interface module.
Table 156 Interface specifications
Item |
· SONET OC-3/SDH STM-1 · SONET OC-12/SDH STM-4 |
4 |
Connector type |
SFP/LC |
Interface rate |
· 155.52 Mbps · 622.08 Mbps |
Interface LEDs
Figure 114 RT-HMIM-4POS-STM1/4 front panel
Table 157 LED description
LED |
Status |
ACT/ALM |
Steady green |
A 155.52 or 622.08 Mbps link is present on the port. |
Flashing green |
Data is being transmitted and/or received at 155.52 or 622.08 Mbps on the port. |
Steady red |
Off |
RUN |
Steady green |
Flashing green |
Steady red |
Off |
CPOS (SDH/SONET) interface modules
· HMIM-1CPOS
· HMIM-2CPOS
HMIM-1CPOS/HMIM-2CPOS
Introduction
The HMIM-1CPOS/HMIM-2CPOS is a 1-port/2-port channelized SDH/SONET interface module. C stands for channelized, and POS for Packet over SDH/SONET. The HMIM-1CPOS/HMIM-2CPOS provides one/two STM-1/OC3-compliant multi-channel interfaces and supports communication speeds up to 155.52 Mbps.
HMIM-1CPOS/HMIM-2CPOS can change between the E1 system and T1 system.
HMIM-1CPOS is inserted in an HMIM slot of a modular router and communicates with the CPU through the PCI interface to receive and transmit data on STM-1 channelized POS interface. It supports:
· Clear channel (unframed) E1 or T1
· Fractional (framed) E1 or T1
· Up to 256 64 kbps logical channels
Table 158 Interface specifications
Item |
Connector |
SFP/LC |
Number of Connectors |
1 |
Interface rate |
155.52 Mbps |
IMPORTANT: If the interface receives signal over a long-haul optical fiber, make sure the transmission distance is longer than 25 km (15.53 miles). If the transmission distance is shorter than 25 km (15.53 miles), use an optical attenuator to reduce the optical power. |
Interface LEDs
Figure 115 HMIM-1CPOS front panel
Figure 116 HMIM-2CPOS front panel
Table 159 LED description
LED |
LINK/ACT |
LP/AL |
Interface mode switchover
You can switch the HMIM-1CPOS/HMIM-2CPOS to operate in E1 and T1 interface modes at the command line interface (CLI).
To switch the interface mode:
1. Insert the HMIM-1CPOS/HMIM-2CPOS into the HMIM slot of the router and then power on the router.
2. Use the card-mode command in system view to set the interface mode. The HMIM-1CPOS/HMIM-2CPOS module is inserted in slot 4 of the router in the following example.
# Enter system view.
# Set the HMIM-1CPOS/HMIM-2CPOS to operate in E1 interface mode.
[Sysname] module-mode slot 4 e1
# Set the HMIM-1CPOS/HMIM-2CPOS to operate in T1 interface mode.
[Sysname] module-mode slot 4 t1
· HMIM-1E1
· HMIM-2E1
· HMIM-4E1
· HMIM-1E1-F
· HMIM-2E1-F
· HMIM-4E1-F
· HMIM-8E1(75)
· HMIM-8E1(75)-F
· RT-HMIM-2E1-V3
· RT-HMIM-4E1-V3
· RT-HMIM-8E1-V3
· HMIM-2T1
· HMIM-4T1-F
· HMIM-2E1T1
· HMIM-4E1T1
· HMIM-8E1T1
· HMIM-2E1T1-F
· HMIM-4E1T1-F
· HMIM-8E1T1-F
HMIM-1E1/HMIM-2E1/HMIM-4E1/HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F
Introduction
The 1-port channelized E1/PRI interface module (HMIM-1E1), 2-port channelized E1/PRI interface module (HMIM-2E1), and 4-port channelized E1/PRI interface module (HMIM-4E1) transmit, receive, and process E1 data traffic. In addition, you can use these modules for other purposes, such as CE1 access and the ISDN PRI function.
The HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F module is different from the HMIM-1E1/HMIM-2E1/HMIM-4E1 module in the sense that:
· The FE1 operating mode supported by the E1-F modules allows only one n No 64 Kbps bundle to be formed on each interface, where the value range of n is 1 to 31. However, an E1 module allows arbitrary grouping of 31 channels and multiple bundles.
· The E1-F modules do not support PRI mode.
Table 160 Interface specifications
Item |
HMIM-1E1/HMIM-1E1-F |
HMIM-2E1/HMIM-2E1-F |
HMIM-4E1/HMIM-4E1-F |
Connector type |
DB15 |
DB15 |
DB25 |
1 |
2 |
1 |
G.703 and G.704 |
Interface rate |
2.048 Mbps |
Cable type |
· E1 75-ohm unbalanced coaxial cable · E1 120-ohm balanced twisted pair cable · 120-ohm 4E1 conversion cable (only supported by the HMIM-4E1/HMIM-4E1-F) · 75-ohm 4E1 conversion cable (only supported by the HMIM-4E1/HMIM-4E1-F) · Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter (with BNC connector) |
Operating mode |
· E1, CE1, ISDN PRI (only supported by the HMIM-1E1/HMIM-2E1/HMIM-4E1) · FE1 (only supported by the HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F) |
Supported services |
· Backup · Terminal access service · ISDN PRI (only supported by the HMIM-1E1/HMIM-2E1/HMIM-4E1) |
Interface LEDs
Figure 117 HMIM-E1 panel
Figure 118 HMIM-E1-F panel
Figure 119 HMIM-2E1 panel
Figure 120 HMIM-2E1-F panel
Figure 121 HMIM-4E1 panel
Figure 122 HMIM-4E1-F panel
Table 161 LED description
LED |
LINK/ACT |
LP/AL |
· On: The interface is in loopback mode. · Off: No loopback or alarm is present. · Flashing: No cable is connected to the interface, the cable is damaged or not connected correctly, or the peer device is faulty. |
LINK |
· On: A carrier signal is received. · Off: No carrier signal is received. |
ACTIVE |
· Off: No data is being transmitted or received. · Flashing: Data is being received or/and transmitted. |
HMIM-8E1(75)/HMIM-8E1-F(75)
Introduction
The 8-port channelized E1/PRI interface module (HMIM-8E1(75)) transmits, receives, and processes eight channels of E1 data traffic. In addition, you can use the module for other purposes, such as CE1 access and the ISDN PRI function.
The 8-port fractional E1 interface module (HMIM-8E1-F(75)) is different from the HMIM-8E1(75) module in the sense that:
· The FE1 operating mode supported by the HMIM-8E1-F(75) module allows only one n No 64 Kbps bundle to be formed on each interface, where the value range of n is 1 to 31. However, an HMIM-8E1(75) module allows arbitrary grouping of 31 channels and therefore multiple bundles.
· The HMIM-8E1-F(75) module does not support PRI mode.
NOTE: For an HMIM-8E1(75) module, the system automatically creates a serial interface for each timeslot bundle formed on a controller E1 interface. |
Table 162 Interface specifications
Item |
Connector type |
D68 |
1 |
G.703 |
Interface rate |
2.048 Mbps |
Cable type |
75 ohm |
Operating mode |
· E1, CE1, ISDN PRI (only supported by the HMIM-8E1(75)) · FE1 (only supported by the HMIM-8E1-F(75)) |
· Backup · Terminal access service · ISDN PRI (only supported by the HMIM-8E1(75)) |
Interface LEDs
Figure 123 HMIM-8E1(75) panel
Figure 124 HMIM-8E1-F(75) panel
Table 163 LED description
LED |
LINK/ACT |
LP/AL |
RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3
CAUTION: The RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3 module stands for 2/4/8-port channelized CE1/PRI and fractional E1 (E1-F) interface module.
The module provides the following features:
· Channelized CE1/PRI mode—The module allows arbitrary grouping of 31 channels and multiple bundles. It transmits/receives and handles E1 data streams, provides CE1 access, and supports ISDN PRI.
· Unchannelized E1 mode—Interfaces on the module are 2.048 Mbps synchronous serial interfaces without timeslot division.
· Fractional E1 (E1-F) mode—The time slots can only be bundled into one n x 64 kbps channel, where the value range of n is 1 to 31. The module does not support PRI mode.
Table 164 Interface specifications
Item |
RT-HMIM-2E1-V3 |
RT-HMIM-4E1-V3 |
RT-HMIM-8E1-V3 |
Connector type |
RJ-45 |
RJ-45 |
RJ-45 |
2 |
4 |
8 |
G.703 |
Interface rate |
2.048 Mbps |
Cable type |
· E1 120-ohm balanced twisted pair cable: 2 m (6.56 ft), 15 m (49.21 ft), or 30 m (98.43 ft) · E1 75-ohm unbalanced coaxial cable · 75-ohm adapter cable · Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter (with BNC connector) |
Operating mode |
· Unchannelized E1 (G.703) · Channelized E1 (CE1/PRI) · Fractional E1 (E1-F) |
· Backup · Terminal access service · ISDN PRI |
NOTE: The E1 cable after extension supports a maximum transmission distance of 100 m (328.08 ft). |
Interface LEDs
Figure 125 RT-HMIM-2E1-V3 panel
Figure 126 RT-HMIM-4E1-V3 panel
Figure 127 RT-HMIM-8E1-V3 panel
On the panel, each port corresponds to one green LED and one yellow LED. Table 165 describes the LEDs on the panel.
LED |
Status |
LINK/ACT |
Steady green |
A carrier signal has been received. |
Flashing green |
Data is being transmitted or/and received. |
Off |
No carrier signal has been received. |
LP/AL |
Steady yellow |
The interface is in loopback mode. |
Flashing yellow |
Off |
No loopback or alarm is present. |
RUN |
Steady green |
The module is operating correctly. You cannot remove it. |
Off |
The module is not recognized and you can remove it, or the module has been removed. |
Jumper caps
The RT-HMIM-2E1-V3/RT-HMIM-4E1-V3/RT-HMIM-8E1-V3 interface module provides jumper caps, the installation status of which determines the interface impedance. By default, each pin pair is installed with a jumper cap and the impedance of an E1 interface is 75 ohms.
To connect a 120-ohm cable to an E1 interface, remove the jumper caps from the pins corresponding to the interface.
Figure 128 Default installation status of jumper caps (RT-HMIM-8E1-V3 as an example)
Every two interfaces on the interface module correspond to a jumper connector, and the pin settings are the same for the jumper connectors. You can set different impedance modes for the interfaces. For example, an RT-HMIM-8E1-V3 interface module has four jumper connectors, with each jumper connector corresponding to two interfaces. The pins on a jumper connector are numbered PIN1 through PIN14. To set the impedance to 75 ohms for E1 interface 0, install jumper caps on pins 1 and 2, pins 3 and 4, and pins 5 and 6. To connect a 120-ohm cable to the E1 interface, remove the jumper caps from these pins. Table 166 displays the mapping relations between pins on jumper connectors and E1 interfaces.
Table 166 Mapping relations between pins on jumper connectors and E1 interfaces
Jumper connector |
Pins |
E1 interface |
Supported interface modules |
1 |
Pins 1 and 2, pins 3 and 4, pins 5 and 6 |
E1 interface 0 |
RT-HMIM-2E1-V3 RT-HMIM-4E1-V3 RT-HMIM-8E1-V3 |
Pins 7 and 8, pins 9 and 10, pins 11 and 12 |
E1 interface 1 |
Pins 13 and 14 |
Keep the jumper cap in its default installation status |
2 |
E1 interface 2 |
E1 interface 3 |
Pins 13 and 14 |
3 |
E1 interface 4 |
RT-HMIM-8E1-V3 |
E1 interface 5 |
Pins 13 and 14 |
4 |
E1 interface 6 |
RT-HMIM-8E1-V3 |
E1 interface 7 |
Pins 13 and 14 |
HMIM-2T1/HMIM-4T1-F
Introduction
The 2-port channelized CT1/PRI interface module (HMIM-2T1) serves to transmit/receive and handle T1 data streams, provide CT1 access, and fulfill the function of ISDN PRI. Thereby, one module can be used for multiple purposes.
The 4-port fractional T1 interface module (HMIM-4T1-F) is different from the HMIM-CT1 module in the sense that:
· FT1 operating mode supported by T1-F modules allows only one bundle. In other words, the time slots can only be bundled into one n x 64 Kbps/56 Kbps channel, where the value range of n is 1 to 24. However, a CT1 module allows of arbitrary grouping of the 24 channels.
· T1-F does not support PRI mode.
NOTE: For a T1 module, the system automatically creates a serial interface for each timeslot bundle formed on a controller T1 interface. |
Table 167 Interface specifications
Item |
Connector type |
RJ-45 |
· 2 (HMIM-2T1) · 4 (HMIM-4T1-F) |
· G.703/T1 102 · G.704 · AT & T TR 54016 · AT & T TR 62411 · ANSI T1.403 |
Interface rate |
1.544 Mbps |
cable type |
Operating mode |
CT1, ISDN PRI (only supported by the HMIM-2T1) FT1 (only supported by the HMIM-4T1-F) |
· Backup · Terminal access service · ISDN PRI (only supported by the HMIM-2T1) |
Interface LEDs
Figure 129 HMIM-2T1 panel
Figure 130 HMIM-4T1-F panel
Table 168 LED description
LEDs |
LINK/ACT |
· On: A carrier signal is received. · Off: No carrier signal is received. · Flashing: Data is being transmitted or/and received. |
LP/AL |
HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1/HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F
Introduction
· HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module
The 2/4/8-port channelized E1/CE1/T1/CT1/PRI interface module transmits/receives and handles T1 data streams, provides CT1 access, and supports ISDN PRI. The module allows arbitrary grouping of 31 channels.
· HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F module
The 2/4/8-port fractional T1 interface module allows only one bundle. The time slots can only be bundled into one n x 64 Kbps/56 Kbps channel, where the value range of n is 1 to 31. The module does not support PRI mode.
· HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1(-F) jumper settings
You can use command lines and a jumper to configure an interface on the interface module as a 75-ohm E1 interface, 100-ohm T1 interface, or 120-ohm E1 interface. By default, an interface is a 75-ohm E1 interface.
¡ To configure an interface on the interface module as a 75-ohm E1 interface, connect the jumper to pins 1 and 2, pins 7 and 8, pins 11 and 12, and pins 13 and 14.
¡ To configure an interface on the interface module as a 100-ohm T1 or 120-ohm E1 interface, connect the jumper to pins 1 to 3, pins 5 to 7, pins 9 and 10, and pins 11 to 13.
Figure 131 Jumper connecting methods
NOTE: · An interface corresponds to a jumper connector. Pin settings for the jumper connectors are the same. · Each interface comes with four jumper caps. · All interfaces must operate in the same mode. |
Table 169 Interface specifications
Item |
HMIM-2E1T1/ |
HMIM-4E1T1/ |
HMIM-8E1T1/ |
Connector type |
RJ-45 |
RJ-45 |
RJ-45 |
2 |
4 |
8 |
· G.703/G.704 · T1 102 · AT&T TR 54016 · AT&T TR 62411 · ANSI T1.403 |
Interface rate |
· 1.544 Mbps · 2.048 Mbps |
Supported cable |
· E1 75-ohm unbalanced twisted pair cable · E1 120-ohm balanced twisted pair cable · T1 cable (100-ohm shielding network cable) · Coaxial connector, network connector, 75-to-120-ohm adapter (with BNC connector) |
Operating mode |
· E1/T1/CE1T1/ISDN PRI (only supported by the HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module) · FE1T1 (only supported by the HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F module) |
· Backup · Terminal access service · ISDN PRI (only supported by the HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1 module) |
Interface LEDs
Figure 132 HMIM-2E1T1 panel
Figure 133 HMIM-2E1T1-F panel
Figure 134 HMIM-4E1T1 panel
Figure 135 HMIM-4E1T1-F panel
Figure 136 HMIM-8E1T1 panel
Figure 137 HMIM-8E1T1-F panel
Table 170 LED description
LED |
Status |
LINK/ACT |
Steady green |
Flashing green |
Off |
LP/AL |
Steady yellow |
Flashing yellow |
Off |
· HMIM-1CE3
HMIM-1CE3
Introduction
The 1-port channelized E3 interface module (HMIM-1CE3) serves to:
· Transmit/receive and handle one channel of E3 fast traffic, as well as provide the accessing of E3 traffic when operating in E3 mode.
· Provide the low-speed accessing service at the speed of n No 64 kbps, where "n" is smaller than or equal to 128, when operating in CE3 mode.
Table 171 Interface specifications
Item |
Connector type |
SMB |
2 |
G.703, G.704, and G.751 |
Interface rate |
34.368 Mbps |
Cable type |
E3 cable (75-ohm coaxial cable) |
Operating mode |
· E3 · CE3 |
E3 leased line |
Interface LEDs
Figure 138 HMIM-1CE3 panel
Table 172 LED description
LED |
LINK/ACT |
LP/AL |
Serial interface modules
· HMIM-2SAE
· HMIM-4SAE
· HMIM-8SAE
· RT-HMIM-4SAE-V2
· RT-HMIM-8SAE-V2
· HMIM-8ASE
· HMIM-16ASE
· RT-HMIM-8ASE-V2
· RT-HMIM-16ASE-V2
HMIM-2SAE/HMIM-4SAE/HMIM-8SAE
Introduction
The 2-port SAE module (HMIM-2SAE), 4-port SAE module (HMIM-4SAE), and 8-port SAE module (HMIM-8SAE) are enhanced high-speed synchronous/asynchronous serial interface modules. In terms of function, SAE modules are the same as SA modules except that SAE modules support more protocols, for example, RS449, X.21, and RS530.
Table 173 Interface specifications
Item |
Synchronous |
Asynchronous |
Connector type |
D28 |
2 (HMIM-2SAE) 4 (HMIM-4SAE) 8 (HMIM-8SAE) |
Interface standard and operating mode |
V.24 |
V.35, RS449, X.21, and RS530 |
RS-232 |
DTE and DCE |
DTE and DCE |
Minimum baud rate (bps) |
1200 |
1200 |
300 |
Maximum baud rate (bps) |
64000 |
2048000 |
115200 |
cable type |
V.24 DTE cable V.24 DCE cable V.35 DTE cable V.35 DCE cable X.21 DTE cable X.21 DCE cable RS449 DTE cable RS449 DCE cable RS530 DTE cable RS530 DCE cable |
· DDN leased line · Terminal access service |
Interface LEDs
Figure 139 HMIM-2SAE panel
Figure 140 HMIM-4SAE panel
Table 174 LED description
LED |
LINK |
ACT |
Figure 141 HMIM-8SAE panel
On the HMIM-8SAE module, each link corresponds to a LED. The LED state indicates the link state as follows:
· On—A link is present.
· Flashing—Data is being transmitted or received.
· Off—No data is being transmitted or received.
For more information about synchronous/asynchronous serial port cables and the connection methods, see "Synchronous/asynchronous serial ports."
RT-HMIM-4SAE-V2/RT-HMIM-8SAE-V2
CAUTION: The RT-HMIM-4SAE-V2/RT-HMIM-8SAE-V2 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The 4-port SAE module (RT-HMIM-4SAE-V2) and 8-port SAE module (RT-HMIM-8SAE-V2) are enhanced high-speed synchronous/asynchronous serial interface modules. In terms of function, SAE modules are the same as SA modules except that SAE modules support more protocols, for example, RS449, X.21, and RS530.
Table 175 Interface specifications
Item |
Synchronous |
Asynchronous |
Connector type |
D28 |
4 (RT-HMIM-4SAE-V2) 8 (RT-HMIM-8SAE-V2) |
V.24 |
RS-232 |
DTE and DCE |
DTE and DCE |
1200 |
1200 |
300 |
64000 |
2048000 |
115200 |
Cable type |
· Backup · Asynchronous leased line · Terminal access |
Interface LEDs
Figure 142 RT-HMIM-4SAE-V2 panel
Figure 143 RT-HMIM-8SAE-V2 panel
Table 176 LED description
LED |
Status |
RUN |
Steady green |
Off |
LINK/ACT |
Steady green |
Flashing green |
Off |
HMIM-8ASE/HMIM-16ASE
Introduction
The 8-port ASE module (HMIM-8ASE) and the 16-port ASE module (HMIM-16ASE) are enhanced asynchronous serial interface modules that are used to transmit, receive, and handle asynchronous serial interface data streams. ASE modules use RJ-45 connectors and AUX cables.
Table 177 Interface specifications
Item |
HMIM-8ASE |
HMIM-16ASE |
Connector type |
RJ-45 |
8 (HMIM-8ASE) 16 (HMIM-16ASE) |
RS-232 |
cable type |
· AUX cable · Standard (straight-through) Ethernet cable · HMIM-8ASE/HMIM-16ASE dumb terminal cable |
300 |
115.2 k |
· Dialup through a modem · Backup · Terminal access service · Asynchronous leased line service |
Interface LEDs
Figure 144 HMIM-8ASE panel
Figure 145 HMIM-16ASE panel
Each channel on HMIM-8ASE/HMIM-16ASE has only one LED. The LED state indicates the link state as follows:
· Off—No link is present.
RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2
CAUTION: The RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2 module is hot swappable. To remove it, first press and hold the remove button until the RUN LED is off. |
Introduction
The 8-port ASE module (RT-HMIM-8ASE-V2) and the 16-port ASE module (RT-HMIM-16ASE-V2) are enhanced asynchronous serial interface modules that are used to transmit, receive, and handle asynchronous serial interface data streams. ASE modules use RJ-45 connectors and AUX cables.
Table 178 Interface specifications
Item |
RT-HMIM-8ASE-V2 |
RT-HMIM-16ASE-V2 |
Connector type |
RJ-45 |
· 8 (RT-HMIM-8ASE-V2) · 16 (RT-HMIM-16ASE-V2) |
RS-232 |
cable type |
· AUX cable · Standard (straight-through) Ethernet cable · Dumb terminal cable |
300 |
115.2 k |
Interface LEDs
Figure 146 RT-HMIM-8ASE-V2 panel
Figure 147 RT-HMIM-16ASE-V2 panel
Each channel on RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2 has only one LED. The LED state indicates the link state as follows:
· HMIM-1E1POS
· DHMIM-1E1POS1DM
HMIM-1E1POS
Introduction
The HMIM-1E1POS is a 1-port channelized E1 high-density POS access interface module. Each E1 port can deal with incoming calls from 30 POS terminals at the same time. The HMIM-1E1POS is applicable to the bank data transaction center for smart card accounting management.
NOTE: The POS access service is a type of smart card service widely used in places such as shopping malls and gasoline service stations. It links a POS terminal device located in a shopping mall or a gasoline service station to a bank card accounting system to provide services. |
NOTE: · The HMIM-1E1POS uses the PRI voice protocol, but cannot be used for regular voice calling. The voice subscriber lines that the HMIM-1E1POS generates cannot be used as regular voice interfaces, and cannot be bound to the voice entities. · The PRI interface is used for transmitting service data. The interfaces Diag Port0 and Diag Port1 are used only for device debugging. |
Table 179 Interface specifications
Item |
Connector |
RJ-45 |
Number of connectors |
1 |
Cable |
120-ohm standard non-shield cable |
Operating mode |
PRI |
Synchronous mode: · ITU-T-V.22 (PSK/QPSK) · V.22 BIS (QAM) |
POS call in PRI mode |
Interface LEDs
Figure 148 HMIM-1E1POS panel
Table 180 LED description
LED |
LINK/ACT |
· Steady green: A carrier signal is detected. · Flashing green: Data is being received or transmitted. · Off: No carrier signals are detected. |
LP/AL |
· Steady yellow: The interface is in loopback. · Flashing yellow: An alarm is present. · Off: No loopback or alarm is present. |
Interface cable
The HMIM-1E1POS uses the 120-ohm unshielded E1 cable with RJ-45 connecters at both ends.
Figure 149 HMIM-1E1POS interface cable
NOTE: The HMIM-1E1POS does not come with the interface cable. You need to order for the E1 cable. |
CAUTION: · Before connecting a port, read its label carefully. A wrong connection can cause damages to the interface module and even the device. · As a best practice, add a lightning arrester between an interface cable and interface module for better lightning protection when the cable is routed outdoors. |
1. Connect one end of the interface cable to the RJ-45 port on the HMIM-1E1POS.
2. Connect the other end of the interface cable to the peer device.
3. Examine the status of the LINK LED on the HMIM-1E1POS. If the LINK LED is off, examine the cable connection and cable condition.
DHMIM-1E1POS1DM
Introduction
The DHMIM-1E1POS1DM is a 1-port channelized E1 high-density POS access interface module. Each E1 port can deal with incoming calls from 30 POS terminals at the same time. The DHMIM-1E1POS1DM is applicable to the bank data transaction center for smart card accounting management.
The DHMIM-1E1POS1DM can operate as the HMIM-1E1POS or the DHMIM-1DM. When the E1 port of the DHMIM-1E1POS1DM operates in asynchronous mode, you can upgrade the POS device remotely.
NOTE: The PRI interface is used for transmitting service data. The interfaces Diag Port0 and Diag Port1 are used only for device debugging. |
Table 181 Interface specifications
Item |
Connector |
RJ-45 |
1 |
Cable |
120-ohm standard non-shielded cable |
Operation mode |
PRI |
· Synchronous mode: ¡ ITU-T-V.22 (PSK/QPSK) ¡ V.22 BIS (QAM) · Asynchronous mode: ¡ ITU-T V.92 ¡ V.90 ¡ V.34 ¡ V.32 bis ¡ V.32 ¡ V.23 ¡ V.22 bis ¡ V.22 ¡ V.21 ¡ Bell 212a ¡ Bell 103 |
Interface LEDS
Figure 150 DHMIM-1E1POS1DM panel
Table 182 LED description
LED |
LINK/ACT |
· Steady green: The carrier signal is detected. · Flashing green (8 Hz): Data is being received or transmitted. · Off: No carrier signals are detected. |
LP/AL |
· Steady yellow: The interface is in loopback. · Flashing yellow (1 Hz): An alarm is present. · Off: No loopback or alarm is present. |
CAUTION: · As a best practice, add a lightning arrester between an interface cable and interface module for better lightning protection when the cable is routed outdoors. · Before connecting a port, read its label carefully. A wrong connection might cause damages to the interface module and even the device. |
If the interface module has been properly installed, follow these steps to connect the cable:
1. Connect one end of the interface cable to the RJ-45 port on the DHMIM-1E1POS1DM.
3. Examine the status of the LINK LED on the DHMIM-1E1POS1DM. If the LINK LED is off, examine the cable connection and cable condition.
Digital modem interface modules
· DHMIM-1DM
DHMIM-1DM
Introduction
The DHMIM-1DM is a 1-port channelized E1 high-density digital modem interface module. You can upgrade the POS device remotely.
Table 183 Interface specifications
Item |
Connector |
RJ-45 |
1 |
Cable |
Operation mode |
PRI |
Asynchronous mode: · ITU-T V.92 · V.90 · V.34 · V.32 bis · V.32 · V.23 · V.22 bis · V.22 · V.21 · Bell 212a · Bell 103 |
Interface LEDs
Figure 151 DHMIM-1DM panel
Table 184 LED description
LED |
LINK/ACT |
LP/AL |
1. Connect one end of the interface cable to the RJ-45 port on the DHMIM-1DM.
3. Examine the status of the LINK LED on the DHMIM-1DM. If the LINK LED is off, examine the cable connection and cable condition.
Voice interface modules
· HMIM-16FXS
· HMIM-8FXS8FXO
· HMIM-2VE1
· HMIM-2VT1
· HMIM-1VE1
· HMIM-1VT1
· HMIM-4FXS
· HMIM-4FXO
· HMIM-4E&M
HMIM-16FXS
Introduction
The 16-port loop trunk interface module (HMIM-16FXS) serves to access and handle 16 channels of analog voice signals over data communication networks. The module provides 16 FXS interfaces.
FXS interfaces are analog subscriber line interfaces that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges.
Table 185 Interface specifications
Item |
Connector type |
RJ-11 |
Interface standard |
· ITU Q.512-compliant subscriber circuit interface (FXS) · ITU K.20-compliant over-current and over-voltage protection |
Cable type |
Telephone cable with ferrite core |
Dial-up mode |
Bandwidth |
300 to 3400 Hz |
Ringing voltage |
40 V |
Interface LEDs
Figure 152 HMIM-16FXS front panel
Table 186 LED description
LED |
LINK/ACT |
· Steady green: A link is present and a call connection is being established. · Off: No link is present. · Flashing yellow: A link is present and there is a call activity. |
Interface cables and the connection methods
HMIM-8FXS8FXO
Introduction
The 8-port analog subscriber circuit interface module and 8-port voice AT0 loop trunk interface module (HMIM-8FXS8FXO) serve to access and handle 16 channels of analog voice signals over data communication networks. Eight FXS interfaces and eight FXO interfaces are available on an HMIM-8FXS8FXO module:
· FXS interfaces are analog subscriber line interfaces that provide ordinary analog telephone and fax access and also can connect AT0 loop trunks of exchanges;
· FXO interfaces are loop trunk interfaces that provide access of common subscriber lines of exchanges.
When you use the HMIM-8FXS8FXO module in a device, make sure the device has been connected to the IP network or other WAN.
Table 187 Interface specifications
Item |
Connector type |
RJ-11 |
· 8 FXS interfaces · 8 FXO interfaces |
· ITU Q.512-compliant subscriber circuit interface (FXS) · ITU Q.552-compliant loop trunk interface (FXO) · ITU K.20-compliant over-current and over-voltage protection |
Cable type |
Dial-up mode |
Bandwidth |
300 Hz to 3400 Hz |
Ringing voltage |
40 V |
Interface LEDs
Figure 153 HMIM-8FXS8FXO front panel
Table 188 LED description
LED |
LINK/ACT |
· Steady green: The link is being occupied for a call connection. · Off: The link is idle. · Flashing yellow: The link is being occupied for communication. |
HMIM-2VE1
Introduction
The 2-port E1 voice interface module (HMIM-2VE1) can handle dense voice signals in VoIP system. It provides two CE1/PRI/R2 ports, allowing the access of 60 channels of voice signals.
Table 189 Interface specifications
Item |
Connector |
D15 |
2 |
Operating mode |
· CE1 · ISDN PRI · R2 |
Interface rate |
2.048 Mbps |
Cable type |
· E1 75-ohm unbalanced coaxial cable · E1 120-ohm balanced twisted pair cable · Coaxial connector, network interface connector, and 75-to-120-ohm adapter (with BNC connector) |
Supported service |
Interface LEDs
Figure 154 HMIM-2VE1 panel
Table 190 LED description
LED |
LINK/ACT |
· On: A carrier signal is received. · Off: No carrier signal is received. · Flashing: Data is being received and/or transmitted. |
LP/AL |
· On: The interface is in loopback mode. · Off: No loopback or alarm is present. · Flashing: An alarm indication signal (AIS), loss of frame alignment (LFA) signal, or remote alarm indication (RAI) signal is present. |
HMIM-2VT1
Introduction
The 2-port T1 voice interface module (HMIM-2VT1) can handle dense voice signals in VoIP system. It provides two CT1/PRI ports, allowing the access of 48 channels of voice signals.
Table 191 Interface specifications
Item |
Connector |
RJ-45 |
Number of connector |
2 |
· G.703/T1.102 · G.704 · AT & T TR 54016 · AT & T TR 62411 · ANSI T1.403 |
Interface rate |
1.544 Mbps |
Cable type |
T1 cable (100-ohm standard shielded cable) |
Operation mode |
· CT1 · ISDN PRI |
Services |
Interface LEDs
Figure 155 HMIM-2VT1 panel
Table 192 LED description
LED |
LINK/ACT |
LP/AL |
HMIM-1VE1
Introduction
The 1-port E1 voice interface module (HMIM-1VE1) can handle dense voice signals in VoIP system. It provides a CE1/PRI/R2 port, allowing the access of 30 channels of voice signals.
Table 193 Interface specifications
Item |
Connector |
D15 |
1 |
Operating mode |
Interface rate |
2.048 Mbps |
Cable |
· E1 75-ohm unbalanced coaxial cable · E1 120-ohm balanced twisted pair cable · Coaxial connector, network interface connector, and 75ohm-to-120ohm adapter (with BNC connector) |
Supported service |
Interface LEDs
Figure 156 HMIM-1VE1 panel
Table 194 LED description
LED |
LINK/ACT |
LP/AL |
HMIM-1VT1
Introduction
The 1-port T1 voice interface module (HMIM-1VT1) can handle dense voice signals in VoIP system. It provides a CT1/PRI port, allowing the access of 24 channels of voice signals.
Table 195 Interface specifications
Item |
Connector |
RJ-45 |
1 |
Interface rate |
1.544 Mbps |
Cable type |
Operation mode |
· CT1 · ISDN PRI |
Services |
Interface LEDs
Figure 157 HMIM-1VT1 panel
Table 196 LED description
LED |
LINK/ACT |
LP/AL |
HMIM-4FXS/HMIM-4FXO
Introduction
The 4-port voice subscriber circuit interface module (HMIM-4FXS) processes and transmits over data communications networks voice signals for 2/4 regular analog phones, faxes, or AT0 loop trunks of telephone exchanges.
The 4-port voice AT0 analog trunk interface module (HMIM-4FXO) processes and transmits over data communications networks voice signals for 2/4 loops of telephone exchanges.
Table 197 Interface specifications
Item |
Connector |
RJ-45 |
4 |
Cable |
· Telephone cable with ferrite core · E&M trunk cable (only for E&M modules, made on site) |
· ITU Q.512-compliant subscriber circuit interface (HMIM-4FXS) · ITU Q.552-compliant loop trunk interface (HMIM-4FXO) · ITU K.20-compliant over-current and over-voltage protection |
Dial-up mode |
Bandwidth |
300 Hz to 3400 Hz |
Interface LEDs
Figure 158 HMIM-4FXS panel
Figure 159 HMIM-4FXO panel
Table 198 LED description
LED |
LINK |
· On: A link is present. · Off: No link is present. |
ACT |
· On: There is call activity. · Off: The channel is idle. |
For more information about FXS/FXO interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
HMIM-4E&M/HMIM-8E&M
Introduction
The 4/8-port voice E&M analog trunk interface module (HMIM-4E&M/HMIM-8E&M) provides and transmits over data communications networks voice signals for 4/8 E&M analog trunks.
Table 199 Interface specifications
Item |
Connector |
RJ-45 |
· 4 (HMIM-4E&M) · 8 (HMIM-8E&M) |
Cable type |
· G.712-compliant E&M trunk interface (HMIM-4E&M/HMIM-8E&M), E&M interface (supporting Bell type I, II, III, V, and support 2-wire and 4-wire) · ITU K.20-compliant over-current and over-voltage protection |
Dial-up mode |
Bandwidth |
300 Hz to 3400 Hz |
Interface LEDs
Figure 160 HMIM-4E&M panel
Figure 161 HMIM-8E&M panel
Table 200 LED description
LED |
Status |
LINK |
Steady green |
Off |
ACT |
Steady yellow |
There is call activity.. |
Off |
Analog modem modules
· HMIM-6AM
· HMIM-6FCM
HMIM-6AM
Introduction
The 6-port analog modem interface module (HMIM-6AM) provides six channels of user dial-in and dial-out, and provides a connection speed of 56 kbps when ITU-T V.90 is applied. Working with the MSR routers, it provides medium-density RAS functions.
Table 201 Interface specifications
Item |
Connector |
RJ-45 |
6 |
Cable |
Telephone cable |
Interface rate |
56 kbps |
ITU-T V.90, K56flex, V.34 (33.6 kbps), V.FC, V.32 bis, V.32, V.22 bis, V.22A/B, V.23, V.21, Bell 212A a, and Bell 103 |
Supported service |
Dialup through modem |
Interface LEDs
Figure 162 HMIM-6AM panel
LED |
LINK |
· On: A link is present. · Off: No link is present. · Flashing: A link is being established. |
ACT |
· Off: No data is being transmitted or received. · Flashing: Data is being transmitted and/or received. |
For more information about AM interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
HMIM-6FCM
Introduction
The 6-port fast connect modem interface module (HMIM-6FCM) provides POS terminal devices to fast dial up to a bank card accounting system.
NOTE: The POS access service refers to a type of smart card service widely used in places such as shopping malls and gasoline service stations. It links a POS terminal device located in a shopping mall or a gasoline service station to a bank card accounting system to provide services. |
Table 203 Interface specifications
Item |
Connector |
RJ-45 |
6 |
Cable |
ITU-T V.22 |
Interface LEDs
Figure 163 HMIM-6FCM panel
Table 204 LED description
LED |
CD |
ACT |
For more information about FCM interface cables and the connection methods, see "ADSL/BS/FXS/FXO/AM/FCM interface."
Network data encryption modules
HMIM-CNDE-SJK
Introduction
The HMIM-CNDE-SJK (CNDE is the acronym of China Network Data Encryption) supports SM1, SM2, and SM4 encryption algorithms and provides high performance and reliable data encryption features for routers.
Interface LEDs
Figure 164 HMIM-CNDE-SJK panel
Table 205 LED description
LED |
RUN |
· Steady green: The module is operating correctly and is not sending or receiving data. · Flashing green: The module is operating correctly and is sending or receiving data. · Steady yellow: The module is faulty. · Off: The module is not installed securely, or no power is present. |
HMIM adapters
· HMIM-Adapter
· HMIM-Adapter-H
HMIM-Adapter/HMIM-Adapter-H
Introduction
The HMIM-Adapter/HMIM-Adapter-H is designed for MIM-to-HMIM conversions. Some MIMs can operate as HMIMs with an HMIM-Adapter/HMIM-Adapter-H adapter installed. For the MIM-to-HMIM conversion relations, see "Appendix B Purchase guide."
Figure 165 HMIM-Adapter view
Figure 166 HMIM-Adapter-H view
VPM modules
VPM purchase guide
· The HMIM-1VE1/HMIM-1VT1 module provides a voice processing module (VPM) slot. The HMIM-2VE1/HMIM-2VT1 module provides two VPM slots. Each VPM slot is installed with a VPM when the HMIM-1VE1/HMIM-1VT1 module or HMIM-2VE1/HMIM-2VT1 module is shipped from the factory.
· The main board of the MSR 36-20 router provides a VPM slot. The main boards of the MSR 36-40, MSR 36-60, MSR 56-60, and MSR 56-80 routers provide two VPM slots. The routers do not provide VPMs when shipped from the factory. The number and specifications of VPMs needed depend on the number of calls.
· The SIC-1VE1/SIC-1VT1 module does not provide any VPM slot, and can only use the VPMs installed on the main board of MSR.
· The MIM-1VE1/MIM-1VT1 module provides a VPM slot, and the MIM-2VE1/MIM-2VT1 module provides two VPM slots. No VPM is installed when the MIM-1VE1/MIM-1VT1 or MIM-2VE1/MIM-2VT1 module is shipped from the factory.
· The MIM-1VE1/MIM-1VT1 module must be used with VPM installed. The number of VPMs needed depends on the number of calls.
· Because the initiator of a three-party conference is responsible for audio mixing, so when using MSR as the initiator of a three-party conference, the main board of MSR must have VPM installed.
Introduction
The voice processing module (VPM) functions encoding/decoding, echo cancellation (EC) and comfortable noise generation (CNG) of voices.
Table 206 Interface specifications
Item |
Number of calls supported |
· 8 · 16 · 24 · 32 · 128 · 256 · 512 |
XMIM interface modules
CAUTION: · XMIM interface modules can be hot-swapped, with the exception of those with a remove button. To remove an XMIM SIC interface module with a remove button while the device is operating, first press and hold the remove button until the RUN LED is off. · For the hot swapping of XMIM interface module, do not install an XMIM interface module during an active/standby MSU switchover. To view the status of dual MSUs, execute the display system stable state command in any view. To remove an XMIM while the device is operating, verify that the RUN LED on the module is steady green. |
· RT-XMIM-8GEE-R
· RT-XMIM-8GEF-R
· RT-XMIM-4XP
RT-XMIM-8GEE-R
The RT-XMIM-8GEE-R is an 8-port GE copper port interface module. It is mainly used for communication between the router and LAN.
The RT-XMIM-8GEE-R has the following features:
· Provides a transmission distance of up to 100 m (328.08 ft) when used with category-5 twisted-pair cables.
· The interfaces can operate at a data rate of 10 Mbps, 100 Mbps, or 1000 Mbps and support data rate auto-sensing.
· Supports half-/full-duplex auto-negotiation.
The following table describes the interface specifications of the RT-XMIM-8GEE-R interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 207 Interface specifications
Item |
Connector type |
RJ-45 |
8 |
Interface type |
MDI/MDIX |
802.3/802.3u/802.3ab |
Cable |
Straight-through and crossover Ethernet cable |
Operating mode |
10/100/1000 Mbps autosensing Half/full-duplex auto-negotiation |
Front panel and LEDs
The RT-XMIM-8GEE-R front panel is as shown in the following figure.
Figure 167 RT-XMIM-8GEE-R front panel
The following table describes the LEDs on the RT-XMIM-8GEE-R front panel.
Table 208 LED description
LED |
Status |
LINK/ACT |
Green LED: On |
A link is present on the interface and the interface is operating in 1000 Mbps mode |
Green LED: Flashing |
The interface is transmitting or receiving data, and is operating in 1000 Mbps mode. |
Yellow LED: On |
A link is present on the interface and the interface is operating in 10 or 100 Mbps mode. |
Yellow LED: Flashing |
The interface is transmitting or receiving data, and is operating in 10 or 100 Mbps mode. |
Off |
RUN |
Steady green |
Flashing green (8 Hz) |
The interface module is being identified. |
Flashing green (1 Hz) |
The device has successfully identified the interface module and has begun initializing the interface module. |
Steady yellow |
The interface module has failed to complete initialization. |
Off |
The interface module has not been identified or has been removed. |
Interface cables and connection methods
For information about the Ethernet interface cables and connection methods, see "Ethernet interface."
RT-XMIM-8GEF-R
The RT-XMIM-8GEF-R is an 8-port GE fiber port interface module. It is mainly used for communication between the router and LAN.
The RT-XMIM-8GEF-R has the following features:
· Supports multiple types of transceiver modules, providing the flexibility for users to select the transceiver modules that meet their specific needs.
· The interfaces can operate at a data rate of 100 Mbps or 1000 Mbps and support data rate auto-sensing.
The following table describes the interface specifications of the RT-XMIM-8GEF-R interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 209 Interface specifications
Item |
Interface quantity |
8 |
Connector type |
SFP/LC |
Operating mode |
100/1000 Mbps auto-sensing Half/full-duplex auto-negotiation |
The RT-XMIM-8GEF-R front panel is as shown in the following figure.
Figure 168 RT-XMIM-8GEF-R front panel
The interface module provides a LED at the bottom of the front panel for each LED.
Table 210 RT-XMIM-8GEF-R LED description
LED |
Status |
LINK/ACT |
Steady green |
A link is present on the interface and the interface is operating in 1000 Mbps mode. |
Flashing green |
Steady yellow |
A link is present on the interface and the interface is operating in 100 Mbps mode. |
Flashing yellow |
The interface is transmitting or receiving data, and is operating in 100 Mbps mode. |
Off |
No link is present on the interface. |
RUN |
Steady green |
Steady yellow |
Off |
Transceiver modules, optical fibers, and connection methods
For more information about the transceiver modules, optical fibers, and connection methods, see "Fiber port."
RT-XMIM-4XP
The RT-XMIM-4XP is a 10GBASE-R Ethernet interface module that provides four SFP+ ports. Each port is a Layer 3 service port. The interface module supports port type switching between standard Ethernet and FlexE. The FlexE mode allows flexible bandwidth assignment to meet different service requirements.
The following table describes the interface specifications of the RT-XMIM-4XP interface module. For information about link mode of the interfaces, see "Link mode of interfaces on Ethernet switching modules and interface modules."
Table 211 Interface specifications
Item |
4 |
Connector type |
SFP+/LC |
10GBASE-R |
Operating mode |
1000 Mbps/10 Gbps auto-sensing, full duplex |
The RT-XMIM-4XP front panel is as shown in the following figure.
Figure 169 RT-XMIM-4XP front panel
Table 212 RT-XMIM-4XP LED description
LED |
Status |
LINK/ACT |
Steady green |
A link is present on the interface and the interface is operating in 10 Gbps mode. |
Flashing green |
The interface is transmitting or receiving data, and is operating in 10 Gbps mode. |
Steady yellow |
Flashing yellow |
Off |
RUN |
Steady green |
Steady yellow |
Off |
· RT-XMIM-1POS
· RT-XMIM-2POS
RT-XMIM-1POS/RT-XMIM-2POS
Introduction
The RT-XMIM-1POS/RT-XMIM-2POS is a 1/2-port packet over SDH/SONET (POS) XMIM interface module. The transmission rates of the modules are STM-1/OC-3 (155.52 Mbit/s) and STM-4/OC-12 (622.08 Mbit/s).
The RT-XMIM-1POS/RT-XMIM-2POS module supports PPP, frame relay, and HDLC at the data link layer and IP at the network layer. Interfaces on the RT-XMIM-1POS/RT-XMIM-2POS implements direct packet transmission over SONET/SDH.
Follow these restrictions and guidelines when using the RT-XMIM-1POS/RT-XMIM-2POS interface module:
· You can use the line-card-mode command to set the POS interfaces on the interface module to operate in STM-1/OC-3 POS mode or STM-4/OC-12 POS mode.
· The setting of the POS interface-operating mode is applicable to the entire interface module, rather than being specific to an individual interface.
The following table describes the interface specifications of the RT-XMIM-1POS/RT-XMIM-2POS interface module.
Table 213 RT-XMIM-1POS, RT-XMIM-2POS, and RT-XMIM-4POS interface specifications
Item |
RT-XMIM-1POS |
RT-XMIM-2POS |
1 |
2 |
Connector type |
SFP/LC |
Interface speed |
155.52 Mbps, 622.08 Mbps |
CAUTION: When the RT-XMIM-2POS interface module is configured to operate in STM-4/OC-12 POS mode, only the interface marked 0 on the front panel is available, while the other interfaces are not available. |
The T-XMIM-1POS and RT-XMIM-2POS front panels are as shown in the following figure.
Figure 170 RT-XMIM-1POS front panel
Figure 171 RT-XMIM-2POS front panel
The following table describes the LEDs on the front panel.
Table 214 RT-XMIM-1POS/RT-XMIM-2POS LED description
LED |
Status |
ACT/ALM |
Steady green |
A link is present on the port. |
Flashing green |
The interface is receiving or sending data. |
Steady yellow |
A transceiver module has been installed in the interface, while an alarm is present on the interface. |
Off |
No transceiver module has been installed in the interface. |
RUN |
Steady green |
The interface module is being identified, or the firmware is being updated. |
Steady yellow |
Off |
RT-XMIM-1CPOS
Introduction
The RT-XMIM-1CPOS is a 1-port channelized SDH/SONET interface module. C stands for channelized, and POS for Packet over SDH/SONET. The RT-XMIM-1CPOS provides an interface transmission rate of 155.52 Mbps (STM-1/OC-3).
The following table describes the interface specifications of the RT-XMIM-1CPOS interface module.
Table 215 RT-XMIM-1CPOS interface specifications
Item |
SONET OC-3/SDH STM-1 |
1 |
Connector type |
SFP/LC |
Interface speed |
155.52 Mbps |
The RT-XMIM-1CPOS front panel is as shown in the following figure.
Figure 172 RT-XMIM-1CPOS front panel
Table 216 RT-XMIM-1CPOS LED description
LED |
Status |
RUN |
Steady green |
The interface module is being identified or the firmware is being updated. |
Steady yellow |
Off |
ACT/ALM |
Steady green |
Flashing green |
Steady yellow |
Off |
E1 interface modules
· RT-XMIM-2E1
· RT-XMIM-4E1
· RT-XMIM-8E1
RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1
When the RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 interface module changes to the fractional E1 (E1-F) mode, the interface module name displayed from the command output on the device will be changed to RT-XMIM-2E1-F/RT-XMIM-4E1-F/RT-XMIM-8E1-F accordingly.
Introduction
The RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 is a 2/4/8-port XMIM module that can operate in channelized E1 (CE1/PRI) mode or fractional E1 (E1-F) mode.
· In channelized E1 (CE1/PRI) mode, the module can group the 31 channels in multiple ways to achieve different bundling configurations. Its primary function is to receive, transmit, and process E1 data streams while also providing CE1 access. In addition, it supports also ISDN PRI. These features enable multiple purposes to be achieved on a single module.
· In non-channelized E1 mode, the module functions as a synchronous serial port with a data bandwidth of 2.048 Mbps and no timeslot division.
· In fractional E1 (E1-F) mode, the module can only be bundled once (into a single channel with a speed of n × 64K, where n = 1 to 31), and does not support PRI mode.
The following table describes the interface specifications of the module.
Table 217 RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 interface specifications
Item |
RT-XMIM-2E1 |
RT-XMIM-4E1 |
RT-XMIM-8E1 |
Connector type |
RJ-45 |
RJ-45 |
RJ-45 |
2 |
4 |
8 |
G.703 |
Interface speed |
2.048 Mbps |
Cable |
E1 120-ohm balanced twisted-pair cable (2m,15m, 30m) E1 75-ohm unbalanced coaxial cable 75-ohm 8E1 repeater cable Coaxial connector, network interface connector, and 75-ohm to 120-ohm adapter (with BNC connector) |
Operating mode |
Non-channelized E1(G.703) Channelized E1 (CE1/PRI) Fractional E1 (E1-F) |
Backup Endpoint access service ISDN PRI |
The RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 front panels are as shown in the following figures.
Figure 173 RT-XMIM-2E1 module front panel
Figure 174 RT-XMIM-4E1 module front panel
Figure 175 RT-XMIM-8E1 module front panel
The module provides a green and a yellow LED for each interface.
Table 218 RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 LED description
LED |
Status |
LINK/ACT (green) |
Steady green |
Carrier signals are received. |
Flashing green |
The interface is sending or receiving data. |
Off |
No carrier signals are received. |
LP/AL (yellow) |
Steady yellow |
The interface is in a loopback state. |
Flashing yellow |
The interface does not have a cable connected, the cable is faulty, or the peer device is faulty. |
Off |
RUN |
Steady green |
Steady yellow |
Off |
Jumper caps
The RT-XMIM-2E1/RT-XMIM-4E1/RT-XMIM-8E1 interface module provides jumper caps, the installation status of which determines the interface impedance. By default, each pin pair is installed with a jumper cap and the impedance of an E1 interface is 75 ohms.
Figure 176 Default installation status of jumper caps (RT-XMIM-8E1 as an example)
Every two interfaces on the interface module correspond to a jumper connector, and the pin settings are the same for the jumper connectors. You can set different impedance modes for the interfaces. For example, an RT-XMIM-8E1 interface module has four jumper connectors, with each jumper connector corresponding to two interfaces. The pins on a jumper connector are numbered PIN1 through PIN14. To set the impedance to 75 ohms for E1 interface 0, install jumper caps on pins 1 and 2, pins 3 and 4, and pins 5 and 6. To connect a 120-ohm cable to the E1 interface, remove the jumper caps from these pins. Table 219 displays the mapping relations between pins on jumper connectors and E1 interfaces.
Table 219 Mapping relations between pins on jumper connectors and E1 interfaces
Jumper connector |
Pins |
E1 interface |
1 |
E1 interface 0 |
RT-XMIM-2E1 RT-XMIM-4E1 RT-XMIM-8E1 |
E1 interface 1 |
Pins 13 and 14 |
2 |
E1 interface 2 |
E1 interface 3 |
Pins 13 and 14 |
3 |
E1 interface 4 |
RT-XMIM-8E1 |
E1 interface 5 |
Pins 13 and 14 |
4 |
E1 interface 6 |
RT-XMIM-8E1 |
E1 interface 7 |
Pins 13 and 14 |
For more information about E1 interface cables and the connection methods, see "E1 interface.”
RT-XMIM-CNDE-SJK
Introduction
RT-XMIM-CNDE-SJK is an SCA SM encryption XMIM module. It supports SM1, SM3, and SM4 encryption algorithms, providing high-performance and high-reliability encryption features for routers.
Interface LEDs
Figure 177 RT-XMIM-CNDE-SJK panel
Table 220 RT-XMIM-CNDE-SJK LED description
LED |
Status |
RUN |
Steady green |
Flashing yellow (8 Hz) |
The interface module resource is being released. |
Steady green |
Off |
· The interface module has not been identified or has been removed. · The interface module can be removed. |
SSD modules
CAUTION: The RT-SSD-960G SSD module can be hot-swapped. To remove an RT-SSD-960G SSD module on an operating device, first press and hold the remove button until the RUN LED is off. |
RT-SSD-960G
Introduction
The RT-SSD-960G is a 960GB SSD module, which is mainly used for storage services.
Table 221 Interface specifications
Item |
Connector |
SATA |
Capacity |
960 GB |
Interface rate |
3 Gbps |
Interface LEDs
Figure 178 RT-SSD-960G panel
Table 222 LED description
LED |
Status |
RUN |
Steady green |
The module is operating correctly. |
Flashing green (eight times per second) |
The module is being identified. |
Flashing yellow (eight times per second) |
The module resource is being released. |
Steady yellow |
The module has failed to complete initialization. |
Off |
· The module has not been identified or has been removed. · The module can be removed. |
Cables and the connection methods
Ethernet interface
Ethernet cable appearance and applicable models
Table 223 Ethernet cable appearance and applicable models
Appearance |
Applicable models |
1 × RJ-45 < ---- > 1 × RJ-45 |
SIC-4FSW SIC-4FSWP SIC-4GSW RT-SIC-4GSW-G DSIC-9FSW DSIC-9FSWP SIC-1FEA SIC-1GEC-V2 SIC-AP220 HMIM-8GSW HMIM-24GSW HMIM-24GSW-PoE HMIM-2GEE HMIM-4GEE HMIM-8GEE RT-HMIM-4GEE-V2 RT-HMIM-8GEE-V2 RT-HMIM-4GEE-V2-G RT-HMIM-8GEE-V2-G HMIM-1E1POS DHMIM-1DM DHMIM-1E1POS1DM RT-XMIM-8GEE-R |
10/100 Mbps Ethernet uses category-5 twisted pair cables, and 1000 Mbps Ethernet uses category-5 enhanced or category-6 twisted pair cables. Twisted pair cables include straight-through cables and crossover cables.
Category-5 cables provide a transmission frequency of 100 MHz for voice and data transmission; they are mainly used in 100BASE-T and 10BASE-T networks. Category-5 cables are common Ethernet cables, which can also be used to transmit 1000 Mbps Ethernet data.
Category-5 enhanced cables feature low attenuation and crosstalk, providing higher attenuation to crosstalk ratio (ACR), less delay error and higher performance than category-5 cables. Category-5 enhanced cables are mainly used in 1000 Mbps Ethernet networks.
Category-6 cables provide a transmission frequency of 1 MHz to 250 MHz, and improve the performance on crosstalk and return loss. A fine better return loss performance is extremely important for new-generation full-duplex high-speed networks. Category-6 cables have sufficient power sum ACR (PS-ACR) when working at 200 MHz. They provide a bandwidth two times than that of category-5 enhanced cables, thus featuring a higher transmission performance. Therefore, category-6 cables are suitable for applications requiring a transmission speed of more than 1 Gbps.
The 10/100 Mbps Ethernet uses two pairs of cables, orange/white, orange, green/white and green cables, to transmit and receive data, while the 1000 Mbps Ethernet uses four pairs of cables to transmit and receive data.
For the pinouts of common twisted pair cables, see the following tables. (A and B represent the two ends of a cable respectively.)
Table 224 Straight-through cable pinouts
Pinout No. |
A |
B |
1 |
Orange/white |
Orange/white |
2 |
Orange |
Orange |
3 |
Green/white |
Green/white |
4 |
Blue |
Blue |
5 |
Blue/white |
Blue/white |
6 |
Green |
Green |
7 |
Brown/white |
Brown/white |
8 |
Brown |
Brown |
Table 225 Crossover cable pinouts
Pinout No. |
A |
B |
1 |
Orange/white |
Green/white |
2 |
Orange |
Green |
3 |
Green/white |
Orange/white |
4 |
Blue |
Blue |
5 |
Blue/white |
Blue/white |
6 |
Green |
Orange |
7 |
Brown/white |
Brown/white |
8 |
Brown |
Brown |
NOTE: Strictly follow the pinouts in the above tables when identifying or making the two types of Ethernet cables; otherwise, the communication quality may be affected. |
Connecting an Ethernet cable
1. Connect one end of an Ethernet cable to an Ethernet interface on the module and the other end to the Ethernet interface on the peer device. Because the Ethernet interface of the module supports MDI/MDIX autosensing, you can use a straight-through cable or crossover cable to connect the interface.
2. Check the status of the LED of the Ethernet interface after power-on. For the status of the LED, see the relevant part in this manual.
Fiber port
Appearances and applicable models of transceiver modules and optical fibers
Optical interfaces must work with SFP or SFP+ transceiver modules and optical fibers with LC connectors. For more information about interface module and transceiver module compatibility, see H3C MSR Router Series Transceiver Module Compatibility Matrix.
Connecting an optical fiber
CAUTION: · Never stare into an open optical Ethernet interface, because invisible rays may be emitted from the optical Ethernet interface. · Cover the dust cover if no optical fiber connector is connected to the optical Ethernet interface. |
To connect an optical fiber:
1. Insert the transceiver module to the interface on the interface module or service module.
2. Identify the Rx and Tx ports on the transceiver module. Plug the LC connector at one end of one fiber cable into the Rx port of the router and the LC connector at the other end into the Tx port of the peer device. Plug the LC connector at one end of another fiber cable into the Tx port of the router and the LC connector at the other end to the Rx port of the peer device.
3. View the LINK LED after connection.
¡ If the LED is on, the optical fiber link is present.
¡ If the LED is off, no link is present. This may be because the TX and Rx port of the optical fiber are not connected correctly. In this case, connect the optical fiber again.
E1 interface
To verify the impedance value of the E1 cable, view the label on the cable. The label location in Figure 179 is for illustration only.
E1 cable appearance and applicable models
Table 226 E1 cable appearance and applicable models
Cable |
Appearance |
Applicable models |
1-port E1 75-ohm cable |
1 × D15 < ---- > 2 × BNC |
SIC-E1-F SIC-1EPRI MIM-1E1 MIM-1E1-F MIM-2E1 MIM-2E1-F HMIM-1E1 HMIM-1E1-F HMIM-2E1 HMIM-2E1-F SIC-1VE1 MIM-1VE1 MIM-2VE1 HMIM-1VE1 HMIM-2VE1 |
1-port E1 120-ohm cable |
1 × D15 < ---- > 1 × RJ-45 |
1-port E1 120-ohm cable (2 m, 15 m, 30 m)-RJ-45 |
RT-HMIM-2E1-V3 RT-HMIM-4E1-V3 RT-HMIM-8E1-V3 HMIM-2E1T1 HMIM-4E1T1 HMIM-8E1T1 HMIM-2E1T1-F HMIM-4E1T1-F HMIM-8E1T1-F SIC-1VE1T1 RT-SIC-2E1-G RT-XMIM-2E1 RT-XMIM-4E1 RT-XMIM-8E1 |
2-port E1 75-ohm cable |
1 × D15 < ---- > 4 × BNC |
SIC-2E1-F |
4-port E1 75-ohm cable |
1 × D25 < ---- > 4 × D15 |
MIM-4E1 MIM-4E1-F HMIM-4E1 HMIM-4E1-F |
4-port E1 120-ohm cable |
8-port E1 75-ohm cable |
1 × D68 < ---- > 16 × BNC |
MIM-8E1 MIM-8E1-F HMIM-8E1(75) HMIM-8E1(75)-F |
1-port E1 75-ohm cable-RJ-45 |
75-ohm adapter cable |
1 × BNC < ---- > 1 × BNC |
Use as needed |
Coaxial connector |
Use as needed |
Impedance converter |
2 × BNC < ---- > 1 × RJ-45 |
Use as needed |
Dual inline package switch
E1 / E1-F / VE1 interface module provides a dual inline package (DIP) switch. The DIP switch setting defines the interface impedance and the grounding method.
Table 227 DIP switch-to-interface map
DIP switch |
E1 interface |
Applicable models |
S1 |
Interface 0 |
MIM-1E1 MIM-1E1-F MIM-2E1 MIM-2E1-F MIM-4E1 MIM-4E1-F HMIM-1E1 HMIM-1E1-F HMIM-2E1 HMIM-2E1-F HMIM-4E1 HMIM-4E1-F SIC-1VE1 MIM-1VE1 MIM-2VE1 HMIM-1VE1 HMIM-2VE1 |
S2 |
Interface1 |
MIM-1E1 MIM-1E1-F MIM-2E1 MIM-2E1-F MIM-4E1 MIM-4E1-F HMIM-1E1 HMIM-1E1-F HMIM-2E1 HMIM-2E1-F HMIM-4E1 HMIM-4E1-F MIM-2VE1 HMIM-2VE1 |
S3 |
Interface2 |
S4 |
Interface3 |
By default, all DIP switches are ON, and the E1 interface impedance is 70 ohms, as shown in the following figure:
Figure 180 Default DIP switch settings
H3C recommends that you use the DIP switch as follows: When the interface is connected to a 70-ohm cable, turn on switches BIT1 through 8; when the interface is connected to a 120-ohm cable, turn off switches BIT1 through 8. Description for DIP switch settings is shown in the following table:
Table 228 Description for DIP switch settings
DIP |
Configuration of 75-ohm impedance |
Configuration of 120-ohm impedance |
1BIT |
75-ohm/120-ohm selection switch |
ON |
Off |
2BIT |
ON |
Off |
3BIT |
ON |
Off |
4BIT |
ON |
Off |
5BIT |
ON |
Off |
6BIT |
RxRing grounding mode selection switch |
Off: RxRing is grounded via capacitance. ON: RxRing is grounded directly. |
N/A |
7BIT |
RxShield grounding mode selection switch |
N/A |
ON: RxShield is grounded. Off: RxShield is not grounded. |
8BIT |
SxShield grounding mode selection switch |
N/A |
Off: RxShield is grounded via capacitance ON: RxShield is grounded directly. |
Connecting a 1/2/8-port E1 75-ohm cable (D15/D68 <----> BNC)
CAUTION: Make sure you insert the cable into the right interface so as to avoid damages to the interface module or the chassis. |
· If you do not need to extend the cable, you can directly connect the BNC connectors of the E1 75-ohm cable to the remote network device as follows:
a. Connect the D15/D68 connector of the E1 75-ohm cable to the D15/D68 interface of the interface module and fasten the bolts to fix the cable.
b. The other end of the cable provides one pair or multiple pairs of 75-ohm BNC connectors. Connect the TX connectors and the RX connectors on this end to the RX connectors and the TX connectors on the remote device respectively.
Figure 181 Connect an E1 75-ohm cable
· If you want to extend the cable, connect each BNC connector of the E1 75-ohm cable to one end of a coaxial connector, and connect the remote device to the other end of the coaxial connector through an E1 75-ohm adapter cable.
Figure 182 Connect an E1 75-ohm cable
· If the impedance of the E1 interface on the remote device is 120 ohms, you must use an impedance converter to adapt the impedance.
Figure 183 Connect an impedance converter
Connecting a 4-port E1 75-ohm cable (D25 <----> D15)
1. Connect the D25 connector of the 4-port E1 75-ohm cable to the D25 interface of the interface module and fasten the bolts to fix the cable.
2. The other end of the cable provides four D15 connectors. Connect them to the D15 interfaces on the remote device as needed.
Figure 184 Connect an 4-port E1 75-ohm cable
Connecting a 1-port E1 120-ohm cable (D15 <----> RJ-45)
1. Connect the D15 connector of the E1 120-ohm cable to the D15 interface on the interface module and fasten the bolts to fix the cable.
2. The other end of the cable provides one or multiple RJ-45 connectors. Connect them to the RJ-45 interface on the remote device as needed.
Figure 185 Connecting an E1 120-ohm cable
Table 229 DB15 to BNC/RJ-45 pinouts
DB15 |
BNC (75-ohm coaxial cable) |
RJ-45 (120-ohm twisted pair cable) |
9 |
Tx Tip |
Tx Tip |
4 |
Tx Tip |
2 |
Tx Ring |
Tx Ring |
5 |
Tx Ring |
10 |
Tx Shield |
N/A |
6 |
Tx Shield |
8 |
Rx Tip |
Rx Tip |
1 |
Rx Tip |
15 |
Rx Ring |
Rx Ring |
2 |
Rx Ring |
7 |
Rx Shield |
N/A |
3 |
Rx Shield |
Connecting a 4-port E1 120-ohm cable (D25 <----> D15)
1. Connect the D25 connector of the 4-port E1 120-ohm cable to the D25 interface on the interface module and fasten the bolts to fix the cable.
2. The other end of the cable provides four D15 connectors. Connect them to the D15 interface on the remote device as needed.
Figure 186 Connecting a 4-port E1 120-ohm cable
T1 interface
CAUTION: To avoid damages to the interface module or the chassis, make sure you insert the cable into the right interface. |
T1 cable appearance and applicable models
Table 230 T1 cable appearance and applicable models
Cable |
Appearance |
Applicable models |
1-port T1 cable (100- ohm standard shielded cable) |
SIC-T1-F MIM-2T1 MIM-4T1-F HMIM-2T1 HMIM-4T1-F SIC-1VT1 SIC-1VE1T1 MIM-1VT1 MIM-2VT1 HMIM-1VT1 HMIM-2VT1 HMIM-2E1T1 HMIM-4E1T1 HMIM-8E1T1 HMIM-2E1T1-F HMIM-4E1T1-F HMIM-8E1T1-F |
RJ-45 connector |
Use as needed |
Connecting a 1-port T1 cable
The two ends of the 1-port T1 cable are RJ-45 connectors. Connect one end of the cable to the T1 connector (RJ-45) of the interface module and the other end of the cable to the T1 connector (RJ-45) on the remote device.
Connecting a 4/8-port T1 cable
· Connect the D68 connector of the 4/8-port T1 cable to the D68 interface on the interface module and fasten the bolts to fix the cable.
· The other end of the cable provides four or eight RJ-45 connectors. Connect them to the RJ-45 interface on the remote device as needed.
E3/T3 interface
E3/T3 cable appearance and applicable models
Table 231 E3/T3 cable appearance and applicable models
Cable |
Appearance |
Applicable models |
E3/T3 interface cable |
1 × BNS < ---- > 1 × SMB |
MIM-1CE3 HMIM-1CE3 |
Connecting the cable
1. Connect the SMB connector of an E3/T3 cable to the Tx port on the interface module and the other end to the Rx port on the device to be connected.
2. Connect the SMB connector of another E3/T3 cable to the Rx port of interface module and the other end to the Tx port on the device to be connected;
3. Check the LINK LED on the module panel. It is off when fault has occurred on the link and signal is out of synchronization. In this case, check the link.
Appearance and applicable models of synchronous/asynchronous serial port cables
Table 232 Appearance and applicable models of synchronous/asynchronous serial port cables
Cable |
Appearance |
Applicable models |
1 × D25 (male) < ---- > 1 × D28 |
SIC-1SAE SIC-2SAE SIC-4SAE MIM-2SAE MIM-4SAE MIM-8SAE HMIM-2SAE HMIM-4SAE HMIM-8SAE RT-HMIM-4SAE-V2 RT-HMIM-8SAE-V2 |
1 × D25 (female) < ---- > 1 × D28 |
1 × D28 < ---- > 1 × D34 (male) |
1 × D28 < ---- > 1 × D34 (female) |
1 × D15 (male) < ---- > 1 × D28 |
1 × D15 (female) < ---- > 1 × D28 |
1 × D28 < ---- > 1 × D37 (male) |
1 × D28 < ---- > 1 × D37 (female) |
1. Check port type of the peer device and choose the synchronous serial interface cable of correct type.
2. Plug the D28 end of the synchronous serial interface cable into the D28 interface of the SAE interface module.
3. If the WAN uses DDN line, connect the cable to the port of CSU/DSU.
4. Check the LINK LED on the SAE panel.
¡ If the LED is on, a link is present.
¡ If the LED is off, a fault has occurred on the link and signal is out of synchronization. In this case, check the link.
Asynchronous serial ports
Appearance and applicable models of asynchronous serial port cables
Table 233 Appearance and applicable models of asynchronous serial port cables
Cable |
Appearance |
Applicable models |
8-port asynchronous serial port adapter cable |
1 × D60 < ---- > 8 × RJ-45 (female) |
SIC-8AS |
4-port asynchronous serial port adapter cable |
1 × D28 < ---- > 4 × RJ-45 (female) |
SIC-16AS |
Serial server cable |
MIM-8ASE MIM-16ASE HMIM-8ASE HMIM-16ASE RT-HMIM-8ASE-V2 RT-HMIM-16ASE-V2 |
Dumb terminal adapter cable |
1 × RJ-45 (female) < ---- > 1 × RJ-45 (male) |
AUX cable |
1 × D25 & 1 × D9 < ---- > 1 × RJ-45 |
Dumb terminal adapter |
1 × D25 < ---- > 1 × RJ-45 |
Console cable |
1 × DB-9 < ---- > 1 × RJ-45 |
SIC-AP220 SIC-AP320 |
Connecting a SIC-8AS/SIC-16AS interface module
To connect the SIC-8AS interface module, connect the D60 connector of the 8-port asynchronous serial port adapter cable to the SIC-8AS interface module.
To connect the SIC-16AS interface module, connect the D28 connector of the 4-port asynchronous serial port adapter cable to the SIC-16AS interface module, which allows up to four such cables.
Choose the cable connection type according to the remote device type:
· If the remote device is a network device with a console port, connect the console port to the RJ-45 interface of the asynchronous serial port adapter cable by using a serial server cable. The sequence is shown in the following figure:
Figure 187 Connecting a network device
· If the remote device is a bank dumb terminal device, connect the RJ-45 connector (male) on one end of the dumb terminal cable to the RJ-45 interface on the asynchronous serial port adapter cable. Connect the RJ-45 connector (female) on the other end of the dumb terminal cable to the RJ-45 interface on one end of the dumb terminal adapter by a straight-through cable. The other end of the dumb terminal adapter is a D25 interface and can be connected to the bank dumb terminal device. The sequence is shown in the following figure:
Figure 188 Connecting the dumb terminal device
· If the interface of the remote device, usually a modem, is a D25/D9 interface, use the AUX cable to connect the asynchronous serial port adapter cable to the interface:
Figure 189 Connecting a modem
Connecting a MIM-8ASE/MIM-16ASE/HMIM-8ASE/HMIM-16ASE/RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2 interface module
WARNING! To avoid damage to the device and the ports, do not plug or unplug the MIM-8ASE/MIM-16ASE module interface cable when the router is powered on. |
· If the remote device is a network device with a console port, connect the console port to the RJ-45 interface of the interface module by using a serial server cable. The sequence is shown in the following figure:
Figure 190 Connecting a network device
· If the remote device is a bank dumb terminal device, connect the RJ-45 connector (male) on one end of the dumb terminal cable to the RJ-45 interface on the interface module. Connect the RJ-45 connector (female) on the other end of the dumb terminal cable to the RJ-45 interface on one end of the dumb terminal adapter by a straight-through cable. The other end of the dumb terminal adapter is a D25 interface and can be connected to the bank dumb terminal device. The sequence is shown in the following figure:
Figure 191 Connecting a bank dumb terminal device
· If the interface of the remote device, usually a modem, is a D25/D9 interface, use the AUX cable to connect the RJ-45 interface on the interface module. The sequence is shown in the following figure:
Figure 192 Connecting a modem
Connecting a SIC-AP220/SIC-AP320 WLAN interface module
To connect the interface module to a configuration terminal (for example, a PC) through the serial console cable:
1. Connect the DB-9 female connector of the console cable to the serial port of the PC
2. Connect the RJ-45 connector to the console port on the module.
To disconnect the console cable, remove the RJ-45 connector end first.
Appearance and applicable models of the magnetic-core telephone cable
Table 234 Appearance and applicable models of magnetic-core telephone cable
Cable |
Appearance |
Applicable models |
Magnetic-core telephone cable |
1 × RJ-11 < ---- > 1 × RJ-11 |
SIC-1ADSL SIC-1ADSL-I SIC-1BS SIC-2BS SIC-1FXS SIC-1FXO SIC-2FXS SIC-2FXO SIC-2FXS1FXO DSIC-4FXS1FXO SIC-1AM SIC-2AM MIM-4FXS MIM-4FXO MIM-16FXS MIM-8FXS8FXO HMIM-4FXS HMIM-4FXO HMIM-16FXS HMIM-8FXS8FXO HMIM-6AM HMIM-6FCM |
Connecting an ADSL/FXS/FXO/AM/FCM interface module
1. Connect one end of the magnetic-core telephone cable to the RJ-11 or RJ-45 interface of the interface module.
2. Connect the other end of the magnetic-core telephone cable to the remote device interface.
Connecting a BS/BU interface module cable
1. If the service provider provides an ISDN U interface cable, you must use an NT1 device for adaptation. Connect one end of the magnetic-core telephone cable to the RJ-45 interface of the SIC-1BS interface module. Connect the other end of the magnetic-core telephone cable to the S/T interface of the NT1 device. Connect the ISDN U interface cable to the U interface on the NT1 device.
Figure 193 Connecting the U interface cable to the SIC-1BS interface module
2. If the service provider provides an ISDN S/T interface cable, directly connect the cable to the RJ-45 interface of the SIC-1BS interface module.
Figure 194 Connecting the S/T interface cable to the SIC-1BS interface module
E&M interface
E&M interface appearance and the applicable model
MIM-4E&M and FIC-4E&M modules support Bell I, II, III, V switches, and 2-wire & 4-wire voice signals.
As a best practice, use Bell V 4-wire voice signal to communicate with the router in practice.
The sequence of E&M RJ-45 pins is shown in the following figure, numbered 1 to 8 from left to right:
Figure 195 Sequence of RJ-45 pins
Table 235 Pinouts of E&M interface cable (Bell V 4-wire)
E&M interface |
RJ-45 Pin |
Signal |
Signal direction |
1 |
2 |
E |
IN |
3 |
RING0 |
IN |
4 |
RING1 |
OUT |
5 |
TIP1 |
OUT |
6 |
TIP0 |
IN |
7 |
M |
OUT |
8 |
SG |
Ground |
NOTE: Because the 4E&M modules cannot determine the interface types (Bell I/II/III/V), cable types (2-wire or 4-wire), and pinouts (E/M/Tx/Rx) of the peer switch, you must prepare the interface cables of the 4E&M modules according to the on-site conditions. To ensure the EMC of the router, install a ferrite core near the connector of the E&M module interface cable at the router side. |
The connection method
BSV/BSE interface
BSV/BSE interface cable appearance and applicable models
Table 236 BSV/BSE interface cable appearance and applicable models
Cable |
Appearance |
Applicable models |
ISDN S/T interface standard cable |
SIC-1BSV SIC-2BSV |
ISDN S/T interface crossover cable |
SIC-1BSV SIC-2BSV |
Connecting a SIC-1BSV / SIC-2BSV / MIM-4BSV interface module cable
BSV interface supports the User and Network operating modes. The BSV interface works in User mode when connecting to an ISDN network, or works in Network mode when connecting to TE devices such as the digital telephones or the BSV interfaces working in User mode.
Choose the cable connection type according to the operating mode:
· When the BSV interface works in User mode, choose the connection method according to the type of the cable provided by the service provider:
¡ If the service provider provides an ISDN U interface cable, you must use an NT1 device for adaptation. Connect one end of the standard ISDN S/T interface cable to the RJ-45 interface of the BSV interface module. Connect the other end of the standard ISDN S/T interface cable to the S/T interface of the NT1 device. Connect the ISDN U interface cable to the U interface on the NT1 device.
Figure 196 Connecting a service provider U interface cable to a BSV interface module
¡ If the service provider provides an ISDN S/T interface cable, directly connect the service provider cable to the BSV interface.
Figure 197 Connecting a service provider S/T interface cable to a BSV interface module
· When the BSV interface works in Network mode, you must use an ISDN S/T interface crossover cable to connect the BSV interface to a TE device such as a digital telephone or a BSV interface working in User mode:
Connect the RJ-45 connector (male) of the ISDN S/T interface crossover cable to the RJ-45 interface on the BSV interface module. Connect the RJ-45 interface (female) of the standard ISDN S/T interface cable to one end of the standard ISDN S/T interface cable. Connect the S/T interface on the TE device to the other end of the standard ISDN S/T interface cable.
Figure 198 Connecting a TE device to a BSV interface module
3G interface
Appearance and applicable models of the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Table 237 Appearance and applicable models of the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Antenna and cable |
Appearance |
Applicable models |
Antenna |
SIC-3G-CDMA SIC-3G-TD SIC-3G-HSPA |
AUX cable |
Table 238 The detailed specifications for the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
Item |
Frequency scope |
824-960 MHz / 1710-2170 MHz |
Voltage standing wave ratio |
≤ 2 |
Input impedance |
50 ohms |
Gain |
1.5 dBi |
Polarization type |
Vertical |
Maximum input power |
10 W |
TNC-Male |
Lightning protection |
Direct current grounding |
Height |
153 mm (6.02 in) |
Weight |
26 g (0.92 oz) |
Length |
None |
Color |
Black |
Operating temperature |
–30 °C to +60 °C (–22°F to +140°F) |
Connecting a SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface module antenna
1. To install an antenna, adjust the angle of the antenna to 180º.
2. Fasten the antenna onto the antenna port that has a MAIN mark. Avoid over-tightening. Make sure the antenna is vertical to the ground or ceiling to achieve the optimal coverage.
Connecting a SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA interface debug antenna
To debug and test the SIC-3G-CDMA/SIC-3G-TD/SIC-3G-HSPA, connect the RJ-45 interface of the AUX cable to the Diag Port interface and connect the D25/D9 connector to a peer device, which is usually a PC.
4G interface
Appearance and applicable models of 4G antennas and extension cables
Table 239 Appearance and applicable models of the 4G antennas and extension cables
Antenna and cable |
Appearance |
Applicable models |
4G antenna |
SIC-4G-LTE-M |
4G antenna |
SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK |
4G antenna |
RT-SIC-4G-CAT6 |
4G antenna extension cable |
RT-SIC-4G-CAT6 |
Table 240 Antenna specifications
Item |
Specification |
SIC-4G-LTE-M |
RT-SIC-4G-CAT6 |
Frequency scope |
698 to 960 MHz 1.71 to 2.7 GHz |
791 to 960 MHz 1710 to 2690 MHz |
617 to 960 MHz 1400 to 1612 MHz 1710 to 2170 MHz 2300 to 2700 MHz 3300 to 3800 MHz 4400 to 5000 MHz 5150 to 5850 MHz |
2.5 |
≤ 3.5 |
≤ 4 |
Input impedance |
50 ohms |
50 ohms |
50 ohms |
Gain |
2 dBi |
791 to 960 MHz @ 3.1 dBi 1710 to 2690 MHz @ 7.2dBi |
617 to 960 MHz/0.59 dBi 1400 to 1612 MHz/1.87 dBi 1710 to 2170 MHz/3.74 dBi 2300 to 2700 MHz/3.51 dBi 3300 to 3800 MHz/3.7 dBi 4400 to 5000 MHz/4.0 dBi 5150 to 5850 MHz/4.87 dBi |
Polarization type |
Vertical |
Vertical |
Vertical |
5 W |
1 W |
1 W |
TNC |
SMA |
SMA, male |
Height |
21.4 cm (8.43 in) |
16.6 cm (6.54 in) |
20.3 cm (7.99 in) |
Weight |
50.5 g (1.78 oz) |
22 g (0.78 oz) |
19.63 g (0.69 oz) |
Color |
Black |
Black |
Black |
–40°C to +85°C (–40°F to +185°F) |
–10°C to +60°C (14°F to 140°F) |
–20°C to +60°C (–4°F to +140°F) |
Table 241 4G antenna extension cable specifications for the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK module
Item |
Specification |
Frequency scope |
698 to 960 MHz 1710 to 2700 MHz |
≤ 2.0 |
Input impedance |
50 ohms |
Gain |
2.0 dBi |
Polarization type |
Vertical |
SMA |
Height |
16.4 ± 0.2 cm (6.46 ± 0.08 in) |
Weight |
134 ± 5 g (4.73 ± 0.18 oz) |
Color |
Black |
Cable length |
200 ± 2 cm (78.74 ± 0.79 in) |
–40°C to +60°C (–40°F to +140°F) |
Table 242 4G antenna extension cable specifications for the RT-SIC-4G-CAT6 module
Item |
Specification |
Frequency range |
DC to 6 GHz |
≤ 5 |
Input impedance |
50 ohms |
Cable type |
RG-174 |
Max input power |
1 W |
SMA |
Cable length |
3000 mm (118.11 in) |
Weight |
65.3 g (2.30 oz) |
Color |
Black |
Connection methods of 4G antennas and antenna extension cables
For how to install a 4G antenna and antenna extension cable for the SIC-4G-LTE-M, SIC-4G-CNDE, SIC-D4G-CNDE, SIC-4G-CNDE-SJK, or SIC-D4G-CNDE-SJK module, see H3C MSR 4G SIC Modules SIM Card&Antenna&Antenna Extension Cable Installation Guides.
For how to install a 4G antenna and antenna extension cable for the RT-SIC-4G-CAT6 module, see H3C MSR 4G SIC-4G-CAT6 Module SIM Card&Antenna&Antenna Extension Cable Installation Guides.
Installing a 4G interface debugging antenna
A 4G interface module has a Mini USB port to connect to the peer device through the USB console cable for third-party software to debug the 4G interface module. When the interface module is operating correctly, you do not need to connect the USB console cable.
To debug a 4G interface module, connect the port at one end of the USB console cable to the peer device (PC), and connect the other end to the Mini USB port on the interface module.
5G interface
Appearance and applicable models of stick antennas and antenna extension cables
Table 243 Appearance and applicable models of the antennas and extension cables
Name |
Appearance |
Applicable models |
Stick antenna A |
RT-SIC-5G RT-SIC-5G-CN |
Stick antenna B |
3 m (9.84 ft) antenna extension cable (with a magnetic antenna mount base) |
1 m (3.28 ft) antenna extension cable (with a magnetic antenna mount base) |
10 cm (3.94 in) cable |
5 m (16.40 ft)/10 m (32.81 ft) antenna extension cable |
Antenna bracket |
Table 244 Stick antenna A specifications
Item |
Frequency range |
698 to 960 MHz 1710 to 2170 MHz 2300 to 2700 MHz 3300 to 3800 MHz 4400 to 5000 MHz 5150 to 5850 MHz |
≤ 4 |
Input impedance |
50 ohms |
Gain |
617 MHz to 960 MHz, 0.59 dBi 1710 MHz to 2170 MHz, 3.74 dBi 2300 MHz to 2700 MHz, 3.51 dBi 3300 MHz to 3800 MHz, 3.7 dBi 4400 MHz to 5000 MHz, 4.0 dBi 5150 MHz to 5850 MHz, 4.87 dBi |
Polarization type |
Vertical |
1 W |
SMA male |
Height |
203 mm (7.99 in) |
Weight |
19.63 g (0.69 oz) |
Color |
Black |
–20 °C to +65 °C (–4°F to +149°F) |
Table 245 Stick antenna B specifications
Item |
Frequency range |
0.6 to 6 GHz |
≤ 6 |
Input impedance |
50 ohms |
Gain (max.) |
2.74 dBi @ 0.617 to 0.96 GHz 1.01 dBi @ 1.4 to 1.612 GHz 4.48 dBi @ 1.71 to 2.17 GHz 3.98 dBi @ 2.3 to 2.7 GHz 4.74 dBi @ 3.3 to 4.0 GHz 5.50 dBi @ 4.0 to 5.0 GHz 5.82 dBi @ 5.15 to 5.85 GHz |
Polarization type |
Vertical |
1 W |
SMA male |
Height |
17.6 cm (6.93 in) |
Weight |
20 g (0.71 oz) |
Color |
Black |
–20°C to +70°C (–4°F to +158°F) |
Table 246 3 m (9.84 ft) antenna extension cable (with a magnetic antenna mount base) specifications
Item |
Specification |
Frequency range |
DC to 6 GHz |
≤ 5 |
Input impedance |
50 ohms |
Cable type |
RG-174 |
Max input power |
1 W |
SMA |
Cable length |
Weight |
65.3 g (2.30 oz) |
Color |
Black |
Table 247 1 m (3.28 ft) antenna extension cable (with a magnetic antenna mount base) specifications
Item |
Specification |
Frequency range |
DC to 6 GHz |
≤ 1.7 |
Input impedance |
50 ohms |
Cable type |
RG-174 |
SMA |
Cable length |
1 m (3.28 ft) |
Weight |
202 g (7.13 oz) |
Color |
Black |
Table 248 10 cm (3.94 in) antenna extension cable specifications
Item |
Specification |
Frequency range |
DC to 6 GHz |
≤ 1.2 @ (3 GHz) ≤ 1.4 @ (3 to 6 GHz) |
Input impedance |
50 ohms |
Cable type |
RG-174 |
SMA |
Cable length |
10 cm (3.94 in) |
Color |
Black |
Table 249 5 m (16.40 ft) antenna extension cable specifications
Item |
Specification |
Frequency range |
DC to 6 GHz |
< 1.2 @ (0.3 to 2.4 GHz) < 1.4 @ (5 to 6 GHz) |
Input impedance |
50 ohms |
Cable type |
RG8 |
SMA |
Cable length |
5 m (16.40 ft) |
Color |
White |
Table 250 10 m (32.81 ft) antenna extension cable specifications
Item |
Specification |
Frequency range |
DC to 6 GHz |
≤ 1.2 @ (2.4 GHz) ≤ 1.5 @ (5 to 6 GHz) |
Input impedance |
50 ohms |
Cable type |
RG8 |
SMA |
Cable length |
10 m (32.81 ft) |
Color |
White |
Connection methods of stick antennas and antenna extension cables
Different antenna configuration schemes and installation methods are used depending on the required antenna extension cable length and application scenario. For more information, see H3C MSR 5G SIC Modules SIM Card&Antenna&Antenna Extension Cable Installation Guides.
GPS interface
Appearance and applicable models of the SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK interface module GPS antenna
Table 251 Appearance and applicable models of the 4G interface module GPS antenna
Antenna |
Appearance |
Applicable models |
GPS antenna |
SIC-4G-CNDE SIC-D4G-CNDE SIC-4G-CNDE-SJK SIC-D4G-CNDE-SJK |
Table 252 Antenna specifications
Item |
Specification |
Frequency scope |
1575.42 ± 3 MHz |
≤ 1.92 |
Input impedance |
50 ohms |
Gain |
1.5 dBic Typ |
Echo return loss |
10 dB Min |
SMA |
Extension cable length |
5 m (16.40 ft) |
Extension cable type |
RG-174 Coaxial Cable |
Color |
Black |
–30°C to +80°C (–22°F to +176°F) |
Connecting an antenna extension cable
1. Fasten the SMA connector onto the GPS antenna port on the module.
2. Put the other end of the extension cable outdoor to achieve better signal coverage.
GNSS interface
Appearance and applicable models of the RT-SIC-4G-CAT6 module GNSS antenna
Table 253 Appearance and applicable models of the RT-SIC-4G-CAT6 module GNSS antenna
Antenna |
Appearance |
Applicable models |
GNSS antenna |
RT-SIC-4G-CAT6 |
Table 254 RT-SIC-4G-CAT6 module GNSS antenna specifications
Item |
Specification |
Frequency scope |
· 1561±3 MHz · 1575.42±3 MHz · 1602±0.5 MHz |
Operating mode |
· GPS · GLONASS · BDS · Galileo |
Input impedance |
50 ohms |
Gain |
–2.91 dBic Typ |
SMA male |
5 m (16.40 ft) |
RG-174 coaxial cable |
Color |
Black |
Connecting a GNSS antenna
1. Fasten the SMA male connector of the antenna extension cable onto the GNSS antenna port on the module.
2. Connect the other end of the extension cable to the antenna. Place the antenna outdoors for better signal receipt.
WLAN interface
Appearance and applicable models of the WLAN interface module antenna
Table 255 Appearance and applicable models of the WLAN interface module antenna
Antenna |
Appearance |
Applicable models |
WLAN interface module antenna |
Connecting a WLAN interface module antenna
1. Unfold the antenna.
2. Attach the antenna to the antenna connector on the interface module. To avoid damage, do not over-tighten the antenna.
3. Fold the antenna to a 90-degree angle so that it is vertical to the ground or ceiling to achieve optimal coverage.
An interface can operate in bridge or route link mode. You can use the port link-mode command to change the link mode of an interface. Interfaces that operate in bridge mode are called Layer 2 interfaces. Interfaces that operate in route mode are called Layer 3 interfaces.
Some interfaces on Ethernet switching modules and interface modules can operate only as Layer 3 interfaces, as shown in Table 256. Some interfaces operate as Layer 2 interfaces by default but can be changed to Layer 3 interfaces by using the port link-mode command, as shown in Table 257.
IMPORTANT: · Interfaces on the SIC-4GSW or RT-SIC-4GSWF interface module can operate only in route link mode (Layer 3 interface mode) when the interface module is installed on an MSR3600-28-G-DP or MSR3600-51-G-DP router. · By default, the nine Ethernet interfaces on the DSIC-9FSW and DSIC-9FSWP interface modules operate in bridge mode. You can execute the port link-mode command to change the operating mode of any four interfaces to route. The remaining five interfaces can operate only in bridge mode. · When the SIC-4FSW, SIC-4FSWP, DSIC-9FSW, or DSIC-9FSWP interface module is installed on an MSR2600-10 or MSR2600-17 router, you can change the operating mode of any two interfaces to route. The remaining interfaces can operate only in bridge mode. · When the SIC-4FSW, SIC-4FSWP, DSIC-9FSW, or DSIC-9FSWP interface module is installed on other routers than MSR2600-10 and MSR2600-17 routers, you can change the operating mode of any four interfaces to route. The remaining interfaces can operate only in bridge mode. · For the interface module compatibility with router models, see "Appendix B Purchase guide." |
Table 256 Ethernet interfaces that can operate only as Layer 3 interfaces
Ethernet switching module/Ethernet interface module |
Interfaces that can operate only as Layer 3 interfaces |
SIC-4FSW |
N/A |
SIC-4FSWP |
N/A |
DSIC-9FSW |
N/A |
DSIC-9FSWP |
N/A |
SIC-4GSW |
N/A |
RT-SIC-4GSWF |
N/A |
SIC-1FEA |
FE0 |
SIC-1FEF |
SFP0 |
RT-SIC-4GSW-G |
GE0 to GE3 |
RT-SIC-4GSWF-G |
GE0 to GE3 |
RT-SIC-1XPF-G |
GE0 |
SIC-1GEC-V2 |
Combo 0 (GE0, SFP0) |
HMIM-8GSW |
N/A |
HMIM-24GSW |
N/A |
HMIM-24GSW-PoE |
N/A |
HMIM-8GSWF |
N/A |
HMIM-2GEE |
GE0 and GE1 |
HMIM-4GEE |
GE0 to GE3 |
HMIM-8GEE |
GE0 to GE7 |
RT-HMIM-4GEE-V2 |
GE0 to GE3 |
RT-HMIM-8GEE-V2 |
GE0 to GE7 |
RT-HMIM-4GEE-V2-G |
GE0 to GE3 |
RT-HMIM-8GEE-V2-G |
GE0 to GE7 |
HMIM-2GEF |
SFP0 and SFP1 |
HMIM-4GEF |
SFP0 to SFP3 |
HMIM-8GEF |
SFP0 to SFP7 |
RT-HMIM-4GEF-V2 |
SFP0 to SFP3 |
RT-HMIM-8GEF-V2 |
SFP0 to SFP7 |
RT-HMIM-4XP |
SFP+0 to SFP+3 |
RT-XMIM-8GEE-R |
GE0 to GE7 |
RT-XMIM-8GEF-R |
SFP0 to SFP7 |
RT-XMIM-4XP |
SFP+0 to SFP+3 |
Interfaces that operate as Layer 2 interfaces by default and can be changed to Layer 3 interfaces |
SIC-4FSW |
FE0 to FE3 |
SIC-4FSWP |
FE0 to FE3 |
DSIC-9FSW |
Any four interfaces |
DSIC-9FSWP |
SIC-4GSW |
GE0 to GE3 |
RT-SIC-4GSWF |
SFP0 to SFP3 |
SIC-1FEA |
N/A |
SIC-1FEF |
N/A |
RT-SIC-4GSW-G |
N/A |
RT-SIC-4GSWF-G |
N/A |
SIC-1GEC-V2 |
N/A |
RT-SIC-1XPF-G |
N/A |
HMIM-8GSW |
GE0 to GE5, Combo 6 (GE6, SFP6), Combo 7 (GE7, SFP7) |
HMIM-24GSW |
GE0 to GE23 |
HMIM-24GSW-PoE |
GE0 to GE23 |
HMIM-8GSWF |
SFP0 to SFP3, Combo 4 (GE4, SFP4), Combo 5 (GE5, SFP5), Combo 6 (GE6, SFP6), Combo 7 (GE7, SFP7) |
HMIM-2GEE |
N/A |
HMIM-4GEE |
N/A |
HMIM-8GEE |
N/A |
RT-HMIM-4GEE-V2 |
N/A |
RT-HMIM-8GEE-V2 |
N/A |
RT-HMIM-4GEE-V2-G |
N/A |
RT-HMIM-8GEE-V2-G |
N/A |
HMIM-2GEF |
N/A |
HMIM-4GEF |
N/A |
HMIM-8GEF |
N/A |
RT-HMIM-4GEF-V2 |
N/A |
RT-HMIM-8GEF-V2 |
N/A |
RT-HMIM-4XP |
N/A |
RT-XMIM-8GEE-R |
N/A |
RT-XMIM-8GEF-R |
N/A |
RT-XMIM-4XP |
N/A |
Frequency bands for 3G/4G/5G interface modules
IMPORTANT: Support for each frequency band varies by mobile communication modem module model used by the interface module. The following tables are for your reference only. |
Table 258 Frequency bands for 3G/4G/5G interface modules (1)
Interface module |
CDMA |
GSM |
LTE-TDD |
LTE-FDD |
SIC-3G-CDMA |
CDMA1x: BC0 |
N/A |
N/A |
N/A |
SIC-4G-LTE-M |
CDMA1x: BC0 |
B2/B3/B5/B8 |
B38/B39/B40/B41 |
B1/B3/B5/B7/B8 |
SIC-4G-CNDE |
CDMA1x: BC0 |
B2/B3/B5/B8 |
B38/B39/B40/B41 |
B1/B3/B5/B7/B8 |
SIC-D4G-CNDE |
CDMA1x: BC0 |
B2/B3/B5/B8 |
B38/B39/B40/B41 |
B1/B3/B5/B7/B8 |
RT-SIC-4G-CAT6 |
N/A |
N/A |
B38/B40/B41 |
B1/B3/B5/B7/B8/B20/B28/B32 |
RT-SIC-5G |
N/A |
N/A |
B34/B38/B39/B40/B41/B42/B43/B48 |
B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/B18/B19/B20/B25/B26/B28/B29/B30/B32/B66/B71 |
RT-SIC-5G-CN |
N/A |
N/A |
B34/B38/B39/B40/B41 |
B1/B2/B3/B5/B7/B8/B20/B28 |
Table 259 Frequency bands for 3G/4G/5G interface modules (2)
Interface module |
TD-SCDMA |
WCDMA |
5G NR |
LAA |
SIC-3G-CDMA |
N/A |
N/A |
N/A |
N/A |
SIC-4G-LTE-M |
B34/B39 |
B1/B8 |
N/A |
N/A |
SIC-4G-CNDE |
B34/B39 |
B1/B8 |
N/A |
N/A |
SIC-D4G-CNDE |
B34/B39 |
B1/B8 |
N/A |
N/A |
RT-SIC-4G-CAT6 |
N/A |
B1/B3/B5/B8 |
N/A |
N/A |
RT-SIC-5G |
N/A |
B1/B2/B3/B4/B5/B8/B19 |
NSA: n38/n41/n71/n77/n78/n79 SA: n1/n2/n3/n5/n7/n8/n12/n20/n25/n28/n38/n40/n41/n48/n66/n71/n77/n78/n79 |
B46 |
RT-SIC-5G-CN |
N/A |
B1/B2/B5/B8 |
NSA: n41/n78/n79 SA: n1/n28/n41/n77/n78/n79 |
N/A |
Interface module net weights and power consumption
Table 260 Interface module net weights and power consumption
Interface module model |
Net weight |
Min power consumption |
Max power consumption |
DSIC-9FSW |
N/A |
N/A |
3.20 W |
DSIC-9FSWP |
N/A |
N/A |
3.20 W |
SIC-4GSW |
0.10 kg (0.22 lb) |
N/A |
3.80 W |
RT-SIC-4GSWF |
0.10 kg (0.22 lb) |
N/A |
4.20 W |
RT-SIC-4GSW-G |
0.10 kg (0.22 lb) |
2.30 W |
3.91 W |
RT-SIC-4GSWF-G |
0.23 kg (0.51 lb) |
1.88 W |
3.97 W |
SIC-1GEC-V2 |
0.10 kg (0.22 lb) |
N/A |
0.80 W |
RT-SIC-1XPF-G |
0.10 kg (0.22 lb) |
10.42 W |
10.43 W |
RT-SIC-1POS-STM1 |
0.10 kg (0.22 lb) |
N/A |
8.40 W |
SIC-E1-F |
0.10 kg (0.22 lb) |
N/A |
0.40 W |
SIC-2E1-F |
0.10 kg (0.22 lb) |
N/A |
0.40 W |
RT-SIC-2E1-G |
0.15 kg (0.33 lb) |
2.74 W |
2.98 W |
SIC-8AS |
0.10 kg (0.22 lb) |
N/A |
3.40 W |
SIC-16AS |
0.10 kg (0.22 lb) |
N/A |
0.80 W |
SIC-1SAE |
N/A |
N/A |
0.42 W |
SIC-2SAE |
N/A |
N/A |
3.40 W |
SIC-4SAE |
N/A |
N/A |
3.40 W |
SIC-4RS |
0.10 kg (0.22 lb) |
0.72 W |
1.00 W |
SIC-2FXS |
N/A |
N/A |
2.00 W |
SIC-2FXO |
N/A |
N/A |
2.00 W |
SIC-2FXS1FXO |
N/A |
N/A |
2.40 W |
SIC-1VE1T1 |
0.15 kg (0.33 lb) |
N/A |
4.00 W |
SIC-3G-CDMA |
N/A |
N/A |
3.40 W |
SIC-3G-TD |
N/A |
N/A |
3.40 W |
SIC-3G-HSPA |
N/A |
N/A |
3.40 W |
SIC-4G-LTE-M |
0.20 kg (0.44 lb) |
N/A |
5.00 W |
SIC-4G-CNDE |
0.15 kg (0.33 lb) |
N/A |
4.20 W |
SIC-D4G-CNDE |
0.10 kg (0.22 lb) |
3.41 W |
6.60 W |
SIC-CNDE |
N/A |
N/A |
5.50 W |
SIC-CNDE-SJK |
N/A |
N/A |
5.50 W |
SIC-4G-CNDE-SJK |
0.10 kg (0.22 lb) |
N/A |
6.60 W |
SIC-D4G-CNDE-SJK |
0.10 kg (0.22 lb) |
N/A |
4.20 W |
RT-SIC-4G-CAT6 |
0.15 kg (0.33 lb) |
2.79 W |
4.80 W |
RT-SIC-5G |
0.25 kg (0.55 lb) |
1.32 W |
7.60 W |
RT-SIC-5G-CN |
0.25 kg (0.55 lb) |
N/A |
10.30 W |
MIM-1ATM-OC3 |
N/A |
N/A |
5.80 W |
HMIM-8GSW |
0.70 kg (1.54 lb) |
N/A |
12.00 W |
HMIM-24GSW |
1.00 kg (2.20 lb) |
4.76 W |
22.40 W |
HMIM-24GSW-PoE |
N/A |
N/A |
22.40 W |
HMIM-2GEE |
0.60 kg (1.32 lb) |
N/A |
6.70 W |
HMIM-4GEE |
0.70 kg (1.54 lb) |
N/A |
6.90 W |
HMIM-8GEE |
0.60 kg (1.32 lb) |
10.20 W |
11.20 W |
RT-HMIM-4GEE-V2 |
0.65 kg (1.43 lb) |
8.97 W |
9.10 W |
RT-HMIM-8GEE-V2 |
0.70 kg (1.54 lb) |
9.12 W |
9.40 W |
RT-HMIM-4GEE-V2-G |
0.65 kg (1.43 lb) |
N/A |
12.00 W |
RT-HMIM-8GEE-V2-G |
0.70 kg (1.54 lb) |
N/A |
12.00 W |
HMIM-2GEF |
0.70 kg (1.54 lb) |
N/A |
6.70 W |
HMIM-4GEF |
0.70 kg (1.54 lb) |
N/A |
6.90 W |
HMIM-8GEF |
0.60 kg (1.32 lb) |
N/A |
11.20 W |
RT-HMIM-4GEF-V2 |
0.65 kg (1.43 lb) |
8.97 W |
9.10 W |
RT-HMIM-8GEF-V2 |
0.70 kg (1.54 lb) |
13.56 W |
13.70 W |
HMIM-8GSWF |
0.60 kg (1.32 lb) |
N/A |
22.00 W |
RT-HMIM-4XP |
0.70 kg (1.54 lb) |
4.73 W |
5.10 W |
HMIM-1ATM-OC3 |
N/A |
N/A |
5.80 W |
HMIM-1POS |
0.50 kg (1.10 lb) |
N/A |
5.10 W |
RT-HMIM-2POS-STM1 |
0.70 kg (1.54 lb) |
N/A |
17.80 W |
RT-HMIM-4POS-STM1/4 |
0.70 kg (1.54 lb) |
N/A |
17.80 W |
HMIM-1CPOS |
0.70 kg (1.54 lb) |
N/A |
10.00 W |
HMIM-2CPOS |
0.60 kg (1.32 lb) |
N/A |
11.50 W |
HMIM-1E1 |
N/A |
N/A |
4.50 W |
HMIM-2E1 |
N/A |
N/A |
4.61 W |
HMIM-4E1 |
N/A |
N/A |
4.71 W |
HMIM-1E1-F |
N/A |
N/A |
4.50 W |
HMIM-2E1-F |
N/A |
N/A |
4.61 W |
HMIM-4E1-F |
N/A |
N/A |
4.71 W |
HMIM-8E1(75) |
N/A |
N/A |
4.90 W |
HMIM-8E1(75)-F |
N/A |
N/A |
4.90 W |
RT-HMIM-2E1-V3 |
0.65 kg (1.43 lb) |
4.28 W |
4.30 W |
RT-HMIM-4E1-V3 |
0.65 kg (1.43 lb) |
4.42 W |
4.60 W |
RT-HMIM-8E1-V3 |
0.70 kg (1.54 lb) |
4.60 W |
4.90 W |
HMIM-2T1 |
N/A |
N/A |
5.10 W |
HMIM-4T1-F |
N/A |
N/A |
5.30 W |
HMIM-2E1T1 |
0.60 kg (1.32 lb) |
N/A |
5.70 W |
HMIM-4E1T1 |
0.60 kg (1.32 lb) |
N/A |
5.70 W |
HMIM-8E1T1 |
0.60 kg (1.32 lb) |
N/A |
5.70 W |
HMIM-2E1T1-F |
0.70 kg (1.54 lb) |
N/A |
5.70 W |
HMIM-4E1T1-F |
0.70 kg (1.54 lb) |
N/A |
5.70 W |
HMIM-8E1T1-F |
0.60 kg (1.32 lb) |
N/A |
5.70 W |
HMIM-1CE3 |
N/A |
N/A |
11.30 W |
HMIM-2SAE |
N/A |
N/A |
6.71 W |
HMIM-4SAE |
N/A |
N/A |
7.00 W |
HMIM-8SAE |
N/A |
N/A |
8.00 W |
RT-HMIM-4SAE-V2 |
0.65 kg (1.43 lb) |
1.56 W |
4.20 W |
RT-HMIM-8SAE-V2 |
0.70 kg (1.54 lb) |
1.80 W |
6.00 W |
HMIM-8ASE |
N/A |
N/A |
4.00 W |
HMIM-16ASE |
0.60 kg (1.32 lb) |
N/A |
5.00 W |
RT-HMIM-8ASE-V2 |
0.70 kg (1.54 lb) |
N/A |
3.00 W |
RT-HMIM-16ASE-V2 |
0.85 kg (1.87 lb) |
3.00 W |
3.10 W |
HMIM-1E1POS |
1.00 kg (2.20 lb) |
N/A |
21.60 W |
HMIM-16FXS |
N/A |
N/A |
21.19 W |
HMIM-8FXS8FXO |
N/A |
N/A |
15.22 W |
HMIM-2VE1 |
0.60 kg (1.32 lb) |
N/A |
10.80 W |
HMIM-2VT1 |
N/A |
N/A |
10.75 W |
HMIM-1VE1 |
N/A |
N/A |
9.50 W |
HMIM-1VT1 |
N/A |
N/A |
9.50 W |
HMIM-4FXS |
0.50 kg (1.10 lb) |
N/A |
6.30 W |
HMIM-4FXO |
0.60 kg (1.32 lb) |
N/A |
3.50 W |
HMIM-4E&M |
0.60 kg (1.32 lb) |
N/A |
7.20 W |
HMIM-8E&M |
0.85 kg (1.87 lb) |
N/A |
12.00 W |
HMIM-6AM |
N/A |
N/A |
12.00 W |
HMIM-6FCM |
N/A |
N/A |
9.90 W |
HMIM-CNDE-SJK |
0.65 kg (1.43 lb) |
N/A |
6.60 W |
HMIM-Adapter |
N/A |
N/A |
2.00 W |
DHMIM-1DM |
1.80 kg (3.97 lb) |
N/A |
45.00 W |
DHMIM-1E1POS1DM |
1.20 kg (2.65 lb) |
N/A |
58.60 W |
VPM2 512 |
N/A |
N/A |
10.00 W |
VPM2 256 |
N/A |
N/A |
6.12 W |
VPM2 128 |
N/A |
N/A |
5.76 W |
RT-XMIM-8GEE-R |
0.65 kg (1.43 lb) |
5.12 W |
8.80 W |
RT-XMIM-8GEF-R |
0.65 kg (1.43 lb) |
10.00 W |
13.00 W |
RT-XMIM-4XP |
0.75 kg (1.65 lb) |
20.10 W |
23.60 W |
RT-XMIM-1POS |
0.60 kg (1.32 lb) |
8.70 W |
9.70 W |
RT-XMIM-2POS |
0.60 kg (1.32 lb) |
9.76 W |
10.30 W |
RT-XMIM-1CPOS |
0.64 kg (1.41 lb) |
8.80 W |
11.00 W |
RT-XMIM-2E1 |
0.60 kg (1.32 lb) |
4.30 W |
5.00 W |
RT-XMIM-4E1 |
0.65 kg (1.43 lb) |
4.60 W |
5.40 W |
RT-XMIM-8E1 |
0.65 kg (1.43 lb) |
6.44 W |
6.80 W |
RT-XMIM-CNDE-SJK |
0.65 kg (1.43 lb) |
12.00 W |
12.50 W |
RT-SSD-960G |
0.50 kg (1.10 lb) |
9.00 W |
11.00 W |
