H3C MSR5680-X3 Router Installation Guide-6W102
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Install & UpgradeInstallation GuidesH3C MSR5680-X3 Router Installation Guide-6W102
00-Preface
00-Preface 115.48 KB
Preface
This installation guide describes the installation procedure for H3C MSR5680-X3 router. It includes the following topics:
·     Preparing for installation.
·     Installing the device.
·     Installing removable components.
·     Access the device.
·     Replacing removable components.
·     Hardware management and maintenance.
·     Troubleshooting.
This preface includes:
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Wireless terminator unit.
Wireless terminator.
We appreciate your comments.
